[GRASS-SVN] r60813 - sandbox/annakrat/r3.flow
Thu Jun 12 20:52:47 PDT 2014
Author: annakrat
Date: 2014-06-12 20:52:47 -0700 (Thu, 12 Jun 2014)
New Revision: 60813
   sandbox/annakrat/r3.flow/r3.flow.py
   sandbox/annakrat/r3.flow/rast3d_functions.py
r3.flow: added more input options; simple flow accumulation implemented
Modified: sandbox/annakrat/r3.flow/r3.flow.py
--- sandbox/annakrat/r3.flow/r3.flow.py	2014-06-12 22:26:32 UTC (rev 60812)
+++ sandbox/annakrat/r3.flow/r3.flow.py	2014-06-13 03:52:47 UTC (rev 60813)
@@ -36,12 +36,20 @@
 #%end
 #%option G_OPT_V_INPUT
 #% key: seed_points
-#% description:
+#% required: no
+#% description: If no map is provided, flow lines are generated from each cell of the input 3D raster
 #% label: Name of vector map with points from which flow lines are generated
 #%end
 #%option G_OPT_V_OUTPUT
+#% key: flowline
+#% required: no
 #% description: Name of vector map of flow lines
 #%end
+#%option G_OPT_R3_OUTPUT
+#% key: flowaccumulation
+#% required: no
+#% description: Name of the output flow accumulation 3D raster map
+#%end
 #%option
 #% key: unit
 #% type: string
@@ -69,12 +77,20 @@
 #% description: Maximum number of steps
 #% gisprompt: Integration
 #%end
+#%option
+#% key: skip
+#% type: integer
+#% required: no
+#% multiple: yes
+#% description: Number of cells between flow lines in x, y and z direction
+#%end
 #%flag
 #% key: u
 #% description: Compute upstream flowlines instead of default downstream flowlines
 #%end
 import math
+import numpy as np
 from grass.script import core as gcore
 from grass.script import array as garray
@@ -83,11 +99,20 @@
 from grass.pygrass.vector.geometry import Line, Point
 from integrate import integrate_next, get_time_step
-from rast3d_functions import get_velocity, norm, compute_gradient
+from rast3d_functions import get_velocity, norm, compute_gradient, rast3d_location2coord
-EPSILON = 1e-7
+EPSILON = 1e-8
+class Seed:
+    def __init__(self, x, y, z, flowline, flowaccum):
+        self.x = x
+        self.y = y
+        self.z = z
+        self.flowline = flowline
+        self.flowaccum = flowaccum
 def main():
     options, flags = gcore.parser()
@@ -106,12 +131,15 @@
     elif options['input']:
         array = garray.array3d()
         array.read(mapname=options['input'])
-        velocity = compute_gradient(array)
+        velocity = compute_gradient(array)
         map_info = grast3d.raster3d_info(options['input'])
     else:
         # this should be handled by parser (in the future)
         gcore.fatal("Either input or vector_field options must be specified.")
+    if not (options['flowaccumulation'] or options['flowline']):
+        gcore.fatal("At least one of output options flowline or flowaccumulation must be specified.")
     # integrating forward means upstream, backward means downstream
     if flags['u']:
         direction = 1
@@ -130,26 +158,69 @@
     # cell size is the diagonal
     cell_size = math.sqrt(map_info['nsres'] ** 2 + map_info['ewres'] ** 2 + map_info['tbres'] ** 2)
-    # read seed points
+    if options['seed_points'] and options['skip']:
+        gcore.warning(_("Option skip is ignored because seed point map was provided."))
