[GRASS-SVN] r60789 - grass/trunk/raster/r.topmodel
svn_grass at osgeo.org
Wed Jun 11 00:02:46 PDT 2014
Author: hcho
Date: 2014-06-11 00:02:46 -0700 (Wed, 11 Jun 2014)
New Revision: 60789
grass/trunk/raster/r.topmodel/file_io.c
grass/trunk/raster/r.topmodel/infiltration.c
grass/trunk/raster/r.topmodel/main.c
grass/trunk/raster/r.topmodel/topmodel.c
r.topmodel: translate fatal errors and warnings
Modified: grass/trunk/raster/r.topmodel/file_io.c
--- grass/trunk/raster/r.topmodel/file_io.c 2014-06-11 06:53:39 UTC (rev 60788)
+++ grass/trunk/raster/r.topmodel/file_io.c 2014-06-11 07:02:46 UTC (rev 60789)
@@ -97,7 +97,7 @@
if (params.qs0 == 0.0) {
fclose(fp);
- G_fatal_error("parameters.qs0 cannot be 0.0");
+ G_fatal_error(_("%s cannot be 0"), "parameters.qs0");
exit(EXIT_FAILURE);
for (; !feof(fp);) {
Modified: grass/trunk/raster/r.topmodel/infiltration.c
--- grass/trunk/raster/r.topmodel/infiltration.c 2014-06-11 06:53:39 UTC (rev 60788)
+++ grass/trunk/raster/r.topmodel/infiltration.c 2014-06-11 07:02:46 UTC (rev 60789)
@@ -66,7 +66,7 @@
if (i == MAXITER)
G_warning(
- _("Maximum number of iterations exceeded at timestep %d."),
+ _("Maximum number of iterations exceeded at timestep %d"),
timestep);
pt = t - input.dt + (f - cumf) / R;
@@ -105,7 +105,7 @@
break;
if (i == MAXITER)
- G_warning(_("Maximum number of iterations exceeded at timestep %d."),
+ G_warning(_("Maximum number of iterations exceeded at timestep %d"),
timestep);
if (f < cumf + R * input.dt) {
Modified: grass/trunk/raster/r.topmodel/main.c
--- grass/trunk/raster/r.topmodel/main.c 2014-06-11 06:53:39 UTC (rev 60788)
+++ grass/trunk/raster/r.topmodel/main.c 2014-06-11 07:02:46 UTC (rev 60789)
@@ -146,13 +146,15 @@
outtopidxstats = params.outtopidxstats->answer;
if (ntopidxclasses <= 0)
- G_fatal_error(_("ntopidxclasses must be positive."));
+ G_fatal_error(_("%s must be positive"), "ntopidxclasses");
create_topidxstats(topidx, ntopidxclasses, outtopidxstats);
} else if (params.topidx->answer) {
- G_warning(_("Ignoring topidx because outtopidxstats is not specified."));
+ G_warning(_("Ignoring %s because %s is not specified"),
+ params.topidx->key, params.outtopidxstats->key);
} else if (params.outtopidxstats->answer) {
- G_warning(_("Ignoring outtopidxstats because topidx is not specified."));
+ params.outtopidxstats->key, params.topidx->key);
if (flags.preprocess->answer)
Modified: grass/trunk/raster/r.topmodel/topmodel.c
--- grass/trunk/raster/r.topmodel/topmodel.c 2014-06-11 06:53:39 UTC (rev 60788)
+++ grass/trunk/raster/r.topmodel/topmodel.c 2014-06-11 07:02:46 UTC (rev 60789)
@@ -1,6 +1,7 @@
#include <math.h>
#include <grass/raster.h>
#include <grass/spawn.h>
+#include <grass/glocale.h>
#include "global.h"
void create_topidxstats(char *topidx, int ntopidxclasses, char *outtopidxstats)
@@ -17,7 +18,7 @@
G_verbose_message("r.stats -Anc %s %s %s ...", input, output, nsteps);
if (G_spawn("r.stats", "r.stats", "-Anc", input, output, nsteps, NULL) != 0)
- G_fatal_error("r.stats failed");
+ G_fatal_error(_("Unable to run %s"), "r.stats");
/* Calculate the areal average of topographic index */
