[GRASS-SVN] r61017 - grass/branches/releasebranch_6_4
svn_grass at osgeo.org
Fri Jun 27 08:14:01 PDT 2014
Author: martinl
Date: 2014-06-27 08:14:01 -0700 (Fri, 27 Jun 2014)
New Revision: 61017
Removed:
grass/branches/releasebranch_6_4/SUBMITTING_DOCS
grass/branches/releasebranch_6_4/SUBMITTING_PYTHON
grass/branches/releasebranch_6_4/SUBMITTING_SCRIPTS
grass/branches/releasebranch_6_4/SUBMITTING_TCLTK
SUBMITTING files moved to Trac http://trac.osgeo.org/grass/wiki/Submitting
Modified: grass/branches/releasebranch_6_4/SUBMITTING
--- grass/branches/releasebranch_6_4/SUBMITTING 2014-06-27 15:12:10 UTC (rev 61016)
+++ grass/branches/releasebranch_6_4/SUBMITTING 2014-06-27 15:14:01 UTC (rev 61017)
@@ -1,486 +1 @@
-$Date$
-NOTE: Please improve this list!
-Dear (new) GRASS Developer,
-When submitting C code to GRASS SVN repository, please take care of
-following rules:
-[ see SUBMITTING_SCRIPTS for shell script hints ]
-[ see SUBMITTING_TCLTK for tcl and tk hints ]
-[ see SUBMITTING_DOCS for documentation ]
-[ see SUBMITTING_PYTHON for Python code hints ]
-1. Get and read the GRASS 6 Programmer's Manual here:
- http://grass.osgeo.org/programming6/
- or generate it from this source code (the programmer's manual is
- integrated in the source code in doxygen style):
- make htmldocs
- make pdfdocs
-2. Use the directory structure to place your module appropriately into
- the source tree
- - libes go into lib/
- - raster goes into raster/
- - vector goes into vector/
- Consider to take a look at "GNU Coding Standards"
- http://www.gnu.org/prep/standards.html
- In future, there will be a centralized contribution directory.
-3. Add a header section to each file you submit and make sure you include
- the copyright. The purpose section is meant to contain a general
- overview of the code in the file to assist other programmers that will
- need to make changes to your code. If you are modifying an existing
- file you may under no circumstances remove prior copyright or licensing
- text that is not your own, even for a major rewrite. If any original
- code or code that is in part derived from another's original work
- remains, it must be properly cited.
- Example (ficticious header for a file called color.c) :
- * MODULE: d.rast (or new higher level module name (eg GRASS core))
- * AUTHOR(S): Original author unknown - probably CERL
- * John Doe <jdoe at somewhere org>
- * PURPOSE: To provide storage and manipulation of colors used for
- * rendering the raster. The colors are stored in a doubly linked
- * list which must be initialized with InitColors() before it can
- * be used. Note that most linked list functionality (add,
- * remove, get) is supported, but there is no sorting
- * functionality.
- * COPYRIGHT: (C) 2010 by the GRASS Development Team
- * This program is free software under the GNU General Public
- * License (>=v2). Read the COPYING file that comes with GRASS
- * for details.
- The copyright protects your rights according to GNU General Public
- License (www.gnu.org).
-4. - deleted.
- We don't want the $ID$ in source code any more as it causes problems
- for the SVN branches.
-5. To ensure that the software system continues to work, please include
- #include <grass/config.h>
- in your files and make use of the various system dependencies
- contained therein. As one example of this, see lib/gmath/fft.c.
- Please refrain from declaring system functions within the
- software; include the proper header files (conditionally dependent
- on config.h macros if necessary) instead.
-6. Order of include headers
- In general, headers should be included in the order:
- 1. Core system headers (stdio.h, ctype.h, ...)
- 2. Headers for non-core system components (X11, libraries).
- 3. Headers for core systems of the package being compiled (grass/gis.h, grass/glocale.h, ...)
- 4. Headers for the specific library/program being compiled (geodesic.h, ...)
- Each class of header has an obligation to be compatible with those
- above it in the list, but not those below it.
-7. Always specify the return type for ALL functions including those that
- return type "void", and insert return statements for any function
- which returns a value.
- Also, use ANSI C prototypes to declare your functions.
- For module return values, see "Exit status" below.
- Examples:
- void G_something(void);
- int G_something_else(int, int);
- /* Snipped out code */
- int G_something_else(int x, int y)
- return 0;
-8. Module exit status is defined as EXIT_SUCCESS or EXIT_FAILURE, e.g.
