[GRASS-SVN] r60667 - grass/branches/develbranch_6/vector/v.vol.rst
svn_grass at osgeo.org
Mon Jun 2 05:23:24 PDT 2014
Author: neteler
Date: 2014-06-02 05:23:24 -0700 (Mon, 02 Jun 2014)
New Revision: 60667
grass/branches/develbranch_6/vector/v.vol.rst/main.c
grass/branches/develbranch_6/vector/v.vol.rst/user1.c
v.vol.rst: more messages about maps which are actually created
Modified: grass/branches/develbranch_6/vector/v.vol.rst/main.c
--- grass/branches/develbranch_6/vector/v.vol.rst/main.c 2014-06-02 12:09:49 UTC (rev 60666)
+++ grass/branches/develbranch_6/vector/v.vol.rst/main.c 2014-06-02 12:23:24 UTC (rev 60667)
@@ -531,14 +531,14 @@
if ((data =
data_new(x_orig, y_orig, z_orig, n_rows, n_cols, n_levs, 0)) == NULL)
- G_fatal_error("cannot create octdata");
+ G_fatal_error("Unable to create octdata");
if ((functions =
OT_functions_new(oct_compare, oct_divide_data, oct_add_data,
oct_intersect, oct_division_check,
oct_get_points)) == NULL)
- G_fatal_error("cannot create octfunc");
+ G_fatal_error("Unable to create octfunc");
if ((tree = OT_tree_new(data, NULL, NULL, functions, 0)) == NULL)
- G_fatal_error("cannot create octtree");
+ G_fatal_error("Unable to create octtree");
root = tree;
@@ -547,7 +547,7 @@
if (TESTOUT) {
if ((fd4 = fopen("testout", "w+")) == NULL)
- G_fatal_error("Cannot open testout");
+ G_fatal_error("Unable to open testout");
Vect_set_open_level(1);
@@ -628,7 +628,8 @@
clean_fatal_error
("Not enough disk space--cannot write temp files");
+ } else
+ G_warning("Unable to create cellout raster map without cellinp");
ertot = 0.;
if (per)
fprintf(stderr, "Percent complete: ");
@@ -822,6 +823,8 @@
G_command_history(&hist);
G_write_history(cellout, &hist);
+ G_message(_("Raster map <%s> created"), cellout);
fclose(Tmp_fd_cell);
unlink(Tmp_file_cell);
@@ -860,6 +863,7 @@
db_close_database_shutdown_driver(driver);
Vect_build(&Map);
Vect_close(&Map);
+ G_message(_("Vector map <%s> created"), cvdev);
fprintf(stderr, "\n");
@@ -874,12 +878,12 @@
else
- clean_fatal_error("Interp_call failed!");
+ clean_fatal_error(_("Interpolation failed"));
else
- clean_fatal_error("input failed!");
+ clean_fatal_error(_("Input failed"));
if (fd4 != NULL)
fclose(fd4);
- return 0;
+ return EXIT_SUCCESS;
Modified: grass/branches/develbranch_6/vector/v.vol.rst/user1.c
--- grass/branches/develbranch_6/vector/v.vol.rst/user1.c 2014-06-02 12:09:49 UTC (rev 60666)
+++ grass/branches/develbranch_6/vector/v.vol.rst/user1.c 2014-06-02 12:23:24 UTC (rev 60667)
@@ -467,7 +467,8 @@
if (G3d_closeCell(cf1) == 0) {
sprintf(buff, "Error closing output file %s ", outz);
clean_fatal_error(buff);
+ } else
+ G_message(_("3D raster map <%s> created"), outz);
/*** Write out the gradient results ***/
@@ -518,7 +519,8 @@
if (G3d_closeCell(cf2) == 0) {
sprintf(buff, "Error closing output file %s ", gradient);
+ } else
+ G_message(_("3D raster map <%s> created"), gradient);
/*** Write out aspect1 results ***/
@@ -569,7 +571,8 @@
if (G3d_closeCell(cf3) == 0) {
sprintf(buff, "Error closing output file %s ", aspect1);
+ } else
+ G_message(_("3D raster map <%s> created"), aspect1);
/*** Write out aspect2 results ***/
@@ -620,7 +623,8 @@
if (G3d_closeCell(cf4) == 0) {
sprintf(buff, "Error closing output file %s ", aspect2);
+ } else
+ G_message(_("3D raster map <%s> created"), aspect2);
/*** Write out ncurv results ***/
@@ -671,7 +675,8 @@
if (G3d_closeCell(cf5) == 0) {
sprintf(buff, "Error closing output file %s ", ncurv);
+ } else
+ G_message(_("3D raster map <%s> created"), ncurv);
/*** Write out gcurv results ***/
@@ -722,7 +727,8 @@
if (G3d_closeCell(cf6) == 0) {
sprintf(buff, "Error closing output file %s ", gcurv);
+ } else
+ G_message(_("3D raster map <%s> created"), gcurv);
/*** Write mcurv results ***/
@@ -773,7 +779,8 @@
if (G3d_closeCell(cf7) == 0) {
sprintf(buff, "Error closing output file %s ", mcurv);
+ } else
+ G_message(_("3D raster map <%s> created"), mcurv);
G_free(data);
