[GRASS-SVN] r60897 - sandbox/krejcmat/src
svn_grass at osgeo.org
Fri Jun 20 09:05:27 PDT 2014
Author: martinl
Date: 2014-06-20 09:05:27 -0700 (Fri, 20 Jun 2014)
New Revision: 60897
sandbox/krejcmat/src/mdgrass.py
sandbox/krejcmat/src/r.info.iso.py
sandbox/krejcmat/src/v.info.iso.py
minor clean up
Modified: sandbox/krejcmat/src/mdgrass.py
--- sandbox/krejcmat/src/mdgrass.py 2014-06-20 15:54:48 UTC (rev 60896)
+++ sandbox/krejcmat/src/mdgrass.py 2014-06-20 16:05:27 UTC (rev 60897)
@@ -6,65 +6,68 @@
PURPOSE: Library for creating ISO metadata for GRASS GIS
-COPYRIGHT: (C) 2007 Matej Krejci, and by the GRASS Development Team
+COPYRIGHT: (C) 2014 Matej Krejci, and by the GRASS Development Team
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
for details.
+import os
+import sys
+import getpass # whoami for linux and ms-win
+import StringIO
+from subprocess import PIPE
+from datetime import date, datetime
from owslib.iso import *
from lxml import etree
-from jinja2 import Environment, FileSystemLoader
+from jinja2 import Environment, FileSystemLoader # TODO: remove this dependency?
-import os
-import sys
from grass.pygrass.modules.shortcuts import general as g
from grass.pygrass.gis import Mapset
from grass.pygrass import raster
from grass.pygrass.modules import Module
-from grass.script import parse_key_val
-from subprocess import PIPE
-from datetime import date,datetime
-import getpass # whoami for linux and ms-win
-from grass.script import parser
+from grass.script import parse_key_val, parser
from grass.script import core as grass
-import StringIO
-import subprocess as sub
class GrassMD():
def __init__(self, map, type):
- self.map = map #name of choosen map by user
- self.type = type #typ of map representation(cell, vector, r3)
- self.isMapExist() #function to check if map exist
- self.md_grass = {} #dict with metadata from r.info v.info except "r.info flag=h"
- self.md_abstract = '' #create abstract from self.md_grass - key: source1, source2 and descriptio etc.
- self.md_vinfo_h = '' #v.info flag=h" - parse
- self.gisenv_grass = grass.gisenv()#dict with gisenv information
- self.schema_type='_md_GRASS.xml' #postfix of output xml file (variables)
+ self.map = map # name of choosen map by user
+ self.type = type # typ of map representation(cell, vector, r3)
+ self.isMapExist() # function to check if map exist
+ self.md_grass = {} # dict with metadata from r.info v.info except "r.info flag=h"
+ self.md_abstract = '' # create abstract from self.md_grass - key: source1, source2 and descriptio etc.
