[GRASS-SVN] r60920 - grass-addons/grass7/raster/r.valley.bottom
svn_grass at osgeo.org
Sun Jun 22 16:10:42 PDT 2014
Author: hellik
Date: 2014-06-22 16:10:42 -0700 (Sun, 22 Jun 2014)
New Revision: 60920
grass-addons/grass7/raster/r.valley.bottom/Makefile
grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.html
grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.py
r.valley.bottom: svn-propset
Modified: grass-addons/grass7/raster/r.valley.bottom/Makefile
--- grass-addons/grass7/raster/r.valley.bottom/Makefile 2014-06-22 23:04:15 UTC (rev 60919)
+++ grass-addons/grass7/raster/r.valley.bottom/Makefile 2014-06-22 23:10:42 UTC (rev 60920)
@@ -1,7 +1,7 @@
-MODULE_TOPDIR = ../..
-PGM = r.valley.bottom
-include $(MODULE_TOPDIR)/include/Make/Script.make
-default: script
+MODULE_TOPDIR = ../..
+PGM = r.valley.bottom
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/raster/r.valley.bottom/Makefile
___________________________________________________________________
Added: svn:mime-type
+ text/x-makefile
Added: svn:eol-style
+ native
Modified: grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.html
--- grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.html 2014-06-22 23:04:15 UTC (rev 60919)
+++ grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.html 2014-06-22 23:10:42 UTC (rev 60920)
@@ -1,49 +1,49 @@
-<h2>DESCRIPTION</h2>
-<p>
-<em>r.valley.bottom</em> calculates a Multi-resolution Valley Bottom
-Flatness (MrVBF) index. The user must specify the input <b>elevation
-raster</b> map.
-</p>
-<h2>EXAMPLE</h2>
-<div class="code">
- <pre>
- # align region to DEM and habitat vector
- g.region -a rast=DEM align=DEM
- # run <em>r.valley.bottom</em>
- r.r.valley.bottom elevation=DEM
- </pre>
-</div>
-<h2>TODO</h2>
-<p>
-Design the script independent of input elevation raster resolution. At
-the moment the input elevation raster map must have a resolution of 25m
-x 25m. Additionally the search window of the elevation percentile may be
-adapted.
-</p>
-<h2>SEE ALSO</h2>
-<em>
-<a href="r.mapcalc.html">r.mapcalc</a>,
-<a href="r.slope.aspect.html">r.slope.aspect</a>
-</em>
-<h2>REFERENCES</h2>
-J.C. Gallant & T.I. Dowling 2003.
-A multiresolution index of valley bottom flatness for mapping depositional areas.
-Water Resources Research, Vol. 39, No. 12, 1347. doi:10.1029/2002WR001426
-<h2>AUTHOR</h2>
-Helmut Kudrnovsky
-<p>
-<i>Last changed: $Date: 2014-05-25 22:16:23 +0200 (So, 25 Mai 2014) $</i>
+<h2>DESCRIPTION</h2>
+<p>
+<em>r.valley.bottom</em> calculates a Multi-resolution Valley Bottom
+Flatness (MrVBF) index. The user must specify the input <b>elevation
+raster</b> map.
+</p>
+<h2>EXAMPLE</h2>
+<div class="code">
+ <pre>
+ # align region to DEM and habitat vector
+ g.region -a rast=DEM align=DEM
+ # run <em>r.valley.bottom</em>
+ r.r.valley.bottom elevation=DEM
+ </pre>
+</div>
+<h2>TODO</h2>
+<p>
+Design the script independent of input elevation raster resolution. At
+the moment the input elevation raster map must have a resolution of 25m
+x 25m. Additionally the search window of the elevation percentile may be
+adapted.
+</p>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.mapcalc.html">r.mapcalc</a>,
+<a href="r.slope.aspect.html">r.slope.aspect</a>
+</em>
+<h2>REFERENCES</h2>
+J.C. Gallant & T.I. Dowling 2003.
+A multiresolution index of valley bottom flatness for mapping depositional areas.
+Water Resources Research, Vol. 39, No. 12, 1347. doi:10.1029/2002WR001426
+<h2>AUTHOR</h2>
+Helmut Kudrnovsky
+<p>
+<i>Last changed: $Date$</i>
</p>
\ No newline at end of file
Property changes on: grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Modified: grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.py
--- grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.py 2014-06-22 23:04:15 UTC (rev 60919)
+++ grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.py 2014-06-22 23:10:42 UTC (rev 60920)
@@ -1,574 +1,574 @@
-#!/usr/bin/env python
-MODULE: r.valley.bottom
-AUTHOR(S): Helmut Kudrnovsky <alectoria AT gmx at>
-PURPOSE: Calculates Multi-resolution Valley Bottom Flatness (MrVBF) index
- Index is inspired by
- John C. Gallant and Trevor I. Dowling 2003.
- A multiresolution index of valley bottom flatness for mapping depositional areas.
- WATER RESOURCES RESEARCH, VOL. 39, NO. 12, 1347, doi:10.1029/2002WR001426, 2003
-COPYRIGHT: (C) 2014 by the GRASS Development Team
- This program is free software under the GNU General Public
- License (>=v2). Read the file COPYING that comes with GRASS
- for details.
