[GRASS-SVN] r60673 - sandbox/annakrat/r3.flow
Mon Jun 2 11:40:18 PDT 2014
Author: annakrat
Date: 2014-06-02 11:40:18 -0700 (Mon, 02 Jun 2014)
New Revision: 60673
   sandbox/annakrat/r3.flow/integrate.py
   sandbox/annakrat/r3.flow/r3.flow.py
   sandbox/annakrat/r3.flow/rast3d_functions.py
   sandbox/annakrat/r3.flow/test_interpolation.py
r3.flow: first working version, support for different integration units
Modified: sandbox/annakrat/r3.flow/integrate.py
--- sandbox/annakrat/r3.flow/integrate.py	2014-06-02 17:03:50 UTC (rev 60672)
+++ sandbox/annakrat/r3.flow/integrate.py	2014-06-02 18:40:18 UTC (rev 60673)
@@ -15,36 +15,44 @@
     k4 = [None] * 3
     x, y, z = point[0], point[1], point[2]
     # first
-    velocity = get_velocity(rast3d_region, arrays[0], arrays[1], arrays[2], x, y, z)
+    velocity = get_velocity(rast3d_region, arrays, point)
     if velocity is None:
         return None
     for i in range(3):
         k1[i] = delta_t * velocity[i]
     # second
-                            x + k1[0] / 2, y + k1[1] / 2, z + k1[2] / 2)
+                            (x + k1[0] / 2, y + k1[1] / 2, z + k1[2] / 2))
         return None
     for i in range(3):
         k2[i] = delta_t * velocity[i]
     # third
-                            x + k2[0] / 2, y + k2[1] / 2, z + k2[2] / 2)
+                            (x + k2[0] / 2, y + k2[1] / 2, z + k2[2] / 2))
         return None
     for i in range(3):
         k3[i] = delta_t * velocity[i]
     # fourth
-                            x + k3[0], y + k3[1], z + k3[2])
+    velocity = get_velocity(rast3d_region, arrays, (x + k3[0], y + k3[1], z + k3[2]))
         return None
     for i in range(3):
         k4[i] = delta_t * velocity[i]
-    print k1, k2, k3, k4
     # next point
     next_point = [None] * 3
     for i in range(3):
         next_point[i] = point[i] + k1[i] / 6 + k2[i] / 3 + k3[i] / 3 + k4[i] / 6
     return next_point
+def get_time_step(unit, step, velocity, cell_size):
+    if unit == 'time':
+        return step
+    elif unit == 'length':
+        return step / velocity
+    elif unit == 'cell':
+        return (step * cell_size) / velocity
Modified: sandbox/annakrat/r3.flow/r3.flow.py
--- sandbox/annakrat/r3.flow/r3.flow.py	2014-06-02 17:03:50 UTC (rev 60672)
+++ sandbox/annakrat/r3.flow/r3.flow.py	2014-06-02 18:40:18 UTC (rev 60673)
@@ -35,16 +35,52 @@
 #%option G_OPT_V_OUTPUT
 #% description: Name of vector map of flow lines
 #%end
+#%option
+#% key: unit
+#% type: string
+#% required: no
+#% answer: cell
+#% options: time,length,cell
+#% descriptions: elapsed time,length in map units,length in cells (voxels)
+#% label: Unit of integration step
+#% description: Default unit is cell
+#% gisprompt: Integration
+#%end
+#%option
+#% key: step
+#% type: double
+#% required: no
+#% label: Integration step in selected unit
+#% description: Default step is 0.5 cell
+#%end
+#%option
+#% key: limit
+#% type: integer
+#% required: no
+#% answer: 2000
+#% description: Maximum number of steps
+#%end
+#%flag
+#% key: u
+#% description: Compute upstream flowlines instead of default downstream flowlines
+#%end
+import math
 from grass.script import core as gcore
 from grass.script import array as garray
 from grass.script import raster3d as grast3d
 from grass.pygrass.vector import VectorTopo
 from grass.pygrass.vector.geometry import Line, Point
-from interpolate import integrate_next
+from integrate import integrate_next, get_time_step
+from rast3d_functions import get_velocity, norm
+EPSILON = 1e-7
 def main():
     options, flags = gcore.parser()
@@ -60,9 +96,24 @@
             gcore.fatal(_("Error when reading input 3D raster maps"))
     map_info = grast3d.raster3d_info(v_x)
-    # how to estimate default delta t?