+ self.md_vinfo_h = '' # v.info flag=h" - parse
+ self.gisenv_grass = grass.gisenv()# dict with gisenv information
+ self.schema_type='_md_GRASS.xml' # postfix of output xml file (variables)
self.dirpath = os.path.dirname(os.path.realpath(__file__))
- self.md = MD_Metadata() #metadata object from OWSLIB ( for define md values)
- self.template = None #path to file with xml templates
+ self.md = MD_Metadata() # metadata object from OWSLIB ( for define md values)
+ self.template = None # path to file with xml templates
if self.type == "cell":
self.parseRast()
elif self.type == "vector":
self.parseVect()
- elif self.type == "r3??":
- #TODO
- self.parseRast3D()
+ elif self.type == "g3dcell":
+ self.parseRast3D() # TODO
def isMapExist(self):
'''Check if is the map in working mapset'''
self.mapset = grass.find_file(self.map, self.type)['mapset']
if not self.mapset:
- grass.fatal(_("Map <%s> doesn't exist"), self.map)
+ grass.fatal(_("Map <%s> not found"), self.map)
def readXML(self,xml_file):
- '''create instance of metadata(owslib) from xml file'''
+ '''Create instance of metadata(owslib) from xml file'''
self.md = MD_Metadata(etree.parse(xml_file))
def parseRast3D(self):
@@ -74,11 +77,11 @@
'''Read metadata from v.info
#self.md_grass dictionary of metadata from v.info '''
- #parse md from v.info flags=-g -e -t
+ # parse md from v.info -get (basic metadata)
vinfo = Module('v.info', self.map, flags='get', quiet = True, stdout_=PIPE)
self.md_grass = parse_key_val(vinfo.outputs.stdout)
- #parse md from v.info flag h (history of map in grass)
+ # parse md from v.info flag -h (history of map in grass)
rinfo_h = Module('v.info', self.map, flags='h', quiet = True, stdout_=PIPE)
md_h_grass = rinfo_h.outputs.stdout
buf = StringIO.StringIO(md_h_grass)
@@ -89,19 +92,18 @@
line = buf.readline().splitlines()
buf.close()
- #change grass generated date format to iso format
- #if date format is diverse from standard, use them
+ # change grass generated date format to iso format
+ # if date format is diverse from standard, use them
self._createISODate('source_date')
def _createISODate(self, key):
'''Function for convert grass-generated date to iso format
if the format of date is different to grass-generated format - use them and print warning '''
try:
date = datetime.strptime(self.md_grass[key], '%a %b %d %H:%M:%S %Y')
self.md_grass['dateofcreation'] = date.strftime('%Y-%m-%d')
except:
- grass.warning('date of creation: unknown date format')
+ grass.warning(_('date of creation: unknown date format'))
self.md_grass['dateofcreation'] = self.md_grass[key]
def parseRast(self):
@@ -112,10 +114,10 @@
rinfo = Module('r.info', self.map, flags='gre', quiet = True, stdout_=PIPE)
self.md_grass = parse_key_val(rinfo.outputs.stdout)
- #convert date to iso format
+ # convert date to iso format
self._createISODate('date')
- #create abstract
+ # create abstract
if self.md_grass['description'] != '""':
self.md_abstract = self.md_grass['description'] + '\n'
if self.md_grass['source1'] != '""':
@@ -125,7 +127,6 @@
self.md_abstract += 'Total cells: '+ self.md_grass['cells']
self.md_abstract += 'A range of values: min: ' + self.md_grass['min'] + ' max: ' + self.md_grass['max']
def createGrassInspireISO(self):
'''Create valid INSPIRE profile and fill it as much as possible by GRASS metadata. Missing values is $NULL
-create basic md profile and add INSPIRE mandatory attributes
@@ -155,7 +156,9 @@
self.md.identification.keywords.append(kw)
# Conformity/Title
self.md.dataquality.conformancetitle.pop() #remove value from basic profile
- self.md.dataquality.conformancetitle.append('Commission Regulation (EU) No 1089/2010 of 23 November 2010 implementing Directive 2007/2/EC of the European Parliament and of the Council as regards interoperability of spatial data sets and services')
+ self.md.dataquality.conformancetitle.append('Commission Regulation (EU) No 1089/2010 of 23 November 2010 implementing '
+ 'Directive 2007/2/EC of the European Parliament and of the Council as regards '
