[GRASS-SVN] r60925 - in grass-addons/grass7/imagery: i.eb.hsebal95 i.feotio2
Mon Jun 23 02:35:59 PDT 2014
Author: ychemin
Date: 2014-06-23 02:35:59 -0700 (Mon, 23 Jun 2014)
New Revision: 60925
Added:
   grass-addons/grass7/imagery/i.eb.hsebal95/i.eb.hsebal95.html
Removed:
   grass-addons/grass7/imagery/i.eb.hsebal95/i.eb.h_sebal95.html
   grass-addons/grass7/imagery/i.eb.hsebal95/Makefile
   grass-addons/grass7/imagery/i.feotio2/Makefile
Naming convention updated
Modified: grass-addons/grass7/imagery/i.eb.hsebal95/Makefile
--- grass-addons/grass7/imagery/i.eb.hsebal95/Makefile	2014-06-23 09:09:38 UTC (rev 60924)
+++ grass-addons/grass7/imagery/i.eb.hsebal95/Makefile	2014-06-23 09:35:59 UTC (rev 60925)
@@ -1,6 +1,6 @@
 MODULE_TOPDIR = ../..
-PGM = i.eb.h_sebal95
+PGM = i.eb.hsebal95
 LIBES = $(RASTERLIB) $(GISLIB)
 DEPENDENCIES = $(RASTERDEP) $(GISDEP)
Deleted: grass-addons/grass7/imagery/i.eb.hsebal95/i.eb.h_sebal95.html
--- grass-addons/grass7/imagery/i.eb.hsebal95/i.eb.h_sebal95.html	2014-06-23 09:09:38 UTC (rev 60924)
+++ grass-addons/grass7/imagery/i.eb.hsebal95/i.eb.h_sebal95.html	2014-06-23 09:35:59 UTC (rev 60925)
@@ -1,102 +0,0 @@
-<h2>DESCRIPTION</h2>
-<i>i.eb.h_sebal95 </i> computes the <i>sensible heat flux</i> [W/m2]
-after Bastiaanssen, 1995 in [1].
-<p><em>i.eb.h_sebal95</em> given the vegetation height (hc), humidity (RU),
-wind speed at two meters height (WS), temperature (T), digital terrain model (DEM),
-and net radiation (NSR) raster input maps,
-calculates the sensible heat flux map (h0).
-<p>Optionally the user can activate a flag (-z)
-that allows him setting to zero all of the negative evapotranspiration cells;
-in fact these negative values motivated by the condensation of the air water
-vapour content, are sometime undesired because they can produce  computational
-problems. The usage of the flag -n detect that the module is run in night hours
-and the appropriate soil heat flux is calculated.
-<p>The algorithm implements well known approaches: the hourly
-Penman-Monteith method as presented in Allen et al. (1998) for land
-surfaces and the Penman method (Penman, 1948) for water surfaces.<br>
-<p>Land and water surfaces are idenfyied by Vh:<br>
--	where Vh less than 0 vegetation is present and evapotranspiration is calculated;<br>
--	where Vh=0 bare ground is present and evapotranspiration is calculated;<br>
--	where Vh more than 0 water surface is present and evaporation is calculated;<br>
-<p>For more details on the algorithms see [1].
-<h3>Parameters:</h3>
-<dl>
- <dt><b>DEM</b>=<I>name</I>
- <dd>Input elevation raster [m a.s.l.]. Required.</dd>
- <dt><b>T</b>=<I>name</I>
- <dd>Input temperature raster [�C]. Required.</dd>
- <dt><b>RH</b> =<I>name</I>
- <dd>Input relative humidity raster [%]. Required.</dd>
- <dt><b>WS</b> =<I>name</I>
- <dd>Input wind speed at two meters raster [m/s]. Required.</dd>
- <dt><b>NSR</b> =<I>name</I>
- <dd>Input net solar radiation raster [MJ/(m2*h)]. Required.</dd>
- <dt><b>Vh</b> =<I>name</I>
- <dd>Input vegetation heigth raster [m]. Required.</dd>
- <dt><b>ETP</b> =<I>name</I>
- <dd>Output evapotranspiration raster [mm/h]. Required.</dd>
-</dl>
-<h2>NOTES</h2>
-<p>Net solar radiation map in MJ/(m2*h) can be computed from the
-combination of the <em>r.sun<em>, run in mode 1, and the r.mapcalc
-commands.
