[GRASS-SVN] r61082 - grass-addons/grass7/raster/r.random.weight
svn_grass at osgeo.org
Mon Jun 30 15:03:01 PDT 2014
Author: pvanbosgeo
Date: 2014-06-30 15:03:01 -0700 (Mon, 30 Jun 2014)
New Revision: 61082
Added:
grass-addons/grass7/raster/r.random.weight/r.random.weight.py
Removed:
py extension
Deleted: grass-addons/grass7/raster/r.random.weight/r.random.weight
--- grass-addons/grass7/raster/r.random.weight/r.random.weight 2014-06-30 19:53:45 UTC (rev 61081)
+++ grass-addons/grass7/raster/r.random.weight/r.random.weight 2014-06-30 22:03:01 UTC (rev 61082)
@@ -1,114 +0,0 @@
-#!/usr/bin/env python
-# -*- coding: utf-8 -*-
-# MODULE: r.rand.weight
-# AUTHOR(S): paulo van Breugel <paulo at ecodiv.org>
-# PURPOSE: Create a layer with weighted random sample
-# COPYRIGHT: (C) 2014 Paulo van Breugel
-# http://ecodiv.org
-# http://pvanb.wordpress.com/
-# This program is free software under the GNU General Public
-# License (>=v2). Read the file COPYING that comes with GRASS
-# for details.
-#%module
-#% description: Weighted sample
-#% keywords: raster, sample
-#%end
-#%option
-#% key: weights
-#% type: string
-#% gisprompt: old,cell,raster
-#% description: layer with weight
-#% key_desc: weight
-#% required: yes
-#% multiple: no
-#%end
-#%option
-#% key: output
-#% type: string
-#% gisprompt: new,cell,raster
-#% description: output layer
-#% key_desc: output
-#% required: yes
-#% multiple: no
-#%end
-#%option
-#% key: start
-#% type: double
-#% description: minimum weight
-#% key_desc: start
-#% answer: 0
-#% required: yes
-#%end
-#%option
-#% key: end
-#% type: double
-#% description: maximum weight
-#% key_desc: end
-#% answer: 100
-#% required: yes
-#%end
-#%option
-#% key: subsample
-#% type: string
-#% description: subsample - not implemented yet
-#% key_desc: ss
-#% answer: 0
-#% required: no
-#%end
-# import libraries
-import os
-import sys
-import atexit
-import grass.script as grass
-def cleanup():
- grass.run_command('g.remove',
- rast = tmp_map, quiet = True)
-# main function
-def main():
- global tmp_map
- # check if GISBASE is set
- if "GISBASE" not in os.environ:
- # return an error advice
- grass.fatal(_("You must be in GRASS GIS to run this program"))
- # input raster map and parameters
- minval = options['start']
- maxval = options['end']
- weight = options['weights']
- outmap = options['output']
- subsample = options['subsample']
- # setup temporary files
- tmp_map = 'r_w_rand_987654321'
- grass.mapcalc("$tmp_map = rand(${minval},${maxval})",
- minval = minval,
- maxval = maxval,
- tmp_map = tmp_map)
- grass.mapcalc("${outmap} = if($tmp_map < ${weight},1,0)",
- weight = weight,
- outmap = outmap,
-if __name__ == "__main__":
- options, flags = grass.parser()
- atexit.register(cleanup)
- sys.exit(main())
Copied: grass-addons/grass7/raster/r.random.weight/r.random.weight.py (from rev 61081, grass-addons/grass7/raster/r.random.weight/r.random.weight)
--- grass-addons/grass7/raster/r.random.weight/r.random.weight.py (rev 0)
+++ grass-addons/grass7/raster/r.random.weight/r.random.weight.py 2014-06-30 22:03:01 UTC (rev 61082)
@@ -0,0 +1,114 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE: r.rand.weight
+# AUTHOR(S): paulo van Breugel <paulo at ecodiv.org>
+# PURPOSE: Create a layer with weighted random sample
+# COPYRIGHT: (C) 2014 Paulo van Breugel
+# http://ecodiv.org
+# http://pvanb.wordpress.com/
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Weighted sample
+#% keywords: raster, sample
+#%end
+#%option
+#% key: weights
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: layer with weight
+#% key_desc: weight
+#% required: yes
+#% multiple: no
+#%end
+#%option
+#% key: output
+#% type: string
+#% gisprompt: new,cell,raster
+#% description: output layer
+#% key_desc: output
+#% required: yes
+#% multiple: no
+#%end
+#%option
+#% key: start
+#% type: double
+#% description: minimum weight
+#% key_desc: start
+#% answer: 0
+#% required: yes
+#%end
+#%option
+#% key: end
+#% type: double
+#% description: maximum weight
+#% key_desc: end
+#% answer: 100
+#% required: yes
+#%end
+#%option
+#% key: subsample
+#% type: string
+#% description: subsample - not implemented yet
+#% key_desc: ss
+#% answer: 0
+#% required: no
+#%end
+# import libraries
+import os
+import sys
+import atexit
+import grass.script as grass
+def cleanup():
+ grass.run_command('g.remove',
+ rast = tmp_map, quiet = True)
+# main function
+def main():
+ global tmp_map
+ # check if GISBASE is set
+ if "GISBASE" not in os.environ:
+ # return an error advice
+ grass.fatal(_("You must be in GRASS GIS to run this program"))
+ # input raster map and parameters
+ minval = options['start']
+ maxval = options['end']
+ weight = options['weights']
+ outmap = options['output']
+ subsample = options['subsample']
+ # setup temporary files
+ tmp_map = 'r_w_rand_987654321'
+ grass.mapcalc("$tmp_map = rand(${minval},${maxval})",
+ minval = minval,
+ maxval = maxval,
+ tmp_map = tmp_map)
+ grass.mapcalc("${outmap} = if($tmp_map < ${weight},1,0)",
+ weight = weight,
+ outmap = outmap,
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ atexit.register(cleanup)
+ sys.exit(main())
