[GRASS-SVN] r60829 - grass/branches/releasebranch_7_0/lib/python/temporal
svn_grass at osgeo.org
Sat Jun 14 05:14:49 PDT 2014
Author: neteler
Date: 2014-06-14 05:14:49 -0700 (Sat, 14 Jun 2014)
New Revision: 60829
grass/branches/releasebranch_7_0/lib/python/temporal/core.py
grass/branches/releasebranch_7_0/lib/python/temporal/datetime_math.py
grass/branches/releasebranch_7_0/lib/python/temporal/extract.py
grass/branches/releasebranch_7_0/lib/python/temporal/list_stds.py
grass/branches/releasebranch_7_0/lib/python/temporal/mapcalc.py
grass/branches/releasebranch_7_0/lib/python/temporal/open_stds.py
grass/branches/releasebranch_7_0/lib/python/temporal/stds_import.py
temporal: minor msg cosmetics
Modified: grass/branches/releasebranch_7_0/lib/python/temporal/core.py
--- grass/branches/releasebranch_7_0/lib/python/temporal/core.py 2014-06-14 12:14:08 UTC (rev 60828)
+++ grass/branches/releasebranch_7_0/lib/python/temporal/core.py 2014-06-14 12:14:49 UTC (rev 60829)
@@ -578,7 +578,7 @@
metadata = get_tgis_metadata(dbif)
dbif.close()
if metadata is None:
- msgr.fatal(_("Unable to receiving temporal database metadata.\n"
+ msgr.fatal(_("Unable to receive temporal database metadata.\n"
"Current temporal database info:%(info)s")%({"info":get_database_info_string()}))
for entry in metadata:
if "tgis_version" in entry and entry[1] != str(get_tgis_version()):
@@ -672,7 +672,7 @@
stvds_tables_sql = stds_tables_template_sql.replace("STDS", "stvds")
str3ds_tables_sql = stds_tables_template_sql.replace("STDS", "str3ds")
- msgr.message(_("Create temporal database: %s" % (tgis_database_string)))
+ msgr.message(_("Creating temporal database: %s" % (tgis_database_string)))
if tgis_backend == "sqlite":
# We need to create the sqlite3 database path if it does not exists
@@ -681,7 +681,7 @@
try:
os.makedirs(tgis_dir)
except Exception as e:
- msgr.fatal(_("Unable to create sqlite temporal database\n"
+ msgr.fatal(_("Unable to create SQLite temporal database\n"
"Exception: %s\nPlease use t.connect to set a "
"read- and writable temporal database path"%(e)))
Modified: grass/branches/releasebranch_7_0/lib/python/temporal/datetime_math.py
--- grass/branches/releasebranch_7_0/lib/python/temporal/datetime_math.py 2014-06-14 12:14:08 UTC (rev 60828)
+++ grass/branches/releasebranch_7_0/lib/python/temporal/datetime_math.py 2014-06-14 12:14:49 UTC (rev 60829)
@@ -734,7 +734,7 @@
# BC is not supported
if time_string.find("bc") > 0:
- return _("Dates Before Christ are not supported")
+ return _("Dates Before Christ (BC) are not supported")
if time_string.find("+") > 0:
Modified: grass/branches/releasebranch_7_0/lib/python/temporal/extract.py
--- grass/branches/releasebranch_7_0/lib/python/temporal/extract.py 2014-06-14 12:14:08 UTC (rev 60828)
+++ grass/branches/releasebranch_7_0/lib/python/temporal/extract.py 2014-06-14 12:14:49 UTC (rev 60829)
@@ -116,17 +116,17 @@
# Add process to the process list
if type == "raster":
- msgr.verbose(_("Apply r.mapcalc expression: \"%s\"")
+ msgr.verbose(_("Applying r.mapcalc expression: \"%s\"")
% expr)
proc_list.append(Process(target=run_mapcalc2d,
args=(expr,)))
elif type == "raster3d":
- msgr.verbose(_("Apply r3.mapcalc expression: \"%s\"")
+ msgr.verbose(_("Applying r3.mapcalc expression: \"%s\"")
% expr)
proc_list.append(Process(target=run_mapcalc3d,
args=(expr,)))
elif type == "vector":
- msgr.verbose(_("Apply v.extract where statement: \"%s\"")
+ msgr.verbose(_("Applying v.extract where statement: \"%s\"")
% expression)
if row["layer"]:
proc_list.append(Process(target=run_vector_extraction,
@@ -154,7 +154,7 @@
exitcodes += proc.exitcode
if exitcodes != 0:
dbif.close()
- msgr.fatal(_("Error while computation"))
+ msgr.fatal(_("Error in computation process"))
# Empty process list
proc_list = []
Modified: grass/branches/releasebranch_7_0/lib/python/temporal/list_stds.py
--- grass/branches/releasebranch_7_0/lib/python/temporal/list_stds.py 2014-06-14 12:14:08 UTC (rev 60828)
+++ grass/branches/releasebranch_7_0/lib/python/temporal/list_stds.py 2014-06-14 12:14:49 UTC (rev 60829)
@@ -175,7 +175,7 @@
if len(maps[0]) > 0:
first_time, dummy = maps[0][0].get_temporal_extent_as_tuple()
else:
- msgr.warning(_("Empty map list."))
