[GRASS-SVN] r61487 - grass/branches/releasebranch_7_0/gui/wxpython/web_services
svn_grass at osgeo.org
Thu Jul 31 11:50:36 PDT 2014
Author: annakrat
Date: 2014-07-31 11:50:36 -0700 (Thu, 31 Jul 2014)
New Revision: 61487
grass/branches/releasebranch_7_0/gui/wxpython/web_services/dialogs.py
grass/branches/releasebranch_7_0/gui/wxpython/web_services/widgets.py
wxGUI/wms: backport r61306, r61485, r61486 from trunk, fixes for Mac and adding display region export
Modified: grass/branches/releasebranch_7_0/gui/wxpython/web_services/dialogs.py
--- grass/branches/releasebranch_7_0/gui/wxpython/web_services/dialogs.py 2014-07-31 18:40:08 UTC (rev 61486)
+++ grass/branches/releasebranch_7_0/gui/wxpython/web_services/dialogs.py 2014-07-31 18:50:36 UTC (rev 61487)
@@ -451,7 +451,7 @@
self.active_ws_panel = self.ws_panels[ws]['panel']
self.active_ws_panel.Show()
self.SetMaxSize((-1, -1))
- self.Layout()
+ self.active_ws_panel.GetContainingSizer().Layout()
def OnAdvConnPaneChanged(self, event):
"""!Collapse search module box
@@ -795,13 +795,21 @@
size = globalvar.DIALOG_GSELECT_SIZE)
self.regionStBoxLabel = wx.StaticBox(parent = self, id = wx.ID_ANY,
- label = _("Region"))
+ label = " %s " % _("Export region"))
- self.region_types_order = ['comp', 'named']
+ self.region_types_order = ['display', 'comp', 'named']
self.region_types = {}
- #self.region_types['map_display'] = wx.RadioButton(parent = self, id = wx.ID_ANY, label = 'Map display', style = wx.RB_GROUP )
- self.region_types['comp'] = wx.RadioButton(parent = self, id = wx.ID_ANY, label = 'Computational region')
- self.region_types['named'] = wx.RadioButton(parent = self, id = wx.ID_ANY, label = 'Named region')
+ self.region_types['display'] = wx.RadioButton(parent=self, label=_("Map display"),
+ style=wx.RB_GROUP)
+ self.region_types['comp'] = wx.RadioButton(parent=self, label=_("Computational region"))
+ self.region_types['named'] = wx.RadioButton(parent=self, label=_("Named region"))
+ self.region_types['display'].SetToolTipString(_("Extent and resolution"
+ " are based on Map Display geometry."))
+ self.region_types['comp'].SetToolTipString(_("Extent and resolution"
+ " are based on computational region."))
+ self.region_types['named'].SetToolTipString(_("Extent and resolution"
+ " are based on named region."))
+ self.region_types['display'].SetValue(True) # set default as map display
self.overwrite = wx.CheckBox(parent = self, id = wx.ID_ANY,
label = _("Overwrite existing raster map"))
@@ -816,10 +824,10 @@
# buttons
self.btn_close = wx.Button(parent = self, id = wx.ID_CLOSE)
self.btn_close.SetToolTipString(_("Close dialog"))
- self.btn_ok = wx.Button(parent = self, id = wx.ID_ANY, label = _("&Save layer"))
- self.btn_ok.SetToolTipString(_("Save web service layer as raster map"))
+ self.btn_ok = wx.Button(parent=self, id=wx.ID_OK, label=_("&Save layer"))
+ self.btn_ok.SetToolTipString(_("Save web service layer as raster map"))
# statusbar
self.statusbar = wx.StatusBar(parent = self, id = wx.ID_ANY)
@@ -827,7 +835,7 @@
def _layout(self):
- border = wx.BoxSizer(wx.VERTICAL)
+ self._border = wx.BoxSizer(wx.VERTICAL)
dialogSizer = wx.BoxSizer(wx.VERTICAL)
regionSizer = wx.BoxSizer(wx.HORIZONTAL)
@@ -835,13 +843,11 @@
dialogSizer.Add(item = self._addSelectSizer(title = self.labels['output'],
sel = self.params['output']))
- dialogSizer.Add(item = self.overwrite)
regionSizer = wx.StaticBoxSizer(self.regionStBoxLabel, wx.VERTICAL)
