[GRASS-SVN] r60960 - grass/branches/releasebranch_7_0/imagery/i.gensigset
svn_grass at osgeo.org
Wed Jun 25 05:13:33 PDT 2014
Author: neteler
Date: 2014-06-25 05:13:33 -0700 (Wed, 25 Jun 2014)
New Revision: 60960
grass/branches/releasebranch_7_0/imagery/i.gensigset/i.gensigset.html
i.gensigset manual: explain 'Unreliable clustering' warning; HTML cosmetics
Modified: grass/branches/releasebranch_7_0/imagery/i.gensigset/i.gensigset.html
--- grass/branches/releasebranch_7_0/imagery/i.gensigset/i.gensigset.html 2014-06-25 12:08:05 UTC (rev 60959)
+++ grass/branches/releasebranch_7_0/imagery/i.gensigset/i.gensigset.html 2014-06-25 12:13:33 UTC (rev 60960)
@@ -2,7 +2,6 @@
<em>i.gensigset</em>
is a non-interactive method for generating input into
<em><a href="i.smap.html">i.smap</a>.</em>
It is used as the first pass in the a two-pass
@@ -12,7 +11,6 @@
extract spectral signatures from an image based on the
classification of the pixels in the training map and make
these signatures available to
@@ -31,7 +29,6 @@
<dd>ground truth training map
<p>
This raster layer, supplied as input by the user, has some
of its pixels already classified, and the rest (probably
@@ -55,7 +52,6 @@
representative
of the classes in the image.
<p>
At present, there is no fully-interactive tool specifically
designed for producing this layer.
@@ -107,7 +103,6 @@
<dd>maximum number of sub-signatures in any class
<br>
default: 5
<p>
@@ -119,7 +114,6 @@
number to a minimal number of subclasses which are
spectrally distinct. The user has the option to set this
starting value with this option.
</dl>
@@ -188,59 +182,60 @@
expectation maximization (EM) algorithm
[<a href="#dempster77">2</a>,<a href="#redner84">3</a>].
+<h2>WARNINGS</h2>
-<h2>REFERENCES</h2>
+If warnings like this occur, reducing the remaining classes to 0:
-<ol>
+<div class="code"><pre>
+WARNING: Removed a singular subsignature number 1 (4 remain)
+WARNING: Removed a singular subsignature number 1 (3 remain)
+WARNING: Removed a singular subsignature number 1 (2 remain)
+WARNING: Removed a singular subsignature number 1 (1 remain)
+WARNING: Unreliable clustering. Try a smaller initial number of clusters
+WARNING: Removed a singular subsignature number 1 (-1 remain)
+Number of subclasses is 0
+</pre></div>
-<li><A NAME="rissanen83">J. Rissanen,</a>
-"A Universal Prior for Integers and Estimation by Minimum
-Description Length,"
-<em>Annals of Statistics,</em>
-vol. 11, no. 2, pp. 417-431, 1983.
+then the user should check for:
+<ul>
+<li>the range of the input data should be between 0 and 100 or 255 but not
+ between 0.0 and 1.0 (<em>r.info</em> and <em>r.univar</em> show the range)</li>
+<li>the training areas need to contain a sufficient amount of pixels</li>
+</ul>
+<h2>REFERENCES</h2>
+<ul>
+<li><A NAME="rissanen83">J. Rissanen,</a>
+"A Universal Prior for Integers and Estimation by Minimum Description Length,"
+<em>Annals of Statistics,</em> vol. 11, no. 2, pp. 417-431, 1983.
<li><A NAME="dempster77">A. Dempster, N. Laird and D. Rubin,</a>
"Maximum Likelihood from Incomplete Data via the EM Algorithm,"
-<em>J. Roy. Statist. Soc. B,</em>
-vol. 39, no. 1, pp. 1-38, 1977.
+<em>J. Roy. Statist. Soc. B,</em> vol. 39, no. 1, pp. 1-38, 1977.
<li><A NAME="redner84">E. Redner and H. Walker,</a>
"Mixture Densities, Maximum Likelihood and the EM Algorithm,"
-<em>SIAM Review,</em>
-vol. 26, no. 2, April 1984.
+<em>SIAM Review,</em> vol. 26, no. 2, April 1984.
+</ul>
-</ol>
<h2>SEE ALSO</h2>
-<em><a href="i.group.html">i.group</a></em>
-for creating groups and subgroups
+<em>
+<a href="i.group.html">i.group</a>,
+<a href="i.smap.html">i.smap</a>,
+<a href="r.info.html">r.info</a>,
+<a href="r.univar.html">r.univar</a>,
+<a href="wxGUI.vdigit.html">wxGUI vector digitizer</a>
+</em>
-<p>
-<em><a href="wxGUI.vdigit.html">wxGUI vector digitizer</a></em>
-and
-<em><a href="r.digit.html">r.digit</a></em>
-for interactively creating the training map.
-<p>
-<em><a href="i.smap.html">i.smap</a></em>
-for creating a final classification layer from the signatures
-generated by <em>i.gensigset.</em>
<h2>AUTHORS</h2>
Charles Bouman,
-School of
-Electrical Engineering,
-Purdue University
+School of Electrical Engineering, Purdue University
<br>
Michael Shapiro,
-U.S.Army Construction Engineering
-Research Laboratory
+U.S.Army Construction Engineering Research Laboratory
<p><i>Last changed: $Date$</i>