+    # read or create seed points
     seeds = []
-    inp_seeds = VectorTopo(options['seed_points'])
-    inp_seeds.open()
-    for point in inp_seeds:
-        point.is2D = False  # just a workaround
-        seeds.append((point.x, point.y, point.z))
-    inp_seeds.close()
+    if options['flowaccumulation'] or (options['flowline'] and not options['seed_points']):
+        if options['skip']:
+            try:
+                skipx, skipy, skipz = [int(each) for each in options['skip'].split(',')]
+            except ValueError:
+                gcore.fatal(_("Please provide 3 values for skip option"))
+        else:
+            skipx = max(1, int(map_info['cols'] / 10))
+            skipy = max(1, int(map_info['rows'] / 10))
+            skipz = max(1, int(map_info['depths'] / 10))
+        for r in range(map_info['rows'], 0, -1):
+            for c in range(0, map_info['cols']):
+                for d in range(0, map_info['depths']):
+                    x = c * map_info['ewres'] + map_info['ewres'] / 2
+                    y = r * map_info['nsres'] + map_info['nsres'] / 2
+                    z = d * map_info['tbres'] + map_info['tbres'] / 2
+                    seed = Seed(x, y, z, False, False)
+                    if options['flowaccumulation']:
+                        seed.flowaccum = True
+                    if options['flowline'] and c % skipx == 0 and r % skipy == 0 and d % skipz == 0:
+                        seed.flowline = True
+                    if seed.flowaccum or seed.flowline:
+                        seeds.append(seed)
+    else:
+        # read seed points
+        inp_seeds = VectorTopo(options['seed_points'])
+        inp_seeds.open()
+        for point in inp_seeds:
+            point.is2D = False  # just a workaround
+            seeds.append(Seed(point.x, point.y, point.z, flowaccum=False, flowline=True))
+        inp_seeds.close()
     # create new vector map to store flow lines
-    flowline_vector = VectorTopo(options['output'])
-    if flowline_vector.exist() and not gcore.overwrite:
-        gcore.fatal(_("Vector map <{flowlines}> already exists.").format(flowlines=flowline_vector))
-    flowline_vector.open('w')
+    if options['flowline']:
+        flowline_vector = VectorTopo(options['flowline'])
+        if flowline_vector.exist() and not gcore.overwrite:
+            gcore.fatal(_("Vector map <{flowline}> already exists.").format(flowline=flowline_vector))
+        flowline_vector.open('w')
+    # create the flowaccumulation 3D raster
+        flowacc = garray.array3d()
+        for depth in range(map_info['depths']):
+            flowacc[depth] = np.zeros((map_info['rows'], map_info['cols']))
     # go through all points and integrate flowline for each
+    seed_count = 0
     for seed in seeds:
-        line = Line([Point(seed[0], seed[1], seed[2])])
-        point = seed
         count = 0
+        gcore.percent(seed_count, len(seeds), 1)
+        seed_count += 1
+        point = seed.x, seed.y, seed.z
+        if seed.flowline:
+            line = Line([Point(point[0], point[1], point[2])])
+        last_coords = (None, None, None)
         while count <= limit:
             velocity_vector = get_velocity(map_info, velocity, point)
             if velocity_vector is None:
@@ -163,17 +234,27 @@
             point = integrate_next(map_info, velocity, point, delta_T * direction)
             if point is None:
                 break
-            line.append(Point(point[0], point[1], point[2]))
+            if seed.flowline:
+                line.append(Point(point[0], point[1], point[2]))
+            if seed.flowaccum:
+                col, row, depth = rast3d_location2coord(map_info, point[1], point[0], point[2])
+                if last_coords != (col, row, depth):
+                    flowacc[depth][row][col] += 1
+                    last_coords = (col, row, depth)
             count += 1
-        if len(line) > 1:
+        if seed.flowline and len(line) > 1:
             # workaround for pygrass bug
             line.is2D = False
             flowline_vector.write(line)
-            gcore.message(_("Flowline ended after %s steps.") % (count - 1), flag='v')
+            gcore.verbose(_("Flowline ended after %s steps") % (count - 1))
-    flowline_vector.close()
+        flowline_vector.close()
+        flowacc.write(mapname=options['flowaccumulation'])
 if __name__ == '__main__':
     main()
Modified: sandbox/annakrat/r3.flow/rast3d_functions.py
--- sandbox/annakrat/r3.flow/rast3d_functions.py	2014-06-12 22:26:32 UTC (rev 60812)
+++ sandbox/annakrat/r3.flow/rast3d_functions.py	2014-06-13 03:52:47 UTC (rev 60813)
@@ -34,9 +34,10 @@
 def rast3d_location2coord(rast3d_region, north, east, top):
     """!Returns column, row and depth of a cell where the input
     coordinates (north, east, top) lie."""
-    col = int((east - rast3d_region['west']) / rast3d_region['ewres'])
-    row = int((rast3d_region['north'] - north) / rast3d_region['nsres'])
-    depth = int((top - rast3d_region['bottom']) / rast3d_region['tbres'])
+    # math.floor to get because int(-0.8) gives 0
+    col = int(math.floor((east - rast3d_region['west']) / rast3d_region['ewres']))
+    row = int(math.floor((rast3d_region['north'] - north) / rast3d_region['nsres']))
+    depth = int(math.floor((top - rast3d_region['bottom']) / rast3d_region['tbres']))
     return col, row, depth
