[GRASS-SVN] r60751 - grass/trunk/general/g.mlist
svn_grass at osgeo.org
Sun Jun 8 05:44:59 PDT 2014
Author: hcho
Date: 2014-06-08 05:44:59 -0700 (Sun, 08 Jun 2014)
New Revision: 60751
grass/trunk/general/g.mlist/g.mlist.html
grass/trunk/general/g.mlist/main.c
g.mlist: changed mapset=.. to mapset=* for all mapsets
Modified: grass/trunk/general/g.mlist/g.mlist.html
--- grass/trunk/general/g.mlist/g.mlist.html 2014-06-08 12:34:04 UTC (rev 60750)
+++ grass/trunk/general/g.mlist/g.mlist.html 2014-06-08 12:44:59 UTC (rev 60751)
@@ -53,12 +53,12 @@
dmt
</pre></div>
-Similarly <b>mapset</b>=.. (two dots) prints data files from all
+Similarly <b>mapset</b>=* (one asterisk) prints data files from all
available mapsets also including those which are not listed in the
current search path (see <tt>g.mapsets -l</tt>).
<div class="code"><pre>
-g.mlist rast mapset=..
+g.mlist rast mapset=*
raster map(s) available in mapset <landsat>:
lsat5_1987_10
Modified: grass/trunk/general/g.mlist/main.c
--- grass/trunk/general/g.mlist/main.c 2014-06-08 12:34:04 UTC (rev 60750)
+++ grass/trunk/general/g.mlist/main.c 2014-06-08 12:44:59 UTC (rev 60751)
@@ -93,7 +93,7 @@
opt.mapset = G_define_standard_option(G_OPT_M_MAPSET);
opt.mapset->label =
_("Name of mapset to list (default: current search path)");
- opt.mapset->description = _("'.' for current mapset; '..' for all mapsets in location");
+ opt.mapset->description = _("'.' for current mapset; '*' for all mapsets in location");
opt.separator = G_define_standard_option(G_OPT_F_SEP);
opt.separator->answer = "newline";
@@ -208,7 +208,7 @@
mapset = "";
else if (strcmp(mapset, ".") == 0)
mapset = G_mapset(); /* current mapset */
- else if (strcmp(mapset, "..") == 0) {
+ else if (strcmp(mapset, "*") == 0) {
if (flag.pretty->answer || flag.full->answer)
G_fatal_error(_("-%c/-%c and %s=%s are mutually exclusive"),
flag.pretty->key, flag.full->key, opt.mapset->key,
