[GRASS-SVN] r60671 - grass/trunk/scripts/v.report
Mon Jun 2 09:40:29 PDT 2014
Author: hcho
Date: 2014-06-02 09:40:29 -0700 (Mon, 02 Jun 2014)
New Revision: 60671
   grass/trunk/scripts/v.report/v.report.py
v.report: tab to spaces
Modified: grass/trunk/scripts/v.report/v.report.py
--- grass/trunk/scripts/v.report/v.report.py	2014-06-02 15:59:27 UTC (rev 60670)
+++ grass/trunk/scripts/v.report/v.report.py	2014-06-02 16:40:29 UTC (rev 60671)
@@ -124,8 +124,8 @@
         records2.sort()
         #make pre-table
-	# len(records1) may not be the same as len(records2) because
-	# v.db.select can return attributes that are not linked to features.
+        # len(records1) may not be the same as len(records2) because
+        # v.db.select can return attributes that are not linked to features.
         records3 = []
         for r2 in records2:
             records3.append(filter(lambda r1: r1[0] == r2[0], records1)[0] + r2[1:])
