[GRASS-SVN] r59159 - grass/trunk/locale/po
Sat Mar 1 10:02:39 PST 2014
Author: marisn
Date: 2014-03-01 10:02:38 -0800 (Sat, 01 Mar 2014)
New Revision: 59159
   grass/trunk/locale/po/grasslibs_lv.po
   grass/trunk/locale/po/grasswxpy_lv.po
Latvial translation update for wxGUI and library; Contains correct plural form use
Modified: grass/trunk/locale/po/grasslibs_lv.po
--- grass/trunk/locale/po/grasslibs_lv.po	2014-03-01 18:00:14 UTC (rev 59158)
+++ grass/trunk/locale/po/grasslibs_lv.po	2014-03-01 18:02:38 UTC (rev 59159)
@@ -1,14 +1,14 @@
 # translation of grasslibs_lv.po to Latvian
 # Peteris Bruns <peteris.bruns at gmail.com>, 2005.
-# Maris Nartiss <maris.kde at gmail.com>, 2006, 2012.
+# Maris Nartiss <maris.kde at gmail.com>, 2006, 2012, 2014.
 # This file is distributed under the same license as the GRASS package.
 # Copyright (C) 2005, GRASS Development Team
 msgid ""
 msgstr ""
 "Project-Id-Version: grasslibs_lv\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2013-10-30 22:30+0100\n"
-"PO-Revision-Date: 2012-08-01 14:37+0300\n"
+"POT-Creation-Date: 2014-03-01 19:19+0200\n"
+"PO-Revision-Date: 2014-03-01 19:39+0200\n"
 "Last-Translator: Maris Nartiss <maris.kde at gmail.com>\n"
 "Language-Team: Latvian\n"
 "Language: lv\n"
@@ -19,2183 +19,2225 @@
 "X-Poedit-Language: Latvian\n"
 "X-Poedit-Country: LATVIA\n"
 "X-Poedit-SourceCharset: utf-8\n"
-"Plural-Forms:  nplurals=3; plural=(n%10==1 && n%100!=11 ? 0 : n != 0 ? 1 : "
-"2);\n"
+"Plural-Forms:  nplurals=3; plural=(n%10==1 && n%100!=11 ? 0 : n != 0 ? 1 : 2);\n"
-#: ../lib/nviz/render.c:106
-msgid "Bad server connection"
+#: ../lib/cairodriver/Graph.c:67
+msgid "Unable to open display"
+msgstr "Nav iespējams atvērt ekrānu"
+#: ../lib/cairodriver/Graph.c:82
+msgid "Unable to obtain visual"
 msgstr ""
-#: ../lib/nviz/render.c:112
-#, fuzzy
-msgid "Unable to get visual info"
-msgstr "Neiespējami atvērt failu %s iekš %s"
+#: ../lib/cairodriver/Graph.c:156
+#, c-format
+msgid "Unknown file extension: %s"
+msgstr ""
-#: ../lib/nviz/render.c:119
-#, fuzzy
-msgid "Unable to create rendering context"
-msgstr "neiespējami izveidot jaunu procesu"
-#: ../lib/nviz/position.c:56
-#, fuzzy
-msgid "Unable to set focus"
-msgstr "Neisespējami atvērt %s"
-#: ../lib/nviz/map_obj.c:59
-msgid "Maximum surfaces loaded!"
+#: ../lib/cairodriver/Graph.c:184
+#, c-format
+msgid "cairo: collecting to file '%s'"
 msgstr ""
-#: ../lib/nviz/map_obj.c:88
-msgid "Maximum vector line maps loaded!"
+#: ../lib/cairodriver/Graph.c:186
+#, c-format
+msgid "cairo: image size %dx%d"
 msgstr ""
-#: ../lib/nviz/map_obj.c:97 ../lib/nviz/map_obj.c:128
-#, fuzzy, c-format
-msgid "Error loading vector map <%s>"
-msgstr "neispējami mainīt direktoriju uz %s"
-#: ../lib/nviz/map_obj.c:116
-msgid "Maximum vector point maps loaded!"
+#: ../lib/cairodriver/Graph.c:353
+msgid "Unknown Cairo surface type"
 msgstr ""
-#: ../lib/nviz/map_obj.c:143
-msgid "Maximum volumes loaded!"
+#: ../lib/cairodriver/Graph.c:358
+msgid "Failed to initialize Cairo surface"
 msgstr ""
-#: ../lib/nviz/map_obj.c:152
-#, fuzzy, c-format
-msgid "Error loading 3d raster map <%s>"
-msgstr "eksistējošām rastra kartēm %d"
-#: ../lib/nviz/map_obj.c:160
-msgid "Nviz_new_map_obj(): unsupported data type"
+#: ../lib/cairodriver/read_ppm.c:28 ../lib/cairodriver/read_bmp.c:88
+#, c-format
+msgid "Cairo: unable to open input file <%s>"
 msgstr ""
-#: ../lib/nviz/nviz.c:128
+#: ../lib/cairodriver/read_ppm.c:32 ../lib/cairodriver/read_bmp.c:92
 #, c-format
-msgid "Invalid color (%s), using \"white\" as default"
+msgid "Cairo: invalid input file <%s>"
 msgstr ""
-#: ../lib/nviz/lights.c:171
-#, fuzzy
-msgid "Unable to define new light"
-#: ../lib/symbol/read.c:211
+#: ../lib/cairodriver/read_ppm.c:38
 #, c-format
-msgid "Cannot read symbol line coordinates: %s"
+msgid "Cairo: input file has incorrect dimensions: expected: %dx%d got: %dx%d"
 msgstr ""
-#: ../lib/symbol/read.c:260
+#: ../lib/cairodriver/read_ppm.c:46
 #, c-format
-msgid ""
-"Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
+msgid "Cairo: unable to open input mask file <%s>"
 msgstr ""
-#: ../lib/symbol/read.c:284
+#: ../lib/cairodriver/read_ppm.c:50
 #, c-format
-msgid "Cannot find/open symbol: '%s'"
-msgstr "Nevar atrast/atvērt simbolu: '%s'"
+msgid "Cairo: invalid input mask file <%s>"
+msgstr ""
-#: ../lib/symbol/read.c:389 ../lib/symbol/read.c:407 ../lib/symbol/read.c:417
-#: ../lib/symbol/read.c:435
+#: ../lib/cairodriver/read_ppm.c:56
 #, c-format
-msgid "Incorrect symbol color: '%s', using default."
+msgid "Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
 msgstr ""
-#: ../lib/htmldriver/Graph_Set.c:97
-#, fuzzy, c-format
-msgid "html: collecting to file '%s'"
-msgstr "Nevar palaist failu '%s'"
-#: ../lib/htmldriver/Graph_Set.c:98
+#: ../lib/cairodriver/read_xid.c:14
 #, c-format
-msgid "html: image size %dx%d"
+msgid "Unable to open input file <%s>"
 msgstr ""
-#: ../lib/htmldriver/Graph_Set.c:111 ../lib/htmldriver/Graph_Set.c:115
-#: ../lib/htmldriver/Graph_Set.c:119
+#: ../lib/cairodriver/read_xid.c:17
 #, c-format
-msgid "html: type '%s'"
+msgid "Unable to read input file <%s>"
 msgstr ""
-#: ../lib/sites/sites.c:106
+#: ../lib/cairodriver/read_xid.c:20
 #, c-format
-msgid "Attributes for category %d not found"
+msgid "Unable to parse input file <%s>"
 msgstr ""
-#: ../lib/sites/sites.c:151
-msgid "Category must be integer"
+#: ../lib/cairodriver/Raster.c:72
+msgid "Failed to create surface"
 msgstr ""
-#: ../lib/sites/sites.c:226
-msgid "Memory error in writing timestamp"
+#: ../lib/cairodriver/write_xid.c:14
+#, c-format
+msgid "Unable to open output file <%s>"
 msgstr ""
-#: ../lib/sites/sites.c:228
-msgid "Illegal TimeStamp string"
+#: ../lib/cairodriver/write_xid.c:19
+#, c-format
+msgid "Unable to write output file <%s>"
 msgstr ""
-#: ../lib/sites/sites.c:255 ../lib/sites/sites.c:385
-msgid ""
-"Dev note: Adapted sites library used for vector points. (module should be "
-"updated to GRASS 6 vector library)"
+#: ../lib/cairodriver/write_bmp.c:72 ../lib/cairodriver/write_ppm.c:27
+#, c-format
+msgid "Cairo: unable to open output file <%s>"
 msgstr ""
-#: ../lib/sites/sites.c:279 ../lib/ogsf/Gv3.c:343 ../lib/ogsf/Gp3.c:206
-#: ../lib/vector/neta/utils.c:119 ../lib/vector/neta/timetables.c:133
-#: ../lib/vector/Vlib/map.c:206 ../lib/vector/Vlib/map.c:346
-#: ../lib/vector/Vlib/net.c:181 ../lib/vector/Vlib/net.c:358
-#: ../lib/vector/Vlib/cats.c:597 ../lib/vector/Vlib/array.c:282
-#: ../lib/vector/Vlib/write_pg.c:578 ../lib/vector/Vlib/write_ogr.c:197
-#: ../lib/vector/Vlib/copy.c:614 ../lib/vector/Vlib/ascii.c:410
-#: ../lib/rst/interp_float/vinput2d.c:88 ../lib/db/dbmi_client/db.c:46
-#: ../lib/db/dbmi_client/copy_tab.c:112 ../lib/db/dbmi_client/copy_tab.c:133
-#, fuzzy, c-format
-msgid "Unable to open database <%s> by driver <%s>"
-msgstr "Nevar atvērt datubāzi %s"
+#: ../lib/cairodriver/Draw_bitmap.c:47
+msgid "Cairo_Bitmap: Failed to create source"
+msgstr ""
-#: ../lib/sites/sites.c:288 ../lib/vector/Vlib/write_ogr.c:210
-#: ../lib/db/dbmi_client/copy_tab.c:218 ../lib/db/dbmi_client/copy_tab.c:295
-#: ../lib/db/dbmi_client/table.c:110
-#, fuzzy, c-format
-msgid "Unable to open select cursor: '%s'"
+#: ../lib/cairodriver/write_ppm.c:34
+#, c-format
+msgid "Cairo: unable to open mask file <%s>"
+msgstr ""
-#: ../lib/sites/sites.c:304
-#, fuzzy
-msgid "Cannot fetch row"
-msgstr "Nevar iegūt slāņa informāciju"
+#: ../lib/cairodriver/read_bmp.c:96
+#, c-format
+msgid "Cairo: Invalid BMP header for <%s>"
+msgstr ""
-#: ../lib/sites/sites.c:440
-msgid "G_oldsite_new_struct: invalid # dims or fields"
+#: ../lib/cairodriver/Text.c:46
+#, c-format
+msgid "Unable to convert from <%s> to UTF-8"
 msgstr ""
-#: ../lib/sites/sites.c:668
-msgid ""
-"G_oldsite_describe() must be called immediately after G_fopen_sites_old()."
+#: ../lib/cairodriver/Text.c:56
+msgid "Some characters could not be converted to UTF-8"
 msgstr ""
-#: ../lib/ogsf/gsd_label.c:58
-msgid "Max. number of labels reached!"
+#: ../lib/psdriver/Graph_set.c:199
+#, c-format
+msgid "ps: truecolor status %s"
 msgstr ""
-#: ../lib/ogsf/gk.c:320
-msgid "Need at least 3 keyframes for spline"
+#: ../lib/psdriver/Graph_set.c:200 ../lib/pngdriver/Graph_set.c:85
+msgid "enabled"
 msgstr ""
-#: ../lib/ogsf/gk.c:622
-msgid "Need at least 2 keyframes for interpolation"
+msgid "disabled"
 msgstr ""
-#: ../lib/ogsf/GS2.c:1211
+#: ../lib/psdriver/Graph_set.c:214
 #, c-format
-msgid "no category info"
+msgid "ps: collecting to file '%s'"
 msgstr ""
-#: ../lib/ogsf/GS2.c:1230
+#: ../lib/psdriver/Graph_set.c:215
 #, c-format
-msgid "no data"
+msgid "ps: image size %dx%d"
 msgstr ""
-#: ../lib/ogsf/GS2.c:1655
-#, fuzzy, c-format
-msgid "Raster map <%s> is outside of current region. Load failed."
-msgstr "Defekts: atteikts papildināt karti,kura nav tekošajā karšu komplektā."
+#: ../lib/python/pygrass/raster/abstract.py:240
+#, fuzzy, python-brace-format
+msgid "Mode type: {0} not supported ('r', 'w')"
+msgstr "Ieejas vektors '%s' nav atrasts"
-#: ../lib/ogsf/GS2.c:1733 ../lib/ogsf/GS2.c:1739 ../lib/ogsf/GS2.c:1747
-#: ../lib/ogsf/GS2.c:1756 ../lib/ogsf/GS2.c:1764 ../lib/ogsf/GS2.c:1774
-#: ../lib/ogsf/GS2.c:1822
-msgid "GS_load_att_map(): Out of memory. Unable to load map"
+#: ../lib/python/pygrass/raster/abstract.py:251
+msgid "Overwrite type: {0} not supported (True/False)"
+#: ../lib/python/pygrass/raster/abstract.py:264
+#: ../lib/python/pygrass/vector/abstract.py:108
+#, python-brace-format
+msgid "Map name {0} not valid"
 msgstr ""
-#: ../lib/ogsf/GS2.c:1850
+#: ../lib/python/pygrass/raster/category.py:83
+msgid "Raser type: {0} not supported"
+#: ../lib/python/pygrass/raster/category.py:168
 #, fuzzy
-msgid "Loading failed"
-msgstr "Pieslēgšanās izgāzusies\n"
+msgid "Error executing: Rast_get_ith_cat"
+msgstr "eksistējošām rastra kartēm %d"
-#: ../lib/ogsf/GS2.c:1854
-msgid "Error finding range"
+#: ../lib/python/pygrass/raster/category.py:196
+#, fuzzy
+msgid "Null value detected"
+msgstr "Ieejas vektorkartes nosaukums"
+#: ../lib/python/pygrass/raster/category.py:198
+#, fuzzy
+msgid "Error executing: Rast_set_cat"
+#: ../lib/python/pygrass/raster/__init__.py:191
+#, fuzzy
+msgid "Raster type not defined"
+msgstr "Nevar ierakstīt līniju,karte nav atvērta"
+#: ../lib/python/pygrass/raster/__init__.py:194
+msgid "Raster map <{0}> already exists"
+msgstr "Laukuma nummurs<%d> vai vārds <%s> jau eksistē"
+#: ../lib/python/pygrass/raster/__init__.py:200
+msgid "The map does not exist, I can't open in 'r' mode"
 msgstr ""
-#: ../lib/ogsf/Gvl3.c:40 ../lib/ogsf/gvl_file.c:427
-#: ../lib/manage/do_remove.c:78 ../lib/manage/do_rename.c:76
-#: ../lib/gpde/N_arrays_io.c:273
-#, fuzzy, c-format
-msgid "3D raster map <%s> not found"
+#: ../lib/python/pygrass/raster/__init__.py:270
+msgid "Mode type: {0} not supported ('r', 'w','rw')"
-#: ../lib/ogsf/gs_bm.c:124
-msgid "Bitmap mismatch"
-msgstr ""
+#: ../lib/python/pygrass/raster/__init__.py:289
+#, fuzzy, python-format
+msgid "Index out of range: %r."
+msgstr "Dubulto atribūtu indekss ārpus diapazona"
-#: ../lib/ogsf/Gv3.c:60 ../lib/ogsf/Gv3.c:326 ../lib/ogsf/Gp3.c:56
-#: ../lib/ogsf/Gp3.c:189 ../lib/python/temporal/space_time_datasets.py:1030
-#: ../lib/manage/do_remove.c:57 ../lib/manage/do_rename.c:54
-#: ../lib/vector/Vlib/legal_vname.c:121 ../lib/vector/Vlib/legal_vname.c:124
-#: ../lib/vector/Vlib/map.c:269 ../lib/vector/Vlib/open.c:235
-#, fuzzy, c-format, python-format
-msgid "Vector map <%s> not found"
+#: ../lib/python/pygrass/raster/__init__.py:405
+msgid "Raster map <{0}> already exists. Use overwrite."
+msgstr "Vektors '%s' jau eksistē un tiks pārrakstīts."
+#: ../lib/python/pygrass/raster/__init__.py:436
+msgid "Raster map <{0}> does not exists"
+msgstr "Nevar atvērt vēsturi vektoram '%s'"
+#: ../lib/python/pygrass/raster/__init__.py:550
+msgid "Mode type: {0} not supported."
-#: ../lib/ogsf/Gv3.c:66 ../lib/ogsf/Gv3.c:331 ../lib/ogsf/Gp3.c:62
-#: ../lib/ogsf/Gp3.c:194 ../lib/python/temporal/space_time_datasets.py:1048
-#: ../lib/vector/Vlib/open.c:290 ../lib/vector/Vlib/open.c:422
-msgid "Unable to open vector map <%s>"
+#: ../lib/python/pygrass/raster/__init__.py:584
+msgid "Invalid type {0}"
-#: ../lib/ogsf/Gv3.c:262
-#, c-format
-msgid "No features from vector map <%s> fall within current region"
+#: ../lib/python/pygrass/raster/__init__.py:586
+msgid "Invalid size {0}"
+msgstr "neispējami mainīt direktoriju uz %s"
+#: ../lib/python/pygrass/functions.py:240
+msgid "Vector doesn't contain points"
 msgstr ""
-#: ../lib/ogsf/Gv3.c:267
-#, fuzzy, c-format
-msgid "Vector map <%s> loaded (%d features)"
-msgstr "Ieejas vektors '%s' nav atrasts"
+#: ../lib/python/pygrass/vector/table.py:927
+#, python-format
+msgid "Deleting table <%s> which is attached to following map(s):"
+msgstr ""
-#: ../lib/ogsf/Gv3.c:337 ../lib/ogsf/Gp3.c:200 ../lib/vector/Vlib/map.c:177
-#: ../lib/vector/Vlib/map.c:305 ../lib/vector/Vlib/map.c:441
-#: ../lib/vector/Vlib/net.c:175 ../lib/vector/Vlib/net.c:353
-#: ../lib/vector/Vlib/cats.c:589 ../lib/vector/Vlib/array.c:276
-#: ../lib/vector/Vlib/copy.c:581 ../lib/vector/Vlib/copy.c:719
-#: ../lib/vector/Vlib/ascii.c:398 ../lib/rst/interp_float/vinput2d.c:79
-#, c-format
-msgid "Database connection not defined for layer %d"
+#: ../lib/python/pygrass/vector/table.py:931
+msgid "You must use the force flag to actually remove it. Exiting."
 msgstr ""
-#: ../lib/ogsf/Gv3.c:346
-#, fuzzy, c-format
-msgid "Loading thematic vector layer <%s>..."
-msgstr " Rastra karte %s@%s ir tukša"
+#: ../lib/python/pygrass/errors.py:46
+msgid "The map is close!"
+msgstr ""
-#: ../lib/ogsf/Gv3.c:370 ../lib/ogsf/Gp3.c:233
-#, fuzzy, c-format
-msgid "No color rule defined for category %d"
+#: ../lib/python/temporal/datetime_math.py:254
+#: ../lib/python/temporal/datetime_math.py:271
+msgid "Wrong increment format: %s"
+msgstr "  formāts: %s\n"
-#: ../lib/ogsf/Gv3.c:385 ../lib/ogsf/Gp3.c:247
-#, fuzzy, c-format
-msgid "Invalid color definition (%s)"
-msgstr "Nederīgas koordinātes"
+#: ../lib/python/temporal/datetime_math.py:447
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1547
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1580
+msgid "Wrong granularity format: %s"
-#: ../lib/ogsf/Gv3.c:407
-#, c-format
-msgid ""
-"%d features without category. Unable to determine color rules for features "
-"without category."
