[GRASS-SVN] r60690 - grass/branches/releasebranch_7_0/gui/wxpython/gui_core
svn_grass at osgeo.org
Tue Jun 3 06:38:48 PDT 2014
Author: annakrat
Date: 2014-06-03 06:38:48 -0700 (Tue, 03 Jun 2014)
New Revision: 60690
grass/branches/releasebranch_7_0/gui/wxpython/gui_core/forms.py
grass/branches/releasebranch_7_0/gui/wxpython/gui_core/widgets.py
wxGUI: backport fixes for #2026
Modified: grass/branches/releasebranch_7_0/gui/wxpython/gui_core/forms.py
--- grass/branches/releasebranch_7_0/gui/wxpython/gui_core/forms.py 2014-06-03 13:36:37 UTC (rev 60689)
+++ grass/branches/releasebranch_7_0/gui/wxpython/gui_core/forms.py 2014-06-03 13:38:48 UTC (rev 60690)
@@ -437,8 +437,9 @@
module_desc = self.task.label + ' ' + self.task.description
else:
module_desc = self.task.description
- self.description = StaticWrapText(parent = self.panel,
- label = module_desc)
+ self.description = StaticWrapText(parent=self.panel,
+ label=module_desc)
topsizer.Add(item = self.description, proportion = 1, border = 5,
flag = wx.ALL | wx.ALIGN_CENTER_VERTICAL | wx.EXPAND)
Modified: grass/branches/releasebranch_7_0/gui/wxpython/gui_core/widgets.py
--- grass/branches/releasebranch_7_0/gui/wxpython/gui_core/widgets.py 2014-06-03 13:36:37 UTC (rev 60689)
+++ grass/branches/releasebranch_7_0/gui/wxpython/gui_core/widgets.py 2014-06-03 13:38:48 UTC (rev 60690)
@@ -40,6 +40,8 @@
import wx
import wx.lib.mixins.listctrl as listmix
import wx.lib.scrolledpanel as SP
+from wx.lib.stattext import GenStaticText
+from wx.lib.wordwrap import wordwrap
import wx.combo
try:
import wx.lib.agw.flatnotebook as FN
@@ -443,36 +445,45 @@
dc.DrawRectangle(0, 0, 2 * size[0] / 5, size[1])
dc.DrawRectangle(3 * size[0] / 5, 0, 2 * size[0] / 5, size[1])
-class StaticWrapText(wx.StaticText):
- """!A Static Text field that wraps its text to fit its width,
- enlarging its height if necessary.
- def __init__(self, parent, id = wx.ID_ANY, label = '', *args, **kwds):
- self.parent = parent
- self.originalLabel = label
- wx.StaticText.__init__(self, parent, id, label = '', *args, **kwds)
- self.SetLabel(label)
- self.Bind(wx.EVT_SIZE, self.OnResize)
+class StaticWrapText(GenStaticText):
+ """!A Static Text widget that wraps its text to fit parents width,
+ enlarging its height if necessary."""
+ def __init__(self, parent, id=wx.ID_ANY, label='', margin=0, *args, **kwds):
+ self._margin = margin
+ self._initialLabel = label
+ self.init = False
+ GenStaticText.__init__(self, parent, id, label, *args, **kwds)
+ self.Bind(wx.EVT_SIZE, self.OnSize)
+ def DoGetBestSize(self):
+ """!Overriden method which reports widget's best size."""
+ if not self.init:
+ self._updateLabel()
+ self.init = True
+ parent = self.GetParent()
+ newExtent = wx.ClientDC(parent).GetMultiLineTextExtent(self.GetLabel())
+ # when starting, width is very small and height is big which creates very high windows
+ if newExtent[0] < newExtent[1]:
+ return (0, 0)
+ return newExtent[:2]
+ def OnSize(self, event):
+ event.Skip()
+ def _updateLabel(self):
+ """!Calculates size of wrapped label"""
+ newLabel = wordwrap(text=self._initialLabel, width=parent.GetSize()[0],
+ dc=wx.ClientDC(parent), breakLongWords=True, margin=self._margin)
+ GenStaticText.SetLabel(self, newLabel)
def SetLabel(self, label):
- self.wrappedSize = None
- self.OnResize(None)
- def OnResize(self, event):
- if not getattr(self, "resizing", False):
- self.resizing = True
- newSize = wx.Size(self.parent.GetSize().width - 50,
- self.GetSize().height)
- if self.wrappedSize != newSize:
- wx.StaticText.SetLabel(self, self.originalLabel)
- self.Wrap(newSize.width)
- self.wrappedSize = newSize
- self.SetSize(self.wrappedSize)
- del self.resizing
class BaseValidator(wx.PyValidator):
def __init__(self):
