[GRASS-SVN] r61012 - in grass/trunk/general: g.mremove g.remove
svn_grass at osgeo.org
Fri Jun 27 08:00:33 PDT 2014
Author: hcho
Date: 2014-06-27 08:00:33 -0700 (Fri, 27 Jun 2014)
New Revision: 61012
grass/trunk/general/g.mremove/check_reclass.c
grass/trunk/general/g.remove/main.c
g.mremove, g.remove: messages synced
Modified: grass/trunk/general/g.mremove/check_reclass.c
--- grass/trunk/general/g.mremove/check_reclass.c 2014-06-27 13:20:11 UTC (rev 61011)
+++ grass/trunk/general/g.mremove/check_reclass.c 2014-06-27 15:00:33 UTC (rev 61012)
@@ -16,8 +16,7 @@
G_warning(_("Raster map <%s@%s> is a base map for <%s>. Remove forced."),
name, mapset, *rmaps);
else
- G_warning(_
- ("Raster map <%s@%s> is a base map. Remove reclassed map first: %s"),
+ G_warning(_("Raster map <%s@%s> is a base map. Remove reclassed map <%s> first."),
@@ -39,8 +38,7 @@
if (nrmaps == 1 && !G_strcasecmp(rmaps[0], qname)) {
if (remove(path) < 0)
- G_warning(_
- ("Removing information about reclassed map from [%s@%s] failed"),
+ G_warning(_("Removing information about reclassed map from <%s@%s> failed"),
rname, rmapset);
else {
@@ -53,10 +51,8 @@
fclose(fp);
else
- G_warning(_
rname, rmapset);
Modified: grass/trunk/general/g.remove/main.c
--- grass/trunk/general/g.remove/main.c 2014-06-27 13:20:11 UTC (rev 61011)
+++ grass/trunk/general/g.remove/main.c 2014-06-27 15:00:33 UTC (rev 61012)
@@ -38,7 +38,7 @@
else
- G_warning(_("Raster <%s@%s> is a base map. Remove reclassed map <%s> first."),