+#: ../lib/python/temporal/datetime_math.py:725
+msgid "Time string seems to specify relative time"
 msgstr ""
-#: ../lib/ogsf/Gp3.c:92 ../lib/vector/Vlib/copy.c:168
-#: ../lib/vector/Vlib/copy.c:245
-#, fuzzy, c-format
-msgid "Unable to read vector map <%s>"
+#: ../lib/python/temporal/datetime_math.py:737
+#, fuzzy
+msgid "Dates Before Christ are not supported"
+msgstr "Vect_write_line() šim formātam/līmenim nav atbalstīta"
-#: ../lib/ogsf/Gp3.c:146
-#, c-format
-msgid "No points from vector map <%s> fall within current region"
+#: ../lib/python/temporal/datetime_math.py:741
+#, fuzzy
+msgid "Time zones are not supported"
+msgstr "Parametrs <%s> nav atbalstīts"
+#: ../lib/python/temporal/datetime_math.py:751
+msgid "Unable to parse time string: %s"
+msgstr "Neiespējami atvērt failu %s iekš %s"
+#: ../lib/python/temporal/core.py:514
+msgid ""
+"Unable to initialize the temporal DBMI interface. Use t.connect to specify "
+"the driver and the database string"
 msgstr ""
-#: ../lib/ogsf/Gp3.c:151
-#, fuzzy, c-format
-msgid "Vector map <%s> loaded (%d points)"
+#: ../lib/python/temporal/core.py:582
+msgid ""
+"Unable to receiving temporal database metadata.\n"
+"Current temporal database info:%(info)s"
+msgstr "neispējami atvērt datumu tabulas failu: %s"
-#: ../lib/ogsf/Gp3.c:209
-#, fuzzy, c-format
-msgid "Loading thematic points layer <%s>..."
+#: ../lib/python/temporal/core.py:586
+#, python-format
+msgid ""
+"Unsupported temporal database. Version mismatch.\n"
+" %(backup)sSupported temporal API version is: %(api)i.\n"
+"Please update your GRASS installation to the latest svn version.\n"
+msgstr ""
-#: ../lib/ogsf/Gp3.c:286
-#, c-format
+#: ../lib/python/temporal/core.py:592
+#, python-format
 msgid ""
-"%d points without category. Unable to determine color rules for features "
+" %(backup)sSupported temporal database version is: %(tdb)i\n"
 msgstr ""
-#: ../lib/ogsf/gsd_prim.c:146
-#, c-format
-msgid "Color Material: %d"
+#: ../lib/python/temporal/core.py:676
+msgid "Create temporal database: %s"
+msgstr "Nevar atvērt datubāzi %s"
+#: ../lib/python/temporal/core.py:962
+msgid ""
+"Unable to execute transaction:\n"
+" %(sql)s"
+msgstr "neiespējami izpildīt komandu"
+#: ../lib/python/temporal/temporal_vector_algebra.py:641
+#, python-format
+msgid ""
+"Error vector maps with basename %s exist. Use --o flag to overwrite existing "
+"file"
 msgstr ""
-#: ../lib/ogsf/gsd_prim.c:630
-#, c-format
+#: ../lib/python/temporal/temporal_vector_algebra.py:673
 msgid ""
-"gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please "
-"advise GRASS developers of this error"
+"Error starting %s : \n"
+"%s"
+msgstr "Kļūdu raskrīšana ārpus topo faila.\n"
+#: ../lib/python/temporal/temporal_vector_algebra.py:721
+msgid ""
+"Error vector map %s exist in temporal database. Use overwrite flag.  : \n"
+"%s"
+#: ../lib/python/temporal/extract.py:54
+msgid "You need to specify the base name of new created maps"
 msgstr ""
-#: ../lib/ogsf/gsd_img_tif.c:64 ../lib/ogsf/GK2.c:216
-#: ../lib/ogsf/gsd_img_ppm.c:52 ../lib/ogsf/gsd_img_ppm.c:95
-#, fuzzy, c-format
-msgid "Unable to open file <%s> for writing"
-msgstr "Neiespējami atvērt %s priekš rakstīšanas"
+#: ../lib/python/temporal/extract.py:112
+#: ../lib/python/temporal/open_stds.py:205
+#: ../lib/python/temporal/mapcalc.py:235
+msgid "Map <%s> is already in temporal database, use overwrite flag to overwrite"
-#: ../lib/ogsf/trans.c:180
-msgid "Out of matrix stack space"
+#: ../lib/python/temporal/extract.py:119
+#, python-format
+msgid "Apply r.mapcalc expression: \"%s\""
 msgstr ""
-#: ../lib/ogsf/trans.c:200
-msgid "Tried to pop an empty stack"
+#: ../lib/python/temporal/extract.py:124
+#, python-format
+msgid "Apply r3.mapcalc expression: \"%s\""
 msgstr ""
-#: ../lib/ogsf/gsd_surf.c:1742
-msgid "Cut-plane points mis-match between surfaces. Check resolution(s)."
+#: ../lib/python/temporal/extract.py:129
+#, python-format
+msgid "Apply v.extract where statement: \"%s\""
 msgstr ""
-#: ../lib/ogsf/gsdrape.c:207
-#, fuzzy
-msgid "Unable to process vector map - out of memory"
+#: ../lib/python/temporal/extract.py:158
+msgid "Error while computation"
+msgstr ""
-#: ../lib/ogsf/gsd_img_mpeg.c:72
-#, fuzzy
-msgid "Unable to allocate stream"
-msgstr "Neiespējami piešķirt atmiņu\n"
+#: ../lib/python/temporal/factory.py:51
+msgid "Unknown dataset type: %s"
+msgstr "nezināns interpolācijas tips"
-#: ../lib/ogsf/gsd_img_mpeg.c:175
-#, fuzzy
-msgid "Video codec not found"
+#: ../lib/python/temporal/temporal_algebra.py:826
+msgid "Space time %s dataset <%s> not found"
-#: ../lib/ogsf/gsd_img_mpeg.c:185
-#, fuzzy
-msgid "Unable to open codec"
+#: ../lib/python/temporal/temporal_algebra.py:844
+#: ../lib/python/temporal/temporal_algebra.py:848
+msgid ""
+"Wrong temporal type of space time dataset <"
+"%s>                                       <%s> time is required"
-#: ../lib/ogsf/gsd_img_mpeg.c:204
-#, fuzzy
-msgid "Unable to allocate picture"
+#: ../lib/python/temporal/abstract_dataset.py:391
+msgid ""
+"Unable to insert dataset <%(ds)s> of type %(type)s in the temporal database. "
+"The mapset of the dataset does not match the current mapset"
-#: ../lib/ogsf/gsd_img_mpeg.c:215
+#: ../lib/python/temporal/abstract_dataset.py:428
+#: ../lib/python/temporal/abstract_dataset.py:469
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2226
+#: ../lib/python/temporal/abstract_map_dataset.py:408
+#: ../lib/python/temporal/abstract_map_dataset.py:499
+msgid ""
+"Unable to update dataset <%(ds)s> of type %(type)s in the temporal database. "
+#: ../lib/python/temporal/temporal_raster_algebra.py:85
 #, fuzzy
-msgid "Unable to allocate temporary picture"
+msgid "Removing empty raster maps"
+msgstr "Ievades rastra faila nosaukums"
-#: ../lib/ogsf/gsd_img_mpeg.c:282
+#: ../lib/python/temporal/temporal_raster3d_algebra.py:44
 #, fuzzy
-msgid "Error while writing video frame"
-msgstr "Kļūdu raskrīšana ārpus topo faila.\n"
+msgid "Removing empty 3D raster maps"
-#: ../lib/ogsf/gsd_img_mpeg.c:328
-#, c-format
-msgid "Opening MPEG stream <%s>..."
-msgstr ""
+#: ../lib/python/temporal/stds_export.py:96
+msgid "Unable to export raster map <%s>"
-#: ../lib/ogsf/gsd_img_mpeg.c:340
-msgid "Unable to deduce output format from file extension: using MPEG"
-msgstr ""
+#: ../lib/python/temporal/stds_export.py:106
+msgid "Unable to export color rules for raster map <%s> r.out.gdal"
-#: ../lib/ogsf/gsd_img_mpeg.c:348
-#, fuzzy
-msgid "Unable to find suitable output format"
+#: ../lib/python/temporal/stds_export.py:128
+msgid "Unable to export raster map <%s> with r.pack"
-#: ../lib/ogsf/gsd_img_mpeg.c:355 ../lib/segment/open.c:97
-#: ../lib/rowio/setup.c:61 ../lib/rowio/setup.c:67
-#: ../lib/vector/neta/centrality.c:63 ../lib/vector/neta/centrality.c:145
-#: ../lib/vector/neta/path.c:136 ../lib/vector/neta/components.c:46
-#: ../lib/vector/neta/components.c:113 ../lib/vector/neta/bridge.c:58
-#: ../lib/vector/neta/flow.c:64 ../lib/vector/neta/flow.c:179
-#: ../lib/vector/neta/timetables.c:69 ../lib/vector/neta/timetables.c:168
-#: ../lib/vector/neta/timetables.c:178 ../lib/vector/neta/timetables.c:191
-#: ../lib/vector/neta/timetables.c:278 ../lib/vector/neta/timetables.c:413
-#: ../lib/vector/neta/timetables.c:425 ../lib/vector/neta/spanningtree.c:99
-#: ../lib/vector/neta/articulation_point.c:60 ../lib/vector/Vlib/line.c:50
-#: ../lib/vector/Vlib/line.c:154 ../lib/rst/interp_float/segmen2d.c:182
-#: ../lib/rst/interp_float/segmen2d.c:188
-#: ../lib/rst/interp_float/segmen2d.c:194
-#: ../lib/rst/interp_float/segmen2d.c:204
-#: ../lib/rst/interp_float/interp2d.c:121
-#: ../lib/rst/interp_float/interp2d.c:127
-#, fuzzy
-msgid "Out of memory"
+#: ../lib/python/temporal/stds_export.py:154
+msgid "Unable to export vector map <%s> as GML with v.out.ogr"
+msgstr "neiespējami atvērt rastra karti [%s iekš %s]"
-#: ../lib/ogsf/gsd_img_mpeg.c:379
-#, fuzzy
-msgid "Invalid output format parameters"
+#: ../lib/python/temporal/stds_export.py:185
+msgid "Unable to export vector map <%s> with v.pack"
-#: ../lib/ogsf/gsd_img_mpeg.c:401
-#, fuzzy, c-format
-msgid "Unable to open <%s>"
+#: ../lib/python/temporal/stds_export.py:210
+msgid "Unable to export raster map <%s> with r3.pack"
-#: ../lib/ogsf/gsd_img_mpeg.c:414
-msgid "OGSF library has not been built with MPEG output support"
-msgstr ""
+#: ../lib/python/temporal/base.py:378
+msgid "Object <%s> not found in the temporal database"
-#: ../lib/ogsf/GP2.c:705
-msgid "Unknown icon marker, using \"sphere\""
+#: ../lib/python/temporal/base.py:459 ../lib/python/temporal/base.py:509
+msgid "Missing identifer"
 msgstr ""
-#: ../lib/ogsf/gsd_legend.c:239 ../lib/ogsf/Gs3.c:125 ../lib/ogsf/Gs3.c:189
-#: ../lib/ogsf/Gs3.c:264 ../lib/ogsf/Gs3.c:336 ../lib/ogsf/Gs3.c:442
-#: ../lib/ogsf/Gs3.c:529 ../lib/ogsf/Gs3.c:588 ../lib/ogsf/Gs3.c:645
-#: ../lib/ogsf/Gs3.c:716 ../lib/ogsf/Gs3.c:786 ../lib/raster/open.c:175
-#: ../lib/raster/open.c:744 ../lib/raster/open.c:781 ../lib/raster/open.c:833
-#: ../lib/python/temporal/space_time_datasets.py:296
-#: ../lib/manage/do_remove.c:73 ../lib/manage/do_rename.c:71
-#: ../lib/rst/interp_float/output2d.c:236
-#: ../lib/rst/interp_float/output2d.c:317
-#: ../lib/rst/interp_float/output2d.c:386
-#: ../lib/rst/interp_float/output2d.c:436
-#: ../lib/rst/interp_float/output2d.c:450
-#: ../lib/rst/interp_float/output2d.c:464
-#: ../lib/rst/interp_float/output2d.c:480
-#: ../lib/rst/interp_float/resout2d.c:205
-#: ../lib/rst/interp_float/resout2d.c:253
-#: ../lib/rst/interp_float/resout2d.c:296
-#: ../lib/rst/interp_float/resout2d.c:327
-#: ../lib/rst/interp_float/resout2d.c:377
-#: ../lib/rst/interp_float/resout2d.c:395
-#: ../lib/rst/interp_float/resout2d.c:410
-#: ../lib/rst/interp_float/resout2d.c:426 ../lib/gis/legal_name.c:94
-#: ../lib/gis/legal_name.c:97
-msgid "Raster map <%s> not found"
+#: ../lib/python/temporal/base.py:615
+#, fuzzy
+msgid "Wrong identifier, the mapset is missing"
-#: ../lib/ogsf/gsd_legend.c:246
-#, fuzzy, c-format
-msgid "Unable to read color file of raster map <%s>"
+#: ../lib/python/temporal/c_libraries_interface.py:280
+#: ../lib/python/temporal/c_libraries_interface.py:297
+#, fuzzy
+msgid "Unable to read range file"
+msgstr "Nevar atvērt 'temp'/pagaidu failu"
-#: ../lib/ogsf/gsd_legend.c:252
-#, fuzzy, c-format
-msgid "Unable to read category file of raster map <%s>"
+#: ../lib/python/temporal/c_libraries_interface.py:358
+#: ../lib/gpde/N_arrays_io.c:281 ../lib/ogsf/gvl_file.c:436
+#, c-format, python-format
+msgid "Unable to open 3D raster map <%s>"
+msgstr ""
-#: ../lib/ogsf/gsd_legend.c:269
-#, fuzzy, c-format
-msgid "Unable to read fp range of raster map <%s>"
+#: ../lib/python/temporal/c_libraries_interface.py:373
+msgid "Unable to load range of 3D raster map <%s>"
-#: ../lib/ogsf/gsd_legend.c:281
-#, fuzzy, c-format
-msgid "Unable to read range of raster map <%s>"
-#: ../lib/ogsf/gsd_legend.c:295
-msgid "Range request error for legend"
+#: ../lib/python/temporal/c_libraries_interface.py:388
+#: ../lib/raster3d/close.c:120 ../lib/raster3d/close.c:130
+#: ../lib/raster3d/close.c:159 ../lib/ogsf/gvl_file.c:470
+msgid "Unable to close 3D raster map <%s>"
 msgstr ""
-#: ../lib/ogsf/gsd_legend.c:385
-#, fuzzy
-msgid "Unable to show discrete FP range (use list"
-msgstr "Nevar ierakstīt datubāzes saites"
+#: ../lib/python/temporal/c_libraries_interface.py:427
+#: ../lib/vector/Vlib/open.c:288 ../lib/vector/Vlib/open.c:425
+#: ../lib/ogsf/Gp3.c:62 ../lib/ogsf/Gp3.c:194 ../lib/ogsf/Gv3.c:66
+#: ../lib/ogsf/Gv3.c:331
+msgid "Unable to open vector map <%s>"
+msgstr "Nav iespējams atvērt vektoru karti <%s>"
-#: ../lib/ogsf/gsd_legend.c:501
-#, fuzzy
-msgid "Too many categories to show as discrete!"
-msgstr "Pārāk daudz pārklasificēšanas kategorijas priekš [%s iekš %s]"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:153
+#: ../lib/python/temporal/abstract_space_time_dataset.py:287
+msgid "Unknown temporal type \"%s\""
-#: ../lib/ogsf/gsd_legend.c:503
-msgid "Try using smaller font!"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:280
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1055
+msgid "Wrong granularity: \"%s\""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:308
+msgid "Unsupported temporal unit: %s"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:360
+msgid "Created register table <%s> for space time %s  dataset <%s>"
+msgstr "Ievades rastra failu nosaukumi"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:679
+#: ../lib/python/temporal/abstract_space_time_dataset.py:925
+msgid "The space time datasets must be of the same temporal type"
 msgstr ""
-#: ../lib/ogsf/gvl_file.c:103
-msgid "Maximum number of datafiles exceeded"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:684
+#: ../lib/python/temporal/abstract_space_time_dataset.py:930
+msgid "The temporal map type of the sample dataset must be interval"
 msgstr ""
-#: ../lib/ogsf/gvl_file.c:436
-#: ../lib/python/temporal/space_time_datasets.py:706
-#: ../lib/gpde/N_arrays_io.c:281
-msgid "Unable to open 3D raster map <%s>"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1465
+msgid "Unable to get map ids from register table <%s>"
-#: ../lib/ogsf/gvl_file.c:442
-#, fuzzy, c-format
-msgid "Unable to read range of 3D raster map <%s>"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1575
+msgid ""
+"Unable to shift dataset <%(ds)s> of type %(type)s in the temporal database. "
-#: ../lib/ogsf/gvl_file.c:470 ../lib/raster3d/close.c:120
-#: ../lib/raster3d/close.c:130 ../lib/raster3d/close.c:159
-#: ../lib/python/temporal/space_time_datasets.py:734
-msgid "Unable to close 3D raster map <%s>"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1742
+msgid ""
+"Unable to snap dataset <%(ds)s> of type %(type)s in the temporal database. "
-#: ../lib/ogsf/GK2.c:272 ../lib/ogsf/GK2.c:285
-msgid "Check no. of frames requested and keyframes marked"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1842
+msgid ""
+"Unable to rename dataset <%(ds)s> of type %(type)s in the temporal database. "
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1849
+msgid "Renaming of space time datasets is not supported for PostgreSQL."
 msgstr ""
-#: ../lib/ogsf/Gs3.c:132 ../lib/ogsf/Gs3.c:196 ../lib/ogsf/Gs3.c:348
-#: ../lib/ogsf/Gs3.c:454 ../lib/ogsf/Gs3.c:540
-#, fuzzy, c-format
-msgid "Loading raster map <%s>..."
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1912
+msgid "Delete space time %s  dataset <%s> from temporal database"
-#: ../lib/ogsf/Gs3.c:596
-#, c-format
-msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
-msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1918
+#: ../lib/python/temporal/abstract_map_dataset.py:805
+msgid ""
+"Unable to delete dataset <%(ds)s> of type %(type)s from the temporal "
+"database. The mapset of the dataset does not match the current mapset"
-#: ../lib/ogsf/Gs3.c:658 ../lib/ogsf/Gs3.c:730
-#, fuzzy, c-format
-msgid "Translating colors from raster map <%s>..."
-msgstr "Lūdzu pārveido topoloģiju vektoram '%s@%s'"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1929
+msgid "Drop map register table: %s"
-#: ../lib/ogsf/Gs3.c:967
-msgid "View not saved by this program,there may be some inconsistancies"
-msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1984
+#, fuzzy
+msgid "Error in register table request"
-#: ../lib/ogsf/gsds.c:109
-msgid "Maximum number of datasets exceeded"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2012
+msgid ""
+"Unable to register map in dataset <%(ds)s> of type %(type)s. The mapset of "
+"the dataset does not match the current mapset"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2020
+msgid ""
+"Only a map that was inserted in the temporal database can be registered in a "
+"space time dataset"
 msgstr ""
-#: ../lib/ogsf/GVL2.c:267
-#, fuzzy, c-format
-msgid "Loading 3d raster map <%s>..."
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2040
+msgid "Map <%(id)s> with layer %(l)s has invalid time"
+msgstr "Defekts: atteikts papildināt karti,kura nav tekošajā karšu komplektā."
-#: ../lib/proj/convert.c:82 ../lib/vector/Vlib/close.c:282
-#: ../lib/vector/Vlib/build_ogr.c:94 ../lib/vector/Vlib/build_ogr.c:169
-#: ../lib/vector/Vlib/open_ogr.c:121 ../lib/vector/Vlib/open_ogr.c:154
-#: ../lib/vector/Vlib/open_ogr.c:231 ../lib/vector/Vlib/write_sfa.c:291
-#: ../lib/vector/Vlib/rewind_ogr.c:47 ../lib/vector/Vlib/rewind_ogr.c:71
-#: ../lib/vector/Vlib/header_finfo.c:41 ../lib/vector/Vlib/header_finfo.c:80
-#: ../lib/vector/Vlib/header_finfo.c:113 ../lib/vector/Vlib/header_finfo.c:153
-#: ../lib/vector/Vlib/simple_features.c:310 ../lib/vector/Vlib/build_sfa.c:712
-#: ../lib/vector/Vlib/close_ogr.c:82 ../lib/vector/Vlib/close_ogr.c:116
-#: ../lib/vector/Vlib/field.c:660 ../lib/vector/Vlib/read_ogr.c:56
-#: ../lib/vector/Vlib/read_ogr.c:157 ../lib/vector/Vlib/read_ogr.c:242
-#: ../lib/vector/Vlib/write_ogr.c:69 ../lib/vector/Vlib/write_ogr.c:105
-#: ../lib/vector/Vlib/write_ogr.c:145
-msgid "GRASS is not compiled with OGR support"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2043
+#, python-format
+msgid "Map <%s> has invalid time"
 msgstr ""
-#: ../lib/proj/convert.c:120
-msgid "Unable parse GRASS PROJ_INFO file"
-msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2061
+msgid ""
+"Temporal type of space time dataset <%(id)s> and map <%(map)s> with layer "
+"%(l)s are different"
-#: ../lib/proj/convert.c:125
-msgid "Unable get PROJ.4-style parameter string"
-msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2066
+msgid "Temporal type of space time dataset <%(id)s> and map <%(map)s> are different"
-#: ../lib/proj/convert.c:139
-#, c-format
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2080
+msgid "Set temporal unit for space time %s dataset <%s> to %s"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2089
 msgid ""
-"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
-msgstr ""
+"Relative time units of space time dataset <%(id)s> and map <%(map)s> with "
+"layer %(l)s are different"
-#: ../lib/proj/convert.c:146
-#, c-format
-msgid "OGR can't get WKT-style parameter string (OGR Error code was %d)"
-msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2095
+msgid ""
+"Relative time units of space time dataset <%(id)s> and map <%(map)s> are "
+"different"
-#: ../lib/proj/convert.c:406
-msgid "No projection name! Projection parameters likely to be meaningless."
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2101
+msgid "Only maps from the same mapset can be registered"
 msgstr ""
-#: ../lib/proj/convert.c:442
-#, c-format
-msgid "Datum <%s> not recognised by GRASS and no parameters found"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2106
+msgid "Map <%(map)s> with layer %(l)s is already registered."
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2110
+#, python-format
+msgid "Map <%s> is already registered."
 msgstr ""
-#: ../lib/proj/convert.c:458
-#, c-format
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2158
 msgid ""
-"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
-"want to look into this."
-msgstr ""
+"Unable to unregister map from dataset <%(ds)s> of type %(type)s in the "
+"temporal database. The mapset of the dataset does not match the current "
+"mapset"
-#: ../lib/proj/convert.c:462
-#, c-format
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2169
 msgid ""
-"Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
-"transform parameters unspecified."
-msgstr ""
+"Map <%(map)s> with layer %(l)s is not registered in space time dataset <"
+"%(base)s>"
-#: ../lib/proj/datum.c:270 ../lib/proj/datum.c:350
-#, fuzzy, c-format
-msgid "Unable to open datum table file <%s>"
-msgstr "neispējami atvērt datumu tabulas failu: %s"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2174
+msgid "Map <%(map)s> is not registered in space time dataset <%(base)s>"
-#: ../lib/proj/datum.c:283 ../lib/proj/datum.c:364
-#, fuzzy, c-format
-msgid "Error in datum table file <%s>, line %d"
-msgstr "kļūda datumu tabulas failā, līnija  %d"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2230
+#, python-format
+msgid "Update metadata, spatial and temporal extent from all registered maps of <%s>"
+msgstr ""
-#: ../lib/proj/get_proj.c:148
-#, fuzzy, c-format
-msgid "Invalid zone %s specified"
-msgstr "nederīgs elipsoīds %s failā"
+#: ../lib/python/temporal/univar_statistics.py:54
+#: ../lib/python/temporal/univar_statistics.py:142
+msgid "Space time %(sp)s dataset <%(i)s> is empty"
-#: ../lib/proj/get_proj.c:228
-msgid "Unable to initialise PROJ.4 with the following parameter list:"
-msgstr ""
+#: ../lib/python/temporal/univar_statistics.py:132
+msgid "Space time %(sp)s dataset <%(i)s> not found"
-#: ../lib/proj/get_proj.c:236
-#, c-format
-msgid "The error message: %s"
+#: ../lib/python/temporal/spatial_extent.py:125
+msgid ""
+"Projections are different. Unable to compute overlapping_2d for spatial "
+"extents"
 msgstr ""
-#: ../lib/proj/get_proj.c:294
-msgid "Option input overflowed option table"
+#: ../lib/python/temporal/spatial_extent.py:536
+msgid "Projections are different. Unable to compute is_in_2d for spatial extents"
 msgstr ""
-#: ../lib/proj/get_proj.c:325
-#, fuzzy, c-format
-msgid "Unable to initialize pj cause: %s"
-#: ../lib/proj/get_proj.c:401
-msgid "Input Projection Parameters"
+#: ../lib/python/temporal/spatial_extent.py:676
+msgid ""
+"Projections are different. Unable to compute equivalent_2d for spatial "
+"extents"
 msgstr ""
-#: ../lib/proj/get_proj.c:404
-msgid "Input Unit Factor"
+#: ../lib/python/temporal/spatial_extent.py:783
+msgid "Projections are different. Unable to compute cover_2d for spatial extents"
 msgstr ""
-#: ../lib/proj/get_proj.c:414
-msgid "Output Projection Parameters"
+#: ../lib/python/temporal/spatial_extent.py:854
+msgid "Projections are different. Unable to compute cover for spatial extents"
 msgstr ""
-#: ../lib/proj/get_proj.c:417
-msgid "Output Unit Factor"
+#: ../lib/python/temporal/spatial_extent.py:1704
+msgid "Volume computation is not supported for LL projections"
 msgstr ""
-#: ../lib/proj/do_proj.c:106 ../lib/proj/do_proj.c:180
-#, c-format
-msgid "pj_transform() failed: %s"
+#: ../lib/python/temporal/spatial_extent.py:1722
+msgid "Area computation is not supported for LL projections"
 msgstr ""
-#: ../lib/proj/ellipse.c:76
-#, fuzzy, c-format
-msgid "Invalid ellipsoid <%s> in file"
+#: ../lib/python/temporal/stds_import.py:84
+msgid "Unable to import/link raster map <%s> from file %s."
-#: ../lib/proj/ellipse.c:103
-msgid "No secondary ellipsoid descriptor (rf, es or b) in file"
-msgstr ""
+#: ../lib/python/temporal/stds_import.py:94
+msgid "Unable to set the color rules for raster map <%s>."
-#: ../lib/proj/ellipse.c:107
-#, fuzzy
-msgid "Invalid ellipsoid descriptors (a, rf, es or b) in file"
+#: ../lib/python/temporal/stds_import.py:118
+msgid "Unable to unpack raster map <%s> from file %s."
-#: ../lib/proj/ellipse.c:120
-msgid "No ellipsoid info given in file"
-msgstr "Nav elipsoīda informācija sniegta failā"
+#: ../lib/python/temporal/stds_import.py:142
+msgid "Unable to import vector map <%s> from file %s."
-#: ../lib/proj/ellipse.c:220 ../lib/gis/get_ellipse.c:263
-#, fuzzy, c-format
-msgid "Unable to open ellipsoid table file <%s>"
-msgstr "neiespējami atvērt elipsoīda tabulas failu: %s"
+#: ../lib/python/temporal/stds_import.py:166
+msgid "Unable to unpack vector map <%s> from file %s."
-#: ../lib/proj/ellipse.c:273 ../lib/gis/get_ellipse.c:322
-#, c-format
-msgid "Line%s of ellipsoid table file <%s> is invalid"
-msgstr "Līnija %s no elipsoīdu tabulas faila <%s> ir nederīga"
+#: ../lib/python/temporal/stds_import.py:204
+msgid "Space time raster dataset archive <%s> not found"
-#: ../lib/proj/ellipse.c:274 ../lib/gis/get_ellipse.c:321
-#, c-format
-msgid "Lines%s of ellipsoid table file <%s> are invalid"
-msgstr "Līnijas %s no elipsoīdu tabulas faila <%s> ir nederīgas"
+#: ../lib/python/temporal/stds_import.py:207
+msgid "Extraction directory <%s> not found"
-#: ../lib/raster3d/range.c:73
-#, fuzzy, c-format
-msgid "Unable to open range file for [%s in %s]"
+#: ../lib/python/temporal/stds_import.py:215
+msgid "Unable to find init file <%s>"
-#: ../lib/raster3d/range.c:88
-#, fuzzy, c-format
-msgid "Error reading range file for [%s in %s]"
-msgstr "Nederīgs histogrammas fails priekš [%s iekš %s]"
+#: ../lib/python/temporal/stds_import.py:217
+msgid "Unable to find list file <%s>"
-#: ../lib/raster3d/range.c:150
-#, fuzzy, c-format
-msgid "Unable to open range file for <%s>"
-msgstr "Nevar atvērt vēsturi vektoram '%s'"
+#: ../lib/python/temporal/stds_import.py:219
+msgid "Unable to find projection file <%s>"
-#: ../lib/raster3d/history.c:43
-#, c-format
-msgid "can't get history information for [%s] in mapset [%s]"
+#: ../lib/python/temporal/stds_import.py:244
+msgid "Projection information does not match. Proceeding..."
 msgstr ""
-"nevar iegūt vēstures informāciju priekš [%s] no karšu biblotēkas/mapset [%s]"
-#: ../lib/raster3d/param.c:84
-msgid "Rast3d_get_standard3d_params: precision value invalid"
+#: ../lib/python/temporal/stds_import.py:248
+msgid ""
+"Difference between PROJ_INFO file of imported map and of current location:\n"
+"{diff}"
 msgstr ""
-#: ../lib/raster3d/param.c:105
-msgid "Rast3d_get_standard3d_params: tile dimension value invalid"
+#: ../lib/python/temporal/stds_import.py:250
+msgid "Projection information does not match. Aborting."
 msgstr ""
-#: ../lib/raster3d/param.c:129
-msgid "Window replacing the default"
-msgstr "Logs aizvieto noklusēto"
-#: ../lib/raster3d/close.c:47
-#, fuzzy, c-format
-msgid "Unable to write history for 3D raster map <%s>"
+#: ../lib/python/temporal/stds_import.py:266
+msgid "Unable to create location %(l)s. Reason: %(e)s"
-#: ../lib/raster3d/close.c:62
-#, fuzzy, c-format
-msgid "Unable to move temp raster map <%s> to 3d data file <%s>"
-msgstr "neiespējami atvērt rastra karti [%s iekš %s]"
+#: ../lib/python/temporal/stds_import.py:273
+msgid "Unable to switch to location %s"
+msgstr "nevar ierakstīt vēstures informāciju priekš [%s]"
-#: ../lib/raster3d/close.c:79
-#, fuzzy
-msgid "Unable to flush all tiles"
+#: ../lib/python/temporal/stds_import.py:277
+msgid "Unable to create default temporal database in new location %s"
-#: ../lib/raster3d/close.c:84
+#: ../lib/python/temporal/stds_import.py:342
+msgid "Key words %(t)s, %(s)s or %(n)s not found in init file."
+#: ../lib/python/temporal/stds_import.py:348
+msgid "Number of maps mismatch in init and list file."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:359
 #, fuzzy
-msgid "Unable to flush index"
-msgstr "neiespējami atrast [%s]"
+msgid "The archive file is of wrong space time dataset type"
-#: ../lib/raster3d/close.c:94
+#: ../lib/python/temporal/stds_import.py:366
+msgid "Unable to find geotiff raster file <%s> in archive."
+msgstr "neispējami atrast pagaidu null failu: %s"
+#: ../lib/python/temporal/stds_import.py:372
+msgid "Unable to find AAIGrid raster file <%s> in archive."
+#: ../lib/python/temporal/stds_import.py:378
+msgid "Unable to find GML vector file <%s> in archive."
+#: ../lib/python/temporal/stds_import.py:387
+msgid "Unable to find GRASS package file <%s> in archive."
+msgstr "Neiespējami atvērt %s priekš rakstīšanas"
+#: ../lib/python/temporal/stds_import.py:390
 #, fuzzy
-msgid "Unable to position file"
+msgid "Unsupported input format"
-#: ../lib/raster3d/close.c:99 ../lib/raster3d/close.c:105
-#: ../lib/raster3d/close.c:191 ../lib/raster3d/header.c:217
-#, fuzzy, c-format
-msgid "Unable to write header for 3D raster map <%s>"
+#: ../lib/python/temporal/stds_import.py:396
+msgid ""
+"Space time %(t)s dataset <%(sp)s> is already in the database. Use the "
+"overwrite flag."
-#: ../lib/raster3d/close.c:110 ../lib/raster3d/close.c:153
-#, fuzzy, c-format
-msgid "Unable to create 3D raster map <%s>"
+#: ../lib/python/temporal/stds_import.py:416
+msgid "Overwrite space time %(sp)s dataset <%(id)s> and unregister all maps."
-#: ../lib/raster3d/close.c:169
-msgid "Error in cache"
-msgstr ""
+#: ../lib/python/temporal/stds_import.py:428
+msgid "Key word %s not found in init file."
-#: ../lib/raster3d/open.c:20
-msgid "Rast3d_open_cell_old_no_header: error in Rast3d_mask_open_old"
-msgstr ""
+#: ../lib/python/temporal/stds_import.py:432
+msgid "Create space time %s dataset."
-#: ../lib/raster3d/open.c:26
-msgid "Rast3d_open_cell_old_no_header: error in Rast3d_malloc"
-msgstr ""
+#: ../lib/python/temporal/aggregation.py:124
+msgid "Aggregate %s raster maps"
+msgstr "Bāzes rastra faila nosaukums"
-#: ../lib/raster3d/open.c:37
-msgid "Rast3d_open_cell_old_no_header: error in G_open_old"
-msgstr ""
+#: ../lib/python/temporal/aggregation.py:138
+msgid ""
+"Raster map <%s> is already in temporal database, use overwrite flag to "
+"overwrite"
-#: ../lib/raster3d/open.c:93
-msgid "Rast3d_open_cell_old: error in Rast3d_open_cell_old_no_header"
+#: ../lib/python/temporal/aggregation.py:142
+#, python-format
+msgid "Compute aggregation of maps between %(st)s - %(end)s"
 msgstr ""
-#: ../lib/raster3d/open.c:98
-msgid "Rast3d_open_cell_old: can't rewind file"
+#: ../lib/python/temporal/aggregation.py:161
+msgid "Error while r.series computation"
 msgstr ""
-#: ../lib/raster3d/open.c:111
-msgid "Rast3d_open_cell_old: error in Rast3d_read_header"
-msgstr ""
+#: ../lib/python/temporal/open_stds.py:60
+#: ../lib/python/temporal/open_stds.py:115
+msgid "Unkown type: %s"
-#: ../lib/raster3d/open.c:119
-msgid "Rast3d_open_cell_old: projection does not match window projection"
-msgstr ""
+#: ../lib/python/temporal/open_stds.py:66
+msgid "Space time %(sp)s dataset <%(name)s> no found"
-#: ../lib/raster3d/open.c:123
-msgid "Rast3d_open_cell_old: zone does not match window zone"
-msgstr ""
+#: ../lib/python/temporal/open_stds.py:104
+#, fuzzy
+msgid "Space time datasets can only be created in the current mapset"
-#: ../lib/raster3d/open.c:135 ../lib/raster3d/open.c:152
-msgid "Rast3d_open_cell_old: can't read header"
-msgstr ""
+#: ../lib/python/temporal/open_stds.py:121
+msgid ""
+"Space time %(sp)s dataset <%(name)s> is already in the database. Use the "
+"overwrite flag."
-#: ../lib/raster3d/open.c:141
-msgid "Rast3d_open_cell_old: index does not fit into long"
+#: ../lib/python/temporal/open_stds.py:155
+msgid "Overwrite space time %(sp)s dataset <%(name)s> and unregister all maps."
+#: ../lib/python/temporal/open_stds.py:163
+msgid "Create new space time %s dataset."
+#: ../lib/python/temporal/gui_support.py:57 ../lib/python/script/core.py:1335
+#, python-format
+msgid "Invalid element '%s'"
 msgstr ""
-#: ../lib/raster3d/open.c:145
-msgid "Rast3d_open_cell_old: error in Rast3d_malloc"
+#: ../lib/python/temporal/abstract_map_dataset.py:339
+msgid ""
+"Start time must be of type datetime for %(type)s map <%(id)s> with layer: "
+"%(l)s"
 msgstr ""
+"Nevar izveidot laikspiedola(timestamp) failu priekš %s kartes %s karšu "
+"biblitēkā %s"
-#: ../lib/raster3d/open.c:172
-msgid "Rast3d_open_cell_old: error in Rast3d_fill_header"
+#: ../lib/python/temporal/abstract_map_dataset.py:345
+msgid "Start time must be of type datetime for %(type)s map <%(id)s>"
 msgstr ""
+"Nederīgs liakspiedola(timestamp) fails priekš %s kartes %s  karšu biblotēkā "
+"%s"
-#: ../lib/raster3d/open.c:219
-msgid "Rast3d_open_cell_new: error in Rast3d_mask_open_old"
+#: ../lib/python/temporal/abstract_map_dataset.py:352
+msgid "End time must be of type datetime for %(type)s map <%(id)s> with layer: %(l)s"
 msgstr ""
+"%s"
-#: ../lib/raster3d/open.c:228
-msgid "Rast3d_open_cell_new: error in Rast3d_malloc"
+#: ../lib/python/temporal/abstract_map_dataset.py:358
+msgid "End time must be of type datetime for %(type)s map <%(id)s>"
 msgstr ""
+"%s"
-#: ../lib/raster3d/open.c:233
-#, fuzzy, c-format
-msgid "map <%s> is not in the current mapset"
+#: ../lib/python/temporal/abstract_map_dataset.py:366
+msgid ""
+"End time must be greater than start time for %(type)s map <%(id)s> with "
+"layer: %(l)s"
+msgstr "Austrumiem ir jābūt lielākiem nekā Rietumiem"
-#: ../lib/raster3d/open.c:243
-msgid "Rast3d_open_cell_new: could not open file"
+#: ../lib/python/temporal/abstract_map_dataset.py:373
+#: ../lib/python/temporal/abstract_map_dataset.py:462
+msgid "End time must be greater than start time for %(type)s map <%(id)s>"
+#: ../lib/python/temporal/abstract_map_dataset.py:443
+msgid ""
+"Unsupported relative time unit type for %(type)s map <%(id)s> with layer "
+"%(l)s: %(u)s"
 msgstr ""
+"biblitēkā %s"
-#: ../lib/raster3d/open.c:287 ../lib/raster3d/open.c:292
-msgid "Rast3d_open_cell_new: can't write header"
+#: ../lib/python/temporal/abstract_map_dataset.py:448
+msgid "Unsupported relative time unit type for %(type)s map <%(id)s>: %(u)s"
+#: ../lib/python/temporal/abstract_map_dataset.py:457
+msgid ""
+"layer %(l)s"
+#: ../lib/python/temporal/abstract_map_dataset.py:766
+#, python-format
+msgid ""
+"Map <%(id)s> with layer %(layer)s has incorrect time interval, start time is "
+"greater than end time"
 msgstr ""
-#: ../lib/raster3d/open.c:314
-msgid "Rast3d_open_cell_new: error in Rast3d_fill_header"
+#: ../lib/python/temporal/abstract_map_dataset.py:772
+#, python-format
+msgid "Map <%s> has incorrect time interval, start time is greater than end time"
 msgstr ""
-#: ../lib/raster3d/maskfn.c:77
-#, c-format
-msgid "Adding rule: %lf - %lf"
+#: ../lib/python/temporal/abstract_map_dataset.py:777
+#, python-format
+msgid "Map <%s> has incorrect start time"
 msgstr ""
-#: ../lib/raster3d/maskfn.c:95
-#, fuzzy, c-format
-msgid "%s: illegal value spec"
-msgstr "Neatļauta līnijas vērtība"
+#: ../lib/python/temporal/abstract_map_dataset.py:821
+msgid "Delete %s dataset <%s> from temporal database"
-#: ../lib/raster3d/color.c:354
-#, fuzzy, c-format
-msgid "mapset <%s> is not the current mapset"
+#: ../lib/python/temporal/abstract_map_dataset.py:870
+msgid ""
+"Unable to unregister dataset <%(ds)s> of type %(type)s from the temporal "
-#: ../lib/init/prompt.py:20
-msgid "[Raster and Volume MASKs present]"
+#: ../lib/python/temporal/sampling.py:92 ../lib/python/temporal/sampling.py:96
+msgid "Dataset <%s> not found in temporal database"
+#: ../lib/python/temporal/temporal_raster_base_algebra.py:316
+msgid "Error computing map <%s>"
+#: ../lib/python/temporal/register.py:77
+#, python-format
+msgid "%(m)s= and %(f)s= are mutually exclusive"
 msgstr ""
-#: ../lib/init/prompt.py:22
-msgid "[Raster MASK present]"
+#: ../lib/python/temporal/register.py:81
+#, python-format
+msgid "%(e)s= and %(i)s= are mutually exclusive"
 msgstr ""
-#: ../lib/init/prompt.py:24
-msgid "[Volume MASK present]"
+#: ../lib/python/temporal/register.py:85
+msgid "Please specify %(st)s= and %(e)s="
 msgstr ""
+"\n"
+"Lūdzu norādi datuma nosaukumu\n"
-#: ../lib/init/lock.c:38
-#, c-format
-msgid "Usage: %s file pid"
+#: ../lib/python/temporal/register.py:89
+msgid "Please specify %(m)s= or %(f)s="
 msgstr ""
+"\n"
+"Lūdzu norādi elipsoīda nosaukumu\n"
-#: ../lib/init/lock.c:42
-msgid "Concurrent mapset locking is not supported on Windows"
+#: ../lib/python/temporal/register.py:101
+msgid ""
+"Space time %(sp)s dataset <%(name)s> with relative time found, but no "
+"relative unit set for %(sp)s maps"
+#: ../lib/python/temporal/register.py:167
+msgid "Gathering map informations"
 msgstr ""
-#: ../lib/init/lock.c:60
-#, fuzzy, c-format
-msgid "Unable to write lockfile %s (%s)"
+#: ../lib/python/temporal/register.py:177
+msgid "Unable to update %(t)s map <%(id)s>. The map does not exists."
