[GRASS-SVN] r61069 - in grass/trunk/vector: v.net.alloc v.net.iso v.net.path v.net.salesman
svn_grass at osgeo.org
Sun Jun 29 11:41:50 PDT 2014
Author: turek
Date: 2014-06-29 11:41:50 -0700 (Sun, 29 Jun 2014)
New Revision: 61069
grass/trunk/vector/v.net.alloc/main.c
grass/trunk/vector/v.net.iso/main.c
grass/trunk/vector/v.net.path/main.c
grass/trunk/vector/v.net.salesman/main.c
v.net.path/alloc/iso/salesman: move -t flag into turntable guisection
Modified: grass/trunk/vector/v.net.alloc/main.c
--- grass/trunk/vector/v.net.alloc/main.c 2014-06-29 18:24:30 UTC (rev 61068)
+++ grass/trunk/vector/v.net.alloc/main.c 2014-06-29 18:41:50 UTC (rev 61069)
@@ -120,6 +120,11 @@
ncol->description = _("Node cost column (number)");
ncol->guisection = _("Costs");
+ turntable_f = G_define_flag();
+ turntable_f->key = 't';
+ turntable_f->description = _("Use turntable");
+ turntable_f->guisection = _("Turntable");
tfield_opt = G_define_standard_option(G_OPT_V_FIELD);
tfield_opt->key = "tlayer";
tfield_opt->answer = "3";
@@ -141,10 +146,6 @@
geo_f->description =
_("Use geodesic calculation for longitude-latitude locations");
- turntable_f = G_define_flag();
- turntable_f->key = 't';
- turntable_f->description = _("Use turntable");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
Modified: grass/trunk/vector/v.net.iso/main.c
--- grass/trunk/vector/v.net.iso/main.c 2014-06-29 18:24:30 UTC (rev 61068)
+++ grass/trunk/vector/v.net.iso/main.c 2014-06-29 18:41:50 UTC (rev 61069)
@@ -131,6 +131,11 @@
@@ -152,10 +157,6 @@
exit(EXIT_FAILURE);
Modified: grass/trunk/vector/v.net.path/main.c
--- grass/trunk/vector/v.net.path/main.c 2014-06-29 18:24:30 UTC (rev 61068)
+++ grass/trunk/vector/v.net.path/main.c 2014-06-29 18:41:50 UTC (rev 61069)
@@ -104,6 +104,11 @@
"and error message is printed. To speed up the process, keep this "
"value as low as possible.");
@@ -130,10 +135,6 @@
segments_f->description = _("Write output as original input segments, "
"not each path as one line.");
exit(EXIT_FAILURE);
Modified: grass/trunk/vector/v.net.salesman/main.c
--- grass/trunk/vector/v.net.salesman/main.c 2014-06-29 18:24:30 UTC (rev 61068)
+++ grass/trunk/vector/v.net.salesman/main.c 2014-06-29 18:41:50 UTC (rev 61069)
@@ -161,20 +161,6 @@
nfield_opt->required = YES;
nfield_opt->label = _("Node layer (used for cities)");
- tfield_opt = G_define_standard_option(G_OPT_V_FIELD);
- tfield_opt->key = "tlayer";
- tfield_opt->answer = "3";
- tfield_opt->label = _("Layer with turntable");
- tfield_opt->description = _("Relevant only with -t flag.");
- tfield_opt->guisection = _("Turntable");
- tucfield_opt = G_define_standard_option(G_OPT_V_FIELD);
- tucfield_opt->key = "tuclayer";
- tucfield_opt->answer = "4";
- tucfield_opt->label = _("Layer with unique categories used in turntable");
- tucfield_opt->description = _("Relevant only with -t flag.");
- tucfield_opt->guisection = _("Turntable");
afcol = G_define_option();
afcol->key = "afcolumn";
afcol->type = TYPE_STRING;
@@ -191,6 +177,25 @@
_("EXPERIMENTAL: Arc backward direction cost column (number)");
abcol->guisection = _("Costs");
+ tfield_opt = G_define_standard_option(G_OPT_V_FIELD);
+ tfield_opt->key = "tlayer";
+ tfield_opt->answer = "3";
+ tfield_opt->label = _("Layer with turntable");
+ tfield_opt->description = _("Relevant only with -t flag.");
+ tfield_opt->guisection = _("Turntable");
+ tucfield_opt = G_define_standard_option(G_OPT_V_FIELD);
+ tucfield_opt->key = "tuclayer";
+ tucfield_opt->answer = "4";
+ tucfield_opt->label = _("Layer with unique categories used in turntable");
+ tucfield_opt->description = _("Relevant only with -t flag.");
+ tucfield_opt->guisection = _("Turntable");
seq = G_define_standard_option(G_OPT_F_OUTPUT);
seq->key = "sequence";
seq->type = TYPE_STRING;
@@ -203,10 +208,6 @@
exit(EXIT_FAILURE);
