[GRASS-SVN] r61067 - grass/trunk/vector/v.net.alloc
svn_grass at osgeo.org
Sun Jun 29 11:12:35 PDT 2014
Author: turek
Date: 2014-06-29 11:12:35 -0700 (Sun, 29 Jun 2014)
New Revision: 61067
grass/trunk/vector/v.net.alloc/main.c
grass/trunk/vector/v.net.alloc/v.net.alloc.html
v.net.alloc: added support for the turntable, guisections reorganized
Modified: grass/trunk/vector/v.net.alloc/main.c
--- grass/trunk/vector/v.net.alloc/main.c 2014-06-29 18:05:40 UTC (rev 61066)
+++ grass/trunk/vector/v.net.alloc/main.c 2014-06-29 18:12:35 UTC (rev 61067)
@@ -4,10 +4,11 @@
* MODULE: v.net.alloc
* AUTHOR(S): Radim Blazek
+ * Stepan Turek <stepan.turek seznam.cz> (turns support)
* PURPOSE: Allocate subnets for nearest centers.
- * COPYRIGHT: (C) 2001 by the GRASS Development Team
+ * COPYRIGHT: (C) 2001,2014 by the GRASS Development Team
* This program is free software under the
* GNU General Public License (>=v2).
@@ -37,14 +38,15 @@
int main(int argc, char **argv)
- int i, ret, center, line, center1, center2;
- int nlines, nnodes, type, ltype, afield, nfield, geo, cat;
+ int i, j, ret, center, line, center1, center2;
+ int nlines, nnodes, type, ltype, afield, nfield, geo, cat, tfield,
+ tucfield;
int node1, node2;
double cost, e1cost, e2cost, n1cost, n2cost, s1cost, s2cost, l, l1, l2;
struct Option *map, *output;
struct Option *afield_opt, *nfield_opt, *afcol, *abcol, *ncol, *type_opt,
- *term_opt;
- struct Flag *geo_f;
+ *term_opt, *tfield_opt, *tucfield_opt;
+ struct Flag *geo_f, *turntable_f;
struct GModule *module;
struct Map_info Map, Out;
struct cat_list *catlist;
@@ -70,19 +72,30 @@
map = G_define_standard_option(G_OPT_V_INPUT);
output = G_define_standard_option(G_OPT_V_OUTPUT);
- type_opt = G_define_standard_option(G_OPT_V_TYPE);
- type_opt->options = "line,boundary";
- type_opt->answer = "line,boundary";
- type_opt->description = _("Arc type");
+ term_opt = G_define_standard_option(G_OPT_V_CATS);
+ term_opt->key = "ccats";
+ term_opt->required = YES;
+ term_opt->description =
+ _("Categories of centers (points on nodes) to which net "
+ "will be allocated, "
+ "layer for this categories is given by nlayer option");
afield_opt = G_define_standard_option(G_OPT_V_FIELD);
afield_opt->key = "alayer";
afield_opt->answer = "1";
+ afield_opt->required = YES;
afield_opt->label = _("Arc layer");
+ type_opt = G_define_standard_option(G_OPT_V_TYPE);
+ type_opt->options = "line,boundary";
+ type_opt->answer = "line,boundary";
+ type_opt->required = YES;
+ type_opt->description = _("Arc type");
nfield_opt = G_define_standard_option(G_OPT_V_FIELD);
nfield_opt->key = "nlayer";
nfield_opt->answer = "2";
+ nfield_opt->required = YES;
nfield_opt->label = _("Node layer");
afcol = G_define_option();
@@ -91,32 +104,47 @@
afcol->required = NO;
afcol->description =
_("Arc forward/both direction(s) cost column (number)");
+ afcol->guisection = _("Costs");
abcol = G_define_option();
abcol->key = "abcolumn";
abcol->type = TYPE_STRING;
abcol->required = NO;
abcol->description = _("Arc backward direction cost column (number)");
+ abcol->guisection = _("Costs");
ncol = G_define_option();
ncol->key = "ncolumn";
ncol->type = TYPE_STRING;
ncol->required = NO;
ncol->description = _("Node cost column (number)");
+ ncol->guisection = _("Costs");
- term_opt = G_define_standard_option(G_OPT_V_CATS);
- term_opt->key = "ccats";
- term_opt->required = YES;
- term_opt->description =
- _("Categories of centers (points on nodes) to which net "
- "will be allocated, "
- "layer for this categories is given by nlayer option");
+ tfield_opt = G_define_standard_option(G_OPT_V_FIELD);
+ tfield_opt->key = "tlayer";
+ tfield_opt->answer = "3";
+ tfield_opt->label = _("Layer with turntable");
+ tfield_opt->description =
+ _("Relevant only with -t flag.");
+ tfield_opt->guisection = _("Turntable");
+ tucfield_opt = G_define_standard_option(G_OPT_V_FIELD);
+ tucfield_opt->key = "tuclayer";
+ tucfield_opt->answer = "4";
+ tucfield_opt->label = _("Layer with unique categories used in turntable");
+ tucfield_opt->description =
+ tucfield_opt->guisection = _("Turntable");
geo_f = G_define_flag();
geo_f->key = 'g';
geo_f->description =
_("Use geodesic calculation for longitude-latitude locations");
+ turntable_f = G_define_flag();
+ turntable_f->key = 't';
+ turntable_f->description = _("Use turntable");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -142,24 +170,34 @@
afield = Vect_get_field_number(&Map, afield_opt->answer);
nfield = Vect_get_field_number(&Map, nfield_opt->answer);
+ tfield = Vect_get_field_number(&Map, tfield_opt->answer);
+ tucfield = Vect_get_field_number(&Map, tucfield_opt->answer);
/* Build graph */
- Vect_net_build_graph(&Map, type, afield, nfield, afcol->answer,
- abcol->answer, ncol->answer, geo, 0);
+ if (turntable_f->answer)
+ Vect_net_ttb_build_graph(&Map, type, afield, nfield, tfield, tucfield,
+ afcol->answer, abcol->answer, ncol->answer,
+ geo, 0);
+ else
+ Vect_net_build_graph(&Map, type, afield, nfield, afcol->answer,
+ abcol->answer, ncol->answer, geo, 0);
nnodes = Vect_get_num_nodes(&Map);
nlines = Vect_get_num_lines(&Map);
/* Create list of centers based on list of categories */
for (i = 1; i <= nlines; i++) {
int node;
ltype = Vect_get_line_type(&Map, i);
if (!(ltype & GV_POINT))
continue;
Vect_read_line(&Map, Points, Cats, i);
- node = Vect_find_node(&Map, Points->x[0], Points->y[0], Points->z[0], 0, 0);
+ node =
+ Vect_find_node(&Map, Points->x[0], Points->y[0], Points->z[0], 0,
+ 0);
if (!node) {
G_warning(_("Point is not connected to the network"));
continue;
@@ -193,13 +231,23 @@
G_warning(_("Not enough centers for selected nlayer. "
"Nothing will be allocated."));
- /* alloc and reset space for all nodes */
- Nodes = (NODE *) G_calloc((nnodes + 1), sizeof(NODE));
- for (i = 1; i <= nnodes; i++) {
- Nodes[i].center = -1;
+ /* alloc and reset space for all lines */
+ if (turntable_f->answer) {
+ /* if turntable is used we are looking for lines as destinations, not the intersections (nodes) */
+ Nodes = (NODE *) G_calloc((nlines * 2 + 2), sizeof(NODE));
+ for (i = 2; i <= (nlines * 2 + 2); i++) {
+ Nodes[i].center = -1;/* NOTE: first two items of Nodes are not used */
+ else {
+ Nodes = (NODE *) G_calloc((nnodes + 1), sizeof(NODE));
+ for (i = 1; i <= nnodes; i++) {
/* Fill Nodes by nearest center and costs from that center */
G_message(_("Calculating costs from centers ..."));
@@ -209,32 +257,75 @@
Vect_net_get_node_cost(&Map, node1, &n1cost);
G_debug(2, "center = %d node = %d cat = %d", center, node1,
Centers[center].cat);
- for (node2 = 1; node2 <= nnodes; node2++) {
- G_debug(5, " node1 = %d node2 = %d", node1, node2);
- Vect_net_get_node_cost(&Map, node2, &n2cost);
- if (n2cost == -1) {
- continue;
- } /* closed, left it as not attached */
- ret = Vect_net_shortest_path(&Map, node1, node2, NULL, &cost);
- if (ret == -1) {
- continue;
- } /* node unreachable */
+ for (line = 1; line <= nlines; line++) {
+ G_debug(5, " node1 = %d line = %d", node1, line);
+ Vect_net_get_node_cost(&Map, line, &n2cost);
+ /* closed, left it as not attached */
- /* We must add center node costs (not calculated by Vect_net_shortest_path() ), but
- * only if center and node are not identical, because at the end node cost is add later */
- if (node1 != node2)
- cost += n1cost;
+ if (Vect_read_line(&Map, Points, Cats, line) < 0)
+ continue;
+ if (Vect_get_line_type(&Map, line) != GV_LINE)
+ continue;
+ if (!Vect_cat_get(Cats, tucfield, &cat))
+ continue;
- G_debug(5,
- "Arc nodes: %d %d cost: %f (x old cent: %d old cost %f",
- node1, node2, cost, Nodes[node2].center,
- Nodes[node2].cost);
- if (Nodes[node2].center == -1 || cost < Nodes[node2].cost) {
- Nodes[node2].cost = cost;
- Nodes[node2].center = center;
+ for (j = 0; j < 2; j++) {
+ if (j == 1)
+ cat *= -1;
+ ret =
+ Vect_net_ttb_shortest_path(&Map, node1, 0, cat, 1,
+ tucfield, NULL,
+ &cost);
+ if (ret == -1) {
+ continue;
+ } /* node unreachable */
+ /* We must add center node costs (not calculated by Vect_net_shortest_path() ), but
+ * only if center and node are not identical, because at the end node cost is add later */
+ if (ret != 1)
+ cost += n1cost;
+ G_debug(5,
+ "Arc nodes: %d %d cost: %f (x old cent: %d old cost %f",
+ node1, line, cost, Nodes[line * 2 + j].center,
+ Nodes[line * 2 + j].cost);
+ if (Nodes[line * 2 + j].center == -1 ||
+ cost < Nodes[line * 2 + j].cost) {
+ Nodes[line * 2 + j].cost = cost;
+ Nodes[line * 2 + j].center = center;
+ else
+ for (node2 = 1; node2 <= nnodes; node2++) {
+ G_debug(5, " node1 = %d node2 = %d", node1, node2);
+ Vect_net_get_node_cost(&Map, node2, &n2cost);
+ if (n2cost == -1) {
+ continue;
+ } /* closed, left it as not attached */
+ ret = Vect_net_shortest_path(&Map, node1, node2, NULL, &cost);
+ if (ret == -1) {
+ continue;
+ if (node1 != node2)
+ cost += n1cost;
+ G_debug(5,
+ node1, node2, cost, Nodes[node2].center,
+ Nodes[node2].cost);
+ if (Nodes[node2].center == -1 || cost < Nodes[node2].cost) {
+ Nodes[node2].cost = cost;
+ Nodes[node2].center = center;
G_percent(1, 1, 1);
@@ -250,21 +341,32 @@
if (!(ltype & type)) {
continue;
- Vect_get_line_nodes(&Map, line, &node1, &node2);
