[GRASS-SVN] r61031 - grass/trunk/lib/python/pygrass/modules/interface
svn_grass at osgeo.org
Sat Jun 28 09:26:15 PDT 2014
Author: huhabla
Date: 2014-06-28 09:26:15 -0700 (Sat, 28 Jun 2014)
New Revision: 61031
grass/trunk/lib/python/pygrass/modules/interface/module.py
Added doctests to verify the handling of PIPE's for stdin, stdout and stderr.
Handling of ParallelModuleQueue is now easier.
Modified: grass/trunk/lib/python/pygrass/modules/interface/module.py
--- grass/trunk/lib/python/pygrass/modules/interface/module.py 2014-06-28 16:22:57 UTC (rev 61030)
+++ grass/trunk/lib/python/pygrass/modules/interface/module.py 2014-06-28 16:26:15 UTC (rev 61031)
@@ -7,7 +7,9 @@
@code
>>> import grass.pygrass.modules as pymod
+>>> from subprocess import PIPE
>>> import copy
>>> region = pymod.Module("g.region")
>>> region.flags["p"].value = True
>>> region.flags["u"].value = True
@@ -23,12 +25,14 @@
>>> neighbors.inputs["input"].value = "mapA"
>>> neighbors.outputs["output"].value = "mapB"
>>> neighbors.inputs["size"].value = 5
+>>> neighbors.inputs["quantile"].value = 0.5
>>> neighbors.get_bash()
u'r.neighbors input=mapA method=average size=5 quantile=0.5 output=mapB'
>>> new_neighbors1 = copy.deepcopy(neighbors)
>>> new_neighbors1.inputs["input"].value = "mapD"
>>> new_neighbors1.inputs["size"].value = 3
+>>> new_neighbors1.inputs["quantile"].value = 0.5
>>> new_neighbors1.get_bash()
u'r.neighbors input=mapD method=average size=3 quantile=0.5 output=mapB'
@@ -39,13 +43,56 @@
>>> neighbors = pymod.Module("r.neighbors")
-u'r.neighbors method=average size=3 quantile=0.5'
+u'r.neighbors method=average size=3'
>>> new_neighbors3 = copy.deepcopy(neighbors)
>>> new_neighbors3(input="mapA", size=3, output="mapB", run_=False)
>>> new_neighbors3.get_bash()
-u'r.neighbors input=mapA method=average size=3 quantile=0.5 output=mapB'
+u'r.neighbors input=mapA method=average size=3 output=mapB'
+>>> mapcalc = pymod.Module("r.mapcalc", expression="test_a = 1",
+... overwrite=True, run_=False)
+>>> mapcalc.run()
+Module('r.mapcalc')
+>>> mapcalc.popen.returncode
+0
+>>> colors = pymod.Module("r.colors", map="test_a", rules="-",
+... run_=False, stdout_=PIPE,
+... stderr_=PIPE, stdin_="1 red")
+>>> colors.run()
+Module('r.colors')
+>>> colors.popen.returncode
+0
+>>> colors.inputs["stdin"].value
+u'1 red'
+>>> colors.outputs["stdout"].value
+u''
+>>> colors.outputs["stderr"].value.strip()
+"Color table for raster map <test_a> set to 'rules'"
+... run_=False, finish_=False, stdin_=PIPE)
+>>> colors.run()
+Module('r.colors')
+>>> stdout, stderr = colors.popen.communicate(input="1 red")
+0
+>>> stdout
+>>> stderr
+... stdin_=PIPE, stderr_=PIPE)
+>>> colors.run()
+Module('r.colors')
+0
+>>> stdout
+>>> stderr.strip()
@endcode
from __future__ import (nested_scopes, generators, division, absolute_import,
@@ -87,8 +134,7 @@
>>> mapcalc_list = []
... overwrite=True,
- ... run_=False,
- ... finish_=False)
+ ... run_=False)
>>> queue = pymod.ParallelModuleQueue(max_num_procs=3)
>>> for i in xrange(5):
... new_mapcalc = copy.deepcopy(mapcalc)
@@ -127,6 +173,9 @@
:type module: Module object
self._list[self._proc_count] = module
+ # Force that finish is False, otherwise the execution
+ # will not be parallel
+ self._list[self._proc_count].finish_ = False
self._list[self._proc_count].run()
self._proc_count += 1