- if (G_parser (argc, argv))
- exit (EXIT_FAILURE);
- exit (EXIT_SUCCESS);
-9. Use fprintf instead of printf. But:
- For errors and warnings please use the G_fatal_error() and
- G_warning() functions. General messages for the user should use
- G_message() while debug messages should use G_debug() whenever
- possible. There are two variants to G_message(): G_verbose_message()
- which will only display the message if in verbose mode, and
- G_important_message() which will always show the message unless
- the module is running in --quiet mode. G_fatal_error() and
- G_warning() will always be displayed regardless of verbosity setting.
- Messages sent to any of these functions will be printed to stderr.
- G_message() output is not expected to be sent to pipe or file.
- Always use the gettext macros with _("") for user messages,
- example:
- G_fatal_error(_("Vector map <%s> not found"), name);
- Pipe/file data output:
- For data output redirected to pipe or file, please use fprintf() and
- specify the stdout stream as follows:
- fprintf(stdout, ...);
- fflush(stdout);
- fflush(stdout) always required when using fprintf(stdout, ...).
-10. Use the GRASS library function G_asprintf() instead of the
- standard C functions asprintf(), vsnprintf() and snprintf(). These
- functions are not portable or have other issues. Example:
- char *msg;
- G_asprintf(&msg, "%s", parameters);
- do_something_with_msg();
- G_free(msg);
- Note that you should free memory when G_asprintf() is used.
-11. Use the following GRASS library functions instead of the standard C
- functions. The reason for this is that the following functions ensure
- good programming practice (e.g. always checking if memory was allocated)
- and/or improves portability. PLEASE refer to the programmers manual
- for the proper use (e.g. determining if any casts are needed for arguments
- or return values) of these library functions. They may perform a task
- slightly different from their corresponding C library function, and thus,
- their use may not be the same.
- G_malloc() instead of malloc()
- G_calloc() instead of calloc()
- G_realloc() instead of realloc()
- G_free() instead of free()
- G_getenv() instead of getenv()
- G_setenv() instead of setenv()
- G_unsetenv() instead of unsetenv()
- G_sleep() instead of sleep()
- G_system() instead of system()
- Could somebody please add others (please verify that they are
- useful and safe first)
-12. Use function names which fulfill the official GNU naming convention.
- http://www.gnu.org/prep/standards/html_node/Names.html#Names
- Instead of naming a function like: MyNewFunction() use underscores
- for seperation and lower case letters: my_new_function().
-13. Don't use the C++ comment style! This confuses several compilers.
- Use instead:
- /* C-comments */
- If you want to comment code portions, use
- #ifdef notdef
- portion_to_be_commented;
- #endif
- This is safe comparing to nested /* comments */
- Functions in the library must be documented in doxygen style to
- get them into the programmer's manual (generate with
- make pdfdocs or
- make htmldocs
- ). See lib/gis/*.c for examples.
-14. PLEASE take the time to add comments throughout your code explaining what
- the code is doing. It will save a HUGE amount of time and frustration for
- other programmers that may have to change your code in the future.
-15. To promote a consistent coding style, please use the "indent" program
- on all new C modules using the following switches:
- $ indent -bad -bap -bbb -br -bli0 -bls -cli0 -ncs -fc1 -hnl -i4 \
- -nbbo -nbc -nbfda -nbfde -ncdb -ncdw -nce -nfca -npcs -nprs \
- -npsl -nsc -nsob -saf -sai -saw -sbi0 -ss -ts8 -ut main.c
- Existing code should not be re-indented except in extreme cases, as this
- will make "diff" comparisons with older versions impossible. If indent is
- needed, do not check in any changes other than the indentation in the same
- commit! Do add the indent switches and any indent warning messages to the
- SVN log. Any change or fix mixed in with an indent is very hard to track
- making it hard for others to follow the change or fix any new bugs.
- For your convenience use the tools/grass_indent.sh script.
-16. Platform dependent code:
- Do not remove #ifdef __CYGWIN__ and/or #ifndef __CYGWIN__ lines and
- their encapsulated lines from source code (one example was that someone
- removed drand48 definition.)
-17. Suggested compiler flags:
- We suggest to use very strict compiler flags to capture errors
- at the very beginning. Here our list of flags, please use them
- to configure you development version of GRASS:
- GNU/Linux:
- MYCFLAGS="-g -Wall -Werror-implicit-function-declaration -fno-common"
- MYCXXFLAGS="-g -Wall"
- CFLAGS="$MYCFLAGS" CXXFLAGS="$MYCXXFLAGS" ./configure ...
- MacOSX: [to be suggested]
- MS-Windows: [to be suggested]
-18. Make sure a new line is at the end of each file and UNIX style newlines
- are used (\n).
-19. When writing Makefiles, use the current standard.
