[GRASS-SVN] r61024 - in grass/branches/releasebranch_7_0/gui/wxpython: core iscatt mapwin
svn_grass at osgeo.org
Sat Jun 28 06:24:01 PDT 2014
Author: martinl
Date: 2014-06-28 06:24:01 -0700 (Sat, 28 Jun 2014)
New Revision: 61024
Added:
grass/branches/releasebranch_7_0/gui/wxpython/core/gthread.py
grass/branches/releasebranch_7_0/gui/wxpython/iscatt/controllers.py
grass/branches/releasebranch_7_0/gui/wxpython/mapwin/buffered.py
wxGUI: move gThread to core package
(merge r60864 from trunk)
Copied: grass/branches/releasebranch_7_0/gui/wxpython/core/gthread.py (from rev 60864, grass/trunk/gui/wxpython/core/gthread.py)
--- grass/branches/releasebranch_7_0/gui/wxpython/core/gthread.py (rev 0)
+++ grass/branches/releasebranch_7_0/gui/wxpython/core/gthread.py 2014-06-28 13:24:01 UTC (rev 61024)
@@ -0,0 +1,120 @@
+ at package core.gthread
+ at brief Threading
+Classes:
+ - gthread::gThread
+(C) 2013-2014 by the GRASS Development Team
+This program is free software under the GNU General Public License
+(>=v2). Read the file COPYING that comes with GRASS for details.
+ at author Stepan Turek <stepan.turek seznam.cz> (mentor: Martin Landa)
+import threading
+import time
+import wx
+import Queue
+from core.gconsole import EVT_CMD_DONE, wxCmdDone
+class gThread(threading.Thread, wx.EvtHandler):
+ """Thread for various backends"""
+ requestId = 0
+ def __init__(self, requestQ=None, resultQ=None, **kwds):
+ wx.EvtHandler.__init__(self)
+ self.terminate = False
+ threading.Thread.__init__(self, **kwds)
+ if requestQ is None:
+ self.requestQ = Queue.Queue()
+ else:
+ self.requestQ = requestQ
+ if resultQ is None:
+ self.resultQ = Queue.Queue()
+ else:
+ self.resultQ = resultQ
+ self.setDaemon(True)
+ self.Bind(EVT_CMD_DONE, self.OnDone)
+ self.start()
+ def Run(self, *args, **kwds):
+ """Run command in queue
+ :param args: unnamed command arguments
+ :param kwds: named command arguments, keyword 'callable'
+ represents function to be run, keyword 'ondone'
+ represents function to be called after the
+ callable is done
+ :return: request id in queue
+ gThread.requestId += 1
+ self.requestQ.put((gThread.requestId, args, kwds))
+ return gThread.requestId
+ def GetId(self):
+ """Get id for next command"""
+ return gThread.requestId + 1
+ def SetId(self, id):
+ """Set starting id"""
+ gThread.requestId = id
+ def run(self):
+ while True:
+ requestId, args, kwds = self.requestQ.get()
+ for key in ('callable', 'ondone', 'userdata'):
+ if key in kwds:
+ vars()[key] = kwds[key]
+ del kwds[key]
+ else:
+ vars()[key] = None
+ requestTime = time.time()
+ ret = None
+ exception = None
+ time.sleep(.01)
+ if self.terminate:
+ return
+ ret = vars()['callable'](*args, **kwds)
+ return
+ #except Exception as e:
+ # exception = e;
+ self.resultQ.put((requestId, ret))
+ event = wxCmdDone(ondone=vars()['ondone'],
+ kwds=kwds,
+ args=args, #TODO expand args to kwds
+ ret=ret,
+ exception=exception,
+ userdata=vars()['userdata'],
+ pid=requestId)
+ # send event
+ wx.PostEvent(self, event)
+ def OnDone(self, event):
+ if event.ondone:
+ event.ondone(event)
+ def Terminate(self):
+ """Abort command(s)"""
+ self.terminate = True
Modified: grass/branches/releasebranch_7_0/gui/wxpython/iscatt/controllers.py
--- grass/branches/releasebranch_7_0/gui/wxpython/iscatt/controllers.py 2014-06-28 09:07:24 UTC (rev 61023)
+++ grass/branches/releasebranch_7_0/gui/wxpython/iscatt/controllers.py 2014-06-28 13:24:01 UTC (rev 61024)
@@ -11,7 +11,6 @@
- controllers::IClassDigitConnection
- controllers::IMapDispConnection
- controllers::IClassConnection
- - controllers::gThread
(C) 2013 by the GRASS Development Team
@@ -25,21 +24,18 @@
from copy import deepcopy
import wx
-import time
-import threading
-import Queue
-from core.gconsole import EVT_CMD_DONE
from core.gcmd import GException, GError, GMessage, RunCommand, GWarning
from core.settings import UserSettings
-from core.gconsole import wxCmdRun, wxCmdDone, wxCmdPrepare
+from core.gthread import gThread
from iscatt.iscatt_core import Core, idBandsToidScatt, GetRasterInfo, GetRegion, \
MAX_SCATT_SIZE, WARN_SCATT_SIZE, MAX_NCELLS, WARN_NCELLS
from iscatt.dialogs import AddScattPlotDialog, ExportCategoryRaster
from iclass.dialogs import IClassGroupDialog
import grass.script as grass
from grass.pydispatch.signal import Signal
class ScattsManager:
@@ -1110,101 +1106,3 @@
if res.split('\n')[0]:
bands = res.split('\n')
self.scatt_mgr.SetBands(bands)
-#TODO it uses also BufferedMapWindow class -> move to core?
-class gThread(threading.Thread, wx.EvtHandler):
- """!Thread for scatter plot backend"""
- requestId = 0
- def __init__(self, requestQ=None, resultQ=None, **kwds):
- wx.EvtHandler.__init__(self)
- self.terminate = False
- threading.Thread.__init__(self, **kwds)
- if requestQ is None:
- self.requestQ = Queue.Queue()
- else:
- self.requestQ = requestQ
- if resultQ is None:
- self.resultQ = Queue.Queue()
- else:
- self.resultQ = resultQ
- self.setDaemon(True)
- self.Bind(EVT_CMD_DONE, self.OnDone)
- self.start()
- def Run(self, *args, **kwds):
- """!Run command in queue
- @param args unnamed command arguments
- @param kwds named command arguments,
- keyword 'callable' represents function to be run,
- keyword 'ondone' represents function to be
- called after the callable is done
- @return request id in queue
- gThread.requestId += 1
- self.requestQ.put((gThread.requestId, args, kwds))
- return gThread.requestId
- def GetId(self):
- """!Get id for next command"""
- return gThread.requestId + 1
- def SetId(self, id):
- """!Set starting id"""
- gThread.requestId = id
- def run(self):
- while True:
- requestId, args, kwds = self.requestQ.get()
- for key in ('callable', 'ondone', 'userdata'):
- if key in kwds:
- vars()[key] = kwds[key]
- del kwds[key]
- else:
- vars()[key] = None
- requestTime = time.time()
- ret = None
- exception = None
- time.sleep(.01)
- if self.terminate:
- return
- ret = vars()['callable'](*args, **kwds)
- return
- #except Exception as e:
- # exception = e;
- self.resultQ.put((requestId, ret))
- event = wxCmdDone(ondone=vars()['ondone'],
- kwds=kwds,
- args=args, #TODO expand args to kwds
- ret=ret,
- exception=exception,
- userdata=vars()['userdata'],
- pid=requestId)
- # send event
- wx.PostEvent(self, event)
- def OnDone(self, event):
- if event.ondone:
- event.ondone(event)
- def Terminate(self):
- """!Abort command(s)"""
- self.terminate = True
Modified: grass/branches/releasebranch_7_0/gui/wxpython/mapwin/buffered.py
--- grass/branches/releasebranch_7_0/gui/wxpython/mapwin/buffered.py 2014-06-28 09:07:24 UTC (rev 61023)
+++ grass/branches/releasebranch_7_0/gui/wxpython/mapwin/buffered.py 2014-06-28 13:24:01 UTC (rev 61024)
@@ -41,7 +41,7 @@
from core.utils import GetGEventAttribsForHandler, _
import core.utils as utils
from mapwin.graphics import GraphicsSet
-from iscatt.controllers import gThread
try:
import grass.lib.gis as gislib