-<p>The sum of the three radiation components outputted by r.sun (beam, diffuse, and reflected)
-multiplied by the Wh to Mj conversion factor (0.0036) and optionally by a
-clear sky factor [0-1] allows the generation of a map to be used as
-an NSR input for the <em>i.evapo.pm</em> command.
-<br>
-example:
-<br>r.sun elev_in=dem asp_in=aspect slope_in=slope lin=2 albedo=alb_Mar \
-    incidout=out beam_rad=beam diff_rad=diffuse refl_rad=reflected day=73 time=13:00 dist=100;
-<br>r.mapcalc 'NSR=0.0036*(beam+diffuse+reflected)';
-<h2>SEE ALSO</h2>
-<ul>
-  <li><a href=i.eb.h_iter.html>i.eb.h_iter</a>,
-      <a href=i.eb.h0.html>i.eb.h0</a>
-      <a href=i.evapo.pm.html>i.evapo.pm</a>
-</ul>
-<h2>REFERENCES</h2>
-  <p>[1] Bastiaanssen, W.G.M., 1995.
-  Estimation of Land surface paramters by remote sensing under clear-sky conditions. PhD thesis, Wageningen University, Wageningen, The Netherlands.
-  <p>[2] Allen, R.G., L.S. Pereira, D. Raes, and M. Smith. 1998.
-  Crop Evapotranspiration: Guidelines for computing crop water requirements.
-  Irrigation and Drainage Paper 56, Food and Agriculture Organization of the
-  United Nations, Rome, pp. 300
-  <p>[3] Penman, H. L. 1948. Natural evaporation from open water,
-  bare soil and grass. Proc. Roy. Soc. London, A193, pp. 120-146.
-<h2>AUTHOR</h2>
-  <p>
-  <i>
-   <br>Yann Chemin
-   <br>International Rice Research Institute, Los Banos, The Philippines.
-   <br>International Water management Institute, Colombo, Sri Lanka.
-  </i>
-  <p>Contact: <a href="mailto:y.chemin at cgiar.org"> Yann chemin</a>
Copied: grass-addons/grass7/imagery/i.eb.hsebal95/i.eb.hsebal95.html (from rev 60924, grass-addons/grass7/imagery/i.eb.hsebal95/i.eb.h_sebal95.html)
--- grass-addons/grass7/imagery/i.eb.hsebal95/i.eb.hsebal95.html	                        (rev 0)
+++ grass-addons/grass7/imagery/i.eb.hsebal95/i.eb.hsebal95.html	2014-06-23 09:35:59 UTC (rev 60925)
@@ -0,0 +1,102 @@
+<h2>DESCRIPTION</h2>
+<i>i.eb.h_sebal95 </i> computes the <i>sensible heat flux</i> [W/m2]
+after Bastiaanssen, 1995 in [1].
+<p><em>i.eb.h_sebal95</em> given the vegetation height (hc), humidity (RU),
+wind speed at two meters height (WS), temperature (T), digital terrain model (DEM),
+and net radiation (NSR) raster input maps,
+calculates the sensible heat flux map (h0).
+<p>Optionally the user can activate a flag (-z)
+that allows him setting to zero all of the negative evapotranspiration cells;
+in fact these negative values motivated by the condensation of the air water
+vapour content, are sometime undesired because they can produce  computational
+problems. The usage of the flag -n detect that the module is run in night hours
+and the appropriate soil heat flux is calculated.
+<p>The algorithm implements well known approaches: the hourly
+Penman-Monteith method as presented in Allen et al. (1998) for land
+surfaces and the Penman method (Penman, 1948) for water surfaces.<br>
+<p>Land and water surfaces are idenfyied by Vh:<br>
+-	where Vh less than 0 vegetation is present and evapotranspiration is calculated;<br>
+-	where Vh=0 bare ground is present and evapotranspiration is calculated;<br>
+-	where Vh more than 0 water surface is present and evaporation is calculated;<br>
+<p>For more details on the algorithms see [1].
+<h3>Parameters:</h3>
+<dl>
+ <dt><b>DEM</b>=<I>name</I>
+ <dd>Input elevation raster [m a.s.l.]. Required.</dd>
+ <dt><b>T</b>=<I>name</I>
+ <dd>Input temperature raster [�C]. Required.</dd>
+ <dt><b>RH</b> =<I>name</I>
+ <dd>Input relative humidity raster [%]. Required.</dd>
+ <dt><b>WS</b> =<I>name</I>
+ <dd>Input wind speed at two meters raster [m/s]. Required.</dd>
+ <dt><b>NSR</b> =<I>name</I>
+ <dd>Input net solar radiation raster [MJ/(m2*h)]. Required.</dd>
+ <dt><b>Vh</b> =<I>name</I>
+ <dd>Input vegetation heigth raster [m]. Required.</dd>
+ <dt><b>ETP</b> =<I>name</I>
+ <dd>Output evapotranspiration raster [mm/h]. Required.</dd>
+</dl>
+<h2>NOTES</h2>
+<p>Net solar radiation map in MJ/(m2*h) can be computed from the
+combination of the <em>r.sun<em>, run in mode 1, and the r.mapcalc
+commands.
+<p>The sum of the three radiation components outputted by r.sun (beam, diffuse, and reflected)
+multiplied by the Wh to Mj conversion factor (0.0036) and optionally by a
+clear sky factor [0-1] allows the generation of a map to be used as
+an NSR input for the <em>i.evapo.pm</em> command.
+<br>
+example:
+<br>r.sun elev_in=dem asp_in=aspect slope_in=slope lin=2 albedo=alb_Mar \
+    incidout=out beam_rad=beam diff_rad=diffuse refl_rad=reflected day=73 time=13:00 dist=100;
+<br>r.mapcalc 'NSR=0.0036*(beam+diffuse+reflected)';
+<h2>SEE ALSO</h2>
+<ul>
+  <li><a href=i.eb.h_iter.html>i.eb.h_iter</a>,
+      <a href=i.eb.h0.html>i.eb.h0</a>
+      <a href=i.evapo.pm.html>i.evapo.pm</a>
+</ul>
+<h2>REFERENCES</h2>
+  <p>[1] Bastiaanssen, W.G.M., 1995.
+  Estimation of Land surface paramters by remote sensing under clear-sky conditions. PhD thesis, Wageningen University, Wageningen, The Netherlands.
+  <p>[2] Allen, R.G., L.S. Pereira, D. Raes, and M. Smith. 1998.
+  Crop Evapotranspiration: Guidelines for computing crop water requirements.
+  Irrigation and Drainage Paper 56, Food and Agriculture Organization of the
+  United Nations, Rome, pp. 300
+  <p>[3] Penman, H. L. 1948. Natural evaporation from open water,
+  bare soil and grass. Proc. Roy. Soc. London, A193, pp. 120-146.
+<h2>AUTHOR</h2>
+  <p>
+  <i>
+   <br>Yann Chemin
+   <br>International Rice Research Institute, Los Banos, The Philippines.
+   <br>International Water management Institute, Colombo, Sri Lanka.
+  </i>
+  <p>Contact: <a href="mailto:y.chemin at cgiar.org"> Yann chemin</a>
Modified: grass-addons/grass7/imagery/i.feotio2/Makefile
--- grass-addons/grass7/imagery/i.feotio2/Makefile	2014-06-23 09:09:38 UTC (rev 60924)
+++ grass-addons/grass7/imagery/i.feotio2/Makefile	2014-06-23 09:35:59 UTC (rev 60925)
@@ -1,6 +1,6 @@
-PGM = i.feo_tio2
+PGM = i.feotio2
