[GRASS-SVN] r60861 - grass/trunk/raster/r.viewshed
Wed Jun 18 01:52:08 PDT 2014
Author: neteler
Date: 2014-06-18 01:52:08 -0700 (Wed, 18 Jun 2014)
New Revision: 60861
   grass/trunk/raster/r.viewshed/grass.cpp
   grass/trunk/raster/r.viewshed/r.viewshed.html
r.viewshed: error msg cosmetics; manual cosmetics
Modified: grass/trunk/raster/r.viewshed/grass.cpp
--- grass/trunk/raster/r.viewshed/grass.cpp	2014-06-18 08:51:26 UTC (rev 60860)
+++ grass/trunk/raster/r.viewshed/grass.cpp	2014-06-18 08:52:08 UTC (rev 60861)
@@ -111,7 +111,7 @@
     else {
 	G_warning("ERROR: nrows (%d) > maxDimension (%d) AND/OR ncols (%d) > maxDimension (%d)",
 	           nrows, maxDimension, ncols, maxDimension);
-	G_fatal_error(_("Grid dimension too big for current precision"));
+	G_fatal_error(_("Computational region too large. Use smaller area or lower raster resolution"));
Modified: grass/trunk/raster/r.viewshed/r.viewshed.html
--- grass/trunk/raster/r.viewshed/r.viewshed.html	2014-06-18 08:51:26 UTC (rev 60860)
+++ grass/trunk/raster/r.viewshed/r.viewshed.html	2014-06-18 08:52:08 UTC (rev 60861)
@@ -172,12 +172,14 @@
 <h2>EXAMPLES</h2>
-Compute viewshed from the point with coordinates 638728.087167, 220609.261501
-which is 5 meters above ground (using NC dataset):
+Using the North Carolina dataset:  Compute viewshed from a observation
+point (coordinates: 638728.087167, 220609.261501) which is 5 meters
+above ground:
 <div class="code"><pre>
-g.region rast=elev_lid792_1m
-r.viewshed input=elev_lid792_1m output=elev_lid792_1m_viewshed coordinates=638728.087167,220609.261501 obs_elev=5
+g.region rast=elev_lid792_1m -p
+r.viewshed input=elev_lid792_1m output=elev_lid792_1m_viewshed \
+  coordinates=638728.087167,220609.261501 obs_elev=5.0
 </pre></div>
 <div align="center" style="margin: 10px">
@@ -185,22 +187,23 @@
 <i>Viewshed</i>
 </div>
-image generated using
+# image generated using
 d.mon wx0
 d.rast elev_lid792_1m
 d.rast elev_lid792_1m_viewshed
-save image to files
-crop the background using Gimp or ImageMagic
+# save image to files
+# crop the background using Gimp or ImageMagic
-some bounding box problems noticed when opening mogrify result in Gimp
+# some bounding box problems noticed when opening mogrify result in Gimp
-Using the Spearfish dataset:  calculating the viewpoint from the top
+Using the Spearfish dataset:  calculating the viewpoint from top
 of a mountain:
 g.region rast=elevation.10m
-r.viewshed input=elevation.10m output=viewshed coordinate=598869,4916642 mem=800
+r.viewshed input=elevation.10m output=viewshed \
+  coordinates=598869,4916642 mem=800
 </pre></div>
@@ -208,18 +211,15 @@
 <ul>
-   <li>Computing Visibility on Terrains in External Memory. Herman
-	 Haverkort, Laura Toma and Yi Zhuang. In <em>ACM Journal
-	 on Experimental Algorithmics (JEA)</em> 13 (2009).
+<li>Computing Visibility on Terrains in External Memory. Herman
+Haverkort, Laura Toma and Yi Zhuang. In <em>ACM Journal on Experimental
+Algorithmics (JEA)</em> 13 (2009).</li>
-	 <li><a
-	 href="http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.76.4282&rep=rep1&type=pdf">
-	 Computing Visibility on Terrains in External Memory</a>. Herman
-	 Haverkort, Laura Toma and Yi Zhuang. In the <em>Proceedings of
-	 the 9th Workshop on Algorithm Engineering and Experiments /
-	 Workshop on Analytic Algorithms and Combinatorics (ALENEX/ANALCO
-	 2007)</em>.</li>
+<li><a href="http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.76.4282&rep=rep1&type=pdf">Computing
+Visibility on Terrains in External Memory</a>. Herman Haverkort, Laura
+Toma and Yi Zhuang. In the <em>Proceedings of the 9th Workshop on
+Algorithm Engineering and Experiments / Workshop on Analytic Algorithms
+and Combinatorics (ALENEX/ANALCO 2007)</em>.</li>
 </ul>
 <h2>SEE ALSO</h2>
