[GRASS-SVN] r60697 - grass/trunk/lib/python/script
svn_grass at osgeo.org
Tue Jun 3 20:27:35 PDT 2014
Author: wenzeslaus
Date: 2014-06-03 20:27:34 -0700 (Tue, 03 Jun 2014)
New Revision: 60697
grass/trunk/lib/python/script/core.py
pythonlib/script: more doctests for core
Modified: grass/trunk/lib/python/script/core.py
--- grass/trunk/lib/python/script/core.py 2014-06-04 02:40:24 UTC (rev 60696)
+++ grass/trunk/lib/python/script/core.py 2014-06-04 03:27:34 UTC (rev 60697)
@@ -659,6 +659,17 @@
"""!Returns separator from G_OPT_F_SEP appropriately converted
to character.
+ >>> separator('pipe')
+ >>> separator('comma')
+ If the string does not match any of the spearator keywords,
+ it is returned as is:
+ >>> separator(', ')
@param separator character or separator keyword
@return separator character
@@ -674,7 +685,6 @@
elif sep == "newline" or sep == "\\n":
return "\n"
return sep
# interface to g.tempfile
@@ -733,11 +743,17 @@
"""!Parse a string into a dictionary, where entries are separated
by newlines and the key and value are separated by `sep' (default: `=')
+ >>> parse_key_val('min=20\\nmax=50') == {'min': '20', 'max': '50'}
+ True
+ >>> parse_key_val('min=20\\nmax=50',
+ ... val_type=float) == {'min': 20, 'max': 50}
+ True
@param s string to be parsed
@param sep key/value separator
@param dflt default value to be used
@param val_type value type (None for no cast)
- @param vsep vertical separator (default os.linesep)
+ @param vsep vertical separator (default is Python 'universal newlines' approach)
@return parsed input (dictionary of keys/values)
@@ -1436,20 +1452,23 @@
name = fs[0]
return name
def find_program(pgm, *args):
"""!Attempt to run a program, with optional arguments.
You must call the program in a way that will return a successful
exit code. For GRASS modules this means you need to pass it some
valid CLI option, like "--help". For other programs a common
- valid do-little option is "--version".
+ valid do-little option is usually "--version".
Example:
@code
- >>> grass.find_program('r.sun', 'help')
+ >>> find_program('r.sun', '--help')
True
- >>> grass.find_program('gdalwarp', '--version')
+ >>> find_program('ls', '--version')
True
@endcode
@param pgm program name
@@ -1461,6 +1480,7 @@
nuldev = file(os.devnull, 'w+')
try:
+ # TODO: the doc or impl is not correct, any return code is accepted
call([pgm] + list(args), stdin = nuldev, stdout = nuldev, stderr = nuldev)
found = True
except:
@@ -1501,6 +1521,11 @@
def float_or_dms(s):
"""!Convert DMS to float.
+ >>> round(float_or_dms('26:45:30'), 5)
+ 26.75833
+ >>> round(float_or_dms('26:0:0.1'), 5)
+ 26.00003
@param s DMS value
@return float value