-#: ../lib/init/grass.py:74
-#, fuzzy
-msgid "WARNING"
-msgstr "BRĪDINĀJUMS:"
+#: ../lib/python/temporal/register.py:196
+msgid ""
+"Unable to register %(t)s map <%(id)s> with layer %(l)s. The map has "
+"timestamp and the start time is not set."
-#: ../lib/init/grass.py:130
-#, fuzzy
-msgid "Exiting..."
-msgstr "Pievienot centroīdus"
+#: ../lib/python/temporal/register.py:202
+msgid ""
+"Unable to register %(t)s map <%(id)s>. The map has no timestamp and the "
+"start time is not set."
-#: ../lib/init/grass.py:200
-#, fuzzy
-msgid "Usage"
+#: ../lib/python/temporal/register.py:210
+#, python-format
+msgid "%(u)s= can only be set for relative time"
 msgstr ""
-"\n"
-"Pieleitojums:\n"
-#: ../lib/init/grass.py:201 ../lib/gis/parser_html.c:142
-#: ../lib/gis/parser_rest.c:146
-#, fuzzy
-msgid "Flags"
+#: ../lib/python/temporal/register.py:212
+#, python-format
+msgid "%(u)s= must be set in case of relative time stamps"
 msgstr ""
-"\n"
-"Karogi:\n"
-#: ../lib/init/grass.py:202
-msgid "print this help message"
-msgstr ""
+#: ../lib/python/temporal/register.py:224
+msgid ""
+"Map is already registered in temporal database. Unable to update %(t)s map <"
+"%(id)s> with layer %(l)s. Overwrite flag is not set."
-#: ../lib/init/grass.py:203
-msgid "show version information and exit"
-msgstr ""
+#: ../lib/python/temporal/register.py:231
+msgid ""
+"%(id)s>. Overwrite flag is not set."
-#: ../lib/init/grass.py:204
-msgid "create given database, location or mapset if it doesn't exist"
-msgstr ""
+#: ../lib/python/temporal/register.py:255
+msgid ""
+"Unable to update %(t)s map <%(id)s> with layer %(l)s. The temporal types are "
+"different."
-#: ../lib/init/grass.py:205
-msgid "use text based interface"
-msgstr ""
+#: ../lib/python/temporal/register.py:261
+msgid "Unable to update %(t)s map <%(id)s>. The temporal types are different."
-#: ../lib/init/grass.py:206 ../lib/init/grass.py:208
+#: ../lib/python/temporal/register.py:307
 #, fuzzy
-msgid "and set as default"
-msgstr "lai apstiprinātu noklusēto"
+msgid "Register maps in the temporal database"
-#: ../lib/init/grass.py:207
-msgid "use $DEFAULT_GUI graphical user interface"
-msgstr ""
+#: ../lib/python/temporal/register.py:314
+#, fuzzy
+msgid "Register maps in the space time raster dataset"
-#: ../lib/init/grass.py:209
-msgid "print GRASS configuration parameters"
+#: ../lib/python/temporal/register.py:323
+msgid "Update space time raster dataset"
 msgstr ""
-#: ../lib/init/grass.py:210
-msgid "options: arch,build,compiler,path,revision"
-msgstr ""
+#: ../lib/python/temporal/register.py:375
+#: ../lib/python/temporal/register.py:383
+msgid "Unable to convert string \"%s\"into a datetime object"
+msgstr "Izgāzusies konvertācija taksta (string) atribūtam."
-#: ../lib/init/grass.py:211 ../lib/gis/parser_html.c:182
-#: ../lib/gis/parser_rest.c:179
+#: ../lib/python/temporal/register.py:391
+#: ../lib/python/temporal/register.py:396
 #, fuzzy
-msgid "Parameters"
-msgstr ""
-"\n"
-"Parametri:\n"
+msgid "Error in increment computation"
-#: ../lib/init/grass.py:212
-msgid "initial database (path to GIS data)"
+#: ../lib/python/temporal/register.py:399
+#, python-format
+msgid ""
+"Set absolute valid time for map <%(id)s> with layer %(layer)s to %(start)s - "
+"%(end)s"
 msgstr ""
-#: ../lib/init/grass.py:213
-#, fuzzy
-msgid "initial location"
+#: ../lib/python/temporal/register.py:404
+#, python-format
+msgid "Set absolute valid time for map <%s> to %s - %s"
 msgstr ""
-"\n"
-"nederīga projekcija\n"
-#: ../lib/init/grass.py:214
-msgid "initial mapset"
+#: ../lib/python/temporal/register.py:421
+#, python-format
+msgid "Set relative valid time for map <%s> with layer %s to %i - %s with unit %s"
 msgstr ""
-#: ../lib/init/grass.py:215
-msgid "fully qualified initial mapset directory"
+#: ../lib/python/temporal/register.py:426
+#, python-format
+msgid "Set relative valid time for map <%s> to %i - %s with unit %s"
 msgstr ""
-#: ../lib/init/grass.py:216
-msgid "Environment variables relevant for startup"
+#: ../lib/python/temporal/list_stds.py:101
+msgid "Empty map list."
 msgstr ""
-#: ../lib/init/grass.py:217
-msgid "select GUI (text, gui)"
+#: ../lib/python/temporal/list_stds.py:112
+msgid "Empty entry in map list, this should not happen."
 msgstr ""
-#: ../lib/init/grass.py:218
-msgid "set html web browser for help pages"
-msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:223
+msgid "Unable to read timestamp file for raster map <%s>"
-#: ../lib/init/grass.py:219
-msgid "set additional path(s) to local GRASS modules or user scripts"
-msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:247
+msgid "Unable to create timestamp file for raster map <%s>"
-#: ../lib/init/grass.py:220
-msgid "set additional GISBASE for locally installed GRASS Addons"
+#: ../lib/python/temporal/space_time_datasets.py:252
+msgid "Invalid datetime in timestamp for raster map <%s>"
 msgstr ""
+"%s"
-#: ../lib/init/grass.py:221
-msgid "shell script to be processed as batch job"
-msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:257
+#: ../lib/python/temporal/space_time_datasets.py:572
+msgid "Internal error"
+msgstr "Iekšēja kļūda"
-#: ../lib/init/grass.py:222
-msgid "set python shell name to override 'python'"
-msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:274
+#: ../lib/python/temporal/space_time_datasets.py:586
+msgid "Unable to remove timestamp for raster map <%s>"
-#: ../lib/init/grass.py:260
+#: ../lib/python/temporal/space_time_datasets.py:538
-msgid ""
-"Unable to create temporary directory <grass7-%(user)s-%(lock)s>! Exiting."
+msgid "Unable to read timestamp file for 3D raster map <%s>"
-#: ../lib/init/grass.py:344
+#: ../lib/python/temporal/space_time_datasets.py:562
-msgid "GUI <%s> not supported in this version"
-msgstr "Pieprasītais formāts nav pieejams/iekļauts šijā versijā"
+msgid "Unable to create timestamp file for 3D raster map <%s>"
-#: ../lib/init/grass.py:488
-msgid "Searched for a web browser, but none found"
+#: ../lib/python/temporal/space_time_datasets.py:567
+msgid "Invalid datetime in timestamp for 3D raster map <%s>"
 msgstr ""
+"%s"
-#: ../lib/init/grass.py:512
-#, fuzzy
-msgid "Hit RETURN to continue"
-msgstr "spied ENTER lai turpinātu -->"
+#: ../lib/python/temporal/space_time_datasets.py:812
+msgid "Unable to read timestamp file for vector map <%s>"
-#: ../lib/init/grass.py:541
-msgid ""
-"The python command does not work as expected!\n"
-"Please check your GRASS_PYTHON environment variable.\n"
-"Use the -help option for details.\n"
-"Switching to text based interface mode.\n"
-"\n"
-"Hit RETURN to continue.\n"
-msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:835
+msgid "Unable to create timestamp file for vector map <%s>"
-#: ../lib/init/grass.py:553
-msgid ""
-"It appears that the X Windows system is not active.\n"
-"A graphical based user interface is not supported.\n"
-"\n"
-"Hit RETURN to continue"
+#: ../lib/python/temporal/space_time_datasets.py:840
+msgid "Invalid datetime in timestamp for vector map <%s>"
 msgstr ""
+"%s"
-#: ../lib/init/grass.py:600
+#: ../lib/python/temporal/space_time_datasets.py:856
-msgid "Location <%s> doesn't exist"
+msgid "Unable to remove timestamp for vector map <%s>"
-#: ../lib/init/grass.py:605
-#, fuzzy, python-format
-msgid "ERROR: <%s> is not a valid GRASS location"
-msgstr "Atvainojiet, <%s> ir nedrīgs parametrs\n"
-#: ../lib/init/grass.py:608
-#, python-format
-msgid ""
-"Mapset <%s> doesn't exist in GRASS location <%s>. A new mapset can be "
-"created by '-c' switch."
+#: ../lib/python/temporal/mapcalc.py:105
+msgid "Start spatio-temporal sampling"
 msgstr ""
-#: ../lib/init/grass.py:627
-#, python-format
-msgid "Failed to create new location. The location <%s> already exists."
+#: ../lib/python/temporal/mapcalc.py:107
+msgid "Start temporal sampling"
 msgstr ""
-#: ../lib/init/grass.py:655
-msgid "Missing WIND file fixed"
+#: ../lib/python/temporal/mapcalc.py:124
+msgid "No samples found for map calculation"
 msgstr ""
-#: ../lib/init/grass.py:667
+#: ../lib/python/temporal/mapcalc.py:151
 msgid ""
-"GISDBASE, LOCATION_NAME and MAPSET variables not set properly.\n"
-"Interactive startup needed."
+"Found more than a single map in a sample granule. Only the first map is used "
+"for computation. Use t.rast.aggregate.ds to create synchronous raster "
+"datasets."
 msgstr ""
-#: ../lib/init/grass.py:682
-#, python-format
-msgid ""
-"Invalid user interface specified - <%s>.\n"
-"Use the --help option to see valid interface names."
+#: ../lib/python/temporal/mapcalc.py:169
+msgid "No maps in input dataset"
 msgstr ""
-#: ../lib/init/grass.py:696
-msgid ""
-"Error in GUI startup. If necessary, please report this error to the GRASS "
-"developers.\n"
-"Switching to text mode now.\n"
-"\n"
-"Hit RETURN to continue..."
+#: ../lib/python/temporal/mapcalc.py:185
+msgid "Start mapcalc computation"
 msgstr ""
-#: ../lib/init/grass.py:706
-msgid ""
-"Received EXIT message from GUI.\n"
-"GRASS is not started. Bye."
+#: ../lib/python/temporal/mapcalc.py:255
+#, python-format
+msgid "Apply mapcalc expression: \"%s\""
 msgstr ""
-#: ../lib/init/grass.py:709
-#, fuzzy
-msgid ""
-"Invalid return code from GUI startup script.\n"
-"Please advise GRASS developers of this error."
-msgstr "Lūdzu dod ziņu GRASS izstrādātājiem par šo kļūdu.\n"
-#: ../lib/init/grass.py:720
-msgid ""
-"Error reading data path information from g.gisenv.\n"
-"GISDBASE=%(gisbase)s\n"
-"LOCATION_NAME=%(location)s\n"
-"MAPSET=%(mapset)s\n"
-"\n"
-"Check the <%s(file)> file."
+#: ../lib/python/temporal/mapcalc.py:274
+msgid "Error while mapcalc computation"
 msgstr ""
-#: ../lib/init/grass.py:818
+#: ../lib/python/temporal/mapcalc.py:280
+#, fuzzy
+msgid "Start map registration in temporal database"
+#: ../lib/python/temporal/mapcalc.py:430 ../lib/python/temporal/mapcalc.py:436
+#: ../lib/python/temporal/mapcalc.py:442 ../lib/python/temporal/mapcalc.py:448
+#: ../lib/python/temporal/mapcalc.py:454 ../lib/python/temporal/mapcalc.py:460
+#: ../lib/python/temporal/mapcalc.py:466 ../lib/python/temporal/mapcalc.py:472
+#: ../lib/python/temporal/mapcalc.py:478 ../lib/python/temporal/mapcalc.py:513
+#: ../lib/python/temporal/mapcalc.py:522 ../lib/python/temporal/mapcalc.py:531
+#: ../lib/python/temporal/mapcalc.py:540 ../lib/python/temporal/mapcalc.py:549
+#: ../lib/python/temporal/mapcalc.py:558 ../lib/python/temporal/mapcalc.py:567
+#: ../lib/python/temporal/mapcalc.py:576 ../lib/python/temporal/mapcalc.py:585
 #, python-format
-msgid "Path '%s' doesn't exist"
+msgid "The temporal operators <%s> supports only absolutetime."
 msgstr ""
-#: ../lib/init/grass.py:826
-#, python-format
+#: ../lib/python/script/raster.py:47
 msgid ""
-"%(user)s is currently running GRASS in selected mapset (file %(file)s "
-"found). Concurrent use not allowed."
+"Unable to write history for <%(map)s>. Raster map <%(map)s> not found in "
+"current mapset."
 msgstr ""
+"Nevar izdzēst līniju, karte '%s' karte nav atvērta rakstīšanas 'write' "
+"režijmā"
-#: ../lib/init/grass.py:830
-#, python-format
-msgid ""
-"Unable to properly access '%s'.\n"
-"Please notify system personel."
+#: ../lib/python/script/raster.py:105
+msgid "An error occurred while running r.mapcalc"
 msgstr ""
-#: ../lib/init/grass.py:847
-#, fuzzy
-msgid "Building user fontcap..."
-msgstr "Veidojam topoloģiju... \n"
+#: ../lib/python/script/raster.py:162
+msgid "No data"
+msgstr "Nav datu"
-#: ../lib/init/grass.py:892
-#, python-format
-msgid "Unsupported shell <%(sh)s>: %(env)s"
-msgstr ""
+#: ../lib/python/script/raster.py:170
+msgid "value"
+msgstr "vērtība"
-#: ../lib/init/grass.py:897
-#, fuzzy
-msgid "The SHELL variable is not set"
-msgstr "GISRC - mainīgais nav norādīts"
+msgid "label"
+msgstr "nosaukums"
-#: ../lib/init/grass.py:908
+msgid "color"
+msgstr "krāsa"
+#: ../lib/python/script/vector.py:88
 #, python-format
-msgid ""
-"Job file '%s' has been defined in the 'GRASS_BATCH_JOB' variable but not "
-"found. Exiting.\n"
-"\n"
-"Use 'unset GRASS_BATCH_JOB' to disable batch job processing."
+msgid "Database connection not defined for layer %s"
 msgstr ""
-#: ../lib/init/grass.py:913
-#, python-format
-msgid "Change file permission to 'executable' for '%s'"
+#: ../lib/python/script/vector.py:238
+msgid "Missing layer %(layer)d in vector map <%(map)s>"
+#: ../lib/python/script/vector.py:256
+msgid "vector_db_select() failed"
 msgstr ""
-#: ../lib/init/grass.py:915
-#, python-format
-msgid "Executing '%s' ..."
+#: ../lib/python/script/core.py:922
+msgid "Mixing value types. Will try to compare after integer conversion"
 msgstr ""
-#: ../lib/init/grass.py:920
+#: ../lib/python/script/core.py:937
 #, python-format
-msgid "Execution of '%s' finished."
+msgid "Several keys (%(miss)i out of %(a)i) are missing in the target file"
 msgstr ""
-#: ../lib/init/grass.py:926
+#: ../lib/python/script/core.py:1148
 #, python-format
-msgid "GRASS GUI should be <%s>"
+msgid "Element type should be \"cell\" and not \"%s\""
 msgstr ""
-#: ../lib/init/grass.py:955
+#: ../lib/python/script/core.py:1177 ../lib/python/script/core.py:1267
+#: ../lib/python/script/core.py:1322
 #, python-format
-msgid "Welcome to GRASS %s"
+msgid "Element type should be \"rast\" and not \"%s\""
 msgstr ""
-#: ../lib/init/grass.py:965
-msgid "GRASS homepage:"
-msgstr "GRASS mājas lapa:"
+#: ../lib/python/script/core.py:1523
+#, fuzzy
+msgid "Unable to list mapsets"
+msgstr "Neisespējami atvērt %s"
-#: ../lib/init/grass.py:966
-msgid "This version running through:"
-msgstr ""
+#: ../lib/python/script/core.py:1559
+msgid "Location <%s> already exists. Operation canceled."
-#: ../lib/init/grass.py:968
-#, fuzzy
-msgid "Help is available with the command:"
-msgstr "Nav pieejama palīdzība komandai [%s]\n"
+#: ../lib/python/script/core.py:1562
+msgid "Location <%s> already exists and will be overwritten"
-#: ../lib/init/grass.py:969
-msgid "See the licence terms with:"
-msgstr ""
+#: ../lib/python/script/core.py:1694
+msgid "Illegal filename <%s>. Cannot be 'NULL' or start with '.'."
+msgstr "Neatļauts faila nosaukums.  Nevar būt '.' vai 'NULL'\n"
-#: ../lib/init/grass.py:972
-msgid "If required, restart the GUI with:"
-msgstr ""
+#: ../lib/python/script/core.py:1703
+msgid "Illegal filename <%(s)s>. <%(il)s> not allowed.\n"
+msgstr "Neatļauts faila nosaukums. zīme <%c> nav atļauta.\n"
-#: ../lib/init/grass.py:974
-msgid "Start the GUI with:"
+#: ../lib/python/script/raster3d.py:89
+msgid "An error occurred while running r3.mapcalc"
 msgstr ""
-#: ../lib/init/grass.py:976
-msgid "When ready to quit enter:"
+#: ../lib/python/script/task.py:52
+#, fuzzy
+msgid "unknown"
+msgstr "nav zināms"
+#: ../lib/python/script/task.py:166
+#, python-format
+msgid "Parameter element '%(element)s' not found: '%(value)s'"
 msgstr ""
-#: ../lib/init/grass.py:1089
+#: ../lib/python/script/task.py:181
-msgid "Failed to start shell '%s'"
-msgstr "Neiespējami atvērt failu %s iekš %s"
+msgid "Flag not found: %s"
+msgstr "%s nav atrasts"
-#: ../lib/init/grass.py:1094
+#: ../lib/python/script/task.py:200
 #, python-format
-msgid "Batch job '%s' (defined in GRASS_BATCH_JOB variable) was executed."