-#%module
-#% description: Calculation of Multi-resolution Valley Bottom Flatness (MrVBF) index
-#% keywords: raster
-#% keywords: terrain
-#%end
-#%option G_OPT_R_ELEV
-#% key: elevation
-#% description: Name of elevation raster map
-#% required: yes
-#%end
-import sys
-import os
-import grass.script as grass
-import math
-if not os.environ.has_key("GISBASE"):
- grass.message( "You must be in GRASS GIS to run this program." )
- sys.exit(1)
-def main():
- r_elevation = options['elevation'].split('@')[0] # elevation raster
- r_slope_degree = r_elevation+'_slope_degree' # slope (percent) step 1
- # Region settings
- current_region = grass.region()
- Yres_base = current_region['nsres']
- Xres_base = current_region['ewres']
- grass.message( "Finest scale calculations" )
- grass.message( "Original resolution: %s x %s" % (Xres_base, Yres_base))
- grass.run_command('g.region', flags = 'p', save = "base_region_MrVBF", overwrite = True)
- # Region settings step 3: resolution 3 x base resolution
- Yres_step3 = Yres_base * 3
- Xres_step3 = Xres_base * 3
- # Region settings step 4: resolution 4 x Xres_step3
- Yres_step4 = Yres_step3 * 3
- Xres_step4 = Xres_step3 * 3
- # Step 1 (S1)
- # Finest-Scale Step
- # Calculation of slope step 1
- # 100 * tan (slope in degree)
- grass.message( "----" )
- grass.message( "Step 1: Calculation of slope" )
- grass.message( "..." )
- grass.run_command('r.slope.aspect', elevation = r_elevation,
- slope = r_slope_degree,
- format = "degrees",
- precision = "DCELL",
- zfactor = 1.0,
- overwrite = True)
- grass.mapcalc("$outmap = 100 * tan($slope) ",
- outmap = "r_slope_step1",
- slope = r_slope_degree)
- grass.run_command("g.remove", rast = r_slope_degree,
- quiet = True)
- grass.message( "Step 1: Calculation of slope done." )
- # Calculation of flatness 1 (0 to 1)
- # Flatness F1 = 1 / (1 + pow ((slope / 16), 4)
- grass.message( "Step 1: Calculation of flatness F1" )
- grass.mapcalc("F1 = 1.0 / (1.0 + pow( ( $slope / 16.0 ) ,4 ) )",
- slope = "r_slope_step1")
- grass.message( "Step 1: Calculation of flatness F1 done." )
- # Calculation of elevation percentile PCTL1 step 1
- # elevation percentile: ratio of the number of points of lower
- # elevation to the total number of points in the surrounding region
- # elevation of percentile step 1: radius of 3 cells
- grass.message( "Step 1: Calculation of elevation percentile PCTL1" )
- grass.mapcalc("elevation_step1 = $r_elevation",
- r_elevation = r_elevation)
- offsets = [d
- for j in xrange(1,3+1)
- for i in [j,-j]
- for d in [(i,0),(0,i),(i,i),(i,-i)]]
- terms = ["(elevation_step1[%d,%d] < elevation_step1)" % d
- for d in offsets]
- expr1 = "PCTL1 = (100.0 / 24.0) * (%s)" % " + ".join(terms)
- grass.mapcalc( expr1 )
- grass.message( "Step 1: Calculation of elevation percentile PCTL1 done" )
- # Elevation percentile is transformed to a local lowness value using
- # equation (1) with t = 0.4 and p = 3, and then combined with
- # flatness F1 to produce the preliminary valley flatness index
- # (PVF1) for the first step:
- grass.message( "Step 1: Calculation of preliminary valley flatness index PVF1" )
- grass.mapcalc("PVF1 = F1 * (1.0 / (1.0 + pow ( ( PCTL1 / 0.4 ), 3 ) ) )")
- grass.message( "Step 1: Calculation of preliminary valley flatness index PVF1 done." )
- # Calculation of the valley flatness step 1 VF1
- # larger values of VF1 indicate increasing valley bottom character
- # with values less than 0.5 considered not to be in valley bottoms
- grass.message( "Step 1: Calculation of valley flatness VF1" )
- grass.mapcalc("VF1 = 1 - (1.0 / (1.0 + pow ( ( PVF1 / 0.3 ), 4 ) ) )")
- grass.message( "Step 1: Calculation of valley flatness VF1 done." )
- # Step 2 (S2)
- # base scale resolution
- grass.message( "Step 2" )
- grass.message( "base resolution: %s x %s" % (Xres_base, Yres_base))
- # The second step commences the same way with the
- # original DEM at its base resolution, using a slope threshold ts,2 half of ts,1:
- # Flatness F2 = 1 / (1 + pow ((slope / 8), 4)
- grass.message( "Step 2: Calculation of flatness F2" )
- grass.mapcalc("F2 = 1.0 / (1.0 + pow( ( $slope / 8.0 ) ,4 ) )",
- grass.message( "Step 2: Calculation of flatness F2 done" )
- # Calculation of elevation percentile PCTL2 step 2
