[GRASS-SVN] r60835 - grass/trunk/raster/r.patch
svn_grass at osgeo.org
Sun Jun 15 23:08:57 PDT 2014
Author: hcho
Date: 2014-06-15 23:08:57 -0700 (Sun, 15 Jun 2014)
New Revision: 60835
grass/trunk/raster/r.patch/do_patch.c
r.patch: rename G_is_zero_value to is_zero_value
Modified: grass/trunk/raster/r.patch/do_patch.c
--- grass/trunk/raster/r.patch/do_patch.c 2014-06-15 19:51:27 UTC (rev 60834)
+++ grass/trunk/raster/r.patch/do_patch.c 2014-06-16 06:08:57 UTC (rev 60835)
@@ -9,7 +9,7 @@
* 0 the result contains no zero nulls
-int G_is_zero_value(void *rast, RASTER_MAP_TYPE data_type)
+int is_zero_value(void *rast, RASTER_MAP_TYPE data_type)
/* insert 0 check here */
@@ -28,14 +28,14 @@
more = 0;
while (ncols-- > 0) {
if (ZEROFLAG) { /* use 0 for transparency instead of NULL */
- if (G_is_zero_value(result, out_type) ||
+ if (is_zero_value(result, out_type) ||
Rast_is_null_value(result, out_type)) {
/* Don't patch hole with a null, just mark as more */
if (Rast_is_null_value(patch, out_type))
more = 1;
else {
/* Mark that there is more to be done if we patch with 0 */
- if (G_is_zero_value(patch, out_type))
+ if (is_zero_value(patch, out_type))
more = 1;
Rast_raster_cpy(result, patch, 1, out_type);
if (out_type == CELL_TYPE)