- If you have to use commands, please check for:
- avoid | use instead
- make target | $(MAKE) target
- mkdir target | $(MKDIR) target
- cp (executable) | $(INSTALL) -m 755 file target
- cp (normal file) | $(INSTALL) -m 644 file target
- ar | $(AR)
- rm: be VERY careful with recursive remove. Also beware of
- removing $(FOO)* if $(FOO) has any chance of being empty.
- Examples: see below examples or others
- raster/r.info/Makefile
- vector/v.digit/Makefile
- If you are unsure, please ask on the GRASS Developers list.
-20. Have a look at ./INSTALL
-21. Have a function included in your module which writes to the history
- file of the map (e.g. command line, parameters etc.). See e.g.
- raster/r.patch/main.c
- (the same applies to vector and g3d modules!)
-22. Standard parser options: use G_define_standard_option() whenever possible
- to define standard module command line options. This will save you time,
- create fewer bugs, and make things easier on the translators.
- See lib/gis/parser.c for details of the function definition.
-23. Add/update, if required the related GUI menus:
- gui/tcltk/gis.m/gmmenu.tcl
- gui/wxpython/xml/menudata.xml
-24. For consistency, use README rather than README.txt for any README files.
-25. GRASS/Environment variables:
- If you add a new variable, please follow the naming convention.
- All variables are described in
- lib/init/variables.html
-26. Be sure to develop on top of the LATEST GRASS code (which is in our SVN
- repository). You can re-check before submission with 'svn diff':
- Be sure to create unified ("diff -u") format. "Plain" diffs (the default
- format) are risky, because they will apply without warning to code which
- has been substantially changed; they are also harder to read than unified.
- Such diffs should be made from the top-level directory, e.g.
- "svn diff display/d.vect/main.c"; that way, the diff will
- include the pathname rather than just an ambiguous "main.c".
-27. Try to use module names which describe shortly the intended purpose of the module.
- The first letters for module name should be:
- d. - display commands
- db. - database commands
- g. - general GIS management commands
- i. - imagery commands
- m. - miscellaneous tool commands
- ps. - postscript commands
- r. - raster commands
- r3. - raster3D commands
- v. - vector commands
- Some additional naming conventions
- * export modules: (type).out.(format) eg: r.out.arc, v.out.ascii
- * import module: (type).in.(format) eg: r.in.arc, v.in.ascii
- * conversion modules: (type).to.(type) eg: r.to.vect, v.to.rast, r3.to.rast
- Avoid module names with more than two dots in the name.
- Example:
- instead of r.to.rast3.elev use r.to.rast3elev
-28. Use the grass test suite to test your modules.
- http://www-pool.math.tu-berlin.de/~soeren/grass/GRASS_TestSuite
- You can easily write specific tests for your modules.
- If your module is part of GRASS and you created some standard test
- cases, please contact the developers to add your tests to the
- default test suite. This will automatize complex test scenarios
- and assure to find bugs much faster, if changes were made to your
- modules or to the grass library.
- Consider to subscribe to the GRASS Quality Assessment System to
- get immediate notification about the code quality:
- http://grass.osgeo.org/mailman/listinfo/grass-qa
-29. When submitting new files to the repository set SVN properties,
- usually for directory
- svn:ignore : *.tmp.html
- *OBJ*
- or e.g. for C-file
- svn:mime-type : text/x-csrc
- svn:keywords : Author Date Id
- svn:eol-style : native
- See
- http://svnbook.red-bean.com/en/1.4/svn.advanced.props.html
- To set a property:
- svn propset svn:keywords 'Author Date Id' <file>
- svn propset svn:mime-type text/x-sh grass_shellscript.sh
- To edit the svn:ignore property using your default text editor:
- svn propedit svn:ignore <directory>
- To set the svn:ignore property non-interactively, first create a
- file containing the value:
- echo "*.tmp.html" > ignore.txt
- echo "*OBJ*" >> ignore.txt
- then use:
- svn propset -F ignore.txt svn:ignore <directory>
- List of mime-type:
- C++ files (.cpp): text/x-c++src
- C files (.c): text/x-csrc
- DTD files (.dtd): text/xml-dtd
- GIF files (.gif): image/gif
- Header files (.h): text/x-chdr
- HTML files (.html): text/html
- JPEG files (.jpg): image/jpeg
- Makefiles: text/x-makefile
- PNG files (.png): image/png
- Python files (.py): text/x-python
- Shell scripts (.sh): text/x-sh
- Text files (.txt): text/plain
- XML files (.xml): text/xml
- (please update the list...)
-30. Use doxygen style for source code documentation. It is required
- for GRASS libraries, but also recommended for GRASS modules.
- Do not use structural command inside documentation block since it
- leads to some duplication of information (e.g. do not use \fn
- command in comment blocks). The exception is \file command for
- documenting a file, in this case structural command is required.
