[GRASS-SVN] r61490 - grass/trunk/lib/python/gunittest
svn_grass at osgeo.org
Thu Jul 31 13:34:44 PDT 2014
Author: wenzeslaus
Date: 2014-07-31 13:34:44 -0700 (Thu, 31 Jul 2014)
New Revision: 61490
Added:
grass/trunk/lib/python/gunittest/multirunner.py
gunittest: Python script to run tests in different locations from outside GRASS session
Added: grass/trunk/lib/python/gunittest/multirunner.py
--- grass/trunk/lib/python/gunittest/multirunner.py (rev 0)
+++ grass/trunk/lib/python/gunittest/multirunner.py 2014-07-31 20:34:44 UTC (rev 61490)
@@ -0,0 +1,116 @@
+# -*- coding: utf-8 -*-
+from __future__ import print_function
+import sys
+import os
+import argparse
+import itertools
+import subprocess
+def main():
+ parser = argparse.ArgumentParser(
+ description='Run tests with new')
+ parser.add_argument('--location', '-l', required=True, action='append',
+ dest='locations', metavar='LOCATION',
+ help='Directories with reports')
+ parser.add_argument('--location-type', '-t', action='append',
+ dest='location_types',
+ default=[], metavar='TYPE',
+ help='Add repeated values to a list',
+ parser.add_argument('--grassbin', required=True,
+ help='Use file timestamp instead of date in test summary')
+ # TODO: rename since every src can be used?
+ parser.add_argument('--grasssrc', required=True,
+ help='GRASS GIS source code (to take tests from)')
+ parser.add_argument('--grassdata', required=True,
+ help='GRASS GIS data base (GISDBASE)')
+ parser.add_argument('--create-main-report',
+ help='Create also main report for all tests',
+ action="store_true", default=False, dest='main_report')
+ args = parser.parse_args()
+ gisdb = args.grassdata
+ locations = args.locations
+ locations_types = args.location_types
+ # TODO: if locations empty or just one we can suppose the same all the time
+ if len(locations) != len(locations_types):
+ print("ERROR: Number of locations and their tags must be the same", file=sys.stderr)
+ return 1
+ main_report = args.main_report
+ grasssrc = args.grasssrc # TODO: can be guessed from dist
+ # TODO: create directory accoring to date and revision and create reports there
+ # some predefined variables, name of the GRASS launch script + location/mapset
+ #grass7bin = 'C:\Program Files (x86)\GRASS GIS 7.0.svn\grass70svn.bat'
+ grass7bin = args.grassbin # TODO: can be used if pressent
+ ########### SOFTWARE
+ # query GRASS 7 itself for its GISBASE
+ # we assume that GRASS GIS' start script is available and in the PATH
+ # the shell=True is here because of MS Windows? (code taken from wiki)
+ startcmd = grass7bin + ' --config path'
+ p = subprocess.Popen(startcmd, shell=True,
+ stdout=subprocess.PIPE, stderr=subprocess.PIPE)
+ out, err = p.communicate()
+ if p.returncode != 0:
+ print("ERROR: Cannot find GRASS GIS 7 start script (%s):\n%s" % (startcmd, err), file=sys.stderr)
+ return 1
+ gisbase = out.strip('\n')
+ # set GISBASE environment variable
+ os.environ['GISBASE'] = gisbase
+ # define GRASS Python environment
+ grass_python_dir = os.path.join(gisbase, "etc", "python")
+ sys.path.append(grass_python_dir)
+ ########### DATA
+ # define GRASS DATABASE
+ # Set GISDBASE environment variable
+ os.environ['GISDBASE'] = gisdb
+ # import GRASS Python package for initialization
+ import grass.script.setup as gsetup
+ # launch session
+ # we need some location and mapset here
+ # TODO: can init work without it or is there some demo location in dist?
+ location = locations[0].split(':')[0]
+ mapset = 'PERMANENT'
+ gsetup.init(gisbase, gisdb, location, mapset)
+ reports = []
+ for location, location_type in itertools.izip(locations, locations_types):
+ # here it is quite a good place to parallelize
+ # including also type to make it unique and preserve it for sure
+ report = 'report_for_' + location + '_' + location_type
+ absreport = os.path.abspath(report)
+ p = subprocess.Popen([sys.executable, '-tt',
+ '-m', 'grass.gunittest.main',
+ '--grassdata', gisdb, '--location', location,
+ '--location-type', location_type,
+ '--output', absreport],
+ cwd=grasssrc)
+ returncode = p.wait()
+ reports.append(report)
+ if main_report:
+ # TODO: solve the path to source code (work now only for grass source code)
+ arguments = [sys.executable, grasssrc + '/lib/python/guittest/' + 'multireport.py', '--timestapms']
+ arguments.extend(reports)
+ p = subprocess.Popen(arguments)
+ if returncode != 0:
+ print("ERROR: Creation of main report failed.", file=sys.stderr)
+ return 1
+ return 0
+if __name__ == '__main__':
+ sys.exit(main())
Property changes on: grass/trunk/lib/python/gunittest/multirunner.py
___________________________________________________________________
Added: svn:mime-type
+ text/x-python
Added: svn:eol-style
+ native