-    delta_T = map_info['nsres'] / map_info['max']
+    # integrating forward means upstream, backward means downstream
+    if flags['u']:
+        direction = 1
+    else:
+        direction = -1
+    limit = int(options['limit'])
+    # see which units to use
+    step = options['step']
+    if step:
+        step = float(step)
+        unit = options['unit']
+    else:
+        unit = 'cell'
+        step = 0.25
+    # cell size is the diagonal
+    cell_size = math.sqrt(map_info['nsres'] ** 2 + map_info['ewres'] ** 2 + map_info['tbres'] ** 2)
     # read seed points
     seeds = []
     inp_seeds = VectorTopo(options['seed_points'])
@@ -77,17 +128,32 @@
     if flowline_vector.exist() and not gcore.overwrite:
         gcore.fatal(_("Vector map <{flowlines}> already exists.").format(flowlines=flowline_vector))
     flowline_vector.open('w')
+    # go through all points and integrate flowline for each
     for seed in seeds:
         line = Line([Point(seed[0], seed[1], seed[2])])
         point = seed
-        while True:
-            point = integrate_next(map_info, velocity, point, delta_T)
+        count = 0
+        while count <= limit:
+            velocity_vector = get_velocity(map_info, velocity, point)
+            if velocity_vector is None:
+                break  # outside region
+            velocity_norm = norm(velocity_vector)
+            if velocity_norm <= EPSILON:
+                break  # zero velocity means end of propagation
+            # convert to time
+            delta_T = get_time_step(unit, step, velocity_norm, cell_size)
+            point = integrate_next(map_info, velocity, point, delta_T * direction)
             if point is None:
-                if len(line) > 1:
-                    flowline_vector.write(line)
                 break
             line.append(Point(point[0], point[1], point[2]))
+            count += 1
+        if len(line) > 1:
+            flowline_vector.write(line)
+            gcore.message(_("Flowline ended after %s steps.") % (count - 1), flag='v')
     flowline_vector.close()
Modified: sandbox/annakrat/r3.flow/rast3d_functions.py
--- sandbox/annakrat/r3.flow/rast3d_functions.py	2014-06-02 17:03:50 UTC (rev 60672)
+++ sandbox/annakrat/r3.flow/rast3d_functions.py	2014-06-02 18:40:18 UTC (rev 60673)
@@ -3,21 +3,21 @@
 @author: Anna Petrasova
+import math
 #from grass.script import raster3d as grast3d
-def get_velocity(rast3d_region, v_x, v_y, v_z, x, y, z):
+def get_velocity(rast3d_region, velocity_arrays, point):
     """Returns tuple of interpolated velocity values
-    in xyz components for a given point"""
-    vel_x = rast3d_get_window_value(rast3d_region, v_x, y, x, z)
-    vel_y = rast3d_get_window_value(rast3d_region, v_y, y, x, z)
-    vel_z = rast3d_get_window_value(rast3d_region, v_z, y, x, z)
+    in xyz components for a given point, or None if outside of region"""
+    return rast3d_trilinear_interpolation(rast3d_region, velocity_arrays,
+                                          point[1], point[0], point[2])
-    if vel_x is None or vel_y is None or vel_z is None:
-        return None
-    return vel_x, vel_y, vel_z
+def norm(vector):
+    return math.sqrt(vector[0] * vector[0] + vector[1] * vector[1] + vector[2] * vector[2])
