[GRASS-SVN] r60998 - in sandbox/wenzeslaus/gunittest: . testsuite
svn_grass at osgeo.org
Thu Jun 26 14:19:13 PDT 2014
Author: wenzeslaus
Date: 2014-06-26 14:19:13 -0700 (Thu, 26 Jun 2014)
New Revision: 60998
sandbox/wenzeslaus/gunittest/gmodules.py
sandbox/wenzeslaus/gunittest/testsuite/test_gmodules.py
gunittest: switch to TypeError from ValueError (more appropiate for bad keyword argument), add tests from #2326
Modified: sandbox/wenzeslaus/gunittest/gmodules.py
--- sandbox/wenzeslaus/gunittest/gmodules.py 2014-06-26 21:12:16 UTC (rev 60997)
+++ sandbox/wenzeslaus/gunittest/gmodules.py 2014-06-26 21:19:13 UTC (rev 60998)
@@ -52,7 +52,7 @@
:raises CalledModuleError: if module return code is non-zero
if 'stdout' in kwargs:
- raise ValueError('stdout argument not allowed, it would be overridden.')
+ raise TypeError('stdout argument not allowed, it would be overridden.')
kwargs['stdout'] = subprocess.PIPE
process = start_command(module, **kwargs)
output = process.communicate()[0]
@@ -130,9 +130,9 @@
if merge_stderr and not (capture_stdout and capture_stderr):
raise ValueError(_("You cannot merge stdout and stderr and not capture them"))
- raise ValueError(_("stdout argument not allowed, it could be overridden"))
+ raise TypeError(_("stdout argument not allowed, it could be overridden"))
if 'stderr' in kwargs:
- raise ValueError(_("stderr argument not allowed, it could be overridden"))
+ raise TypeError(_("stderr argument not allowed, it could be overridden"))
if capture_stdout:
Modified: sandbox/wenzeslaus/gunittest/testsuite/test_gmodules.py
--- sandbox/wenzeslaus/gunittest/testsuite/test_gmodules.py 2014-06-26 21:12:16 UTC (rev 60997)
+++ sandbox/wenzeslaus/gunittest/testsuite/test_gmodules.py 2014-06-26 21:19:13 UTC (rev 60998)
@@ -8,7 +8,8 @@
sys.path.insert(0, os.path.split(os.path.split((os.path.dirname(__file__)))[0])[0])
from gunittest.case import GrassTestCase
-from gunittest.gmodules import call_module, CalledModuleError
+from gunittest.gmodules import (call_module, CalledModuleError,
+ run_module, read_module, write_module)
G_REGION_OUTPUT = """n=...
s=...
@@ -83,11 +84,41 @@
call_module,
'm.proj', flags='i', input='-',
stdin=subprocess.PIPE)
- self.assertRaises(ValueError,
+ self.assertRaises(TypeError,
call_module,
- 'm.proj', flags='i', input='-',
+ 'm.proj', flags='i', input='-', stdin="50.0 41.5",
stdout='any_value_or_type_here')
call_module,
stderr='any_value_or_type_here')
+class ModuleFunctionsTest(GrassTestCase):
+ def test_run_module_raise(self):
+ self.assertRaises(CalledModuleError,
+ run_module,
+ 'r.univar', aaabbbcc='notexist')
+ def test_read_module_return(self):
+ self.assertTrue(read_module('r.info', map='elevation'))
+ def test_read_module_raise(self):
+ read_module,
+ def test_write_module_missing_stdin(self):
+ write_module,
+ 'm.proj', aaabbbcc='notexist')
+ def test_write_module_return(self):
+ self.assertIsNone(write_module('m.proj', input='-', stdin='50,50',
+ flags='o'))
+ def test_write_module_raise(self):
+ write_module,
+ 'm.proj', stdin='50,50', aaabbbcc='notexist')
