[GRASS-SVN] r60931 - sandbox/annakrat/r3.flow
Mon Jun 23 15:25:37 PDT 2014
Author: annakrat
Date: 2014-06-23 15:25:37 -0700 (Mon, 23 Jun 2014)
New Revision: 60931
   sandbox/annakrat/r3.flow/integrate.py
   sandbox/annakrat/r3.flow/r3.flow.py
r3.flow: added adaptive runge-kutta method
Modified: sandbox/annakrat/r3.flow/integrate.py
--- sandbox/annakrat/r3.flow/integrate.py	2014-06-23 22:02:01 UTC (rev 60930)
+++ sandbox/annakrat/r3.flow/integrate.py	2014-06-23 22:25:37 UTC (rev 60931)
@@ -1,14 +1,34 @@
 # -*- coding: utf-8 -*-
+ at brief Runge-Kutta integration methods (RK4, RK45 with adaptive step size)
 @author: Anna Petrasova
-from rast3d_functions import get_velocity
+import sys
+from rast3d_functions import get_velocity, rast3d_is_valid_location, norm
+# constants for adaptive step size integration
+# min and max steps given in 'cell' unit
+MIN_STEP = 0.01
+MAX_STEP = 1.
+# max error to compare with estimated error coming from RK45
+MAX_ERROR = 1.0e-6
 # nice explanation of runge-kutta with picture:
 # http://www.marekfiser.com/Projects/Vector-field-visualization-on-GPU-using-CUDA/
 #4-Vector-field-integrators-for-stream-line-visualization
-def integrate_next(rast3d_region, arrays, point, delta_t):
+def rk4_integrate_next(rast3d_region, arrays, point, next_point, delta_t):
+    """Integrates new point of a flowline using 4th order Runge-Kutta method.
+    :param dict rast3d_region: information about region
+    :param arrays: 3D arrays of velocity components
+    :param list point: list of x, y, z coordinates from where to integrate
+    :param list next_point: list of x, y, z coordinates of the integrated point
+    (computed here and the list is modified)
+    :param float delta_t: time step for integration
+    :return: True if next point is found, False if not (out of region/3D raster)
     k1 = [None] * 3
     k2 = [None] * 3
     k3 = [None] * 3
@@ -17,38 +37,165 @@
     # first
     velocity = get_velocity(rast3d_region, arrays, point)
     if velocity is None:
-        return None
+        return False
     for i in range(3):
         k1[i] = delta_t * velocity[i]
     # second
                             (x + k1[0] / 2, y + k1[1] / 2, z + k1[2] / 2))
-        return None
+        return False
     for i in range(3):
         k2[i] = delta_t * velocity[i]
     # third
                             (x + k2[0] / 2, y + k2[1] / 2, z + k2[2] / 2))
-        return None
+        return False
     for i in range(3):
         k3[i] = delta_t * velocity[i]
     # fourth
     velocity = get_velocity(rast3d_region, arrays, (x + k3[0], y + k3[1], z + k3[2]))
-        return None
+        return False
     for i in range(3):
         k4[i] = delta_t * velocity[i]
     # next point
-    next_point = [None] * 3
     for i in range(3):
         next_point[i] = point[i] + k1[i] / 6 + k2[i] / 3 + k3[i] / 3 + k4[i] / 6
+    if rast3d_is_valid_location(rast3d_region, next_point[1], next_point[0], next_point[2]):
+        return True
-    return next_point
+    return False
+# Runge-Kutta with adaptive step size
+# adapted from vtkRungeKutta45 class implementation.
+# Cash-Karp parameters
+# http://en.wikipedia.org/wiki/Cash-Karp_method
+B = [[1. / 5, 0, 0, 0, 0],
+     [3. / 40, 9. / 40, 0, 0, 0],
+     [3. / 10, -9. / 10, 6. / 5, 0, 0],
+     [-11. / 54, 5. / 2, -70. / 27, 35. / 27, 0],
+     [1631. / 55296, 175. / 512, 575. / 13824, 44275. / 110592, 253. / 4096]
+C = [37. / 378, 0, 250. / 621, 125. / 594, 0, 512. / 1771]
+DC = [37. / 378 - 2825. / 27648, 0,
+      250. / 621 - 18575. / 48384, 125. / 594 - 13525. / 55296,
+      -277. / 14336, 512. / 1771 - 1. / 4]
+def rk45_integrate_next(rast3d_region, arrays, point, next_point, delta_t, min_step, max_step):
+    """Integrates new point of a flowline using Runge-Kutta method with adaptive step size.
+    Uses Cash-Karp coefficients. Tries to decrease the estimated error below max error.
+    :param float min_step: min time step for integration
+    :param float max_step: max time step for integration
+    estimated_error = sys.float_info.max
+    error = [0] * 3
+    # check if min_step < delta_t < max_step, what if not?