- For files
- \file snap.c
- \brief Vector library - Clean vector map (snap lines)
- (C) 2001-2008 by the GRASS Development Team
- This program is free software under the
- GNU General Public License (>=v2).
- Read the file COPYING that comes with GRASS
- for details.
- \author Radim Blazek
- \date 2001-2008
- For functions
- \brief Snap lines in vector map to existing vertex in threshold
- For details see Vect_snap_lines_list()
- \param Map pointer to input vector map
- \param type filter features of given type to be snap
- \param thresh threshold value for snapping
- \param[out] Err pointer to vector map where lines representing snap are written or NULL
- \param[out] msgout file pointer where messages will be written or NULL
- \return 1
-31. Tell the other developers about the new code using the following e-mail:
- grass-dev at lists.osgeo.org
- To subscribe to this mailing list, see
- http://lists.osgeo.org/mailman/listinfo/grass-dev
-32. In case of questions feel free to contact the developers at the above
- mailing list.
- http://grass.osgeo.org/devel/index.php#submission
-[please add further hints if required]
+See http://trac.osgeo.org/grass/wiki/Submitting
Deleted: grass/branches/releasebranch_6_4/SUBMITTING_DOCS
--- grass/branches/releasebranch_6_4/SUBMITTING_DOCS 2014-06-27 15:12:10 UTC (rev 61016)
+++ grass/branches/releasebranch_6_4/SUBMITTING_DOCS 2014-06-27 15:14:01 UTC (rev 61017)
@@ -1,124 +0,0 @@
-$Date$
-Dear (new) GRASS GIS Developer,
-When submitting documentation to GRASS SVN repository, please take
-care of following rules:
-[ see SUBMITTING for C hints ]
-0. Introduction
- There are two types of documentation
- - Libraries programmers docs: we use doxygen and document the functions
- directly in the source code. See lib/*/*.c and lib/*/*.dox for examples
- - User manual: we write it in simple HTML, storing the manual in a
- file "description.html" within the subdirectory of the module.
- The file contains no header nor footer. The complete HTML file is
- autogenerated during the compilation process (indeed, it is generated
- in a virtual session directly after compilation of the module).
- In this virtual session the module is called internally with
- --html-description which generates the parameters/flags list in
- HTML format, along with "description.html", HTML header and footer
- the final HTML manual page is created and stored in the target
- binaries directory. In a separate process the MAN format is
- generated from the complete HTML files.
-1. Editing of HTML pages
- To avoid insertion of too complicated HTML tags (see also below),
- we strongly suggest to use a plain text editor rather than a
- HTML editor for editing.
-2. Module manual page:
- Place the documentation in HTML format into 'description.html'.
- The easiest way to do this is to study an existing HTML page
- (to get the page style, e.g. vector/v.to.db/v.to.db.html).
- With a few exceptions, header and footer are NOT allowed.
- You can add figures (PNG format); the figure name prefix should be the
- module name. See raster/r.terraflow/r.terraflow.html for an example.
- A number of major sections should be present in each help page.
- * = Required
- ! = Suggested
- . = Optional
- In recommended order
- * <h2>DESCRIPTION</h2>
- ! <h2>NOTE</H2>, <h2>NOTES</h2>
- ! <h2>EXAMPLE</h2>, <h2>EXAMPLES</h2>
- . <h2>TODO</h2>
- . <h2>BUGS</h2>
- . <h2>REFERENCE</h2>, <h2>REFERENCES</h2>
- * <h2>SEE ALSO</h2>
- * <h2>AUTHOR</h2>, <h2>AUTHORS</h2>
- Note that the parameter information is auto-generated upon
- compilation. This is done by running the module in a virtual session
- after compilation (see the output of 'make'). To subsequently
- verify the final HTML page, check the resulting HTML pages which
- will be stored with the name of the module.
- Examples (please add some) should be coded like this:
- <div class="code"><pre>
- v.to.db map=soils type=area option=area col=area_size unit=h
- </pre></div>
- The online WWW man pages is updated every Saturday (from SVN
- repository).
-3. Usage of limited HTML tags
- Since the MAN conversion of g.html2man is limited, please use
- no other HTML tags than:
- <a> <b> <blink> <body> <br> <code> <dd> <dl> <dt> <em>
- <h2> <h3> <h4> <head> <header> <hr> <i> <img> <li> <ol> <p>
- <pre> <sup> <table> <td> <th> <title> <tr> <ul>
- Note that all tags has a closing tag except for <hr/>, <br/> and <p>.
- Use lower case forms.
- (The MAN converter is here: tools/g.html2man/)
-4. Suggested HTML markup protocol:
- Module names (i.e., v.category) should be emphsized with <em>,
- and boldface <b> for flags and parameter names. Shell commands,
- names, values, etc. should use <tt>. Empahsized phrases should use
- italics <i>. The SEE ALSO section of each page should also be
- alphabetized.
