[GRASS-SVN] r60756 - in	grass/branches/releasebranch_7_0/gui/wxpython: core gui_core	mapswipe
    svn_grass at osgeo.org
    Sun Jun  8 11:58:42 PDT 2014
Author: annakrat
Date: 2014-06-08 11:58:42 -0700 (Sun, 08 Jun 2014)
New Revision: 60756
   grass/branches/releasebranch_7_0/gui/wxpython/core/layerlist.py
   grass/branches/releasebranch_7_0/gui/wxpython/gui_core/simplelmgr.py
   grass/branches/releasebranch_7_0/gui/wxpython/mapswipe/dialogs.py
wxGUI/mapswipe: add support for RGB maps - #2315 (merge from trunk, r60594,r60611,r60753)
Modified: grass/branches/releasebranch_7_0/gui/wxpython/core/layerlist.py
--- grass/branches/releasebranch_7_0/gui/wxpython/core/layerlist.py	2014-06-08 16:41:33 UTC (rev 60755)
+++ grass/branches/releasebranch_7_0/gui/wxpython/core/layerlist.py	2014-06-08 18:58:42 UTC (rev 60756)
@@ -189,10 +189,11 @@
         self._hidden = False
         self._initialized = False
-        self._mapTypes = ['rast', 'vect', 'rast3d']
+        self._mapTypes = ['rast', 'vect', 'rast3d', 'rgb']
         self._internalTypes = {'rast': 'cell',
                                'vect': 'vector',
-                               'rast3d': 'grid3'}
+                               'rast3d': 'grid3',
+                               'rgb': 'rgb'}
     def GetName(self):
         return self._name
@@ -206,7 +207,7 @@
         if not self.hidden:
             fullName = name.split('@')
-            if len(fullName) == 1:
+            if len(fullName) == 1 and self._mapType != 'rgb':  # skip checking rgb maps for now
                 if self._mapType is None:
                     raise ValueError("To set layer name, the type of layer must be specified.")
@@ -361,6 +362,8 @@
             mapType = 'vector'
         elif layer.mapType == 'rast3d':
             mapType = '3d-raster'
+        elif layer.mapType == 'rgb':
+            mapType = 'rgb'
         self._renderer.AddLayer(ltype=mapType, command=layer.cmd,
                                 name=layer.name, active=layer.active,
                                 hidden=False, opacity=layer.opacity,
Modified: grass/branches/releasebranch_7_0/gui/wxpython/gui_core/simplelmgr.py
--- grass/branches/releasebranch_7_0/gui/wxpython/gui_core/simplelmgr.py	2014-06-08 16:41:33 UTC (rev 60755)
+++ grass/branches/releasebranch_7_0/gui/wxpython/gui_core/simplelmgr.py	2014-06-08 18:58:42 UTC (rev 60756)
@@ -33,12 +33,14 @@
 SIMPLE_LMGR_RASTER = 1
 SIMPLE_LMGR_VECTOR = 2
 SIMPLE_LMGR_RASTER3D = 4
-SIMPLE_LMGR_TB_TOP = 8
-SIMPLE_LMGR_TB_BOTTOM = 16
-SIMPLE_LMGR_TB_LEFT = 32
-SIMPLE_LMGR_TB_RIGHT = 64
+SIMPLE_LMGR_RGB = 8
+SIMPLE_LMGR_TB_TOP = 16
+SIMPLE_LMGR_TB_BOTTOM = 32
+SIMPLE_LMGR_TB_LEFT = 64
+SIMPLE_LMGR_TB_RIGHT = 128
 class SimpleLayerManager(wx.Panel):
     """!Simple layer manager class provides similar functionality to
     Layertree, but it's just list, not tree."""
@@ -193,6 +195,15 @@
                                                    completed=(self.GetOptData, layer, ''))
         event.Skip()
+    def OnAddRGB(self, event):
+        """!Opens d.rgb dialog and adds layer.
+        Dummy layer is added first."""
