[GRASS-SVN] r60853 - grass-addons/grass7/raster/r.fidimo
Tue Jun 17 07:13:14 PDT 2014
Author: jradinger
Date: 2014-06-17 07:13:14 -0700 (Tue, 17 Jun 2014)
New Revision: 60853
   grass-addons/grass7/raster/r.fidimo/r.fidimo.py
Modified: grass-addons/grass7/raster/r.fidimo/r.fidimo.py
--- grass-addons/grass7/raster/r.fidimo/r.fidimo.py	2014-06-17 13:45:46 UTC (rev 60852)
+++ grass-addons/grass7/raster/r.fidimo/r.fidimo.py	2014-06-17 14:13:14 UTC (rev 60853)
@@ -229,7 +229,7 @@
 	if options['barriers']:
-		tmp_map_rast = tmp_map_rast + ['downstream_barrier_density_tmp_','distance_barrier_tmp_', 'distance_downstream_barrier_tmp_', 'lower_distance_barrier_tmp_', 'upper_distance_barrier_tmp_', 'upstream_barrier_tmp_',  'upstream_barrier_density_tmp_']
+		tmp_map_rast = tmp_map_rast + ['downstream_barrier_density_tmp_','distance_barrier_tmp_','distance_downstream_barrier_tmp_', 'distance_upstream_point_tmp_','inv_distance_downstream_barrier_tmp_', 'lower_distance_barrier_tmp_', 'upper_distance_barrier_tmp_', 'upstream_barrier_tmp_',  'upstream_barrier_density_tmp_']
 		tmp_map_vect = tmp_map_vect + ["barriers_",'barriers_tmp_']
