[GRASS-SVN] r61467 - grass/branches/develbranch_6/gui/wxpython/xml
Wed Jul 30 22:37:54 PDT 2014
Author: neteler
Date: 2014-07-30 22:37:54 -0700 (Wed, 30 Jul 2014)
New Revision: 61467
   grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
wxGUI: added v.vect.stats to menu (fixes #2384)
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml	2014-07-31 05:35:59 UTC (rev 61466)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml	2014-07-31 05:37:54 UTC (rev 61467)
@@ -2413,6 +2413,13 @@
               <command>v.rast.stats</command>
             </menuitem>
             <menuitem>
+              <label>Update area attributes from vector</label>
+              <help>Count points in areas, calculate statistics from point attributes.</help>
+              <keywords>vector,attribute table,database,univariate statistics,zonal statistics</keywords>
+              <handler>OnMenuCmd</handler>
+              <command>v.vect.stats</command>
+            </menuitem>
+            <menuitem>
               <label>Update point attributes from areas</label>
               <help>Uploads vector values at positions of vector points to the table.</help>
               <keywords>vector,database,attribute table</keywords>