+msgid "Parameter '%(name)s' (%(desc)s) is missing."
 msgstr ""
-#: ../lib/init/grass.py:1095 ../lib/init/grass.py:1100
-msgid "Goodbye from GRASS GIS"
-msgstr ""
+#: ../lib/python/script/task.py:231
+#, fuzzy
+msgid "<required>"
+msgstr "prasītais: %s\n"
-#: ../lib/init/grass.py:1098
-msgid "Done."
-msgstr "Pabeigts."
-#: ../lib/init/grass.py:1105
-msgid "Cleaning up temporary files..."
-msgstr "Satīra pagaidu failus..."
-#: ../lib/init/grass.py:1149
-msgid "Parameter <%s> not supported"
-#: ../lib/init/grass.py:1293
+#: ../lib/python/script/task.py:485 ../lib/python/script/task.py:489
 #, python-format
 msgid ""
-"Unable to start GRASS. You can:\n"
-" - Launch GRASS with '-gui' switch (`grass70 -gui`)\n"
-" - Create manually GISRC file (%s)\n"
-" - Launch GRASS with path to the location/mapset as an argument (`grass70 /"
-"path/to/location/mapset`)"
+"Unable to fetch interface description for command '%(cmd)s'.\n"
+"\n"
+"Details: %(det)s"
 msgstr ""
-#: ../lib/init/grass.py:1302
-msgid "Starting GRASS GIS..."
-msgstr "Startē GRASS GIS..."
+#: ../lib/python/script/db.py:48 ../lib/vector/Vlib/ascii.c:431
+#: ../lib/db/dbmi_client/column.c:136
+#, fuzzy, c-format, python-format
+msgid "Unable to describe table <%s>"
-#: ../lib/init/grass.py:1359
+#: ../lib/python/script/db.py:142
 #, python-format
-msgid "Launching <%s> GUI in the background, please wait..."
+msgid "Programmer error: '%(sql)s', '%(filename)s', or '%(table)s' must be provided"
 msgstr ""
-#: ../lib/raster/range.c:102 ../lib/raster/range.c:110
-#, fuzzy, c-format
-msgid "Unable to read fp range file for <%s>"
+#: ../lib/python/script/db.py:154
+#, fuzzy
+msgid "Fetching data failed"
-#: ../lib/raster/range.c:169
-#, fuzzy, c-format
-msgid "Unable to read quant rules for raster map <%s>"
-msgstr "neispējami mainīt direktoriju uz %s"
+#: ../lib/rowio/setup.c:61 ../lib/rowio/setup.c:67 ../lib/segment/open.c:97
+#: ../lib/rst/interp_float/interp2d.c:121
+#: ../lib/rst/interp_float/interp2d.c:127
+#: ../lib/rst/interp_float/segmen2d.c:182
+#: ../lib/rst/interp_float/segmen2d.c:188
+#: ../lib/rst/interp_float/segmen2d.c:194
+#: ../lib/rst/interp_float/segmen2d.c:204 ../lib/vector/Vlib/line.c:50
+#: ../lib/vector/Vlib/line.c:154 ../lib/vector/neta/components.c:46
+#: ../lib/vector/neta/components.c:113 ../lib/vector/neta/centrality.c:63
+#: ../lib/vector/neta/centrality.c:145 ../lib/vector/neta/flow.c:64
+#: ../lib/vector/neta/flow.c:179 ../lib/vector/neta/articulation_point.c:60
+#: ../lib/vector/neta/timetables.c:69 ../lib/vector/neta/timetables.c:168
+#: ../lib/vector/neta/timetables.c:178 ../lib/vector/neta/timetables.c:191
+#: ../lib/vector/neta/timetables.c:278 ../lib/vector/neta/timetables.c:413
+#: ../lib/vector/neta/timetables.c:425 ../lib/vector/neta/bridge.c:58
+#: ../lib/vector/neta/spanningtree.c:99 ../lib/vector/neta/path.c:136
+#: ../lib/ogsf/gsd_img_mpeg.c:359
+msgid "Out of memory"
+msgstr "Nepietiek atmiņas"
-#: ../lib/raster/range.c:206 ../lib/raster/range.c:226
-#, fuzzy, c-format
-msgid "Unable to read range file for <%s>"
-#: ../lib/raster/range.c:264 ../lib/raster/range.c:270
-#: ../lib/raster/range.c:300 ../lib/raster/range.c:314
-#, fuzzy, c-format
-msgid "Unable to write range file for <%s>"
-#: ../lib/raster/history.c:115 ../lib/raster/history.c:123
-#, fuzzy, c-format
-msgid "Unable to get history information for <%s@%s>"
-msgstr "nevar ierakstīt vēstures informāciju priekš [%s]"
-#: ../lib/raster/history.c:162
-#, fuzzy, c-format
-msgid "Unable to write history information for <%s>"
-#: ../lib/raster/history.c:235
+#: ../lib/proj/get_proj.c:148
 #, c-format
-msgid "generated by %s"
+msgid "Invalid zone %s specified"
+msgstr "Norādīta nederīga zona %s"
+#: ../lib/proj/get_proj.c:228
+msgid "Unable to initialise PROJ.4 with the following parameter list:"
 msgstr ""
-#: ../lib/raster/put_title.c:28
+#: ../lib/proj/get_proj.c:236
 #, c-format
-msgid "category information for [%s] in [%s] missing or invalid"
-msgstr "kategorijas informācija priekš [%s] no [%s] trūkst vai ir nederīga"
+msgid "The error message: %s"
+msgstr "Kļūdas paziņojums: %s"
-#: ../lib/raster/put_title.c:37
-msgid "G_put_title - can't create a temp file"
-msgstr "G_put_title - nevar izveidot pagaidu failu"
+#: ../lib/proj/get_proj.c:294
+msgid "Option input overflowed option table"
+msgstr ""
-#: ../lib/raster/put_title.c:53
+#: ../lib/proj/get_proj.c:325
 #, c-format
-msgid "category information for [%s] in [%s] invalid"
-msgstr "kategorijas informācija priekš [%s] iekš [%s] ir nederīga"
+msgid "Unable to initialize pj cause: %s"
+msgstr ""
-#: ../lib/raster/put_title.c:60
-msgid "G_put_title - can't reopen temp file"
+#: ../lib/proj/get_proj.c:401
+msgid "Input Projection Parameters"
 msgstr ""
-#: ../lib/raster/put_title.c:67
-#, c-format
-msgid "can't write category information for [%s] in [%s]"
-msgstr "nevar ierakstīt kategorijas informāciju priekš [%s] iekš [%s]"
-#: ../lib/raster/color_rand.c:33
-#, c-format
-msgid "Rast_make_random_colors: min (%d) > max (%d)"
+#: ../lib/proj/get_proj.c:404
+msgid "Input Unit Factor"
 msgstr ""
-#: ../lib/raster/init.c:61
-#, fuzzy
-msgid "Raster library not initialized. Programmer forgot to call Rast_init()."
+#: ../lib/proj/get_proj.c:414
+msgid "Output Projection Parameters"
 msgstr ""
-"\aKĻŪDA: Sistēma nav inicializēta. Programmētājs aizmirsis izsaukt "
-"G_gisinit()\n"
-#: ../lib/raster/color_read.c:103
-#, fuzzy
-msgid "missing"
-msgstr "kurš ir trūkstošs"
-#: ../lib/raster/color_read.c:106
-#, fuzzy
-msgid "invalid"
+#: ../lib/proj/get_proj.c:417
+msgid "Output Unit Factor"
 msgstr ""
-"ir nederīgs\n"
-"%s"
-#: ../lib/raster/color_read.c:112
-#, fuzzy, c-format
-msgid "Color support for <%s@%s> %s"
-msgstr "krāsu atbalsts [%s] karšu biblotēkā [%s] %s"
+#: ../lib/proj/datum.c:270 ../lib/proj/datum.c:350
+#, c-format
+msgid "Unable to open datum table file <%s>"
+msgstr "Nav iespējams atvērt datumu tabulas failu <%s>"
-#: ../lib/raster/close.c:74 ../lib/raster/close.c:107
-#, fuzzy, c-format
-msgid "Invalid descriptor: %d"
+#: ../lib/proj/datum.c:283 ../lib/proj/datum.c:364
+#, c-format
+msgid "Error in datum table file <%s>, line %d"
+msgstr "Kļūda datumu tabulas failā <%s> līnijā %d"
-#: ../lib/raster/close.c:373
-#, fuzzy, c-format
-msgid "Unable to rename null file '%s' to '%s'"
+#: ../lib/proj/convert.c:82 ../lib/vector/Vlib/build_sfa.c:711
+#: ../lib/vector/Vlib/simple_features.c:310 ../lib/vector/Vlib/close.c:284
+#: ../lib/vector/Vlib/header_finfo.c:41 ../lib/vector/Vlib/header_finfo.c:80
+#: ../lib/vector/Vlib/header_finfo.c:113 ../lib/vector/Vlib/header_finfo.c:153
+#: ../lib/vector/Vlib/header_finfo.c:254 ../lib/vector/Vlib/write_sfa.c:291
+#: ../lib/vector/Vlib/close_ogr.c:77 ../lib/vector/Vlib/close_ogr.c:111
+#: ../lib/vector/Vlib/write_ogr.c:69 ../lib/vector/Vlib/write_ogr.c:105
+#: ../lib/vector/Vlib/write_ogr.c:145 ../lib/vector/Vlib/build_ogr.c:94
+#: ../lib/vector/Vlib/build_ogr.c:169 ../lib/vector/Vlib/rewind_ogr.c:47
+#: ../lib/vector/Vlib/rewind_ogr.c:71 ../lib/vector/Vlib/open_ogr.c:121
+#: ../lib/vector/Vlib/open_ogr.c:154 ../lib/vector/Vlib/open_ogr.c:231
+#: ../lib/vector/Vlib/read_ogr.c:56 ../lib/vector/Vlib/read_ogr.c:157
+#: ../lib/vector/Vlib/read_ogr.c:242 ../lib/vector/Vlib/field.c:660
+msgid "GRASS is not compiled with OGR support"
+msgstr "GRASS nav kompilēts ar OGR atbalstu"
-#: ../lib/raster/close.c:439
-#, fuzzy, c-format
-msgid "Unable to rename cell file '%s' to '%s'"
+#: ../lib/proj/convert.c:120
+msgid "Unable parse GRASS PROJ_INFO file"
+msgstr "Nebija iespējams parsēt GRASS PROJ_INFO failu"
-#: ../lib/raster/close.c:474
-msgid "unable to write f_format file for CELL maps"
+#: ../lib/proj/convert.c:125
+msgid "Unable get PROJ.4-style parameter string"
 msgstr ""
-#: ../lib/raster/auto_mask.c:69
-msgid "Unable to open automatic MASK file"
-msgstr "Neiespējami atvērt automātisku MASK failu"
-#: ../lib/raster/interp.c:211
-#, fuzzy, c-format
-msgid "Unknown interpolation method: %s"
-msgstr "nezināns interpolācijas tips"
-#: ../lib/raster/gdal.c:88
-#, fuzzy, c-format
-msgid "Unable to locate symbol <%s>"
-#: ../lib/raster/gdal.c:140
-#, fuzzy
-msgid "Unable to load GDAL library"
-msgstr "Nevar atvērt topo failu rakstīšanai: %s\n"
-#: ../lib/raster/gdal.c:370
-#, fuzzy
-msgid "Unable to open GDAL file"
-#: ../lib/raster/gdal.c:474 ../lib/raster/open.c:569
-#, fuzzy, c-format
-msgid "Invalid map type <%d>"
-#: ../lib/raster/gdal.c:480
-#, fuzzy, c-format
-msgid "Unable to get <%s> driver"
-msgstr "Neisespējami atvērt %s"
-#: ../lib/raster/gdal.c:489
-#, fuzzy, c-format
-msgid "Unable to create <%s> dataset using <%s> driver"
-#: ../lib/raster/gdal.c:497
+#: ../lib/proj/convert.c:139
 #, c-format
-msgid ""
-"Driver <%s> does not support direct writing. Using MEM driver for "
-"intermediate dataset."
+msgid "OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
 msgstr ""
-#: ../lib/raster/gdal.c:503
-#, fuzzy
-msgid "Unable to get in-memory raster driver"
-msgstr "neiespējami rakstīt quant failu!"
-#: ../lib/raster/gdal.c:510
-#, fuzzy, c-format
-msgid "Unable to create <%s> dataset using memory driver"
-msgstr "Nevar atvērt datubāzi %s"
-#: ../lib/raster/gdal.c:514
+#: ../lib/proj/convert.c:146
 #, c-format
-msgid "Driver <%s> does not support creating rasters"
+msgid "OGR can't get WKT-style parameter string (OGR Error code was %d)"
 msgstr ""
-#: ../lib/raster/gdal.c:530
-#, fuzzy
-msgid "Unable to set geo transform"
+#: ../lib/proj/convert.c:406
+msgid "No projection name! Projection parameters likely to be meaningless."
+msgstr ""
-#: ../lib/raster/gdal.c:534
-#, fuzzy
-msgid "Unable to set projection"
+#: ../lib/proj/convert.c:442
+#, c-format
+msgid "Datum <%s> not recognised by GRASS and no parameters found"
+msgstr "Datums <%s> nav atpazīts un parametri nav atrasti"
-#: ../lib/raster/gdal.c:538
-#, fuzzy, c-format
-msgid "Unable to create cell_misc/%s/gdal file"
-msgstr "Nevar atvērt 'temp'/pagaidu failu"
-#: ../lib/raster/gdal.c:554
-#, fuzzy, c-format
-msgid "Error writing cell_misc/%s/gdal file"
-msgstr "Kļūdu rakstīšana ārpus telpisko datu index faila.\n"
-#: ../lib/raster/gdal.c:602
-#, fuzzy, c-format
-msgid "Unable to create output file <%s> using driver <%s>"
-#: ../lib/raster/window.c:18
+#: ../lib/proj/convert.c:458
+#, c-format
 msgid ""
-"Internal error: Rast_get_window() called with split window. Use "
-"Rast_get_input_window() or Rast_get_output_window() instead."
+"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
+"want to look into this."
 msgstr ""
-#: ../lib/raster/window.c:77
+#: ../lib/proj/convert.c:462
+#, c-format
 msgid ""
-"Internal error: Rast_window_rows() called with split window. Use "
-"Rast_input_window_rows() or Rast_output_window_rows() instead."
+"Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
+"transform parameters unspecified."
 msgstr ""
-#: ../lib/raster/window.c:112
-msgid ""
-"Internal error: Rast_window_cols() called with split window. Use "
-"Rast_input_window_cols() or Rast_output_window_cols() instead."
-msgstr ""
+#: ../lib/proj/ellipse.c:76
+#, c-format
+msgid "Invalid ellipsoid <%s> in file"
+msgstr "Nederīgs elipsoīds failā <%s>"
-#: ../lib/raster/color_rules.c:125
-msgid "syntax error"
+#: ../lib/proj/ellipse.c:103
+msgid "No secondary ellipsoid descriptor (rf, es or b) in file"
 msgstr ""
-#: ../lib/raster/color_rules.c:127
-msgid "R/G/B not in range 0-255"
+#: ../lib/proj/ellipse.c:107
+msgid "Invalid ellipsoid descriptors (a, rf, es or b) in file"
 msgstr ""
-#: ../lib/raster/color_rules.c:129
-#, fuzzy
-msgid "invalid color name"
-msgstr "Nederīgas koordinātes"
+#: ../lib/proj/ellipse.c:120
+msgid "No ellipsoid info given in file"
+msgstr "Failā nav sniegta elipsoīda informācija"
-#: ../lib/raster/color_rules.c:131
-msgid "percentage not in range 0-100"
-msgstr ""
+#: ../lib/proj/ellipse.c:220 ../lib/gis/get_ellipse.c:263
+#, c-format
+msgid "Unable to open ellipsoid table file <%s>"
+msgstr "Nav iespējams atvērt elipsoīda tabulas failu <%s>"
-#: ../lib/raster/color_rules.c:133
-#, fuzzy
-msgid "invalid value"
-msgstr ""
-"\n"
-"nederīgs datums\n"
-#: ../lib/raster/color_rules.c:135
-#, fuzzy
-msgid "unknown error"
-#: ../lib/raster/color_rules.c:181
+#: ../lib/proj/do_proj.c:106 ../lib/proj/do_proj.c:180
 #, c-format
-msgid "bad rule (%s): [%s]"
+msgid "pj_transform() failed: %s"
 msgstr ""
-#: ../lib/raster/color_rules.c:328
-#, fuzzy, c-format
-msgid "Unable to load color rules <%s>"
-#: ../lib/raster/set_window.c:48
-msgid "Rast_set_window() called while window split"
+#: ../lib/arraystats/class.c:21
+msgid "Discont algorithm currently not available because of bugs"
 msgstr ""
-#: ../lib/raster/set_window.c:131
-#, fuzzy
-msgid ""
-"Rast_set_read_window(): projection/zone differs from that of currently open "
-"raster maps"
-msgstr ""
-"G_set_window(): projekcija/zona atšķiras no tās kas ir tekoši atverajamajiem "
-"rastra failiem"
-#: ../lib/raster/set_window.c:158
+#: ../lib/arraystats/class.c:23
 #, c-format
-msgid "Input window changed while maps are open for read. Map name <%s>"
+msgid "%s: Unknown algorithm"
 msgstr ""
-#: ../lib/raster/set_window.c:174
+#: ../lib/arraystats/class.c:26
 #, c-format
-msgid "Output window changed while maps are open for write. Map name <%s>"
+msgid "%s: Error in classification algorithm"
 msgstr ""
-#: ../lib/raster/color_write.c:81 ../lib/vector/Vlib/color_write.c:71
+#: ../lib/arraystats/class.c:221
 #, c-format
-msgid "Qualified name <%s> doesn't match mapset <%s>"
+msgid ""
+"There are classbreaks outside the range min-max. Number of classes reduced "
+"to %i, but using probabilities for %i classes."