- # elevation of percentile step 2: radius of 3 cells
- grass.message( "Step 2: Calculation of elevation percentile PCTL2" )
- offsets2 = [d
- for j in xrange(1,6+1)
- for i in [j,-j]
- terms2 = ["(elevation_step1[%d,%d] < elevation_step1)" % d
- for d in offsets2]
- expr2 = "PCTL2 = (100.0 / 48.0) * (%s)" % " + ".join(terms2)
- grass.mapcalc( expr2 )
- grass.run_command("g.remove", rast = "elevation_step1",
- quiet = True)
- grass.message( "Step 2: Calculation of elevation percentile PCTL2 done" )
- # PVF2 for step 2:
- grass.message( "Step 2: Calculation of preliminary valley flatness index PVF2" )
- grass.mapcalc("PVF2 = F2 * (1.0 / (1.0 + pow ( ( PCTL2 / 0.4 ), 3 ) ) )")
- grass.message( "Step 2: Calculation of preliminary valley flatness index PVF2 done." )
- # Calculation of the valley flatness step 2 VF2
- grass.message( "Step 2: Calculation of valley flatness VF2" )
- grass.mapcalc("VF2 = 1 - (1.0 / (1.0 + pow ( ( PVF2 / 0.3 ), 4 ) ) )")
- grass.message( "Step 2: Calculation of valley flatness VF2 done." )
- # Calculation of weight W2
- grass.message( "Step 2: Calculation of weight W2" )
- grass.mapcalc("W2 = 1 - (1.0 / (1.0 + pow ( ( VF2 / 0.4 ), 6.68 ) ) )")
- grass.message( "Step 2: Calculation of weight W2 done." )
- # Calculation of MRVBF2
- grass.message( "Step 2: Calculation of MRVBF2" )
- grass.mapcalc("MRVBF2 = (W2 * (1 + VF2)) + ((1 - W2) * VF1)")
- grass.message( "Step 2: Calculation of MRVBF2 done." )
- # Calculation of combined flatness index CF2
- grass.message( "Step 2: Calculation of combined flatness index CF2" )
- grass.mapcalc("CF2 = F1 * F2")
- grass.message( "Step 2: Calculation of combined flatness index CF2 done." )
- # step 2 finished
- grass.message( "Step 2 calculations done." )
- # remaining steps
- grass.message( "two remaining steps" )
- # Step 3
- grass.message( "Step 3" )
- # DEM smoothing 11 x 11 windows with Gaussian smoothing kernel (sigma) 3 x 3 -> change resolution (3 x base resolution) -> calculations
- # DEM smoothing
- grass.message( "Step 3: DEM smoothing 11 x 11 windows with Gaussian smoothing kernel (sigma) 3" )
- grass.run_command('r.neighbors', input = r_elevation,
- output = "DEM_smoothed_step3",
- size = 11,
- gauss=3)
- grass.message( "Step 3 DEM smoothing 11 x 11 windows with Gaussian smoothing kernel (sigma) 3 done." )
- # Calculate slope step 3
- grass.message( "Step 3: Calculation of slope" )
- grass.run_command('r.slope.aspect', elevation = "DEM_smoothed_step3",
- slope = "DEM_smoothed_step3_slope_degree",
- zfactor = 1.0,
- overwrite = True)
- outmap = "r_slope_step3",
- slope = "DEM_smoothed_step3_slope_degree")
- grass.run_command('g.remove', rast = "DEM_smoothed_step3_slope_degree",
- quiet = True)
- grass.message( "Step 3: Calculation of slope done." )
- # change resolution
- grass.message( "Step 3: change to resolution to 3 x base resolution" )
- grass.run_command('g.region', res = Xres_step3,
- flags = 'a')
- current_region_step3 = grass.region()
- Y_step3 = current_region_step3['nsres']
- X_step3 = current_region_step3['ewres']
- grass.message( "Resolution step 3: %s x %s" % (X_step3, Y_step3))
- # coarsening DEM to resolution step 3 and calculate PCTL3 step 3
- grass.message( "Step 3: Calculation of elevation percentile PCTL3" )
- grass.mapcalc("DEM_smoothed_step3_coarsed = DEM_smoothed_step3")
- offsets3 = [d
- for i in [j,-j]
- terms3 = ["(DEM_smoothed_step3_coarsed[%d,%d] < DEM_smoothed_step3_coarsed)" % d
- for d in offsets3]
- expr3 = "PCTL3 = (100.0 / 48.0) * (%s)" % " + ".join(terms3)
- grass.mapcalc( expr3 )
- grass.message( "Step 3: Calculation of elevation percentile PCTL3 done." )
- # switch back to base resolution
- grass.message( "Step 3: switch back to base resolution." )
- grass.run_command('g.region', rast = r_elevation,
- align = r_elevation,
- flags = 'a')
- current_region_step3_switched_back = grass.region()
- Y_step3_switched_back = current_region_step3_switched_back['nsres']
- X_step3_switched_back = current_region_step3_switched_back['ewres']
- grass.message( "Resolution step 3: %s x %s" % (X_step3_switched_back, Y_step3_switched_back))
- # resample/refine PCTL3 to base resolution
- grass.message( "Step 3: refine PCTL3 to base resolution" )
- grass.run_command('r.resamp.interp', input = "PCTL3",
- output = "PCTL3_refined_base_resolution",
- method = "bilinear")
- grass.message( "Step 3: refine PCTL3 to base resolution done." )
- # calculate flatness F3 at the base resolution
- grass.message( "Step 3: calculate F3 at base resolution" )
- grass.mapcalc("F3 = 1.0 / (1.0 + pow( ( $slope / 8.0 ) ,4 ) )",
- slope = "r_slope_step3")
- grass.message( "Step 3: calculate F3 at base resolution done." )
- # calculate accumulated combined flatness CF3 at the base resolution
- grass.message( "Step 3: calculate combined flatness CF3 at base resolution" )
- grass.mapcalc("CF3 = CF2 * F3")
- grass.message( "Step 3: calculate combined flatness CF3 at base resolution done." )
- # calculate preliminary valley flatness index PVF3 at the base resolution
- grass.message( "Step 3: calculate preliminary valley flatness index PVF3 at base resolution" )
- grass.mapcalc("PVF3 = CF3 * (1.0 / (1.0 + pow ( ( PCTL3_refined_base_resolution / 0.4 ), 3 ) ) )")
- grass.message( "Step 3: calculate preliminary valley flatness index PVF3 at base resolution done." )
- # calculate valley flatness index VF3
- grass.message( "Step 3: calculate valley flatness index VF3 at base resolution" )
- grass.mapcalc("VF3 = 1 - (1.0 / (1.0 + pow ( ( PVF3 / 0.3 ), 4 ) ) )")
- grass.message( "Step 3: calculate valley flatness index VF3 at base resolution done." )
- # Calculation of weight W3
- grass.message( "Step 3: Calculation of weight W3" )
- p3 = (math.log10((3 - 0.5) / 0.1)) / math.log10(1.5)
- grass.mapcalc("W3 = 1 - (1.0 / (1.0 + pow ( ( VF3 / 0.4 ), $p ) ) )", p = p3)
- grass.message( "Step 3: Calculation of weight W3 done." )
- # Calculation of MRVBF3
- grass.message( "Step 3: Calculation of MRVBF3" )
- grass.mapcalc("MRVBF3 = (W3 * (3 - 1 + VF3)) + ((1 - W3) * MRVBF2)")
- grass.message( "Step 3: Calculation of MRVBF3 done." )
- # Step 4
- grass.message( "Step 4" )
- grass.message( "Step 4: change to resolution of step 3" )
- flags = 'a')
- grass.message( "Resolution 1 for step 4: %s x %s" % (X_step3, Y_step3))
- # DEM smoothing
- grass.message( "Step 4: DEM smoothing 11 x 11 windows with Gaussian smoothing kernel (sigma) 3" )
- grass.run_command('r.neighbors', input = "DEM_smoothed_step3_coarsed",
- output = "DEM_smoothed_step4",
- size = 11,
- gauss=3)
- grass.message( "Step 4 DEM smoothing 11 x 11 windows with Gaussian smoothing kernel (sigma) 3 done." )
- # Calculate slope step 4
- grass.message( "Step 4: Calculation of slope" )
- grass.run_command('r.slope.aspect', elevation = "DEM_smoothed_step4",
- slope = "DEM_smoothed_step4_slope_degree",
- zfactor = 1.0,
- overwrite = True)
- outmap = "r_slope_step4",
- slope = "DEM_smoothed_step4_slope_degree")
- grass.run_command('g.remove', rast = "DEM_smoothed_step4_slope_degree",
- quiet = True)
- grass.message( "Step 4: Calculation of slope done." )
- grass.message( "Step 4: change to resolution to 3 x 3 step 3 resolution" )
- grass.run_command('g.region', res = Xres_step4,
- flags = 'a')
- current_region_step4 = grass.region()
- Y_step4 = current_region_step4['nsres']
- X_step4 = current_region_step4['ewres']
- grass.message( "Resolution step 3: %s x %s" % (X_step4, Y_step4))
- # coarsening DEM to resolution step 4 and calculate PCTL step 4
- grass.message( "Step 4: Calculation of elevation percentile PCTL4" )
- grass.mapcalc("DEM_smoothed_step4_coarsed = DEM_smoothed_step4")
- offsets4 = [d
- for i in [j,-j]
- terms4 = ["(DEM_smoothed_step4_coarsed[%d,%d] < DEM_smoothed_step4_coarsed)" % d
- for d in offsets4]
- expr4 = "PCTL4 = (100.0 / 48.0) * (%s)" % " + ".join(terms4)
- grass.mapcalc( expr4 )
- grass.message( "Step 4: Calculation of elevation percentile PCTL4 done." )
- grass.message( "Step 4: switch back to base resolution." )
- flags = 'a')
- current_region_step4_switched_back = grass.region()
- Y_step4_switched_back = current_region_step4_switched_back['nsres']
- X_step4_switched_back = current_region_step4_switched_back['ewres']
- grass.message( "Resolution step 4: %s x %s" % (X_step4_switched_back, Y_step4_switched_back))
- # resample/refine PCTL4 to base resolution
- grass.message( "Step 4: refine PCTL4 to base resolution" )
- grass.run_command('r.resamp.interp', input = "PCTL4",
- output = "PCTL4_refined_base_resolution",
