[GRASS-SVN] r60730 - sandbox/wenzeslaus/gunittest
Fri Jun 6 14:13:15 PDT 2014
Author: wenzeslaus
Date: 2014-06-06 14:13:15 -0700 (Fri, 06 Jun 2014)
New Revision: 60730
   sandbox/wenzeslaus/gunittest/case.py
gunittest: few experimental lines for basic code coverage (coverage package)
Modified: sandbox/wenzeslaus/gunittest/case.py
--- sandbox/wenzeslaus/gunittest/case.py	2014-06-06 17:46:12 UTC (rev 60729)
+++ sandbox/wenzeslaus/gunittest/case.py	2014-06-06 21:13:15 UTC (rev 60730)
@@ -1,19 +1,48 @@
 # -*- coding: utf-8 -*-
+"""!@package grass.gunittest.case
+ at brief GRASS Python testing framework test case
+(C) 2014 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Vaclav Petras
 import unittest
 from unittest.util import safe_repr
 from .checkers import check_text_ellipsis
 class GrassTestCase(unittest.TestCase):
     def assertLooksLike(self, actual, reference, msg=None):
         self.assert_(isinstance(actual, basestring), (
-                'actual argument is not a string'))
+                     'actual argument is not a string'))
         self.assert_(isinstance(reference, basestring), (
-                'reference argument is not a string'))
+                     'reference argument is not a string'))
         if not check_text_ellipsis(actual=actual, reference=reference):
             standardMsg = self._formatMessage(msg, '"%s" does not correspond with "%s"'
                                                    % (safe_repr(actual),
                                                       safe_repr(reference)))
             self.fail(self._formatMessage(msg, standardMsg))
+# the following lines are for code coverage
+import coverage
+cov = coverage.coverage(omit="*testsuite*")
+cov.start()
+def endcov(cov):
+    cov.stop()
+    cov.html_report(directory='testcodecoverage')
+import atexit
+atexit.register(endcov, cov)
