[GRASS-SVN] r60693 - grass/trunk/vector/v.out.ogr
Tue Jun 3 12:11:35 PDT 2014
Author: hcho
Date: 2014-06-03 12:11:35 -0700 (Tue, 03 Jun 2014)
New Revision: 60693
   grass/trunk/vector/v.out.ogr/local_proto.h
v.out.ogr: removed unnecessary function prototype
Modified: grass/trunk/vector/v.out.ogr/local_proto.h
--- grass/trunk/vector/v.out.ogr/local_proto.h	2014-06-03 17:57:55 UTC (rev 60692)
+++ grass/trunk/vector/v.out.ogr/local_proto.h	2014-06-03 19:11:35 UTC (rev 60693)
@@ -44,13 +44,6 @@
                  const char **, int, int,
                  int *, int *);
-/* export_lines_3d.c */
-int export_lines_3d(struct Map_info *, int, int, int,
-                    OGRFeatureDefnH, OGRLayerH,
-                    struct field_info *, dbDriver *, int, int *,
-                    const char **, int, int,
-                    int *, int *);
 /* export_areas.c */
 int export_areas(struct Map_info *, int, int, int,
