[GRASS-SVN] r61034 - grass/trunk/general/g.mlist
svn_grass at osgeo.org
Sat Jun 28 14:29:03 PDT 2014
Author: hcho
Date: 2014-06-28 14:29:03 -0700 (Sat, 28 Jun 2014)
New Revision: 61034
grass/trunk/general/g.mlist/main.c
g.mlist: List old 3dview files always with a warning
Modified: grass/trunk/general/g.mlist/main.c
--- grass/trunk/general/g.mlist/main.c 2014-06-28 18:57:00 UTC (rev 61033)
+++ grass/trunk/general/g.mlist/main.c 2014-06-28 21:29:03 UTC (rev 61034)
@@ -428,11 +428,11 @@
int has_region;
struct Cell_head map_window;
- RASTER3D_Region wind;
+ RASTER3D_Region region3d;
struct Map_info Map;
struct bound_box box;
int ret;
- struct G_3dview view;
+ struct G_3dview view3d;
switch (type) {
case TYPE_RAST:
@@ -440,17 +440,17 @@
has_region = 1;
break;
case TYPE_RAST3D:
- if (Rast3d_read_region_map(name, mapset, &wind) < 0)
+ if (Rast3d_read_region_map(name, mapset, ®ion3d) < 0)
G_fatal_error(_("Unable to read header of 3D raster map <%s@%s>"),
name, mapset);
- Rast3d_region_to_cell_head(&wind, &map_window);
+ Rast3d_region_to_cell_head(®ion3d, &map_window);
has_region = 1;
break;
case TYPE_VECT:
Vect_set_open_level(2);
if (Vect_open_old(&Map, name, mapset) < 2)
- G_fatal_error(_("Unable to open vector map <%s> on topological level"),
- name);
+ G_fatal_error(_("Unable to open vector map <%s@%s> on topological level"),
+ name, mapset);
Vect_get_map_box(&Map, &box);
Vect_close(&Map);
@@ -461,18 +461,21 @@
has_region = 1;
break;
case TYPE_3DVIEW:
- if ((ret = G_get_3dview(name, mapset, &view)) < 0)
- G_fatal_error(_("Unable to read 3dview file <%s> in <%s>"),
+ if ((ret = G_get_3dview(name, mapset, &view3d)) < 0)
+ G_fatal_error(_("Unable to read 3dview file <%s@%s>"),
name, mapset);
- if (ret == 0)
- G_fatal_error(_("Old 3dview file. Region <%s> not found in <%s>"),
+ if (ret == 0) {
+ G_warning(_("No region in an old 3dview file <%s@%s>. Listing anyway"),
name, mapset);
- map_window.north = view.vwin.north;
- map_window.south = view.vwin.south;
- map_window.west = view.vwin.west;
- map_window.east = view.vwin.east;
- has_region = 1;
+ has_region = 0;
+ else {
+ map_window.north = view3d.vwin.north;
+ map_window.south = view3d.vwin.south;
+ map_window.west = view3d.vwin.west;
+ map_window.east = view3d.vwin.east;
+ has_region = 1;
break;
default:
has_region = 0;
