[GRASS-SVN] r60992 - in sandbox/wenzeslaus/gunittest: . testsuite
Thu Jun 26 13:28:04 PDT 2014
Author: wenzeslaus
Date: 2014-06-26 13:28:04 -0700 (Thu, 26 Jun 2014)
New Revision: 60992
   sandbox/wenzeslaus/gunittest/checkers.py
   sandbox/wenzeslaus/gunittest/testsuite/test_assertions.py
gunittest: improve handling of multiline strings in comparison with ellipsis
Modified: sandbox/wenzeslaus/gunittest/checkers.py
--- sandbox/wenzeslaus/gunittest/checkers.py	2014-06-26 20:26:14 UTC (rev 60991)
+++ sandbox/wenzeslaus/gunittest/checkers.py	2014-06-26 20:28:04 UTC (rev 60992)
@@ -385,9 +385,15 @@
                             key_equal=key_equal)
+# TODO: support also float (with E, e, inf, nan, ...?) and int (###, ##.)
+# http://hg.python.org/cpython/file/943d3e289ab4/Lib/decimal.py#l6098
+# perhaps a separate function?
 # alternative names: looks like, correspond with/to
+# TODO: change checking over lines?
+# TODO: change parameter order?
+# TODO: the behavior with last \n is strange but now using DOTALL and $
 def check_text_ellipsis(reference, actual):
+    r"""
     >>> check_text_ellipsis("Vector map <...> contains ... points.",
     ...                     "Vector map <bridges> contains 5268 points.")
     True
@@ -395,7 +401,7 @@
     ...                     "user: some_user\\nname: elevation")
     True
     >>> check_text_ellipsis("user: ...\\nname: elevation",
-    ...                     "user: \\nname: elevation",)
+    ...                     "user: \\nname: elevation")
     False
     The ellipsis is always considered even if it is followed by another
@@ -403,30 +409,34 @@
     ellipsis will work as well as a line filled with undefined number of dots.
     >>> check_text_ellipsis("The result is ....",
-    ...                     "The result is 25.",)
+    ...                     "The result is 25.")
     True
     >>> check_text_ellipsis("max ..... ...",
-    ...                     "max ....... 6",)
+    ...                     "max ....... 6")
     True
     However, there is no way how to express that the dot should be in the
     beginning and the ellipsis is at the end of the group of dots.
-    ...                     "The result is .25",)
+    ...                     "The result is .25")
     False
+    The matching goes over lines (TODO: should this be changed?):
+    >>> check_text_ellipsis("a=11\nb=...", "a=11\nb=22\n")
+    True
     This function is based on regular expression containg .+ but no other
     regular expression matching will be done.
     >>> check_text_ellipsis("Result: [569] (...)",
-    ...                     "Result: 9 (too high)",)
+    ...                     "Result: 9 (too high)")
     False
     ref_escaped = re.escape(reference)
     exp = re.compile(r'\\\.\\\.\\\.')  # matching escaped ...
-    ref_regexp = exp.sub('.+', ref_escaped)
-    if re.match(ref_regexp, actual):
+    ref_regexp = exp.sub('.+', ref_escaped) + "$"
+    if re.match(ref_regexp, actual, re.DOTALL):
         return True
     else:
         return False
Modified: sandbox/wenzeslaus/gunittest/testsuite/test_assertions.py
--- sandbox/wenzeslaus/gunittest/testsuite/test_assertions.py	2014-06-26 20:26:14 UTC (rev 60991)
+++ sandbox/wenzeslaus/gunittest/testsuite/test_assertions.py	2014-06-26 20:28:04 UTC (rev 60992)
@@ -22,6 +22,10 @@
                           self.assertLooksLike,
                           "Generated map is elevation.",
                           "Generated map is <...>")
+        self.assertLooksLike("Projection string: '+proj=longlat +datum=WGS84'",
+                             "Projection string: ...")
+        self.assertLooksLike("a=123\nb=456\nc=789",
+                             "a=...\nb=...\nc=...")
 R_UNIVAR_ELEVATION_SUBSET = """n=2025000