-5. When submitting new files to the repository set SVN properties,
- e.g. for HTML file
- svn:mime-type : text/html
- See
- You can also simply use this script:
- http://svn.osgeo.org/grass/grass-addons/tools/module_svn_propset.sh
-6. Compress PNG images with
-7. See also
- http://grass.osgeo.org/wiki/Updating_GRASS_Documentation
-"Your attention to detail is appreciated."
Deleted: grass/branches/releasebranch_6_4/SUBMITTING_PYTHON
--- grass/branches/releasebranch_6_4/SUBMITTING_PYTHON 2014-06-27 15:12:10 UTC (rev 61016)
+++ grass/branches/releasebranch_6_4/SUBMITTING_PYTHON 2014-06-27 15:14:01 UTC (rev 61017)
@@ -1,212 +0,0 @@
-Dear (new) GRASS developer,
-when submitting Python code to GRASS SVN repository, please take
-See also http://www.python.org/dev/peps/pep-0008/
-0. Indentation
- As Python determines nesting based upon indentation, it isn't just
- a stylistic issue.
- Please use 4-space indentation (GNU Emacs python-mode default).
- See also "Python Style Guide" by Guido van Rossum
- http://www.python.org/doc/essays/styleguide.html
-1. Instructions for the GRASS script parser can be found in the g.parser
- module's help page.
- http://grass.osgeo.org/grass70/manuals/html70_user/g.parser.html
-2. Use the directory structure to place your script appropriately into
- the source tree
- - scripts go into scripts/
- Also add a Makefile and a <module>.html file into this directory.
- See existing Python scripts for examples.
-3. Add a header section to the script you submit and make sure you
- include the copyright. The purpose section is meant to contain a
- general over view of the code in the file to assist other
- programmers that will need to make changes to your code. For this
- purpose use Python Docstring, see
- http://epydoc.sourceforge.net/docstrings.html
- Example (fictitious header for a script called g.myscript):
-MODULE: g.myscript
-AUTHOR(S): John Doe <email AT some domain>
-PURPOSE: Describe your script here...
-COPYRIGHT: (C) 2007 John Doe, and by the GRASS Development Team
- This program is free software under the GNU General Public
- License (>=v2). Read the file COPYING that comes with GRASS
- for details.
- You can easily autogenerate the header and parameters from an existing
- module using the --script flag. Example:
- d.rast --script
- Just select an existing module which is close to your application to save
- efforts.
-4. We don't want the $ ID $ in source code any more as it causes problems
- for the branches.
-5. Create and use secure temporary files and directories. Use the
- grass.tempfile() or grass.tempdir() functions to do this. e.g.
- # setup temporary file
- TMP = grass.tempfile()
- if TMP is None:
- grass.fatal("Unable to create temporary files")
-6. Use grass.findfile() when there is a need to test if a map exists.
- # test for input raster map
- result = grass.find_file(name = map_name, element = 'cell', quiet = True)
- if not result['file']
- grass.fatal("Raster map <%s> not found" % map_name)
- # test for input vector map
- result = grass.find_file(name = map_name, element = 'vector', quiet = True)
- grass.fatal("Vector map <%s> not found" % map_name)
- ... and so forth. See 'g.manual g.findfile' for details.
-7. For any informational output, use the grass.message()
- function. For error messages should be used grass.fatal_error() or
- grass.error() and for warnings grass.warning(). For debugging
- purposes grass.debug().
- #normal message:
- grass.message("Done")
- # warning:
- grass.warning("No input values found, using default values")
- # error:
- grass.error("No map found")
- # fatal error:
- grass.fatal_error("No map found, exiting")
- # debug output (use g.gisenv to enable/disable)
- grass.debug("Our calculated value is: %d" % value)
- Try to omit any usage of the 'print' command for informational output.
-8. PLEASE take the time to add comments throughout your code explaining what
-9. Make sure a new line is at the end of each file.
-10. For consistency, use README rather than README.txt for any README files.
-11. Be sure to develop on top of the LATEST GRASS code (which is in SVN repository).
- You can re-check before submission with 'svn diff':
- "svn diff gui/wxpython/wxgui.py"; that way, the diff will
- include the pathname rather than just "wxgui.py".
-12. When submitting new files to the repository set SVN properties,
- svn:ignore : *.pyc
- or e.g. for Python file
- svn:mime-type : text/python
- See
-13. wxGUI (gui/wxpython)
- See http://wiki.wxpython.org/wxPython_Style_Guide
- Major rules:
- - use named parameters in functions, e.g.
- dlg = wx.FileDialog(parent = self, message = _("Choose file to save current workspace"),
- wildcard = _("GRASS Workspace File (*.gxw)|*.gxw"), style = wx.FD_SAVE)
- instead of
- dlg = wx.FileDialog(self, _("Choose file to save current workspace"),
- _("GRASS Workspace File (*.gxw)|*.gxw"), wx.FD_SAVE)
- - use wx.ID_ANY instead of `-1`
- - use gcmd.GError(), gcmd.GWarning and gcmd.GMessage instead of wx.MessageBox()
- - use gcmd.RunCommand() instead of grass.run_command() or grass.read_command()
- - use full strings, eg.
- if ...:
- win.SetLabel(_('Name for new 3D raster map to create'))
- else:
- win.SetLabel(_('Name for new raster map to create'))
- instead of
- _('Name for new %s to create') % maplabel
- where `maplabel` can be 'raster map' or '3D raster map'
-14. Tell the other developers about the new code using the following e-mail:
-15. In case of questions feel free to contact the developers at the above
- mailing list.
Deleted: grass/branches/releasebranch_6_4/SUBMITTING_SCRIPTS
--- grass/branches/releasebranch_6_4/SUBMITTING_SCRIPTS 2014-06-27 15:12:10 UTC (rev 61016)
+++ grass/branches/releasebranch_6_4/SUBMITTING_SCRIPTS 2014-06-27 15:14:01 UTC (rev 61017)
@@ -1,247 +0,0 @@
-$Date$
-When submitting SHELL scripts to GRASS SVN repositiory,
-please take care of following rules:
-[ see SUBMITTING for C code hints ]
-0. Instructions for the GRASS script parser can be found in the g.parser
- http://grass.osgeo.org/grass64/manuals/html64_user/g.parser.html
-1. Use the directory structure to place your script appropriately into
- the source tree
- Consider to take a look at [please suggest Shell tutorial].
- Also add a Makefile and a description.html file into this directory.
- See existing scripts for examples.
-2. Add a header section to the script you submit and make sure you include
- Example (ficticious header for a script called r.myscript) :
-#!/bin/sh
-# MODULE: r.myscript
-# AUTHOR(S): Me <email AT some domain>
-# PURPOSE: Calculates univariate statistics from a GRASS raster map
-# COPYRIGHT: (C) 2005 by the GRASS Development Team
-# This program is free software under the GNU General Public
-# License (>=v2). Read the file COPYING that comes with GRASS
-# for details.
- d.rast --script
- efforts.
-3. - deleted.
- We don't want the $ ID $ in scripts any more as it
- causes problems for the SVN branches.
-4. As a general principle, shell variables should almost always be quoted.
- Use only secure temp files, see g.tempfile and scripts/* for examples.
-5. [This rule is currently under review] If you search for a command in $PATH, do NOT
- use the "which" command or the "type -p" command. Both commands are not
- supported on all platforms, thus causing problems for some people. As an
- alternative, please use code similar to the following shell script snippet
- which will perform the same function. In this case, the path of the grass60
- command is saved if grass60 is found in $PATH. This won't recognize aliased
- command name.
- # Search for grass5 command in user's path
- for i in `echo $PATH | sed 's/^:/.:/
- s/::/:.:/g
- s/:$/:./
- s/:/ /g'`
- do
- if [ -f $i/grass5 ] ; then
- # Save the path of the grass60 command
- GRASS_PATH=$i/grass60
- # Use the first one in user's path
- break
- fi
- done
- If you must use "which", use as follows:
- # check if we have awk
- if [ ! -x "`which awk`" ] ; then
- g.message -e "awk required, please install awk or gawk first"
- exit 1
- fi
-6. Add a test to check if the user is in GRASS before starting main part
- of script. Result of running the script is unpredicable otherwise.
- if [ -z "$GISBASE" ] ; then
- echo "You must be in GRASS GIS to run this program." 1>&2
- exit 1
- fi
- This is the only case, where g.message module (see below) can not be used.
- In all other cases, you should prefer it's usage over the 'echo' command.
-7. Create and use secure temporary files and directories. Use the g.tempfile
- module to do this. e.g.
- TMP="`g.tempfile pid=$$`"
- if [ $? -ne 0 ] || [ -z "$TMP" ] ; then
- g.message -e "unable to create temporary files"
- exit 1
- fi
- For temportary directories remove the newly created file and mkdir using
- the same name. Beware of commands like "rm -f ${TMP}*" as this becomes
- "rm -f *" if $TMP is unset (hence the test above).
-8. Testing the existence of variables. For portability, use
- if [ -z "$VARIABLE" ] ; then
- instead of
- if [ "$VARIABLE" = "" ] ; then
- and
- if [ -n "$VARIABLE" ] ; then
- instead of
- if [ "$VARIABLE" != "" ] ; then
-9. Internationalization proofing Awk: In some areas (e.g. some European
- countries) the decimal place is held with a comma instead of a dot.
