[GRASS-SVN] r60736 - in grass/branches/releasebranch_7_0: include/vect lib/vector/Vlib
svn_grass at osgeo.org
Sun Jun 8 01:27:30 PDT 2014
Author: martinl
Date: 2014-06-08 01:27:30 -0700 (Sun, 08 Jun 2014)
New Revision: 60736
grass/branches/releasebranch_7_0/include/vect/dig_structs.h
grass/branches/releasebranch_7_0/lib/vector/Vlib/close_pg.c
grass/branches/releasebranch_7_0/lib/vector/Vlib/write_pg.c
vlib/pg: add field_info to Format_info_pg struct
(merge r60561 from trunk)
Modified: grass/branches/releasebranch_7_0/include/vect/dig_structs.h
--- grass/branches/releasebranch_7_0/include/vect/dig_structs.h 2014-06-07 22:20:09 UTC (rev 60735)
+++ grass/branches/releasebranch_7_0/include/vect/dig_structs.h 2014-06-08 08:27:30 UTC (rev 60736)
@@ -642,6 +642,7 @@
V1_close_pg().
dbDriver *dbdriver;
+ struct field_info *fi;
\brief Start/Finish transaction
Modified: grass/branches/releasebranch_7_0/lib/vector/Vlib/close_pg.c
--- grass/branches/releasebranch_7_0/lib/vector/Vlib/close_pg.c 2014-06-07 22:20:09 UTC (rev 60735)
+++ grass/branches/releasebranch_7_0/lib/vector/Vlib/close_pg.c 2014-06-08 08:27:30 UTC (rev 60736)
@@ -85,6 +85,9 @@
G_free(pg_info->geom_column);
G_free(pg_info->fid_column);
+ if (pg_info->fi)
+ G_free(pg_info->fi);
if (pg_info->toposchema_name)
G_free(pg_info->toposchema_name);
Modified: grass/branches/releasebranch_7_0/lib/vector/Vlib/write_pg.c
--- grass/branches/releasebranch_7_0/lib/vector/Vlib/write_pg.c 2014-06-07 22:20:09 UTC (rev 60735)
+++ grass/branches/releasebranch_7_0/lib/vector/Vlib/write_pg.c 2014-06-08 08:27:30 UTC (rev 60736)
@@ -11,7 +11,7 @@
\todo function to delete corresponding entry in fidx
\todo PostGIS version of V2__add_area_cats_to_cidx_nat
- (C) 2012-2013 by Martin Landa, and the GRASS Development Team
+ (C) 2012-2014 by Martin Landa, and the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
@@ -38,7 +38,7 @@
#define USE_TOPO_STMT 0
-static int create_table(struct Format_info_pg *, const struct field_info *);
+static int create_table(struct Format_info_pg *);
static int check_schema(const struct Format_info_pg *);
static int create_topo_schema(struct Format_info_pg *, int);
static int create_pg_layer(struct Map_info *, int);
@@ -58,9 +58,8 @@
static char *line_to_wkb(struct Format_info_pg *, const struct line_pnts **,
int, int, int);
static int write_feature(struct Map_info *, int, int,
- const struct line_pnts **, int, int, const struct field_info *);
-static char *build_insert_stmt(const struct Format_info_pg *, const char *, int,
- int, const struct field_info *);
+ const struct line_pnts **, int, int);
+static char *build_insert_stmt(const struct Format_info_pg *, const char *, int, int);
static int insert_topo_element(struct Map_info *, int, int, const char *);
static int update_next_edge(struct Map_info*, int, int);
static int delete_face(const struct Map_info *, int);
@@ -70,7 +69,7 @@
static int delete_line_from_topo_pg(struct Map_info *, int, int, const struct line_pnts *);
static int set_constraint_to_deferrable(struct Format_info_pg *, const char *, const char *,
const char *, const char *, const char *);
-static dbDriver *open_db(struct Format_info_pg *, const struct field_info *);