- grass.message( "Step 4: refine PCTL4 to base resolution done." )
- # calculate flatness F4 at the base resolution
- grass.message( "Step 4: calculate F4 at base resolution" )
- grass.run_command('r.resamp.interp', input = "r_slope_step4",
- output = "r_slope_step4_refined_base_resolution",
- grass.mapcalc("F4 = 1.0 / (1.0 + pow( ( $slope / 4.0 ) ,4 ) )",
- slope = "r_slope_step4_refined_base_resolution")
- grass.message( "Step 4: calculate F4 at base resolution done." )
- grass.message( "Step 4: calculate combined flatness CF4 at base resolution" )
- grass.mapcalc("CF4 = CF3 * F4")
- grass.message( "Step 4: calculate combined flatness CF4 at base resolution done." )
- grass.message( "Step 4: calculate preliminary valley flatness index PVF4 at base resolution" )
- grass.mapcalc("PVF4 = CF4 * (1.0 / (1.0 + pow ( ( PCTL4_refined_base_resolution / 0.4 ), 3 ) ) )")
- grass.message( "Step 4: calculate preliminary valley flatness index PVF4 at base resolution done." )
- # calculate valley flatness index VF4
- grass.message( "Step 4: calculate valley flatness index VF4 at base resolution" )
- grass.mapcalc("VF4 = 1 - (1.0 / (1.0 + pow ( ( PVF4 / 0.3 ), 4 ) ) )")
- grass.message( "Step 4: calculate valley flatness index VF4 at base resolution done." )
- # Calculation of weight W4
- grass.message( "Step 4: Calculation of weight W4" )
- p4 = (math.log10((4 - 0.5) / 0.1)) / math.log10(1.5)
- grass.mapcalc("W4 = 1 - (1.0 / (1.0 + pow ( ( VF4 / 0.4 ), $p ) ) )", p = p3)
- grass.message( "Step 4: Calculation of weight W4 done." )
- # Calculation of MRVBF4
- grass.message( "Step 4: Calculation of MRVBF4" )
- grass.mapcalc("MRVBF4 = (W4 * (3 - 1 + VF4)) + ((1 - W4) * MRVBF3)")
- grass.message( "Step 4: Calculation of MRVBF4 done." )
-if __name__ == "__main__":
- options, flags = grass.parser()
- sys.exit(main())
+#!/usr/bin/env python
+MODULE: r.valley.bottom
+AUTHOR(S): Helmut Kudrnovsky <alectoria AT gmx at>
+PURPOSE: Calculates Multi-resolution Valley Bottom Flatness (MrVBF) index
+ Index is inspired by
+ John C. Gallant and Trevor I. Dowling 2003.
+ A multiresolution index of valley bottom flatness for mapping depositional areas.
+ WATER RESOURCES RESEARCH, VOL. 39, NO. 12, 1347, doi:10.1029/2002WR001426, 2003
+COPYRIGHT: (C) 2014 by the GRASS Development Team
+ This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+#%module
+#% description: Calculation of Multi-resolution Valley Bottom Flatness (MrVBF) index
+#% keywords: raster
+#% keywords: terrain
+#%end
+#%option G_OPT_R_ELEV
+#% key: elevation
+#% description: Name of elevation raster map
+#% required: yes
+#%end
+import sys
+import os
+import grass.script as grass
+import math
+if not os.environ.has_key("GISBASE"):
+ grass.message( "You must be in GRASS GIS to run this program." )
+ sys.exit(1)
+def main():
+ r_elevation = options['elevation'].split('@')[0] # elevation raster
+ r_slope_degree = r_elevation+'_slope_degree' # slope (percent) step 1
+ # Region settings
+ current_region = grass.region()
+ Yres_base = current_region['nsres']
+ Xres_base = current_region['ewres']
+ grass.message( "Finest scale calculations" )
+ grass.message( "Original resolution: %s x %s" % (Xres_base, Yres_base))
+ grass.run_command('g.region', flags = 'p', save = "base_region_MrVBF", overwrite = True)
+ # Region settings step 3: resolution 3 x base resolution
+ Yres_step3 = Yres_base * 3
+ Xres_step3 = Xres_base * 3
+ # Region settings step 4: resolution 4 x Xres_step3
+ Yres_step4 = Yres_step3 * 3
+ Xres_step4 = Xres_step3 * 3
+ # Step 1 (S1)
+ # Finest-Scale Step
+ # Calculation of slope step 1
+ # 100 * tan (slope in degree)
+ grass.message( "----" )
+ grass.message( "Step 1: Calculation of slope" )
+ grass.message( "..." )
+ grass.run_command('r.slope.aspect', elevation = r_elevation,
+ slope = r_slope_degree,
+ format = "degrees",
+ precision = "DCELL",
+ zfactor = 1.0,
+ overwrite = True)
+ grass.mapcalc("$outmap = 100 * tan($slope) ",
+ outmap = "r_slope_step1",
+ slope = r_slope_degree)
+ grass.run_command("g.remove", rast = r_slope_degree,
+ quiet = True)
+ grass.message( "Step 1: Calculation of slope done." )
+ # Calculation of flatness 1 (0 to 1)
+ # Flatness F1 = 1 / (1 + pow ((slope / 16), 4)
+ grass.message( "Step 1: Calculation of flatness F1" )