 # following functions are already in raster3d library, this is simpler Python version
 # except for trilinear interpolation which could be added there.
@@ -43,13 +43,13 @@
     return array[depth][row][col]
-def rast3d_get_window_value(rast3d_region, array, north, east, top):
-    """Returns interpolated value in a point defined by geogr. coordinates"""
-    return rast3d_trilinear_interpolation(rast3d_region, array, north, east, top)
+#def rast3d_get_window_value(rast3d_region, array, north, east, top):
+#    """Returns interpolated value in a point defined by geogr. coordinates"""
+#    return rast3d_trilinear_interpolation(rast3d_region, array, north, east, top)
-def rast3d_trilinear_interpolation(rast3d_region, array, north, east, top):
-    """Linearly interpolates value in a given point from the 8 closest cells
+def rast3d_trilinear_interpolation(rast3d_region, arrays, north, east, top):
+    """Linearly interpolates value of multiple 3D maps in a given point from the 8 closest cells
     based on the centers of cells."""
     reg = rast3d_region
     # find nearest cells
@@ -63,20 +63,22 @@
               (north + reg['nsres'] / 2., east + reg['ewres'] / 2., top + reg['tbres'] / 2.)]
     # get values of the nearest cells
-    values = []
+    array_values = [[] for i in range(len(arrays))]
     for point in points:
         col, row, depth = rast3d_location2coord(reg, *point)
-        value = rast3d_get_value_region(reg, array, col, row, depth)
-        if value is None:
-            values.append(0)
-        else:
-            values.append(value)
+        for i in range(len(arrays)):
+            value = rast3d_get_value_region(reg, arrays[i], col, row, depth)
+            if value is None:
+                array_values[i].append(0)
+            else:
+                array_values[i].append(value)
     # compute weights
     col, row, depth = rast3d_location2coord(reg, north, east, top)
-    if rast3d_get_value_region(reg, array, col, row, depth) is None:
+    # check if we are out of region, any array should work
+    if rast3d_get_value_region(reg, arrays[0], col, row, depth) is None:
         return None
     # hm, is there some more elegant way?
     # x
     temp = east - reg['west'] - col * reg['ewres']
@@ -100,7 +102,10 @@
                x * y * z]
     # weighted of surrounding values
-    value = 0
-    for i in range(len(weights)):
-        value += weights[i] * values[i]
-    return value
+    interpolated_values = []
+    for values in array_values:
+        value = 0
+        for i in range(len(weights)):
+            value += weights[i] * values[i]
+        interpolated_values.append(value)
+    return interpolated_values
Modified: sandbox/annakrat/r3.flow/test_interpolation.py
--- sandbox/annakrat/r3.flow/test_interpolation.py	2014-06-02 17:03:50 UTC (rev 60672)
+++ sandbox/annakrat/r3.flow/test_interpolation.py	2014-06-02 18:40:18 UTC (rev 60673)
@@ -36,12 +36,14 @@
             point = [uniform(self.minim + reg['ewres'] / 2., self.maxim - reg['ewres'] / 2.),
                      uniform(self.minim + reg['nsres'] / 2., self.maxim - reg['nsres'] / 2.),
                      uniform(self.minim + reg['tbres'] / 2., self.maxim - reg['tbres'] / 2.)]
-            tested = rast3d_trilinear_interpolation(reg, rast3d, point[1], point[0], point[2])
+            tested = rast3d_trilinear_interpolation(reg, [rast3d, rast3d, rast3d],
             coordinates = [[(point[2] - 0.5 * reg['tbres'] - self.minim) / reg['tbres']],
                           [(reg['north'] - point[1] - 0.5 * reg['nsres']) / reg['nsres']],
                           [(point[0] - 0.5 * reg['ewres'] - self.minim) / reg['ewres']]]
             reference = ndimage.map_coordinates(rast3d, order=1, coordinates=coordinates)
-            self.assertAlmostEqual(tested, reference, places=4)
+            self.assertAlmostEqual(tested[0], reference, places=4)
+            self.assertAlmostEqual(tested[1], reference, places=4)
     def tearDown(self):
         gcore.run_command('g.remove', rast3d=self.name)
