[GRASS-SVN] r60958 - grass/branches/releasebranch_7_0/imagery/i.landsat.toar
svn_grass at osgeo.org
Wed Jun 25 05:00:23 PDT 2014
Author: neteler
Date: 2014-06-25 05:00:23 -0700 (Wed, 25 Jun 2014)
New Revision: 60958
grass/branches/releasebranch_7_0/imagery/i.landsat.toar/i.landsat.toar.html
grass/branches/releasebranch_7_0/imagery/i.landsat.toar/main.c
i.landsat.toar: added scale parameter to make output usable for i.gensigset
Modified: grass/branches/releasebranch_7_0/imagery/i.landsat.toar/i.landsat.toar.html
--- grass/branches/releasebranch_7_0/imagery/i.landsat.toar/i.landsat.toar.html 2014-06-25 12:00:14 UTC (rev 60957)
+++ grass/branches/releasebranch_7_0/imagery/i.landsat.toar/i.landsat.toar.html 2014-06-25 12:00:23 UTC (rev 60958)
@@ -103,6 +103,10 @@
<h2>NOTES</h2>
+The output raster cell values can be rescaled with the <b>scale</b>
+parameter (e.g., with 100 in case of using reflectance output
+in <em>i.gensigset</em>).
<h3>On Landsat-8 metadata file </h3>
NASA reports a structure of the L1G Metadata file
Modified: grass/branches/releasebranch_7_0/imagery/i.landsat.toar/main.c
--- grass/branches/releasebranch_7_0/imagery/i.landsat.toar/main.c 2014-06-25 12:00:14 UTC (rev 60957)
+++ grass/branches/releasebranch_7_0/imagery/i.landsat.toar/main.c 2014-06-25 12:00:23 UTC (rev 60958)
@@ -45,7 +45,7 @@
RASTER_MAP_TYPE in_data_type;
struct Option *input_prefix, *output_prefix, *metfn, *sensor, *adate,
- *pdate, *elev, *bgain, *metho, *perc, *dark, *atmo, *lsatmet;
+ *pdate, *elev, *bgain, *metho, *perc, *dark, *atmo, *lsatmet, *oscale;
char *inputname, *met, *outputname, *sensorname;
struct Flag *frad, *print_meta, *named;
@@ -53,7 +53,7 @@
char band_in[GNAME_MAX], band_out[GNAME_MAX];
int i, j, q, method, pixel, dn_dark[MAX_BANDS], dn_mode[MAX_BANDS], dn_sat;
int overwrite;
- double qcal, rad, ref, percent, ref_mode, rayleigh;
+ double qcal, rad, ref, percent, ref_mode, rayleigh, scale;
unsigned long hist[QCALMAX], h_max;
struct Colors colors;
@@ -213,6 +213,13 @@
lsatmet->descriptions = desc;
lsatmet->guisection = _("Settings");
+ oscale = G_define_option();
+ oscale->key = "scale";
+ oscale->type = TYPE_DOUBLE;
+ oscale->answer = "1.0";
+ oscale->required = NO;
+ oscale->description = _("Scale factor for output");
/* define the different flags */
frad = G_define_flag();
frad->key = 'r';
@@ -269,6 +276,7 @@
percent = atof(perc->answer);
pixel = atoi(dark->answer);
rayleigh = atof(atmo->answer);
+ scale = atof(oscale->answer);
* Data from metadata file
@@ -612,7 +620,7 @@
ref = lsat_rad2temp(rad, &lsat.band[i]);
else {
- ref = lsat_rad2ref(rad, &lsat.band[i]);
+ ref = lsat_rad2ref(rad, &lsat.band[i]) * scale;
if (ref < 0. && method > DOS)
ref = 0.;
