[GRASS-SVN] r60733 - grass/trunk/lib/python/temporal
Fri Jun 6 15:31:09 PDT 2014
Author: huhabla
Date: 2014-06-06 15:31:08 -0700 (Fri, 06 Jun 2014)
New Revision: 60733
   grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
   grass/trunk/lib/python/temporal/register.py
   grass/trunk/lib/python/temporal/stds_import.py
Small bugfixes
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py	2014-06-06 22:29:56 UTC (rev 60732)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py	2014-06-06 22:31:08 UTC (rev 60733)
@@ -1775,7 +1775,7 @@
         date_list.append((start, end))
-        self. _update_map_timestamps(maps, date_list, dbif)
+        self._update_map_timestamps(maps, date_list, dbif)
         if connected:
             dbif.close()
Modified: grass/trunk/lib/python/temporal/register.py
--- grass/trunk/lib/python/temporal/register.py	2014-06-06 22:29:56 UTC (rev 60732)
+++ grass/trunk/lib/python/temporal/register.py	2014-06-06 22:31:08 UTC (rev 60733)
@@ -30,7 +30,7 @@
 def register_maps_in_space_time_dataset(
     type, name, maps=None, file=None, start=None,
     end=None, unit=None, increment=None, dbif=None,
-        interval=False, fs="|"):
+        interval=False, fs="|", update_cmd_list=True):
     """!Use this method to register maps in space time datasets.
        Additionally a start time string and an increment string can be
@@ -60,6 +60,8 @@
        @param interval If True, time intervals are created in case the start
                        time and an increment is provided
        @param fs Field separator used in input file
+       @param update_cmd_list If is True, the command that was invoking this process
+                              will be written to the process history
     start_time_in_file = False
     end_time_in_file = False
@@ -318,7 +320,8 @@
     if name and map_object_list:
         msgr.message(_("Update space time raster dataset"))
         sp.update_from_registered_maps(dbif)
-        sp.update_command_string(dbif=dbif)
+        if update_cmd_list is True:
+            sp.update_command_string(dbif=dbif)
     # Update affected datasets
     if datatsets_to_modify:
Modified: grass/trunk/lib/python/temporal/stds_import.py
--- grass/trunk/lib/python/temporal/stds_import.py	2014-06-06 22:29:56 UTC (rev 60732)
+++ grass/trunk/lib/python/temporal/stds_import.py	2014-06-06 22:31:08 UTC (rev 60733)
@@ -442,7 +442,8 @@
             type=sp.get_new_map_instance(None).get_type(),
             name=output, file=new_list_file_name, start="file",
-            end="file", unit=relative_time_unit, dbif=None, fs=fs)
+            end="file", unit=relative_time_unit, dbif=None, fs=fs,
+            update_cmd_list=False)
         os.chdir(old_cwd)
     except:
