[GRASS-SVN] r61058 - sandbox/krejcmat/src
Sun Jun 29 04:27:28 PDT 2014
Author: martinl
Date: 2014-06-29 04:27:28 -0700 (Sun, 29 Jun 2014)
New Revision: 61058
   sandbox/krejcmat/src/mdgrass.py
   sandbox/krejcmat/src/r.info.iso.py
   sandbox/krejcmat/src/v.info.iso.py
r/v.info.iso: write output to current directory, fix output options
Modified: sandbox/krejcmat/src/mdgrass.py
--- sandbox/krejcmat/src/mdgrass.py	2014-06-29 11:11:53 UTC (rev 61057)
+++ sandbox/krejcmat/src/mdgrass.py	2014-06-29 11:27:28 UTC (rev 61058)
@@ -273,7 +273,7 @@
         # if path is None, use lunch. dir
         # TODO change default folder to mapset location
         if not path:
-            path = os.path.join(self.dirpath,xml_out_name)
+            path = os.path.join(os.getcwd(),xml_out_name)
         else:
             path = os.path.join(path, xml_out_name)
Modified: sandbox/krejcmat/src/r.info.iso.py
--- sandbox/krejcmat/src/r.info.iso.py	2014-06-29 11:11:53 UTC (rev 61057)
+++ sandbox/krejcmat/src/r.info.iso.py	2014-06-29 11:27:28 UTC (rev 61058)
@@ -29,12 +29,13 @@
 #%option G_OPT_F_OUTPUT
 #% label: Name for output metadata file
+#% description: Default: /path/to/current/directory/<map>.xml
 #% required: no
 #%end
 #%option G_OPT_M_DIR
 #% key: destination
-#% label: Path to destination directory
+#% description: Path to destination directory
 #% required: no
 #%end
@@ -48,10 +49,10 @@
     else:
         destination = options['destination']
-    if not options['mdout']:
+    if not options['output']:
         mdout = None
     else:
-        mdout=options['mdout']
+        mdout=options['output']
     md = GrassMD(options['map'], 'cell')
     if options['profil']=='inspire':
Modified: sandbox/krejcmat/src/v.info.iso.py
--- sandbox/krejcmat/src/v.info.iso.py	2014-06-29 11:11:53 UTC (rev 61057)
+++ sandbox/krejcmat/src/v.info.iso.py	2014-06-29 11:27:28 UTC (rev 61058)
@@ -29,12 +29,13 @@
 #% required: no
 #%end
 #% key: destination
 #% required: no
 #%end
@@ -48,21 +49,21 @@
     else:
         mdout = None
     else:
     # create instance of metadata in owslib
     md = GrassMD(options['map'], 'vector')
         md.createGrassInspireISO()
-        xml_file=md.saveXML(options['destination'],options['mdout'])
+        xml_file=md.saveXML(options['destination'],mdout)
         md.readXML(xml_file)
     else:
         md.createGrassBasicISO()
-        md.saveXML(options['destination'],options['mdout'])
+        md.saveXML(options['destination'],mdout)
     return 0
