[GRASS-SVN] r60871 - in grass/trunk: include/defs lib/gis
svn_grass at osgeo.org
Thu Jun 19 07:35:40 PDT 2014
Author: glynn
Date: 2014-06-19 07:35:40 -0700 (Thu, 19 Jun 2014)
New Revision: 60871
Added:
grass/trunk/lib/gis/parser_dependencies.c
grass/trunk/include/defs/gis.h
grass/trunk/lib/gis/parser_local_proto.h
First draft of inter-option dependency rules
Modified: grass/trunk/include/defs/gis.h
--- grass/trunk/include/defs/gis.h 2014-06-19 14:35:05 UTC (rev 60870)
+++ grass/trunk/include/defs/gis.h 2014-06-19 14:35:40 UTC (rev 60871)
@@ -501,6 +501,12 @@
FILE *G_open_option_file(const struct Option *);
void G_close_option_file(FILE *);
+void G_option_exclusive(void *first, ...);
+void G_option_required(void *first, ...);
+void G_option_requires(void *first, ...);
+void G_option_requires_all(void *first, ...);
+void G_option_collective(void *first, ...);
/* paths.c */
int G_mkdir(const char *);
int G_is_dirsep(char);
Added: grass/trunk/lib/gis/parser_dependencies.c
--- grass/trunk/lib/gis/parser_dependencies.c (rev 0)
+++ grass/trunk/lib/gis/parser_dependencies.c 2014-06-19 14:35:40 UTC (rev 60871)
@@ -0,0 +1,313 @@
+ \file lib/gis/parser_dependencies.c
+ \brief GIS Library - Argument parsing functions (dependencies between options)
+ (C) 2014 by the GRASS Development Team
+ This program is free software under the GNU General Public License
+ (>=v2). Read the file COPYING that comes with GRASS for details.
+ \author Glynn Clements Jun. 2014
+#include <stdarg.h>
+#include <string.h>
+#include <stdio.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include "parser_local_proto.h"
+enum rule_type {
+ RULE_EXCLUSIVE,
+ RULE_REQUIRED,
+ RULE_REQUIRES,
+ RULE_REQUIRES_ALL,
+ RULE_COLLECTIVE
+struct vector {
+ size_t elsize;
+ size_t increment;
+ size_t count;
+ size_t limit;
+ void *data;
+static void vector_new(struct vector *v, size_t elsize, size_t increment)
+ v->elsize = elsize;
+ v->increment = increment;
+ v->count = 0;
+ v->limit = 0;
+ v->data = NULL;
+static void vector_append(struct vector *v, const void *data)
+ void *p;
+ if (v->count >= v->limit) {
+ v->limit += v->increment;
+ v->data = G_realloc(v->data, v->limit * v->elsize);
+ p = G_incr_void_ptr(v->data, v->count * v->elsize);
+ memcpy(p, data, v->elsize);
+ v->count++;
+struct rule {
+ int type;
+ int count;
+ void **opts;
+static struct vector rules = {sizeof(struct rule), 50};
+static void make_rule(int type, void *first, va_list ap)
+ struct vector opts;
+ void *opt;
+ struct rule rule;
+ vector_new(&opts, sizeof(void *), 10);
+ opt = first;
+ vector_append(&opts, &opt);
+ for (;;) {
+ opt = va_arg(ap, void*);
+ if (!opt)
+ break;
+ rule.type = type;
+ rule.count = opts.count;
+ rule.opts = (void**) opts.data;
+ vector_append(&rules, &rule);
+static int is_flag(const void *p)
+ if (st->n_flags) {
+ const struct Flag *flag;
+ for (flag = &st->first_flag; flag; flag = flag->next_flag)
+ if ((const void *) flag == p)
+ return 1;
+ if (st->n_opts) {
+ const struct Option *opt;
+ for (opt = &st->first_option; opt; opt = opt->next_opt)
+ if ((const void *) opt == p)
+ return 0;
+ G_fatal_error(_("Internal error: option or flag not found"));
+static int is_present(const void *p)
+ if (is_flag(p)) {
+ const struct Flag *flag = p;
+ return (int) flag->answer;
+ else {
+ const struct Option *opt = p;
+ return opt->count > 0;
+static char *get_name(const void *p)
+ if (is_flag(p)) {
+ char *s;
+ G_asprintf(&s, "-%c", ((const struct Flag *) p)->key);
+ return s;
+ else
+ return G_store(((const struct Option *) p)->key);
+static int count_present(const struct rule *rule, int start)
+ int i;
+ int count = 0;
+ for (i = start; i < rule->count; i++)
+ if (is_present(rule->opts[i]))
+ count++;
+ return count;
