[GRASS-SVN] r60878 - grass-addons/grass7/raster/r.diversity
svn_grass at osgeo.org
Thu Jun 19 22:39:24 PDT 2014
Author: neteler
Date: 2014-06-19 22:39:24 -0700 (Thu, 19 Jun 2014)
New Revision: 60878
grass-addons/grass7/raster/r.diversity/r.diversity.py
r.diversity: remove quiet flags to print the output map names
Modified: grass-addons/grass7/raster/r.diversity/r.diversity.py
--- grass-addons/grass7/raster/r.diversity/r.diversity.py 2014-06-20 05:06:46 UTC (rev 60877)
+++ grass-addons/grass7/raster/r.diversity/r.diversity.py 2014-06-20 05:39:24 UTC (rev 60878)
@@ -167,12 +167,12 @@
output=map_out + '_renyi_size_' + r + \
'_alpha_' + str(alp), alpha=alp,
conf='conf_diversity_' + r,
- quiet=quiet, overwrite=overw)
+ overwrite=overw)
else:
grass.run_command('r.li.' + i, input=map_in,
output=map_out + '_' + i + '_size_' + r,
+ overwrite=overw)
# calculate only method excluded with exclude option
@@ -193,12 +193,12 @@
output=map_out + '_renyi_size_' + r \
+ '_alpha_' + str(alp), alpha=alp,
+ overwrite=overw)
else:
grass.run_command('r.li.' + i, input=map_in, output=map_out \
+ overwrite=overw)
# check if alpha value it's set when renyi entropy must be calculate