 msgstr ""
-#: ../lib/raster/color_write.c:96 ../lib/vector/Vlib/color_write.c:91
+#: ../lib/manage/option.c:47
 #, fuzzy, c-format
-msgid "Unable to create <%s> file for map <%s>"
+msgid "%s to be %s"
+msgstr "%s izpildīts. %s"
-#: ../lib/raster/reclass.c:168
-#, fuzzy, c-format
-msgid "Too many reclass categories for <%s@%s>"
+#: ../lib/manage/option.c:51
+msgid "Raster"
+msgstr "Rastrs"
-#: ../lib/raster/reclass.c:171
-#, fuzzy, c-format
-msgid "Illegal reclass format in header file for <%s@%s>"
+#: ../lib/manage/option.c:55
+msgid "Vector"
+msgstr "Vektors"
-#: ../lib/raster/reclass.c:273
-msgid "Illegal reclass request"
-msgstr "Netļauts pārklasificēšanas pieprasījums"
+#: ../lib/manage/option.c:57
+msgid "Region"
+msgstr "Reģions"
-#: ../lib/raster/reclass.c:278
-msgid "Illegal reclass type"
-msgstr "Netļauts klases tips"
+#: ../lib/manage/option.c:59
+msgid "Group"
+msgstr "Grupa"
-#: ../lib/raster/reclass.c:284
+#: ../lib/manage/do_list.c:30
 #, fuzzy, c-format
-msgid "Unable to create header file for <%s@%s>"
+msgid "%s: invalid index %d"
+msgstr ""
+"\n"
+"%s nederīgs; Meiģini vēlreiz > "
-#: ../lib/raster/reclass.c:332
+#: ../lib/manage/read_list.c:73
 #, fuzzy, c-format
-msgid "Unable to create dependency file in <%s@%s>"
-msgstr "Niespējami izveidot atkarību failu [%s iekš %s]"
+msgid "Unable to open data base element list '%s'"
+msgstr "neispējami atvērt datumu tabulas failu: %s"
-#: ../lib/raster/get_row.c:36 ../lib/raster/get_row.c:838
+#: ../lib/manage/read_list.c:134
+#, c-format
+msgid "Format error: file ('%s') line (%d) - %s"
+msgstr ""
+#: ../lib/manage/do_rename.c:42
 #, fuzzy, c-format
-msgid "Reading raster map <%s@%s> request for row %d is outside region"
-msgstr "[%s iekš %s] -nolasīšanas atbilde rindai %d ir ārpus reģiona "
+msgid "Rename %s <%s> to <%s>"
+msgstr "Nevar atvērt datubāzi %s"
-#: ../lib/raster/get_row.c:95 ../lib/raster/get_row.c:100
-#: ../lib/raster/get_row.c:133 ../lib/raster/get_row.c:139
-#: ../lib/raster/get_row.c:173 ../lib/raster/get_row.c:176
-#, fuzzy
-msgid "Error reading raster data"
-msgstr "eksistējošām rastra kartēm %d"
+#: ../lib/manage/do_rename.c:54 ../lib/manage/do_remove.c:57
+#: ../lib/vector/Vlib/legal_vname.c:121 ../lib/vector/Vlib/legal_vname.c:124
+#: ../lib/vector/Vlib/map.c:269 ../lib/vector/Vlib/open.c:235
+#: ../lib/ogsf/Gp3.c:56 ../lib/ogsf/Gp3.c:189 ../lib/ogsf/Gv3.c:60
+#: ../lib/ogsf/Gv3.c:326
+#, c-format
+msgid "Vector map <%s> not found"
+msgstr "Vektorkarte <%s> nav atrasta"
-#: ../lib/raster/get_row.c:211
-#, fuzzy
-msgid "Error reading raster data via GDAL"
-#: ../lib/raster/get_row.c:822 ../lib/raster/get_row.c:825
+#: ../lib/manage/do_rename.c:62
 #, fuzzy, c-format
-msgid "Error reading null row %d"
-msgstr "kļūda lasot null row %d"
+msgid "Unable to rename vector map <%s> to <%s>"
-#: ../lib/raster/open.c:190
-#, fuzzy, c-format
-msgid ""
-"Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@"
-"%s> which does not exist"
-msgstr ""
-"neiespējami atvērt [%s] iekš [%s] kopš tas ir pārklasificēts  [%s] iekš [%s] "
-"kas neeksistē"
+#: ../lib/manage/do_rename.c:71 ../lib/manage/do_remove.c:73
+#: ../lib/rst/interp_float/resout2d.c:205
+#: ../lib/rst/interp_float/resout2d.c:253
+#: ../lib/rst/interp_float/resout2d.c:296
+#: ../lib/rst/interp_float/resout2d.c:327
+#: ../lib/rst/interp_float/resout2d.c:377
+#: ../lib/rst/interp_float/resout2d.c:395
+#: ../lib/rst/interp_float/resout2d.c:410
+#: ../lib/rst/interp_float/resout2d.c:426
+#: ../lib/rst/interp_float/output2d.c:236
+#: ../lib/rst/interp_float/output2d.c:317
+#: ../lib/rst/interp_float/output2d.c:386
+#: ../lib/rst/interp_float/output2d.c:436
+#: ../lib/rst/interp_float/output2d.c:450
+#: ../lib/rst/interp_float/output2d.c:464
+#: ../lib/rst/interp_float/output2d.c:480 ../lib/raster/open.c:175
+#: ../lib/raster/open.c:744 ../lib/raster/open.c:781 ../lib/raster/open.c:833
+#: ../lib/gis/legal_name.c:94 ../lib/gis/legal_name.c:97
+#: ../lib/ogsf/gsd_legend.c:239 ../lib/ogsf/Gs3.c:125 ../lib/ogsf/Gs3.c:189
+#: ../lib/ogsf/Gs3.c:264 ../lib/ogsf/Gs3.c:336 ../lib/ogsf/Gs3.c:442
+#: ../lib/ogsf/Gs3.c:529 ../lib/ogsf/Gs3.c:588 ../lib/ogsf/Gs3.c:645
+#: ../lib/ogsf/Gs3.c:716 ../lib/ogsf/Gs3.c:786
+#, c-format
+msgid "Raster map <%s> not found"
+msgstr "Rastra karte <%s> nav atrasta"
-#: ../lib/raster/open.c:195
-#, fuzzy, c-format
-msgid "Error reading reclass file for raster map <%s>"
+#: ../lib/manage/do_rename.c:76 ../lib/manage/do_remove.c:78
+#: ../lib/gpde/N_arrays_io.c:273 ../lib/ogsf/Gvl3.c:40
+#: ../lib/ogsf/gvl_file.c:427
+#, c-format
+msgid "3D raster map <%s> not found"
+msgstr "3D rastra karte <%s> nav atrasta"
-#: ../lib/raster/open.c:206
+#: ../lib/manage/do_rename.c:83 ../lib/manage/do_rename.c:103
 #, fuzzy, c-format
-msgid "Error reading map type for raster map <%s>"
+msgid "Unable to rename %s"
-#: ../lib/raster/open.c:214
-#, fuzzy, c-format
-msgid "Raster map <%s@%s>: format field in header file invalid"
+#: ../lib/manage/do_rename.c:87 ../lib/manage/do_rename.c:107
+#: ../lib/manage/do_copy.c:63 ../lib/manage/do_remove.c:89
+#: ../lib/manage/do_remove.c:109
+#, c-format
+msgid "%s is missing"
 msgstr ""
-"[%s] karšu biblotēkā [%s]-formāta lauks faila galvā (header) ir nederīgs"
-#: ../lib/raster/open.c:219
-#, fuzzy, c-format
-msgid ""
-"Raster map <%s> is in different projection than current region. Found <%s>, "
-"should be <%s>."
-msgstr "Defekts: atteikts papildināt karti,kura nav tekošajā karšu komplektā."
-#: ../lib/raster/open.c:226
-#, fuzzy, c-format
-msgid "Raster map <%s> is in different zone (%d) than current region (%d)"
-#: ../lib/raster/open.c:231
+#: ../lib/manage/do_rename.c:90 ../lib/manage/do_rename.c:110
 #, c-format
-msgid "Raster map <%s>: bytes per cell (%d) too large"
+msgid "%s renamed"
 msgstr ""
-#: ../lib/raster/open.c:256
+#: ../lib/manage/do_rename.c:119
 #, c-format
-msgid ""
-"Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
+msgid "<%s> nothing renamed"
 msgstr ""
-#: ../lib/raster/open.c:264
+#: ../lib/manage/do_copy.c:43
 #, fuzzy, c-format
-msgid "Unable to open %s file for raster map <%s@%s>"
+msgid "Copy %s <%s> to current mapset as <%s>"
+msgstr "nav %s faili pieejami pašreizējā karšu biblotēkā\n"
-#: ../lib/raster/open.c:301
+#: ../lib/manage/do_copy.c:52
 #, fuzzy, c-format
-msgid "Error reading format for <%s@%s>"
-msgstr "kļūda nolasot %smap [%s] karšu biblotēkā [%s], līnija %d"
+msgid "Unable to copy <%s> to current mapset as <%s>"
-#: ../lib/raster/open.c:498
-#, fuzzy
-msgid "Unable to create GDAL link"
+#: ../lib/manage/do_copy.c:72
+#, c-format
+msgid "%s copied"
+msgstr ""
-#: ../lib/raster/open.c:574
+#: ../lib/manage/do_remove.c:42
 #, fuzzy, c-format
-msgid "Raster map <%s> is not in the current mapset (%s)"
+msgid "Removing %s <%s>"
+msgstr "neiespējami atrast [%s]"
-#: ../lib/raster/open.c:581
-#, fuzzy, c-format
-msgid "<%s> is an illegal file name"
-msgstr "%s - ** neatļauts vārds/nosaukums **"
-#: ../lib/raster/open.c:595
+#: ../lib/manage/do_remove.c:65
 #, fuzzy
-msgid "No temp files available"
-msgstr "Krāsu fails priekš [%s] nav pieejams"
+msgid "Unable to delete vector map"
+msgstr "neispējami mainīt direktoriju uz %s"
-#: ../lib/raster/open.c:667
-#, fuzzy
-msgid "no temp files available"
-msgstr "nav %s faili pieejami karšu biblotēkā %s\n"
+#: ../lib/manage/do_remove.c:85
+#, fuzzy, c-format
+msgid "Unable to remove %s element"
-#: ../lib/raster/open.c:720
-msgid "Rast_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
+#: ../lib/manage/do_remove.c:92 ../lib/manage/do_remove.c:112
+#, c-format
+msgid "%s removed"
 msgstr ""
-#: ../lib/raster/open.c:778
+#: ../lib/manage/do_remove.c:105
 #, fuzzy, c-format
-msgid "Raster map <%s> not found in mapset <%s>"
-msgstr "Ieejas vektors '%s' nav atrasts"
+msgid "Unable to remove %s"
-#: ../lib/raster/open.c:839
-#, fuzzy, c-format
-msgid "Unable to find '%s'"
+#: ../lib/manage/do_remove.c:121
+#, c-format
+msgid "<%s> nothing removed"
+msgstr ""
-#: ../lib/raster/open.c:850
-#, fuzzy, c-format
-msgid "Invalid type: field '%s' in file '%s'"
-msgstr "nederīgs tips: lauks %s failā %s"
+#: ../lib/nviz/position.c:56
+msgid "Unable to set focus"
+msgstr ""
-#: ../lib/raster/open.c:855
-#, fuzzy, c-format
-msgid "Missing type: field in file '%s'"
+#: ../lib/nviz/map_obj.c:59
+msgid "Maximum surfaces loaded!"
+msgstr ""
-#: ../lib/raster/open.c:860
-#, fuzzy, c-format
-msgid "Raster map <%s> is not xdr: byte_order: %s"
+#: ../lib/nviz/map_obj.c:88
+msgid "Maximum vector line maps loaded!"
+msgstr ""
-#: ../lib/raster/open.c:929
-msgid ""
-"Rast_set_quant_rules() can be called only for raster maps opened for reading"
+#: ../lib/nviz/map_obj.c:97 ../lib/nviz/map_obj.c:128
+#, c-format
+msgid "Error loading vector map <%s>"
 msgstr ""
-#: ../lib/raster/null_val.c:64
-#, fuzzy
-msgid "EmbedGivenNulls: wrong data type"
-msgstr "EmbedGivenNulls: nepareizs datu tips!"
+#: ../lib/nviz/map_obj.c:116
+msgid "Maximum vector point maps loaded!"
+msgstr ""
-#: ../lib/raster/null_val.c:114
-#, fuzzy
-msgid "Rast_set_null_value: wrong data type!"
-msgstr "G_set_null_value: nepareizs datu tips!"
+#: ../lib/nviz/map_obj.c:143
+msgid "Maximum volumes loaded!"
+msgstr ""
-#: ../lib/raster/put_row.c:120
-#, fuzzy, c-format
-msgid "Error writing uncompressed FP data for row %d of <%s>"
+#: ../lib/nviz/map_obj.c:152
+#, c-format
+msgid "Error loading 3d raster map <%s>"
+msgstr ""
-#: ../lib/raster/put_row.c:130
-#, fuzzy, c-format
-msgid "Error writing compressed FP data for row %d of <%s>"
+#: ../lib/nviz/map_obj.c:160
+msgid "Nviz_new_map_obj(): unsupported data type"
+msgstr ""
-#: ../lib/raster/put_row.c:389 ../lib/raster/put_row.c:395
-#, fuzzy, c-format
-msgid "Error writing compressed data for row %d of <%s>"
+#: ../lib/nviz/lights.c:171
+msgid "Unable to define new light"
+msgstr ""
-#: ../lib/raster/put_row.c:405
-#, fuzzy, c-format
-msgid "Error writing uncompressed data for row %d of <%s>"
+#: ../lib/nviz/nviz.c:128
+#, c-format
+msgid "Invalid color (%s), using \"white\" as default"
+msgstr ""
-#: ../lib/raster/put_row.c:464
-#, fuzzy, c-format
-msgid "Error writing data via GDAL for row %d of <%s>"
+#: ../lib/nviz/render.c:106
+msgid "Bad server connection"
+msgstr ""
-#: ../lib/raster/put_row.c:488
-#, fuzzy, c-format
-msgid "No null file for <%s>"
+#: ../lib/nviz/render.c:112
+#, fuzzy
+msgid "Unable to get visual info"
+msgstr "Neiespējami atvērt failu %s iekš %s"
-#: ../lib/raster/put_row.c:502
-msgid "GDAL output doesn't support writing null rows separately"
+#: ../lib/nviz/render.c:119
+msgid "Unable to create rendering context"
 msgstr ""
-#: ../lib/raster/put_row.c:522
-#, fuzzy, c-format
-msgid "Unable to find a temporary null file <%s>"
-msgstr "neispējami atrast pagaidu null failu: %s"
+#: ../lib/sites/sites.c:106
+#, c-format
+msgid "Attributes for category %d not found"
+msgstr "Kategorijai %d atribūti nav atrasti"
-#: ../lib/raster/put_row.c:527
-#, fuzzy, c-format
-msgid "Unable to open null file <%s>"
-msgstr "G_spawn: neispējami atvērt failu %s"
+#: ../lib/sites/sites.c:151
+msgid "Category must be integer"
+msgstr "Kategorijai ir jābūt veselam skaitlim"
-#: ../lib/raster/put_row.c:554 ../lib/raster/put_row.c:557
-#, fuzzy, c-format
-msgid "Error writing null row %d"
-msgstr "Kļūdas rakstīšana null row %d"
+#: ../lib/sites/sites.c:226
+msgid "Memory error in writing timestamp"
+msgstr "Laika zīmoga rakstīšanas atmiņas kļūda"
-#: ../lib/raster/put_row.c:682
-#, fuzzy, c-format
-msgid "put_raster_row: raster map <%s> not open for write - request ignored"
+#: ../lib/sites/sites.c:228
+msgid "Illegal TimeStamp string"
+msgstr "Nederīgs laika zīmoga teksts"
-#: ../lib/raster/put_row.c:689
-#, fuzzy
-msgid "put_raster_row: unopened file descriptor - request ignored"
+#: ../lib/sites/sites.c:255 ../lib/sites/sites.c:385
+msgid ""
+"Dev note: Adapted sites library used for vector points. (module should be "
+"updated to GRASS 6 vector library)"
+msgstr ""
-#: ../lib/raster/quant_rw.c:88
-#, fuzzy, c-format
-msgid "Unable to read fp range for raster map <%s>"
+#: ../lib/sites/sites.c:279 ../lib/rst/interp_float/vinput2d.c:88
+#: ../lib/vector/Vlib/net.c:181 ../lib/vector/Vlib/net.c:358
+#: ../lib/vector/Vlib/array.c:282 ../lib/vector/Vlib/copy.c:628
+#: ../lib/vector/Vlib/write_pg.c:2893 ../lib/vector/Vlib/map.c:206
+#: ../lib/vector/Vlib/map.c:346 ../lib/vector/Vlib/cats.c:597
+#: ../lib/vector/Vlib/ascii.c:410 ../lib/vector/Vlib/write_ogr.c:197
+#: ../lib/vector/neta/timetables.c:133 ../lib/vector/neta/utils.c:119
+#: ../lib/db/dbmi_client/db.c:46 ../lib/db/dbmi_client/copy_tab.c:112
+#: ../lib/db/dbmi_client/copy_tab.c:133 ../lib/ogsf/Gp3.c:206
+#: ../lib/ogsf/Gv3.c:343
+#, c-format
+msgid "Unable to open database <%s> by driver <%s>"
+msgstr "Nav iespējams atvērt datu bāzi <%s> izmantojot <%s> dzinēju"
-#: ../lib/raster/quant_rw.c:92
-#, fuzzy, c-format
-msgid "Raster map <%s> is empty"
-msgstr " Rastra karte %s@%s ir tukša"
+#: ../lib/sites/sites.c:288 ../lib/vector/Vlib/write_ogr.c:210
+#: ../lib/db/dbmi_client/copy_tab.c:218 ../lib/db/dbmi_client/copy_tab.c:295
+#: ../lib/db/dbmi_client/table.c:110
+#, c-format
+msgid "Unable to open select cursor: '%s'"
+msgstr ""
-#: ../lib/raster/quant_rw.c:157
-#, fuzzy, c-format
-msgid "Unable to write quant rules: raster map <%s> is integer"
+#: ../lib/sites/sites.c:304
+msgid "Cannot fetch row"
+msgstr "Nevar saņemt rindu"
-#: ../lib/raster/quant_rw.c:166
-#, fuzzy, c-format
-msgid "Unable to write quant rules for raster map <%s>"
+#: ../lib/sites/sites.c:440
+msgid "G_oldsite_new_struct: invalid # dims or fields"
+msgstr ""
-#: ../lib/raster/cats.c:109
-#, fuzzy, c-format
-msgid "Category support for <%s@%s> missing"
-msgstr "kategoriju atbalsts priekš [%s] karšu biblotēkā [%s] %s"
+#: ../lib/sites/sites.c:668
+msgid "G_oldsite_describe() must be called immediately after G_fopen_sites_old()."
+msgstr ""
-#: ../lib/raster/cats.c:112
+#: ../lib/lidar/zones.c:473 ../lib/lidar/zones.c:510
 #, fuzzy, c-format
-msgid "Category support for <%s@%s> invalid"
+msgid "<%s> created in database."
+msgstr "neiespējami atvērt elipsoīda tabulas failu: %s"
-#: ../lib/raster/cats.c:145
-#, fuzzy, c-format
-msgid "Category support for vector map <%s@%s> missing"
-msgstr "kategoriju atbalsts vektoru failam [%s] karšu biblotēkā [%s] %s"
+#: ../lib/lidar/zones.c:477 ../lib/lidar/zones.c:514
+#, c-format
+msgid "<%s> has not been created in database."
+msgstr ""
-#: ../lib/raster/cats.c:149
+#: ../lib/lidar/raster.c:74 ../lib/lidar/raster.c:89 ../lib/lidar/raster.c:102
+#: ../lib/lidar/raster.c:119 ../lib/lidar/raster.c:134
+#: ../lib/lidar/raster.c:147 ../lib/lidar/raster.c:162
+#: ../lib/lidar/raster.c:175
 #, fuzzy, c-format
-msgid "Category support for vector map <%s@%s> invalid"
+msgid "Unable to access table <%s>"
-#: ../lib/raster/cats.c:968
-#, fuzzy, c-format
-msgid "Unable to open %s file for map <%s>"
+#: ../lib/segment/open.c:53
+msgid "Segment file name is NULL"
+msgstr ""
-#: ../lib/raster/sample.c:70
-#, fuzzy
-msgid "Unknown interpolation type"
-#: ../lib/raster/sample.c:327
-msgid "\"no data\" label found; setting to zero"
+#: ../lib/segment/open.c:58
+msgid "Segment file exists already"
 msgstr ""
-#: ../lib/raster/format.c:154
-#, c-format
-msgid "Fail of initial read of compressed file [%s in %s]"
-msgstr "Izgāzusies arhivētā faila lasīšanas inicializācija [%s iekš %s]"
+#: ../lib/segment/open.c:66
+#, fuzzy
+msgid "Unable to create segment file"
+msgstr "Nevar atvērt 'temp'/pagaidu failu"
-#: ../lib/raster/mask_info.c:43
-#, c-format
-msgid "<%s> in mapset <%s>"
-msgstr "<%s>karšu kopā <%s>"
+#: ../lib/segment/open.c:74
+#, fuzzy
+msgid "Could not write segment file"
+msgstr "neiespējami rakstīt quant failu!"