+static dbDriver *open_db(struct Format_info_pg *);
#endif
static struct line_pnts *Points;
@@ -574,17 +573,18 @@
\brief Create new feature table
\param pg_info pointer to Format_info_pg
- \param Fi pointer to field_info
\return -1 on error
\return 0 on success
-int create_table(struct Format_info_pg *pg_info, const struct field_info *Fi)
+int create_table(struct Format_info_pg *pg_info)
int spatial_index, primary_key;
char stmt[DB_SQL_MAX];
char *geom_type, *def_file;
+ struct field_info *Fi;
PGresult *result;
def_file = getenv("GRASS_VECTOR_PGFILE");
@@ -630,6 +630,8 @@
pg_info->schema_name, pg_info->table_name, pg_info->fid_column,
primary_key ? " PRIMARY KEY" : "", GV_KEY_COLUMN);
+ Fi = pg_info->fi;
if (Fi) {
/* append attributes */
int col, ncols, sqltype, length;
@@ -644,7 +646,7 @@
db_init_string(&dbtable_name);
- driver = open_db(pg_info, Fi);
+ driver = open_db(pg_info);
if (driver == NULL)
return -1;
@@ -795,6 +797,11 @@
PGresult *result;
+ if (!pg_info->conn || !pg_info->table_name) {
+ G_warning(_("No connection defined"));
+ return -1;
/* add geometry column */
sprintf(stmt, "SELECT nspname FROM pg_namespace");
G_debug(2, "SQL: %s", stmt);
@@ -1049,10 +1056,7 @@
int ndblinks;
struct Format_info_pg *pg_info;
- struct field_info *Fi;
- Fi = NULL;
pg_info = &(Map->fInfo.pg);
if (!pg_info->conninfo) {
G_warning(_("Connection string not defined"));
@@ -1096,11 +1100,12 @@
/* create new PostGIS table */
ndblinks = Vect_get_num_dblinks(Map);
if (ndblinks > 0) {
- Fi = Vect_get_dblink(Map, 0);
- if (Fi) {
+ pg_info->fi = Vect_get_dblink(Map, 0); /* TODO: support more layers */
+ if (pg_info->fi) {
if (ndblinks > 1)
G_warning(_("More layers defined, using driver <%s> and "
- "database <%s>"), Fi->driver, Fi->database);
+ "database <%s>"),
+ pg_info->fi->driver, pg_info->fi->database);
else {
G_warning(_("Database connection not defined. "
@@ -1109,7 +1114,7 @@
/* create new feature table */
- if (create_table(pg_info, Fi) == -1) {
+ if (create_table(pg_info) == -1) {
G_warning(_("Unable to create new PostGIS feature table"));
return -1;
@@ -1129,9 +1134,6 @@
- if (Fi)
- G_free(Fi);
return 0;
@@ -1185,7 +1187,6 @@
SF_FeatureType sf_type;
struct Format_info_offset *offset_info;
@@ -1212,17 +1213,10 @@
/* get category & check for attributes */
- Fi = NULL;
cat = -1;
if (cats->n_cats > 0) {
- int field;
+ int field = pg_info->fi->number;
- field = cats->field[0]; /* we assume only one layer defined */
- if (Vect_get_num_dblinks(Map) > 0) {
- /* check for attributes */
- Fi = Vect_get_field(Map, field);
if (!Vect_cat_get(cats, field, &cat))
G_warning(_("No category defined for layer %d"), field);
if (cats->n_cats > 1) {
@@ -1288,7 +1282,7 @@
/* write feature's geometry and fid */
- if (-1 == write_feature(Map, -1, type, points, nparts, cat, Fi)) {
+ if (-1 == write_feature(Map, -1, type, points, nparts, cat)) {
Vect__execute_pg(pg_info->conn, "ROLLBACK");
return -1;
@@ -1332,9 +1326,9 @@
int line, cat, line_id;
struct Plus_head *plus;
plus = &(Map->plus);
@@ -1371,22 +1365,19 @@
G_debug(3, "write_line_pg(): type = %d n_points = %d",
type, points->n_points);
- Fi = NULL; /* no attributes to be written */
+ Fi = pg_info->fi;
cat = -1;
if (cats && cats->n_cats > 0) {
- if (Fi) {
- if (!pg_info->dbdriver)
- open_db(pg_info, Fi);
- if (!Vect_cat_get(cats, Fi->number, &cat))
- G_warning(_("No category defined for layer %d"), Fi->number);
- if (cats->n_cats > 1) {
- G_warning(_("Feature has more categories, using "
- "category %d (from layer %d)"),
- cat, cats->field[0]);
+ if (Fi) {
+ if (!pg_info->dbdriver)
+ open_db(pg_info);
+ if (!Vect_cat_get(cats, Fi->number, &cat))
+ G_warning(_("No category defined for layer %d"), Fi->number);
+ if (cats->n_cats > 1) {
+ G_warning(_("Feature has more categories, using "
+ "category %d (from layer %d)"),
+ cat, cats->field[0]);
/* assume layer=1 */
@@ -1420,7 +1411,7 @@
- feature table for simple features
- feature table and topo schema for topological access
- line_id = write_feature(Map, line, type, &points, 1, cat, Fi);
+ line_id = write_feature(Map, line, type, &points, 1, cat);
if (line_id < 0) {
return -1;
@@ -1841,15 +1832,13 @@
\param points pointer to line_pnts struct
\param nparts number of parts (rings for polygon)
\param cat category number (-1 for no category)
- \param Fi pointer to field_info (attributes to copy, NULL for no attributes)
\return topo_id for PostGIS Topology
\return 0 for simple features access
\return -1 on error
int write_feature(struct Map_info *Map, int line, int type,
- const struct line_pnts **points, int nparts,
- int cat, const struct field_info *Fi)
+ const struct line_pnts **points, int nparts, int cat)
int with_z, topo_id;
char *stmt, *geom_data;
@@ -1900,7 +1889,7 @@
/* build INSERT statement
simple feature geometry + attributes
- stmt = build_insert_stmt(pg_info, geom_data, topo_id, cat, Fi);
+ stmt = build_insert_stmt(pg_info, geom_data, topo_id, cat);
/* stmt can NULL when writing PostGIS topology with no attributes
* attached */
@@ -1934,13 +1923,14 @@
\return allocated string with INSERT statement
char *build_insert_stmt(const struct Format_info_pg *pg_info,
- const char *geom_data, int topo_id,
+ const char *geom_data, int topo_id, int cat)
int topogeom_type;
char *stmt, buf[DB_SQL_MAX];
topogeom_type = -1;
if (pg_info->toposchema_name) {
switch (pg_info->feature_type) {
@@ -1959,6 +1949,8 @@
+ Fi = pg_info->fi;
stmt = NULL;
if (Fi && cat > -1) {
/* write attributes (simple features and topology elements) */
@@ -2775,8 +2767,7 @@
Vect_reset_line(Points);
Vect_append_point(Points, x, y, z);
- write_feature(Map, node, GV_POINT, (const struct line_pnts **) &Points, 1,
- -1, NULL);
+ write_feature(Map, node, GV_POINT, (const struct line_pnts **) &Points, 1, -1);
@@ -2872,17 +2863,20 @@
\brief Open database connection with attribute table
\param pg_info pointer to Format_info_pg struct
- \param Fi pointer to field_info struct
\return pointer to dbDriver on succes
\return NULL on failure
-dbDriver *open_db(struct Format_info_pg *pg_info, const struct field_info *Fi) {
+dbDriver *open_db(struct Format_info_pg *pg_info) {
dbDriver *driver;
dbHandle handle;
db_init_handle(&handle);
+ Fi = pg_info->fi;
pg_info->dbdriver = driver = db_start_driver(Fi->driver);
if (!driver) {
G_warning(_("Unable to start driver <%s>"), Fi->driver);