regionTypeSizer = wx.BoxSizer(wx.HORIZONTAL)
for r_type in self.region_types_order:
- regionTypeSizer.Add(item = self.region_types[r_type])
+ regionTypeSizer.Add(item=self.region_types[r_type], flag=wx.RIGHT, border=8)
regionSizer.Add(item = regionTypeSizer)
@@ -852,6 +858,8 @@
dialogSizer.Add(item = regionSizer, flag = wx.EXPAND)
+ dialogSizer.Add(item=self.overwrite, flag=wx.TOP, border=10)
# buttons
self.btnsizer = wx.BoxSizer(orient = wx.HORIZONTAL)
@@ -866,12 +874,12 @@
dialogSizer.Add(item = self.btnsizer, proportion = 0,
flag = wx.ALIGN_CENTER)
- border.Add(item = dialogSizer, proportion = 0,
- flag = wx.ALL, border = 5)
+ self._border.Add(item=dialogSizer, proportion=0,
+ flag=wx.ALL, border=5)
- border.Add(item = self.statusbar, proportion = 0)
+ self._border.Add(item=self.statusbar, proportion=0)
- self.SetSizer(border)
+ self.SetSizer(self._border)
self.Layout()
self.Fit()
@@ -911,14 +919,13 @@
event.Skip()
def OnRegionType(self, event):
selected = event.GetEventObject()
if selected == self.region_types['named']:
self.named_reg_panel.Show()
else:
self.named_reg_panel.Hide()
- self.Layout()
+ self._border.Layout()
self.Fit()
def OnSave(self, event):
@@ -959,13 +966,12 @@
if len(reg_spl) > 1:
reg_mapset = reg_spl[1]
- if self.region_types['comp'].GetValue() == 1:
- pass
- elif grass.find_file(reg_spl[0], 'region', reg_mapset)['fullname']:
- msg = _('Region <%s> does not exists.' % self.params['region'].GetValue())
- GWarning(parent = self,
- message = msg)
- return
+ if self.region_types['named'].GetValue():
+ if not grass.find_file(reg_spl[0], 'windows', reg_mapset)['fullname']:
+ msg = _('Region <%s> does not exist.' % self.params['region'].GetValue())
+ GWarning(parent=self,
+ message=msg)
+ return
# create r.in.wms command
cmd = ('r.in.wms', deepcopy(self.cmd[1]))
@@ -978,13 +984,17 @@
if self.overwrite.IsChecked():
cmd[1]['overwrite'] = True
- if self.region_types['named'].GetValue() == 1:
+ env = os.environ.copy()
cmd[1]['region'] = region
+ elif self.region_types['display'].GetValue():
+ region = self._giface.GetMapWindow().GetMap().SetRegion()
+ env['GRASS_REGION'] = region
cmdList = CmdTupleToList(cmd)
self.currentPid = self.thread.GetId()
- self.thread.RunCmd(cmdList, stderr = self.cmdStdErr)
+ self.thread.RunCmd(cmdList, env=env, stderr=self.cmdStdErr)
self.statusbar.SetStatusText(_("Downloading data..."))
Modified: grass/branches/releasebranch_7_0/gui/wxpython/web_services/widgets.py
--- grass/branches/releasebranch_7_0/gui/wxpython/web_services/widgets.py 2014-07-31 18:40:08 UTC (rev 61486)
+++ grass/branches/releasebranch_7_0/gui/wxpython/web_services/widgets.py 2014-07-31 18:50:36 UTC (rev 61487)
@@ -118,6 +118,8 @@
self.cmd_thread = CmdThread(self)
self.cap_file = grass.tempfile()
+ reqDataBox = wx.StaticBox(parent=self, label=_(" Requested data settings "))
+ self._nb_sizer = wx.StaticBoxSizer(reqDataBox, wx.VERTICAL)
self.notebook = GNotebook(parent = self,
style = FN.FNB_FANCY_TABS | FN.FNB_NO_X_BUTTON)
@@ -136,12 +138,8 @@
grass.try_remove(self.cap_file)
def _layout(self):
- reqDataBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
- label = _(" Requested data settings "))
- sizer = wx.StaticBoxSizer(reqDataBox, wx.VERTICAL)
- sizer.Add(item = self.notebook, proportion = 1,
- flag = wx.EXPAND)
- self.SetSizer(sizer)
+ self._nb_sizer.Add(item=self.notebook, proportion=1, flag=wx.EXPAND)
+ self.SetSizer(self._nb_sizer)
def _requestPage(self):
"""!Create request page"""