-#: ../lib/raster/mask_info.c:46
-msgid "none"
-msgstr "neviens"
+#: ../lib/segment/open.c:78
+msgid "Illegal segment configuration parameter(s)"
+msgstr ""
-#: ../lib/raster/mask_info.c:49
-msgid "not known"
-msgstr "nav zināms"
+#: ../lib/segment/open.c:86
+#, fuzzy
+msgid "Unable to re-open segment file"
-#: ../lib/raster/raster_metadata.c:109
-#, fuzzy, c-format
-msgid "Unable to read <%s> for raster map <%s@%s>"
+#: ../lib/segment/open.c:93
+#, fuzzy
+msgid "Could not read segment file"
+msgstr "Nevar palaist failu '%s'"
-#: ../lib/raster/raster_metadata.c:119 ../lib/raster/raster_metadata.c:148
-#, fuzzy, c-format
-msgid "Error closing <%s> metadata file for raster map <%s@%s>"
+#: ../lib/segment/format.c:143
+msgid "Segment format: file size too large"
+msgstr ""
-#: ../lib/raster/raster_metadata.c:142
-#, fuzzy, c-format
-msgid "Unable to create <%s> metadata file for raster map <%s@%s>"
+#: ../lib/segment/format.c:144
+msgid "Please recompile with Large File Support (LFS)"
+msgstr ""
-#: ../lib/raster/put_cellhd.c:34
-#, fuzzy, c-format
-msgid "Unable to create header file for <%s>"
+#: ../lib/gpde/N_parse_options.c:106
+msgid "The calculation time in seconds"
+msgstr ""
-#: ../lib/raster/quant_io.c:43
-#, fuzzy, c-format
-msgid "Floating data range for raster map <%s> is empty"
-msgstr "'Peldošo' datu dipazons priekš %s@%s ir tukšs"
+#: ../lib/gpde/test/test_main.c:88
+msgid "Performs unit and integration tests for gpde library"
+msgstr ""
-#: ../lib/raster/quant_io.c:52
+#: ../lib/gpde/N_arrays_io.c:93
 #, fuzzy, c-format
-msgid "Integer data range for raster map <%s> is empty"
-msgstr "Veselo skaitļu datu diapazons priekš %s@%s ir tukšs"
+msgid "Reading raster map <%s> into memory"
+msgstr " Rastra karte %s@%s ir tukša"
-#: ../lib/raster/quant_io.c:105
-#, fuzzy, c-format
-msgid "Attempt to open quantization table for CELL raster map <%s>"
+#: ../lib/gpde/N_arrays_io.c:183
+msgid "N_array_2d * array is empty"
+msgstr ""
-#: ../lib/raster/quant_io.c:135
-#, fuzzy, c-format
-msgid "Quantization file for raster map <%s> is missing"
+#: ../lib/gpde/N_arrays_io.c:202
+#, c-format
+msgid "Write 2d array to raster map <%s>"
+msgstr ""
-#: ../lib/raster/quant_io.c:145
-#, fuzzy, c-format
-msgid "Quantization file for raster map <%s> is empty"
+#: ../lib/gpde/N_arrays_io.c:309
+#, c-format
+msgid "Read g3d map <%s> into the memory"
+msgstr ""
-#: ../lib/raster/get_cellhd.c:66
-#, fuzzy, c-format
-msgid ""
-"Unable to read header file for raster map <%s@%s>.It is a reclass of raster "
-"map <%s@%s> %s"
+#: ../lib/gpde/N_arrays_io.c:364 ../lib/gpde/N_arrays_io.c:464
+msgid "Error closing g3d file"
 msgstr ""
-"kas neeksistē"
-#: ../lib/raster/get_cellhd.c:70
-#, fuzzy
-msgid "which is missing."
-#: ../lib/raster/get_cellhd.c:71
-msgid "whose header file can't be opened."
+#: ../lib/gpde/N_arrays_io.c:420
+#, c-format
+msgid "Error opening g3d map <%s>"
 msgstr ""
-#: ../lib/raster/get_cellhd.c:76
-#, fuzzy, c-format
-msgid "Unable to open header file for raster map <%s@%s>"
-#: ../lib/raster/histogram.c:55
+#: ../lib/gpde/N_arrays_io.c:422
 #, c-format
-msgid "Histogram for [%s in %s] missing (run r.support)"
-msgstr "Histogramma preikš [%s iekš %s] pietrūkst (palaist r.support)"
+msgid "Write 3d array to g3d map <%s>"
+msgstr ""
-#: ../lib/raster/histogram.c:62
+#: ../lib/gpde/N_gwflow.c:436 ../lib/gpde/N_gwflow.c:715
 #, c-format
-msgid "Can't read histogram for [%s in %s]"
-msgstr "Nevar nolasīt histogrammu priekš [%s no %s]"
+msgid "The total sum of the water budget: %g\n"
+msgstr ""
-#: ../lib/raster/histogram.c:66 ../lib/raster/histogram.c:73
+#: ../lib/gpde/N_gwflow.c:438 ../lib/gpde/N_gwflow.c:717
 #, c-format
-msgid "Invalid histogram file for [%s in %s]"
+msgid "The total sum of the water budget is significant larger then 0: %g\n"
+msgstr ""
-#: ../lib/raster/histogram.c:331
-#, fuzzy, c-format
-msgid "Unable to create histogram file for <%s>"
-#: ../lib/raster/alloc_cell.c:151
+#: ../lib/driver/parse_ftcap.c:84
 #, c-format
-msgid "Rast__null_bitstream_size: cols (%d) is negative"
+msgid "%s: Unable to read font definition file; use the default"
 msgstr ""
-#: ../lib/imagery/iclass_perimeter.c:109
+#: ../lib/driver/parse_ftcap.c:90
 #, c-format
-msgid "Get area %d failed"
+msgid "%s: No font definition file"
 msgstr ""
-#: ../lib/imagery/iclass_perimeter.c:116
-msgid "Perimeter computation failed"
+#: ../lib/symbol/read.c:211
+#, c-format
+msgid "Cannot read symbol line coordinates: %s"
 msgstr ""
-#: ../lib/imagery/iclass_perimeter.c:196
-msgid "Absurd polygon."
+#: ../lib/symbol/read.c:260
+#, c-format
+msgid "Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
 msgstr ""
-#: ../lib/imagery/iclass_perimeter.c:241
-msgid "Outlined area is too large."
+#: ../lib/symbol/read.c:284
+#, c-format
+msgid "Cannot find/open symbol: '%s'"
+msgstr "Nevar atrast/atvērt simbolu: '%s'"
+#: ../lib/symbol/read.c:389 ../lib/symbol/read.c:407 ../lib/symbol/read.c:417
+#: ../lib/symbol/read.c:435
+#, c-format
+msgid "Incorrect symbol color: '%s', using default."
+msgstr "Nederīga simbola krāsa: '%s', tiek izmantota noklusējuma."
+#: ../lib/gmath/del2g.c:50
+msgid "    taking FFT of image..."
 msgstr ""
-#: ../lib/imagery/iclass_statistics.c:218
-msgid "prepare_signature: outline has odd number of points."
+#: ../lib/gmath/del2g.c:56
+msgid "    computing del**2 g..."
 msgstr ""
-#: ../lib/imagery/iclass_statistics.c:227 ../lib/imagery/iscatt_core.c:971
-#, c-format
-msgid "prepare_signature: scan line %d has odd number of points."
+#: ../lib/gmath/del2g.c:59
+msgid "    taking FFT of del**2 g..."
 msgstr ""
-#: ../lib/imagery/iclass_statistics.c:237 ../lib/imagery/iscatt_core.c:980
-msgid "signature: perimeter points out of order."
+#: ../lib/gmath/del2g.c:63
+msgid "    multiplying transforms..."
 msgstr ""
-#: ../lib/imagery/iclass_statistics.c:248
-#, c-format
-msgid "Data error preparing signatures: value (%d) > num of cats (%d)"
+#: ../lib/gmath/del2g.c:66
+msgid "    taking inverse FFT..."
 msgstr ""
-#: ../lib/imagery/iclass_statistics.c:561
-#: ../lib/imagery/iclass_statistics.c:584
-#: ../lib/imagery/iclass_statistics.c:607
-#: ../lib/imagery/iclass_statistics.c:630
-#: ../lib/imagery/iclass_statistics.c:653
-#: ../lib/imagery/iclass_statistics.c:680
-#: ../lib/imagery/iclass_statistics.c:712
-#: ../lib/imagery/iclass_statistics.c:735
-#: ../lib/imagery/iclass_statistics.c:758
+#: ../lib/gmath/test/test_matrix_conversion.c:37
 #, fuzzy
-msgid "Band index out of range"
-msgstr "Dubulto atribūtu indekss ārpus diapazona"
+msgid ""
+"\n"
+"++ Running matrix conversion unit tests ++"
+msgstr "nezināns interpolācijas tips"
-#: ../lib/imagery/iclass_statistics.c:684
+#: ../lib/gmath/test/test_matrix_conversion.c:42
 #, fuzzy
-msgid "Cell category value out of range"
+msgid ""
+"\n"
+"-- Matrix conversion unit tests failure --"
-#: ../lib/imagery/iclass_signatures.c:120
-#, fuzzy, c-format
-msgid "Unable to open output signature file '%s'"
-msgstr "neispējami atvērt datumu tabulas failu: %s"
+#: ../lib/gmath/test/test_matrix_conversion.c:44
+#, fuzzy
+msgid ""
+"\n"
+"-- Matrix conversion unit tests finished successfully --"
-#: ../lib/imagery/list_gp.c:34
-#, c-format
-msgid "group <%s> is empty\n"
+#: ../lib/gmath/test/bench_blas2.c:35
+msgid ""
+"\n"
+"++ Running blas level 2 benchmark ++"
 msgstr ""
-#: ../lib/imagery/list_gp.c:44
-#, c-format
-msgid "group <%s> references the following raster maps\n"
-msgstr ""
+#: ../lib/gmath/test/test_ccmath_wrapper.c:37
+#, fuzzy
+msgid ""
+"\n"
+"++ Running ccmath wrapper unit tests ++"
-#: ../lib/imagery/sigsetfile.c:41
-#, fuzzy, c-format
+#: ../lib/gmath/test/test_ccmath_wrapper.c:42
+#, fuzzy
 msgid ""
-"Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> "
-"is not current mapset"
+"\n"
+"-- ccmath wrapper unit tests failure --"
-#: ../lib/imagery/sigsetfile.c:57
-#, fuzzy, c-format
-msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s>"
+#: ../lib/gmath/test/test_ccmath_wrapper.c:44
+#, fuzzy
+msgid ""
+"\n"
+"-- ccmath wrapper unit tests finished successfully --"
-#: ../lib/imagery/fopen.c:23
-#, fuzzy, c-format
-msgid "Unable to create file [%s] of group [%s in %s]"
+#: ../lib/gmath/test/test_main.c:47
+#: ../lib/vector/rtree/test_suite/test_main.c:45
+#: ../lib/db/dbmi_base/test/test_main.c:47
+msgid "Choose the unit tests to run"
+msgstr ""
-#: ../lib/imagery/fopen.c:36 ../lib/imagery/fopen.c:57
-#, fuzzy, c-format
-msgid "Unable to open file [%s] of group [%s in %s]"
+#: ../lib/gmath/test/test_main.c:54 ../lib/db/dbmi_base/test/test_main.c:54
+msgid "Choose the integration tests to run"
+msgstr ""
-#: ../lib/imagery/fopen.c:49
-#, fuzzy, c-format
-msgid "Unable to find file [%s] of group [%s in %s]"
-msgstr "neiespējami atrast [%s] iekš [%s]"
-#: ../lib/imagery/fopen.c:79
-#, c-format
-msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
+#: ../lib/gmath/test/test_main.c:61
+msgid "The size of the matrices and vectors for benchmarking"
 msgstr ""
-#: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
-#, fuzzy, c-format
-msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
-#: ../lib/imagery/fopen.c:116
-#, c-format
-msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
+#: ../lib/gmath/test/test_main.c:68
+msgid "Choose solver benchmark"
 msgstr ""
-#: ../lib/imagery/georef_tps.c:219
-msgid "Calculating forward transformation coefficients"
+#: ../lib/gmath/test/test_main.c:75
+msgid "Choose blas benchmark"
 msgstr ""
-#: ../lib/imagery/georef_tps.c:236
-msgid "Calculating backward transformation coefficients"
+#: ../lib/gmath/test/test_main.c:79
+#: ../lib/vector/rtree/test_suite/test_main.c:49
+#: ../lib/db/dbmi_base/test/test_main.c:58
+msgid "Run all unit tests"
 msgstr ""
-#: ../lib/imagery/georef_tps.c:279 ../lib/imagery/georef_tps.c:282
-#: ../lib/imagery/georef_tps.c:285 ../lib/imagery/georef_tps.c:290
-#: ../lib/imagery/georef_tps.c:293
-#, fuzzy, c-format
-msgid "%s: out of memory"
-msgstr "Neiespējami piešķirt atmiņu\n"
+#: ../lib/gmath/test/test_main.c:83 ../lib/db/dbmi_base/test/test_main.c:62
+#, fuzzy
+msgid "Run all integration tests"
-#: ../lib/imagery/iscatt_core.c:80
-#, fuzzy, c-format
-msgid "Unable to write header into category raster condition file <%s>."
+#: ../lib/gmath/test/test_main.c:87 ../lib/db/dbmi_base/test/test_main.c:66
+#, fuzzy
+msgid "Run all unit and integration tests"
-#: ../lib/imagery/iscatt_core.c:97
-#, fuzzy, c-format
-msgid "Unable to write into category raster condition file <%s>."
-#: ../lib/imagery/iscatt_core.c:254
-#, fuzzy, c-format
-msgid "Unable to open category raster condtions file <%s>."
-#: ../lib/imagery/iscatt_core.c:262
-#, fuzzy, c-format
-msgid "Unable to find patch raster <%s>."
-#: ../lib/imagery/iscatt_core.c:279
-#, c-format
-msgid "Resolutions of patch <%s> and patched file <%s> are not same."
+#: ../lib/gmath/test/test_main.c:106
+#: ../lib/vector/rtree/test_suite/test_main.c:67
+msgid "Performs benchmarks, unit and integration tests for the gmath library"
 msgstr ""
-#: ../lib/imagery/iscatt_core.c:306 ../lib/imagery/iscatt_core.c:348
-#, c-format
-msgid "Corrupted  category raster conditions file <%s> (fseek failed)"
+#: ../lib/gmath/test/bench_solver_krylov.c:34
+msgid ""
+"\n"
+"++ Running krylov solver benchmark ++"
 msgstr ""
-#: ../lib/imagery/iscatt_core.c:337
-#, fuzzy, c-format
-msgid "Unable to write into category raster conditions file <%s>"
+#: ../lib/gmath/test/test_blas3.c:38
+#, fuzzy
+msgid ""
+"\n"
+"++ Running blas level 3 unit tests ++"
-#: ../lib/imagery/iscatt_core.c:525
+#: ../lib/gmath/test/test_blas3.c:44
 #, fuzzy
-msgid "Unable to read from category raster condtition file."
+msgid ""
+"\n"
+"-- blas level 3 unit tests failure --"
-#: ../lib/imagery/iscatt_core.c:532
-msgid "Invalid size of category raster conditions file."
+#: ../lib/gmath/test/test_blas3.c:46
+msgid ""
+"\n"
+"-- blas level 3 unit tests finished successfully --"
 msgstr ""
-#: ../lib/imagery/iscatt_core.c:578
+#: ../lib/gmath/test/bench_solver_direct.c:34
 msgid ""
-"Data inconsistent. Value computed for scatter plot is out of initialized "
-"range."
+"\n"
+"++ Running direct solver benchmark ++"
 msgstr ""
-#: ../lib/imagery/iscatt_core.c:744
-#, fuzzy, c-format
-msgid "Unbale to read find raster <%s>"
+#: ../lib/gmath/test/test_blas1.c:40
+#, fuzzy
+msgid ""
+"\n"
+"++ Running blas level 1 unit tests ++"
-#: ../lib/imagery/iscatt_core.c:754
-#, fuzzy, c-format
-msgid "Unbale to open raster <%s>"
+#: ../lib/gmath/test/test_blas1.c:47
+#, fuzzy
+msgid ""
+"\n"
+"-- blas level 1 unit tests failure --"
-#: ../lib/imagery/iscatt_core.c:760
-#, fuzzy, c-format
-msgid "Raster <%s> type is not <%s>"
+#: ../lib/gmath/test/test_blas1.c:49
+msgid ""
+"\n"
+"-- blas level 1 unit tests finished successfully --"
+msgstr ""
-#: ../lib/imagery/iscatt_core.c:774
-#, fuzzy, c-format
-msgid "Unable to read range of raster <%s>"
+#: ../lib/gmath/test/test_blas2.c:38
+#, fuzzy
+msgid ""
+"\n"
+"++ Running blas level 2 unit tests ++"
-#: ../lib/imagery/iscatt_core.c:802
-#, fuzzy, c-format
-msgid "Unable to open category raster condtition file <%s>"
+#: ../lib/gmath/test/test_blas2.c:44
+#, fuzzy
+msgid ""
+"\n"
+"-- blas level 2 unit tests failure --"
-#: ../lib/imagery/iscatt_core.c:816
-msgid "Corrupted category raster conditions file (fseek failed)"
+#: ../lib/gmath/test/test_blas2.c:46
+msgid ""
+"\n"
+"-- blas level 2 unit tests finished successfully --"
 msgstr ""
-#: ../lib/imagery/iclass.c:83
-#, fuzzy, c-format
-msgid "No areas in category %d"
+#: ../lib/gmath/test/test_solvers.c:37
+msgid ""
+"\n"
+"++ Running solver unit tests ++"
+msgstr ""
-#: ../lib/imagery/iclass.c:127
-#, fuzzy, c-format
-msgid "Raster map <%s@%s> in subgroup <%s> does not exist"
-msgstr "Nevar atvērt vēsturi vektoram '%s'"
-#: ../lib/imagery/iclass.c:131
-#, fuzzy, c-format
-msgid "Raster map <%s@%s> in group <%s> does not exist"
-#: ../lib/imagery/iclass.c:143
-#, c-format
-msgid "Subgroup <%s> does not have enough files (it has %d files)"
+#: ../lib/gmath/test/test_solvers.c:42
+msgid ""
+"\n"
+"-- Solver unit tests failure --"
 msgstr ""
-#: ../lib/imagery/iclass.c:147
-#, c-format
-msgid "Group <%s> does not have enough files (it has %d files)"
+#: ../lib/gmath/test/test_solvers.c:44
+msgid ""
+"\n"
+"-- Solver unit tests finished successfully --"
 msgstr ""
-#: ../lib/imagery/list_subgp.c:72
-#, c-format
-msgid "subgroup <%s> of group <%s> is empty\n"
+#: ../lib/gmath/test/bench_blas3.c:34
+msgid ""
+"\n"
+"++ Running blas level 3 benchmark ++"
 msgstr ""
-#: ../lib/imagery/list_subgp.c:85
+#: ../lib/gmath/solvers_direct_cholesky_band.c:33
 #, c-format
-msgid "subgroup <%s> of group <%s> references the following raster maps\n"
+msgid "Decomposition failed at row %i and col %i"
 msgstr ""
-#: ../lib/imagery/target.c:38
-#, fuzzy, c-format
-msgid "Unable to read target file for group [%s]"
-#: ../lib/imagery/points.c:124
-#, fuzzy, c-format
-msgid "Unable to open control point file for group [%s in %s]"
-#: ../lib/imagery/points.c:132
-#, fuzzy, c-format
-msgid "Bad format in control point file for group [%s in %s]"
-#: ../lib/imagery/points.c:159
-#, fuzzy, c-format
-msgid "Unable to create control point file for group [%s in %s]"
 #: ../lib/gmath/la.c:60 ../lib/gmath/la.c:116
 #, fuzzy
 msgid "Matrix dimensions out of range"
@@ -2360,11 +2402,6 @@
 msgid "Input format error"
 msgstr ""
-#: ../lib/gmath/solvers_direct_cholesky_band.c:33
-#, c-format
-msgid "Decomposition failed at row %i and col %i"
-msgstr ""
 #: ../lib/gmath/solvers_classic_iter.c:84
 #, c-format
 msgid "sparse Jacobi -- iteration %5i error %g\n"
@@ -2385,213 +2422,6 @@
 msgid "SOR -- iteration %5i error %g\n"
 msgstr ""
-#: ../lib/gmath/del2g.c:50
-msgid "    taking FFT of image..."
-msgstr ""
-#: ../lib/gmath/del2g.c:56
-msgid "    computing del**2 g..."
-msgstr ""
-#: ../lib/gmath/del2g.c:59
-msgid "    taking FFT of del**2 g..."
-msgstr ""
-#: ../lib/gmath/del2g.c:63
-msgid "    multiplying transforms..."
-msgstr ""
-#: ../lib/gmath/del2g.c:66
-msgid "    taking inverse FFT..."