+    # try to iteratively decrease error to less than max error
+    while estimated_error > MAX_ERROR:
+        # compute next point and get estimated error
+        if rk45_next(rast3d_region, arrays, point, next_point, delta_t, error):
+            estimated_error = norm(error)
+        else:
+            return False
+        # compute new step size (empirically)
+        error_ratio = estimated_error / MAX_ERROR
+        if error_ratio == 0.0:
+            tmp = min_step if delta_t > 0 else -min_step
+        elif error_ratio > 1:
+            tmp = 0.9 * delta_t * pow(error_ratio, -0.25)
+        else:
+            tmp = 0.9 * delta_t * pow(error_ratio, -0.2)
+        tmp2 = abs(tmp)
+        do_break = False
+        # adjust new step size to be within min max limits
+        if tmp2 > max_step:
+            delta_t = max_step * (1 if delta_t > 0 else -1)
+            do_break = True
+        elif tmp2 < min_step:
+            delta_t = min_step * (1 if delta_t > 0 else -1)
+            do_break = True
+        else:
+            delta_t = tmp
+        # break when the adjustment was needed (not sure why)
+        if do_break:
+            if not rk45_next(rast3d_region, arrays, point, next_point, delta_t, error):
+                return False
+            break
+    return True
+def rk45_next(rast3d_region, arrays, point, next_point, delta_t, error):
+    """The actual method which integrates new point of a flowline
+    using Runge-Kutta method with Cash-Karp coefficients. Provides error estimate.
+    :param list error: error vector (here modified)
+    # 3 is 3 dimensions, 6 is the number of k's
+    tmp1 = [[0] * 3] * 6
+    tmp_point = [0] * 3
+    velocity = get_velocity(rast3d_region, arrays, point)
+    if velocity is None:
+        return False
+    tmp1[0] = velocity
+    # compute k's
+    for i in range(1, 6):
+        for j in range(3):  # for each coordinate
+            sum_tmp = 0
+            for k in range(i):  # k1; k1, k2; ...
+                sum_tmp += B[i - 1][k] * tmp1[k][j]
+            tmp_point[j] = point[j] + delta_t * sum_tmp
+        velocity = get_velocity(rast3d_region, arrays, tmp_point)
+            return False
+        tmp1[i] = velocity
+        sum_tmp = 0
+        for i in range(6):
+            sum_tmp += C[i] * tmp1[i][j]
+        next_point[j] = point[j] + delta_t * sum_tmp
+    if not rast3d_is_valid_location(rast3d_region, next_point[1], next_point[0], next_point[2]):
+        return False
+    # compute error vector
+        sum_tmp = 0
+            sum_tmp += DC[i] * tmp1[i][j]
+        error[j] = delta_t * sum_tmp
+    return True
 def get_time_step(unit, step, velocity, cell_size):
     if unit == 'time':
         return step
Modified: sandbox/annakrat/r3.flow/r3.flow.py
--- sandbox/annakrat/r3.flow/r3.flow.py	2014-06-23 22:02:01 UTC (rev 60930)
+++ sandbox/annakrat/r3.flow/r3.flow.py	2014-06-23 22:25:37 UTC (rev 60931)
@@ -98,11 +98,12 @@
 from grass.pygrass.vector import VectorTopo
 from grass.pygrass.vector.geometry import Line, Point
-from integrate import integrate_next, get_time_step
-from rast3d_functions import get_velocity, norm, compute_gradient, rast3d_location2coord, rast3d_is_valid_location
+from integrate import rk4_integrate_next, rk45_integrate_next, get_time_step, MIN_STEP, MAX_STEP
+from rast3d_functions import get_velocity, norm, compute_gradient, rast3d_location2coord
 from voxel_traversal import traverse
 EPSILON = 1e-8
+RK45 = True  # have it as an option?
 class Seed:
@@ -216,6 +217,7 @@
     # go through all points and integrate flowline for each
     seed_count = 0
+    gcore.info(_("Flow lines for {count} seed points will be computed.").format(count=len(seeds)))
     for seed in seeds:
         count = 0
         gcore.percent(seed_count, len(seeds), 1)
@@ -224,6 +226,7 @@
         if seed.flowline:
             line = Line([Point(point[0], point[1], point[2])])
         last_coords = (None, None, None)
+        new_point = [None, None, None]
         while count <= limit:
             velocity_vector = get_velocity(map_info, velocity, point)
             if velocity_vector is None:
@@ -234,10 +237,18 @@
                 break  # zero velocity means end of propagation
             # convert to time
             delta_T = get_time_step(unit, step, velocity_norm, cell_size)
-            new_point = integrate_next(map_info, velocity, point, delta_T * direction)
-            if new_point is None or \
-               not rast3d_is_valid_location(map_info, new_point[1], new_point[0], new_point[2]):
+            # decide which integration method to choose
+            if not RK45:
+                ret = rk4_integrate_next(map_info, velocity, point, new_point,
+                                         delta_T * direction)
+            else:
+                min_step = get_time_step('cell', MIN_STEP, velocity_norm, cell_size)
+                max_step = get_time_step('cell', MAX_STEP, velocity_norm, cell_size)
+                ret = rk45_integrate_next(map_info, velocity, point, new_point,
+                                          delta_T * direction, min_step, max_step)
+            if not ret:
                 break
             if seed.flowline:
                 line.append(Point(new_point[0], new_point[1], new_point[2]))
             if seed.flowaccum:
