[GRASS-SVN] r60937 - grass/trunk/imagery/i.eb.hsebal01
svn_grass at osgeo.org
Mon Jun 23 21:07:13 PDT 2014
Author: ychemin
Date: 2014-06-23 21:07:13 -0700 (Mon, 23 Jun 2014)
New Revision: 60937
Added:
grass/trunk/imagery/i.eb.hsebal01/i.eb.hsebal01.html
Removed:
grass/trunk/imagery/i.eb.hsebal01/i.eb.h_sebal01.html
naming convention corrected
Deleted: grass/trunk/imagery/i.eb.hsebal01/i.eb.h_sebal01.html
--- grass/trunk/imagery/i.eb.hsebal01/i.eb.h_sebal01.html 2014-06-24 03:55:10 UTC (rev 60936)
+++ grass/trunk/imagery/i.eb.hsebal01/i.eb.h_sebal01.html 2014-06-24 04:07:13 UTC (rev 60937)
@@ -1,72 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>i.eb.h_sebal01</em> will calculate the sensible heat flux map (h0), given
-both maps of Net Radiation and soil Heat flux (Rn, g0) at instantaneous time,
-the surface roughness (z0m), a map of the altitude corrected temperature
-(t0dem), a point data of the frictional velocity (u*), a value of actual vapour
-pressure (ea[KPa]) and the (x,y) pairs for wet and dry pixels.
-Full process will need those:
-<ul>
- <li>i.vi, i.albedo, r.latlong, i.emissivity
- <li>i.evapo.potrad (Addon)
- <li>i.eb.netrad, i.eb.soilheatflux, i.eb.h_sebal01
- <li>i.eb.evapfr, i.eb.eta
-</ul>
-(for time integration: i.evapo.time_integration)
-<p>
-<em>i.eb.h_sebal01</em> performs the computation of <i>sensible heat flux</i>
-[W/m2] after Bastiaanssen, 1995 in [1], used in this form in 2001 by [2]. Implemented
-in this code in [3].
-<h2>NOTES</h2>
-<ul>
-<li> z0m can be alculated by i.eb.z0m or i.eb.z0m0 (grass-addons).
-<li> ea can be calculated with standard meteorological data.<br>
- eoTmin=0.6108*EXP(17.27*Tmin/(Tmin+237.3))<br>
- eoTmax=0.6108*EXP(17.27*Tmax/(Tmax+237.3))<br>
- ea=(RH/100)/((eoTmin+eoTmax)/2)
-<li> t0dem = surface temperature + (altitude * 0.627 / 100)
-</ul>
-<h2>SEE ALSO</h2>
-<em>
-<a href=i.eb.soilheatflux.html>i.eb.soilheatflux</a>,
-<a href=i.eb.h_sebal01.html>i.eb.h_sebal01</a>,
-<a href=i.eb.evapfr.html>i.eb.evapfr</a>
-</em>
-<h2>REFERENCES</h2>
-<p>[1] Bastiaanssen, W.G.M., 1995.
- Estimation of Land surface paramters by remote sensing under clear-sky
-conditions. PhD thesis, Wageningen University, Wageningen, The Netherlands.
-(<a href="http://edepot.wur.nl/206553">PDF</a>)
-<p>[2] Chemin Y., Alexandridis T.A., 2001. Improving spatial resolution of ET
-seasonal for irrigated rice in Zhanghe, China}''. Asian Journal of
-Geoinformatics. 5(1):3-11,2004.
-<p>[3] Alexandridis T.K., Cherif I., Chemin Y., Silleos N.G., Stavrinos E.,
-Zalidis G.C. Integrated methodology for estimating water use in Mediterranean
-agricultural areas. Remote Sensing. 2009, 1, 445-465.
-(<a href="http://www.mdpi.com/2072-4292/1/3/445">PDF</a>)
-<p>[4] Chemin, Y., 2012.
-A Distributed Benchmarking Framework for Actual ET Models,
-in: Irmak, A. (Ed.), Evapotranspiration - Remote Sensing and Modeling. InTech.
-(<a href="http://www.intechopen.com/books/evapotranspiration-remote-sensing-and-modeling/a-distributed-benchmarking-framework-for-actual-et-models">PDF</a>)
-<h2>AUTHORS</h2>
-Yann Chemin, International Rice Research Institute, Los Banos, The
-Philippines.
