[GRASS-SVN] r60766 - grass/trunk/imagery/i.albedo
Mon Jun 9 02:49:19 PDT 2014
Author: ychemin
Date: 2014-06-09 02:49:19 -0700 (Mon, 09 Jun 2014)
New Revision: 60766
Added:
   grass/trunk/imagery/i.albedo/bb_alb_landsat8.c
   grass/trunk/imagery/i.albedo/i.albedo.html
   grass/trunk/imagery/i.albedo/main.c
Added a weighted average function for Landsat 8
Added: grass/trunk/imagery/i.albedo/bb_alb_landsat8.c
--- grass/trunk/imagery/i.albedo/bb_alb_landsat8.c	                        (rev 0)
+++ grass/trunk/imagery/i.albedo/bb_alb_landsat8.c	2014-06-09 09:49:19 UTC (rev 60766)
@@ -0,0 +1,16 @@
+/* Broadband albedo Landsat OLI 8
+ * Simple weighted average from band 2 - 7
+ * Temporary until a publication creates an algorithm
+-* chan5 is OLI Band 6 (1.57-1.65)
+ * chan7 is OLI band 7 (2.11-2.29)
+double bb_alb_landsat8(double bluechan, double greenchan, double redchan,
+		      double nirchan, double chan5, double chan7)
+    double result;
+    result =
+	(0.06 * bluechan + 0.06 * greenchan + 0.03 * redchan +
+	 0.03 * nirchan + 0.08 * chan5 + 0.18 * chan7)/0.44;
+    return result;
Modified: grass/trunk/imagery/i.albedo/i.albedo.html
--- grass/trunk/imagery/i.albedo/i.albedo.html	2014-06-09 09:23:51 UTC (rev 60765)
+++ grass/trunk/imagery/i.albedo/i.albedo.html	2014-06-09 09:49:19 UTC (rev 60766)
@@ -6,6 +6,8 @@
 Aster and calculates the Albedo for those.  This is an precursor to
 r.sun and any Energy-Balance processing.
+Landsat 8 weighted average reflectance (temporary until algorithm is found)
 <h2>NOTES</h2>
 It assumes MODIS product surface reflectance in [0;10000]
@@ -21,6 +23,6 @@
 <h2>AUTHORS</h2>
-Yann Chemin, International Rice Research Institute, The Philippines
+GRASS Development Team
 <p><i>Last changed: $Date$</i>
Modified: grass/trunk/imagery/i.albedo/main.c
--- grass/trunk/imagery/i.albedo/main.c	2014-06-09 09:23:51 UTC (rev 60765)
+++ grass/trunk/imagery/i.albedo/main.c	2014-06-09 09:49:19 UTC (rev 60766)
@@ -25,8 +25,13 @@
 double bb_alb_aster(double greenchan, double nirchan, double swirchan2,
 		    double swirchan3, double swirchan5, double swirchan6);
 double bb_alb_landsat(double bluechan, double greenchan, double redchan,
 		      double nirchan, double chan5, double chan7);
+		      double nirchan, double chan5, double chan7);
 double bb_alb_noaa(double redchan, double nirchan);
 double bb_alb_modis(double redchan, double nirchan, double chan3,
@@ -41,11 +46,11 @@
     struct Option *input, *output;
     struct Flag *flag1, *flag2, *flag3;
     struct Flag *flag4, *flag5, *flag6;
+    struct Flag *flag7;
     struct History history;	/*metadata */
     struct Colors colors;	/*Color rules */
-    /* FMEO Declarations**************** */
     char *name;			/*input raster name */
     char *result;		/*output raster name */
     /*File Descriptors */
@@ -55,7 +60,8 @@
     char **names;
     char **ptr;
     int i = 0;
-    int modis = 0, aster = 0, avhrr = 0, landsat = 0;
+    int modis = 0, aster = 0, avhrr = 0;
+    int landsat = 0, landsat8 = 0;
     void *inrast[MAXFILES];
     unsigned char *outrast;
@@ -112,23 +118,27 @@
     flag3->description = _("Landsat (6 input bands:1,2,3,4,5,7)");
     flag4 = G_define_flag();
-    flag4->key = 'a';
-    flag4->description = _("Aster (6 input bands:1,3,5,6,8,9)");
+    flag4->key = '8';
+    flag4->description = _("Landsat 8 (6 input bands:2,3,4,5,6,7)");
     flag5 = G_define_flag();
-    flag5->key = 'c';
-    flag5->label = _("Agressive mode (Landsat)");
-    flag5->description =
-	_("Albedo dry run to calculate some water to beach/sand/desert stretching, "
-	  "a kind of simple atmospheric correction");
+    flag5->key = 'a';
+    flag5->description = _("Aster (6 input bands:1,3,5,6,8,9)");
     flag6 = G_define_flag();
-    flag6->key = 'd';
-    flag6->label = _("Soft mode (Modis)");
+    flag6->key = 'c';
+    flag6->label = _("Agressive mode (Landsat)");
     flag6->description =
+    flag7 = G_define_flag();
+    flag7->key = 'd';
+    flag7->label = _("Soft mode (Modis)");
+    flag7->description =
+	_("Albedo dry run to calculate some water to beach/sand/desert stretching, "
+	  "a kind of simple atmospheric correction");
     /* FMEO init nfiles */
     nfiles = 1;
@@ -143,7 +153,8 @@
     modis = (flag1->answer);
     avhrr = (flag2->answer);
     landsat = (flag3->answer);
-    aster = (flag4->answer);
+    landsat8 = (flag4->answer);
+    aster = (flag5->answer);
     for (; *ptr != NULL; ptr++) {
 	if (nfiles >= MAXFILES)
@@ -177,7 +188,7 @@
     for (i = 0; i < 100; i++)
 	histogram[i] = 0;
-    if (flag5->answer || flag6->answer) {
+    if (flag6->answer || flag7->answer) {
 	DCELL de;
 	DCELL d[MAXFILES];
@@ -204,17 +215,19 @@
 		if (modis) {
-		    de = bb_alb_modis(d[1], d[2], d[3], d[4], d[5], d[6],
-				      d[7]);
+		    de = bb_alb_modis(d[1],d[2],d[3],d[4],d[5],d[6],d[7]);
 		else if (avhrr) {
-		    de = bb_alb_noaa(d[1], d[2]);
+		    de = bb_alb_noaa(d[1],d[2]);
 		else if (landsat) {
-		    de = bb_alb_landsat(d[1], d[2], d[3], d[4], d[5], d[6]);
+		    de = bb_alb_landsat(d[1],d[2],d[3],d[4],d[5],d[6]);
+		else if (landsat8) {
+		    de = bb_alb_landsat8(d[1],d[2],d[3],d[4],d[5],d[6]);
 		else if (aster) {
-		    de = bb_alb_aster(d[1], d[2], d[3], d[4], d[5], d[6]);
+		    de = bb_alb_aster(d[1],d[2],d[3],d[4],d[5],d[6]);
 		if (Rast_is_d_null_value(&de)) {
 		    /*Do nothing */
@@ -359,18 +372,21 @@
 	    if (modis) {
-		de = bb_alb_modis(d[1], d[2], d[3], d[4], d[5], d[6], d[7]);
 	    else if (avhrr) {
 	    else if (landsat) {
 	    else if (aster) {
 		/* Post-Process Albedo */
 		de = a * de + b;