- center1 = Nodes[node1].center;
- center2 = Nodes[node2].center;
- s1cost = Nodes[node1].cost;
- s2cost = Nodes[node2].cost;
- G_debug(3, "Line %d:", line);
- G_debug(3, "Arc centers: %d %d (nodes: %d %d)", center1, center2,
- node1, node2);
- Vect_net_get_node_cost(&Map, node1, &n1cost);
+ center1 = Nodes[line * 2].center;
+ center2 = Nodes[line * 2 + 1].center;
+ s1cost = Nodes[line * 2].cost;
+ s2cost = Nodes[line * 2 + 1].cost;
+ n1cost = n2cost = 0;
+ else {
+ Vect_get_line_nodes(&Map, line, &node1, &node2);
+ center1 = Nodes[node1].center;
+ center2 = Nodes[node2].center;
+ s1cost = Nodes[node1].cost;
+ s2cost = Nodes[node2].cost;
+ Vect_net_get_node_cost(&Map, node1, &n1cost);
Vect_net_get_line_cost(&Map, line, GV_FORWARD, &e1cost);
Vect_net_get_line_cost(&Map, line, GV_BACKWARD, &e2cost);
+ G_debug(3, "Line %d:", line);
+ G_debug(3, "Arc centers: %d %d (nodes: %d %d)", center1, center2,
+ node1, node2);
G_debug(3, " s1cost = %f n1cost = %f e1cost = %f", s1cost, n1cost,
e1cost);
G_debug(3, " s2cost = %f n2cost = %f e2cost = %f", s2cost, n2cost,
@@ -343,7 +445,8 @@
/* First segment */
ret = Vect_line_segment(Points, 0, l1, SPoints);
if (ret == 0) {
- G_warning(_("Cannot get line segment, segment out of line"));
+ G_warning(_
+ ("Cannot get line segment, segment out of line"));
else {
cat = Centers[center1].cat;
@@ -354,7 +457,8 @@
/* Second segment */
ret = Vect_line_segment(Points, l1, l, SPoints);
if (ret == 0) {
+ G_warning(_
else {
Vect_reset_cats(Cats);
Modified: grass/trunk/vector/v.net.alloc/v.net.alloc.html
--- grass/trunk/vector/v.net.alloc/v.net.alloc.html 2014-06-29 18:05:40 UTC (rev 61066)
+++ grass/trunk/vector/v.net.alloc/v.net.alloc.html 2014-06-29 18:12:35 UTC (rev 61067)
@@ -18,6 +18,19 @@
<p>
The input vector needs to be prepared with <em>v.net operation=connect</em>
in order to connect points representing center nodes to the network.
+<p>
+Application of flag <b>-t</b> enables a turntable support.
+This flag requires additional parameters <b>tlayer</b> and <b>tuclayer</b>
+that are otherwise ignored.
+ The turntable allows
+to model e.g. trafic code, where some turns may be prohibited.
+This means that the input layer is expanded by
+turntable with costs of every possible turn on any possible node
+(intersection) in both directions.
+ Turntable can be created by
+ the <em><a href="v.net.html">v.net</a></em> module.
+For more information about turns in the vector network analyses see
+<a href="http://grasswiki.osgeo.org/wiki/Turns_in_the_vector_network_analysis">wiki page</a>.
<h2>NOTES</h2>
@@ -152,5 +165,13 @@
Radim Blazek, ITC-Irst, Trento, Italy<br>
Documentation: Markus Neteler, Markus Metz
+<h3>TURNS SUPPORT</h3>
+The turns support was implemnented as part of GRASS GIS turns cost project at Czech Technical University in Prague, Czech Republic.
+Eliska Kyzlikova, Stepan Turek, Lukas Bocan and Viera Bejdova participated at the project.
+Implementation: Stepan Turek
+Documentation: Lukas Bocan
+Mentor: Martin Landa
<p><i>Last changed: $Date$</i>
