[GRASS-SVN] r60764 - grass/trunk/imagery/i.atcorr
Mon Jun 9 02:18:50 PDT 2014
Author: martinl
Date: 2014-06-09 02:18:50 -0700 (Mon, 09 Jun 2014)
New Revision: 60764
Added:
   grass/trunk/imagery/i.atcorr/README
Removed:
   grass/trunk/imagery/i.atcorr/readme
i.atcorr: rename readme back to uppercase
Copied: grass/trunk/imagery/i.atcorr/README (from rev 60763, grass/trunk/imagery/i.atcorr/readme)
--- grass/trunk/imagery/i.atcorr/README	                        (rev 0)
+++ grass/trunk/imagery/i.atcorr/README	2014-06-09 09:18:50 UTC (rev 60764)
@@ -0,0 +1,53 @@
+Adding new band filters (see also Iwave.h):
+ Note: the spectral range is from 250 nm to 4000 nm (see Iwave.h) which is
+   4000-250=3750nm. The step size is (4000-250)/1500=2.5 nm in the ffu.s array.
+ o bands are defined by their discrete filter function
+ o to compute a band position in the 1500 slots of ffu.s array, start
+   with 250nm using 2.5nm increments. The result is the starting index
+   for the spectral band.
+ o 1500 is the number of wavelength spectral description slots.
+   - a 'for' loop fills up the slots with 0
+   - then the ffu.s array is filled with each of the spectral band data
+     one after the other.
+     Example Lsat TM: (435-250) / 2.5 = 74
+ o add filter function to Iwave.cpp, before IWave::equivwl()
+ o add else-if in IWave::parse() in Iwave.cpp
+ o add print strings in Iwave.cpp
+ o add iwave values and signature in Iwave.h
+ o add to GeomCond.cpp and GeomCond.h
+ o add to i.atcorr.html
+Preparation of the Iwave.cpp file code:
+The helper script create_iwave.py can help to interpolate the filter functions
+to the correct step size of 2.5 nm (in case that the filter function data
+are delivered with a different step size).
+The output filter function in a format as needed in the Iwave.cpp file.
+The script create_iwave.py basically needs a .csv file with spectral
+response for each band in a column. The first column has to be the
+wavelength (nm). The first line (and only first) is a header with
+wavelength, followed by band names file name is used for sensor name.
+See for example ./sensors_csv/ikonos.csv.
+Usage
+  create_iwave.py <csv file>
+If generates the filter function as IWave.cpp template from csv file.
+Note: If the spectral response is null for a frequency, leave it empty
+in csv file. Ex.:
+  WL(nm),band 1,band 2,band 3,band 4
+  455,0.93,,,
+  485,0.94,0.00,,
+  545,0.00,0.87,0.00,
+Program will interpolate filter function to 2.5 nm steps
+and output a CPP template file in the IWave format.
Deleted: grass/trunk/imagery/i.atcorr/readme
--- grass/trunk/imagery/i.atcorr/readme	2014-06-09 09:12:09 UTC (rev 60763)
+++ grass/trunk/imagery/i.atcorr/readme	2014-06-09 09:18:50 UTC (rev 60764)
@@ -1,53 +0,0 @@
-Adding new band filters (see also Iwave.h):
- Note: the spectral range is from 250 nm to 4000 nm (see Iwave.h) which is
-   4000-250=3750nm. The step size is (4000-250)/1500=2.5 nm in the ffu.s array.
- o bands are defined by their discrete filter function
- o to compute a band position in the 1500 slots of ffu.s array, start
-   with 250nm using 2.5nm increments. The result is the starting index
-   for the spectral band.
- o 1500 is the number of wavelength spectral description slots.
-   - a 'for' loop fills up the slots with 0
-   - then the ffu.s array is filled with each of the spectral band data
-     one after the other.
-     Example Lsat TM: (435-250) / 2.5 = 74
- o add filter function to Iwave.cpp, before IWave::equivwl()
- o add else-if in IWave::parse() in Iwave.cpp
- o add print strings in Iwave.cpp
- o add iwave values and signature in Iwave.h
- o add to GeomCond.cpp and GeomCond.h
- o add to i.atcorr.html
-Preparation of the Iwave.cpp file code:
-The helper script create_iwave.py can help to interpolate the filter functions
-to the correct step size of 2.5 nm (in case that the filter function data
-are delivered with a different step size).
-The output filter function in a format as needed in the Iwave.cpp file.
-The script create_iwave.py basically needs a .csv file with spectral
-response for each band in a column. The first column has to be the
-wavelength (nm). The first line (and only first) is a header with
-wavelength, followed by band names file name is used for sensor name.
-See for example ./sensors_csv/ikonos.csv.
-Usage
-  create_iwave.py <csv file>
-If generates the filter function as IWave.cpp template from csv file.
-Note: If the spectral response is null for a frequency, leave it empty
-in csv file. Ex.:
-  WL(nm),band 1,band 2,band 3,band 4
-  455,0.93,,,
-  485,0.94,0.00,,
-  545,0.00,0.87,0.00,
-Program will interpolate filter function to 2.5 nm steps
-and output a CPP template file in the IWave format.