+static const char *describe_rule(const struct rule *rule, int start, int disjunction)
+ char *s = get_name(rule->opts[start]);
+ int i;
+ for (i = start + 1; i < rule->count - 1; i++) {
+ char *s0 = s;
+ char *ss = get_name(rule->opts[i]);
+ s = NULL;
+ G_asprintf(&s, "%s, %s", s0, ss);
+ G_free(s0);
+ G_free(ss);
+ if (rule->count - start > 1) {
+ char *s0 = s;
+ s = NULL;
+ G_asprintf(&s, disjunction ? _("%s or %s") : _("%s and %s"), s0, ss);
+ G_free(s0);
+ G_free(ss);
+ return s;
+/* at most one option from a set */
+ va_list ap;
+ va_start(ap, first);
+ make_rule(RULE_EXCLUSIVE, first, ap);
+ va_end(ap);
+static void check_exclusive(const struct rule *rule)
+ if (count_present(rule, 0) > 1)
+ G_fatal_error(_("Options %s are mutually exclusive"), describe_rule(rule, 0, 0));
+/* at least one option from a set */
+ va_list ap;
+ make_rule(RULE_REQUIRED, first, ap);
+ va_end(ap);
+static void check_required(const struct rule *rule)
+ if (count_present(rule, 0) < 1)
+ G_fatal_error(_("At least one of %s is required"), describe_rule(rule, 0, 0));
+/* if the first option is present, at least one of the other
+ options must also be present */
+ va_list ap;
+ make_rule(RULE_REQUIRES, first, ap);
+ va_end(ap);
+static void check_requires(const struct rule *rule)
+ if (!is_present(rule->opts[0]))
+ return;
+ if (count_present(rule, 1) < 1)
+ G_fatal_error(_("Options %s requires at least one of %s"), describe_rule(rule, 0, 1));
+/* if the first option is present, all the other options must also
+ be present. */
+ va_list ap;
+ make_rule(RULE_REQUIRES_ALL, first, ap);
+ va_end(ap);
+static void check_requires_all(const struct rule *rule)
+ return;
+ if (count_present(rule, 1) < rule->count - 1)
+ G_fatal_error(_("Options %s requires all of %s"), describe_rule(rule, 0, 0));
+/* if any option is present, all the other options must also be present
+ all or nothing from a set */
+ va_list ap;
+ make_rule(RULE_COLLECTIVE, first, ap);
+ va_end(ap);
+static void check_collective(const struct rule *rule)
+ int count = count_present(rule, 0);
+ if (count > 0 && count < rule->count)
+ G_fatal_error(_("Either all or none of %s must be given"), describe_rule(rule, 0, 0));
+void G__check_option_rules(void)
+ int i;
+ for (i = 0; i < rules.count; i++) {
+ const struct rule *rule = &((const struct rule *) rules.data)[i];
+ switch (rule->type) {
+ case RULE_EXCLUSIVE:
+ check_exclusive(rule);
+ break;
+ case RULE_REQUIRED:
+ check_required(rule);
+ break;
+ case RULE_REQUIRES:
+ check_requires(rule);
+ break;
+ case RULE_REQUIRES_ALL:
+ check_requires_all(rule);
+ break;
+ case RULE_COLLECTIVE:
+ check_collective(rule);
+ break;
+ default:
+ G_fatal_error(_("Internal error: invalid rule type: %d"), rule->type);
+ break;
+void G__describe_option_rules(void)
+ int i;
+ fprintf(stderr, "Exclusive: %s", describe_rule(rule, 0, 0));
+ break;
+ fprintf(stderr, "Required: %s", describe_rule(rule, 0, 1));
+ break;
+ fprintf(stderr, "Requires: %s => %s", rule->opts[0], describe_rule(rule, 1, 1));
+ break;
+ fprintf(stderr, "Requires: %s => %s", rule->opts[0], describe_rule(rule, 1, 0));
+ break;
+ fprintf(stderr, "Collective: %s", describe_rule(rule, 0, 0));
+ break;
+ default:
+ break;
Property changes on: grass/trunk/lib/gis/parser_dependencies.c
___________________________________________________________________
Added: svn:mime-type
+ text/x-csrc
Added: svn:eol-style
+ native
Modified: grass/trunk/lib/gis/parser_local_proto.h
--- grass/trunk/lib/gis/parser_local_proto.h 2014-06-19 14:35:05 UTC (rev 60870)
+++ grass/trunk/lib/gis/parser_local_proto.h 2014-06-19 14:35:40 UTC (rev 60871)
@@ -54,5 +54,8 @@
int G__uses_new_gisprompt(void);
void G__print_keywords(FILE *, void (*)(FILE *, const char *));
+void G__check_option_rules(void);
+void G__describe_option_rules(void);
#endif