+        cmd = ['d.rgb']
+        layer = self.AddRGB(name='', cmd=cmd, hidden=True, dialog=None)
+        GUI(parent=self, giface=None, modal=self._modal).ParseCommand(cmd=cmd,
+                                                    completed=(self.GetOptData, layer, ''))
+        event.Skip()
     def OnRemove(self, event):
         """!Removes selected layers from list."""
         layers = self._layerList.GetSelectedLayers(activeOnly=False)
@@ -278,6 +289,12 @@
         items = []
         active = []
         selected = []
+        # remove hidden (temporary) layers first
+        for layer in reversed(self._layerList):
+            if layer.hidden:
+                self._layerList.RemoveLayer(layer)
         for layer in self._layerList:
             if layer.opacity < 1:
                 items.append("{name} (opacity {opacity}%)".format(name=layer.name,
@@ -343,6 +360,13 @@
                                             cmd=cmd, hidden=hidden)
         return layer
+    def AddRGB(self, name, cmd, hidden, dialog):
+        """!Ads new vector layer."""
+        layer = self._layerList.AddNewLayer(name=name, mapType='rgb',
+                                            active=True,
+                                            cmd=cmd, hidden=hidden)
+        return layer
     def GetLayerInfo(self, layer, key):
         """!Just for compatibility, should be removed in the future"""
         value = getattr(layer, key)
@@ -396,6 +420,9 @@
         if self._style & SIMPLE_LMGR_RASTER3D:
             data.insert(0, ('addRaster3d', icons['addRast3d'],
                             self.parent.OnAddRast3d))
+        if self._style & SIMPLE_LMGR_RGB:
+            data.insert(0, ('addRGB', icons['addRGB'],
+                            self.parent.OnAddRGB))
         if self._style & SIMPLE_LMGR_VECTOR:
             data.insert(0, ('addVector', BaseIcons['addVect'],
                             self.parent.OnAddVector))
@@ -425,6 +452,7 @@
     'addRast3d': MetaIcon(img='layer-raster3d-add',
                           label=_("Add 3D raster map layer"),
                           desc=_("Add 3D raster map layer")),
+    'addRGB': MetaIcon(img='layer-rgb-add', label=_('Add RGB map layer'))
Modified: grass/branches/releasebranch_7_0/gui/wxpython/mapswipe/dialogs.py
--- grass/branches/releasebranch_7_0/gui/wxpython/mapswipe/dialogs.py	2014-06-08 16:41:33 UTC (rev 60755)
+++ grass/branches/releasebranch_7_0/gui/wxpython/mapswipe/dialogs.py	2014-06-08 18:58:42 UTC (rev 60756)
@@ -28,7 +28,7 @@
 from core.layerlist import LayerList
 from core.settings import UserSettings
 from gui_core.simplelmgr import SimpleLayerManager, SIMPLE_LMGR_RASTER, \
-   SIMPLE_LMGR_VECTOR, SIMPLE_LMGR_TB_LEFT, SIMPLE_LMGR_TB_RIGHT
+   SIMPLE_LMGR_VECTOR, SIMPLE_LMGR_RGB, SIMPLE_LMGR_TB_LEFT, SIMPLE_LMGR_TB_RIGHT
 from grass.pydispatch.signal import Signal
@@ -137,10 +137,10 @@
         sizer = wx.BoxSizer(wx.HORIZONTAL)
         self._firstLmgr = SimpleLayerManager(parent=panel, layerList=self._firstLayerList,
-                                             lmgrStyle=SIMPLE_LMGR_RASTER |
+                                             lmgrStyle=SIMPLE_LMGR_RASTER | SIMPLE_LMGR_RGB |
                                              SIMPLE_LMGR_VECTOR | SIMPLE_LMGR_TB_LEFT)
         self._secondLmgr = SimpleLayerManager(parent=panel, layerList=self._secondLayerList,
                                               SIMPLE_LMGR_VECTOR | SIMPLE_LMGR_TB_RIGHT)
         sizer.Add(self._firstLmgr, proportion=1, flag=wx.EXPAND | wx.ALL, border=5)
         sizer.Add(self._secondLmgr, proportion=1, flag=wx.EXPAND | wx.ALL, border=5)
