[GRASS-SVN] r60778 - grass-addons/grass7/imagery/i.points.auto
svn_grass at osgeo.org
Tue Jun 10 01:01:48 PDT 2014
Author: mmetz
Date: 2014-06-10 01:01:48 -0700 (Tue, 10 Jun 2014)
New Revision: 60778
grass-addons/grass7/imagery/i.points.auto/target.c
i.points.auto: fix for changed API
Modified: grass-addons/grass7/imagery/i.points.auto/target.c
--- grass-addons/grass7/imagery/i.points.auto/target.c 2014-06-10 07:46:15 UTC (rev 60777)
+++ grass-addons/grass7/imagery/i.points.auto/target.c 2014-06-10 08:01:48 UTC (rev 60778)
@@ -28,14 +28,14 @@
G_fatal_error(_("Can not continue"));
- G__create_alt_env();
- G__setenv("LOCATION_NAME", location);
+ G_create_alt_env();
+ G_setenv("LOCATION_NAME", location);
stat = G__mapset_permissions(mapset);
if (stat > 0) {
- G__setenv("MAPSET", mapset);
- G__create_alt_search_path();
- G__switch_env();
- G__switch_search_path();
+ G_setenv("MAPSET", mapset);
+ G_create_alt_search_path();
+ G_switch_env();
+ G_switch_search_path();
which_env = SRC_ENV;
return 1;
@@ -48,8 +48,8 @@
int select_env(int env)
if (which_env != env) {
- G__switch_env();
+ G_switch_env();
which_env = env;
@@ -59,8 +59,8 @@
int select_current_env(void)
if (which_env != SRC_ENV) {
- G__switch_env();
+ G_switch_env();
@@ -70,8 +70,8 @@
int select_target_env(void)
if (which_env != TGT_ENV) {
- G__switch_env();
+ G_switch_env();
which_env = TGT_ENV;