+ 'interoperability of spatial data sets and services')
# Conformity/Date
self.md.dataquality.conformancedate.append(n)
@@ -180,9 +183,9 @@
n = '$NULL'
- #jinja templates
+ # jinja templates
self.template = 'data/grassBasicISOTemplate.xml'
- #OWSLib md object
+ # OWSLib md object
self.md.identification = MD_DataIdentification()
self.md.dataquality = DQ_DataQuality()
self.md.distribution = MD_Distribution()
@@ -210,11 +213,11 @@
self.md.identification.identtype = 'dataset'
# Identification/Unique Resource Identifier
- #TODO GENERATOR
+ # TODO GENERATOR
self.md.identifier = '286c0725-146e-4533-b1bf-d6e367f6c342'
self.md.identification.uricode.append('286c0725-146e-4533-b1bf-d6e367f6c342')
- #Geographic/BB
+ # Geographic/BB
self.md.identification.extent.boundingBox.minx = self.md_grass['south']
self.md.identification.extent.boundingBox.maxx = self.md_grass['north']
self.md.identification.extent.boundingBox.miny = self.md_grass['west']
@@ -231,7 +234,7 @@
val.type = 'creation'
self.md.identification.date.append(val)
- #different metadata sources for vector and raster
+ # Different metadata sources for vector and raster
if self.type == 'cell':
# Identification/Resource Abstract
self.md.identification.abstract = self.md_abstract
@@ -267,12 +270,12 @@
xml_out_name = str(self.map) + self.schema_type
if not xml_out_name.lower().endswith('.xml'):
xml_out_name +='.xml'
- #if path is None, use lunch. dir
- #TODO change default folder to mapset location
+ # if path is None, use lunch. dir
+ # TODO change default folder to mapset location
if not path:
path = os.path.join(self.dirpath,xml_out_name)
else:
- path = os.path.join(path,xml_out_name)
+ path = os.path.join(path, xml_out_name)
#generate xml using jinja tempaltes
env = Environment(loader=FileSystemLoader(self.dirpath))
@@ -281,17 +284,17 @@
iso_xml = template.render(md=self.md)
xml_file = xml_out_name
- #write xml to flat file
+ # write xml to flat file
try:
xml_file = open(path, "w")
xml_file.write(iso_xml)
xml_file.close()
- Module('g.message', message='metadata exported: \n\
- %s'%(str(path)))
+ grass.message(_('Metadata exported: %s') % (str(path)))
except IOError as e:
print "I/O error({0}): {1}".format(e.errno, e.strerror)
- grass.fatal('error: cannot write xml file')
- return path
+ grass.fatal(_('Unable to write xml file'))
+ return path
def validate_inspire(self):
'''function for validation INSPIRE XML file'''
Modified: sandbox/krejcmat/src/r.info.iso.py
--- sandbox/krejcmat/src/r.info.iso.py 2014-06-20 15:54:48 UTC (rev 60896)
+++ sandbox/krejcmat/src/r.info.iso.py 2014-06-20 16:05:27 UTC (rev 60897)
@@ -27,20 +27,19 @@
#% answer: basic
#%end
-#%option G_OPT_R_MAP
-#% key: mdout
-#% label: Name of output metadata file
+#%option G_OPT_F_OUTPUT
+#% label: Name for output metadata file
#% required: no
#%end
#%option G_OPT_M_DIR
#% key: destination
-#% label: Path to destination folder
+#% label: Path to destination directory
#% required: no
#%end
-from mdgrass import *
+from mdgrass import *
def main():
@@ -53,8 +52,7 @@
mdout = None
else:
mdout=options['mdout']
md = GrassMD(options['map'], 'cell')
if options['profil']=='inspire':
md.createGrassInspireISO()
@@ -64,8 +62,9 @@
else:
md.createGrassBasicISO()
md.saveXML(destination,mdout)
+ return 0
if __name__ == "__main__":
options, flags = parser()
- main()
+ sys.exit(main())
Modified: sandbox/krejcmat/src/v.info.iso.py
--- sandbox/krejcmat/src/v.info.iso.py 2014-06-20 15:54:48 UTC (rev 60896)
+++ sandbox/krejcmat/src/v.info.iso.py 2014-06-20 16:05:27 UTC (rev 60897)
@@ -27,20 +27,20 @@
#% answer: basic
#%end
-#%option G_OPT_V_MAP
-#% key: mdout
#% required: no
#%end
#% key: destination
#% required: no
#%end
def main():
if not options['destination']:
@@ -53,18 +53,19 @@
else:
- #create instance of metadata in owslib
+ # create instance of metadata in owslib
md = GrassMD(options['map'], 'vector')
xml_file=md.saveXML(options['destination'],options['mdout'])
md.readXML(xml_file)
- print md.validate_inspire()
else:
+ return 0
- main()
+ sys.exit(main())