+ msgr.warning(_("Empty map list"))
return
else:
first_time, dummy = maps[0].get_temporal_extent_as_tuple()
@@ -186,7 +186,7 @@
if len(mymap) > 0:
map = mymap[0]
else:
- msgr.fatal(_("Empty entry in map list, this should not happen."))
+ msgr.fatal(_("Empty entry in map list, this should not happen"))
else:
map = mymap
Modified: grass/branches/releasebranch_7_0/lib/python/temporal/mapcalc.py
--- grass/branches/releasebranch_7_0/lib/python/temporal/mapcalc.py 2014-06-14 12:14:08 UTC (rev 60828)
+++ grass/branches/releasebranch_7_0/lib/python/temporal/mapcalc.py 2014-06-14 12:14:49 UTC (rev 60829)
@@ -427,55 +427,55 @@
if expr.find("start_year()") >= 0:
if not is_time_absolute:
- msgr.fatal(_("The temporal operators <%s> supports only absolute "\
+ msgr.fatal(_("The temporal operators <%s> support only absolute "\
"time." % ("start_*")))
expr = expr.replace("start_year()", str(start.year))
if expr.find("start_month()") >= 0:
expr = expr.replace("start_month()", str(start.month))
if expr.find("start_week()") >= 0:
expr = expr.replace("start_week()", str(start.isocalendar()[1]))
if expr.find("start_day()") >= 0:
expr = expr.replace("start_day()", str(start.day))
if expr.find("start_hour()") >= 0:
expr = expr.replace("start_hour()", str(start.hour))
if expr.find("start_minute()") >= 0:
expr = expr.replace("start_minute()", str(start.minute))
if expr.find("start_second()") >= 0:
expr = expr.replace("start_second()", str(start.second))
if expr.find("start_dow()") >= 0:
expr = expr.replace("start_dow()", str(start.isoweekday()))
if expr.find("start_doy()") >= 0:
year = datetime(start.year, 1, 1)
delta = start - year
@@ -510,7 +510,7 @@
if expr.find("end_year()") >= 0:
"time." % ("end_*")))
if not end:
expr = expr.replace("end_year()", "null()")
@@ -519,7 +519,7 @@
if expr.find("end_month()") >= 0:
if not end:
expr = expr.replace("end_month()", "null()")
@@ -528,7 +528,7 @@
if expr.find("end_week()") >= 0:
if not end:
expr = expr.replace("end_week()", "null()")
@@ -537,7 +537,7 @@
if expr.find("end_day()") >= 0:
if not end:
expr = expr.replace("end_day()", "null()")
@@ -546,7 +546,7 @@
if expr.find("end_hour()") >= 0:
if not end:
expr = expr.replace("end_hour()", "null()")
@@ -555,7 +555,7 @@
if expr.find("end_minute()") >= 0:
if not end:
expr = expr.replace("end_minute()", "null()")
@@ -564,7 +564,7 @@
if expr.find("end_second()") >= 0:
if not end:
expr = expr.replace("end_second()", "null()")
@@ -573,7 +573,7 @@
if expr.find("end_dow()") >= 0:
if not end:
expr = expr.replace("end_dow()", "null()")
@@ -582,7 +582,7 @@
if expr.find("end_doy()") >= 0:
if not end:
expr = expr.replace("end_doy()", "null()")
Modified: grass/branches/releasebranch_7_0/lib/python/temporal/open_stds.py
--- grass/branches/releasebranch_7_0/lib/python/temporal/open_stds.py 2014-06-14 12:14:08 UTC (rev 60828)
+++ grass/branches/releasebranch_7_0/lib/python/temporal/open_stds.py 2014-06-14 12:14:49 UTC (rev 60829)
@@ -14,7 +14,7 @@
@endcode
-(C) 2012-2013 by the GRASS Development Team
+(C) 2012-2014 by the GRASS Development Team
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
for details.
@@ -152,15 +152,15 @@
sp = check_new_space_time_dataset(name, type, dbif, overwrite)
if sp.is_in_db(dbif):
- msgr.warning(_("Overwrite space time %(sp)s dataset <%(name)s> and "
- "unregister all maps.") % {
+ msgr.warning(_("Overwriting space time %(sp)s dataset <%(name)s> and "
+ "unregistering all maps") % {
'sp': sp.get_new_map_instance(None).get_type(),
'name': name})
id = sp.get_id()
sp.delete(dbif)
sp = sp.get_new_instance(id)
- msgr.verbose(_("Create new space time %s dataset.") %
+ msgr.verbose(_("Creating a new space time %s dataset") %
sp.get_new_map_instance(None).get_type())
sp.set_initial_values(temporal_type=temporaltype, semantic_type=semantic,
Modified: grass/branches/releasebranch_7_0/lib/python/temporal/stds_import.py
--- grass/branches/releasebranch_7_0/lib/python/temporal/stds_import.py 2014-06-14 12:14:08 UTC (rev 60828)
+++ grass/branches/releasebranch_7_0/lib/python/temporal/stds_import.py 2014-06-14 12:14:49 UTC (rev 60829)
@@ -363,7 +363,7 @@
for row in maplist:
filename = row["filename"] + ".tif"
if not os.path.exists(filename):
- core.fatal(_("Unable to find geotiff raster file "
+ core.fatal(_("Unable to find GeoTIFF raster file "
"<%s> in archive.") % filename)
elif format_ == "AAIGrid":
for row in maplist:
