[GRASS-SVN] r61026 - grass/trunk/general/g.mlist
svn_grass at osgeo.org
Sat Jun 28 06:59:27 PDT 2014
Author: hcho
Date: 2014-06-28 06:59:27 -0700 (Sat, 28 Jun 2014)
New Revision: 61026
grass/trunk/general/g.mlist/Makefile
grass/trunk/general/g.mlist/g.mlist.html
grass/trunk/general/g.mlist/main.c
g.mlist: Add region= for finding maps whose region intersects with the input region (ticket #2355)
Modified: grass/trunk/general/g.mlist/Makefile
--- grass/trunk/general/g.mlist/Makefile 2014-06-28 13:39:45 UTC (rev 61025)
+++ grass/trunk/general/g.mlist/Makefile 2014-06-28 13:59:27 UTC (rev 61026)
@@ -2,8 +2,8 @@
PGM = g.mlist
-LIBES = $(MANAGELIB) $(GISLIB)
-DEPENDENCIES = $(MANAGEDEP) $(GISDEP)
+LIBES = $(MANAGELIB) $(GISLIB) $(RASTERLIB) $(RASTER3DLIB) $(VECTORLIB)
+DEPENDENCIES = $(MANAGEDEP) $(GISDEP) $(RASTERDEP) $(RASTER3DDEP) $(VECTORDEP)
include $(MODULE_TOPDIR)/include/Make/Module.make
Modified: grass/trunk/general/g.mlist/g.mlist.html
--- grass/trunk/general/g.mlist/g.mlist.html 2014-06-28 13:39:45 UTC (rev 61025)
+++ grass/trunk/general/g.mlist/g.mlist.html 2014-06-28 13:59:27 UTC (rev 61026)
@@ -123,7 +123,7 @@
List "tmp" if "tmp" raster map exists:
<div class="code"><pre>
-g.mlist -r pattern='^tmp$'
+g.mlist -r type=rast pattern='^tmp$'
</pre></div>
List "tmp0" ..."tmp9" if corresponding vector map exists
@@ -145,6 +145,20 @@
g.mlist -e type=rast separator=comma pattern="precip_total.(199[7-9]|200[0-9]|201[0-2]).sum"
</pre></div>
+<h3>Maps whose region overlaps with a saved region</h3>
+List all raster maps starting with "tmp_" whose region overlaps with
+a saved region "myregion":
+<div class="code"><pre>
+g.mlist type=rast pattern='tmp_*' region=myregion
+</pre></div>
+List "tmp0"..."tmp9" vector maps whose region overlaps with
+the current region:
+g.mlist -r type=vect pattern='^tmp[0-9]$' region=.
+</pre></div>
<h2>SEE ALSO</h2>
<em>
Modified: grass/trunk/general/g.mlist/main.c
--- grass/trunk/general/g.mlist/main.c 2014-06-28 13:39:45 UTC (rev 61025)
+++ grass/trunk/general/g.mlist/main.c 2014-06-28 13:59:27 UTC (rev 61026)
@@ -21,14 +21,25 @@
#include <unistd.h>
#include <string.h>
#include <grass/gis.h>
+#include <grass/raster3d.h>
+#include <grass/vector.h>
#include <grass/manage.h>
#include <grass/glocale.h>
#include <grass/spawn.h>
+enum {
+ TYPE_RAST = 0,
+ TYPE_RAST3D,
+ TYPE_VECT,
+ TYPE_3DVIEW,
+ TYPE_OTHERS
static int any = 0;
static void make_list(FILE *, const struct list *, const char *,
- const char *, int, int);
+ const char *, int, int, struct Cell_head *);
+static int region_overlaps(struct Cell_head *, const char *, const char *, int);
int main(int argc, char *argv[])
@@ -40,6 +51,7 @@
struct Option *exclude;
struct Option *separator;
struct Option *mapset;
+ struct Option *region;
struct Option *output;
} opt;
struct
@@ -57,6 +69,8 @@
FILE *fp;
const char *mapset;
char *separator;
+ int use_region;
+ struct Cell_head window;
G_gisinit(argv[0]);
@@ -95,10 +109,17 @@
opt.mapset->multiple = YES;
opt.mapset->label =
_("Name of mapset to list (default: current search path)");
- opt.mapset->description = _("'.' for current mapset; '*' for all mapsets in location");
+ opt.mapset->description =
+ _("'.' for current mapset; '*' for all mapsets in location");
opt.separator = G_define_standard_option(G_OPT_F_SEP);
opt.separator->answer = "newline";
+ opt.region = G_define_standard_option(G_OPT_M_REGION);
+ opt.region->label = _("Name of saved region for map search");
+ opt.region->description =
+ _("'*' for default region; '.' for current region "
+ "(default: not restricted)");
opt.output = G_define_standard_option(G_OPT_F_OUTPUT);
opt.output->required = NO;
opt.output->label = _("Name for output file");
@@ -143,6 +164,10 @@
G_fatal_error(_("-%c/-%c and %s= are mutually exclusive"),
flag.pretty->key, flag.full->key, opt.output->key);
+ if ((flag.pretty->answer || flag.full->answer) && opt.region->answer)
+ G_fatal_error(_("-%c/-%c and %s= are mutually exclusive"),
+ flag.pretty->key, flag.full->key, opt.region->key);
(flag.mapset->answer || flag.type->answer))
G_fatal_error(_("-%c/-%c and -%c/-%c are mutually exclusive"),
@@ -207,6 +232,25 @@
separator = G_option_to_separator(opt.separator);
+ if (opt.region->answer) {
+ use_region = 1;
+ if (strcmp(opt.region->answer, "*") == 0)
+ G_get_default_window(&window);
+ else if (strcmp(opt.region->answer, ".") == 0)
+ G_get_window(&window);
+ else {
+ char name[GNAME_MAX], mapset[GMAPSET_MAX];
+ if (G_name_is_fully_qualified(opt.region->answer, name, mapset))
+ G__get_window(&window, "windows", name, mapset);
+ else
+ G__get_window(&window, "windows", opt.region->answer, "");
+ else
+ use_region = 0;
for (i = 0; opt.type->answers[i]; i++) {
if (strcmp(opt.type->answers[i], "all") == 0)
break;
@@ -270,7 +314,7 @@
else {
for (j = 0; (mapset = G_get_mapset_name(j)); j++)
make_list(fp, elem, mapset, separator, flag.type->answer,
- flag.mapset->answer);
+ flag.mapset->answer, use_region ? &window : NULL);
@@ -294,16 +338,19 @@
static void make_list(FILE *fp, const struct list *elem, const char *mapset,
- const char *separator, int add_type, int add_mapset)
+ const char *separator, int add_type, int add_mapset,
+ struct Cell_head *window)
static int first_mapset = 1;
char path[GPATH_MAX];
- const char *element = elem->element[0];
- const char *alias = elem->alias;
+ const char *element, *alias;
char **list;
- int count;
- int i;
+ int count, first, i;
+ int type;
+ element = elem->element[0];
+ alias = elem->alias;
G_file_name(path, element, "", mapset);
if (access(path, 0) != 0)
return;
@@ -311,20 +358,43 @@
if ((list = G__ls(path, &count)) == NULL)
return;
- if (count > 0) {
- if (any)
- fprintf(fp, "%s", separator);
- if (fp == stdout && isatty(STDOUT_FILENO))
- G_message(_("%s available in mapset <%s>:"), elem->text, mapset);
+ if (strcmp(alias, "rast") == 0)
+ type = TYPE_RAST;
+ else if (strcmp(alias, "rast3d") == 0)
+ type = TYPE_RAST3D;
+ else if (strcmp(alias, "vect") == 0)
+ type = TYPE_VECT;
+ else if (strcmp(alias, "3dview") == 0)
+ type = TYPE_3DVIEW;
+ else
+ type = TYPE_OTHERS;
/* Suppress "... found in more mapsets" warnings from G_find_file2. */
G_suppress_warnings(1);
+ first = 1;
for (i = 0; i < count; i++) {
char *name = list[i];
int need_mapset = 0;
+ /* If region= is used, read the map region. */
+ if (window) {
+ /* If the map region doesn't overlap with the input region, don't
+ * print the map. */
+ if (!region_overlaps(window, name, mapset, type))
+ continue;
+ if (first) {
+ first = 0;
+ if (any)
+ fprintf(fp, "%s", separator);
+ if (fp == stdout && isatty(STDOUT_FILENO))
+ G_message(_("%s available in mapset <%s>:"),
+ elem->text, mapset);
if (any && i != 0)
@@ -353,3 +423,72 @@
first_mapset = 0;
+static int region_overlaps(struct Cell_head *window, const char *name,
+ const char *mapset, int type)
+ int has_region;
+ struct Cell_head map_window;
+ RASTER3D_Region wind;
+ struct Map_info Map;
+ struct bound_box box;
+ int ret;
+ struct G_3dview view;
+ switch (type) {
+ case TYPE_RAST:
+ Rast_get_cellhd(name, mapset, &map_window);
+ has_region = 1;
+ break;
+ case TYPE_RAST3D:
+ if (Rast3d_read_region_map(name, mapset, &wind) < 0)
+ G_fatal_error(_("Unable to read header of 3D raster map <%s@%s>"),
+ name, mapset);
+ Rast3d_region_to_cell_head(&wind, &map_window);
+ has_region = 1;
+ break;
+ case TYPE_VECT:
+ Vect_set_open_level(2);
+ if (Vect_open_old(&Map, name, mapset) < 2)
+ G_fatal_error(_("Unable to open vector map <%s> on topological level"),
+ name);
+ Vect_get_map_box(&Map, &box);
+ Vect_close(&Map);
+ map_window.north = box.N;
+ map_window.south = box.S;
+ map_window.west = box.W;
+ map_window.east = box.E;
+ has_region = 1;
+ break;
+ case TYPE_3DVIEW:
+ if ((ret = G_get_3dview(name, mapset, &view)) < 0)
+ G_fatal_error(_("Unable to read 3dview file <%s> in <%s>"),
+ name, mapset);
+ if (ret == 0)
+ G_fatal_error(_("Old 3dview file. Region <%s> not found in <%s>"),
+ name, mapset);
+ map_window.north = view.vwin.north;
+ map_window.south = view.vwin.south;
+ map_window.west = view.vwin.west;
+ map_window.east = view.vwin.east;
+ has_region = 1;
+ break;
+ default:
+ has_region = 0;
+ break;
+ /* If an element doesn't have a concept of region at all, return 1 so we
+ * can always print it. */
+ if (!has_region)
+ return 1;
+ /* If the map region is outside the input region, return 0. Otherwise
+ * return 1 */
+ return !(window->north <= map_window.south ||
+ window->south >= map_window.north ||
+ window->west >= map_window.east ||
+ window->east <= map_window.west);