- When scanning variables awk doesn't understand this, so scripts need to
- temporarily discard locale settings before calling awk.
- # set environment so that awk works properly in all languages
- unset LC_ALL
- LC_NUMERIC=C
- export LC_NUMERIC
- awk '{print $1}'
-10. Use g.findfile when there is a need to test if a map exists.
- g.findfile element=cell file="$INPUT" > /dev/null
- if [ $? -eq 0 ] ; then
- g.message -e "Raster map <$GIS_OPT_MAP> not found in mapset search path"
- exit 1
- fi
- eval `g.findfile element=vector file=$GIS_OPT_MAP`
- if [ ! "$file" ] ; then
- g.message -e "Vector map <$GIS_OPT_MAP> not found in mapset search path"
- exit 1
- fi
-11. For any informational output, use the g.message modul. This module should
- be also used for error messages and warnings. You can also use it for
- debugging purposes.
- #normal message:
- g.message "Done"
- # warning:
- g.message -w "No input values found, using default values"
- # error:
- g.message -e "No map found, exiting."
- g.message -d "Our calculated value is: $value"
- Try to omit any usage of the 'echo' command for informational output.
-12. For consistency, use README rather than README.txt for any README files.
-13. Be sure to develop on top of the LATEST GRASS code (which is in SVN).
- You can re-check before submission with 'cvs diff':
- diffs (the default format) are risky, because they will apply without
- warning to code which has been substantially changed; they are also
- harder to read than unified.
- "cvs diff display/d.vect/main.c"; that way, the diff will
- include the pathname rather than just "main.c".
-14. For portability, scripts must work on any POSIX compliant shell, and
- therefore may not include any Bashisms. Test with ash for errors:
- ash -n scriptname
-15. When submitting new files to the repository set SVN properties,
- or e.g. for script file
- svn:executable : *
- svn:mime-type : text/x-sh
- See
-16. Tell the other developers about the new code using the following e-mail:
-17. In case of questions feel free to contact the developers at the above
- mailing list.
Deleted: grass/branches/releasebranch_6_4/SUBMITTING_TCLTK
--- grass/branches/releasebranch_6_4/SUBMITTING_TCLTK 2014-06-27 15:12:10 UTC (rev 61016)
+++ grass/branches/releasebranch_6_4/SUBMITTING_TCLTK 2014-06-27 15:14:01 UTC (rev 61017)
@@ -1,281 +0,0 @@
-$Date$
-When submitting TCL and TK SCRIPTS to GRASS SVN repository,
-1. Use the directory structure to place your program appropriately into
- the source tree
- - general grass tcl/tk libraries and reusable code go into lib/gtcltk
- - user interfaces go in gui/tcltk
- - scripts go in scripts/
- Programs here must have a proper Makefile and description.html
- Example (fictitious header for a script called r.myscript) :
-# for details.
-3. PLEASE take the time to add comments throughout your code explaining what
- other programmers that need to change or understand your code in the future.
- Many of the programmers working on grass are not heavily invested in tcl
- and tk, so extra documentation and explanation are greatly appreciated.
-4. Test your program with both tcl/tk 8.3 and tcl/tk 8.4.
-5. Always use the gettext macros with [G_msg "..."] for user messages.
- The string must be quoted using quotation marks, not braces, for
- xgettext to find it. The string cannot include variable ($) or
- command ([...]) substitutions. If you need substitutions use
- [format ...].
- Examples:
- button .ok -text [G_msg "Ok"]
- set statusbartext [format [G_msg "Monitor %d running"] $monitor_number]]
- Use positional parameters if substitutions might be rearranged in another language:
- format [G_msg "We produced %1\$d units in location %2\$s"] $num $city
- format [G_msg "In location %2\$s we produced %1\$d units"] $num $city
-6. Use "GRASS_TCLSH" and "GRASS_WISH" environment variables instead of
- "tclsh" and "wish" at the start of Tcl/Tk scripts. This allows users to
- override the default names, so that developers don't need worry about the
- shell names.
- Tcl script:
- #!/bin/sh
- # the next line restarts using tclsh. Note the backslash: \
- exec $GRASS_TCLSH "$0" "$@"
- Tk script:
- #!/bin/sh
- # the next line restarts using wish. Note the backslash: \
- exec $GRASS_WISH "$0" "$@"
-7. Do not source files that have already been sourced.
- gui.tcl sources:
- options.tcl
- select.tcl
- gronsole.tcl
- If your code requires something to be sourced before it note so
- in a comment at the top of the file.
-8. Set tabstops in your editor to 8 spaces.
- When modifying files use the indentation style that is already present.
