[GRASS-SVN] r60783 - grass/branches/releasebranch_7_0/scripts/m.proj
Tue Jun 10 12:58:08 PDT 2014
Author: neteler
Date: 2014-06-10 12:58:08 -0700 (Tue, 10 Jun 2014)
New Revision: 60783
   grass/branches/releasebranch_7_0/scripts/m.proj/m.proj.html
m.proj manual: input=- is needed (while it should be default like in G6?)
Modified: grass/branches/releasebranch_7_0/scripts/m.proj/m.proj.html
--- grass/branches/releasebranch_7_0/scripts/m.proj/m.proj.html	2014-06-10 19:58:00 UTC (rev 60782)
+++ grass/branches/releasebranch_7_0/scripts/m.proj/m.proj.html	2014-06-10 19:58:08 UTC (rev 60783)
@@ -87,7 +87,7 @@
 To convert a WGS84 long/lat coordinate to the current map projection
 using the <b>-i</b> flag to set projection parameters automatically:
 <div class="code"><pre>
-GRASS> echo "170.510125 -45.868537" | m.proj -i
+GRASS> echo "170.510125 -45.868537" | m.proj -i input=-
 2316541.70      5479193.51 1.23
 </pre></div>