+ grass.mapcalc("F1 = 1.0 / (1.0 + pow( ( $slope / 16.0 ) ,4 ) )",
+ slope = "r_slope_step1")
+ grass.message( "Step 1: Calculation of flatness F1 done." )
+ # Calculation of elevation percentile PCTL1 step 1
+ # elevation percentile: ratio of the number of points of lower
+ # elevation to the total number of points in the surrounding region
+ # elevation of percentile step 1: radius of 3 cells
+ grass.message( "Step 1: Calculation of elevation percentile PCTL1" )
+ grass.mapcalc("elevation_step1 = $r_elevation",
+ r_elevation = r_elevation)
+ offsets = [d
+ for j in xrange(1,3+1)
+ for i in [j,-j]
+ for d in [(i,0),(0,i),(i,i),(i,-i)]]
+ terms = ["(elevation_step1[%d,%d] < elevation_step1)" % d
+ for d in offsets]
+ expr1 = "PCTL1 = (100.0 / 24.0) * (%s)" % " + ".join(terms)
+ grass.mapcalc( expr1 )
+ grass.message( "Step 1: Calculation of elevation percentile PCTL1 done" )
+ # Elevation percentile is transformed to a local lowness value using
+ # equation (1) with t = 0.4 and p = 3, and then combined with
+ # flatness F1 to produce the preliminary valley flatness index
+ # (PVF1) for the first step:
+ grass.message( "Step 1: Calculation of preliminary valley flatness index PVF1" )
+ grass.mapcalc("PVF1 = F1 * (1.0 / (1.0 + pow ( ( PCTL1 / 0.4 ), 3 ) ) )")
+ grass.message( "Step 1: Calculation of preliminary valley flatness index PVF1 done." )
+ # Calculation of the valley flatness step 1 VF1
+ # larger values of VF1 indicate increasing valley bottom character
+ # with values less than 0.5 considered not to be in valley bottoms
+ grass.message( "Step 1: Calculation of valley flatness VF1" )
+ grass.mapcalc("VF1 = 1 - (1.0 / (1.0 + pow ( ( PVF1 / 0.3 ), 4 ) ) )")
+ grass.message( "Step 1: Calculation of valley flatness VF1 done." )
+ # Step 2 (S2)
+ # base scale resolution
+ grass.message( "Step 2" )
+ grass.message( "base resolution: %s x %s" % (Xres_base, Yres_base))
+ # The second step commences the same way with the
+ # original DEM at its base resolution, using a slope threshold ts,2 half of ts,1:
+ # Flatness F2 = 1 / (1 + pow ((slope / 8), 4)
+ grass.message( "Step 2: Calculation of flatness F2" )
+ grass.mapcalc("F2 = 1.0 / (1.0 + pow( ( $slope / 8.0 ) ,4 ) )",
+ grass.message( "Step 2: Calculation of flatness F2 done" )
+ # Calculation of elevation percentile PCTL2 step 2
+ # elevation of percentile step 2: radius of 3 cells
+ grass.message( "Step 2: Calculation of elevation percentile PCTL2" )
+ offsets2 = [d
+ for j in xrange(1,6+1)
+ for i in [j,-j]
+ terms2 = ["(elevation_step1[%d,%d] < elevation_step1)" % d
+ for d in offsets2]
+ expr2 = "PCTL2 = (100.0 / 48.0) * (%s)" % " + ".join(terms2)
+ grass.mapcalc( expr2 )
+ grass.run_command("g.remove", rast = "elevation_step1",
+ quiet = True)
+ grass.message( "Step 2: Calculation of elevation percentile PCTL2 done" )
+ # PVF2 for step 2:
+ grass.message( "Step 2: Calculation of preliminary valley flatness index PVF2" )
+ grass.mapcalc("PVF2 = F2 * (1.0 / (1.0 + pow ( ( PCTL2 / 0.4 ), 3 ) ) )")
+ grass.message( "Step 2: Calculation of preliminary valley flatness index PVF2 done." )
+ # Calculation of the valley flatness step 2 VF2
+ grass.message( "Step 2: Calculation of valley flatness VF2" )
+ grass.mapcalc("VF2 = 1 - (1.0 / (1.0 + pow ( ( PVF2 / 0.3 ), 4 ) ) )")
+ grass.message( "Step 2: Calculation of valley flatness VF2 done." )
+ # Calculation of weight W2
+ grass.message( "Step 2: Calculation of weight W2" )
+ grass.mapcalc("W2 = 1 - (1.0 / (1.0 + pow ( ( VF2 / 0.4 ), 6.68 ) ) )")
+ grass.message( "Step 2: Calculation of weight W2 done." )
+ # Calculation of MRVBF2
+ grass.message( "Step 2: Calculation of MRVBF2" )
+ grass.mapcalc("MRVBF2 = (W2 * (1 + VF2)) + ((1 - W2) * VF1)")
+ grass.message( "Step 2: Calculation of MRVBF2 done." )
+ # Calculation of combined flatness index CF2
+ grass.message( "Step 2: Calculation of combined flatness index CF2" )
+ grass.mapcalc("CF2 = F1 * F2")
+ grass.message( "Step 2: Calculation of combined flatness index CF2 done." )
+ # step 2 finished
+ grass.message( "Step 2 calculations done." )
+ # remaining steps
+ grass.message( "two remaining steps" )
+ # Step 3
+ grass.message( "Step 3" )
+ # DEM smoothing 11 x 11 windows with Gaussian smoothing kernel (sigma) 3 x 3 -> change resolution (3 x base resolution) -> calculations