- Please use consistent indentation style in your new code. Whether you use
- tabs or spaces to indent please be consistent. Where tabs and spaces are
- mixed please remember that a tab is 8 spaces.
-9. Use the tk options database to control the appearance of your user interface.
- In general do not set options on tk widgets unless that option is truly
- specific to that widget. It makes them harder to customize.
- Example: Don't set options like -foreground or -background or -font
- when creating widgets, unless there's a really _really_ specific reason to
- have it that color (like it's demonstrating that color).
- If you want something like a label to look different than everything else
- of that class (other labels) give it a distinctive name, like
- .moduletitlelabel . If you have a bunch of them give them all the same
- distinctive name. This allows them to have their options controlled by the
- options database.
- You can put your options at the start of your script (before creating any
- widgets) like this:
- option add *modultitlelabel.background red
- More examples are in lib/gtcltk/options.tcl
- Many common options, like font, background and foreground colors,
- highlighting, scrollbar colors, and help bubble appearance are controlled
- by options.tcl. You can include it at the start of your script with:
- source $env(GISBASE)/etc/gtcltk/options.tcl
-10. Avoid using global variables. Thay are a frequent source of bugs, make code
- harder to understand, and make your program difficult to reuse. Additionally,
- putting code into procs usually makes it run faster (it gets compiled).
-11. For consistency, use README rather than README.txt for any README files.
-12. Use of GRASS commands in shell wrapper.
- Any GRASS program run in an xterm (those which do interactive query) needs
- to use grass-run.sh, e.g.:
- exec -- $env(GISBASE)/etc/grass-xterm-wrapper -e $env(GISBASE)/etc/grass-run.sh g.proj ...
- You should probably also use "-T g.proj -n g.proj" to set the title
- back (otherwise it will be "grass-run.sh", which isn't particularly
- informative).
- The xterm will close as soon as the command completes (whether it
- succeeds or fails). You can use the -hold switch to retain the xterm
- window after the command completes, but you should only do that for
- debugging; having to manually close the xterm window each time would
- be annoying in normal use. Alternatively, redirect stdout/stderr to a
- file, to catch any error messages.
- SVN repository). You can re-check before submission with 'svn
- diff':
- mailing list.
-16. Try to evaluate things only once. Tcl compiles the program to bytecode which
- can be interpreted fairly quickly. If there are strings that must still be
- evaluated tcl must parse and either compile or interpret them
- each time they are encountered. In general this means put braces around
- expressions and especially regular expressions (Tcl also compiles regular
- expressions). Multiple evaluation can also lead to bugs.
- Expressions via expr command:
- Slow:
- set y [expr $a * $x + $b]
- Fast:
- set y [expr {$a * $x + $b}]
- Expressions in conditions:
- Slow:
- if [...] {...
- Fast:
- if {[...]} {...
- Regular expressions:
- Very slow:
- regex "x(\[0-9\]+).*not" $string trash number
- Fast:
- regex {x([0-9]+).*not} $string trash number
- If you really want speed:
- If a regular expression needs to be constructed from variables but used
- multiple times store it in a variable that will not be destroyed or
- changed between reuse. Tcl stores the compiled regex with the variable.
-17. You might want to decompose lists in a somewhat easy way:
- Difficult and slow:
- # Make x1 y1 x2 y2 the first four things in the list
- set list [commandMakesList]
- set x1 [lindex $list 0]
- set y1 [lindex $list 1]
- set x2 [lindex $list 2]
- set y2 [lindex $list 3]
- Easier and faster:
- foreach {x1 y1 x2 y2} [commandMakesList] {break}
- Be sure to include a comment as to what you are doing.
-18. Use the Tcl list functions (list, lappend etc) for manipulating lists.
- For example, use:
- set vals [list $foo $bar]
- rather than:
- set vals "$foo $bar"
- The former will always create a list with two elements, adding braces
- if necessary, while the latter will split $foo and $bar into multiple
- elements if they contain spaces. Additionally the first is faster
- because tcl is not internally converting between strings and lists.
- A related issue is to remember that command lines (as used by exec and
- open "|...") are lists. exec behaves like execl(), spawnl() etc, and
- not like system().
- Overlooking either of these points is likely to result in code which
- fails when a command argument contains a space.
-19. Tcl C library:
- Memory allocated with Tcl_Alloc (such as the result of Tcl_Merge)
- must be freed with Tcl_Free. This means that the ->freeProc of
- an interpreter when returning a string using Tcl_Merge should be
- TCL_DYNAMIC. Incorrectly freeing memory with glibc free will
- cause segfaults in Tcl 8.4 and later.
-20. When submitting new files to the repository set SVN properties,
- e.g.
- svn:mime-type : text/x-tcl
- See
