[GRASS-SVN] r60976 - grass/trunk/general/g.rename
Wed Jun 25 10:10:40 PDT 2014
Author: hcho
Date: 2014-06-25 10:10:40 -0700 (Wed, 25 Jun 2014)
New Revision: 60976
   grass/trunk/general/g.rename/main.c
g.rename: Rename basemaps only for rast= after successful renaming
Modified: grass/trunk/general/g.rename/main.c
--- grass/trunk/general/g.rename/main.c	2014-06-25 16:59:53 UTC (rev 60975)
+++ grass/trunk/general/g.rename/main.c	2014-06-25 17:10:40 UTC (rev 60976)
@@ -7,9 +7,10 @@
  *               Cedric Shock <cedricgrass shockfamily.net>,
  *               Glynn Clements <glynn gclements.plus.com>,
  *               Markus Neteler <neteler itc.it>,
- *               Martin Landa <landa.martin gmail.com>
+ *               Martin Landa <landa.martin gmail.com>,
+ *               Huidae Cho <grass4u gmail.com>
  * PURPOSE:
- * COPYRIGHT:    (C) 1994-2007, 2011 by the GRASS Development Team
+ * COPYRIGHT:    (C) 1994-2007, 2011-2014 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -28,7 +29,7 @@
     int i, n;
     struct GModule *module;
-    struct Option **parm, *p;
+    struct Option **parm;
     char *old, *new;
     int nrmaps, nlist;
     const char *mapset, *location_path;
@@ -50,7 +51,7 @@
     parm = (struct Option **)G_calloc(nlist, sizeof(struct Option *));
     for (n = 0; n < nlist; n++) {
-	p = parm[n] = M_define_option(n, _("renamed"), NO);
+	parm[n] = M_define_option(n, _("renamed"), NO);
     if (G_parser(argc, argv))
@@ -64,6 +65,8 @@
 	    continue;
 	i = 0;
 	while (parm[n]->answers[i]) {
+	    int renamed;
 	    old = parm[n]->answers[i++];
 	    new = parm[n]->answers[i++];
 	    if (!M_find(n, old, mapset)) {
@@ -86,7 +89,12 @@
 		continue;
-	    if (Rast_is_reclassed_to(old, mapset, &nrmaps, &rmaps) > 0) {
+	    if ((renamed = M_do_rename(n, old, new)) == 1) {
+		result = EXIT_FAILURE;
+	    if (!renamed && strcmp(parm[n]->key, "rast") == 0 &&
+		Rast_is_reclassed_to(old, mapset, &nrmaps, &rmaps) > 0) {
 		int ptr, l;
 		char buf1[256], buf2[256], buf3[256], *str;
 		FILE *fp;
@@ -132,9 +140,6 @@
 		    fclose(fp);
-	    if (M_do_rename(n, old, new) == 1) {
-		result = EXIT_FAILURE;
     exit(result);