+ # DEM smoothing
+ grass.message( "Step 3: DEM smoothing 11 x 11 windows with Gaussian smoothing kernel (sigma) 3" )
+ grass.run_command('r.neighbors', input = r_elevation,
+ output = "DEM_smoothed_step3",
+ size = 11,
+ gauss=3)
+ grass.message( "Step 3 DEM smoothing 11 x 11 windows with Gaussian smoothing kernel (sigma) 3 done." )
+ # Calculate slope step 3
+ grass.message( "Step 3: Calculation of slope" )
+ grass.run_command('r.slope.aspect', elevation = "DEM_smoothed_step3",
+ slope = "DEM_smoothed_step3_slope_degree",
+ zfactor = 1.0,
+ overwrite = True)
+ outmap = "r_slope_step3",
+ slope = "DEM_smoothed_step3_slope_degree")
+ grass.run_command('g.remove', rast = "DEM_smoothed_step3_slope_degree",
+ quiet = True)
+ grass.message( "Step 3: Calculation of slope done." )
+ # change resolution
+ grass.message( "Step 3: change to resolution to 3 x base resolution" )
+ grass.run_command('g.region', res = Xres_step3,
+ flags = 'a')
+ current_region_step3 = grass.region()
+ Y_step3 = current_region_step3['nsres']
+ X_step3 = current_region_step3['ewres']
+ grass.message( "Resolution step 3: %s x %s" % (X_step3, Y_step3))
+ # coarsening DEM to resolution step 3 and calculate PCTL3 step 3
+ grass.message( "Step 3: Calculation of elevation percentile PCTL3" )
+ grass.mapcalc("DEM_smoothed_step3_coarsed = DEM_smoothed_step3")
+ offsets3 = [d
+ for i in [j,-j]
+ terms3 = ["(DEM_smoothed_step3_coarsed[%d,%d] < DEM_smoothed_step3_coarsed)" % d
+ for d in offsets3]
+ expr3 = "PCTL3 = (100.0 / 48.0) * (%s)" % " + ".join(terms3)
+ grass.mapcalc( expr3 )
+ grass.message( "Step 3: Calculation of elevation percentile PCTL3 done." )
+ # switch back to base resolution
+ grass.message( "Step 3: switch back to base resolution." )
+ grass.run_command('g.region', rast = r_elevation,
+ align = r_elevation,
+ flags = 'a')
+ current_region_step3_switched_back = grass.region()
+ Y_step3_switched_back = current_region_step3_switched_back['nsres']
+ X_step3_switched_back = current_region_step3_switched_back['ewres']
+ grass.message( "Resolution step 3: %s x %s" % (X_step3_switched_back, Y_step3_switched_back))
+ # resample/refine PCTL3 to base resolution
+ grass.message( "Step 3: refine PCTL3 to base resolution" )
+ grass.run_command('r.resamp.interp', input = "PCTL3",
+ output = "PCTL3_refined_base_resolution",
+ method = "bilinear")
+ grass.message( "Step 3: refine PCTL3 to base resolution done." )
+ # calculate flatness F3 at the base resolution
+ grass.message( "Step 3: calculate F3 at base resolution" )
+ grass.mapcalc("F3 = 1.0 / (1.0 + pow( ( $slope / 8.0 ) ,4 ) )",
+ slope = "r_slope_step3")
+ grass.message( "Step 3: calculate F3 at base resolution done." )
+ # calculate accumulated combined flatness CF3 at the base resolution
+ grass.message( "Step 3: calculate combined flatness CF3 at base resolution" )
+ grass.mapcalc("CF3 = CF2 * F3")
+ grass.message( "Step 3: calculate combined flatness CF3 at base resolution done." )
+ # calculate preliminary valley flatness index PVF3 at the base resolution
+ grass.message( "Step 3: calculate preliminary valley flatness index PVF3 at base resolution" )
+ grass.mapcalc("PVF3 = CF3 * (1.0 / (1.0 + pow ( ( PCTL3_refined_base_resolution / 0.4 ), 3 ) ) )")
+ grass.message( "Step 3: calculate preliminary valley flatness index PVF3 at base resolution done." )
+ # calculate valley flatness index VF3
+ grass.message( "Step 3: calculate valley flatness index VF3 at base resolution" )
+ grass.mapcalc("VF3 = 1 - (1.0 / (1.0 + pow ( ( PVF3 / 0.3 ), 4 ) ) )")
+ grass.message( "Step 3: calculate valley flatness index VF3 at base resolution done." )
+ # Calculation of weight W3
+ grass.message( "Step 3: Calculation of weight W3" )
+ p3 = (math.log10((3 - 0.5) / 0.1)) / math.log10(1.5)
+ grass.mapcalc("W3 = 1 - (1.0 / (1.0 + pow ( ( VF3 / 0.4 ), $p ) ) )", p = p3)
+ grass.message( "Step 3: Calculation of weight W3 done." )
+ # Calculation of MRVBF3
+ grass.message( "Step 3: Calculation of MRVBF3" )
+ grass.mapcalc("MRVBF3 = (W3 * (3 - 1 + VF3)) + ((1 - W3) * MRVBF2)")
+ grass.message( "Step 3: Calculation of MRVBF3 done." )
+ # Step 4
+ grass.message( "Step 4" )
+ grass.message( "Step 4: change to resolution of step 3" )
+ flags = 'a')
+ grass.message( "Resolution 1 for step 4: %s x %s" % (X_step3, Y_step3))
+ # DEM smoothing
+ grass.message( "Step 4: DEM smoothing 11 x 11 windows with Gaussian smoothing kernel (sigma) 3" )
+ grass.run_command('r.neighbors', input = "DEM_smoothed_step3_coarsed",
+ output = "DEM_smoothed_step4",
+ size = 11,
+ gauss=3)
+ grass.message( "Step 4 DEM smoothing 11 x 11 windows with Gaussian smoothing kernel (sigma) 3 done." )
+ # Calculate slope step 4
+ grass.message( "Step 4: Calculation of slope" )
+ grass.run_command('r.slope.aspect', elevation = "DEM_smoothed_step4",
+ slope = "DEM_smoothed_step4_slope_degree",
+ zfactor = 1.0,
+ overwrite = True)
+ outmap = "r_slope_step4",
+ slope = "DEM_smoothed_step4_slope_degree")
+ grass.run_command('g.remove', rast = "DEM_smoothed_step4_slope_degree",
+ quiet = True)
+ grass.message( "Step 4: Calculation of slope done." )
+ grass.message( "Step 4: change to resolution to 3 x 3 step 3 resolution" )
+ grass.run_command('g.region', res = Xres_step4,
+ flags = 'a')
+ current_region_step4 = grass.region()
+ Y_step4 = current_region_step4['nsres']
+ X_step4 = current_region_step4['ewres']
+ grass.message( "Resolution step 3: %s x %s" % (X_step4, Y_step4))
+ # coarsening DEM to resolution step 4 and calculate PCTL step 4
+ grass.message( "Step 4: Calculation of elevation percentile PCTL4" )
+ grass.mapcalc("DEM_smoothed_step4_coarsed = DEM_smoothed_step4")
+ offsets4 = [d
+ for i in [j,-j]
+ terms4 = ["(DEM_smoothed_step4_coarsed[%d,%d] < DEM_smoothed_step4_coarsed)" % d
+ for d in offsets4]
+ expr4 = "PCTL4 = (100.0 / 48.0) * (%s)" % " + ".join(terms4)
+ grass.mapcalc( expr4 )
+ grass.message( "Step 4: Calculation of elevation percentile PCTL4 done." )
+ grass.message( "Step 4: switch back to base resolution." )
+ flags = 'a')
+ current_region_step4_switched_back = grass.region()
+ Y_step4_switched_back = current_region_step4_switched_back['nsres']
+ X_step4_switched_back = current_region_step4_switched_back['ewres']
+ grass.message( "Resolution step 4: %s x %s" % (X_step4_switched_back, Y_step4_switched_back))
+ # resample/refine PCTL4 to base resolution
+ grass.message( "Step 4: refine PCTL4 to base resolution" )
+ grass.run_command('r.resamp.interp', input = "PCTL4",
+ output = "PCTL4_refined_base_resolution",
+ grass.message( "Step 4: refine PCTL4 to base resolution done." )
+ # calculate flatness F4 at the base resolution
+ grass.message( "Step 4: calculate F4 at base resolution" )
+ grass.run_command('r.resamp.interp', input = "r_slope_step4",
+ output = "r_slope_step4_refined_base_resolution",
+ grass.mapcalc("F4 = 1.0 / (1.0 + pow( ( $slope / 4.0 ) ,4 ) )",
+ slope = "r_slope_step4_refined_base_resolution")
+ grass.message( "Step 4: calculate F4 at base resolution done." )
+ grass.message( "Step 4: calculate combined flatness CF4 at base resolution" )
+ grass.mapcalc("CF4 = CF3 * F4")
+ grass.message( "Step 4: calculate combined flatness CF4 at base resolution done." )
+ grass.message( "Step 4: calculate preliminary valley flatness index PVF4 at base resolution" )
+ grass.mapcalc("PVF4 = CF4 * (1.0 / (1.0 + pow ( ( PCTL4_refined_base_resolution / 0.4 ), 3 ) ) )")
+ grass.message( "Step 4: calculate preliminary valley flatness index PVF4 at base resolution done." )
+ # calculate valley flatness index VF4
+ grass.message( "Step 4: calculate valley flatness index VF4 at base resolution" )
+ grass.mapcalc("VF4 = 1 - (1.0 / (1.0 + pow ( ( PVF4 / 0.3 ), 4 ) ) )")
+ grass.message( "Step 4: calculate valley flatness index VF4 at base resolution done." )
+ # Calculation of weight W4
+ grass.message( "Step 4: Calculation of weight W4" )
+ p4 = (math.log10((4 - 0.5) / 0.1)) / math.log10(1.5)
+ grass.mapcalc("W4 = 1 - (1.0 / (1.0 + pow ( ( VF4 / 0.4 ), $p ) ) )", p = p3)
+ grass.message( "Step 4: Calculation of weight W4 done." )
+ # Calculation of MRVBF4
+ grass.message( "Step 4: Calculation of MRVBF4" )
+ grass.mapcalc("MRVBF4 = (W4 * (3 - 1 + VF4)) + ((1 - W4) * MRVBF3)")
+ grass.message( "Step 4: Calculation of MRVBF4 done." )
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ sys.exit(main())
Property changes on: grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.py
+ text/x-python
+ native