-<p>Contact: <a href="mailto:yann.chemin at gmail.com">Yann Chemin</a>
-<p><i>Last changed: $Date$</i>
Copied: grass/trunk/imagery/i.eb.hsebal01/i.eb.hsebal01.html (from rev 60936, grass/trunk/imagery/i.eb.hsebal01/i.eb.h_sebal01.html)
--- grass/trunk/imagery/i.eb.hsebal01/i.eb.hsebal01.html (rev 0)
+++ grass/trunk/imagery/i.eb.hsebal01/i.eb.hsebal01.html 2014-06-24 04:07:13 UTC (rev 60937)
@@ -0,0 +1,72 @@
+<h2>DESCRIPTION</h2>
+<em>i.eb.h_sebal01</em> will calculate the sensible heat flux map (h0), given
+both maps of Net Radiation and soil Heat flux (Rn, g0) at instantaneous time,
+the surface roughness (z0m), a map of the altitude corrected temperature
+(t0dem), a point data of the frictional velocity (u*), a value of actual vapour
+pressure (ea[KPa]) and the (x,y) pairs for wet and dry pixels.
+Full process will need those:
+<ul>
+ <li>i.vi, i.albedo, r.latlong, i.emissivity
+ <li>i.evapo.potrad (Addon)
+ <li>i.eb.netrad, i.eb.soilheatflux, i.eb.h_sebal01
+ <li>i.eb.evapfr, i.eb.eta
+</ul>
+(for time integration: i.evapo.time_integration)
+<p>
+<em>i.eb.h_sebal01</em> performs the computation of <i>sensible heat flux</i>
+[W/m2] after Bastiaanssen, 1995 in [1], used in this form in 2001 by [2]. Implemented
+in this code in [3].
+<h2>NOTES</h2>
+<ul>
+<li> z0m can be alculated by i.eb.z0m or i.eb.z0m0 (grass-addons).
+<li> ea can be calculated with standard meteorological data.<br>
+ eoTmin=0.6108*EXP(17.27*Tmin/(Tmin+237.3))<br>
+ eoTmax=0.6108*EXP(17.27*Tmax/(Tmax+237.3))<br>
+ ea=(RH/100)/((eoTmin+eoTmax)/2)
+<li> t0dem = surface temperature + (altitude * 0.627 / 100)
+</ul>
+<h2>SEE ALSO</h2>
+<em>
+<a href=i.eb.soilheatflux.html>i.eb.soilheatflux</a>,
+<a href=i.eb.h_sebal01.html>i.eb.h_sebal01</a>,
+<a href=i.eb.evapfr.html>i.eb.evapfr</a>
+</em>
+<h2>REFERENCES</h2>
+<p>[1] Bastiaanssen, W.G.M., 1995.
+ Estimation of Land surface paramters by remote sensing under clear-sky
+conditions. PhD thesis, Wageningen University, Wageningen, The Netherlands.
+(<a href="http://edepot.wur.nl/206553">PDF</a>)
+<p>[2] Chemin Y., Alexandridis T.A., 2001. Improving spatial resolution of ET
+seasonal for irrigated rice in Zhanghe, China}''. Asian Journal of
+Geoinformatics. 5(1):3-11,2004.
+<p>[3] Alexandridis T.K., Cherif I., Chemin Y., Silleos N.G., Stavrinos E.,
+Zalidis G.C. Integrated methodology for estimating water use in Mediterranean
+agricultural areas. Remote Sensing. 2009, 1, 445-465.
+(<a href="http://www.mdpi.com/2072-4292/1/3/445">PDF</a>)
+<p>[4] Chemin, Y., 2012.
+A Distributed Benchmarking Framework for Actual ET Models,
+in: Irmak, A. (Ed.), Evapotranspiration - Remote Sensing and Modeling. InTech.
+(<a href="http://www.intechopen.com/books/evapotranspiration-remote-sensing-and-modeling/a-distributed-benchmarking-framework-for-actual-et-models">PDF</a>)
+<h2>AUTHORS</h2>
+Yann Chemin, International Rice Research Institute, Los Banos, The
+Philippines.
+<p>Contact: <a href="mailto:yann.chemin at gmail.com">Yann Chemin</a>
+<p><i>Last changed: $Date$</i>
