[GRASS-SVN] r60922 - grass/trunk/raster/r.spread
svn_grass at osgeo.org
Sun Jun 22 18:36:47 PDT 2014
Author: wenzeslaus
Date: 2014-06-22 18:36:47 -0700 (Sun, 22 Jun 2014)
New Revision: 60922
grass/trunk/raster/r.spread/collect_ori.c
grass/trunk/raster/r.spread/local_proto.h
grass/trunk/raster/r.spread/main.c
r.spread: add a flag (-i) to use start raster map values instead of init time
Modified: grass/trunk/raster/r.spread/collect_ori.c
--- grass/trunk/raster/r.spread/collect_ori.c 2014-06-22 23:19:51 UTC (rev 60921)
+++ grass/trunk/raster/r.spread/collect_ori.c 2014-06-23 01:36:47 UTC (rev 60922)
@@ -43,7 +43,13 @@
int x_out;
int y_out;
-void collect_ori(int start_fd)
+ * \param start_fd start raster map
+ * \param start_is_time 1 if start map values should be used instead of init_time
+ * Other variables passed as global variables.
+void collect_ori(int start_fd, int start_is_time)
extern CELL *cell;
extern CELL *map_base, *map_x_out, *map_y_out, *map_visit;
@@ -70,7 +76,11 @@
continue;
- DATA(map_out, row, col) = (float)init_time;
+ if (start_is_time)
+ /* here we ignore the issue with null value if any */
+ DATA(map_out, row, col) = cell[col];
+ else
+ DATA(map_out, row, col) = (float)init_time;
insertHa((float)init_time, zero, row, col, heap, &heap_len);
/*mark it to avoid redundant computing */
DATA(map_visit, row, col) = 1;
Modified: grass/trunk/raster/r.spread/local_proto.h
--- grass/trunk/raster/r.spread/local_proto.h 2014-06-22 23:19:51 UTC (rev 60921)
+++ grass/trunk/raster/r.spread/local_proto.h 2014-06-23 01:36:47 UTC (rev 60922)
@@ -1,7 +1,7 @@
#include "cell_ptrHa.h"
#include "costHa.h"
/* collect_ori.c */
-void collect_ori(int);
+void collect_ori(int, int);
/* deleteHa.c */
void deleteHa(float, int, int, struct costHa *, long *);
Modified: grass/trunk/raster/r.spread/main.c
--- grass/trunk/raster/r.spread/main.c 2014-06-22 23:19:51 UTC (rev 60921)
+++ grass/trunk/raster/r.spread/main.c 2014-06-23 01:36:47 UTC (rev 60922)
@@ -40,7 +40,6 @@
#define DATA(map, r, c) (map)[(r) * ncols + (c)]
-CELL range_min, range_max;
CELL *cell;
CELL *x_cell;
CELL *y_cell;
@@ -70,7 +69,6 @@
long heap_len;
struct Cell_head window;
-struct Range range;
struct costHa *heap;
@@ -79,6 +77,11 @@
int col, row;
+ /* to menage start (source) raster map */
+ struct Range start_range;
+ CELL start_range_min, start_range_max;
+ int start_is_time; /* 0 or 1 */
struct
struct Option *max, *dir, *base, *start,
@@ -88,8 +91,8 @@
} parm;
struct
- /* please, remove before GRASS 7 released */
- struct Flag *display, *spotting;
+ /* please, remove display before GRASS 7 released */
+ struct Flag *display, *spotting, *start_is_time;
} flag;
struct GModule *module;
@@ -307,7 +310,7 @@
#if 0
flag.display->label = _("DISPLAY 'live' spread process on screen");
flag.display->description =
- _("Display the "live" simulation on screen. A graphics window "
+ _("Display the 'live' simulation on screen. A graphics window "
"must be opened and selected before using this option.");
#else
flag.display->description = _("Live display - disabled and depreciated");
@@ -317,6 +320,17 @@
flag.spotting->key = 's';
flag.spotting->description = _("Consider spotting effect (for wildfires)");
+ flag.start_is_time = G_define_flag();
+ flag.start_is_time->key = 'i';
+ flag.start_is_time->label = _("Use start raster map values in"
+ " output spread time raster map");
+ flag.start_is_time->description = _("Designed to be used with output"
+ " of previous run of r.spread when computing spread iteratively."
+ " The values in start raster map are considered as time."
+ " Allowed values in raster map are from zero"
+ " to the value of init_time option."
+ " If not enabled, init_time is used in the area of start raster map");
/* Parse command line */
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -522,9 +536,20 @@
start_fd = Rast_open_old(start_layer, G_find_raster2(start_layer, ""));
- Rast_read_range(start_layer, G_find_file("cell", start_layer, ""), &range);
- Rast_get_range_min_max(&range, &range_min, &range_max);
+ Rast_read_range(start_layer, G_find_file("cell", start_layer, ""),
+ &start_range);
+ Rast_get_range_min_max(&start_range, &start_range_min, &start_range_max);
+ start_is_time = flag.start_is_time->answer;
+ /* values higher than init_time are unexpected and may cause segfaults */
+ if (start_is_time && start_range_max > init_time)
+ G_fatal_error(_("Maximum of start raster map is grater than init_time"
+ " (%d > %d)"), start_range_max, init_time);
+ /* values lower then zero does not make sense for time */
+ if (start_is_time && start_range_min < 0)
+ G_fatal_error(_("Minimum of start raster map is less than zero"
+ " (%d < 0)"), start_range_min, init_time);
/* Initialize the heap */
heap =
(struct costHa *)G_calloc(nrows * ncols + 1, sizeof(struct costHa));
@@ -532,7 +557,7 @@
G_message(_("Reading %s..."), start_layer);
G_debug(1, "Collecting origins...");
- collect_ori(start_fd);
+ collect_ori(start_fd, start_is_time);
G_debug(1, "Done");