-msgstr ""
-#: ../lib/gmath/test/bench_blas2.c:35
-msgid ""
-"\n"
-"++ Running blas level 2 benchmark ++"
-msgstr ""
-#: ../lib/gmath/test/bench_blas3.c:34
-msgid ""
-"\n"
-"++ Running blas level 3 benchmark ++"
-msgstr ""
-#: ../lib/gmath/test/test_solvers.c:37
-msgid ""
-"\n"
-"++ Running solver unit tests ++"
-msgstr ""
-#: ../lib/gmath/test/test_solvers.c:42
-msgid ""
-"\n"
-"-- Solver unit tests failure --"
-msgstr ""
-#: ../lib/gmath/test/test_solvers.c:44
-msgid ""
-"\n"
-"-- Solver unit tests finished successfully --"
-msgstr ""
-#: ../lib/gmath/test/test_matrix_conversion.c:37
-#, fuzzy
-msgid ""
-"\n"
-"++ Running matrix conversion unit tests ++"
-#: ../lib/gmath/test/test_matrix_conversion.c:42
-#, fuzzy
-msgid ""
-"\n"
-"-- Matrix conversion unit tests failure --"
-#: ../lib/gmath/test/test_matrix_conversion.c:44
-#, fuzzy
-msgid ""
-"\n"
-"-- Matrix conversion unit tests finished successfully --"
-#: ../lib/gmath/test/bench_solver_direct.c:34
-msgid ""
-"\n"
-"++ Running direct solver benchmark ++"
-msgstr ""
-#: ../lib/gmath/test/test_blas1.c:40
-#, fuzzy
-msgid ""
-"\n"
-"++ Running blas level 1 unit tests ++"
-#: ../lib/gmath/test/test_blas1.c:47
-#, fuzzy
-msgid ""
-"\n"
-"-- blas level 1 unit tests failure --"
-#: ../lib/gmath/test/test_blas1.c:49
-msgid ""
-"\n"
-"-- blas level 1 unit tests finished successfully --"
-msgstr ""
-#: ../lib/gmath/test/test_main.c:47
-#: ../lib/vector/rtree/test_suite/test_main.c:45
-#: ../lib/db/dbmi_base/test/test_main.c:47
-msgid "Choose the unit tests to run"
-msgstr ""
-#: ../lib/gmath/test/test_main.c:54 ../lib/db/dbmi_base/test/test_main.c:54
-msgid "Choose the integration tests to run"
-msgstr ""
-#: ../lib/gmath/test/test_main.c:61
-msgid "The size of the matrices and vectors for benchmarking"
-msgstr ""
-#: ../lib/gmath/test/test_main.c:68
-msgid "Choose solver benchmark"
-msgstr ""
-#: ../lib/gmath/test/test_main.c:75
-msgid "Choose blas benchmark"
-msgstr ""
-#: ../lib/gmath/test/test_main.c:79
-#: ../lib/vector/rtree/test_suite/test_main.c:49
-#: ../lib/db/dbmi_base/test/test_main.c:58
-msgid "Run all unit tests"
-msgstr ""
-#: ../lib/gmath/test/test_main.c:83 ../lib/db/dbmi_base/test/test_main.c:62
-#, fuzzy
-msgid "Run all integration tests"
-#: ../lib/gmath/test/test_main.c:87 ../lib/db/dbmi_base/test/test_main.c:66
-#, fuzzy
-msgid "Run all unit and integration tests"
-#: ../lib/gmath/test/test_main.c:106
-#: ../lib/vector/rtree/test_suite/test_main.c:67
-msgid "Performs benchmarks, unit and integration tests for the gmath library"
-msgstr ""
-#: ../lib/gmath/test/test_ccmath_wrapper.c:37
-#, fuzzy
-msgid ""
-"\n"
-"++ Running ccmath wrapper unit tests ++"
-#: ../lib/gmath/test/test_ccmath_wrapper.c:42
-#, fuzzy
-msgid ""
-"\n"
-"-- ccmath wrapper unit tests failure --"
-#: ../lib/gmath/test/test_ccmath_wrapper.c:44
-#, fuzzy
-msgid ""
-"\n"
-"-- ccmath wrapper unit tests finished successfully --"
-#: ../lib/gmath/test/bench_solver_krylov.c:34
-msgid ""
-"\n"
-"++ Running krylov solver benchmark ++"
-msgstr ""
-#: ../lib/gmath/test/test_blas3.c:38
-#, fuzzy
-msgid ""
-"\n"
-"++ Running blas level 3 unit tests ++"
-#: ../lib/gmath/test/test_blas3.c:44
-#, fuzzy
-msgid ""
-"\n"
-"-- blas level 3 unit tests failure --"
-#: ../lib/gmath/test/test_blas3.c:46
-msgid ""
-"\n"
-"-- blas level 3 unit tests finished successfully --"
-msgstr ""
-#: ../lib/gmath/test/test_blas2.c:38
-#, fuzzy
-msgid ""
-"\n"
-"++ Running blas level 2 unit tests ++"
-#: ../lib/gmath/test/test_blas2.c:44
-#, fuzzy
-msgid ""
-"\n"
-"-- blas level 2 unit tests failure --"
-#: ../lib/gmath/test/test_blas2.c:46
-msgid ""
-"\n"
-"-- blas level 2 unit tests finished successfully --"
-msgstr ""
 #: ../lib/gmath/solvers_direct.c:45
 msgid "Starting direct gauss elimination solver"
 msgstr ""
@@ -2639,1601 +2469,1108 @@
 msgid "BiCGStab -- iteration %i error  %g\n"
 msgstr ""
-#: ../lib/lidar/zones.c:473 ../lib/lidar/zones.c:510
-#, fuzzy, c-format
-msgid "<%s> created in database."
-msgstr "neiespējami atvērt elipsoīda tabulas failu: %s"
-#: ../lib/lidar/zones.c:477 ../lib/lidar/zones.c:514
+#: ../lib/rst/interp_float/interp2d.c:214
 #, c-format
-msgid "<%s> has not been created in database."
+msgid ""
+"Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) "
+"cell. Z-value %f, zmin %f, zmax %f."
 msgstr ""
-#: ../lib/lidar/raster.c:74 ../lib/lidar/raster.c:89 ../lib/lidar/raster.c:102
-#: ../lib/lidar/raster.c:119 ../lib/lidar/raster.c:134
-#: ../lib/lidar/raster.c:147 ../lib/lidar/raster.c:162
-#: ../lib/lidar/raster.c:175
+#: ../lib/rst/interp_float/input2d.c:48
 #, fuzzy, c-format
-msgid "Unable to access table <%s>"
+msgid "Mask raster map <%s> not found"
+msgstr "Ieejas vektors '%s' nav atrasts"
-#: ../lib/segment/open.c:53
-msgid "Segment file name is NULL"
+#: ../lib/rst/interp_float/input2d.c:70
+msgid "Bitmap mask created"
 msgstr ""
-#: ../lib/segment/open.c:58
-msgid "Segment file exists already"
+#: ../lib/rst/interp_float/resout2d.c:77
+msgid "Temporarily changing the region to desired resolution..."
 msgstr ""
-#: ../lib/segment/open.c:66
-#, fuzzy
-msgid "Unable to create segment file"
+#: ../lib/rst/interp_float/resout2d.c:103
+#, c-format
+msgid "First change your rows number(%d) to %d"
+msgstr ""
-#: ../lib/segment/open.c:74
-#, fuzzy
-msgid "Could not write segment file"
+#: ../lib/rst/interp_float/resout2d.c:110
+#, c-format
+msgid "First change your columns number(%d) to %d"
+msgstr ""
-#: ../lib/segment/open.c:78
-msgid "Illegal segment configuration parameter(s)"
+#: ../lib/rst/interp_float/resout2d.c:264
+msgid "No color table for input raster map -- will not create color table"
 msgstr ""
-#: ../lib/segment/open.c:86
-#, fuzzy
-msgid "Unable to re-open segment file"
+#: ../lib/rst/interp_float/resout2d.c:458
+msgid "Changing the region back to initial..."
+msgstr ""
-#: ../lib/segment/open.c:93
+#: ../lib/rst/interp_float/write2d.c:40 ../lib/rst/interp_float/write2d.c:51
+#: ../lib/rst/interp_float/write2d.c:66 ../lib/rst/interp_float/write2d.c:75
+#: ../lib/rst/interp_float/write2d.c:83 ../lib/rst/interp_float/write2d.c:91
 #, fuzzy
-msgid "Could not read segment file"
-msgstr "Nevar palaist failu '%s'"
+msgid "Cannot write files"
+msgstr "Nevar pārrakstīt līniju"
-#: ../lib/segment/format.c:143
-msgid "Segment format: file size too large"
-msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:73
+#, fuzzy, c-format
+msgid "Vector map <%s> is not 3D"
-#: ../lib/segment/format.c:144
-msgid "Please recompile with Large File Support (LFS)"
+#: ../lib/rst/interp_float/vinput2d.c:76
+msgid "Loading data from attribute table ..."
 msgstr ""
-#: ../lib/temporal/lib/default_name.c:69
-msgid "Programmer error - only SQLite driver is currently supported"
-msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:79 ../lib/vector/Vlib/net.c:175
+#: ../lib/vector/Vlib/net.c:353 ../lib/vector/Vlib/array.c:276
+#: ../lib/vector/Vlib/copy.c:595 ../lib/vector/Vlib/copy.c:733
+#: ../lib/vector/Vlib/map.c:177 ../lib/vector/Vlib/map.c:305
+#: ../lib/vector/Vlib/map.c:441 ../lib/vector/Vlib/cats.c:589
+#: ../lib/vector/Vlib/ascii.c:398 ../lib/ogsf/Gp3.c:200 ../lib/ogsf/Gv3.c:337
+#, c-format
+msgid "Database connection not defined for layer %d"
+msgstr "Slānim %d nav definēts savienojums ar datu bāzi"
-#: ../lib/display/icon.c:80
+#: ../lib/rst/interp_float/vinput2d.c:94
+#: ../lib/rst/interp_float/vinput2d.c:108 ../lib/db/dbmi_client/copy_tab.c:267
 #, fuzzy, c-format
-msgid "Unsupported icon %d"
+msgid "Column <%s> not found"
-#: ../lib/display/r_raster.c:113
+#: ../lib/rst/interp_float/vinput2d.c:97
+#: ../lib/rst/interp_float/vinput2d.c:110
 #, c-format
-msgid "%s variable defined, %s ignored"
+msgid "Data type of column <%s> must be numeric"
 msgstr ""
-#: ../lib/display/r_raster.c:148
-#, fuzzy, c-format
-msgid "Unknown display driver <%s>"
+#: ../lib/rst/interp_float/vinput2d.c:121
+#, fuzzy
+msgid "Reading features from vector map ..."
-#: ../lib/display/r_raster.c:149
-#, fuzzy, c-format
-msgid "Using display driver <%s>..."
+#: ../lib/rst/interp_float/vinput2d.c:153
+#, c-format
+msgid "Database record for cat %d not found"
+msgstr ""
-#: ../lib/display/r_raster.c:215
-#, fuzzy, c-format
-msgid "Unable to open file '%s'"
+#: ../lib/rst/interp_float/vinput2d.c:171
+msgid "Negative value of smoothing detected: sm must be >= 0"
+msgstr ""
-#: ../lib/display/tran_colr.c:107 ../lib/display/tran_colr.c:109
+#: ../lib/rst/interp_float/vinput2d.c:235
+msgid "Strip exists with insufficient data"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:249
 #, c-format
-msgid "[%s]: No such color"
+msgid "There are points outside specified 2D/3D region - %d points ignored"
 msgstr ""
-#: ../lib/cairodriver/Raster.c:72
-#, fuzzy
-msgid "Failed to create surface"
-msgstr "neiespējami izveidot jaunu procesu"
+#: ../lib/rst/interp_float/vinput2d.c:252
+#, c-format
+msgid "Ignoring %d points (too dense)"
+msgstr ""
-#: ../lib/cairodriver/read_xid.c:14 ../lib/gis/key_value3.c:58
-#, fuzzy, c-format
-msgid "Unable to open input file <%s>"
+#: ../lib/rst/interp_float/vinput2d.c:256
+#, c-format
+msgid ""
+"%d points given for interpolation (after thinning) is less than given NPMIN="
+"%d"
+msgstr ""
-#: ../lib/cairodriver/read_xid.c:17
-#, fuzzy, c-format
-msgid "Unable to read input file <%s>"
+#: ../lib/rst/interp_float/vinput2d.c:261
+msgid "Zero points in the given region"
+msgstr ""
-#: ../lib/cairodriver/read_xid.c:20
-#, fuzzy, c-format
-msgid "Unable to parse input file <%s>"
+#: ../lib/rst/interp_float/vinput2d.c:266
+#, c-format
+msgid ""
+"Segmentation parameters set to invalid values: npmin= %d, segmax= %d for "
+"smooth connection of segments, npmin > segmax (see manual)"
+msgstr ""
-#: ../lib/cairodriver/write_ppm.c:27 ../lib/cairodriver/write_bmp.c:72
-#, fuzzy, c-format
-msgid "Cairo: unable to open output file <%s>"
+#: ../lib/rst/interp_float/vinput2d.c:272
+#, c-format
+msgid ""
+"There are less than %d points for interpolation. No segmentation is "
+"necessary, to run the program faster set segmax=%d (see manual)"
+msgstr ""
-#: ../lib/cairodriver/write_ppm.c:34
+#: ../lib/rst/interp_float/vinput2d.c:276
 #, fuzzy, c-format
-msgid "Cairo: unable to open mask file <%s>"
+msgid "Number of points from vector map %d"
+msgstr "Ieejas vektorkartes nosaukums"
-#: ../lib/cairodriver/write_xid.c:14 ../lib/gis/key_value3.c:31
+#: ../lib/rst/interp_float/vinput2d.c:277
 #, fuzzy, c-format
-msgid "Unable to open output file <%s>"
+msgid "Number of points outside of 2D/3D region %d"
+msgstr "Ārpus laukuma esošu centroīdu skaits :   %d\n"
-#: ../lib/cairodriver/write_xid.c:19
+#: ../lib/rst/interp_float/vinput2d.c:279
 #, fuzzy, c-format
-msgid "Unable to write output file <%s>"
+msgid "Number of points being used %d"
+msgstr "Punktu skaits    :   %d\n"
-#: ../lib/cairodriver/read_bmp.c:88 ../lib/cairodriver/read_ppm.c:28
-#, fuzzy, c-format
-msgid "Cairo: unable to open input file <%s>"
-#: ../lib/cairodriver/read_bmp.c:92 ../lib/cairodriver/read_ppm.c:32
-#, fuzzy, c-format
-msgid "Cairo: invalid input file <%s>"
-msgstr "Nevar atrast ieejas karti '%s'"
-#: ../lib/cairodriver/read_bmp.c:96
-#, c-format
-msgid "Cairo: Invalid BMP header for <%s>"
+#: ../lib/rst/interp_float/vinput2d.c:312
+msgid "Some points outside of region (ignored)"
 msgstr ""
-#: ../lib/cairodriver/Graph.c:67
+#: ../lib/rst/interp_float/vinput2d.c:318
 #, fuzzy
-msgid "Unable to open display"
+msgid "Unable to allocate memory"
+msgstr "Neiespējami piešķirt atmiņu\n"
-#: ../lib/cairodriver/Graph.c:82
-#, fuzzy
-msgid "Unable to obtain visual"
+#: ../lib/rst/interp_float/vinput2d.c:326
+#, fuzzy, c-format
+msgid "Unable to insert %f,%f,%f a = %d"
-#: ../lib/cairodriver/Graph.c:156
+#: ../lib/rst/interp_float/segmen2d.c:118
+msgid ""
+"Taking too long to find points for interpolation - please change the region "
+"to area where your points are. Continuing calculations..."
+msgstr ""
+#: ../lib/rst/interp_float/output2d.c:106
 #, c-format
-msgid "Unknown file extension: %s"
+msgid "First change your rows number to nsizr! %d %d"
 msgstr ""
-#: ../lib/cairodriver/Graph.c:184
-#, fuzzy, c-format
-msgid "cairo: collecting to file '%s'"
-#: ../lib/cairodriver/Graph.c:186
+#: ../lib/rst/interp_float/output2d.c:113
 #, c-format
-msgid "cairo: image size %dx%d"
+msgid "First change your cols number to nsizc %d %d"
 msgstr ""
-#: ../lib/cairodriver/Graph.c:353
-#, fuzzy
-msgid "Unknown Cairo surface type"
+#: ../lib/htmldriver/Graph_Set.c:97
+#, c-format
+msgid "html: collecting to file '%s'"
+msgstr "html: apvieno failā '%s'"
-#: ../lib/cairodriver/Graph.c:358
-#, fuzzy
-msgid "Failed to initialize Cairo surface"
+#: ../lib/htmldriver/Graph_Set.c:98
+#, c-format
+msgid "html: image size %dx%d"
+msgstr "html: attēla izmērs %dx%d"
-#: ../lib/cairodriver/Text.c:46
-#, fuzzy, c-format
-msgid "Unable to convert from <%s> to UTF-8"
-msgstr "neiespējami atvērt rastra karti [%s iekš %s]"
+#: ../lib/htmldriver/Graph_Set.c:111 ../lib/htmldriver/Graph_Set.c:115
+#: ../lib/htmldriver/Graph_Set.c:119
+#, c-format
+msgid "html: type '%s'"
+msgstr "html: tips '%s'"
-#: ../lib/cairodriver/Text.c:56
-msgid "Some characters could not be converted to UTF-8"
+#: ../lib/pngdriver/Graph_set.c:84
+#, c-format
+msgid "png: truecolor status %s"
 msgstr ""
-#: ../lib/cairodriver/read_ppm.c:38
+#: ../lib/pngdriver/Graph_set.c:132
 #, c-format
-msgid "Cairo: input file has incorrect dimensions: expected: %dx%d got: %dx%d"
+msgid "png: collecting to file '%s'"
 msgstr ""
-#: ../lib/cairodriver/read_ppm.c:46
-#, fuzzy, c-format
-msgid "Cairo: unable to open input mask file <%s>"
-#: ../lib/cairodriver/read_ppm.c:50
-#, fuzzy, c-format
-msgid "Cairo: invalid input mask file <%s>"
-#: ../lib/cairodriver/read_ppm.c:56
+#: ../lib/pngdriver/Graph_set.c:133
 #, c-format
-msgid ""
-"Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
+msgid "png: image size %dx%d"
 msgstr ""
-#: ../lib/cairodriver/Draw_bitmap.c:47
-msgid "Cairo_Bitmap: Failed to create source"
+#: ../lib/temporal/lib/default_name.c:69
+msgid "Programmer error - only SQLite driver is currently supported"
 msgstr ""
-#: ../lib/driver/parse_ftcap.c:84
+#: ../lib/raster3d/close.c:47
 #, c-format
-msgid "%s: Unable to read font definition file; use the default"
+msgid "Unable to write history for 3D raster map <%s>"
 msgstr ""
-#: ../lib/driver/parse_ftcap.c:90
+#: ../lib/raster3d/close.c:62
 #, c-format
-msgid "%s: No font definition file"
+msgid "Unable to move temp raster map <%s> to 3d data file <%s>"
 msgstr ""
-#: ../lib/python/pygrass/raster/category.py:81
-#, fuzzy
-msgid "Raser type: {0} not supported"
+#: ../lib/raster3d/close.c:79
+msgid "Unable to flush all tiles"
+msgstr ""
-#: ../lib/python/pygrass/raster/category.py:166
-msgid "Error executing: Rast_get_ith_cat"
+#: ../lib/raster3d/close.c:84
+msgid "Unable to flush index"
 msgstr ""
-#: ../lib/python/pygrass/raster/category.py:194
-#, fuzzy
-msgid "Null value detected"
-msgstr "Ieejas vektorkartes nosaukums"
+#: ../lib/raster3d/close.c:94
+msgid "Unable to position file"
+msgstr ""
-#: ../lib/python/pygrass/raster/category.py:196
-#, fuzzy
-msgid "Error executing: Rast_set_cat"
+#: ../lib/raster3d/close.c:99 ../lib/raster3d/close.c:105
+#: ../lib/raster3d/close.c:191 ../lib/raster3d/header.c:217
+#, c-format
+msgid "Unable to write header for 3D raster map <%s>"
+msgstr ""
-#: ../lib/python/pygrass/raster/category.py:248
-msgid "Mapset and maptype must be specify"
+#: ../lib/raster3d/close.c:110 ../lib/raster3d/close.c:153
+#, c-format
+msgid "Unable to create 3D raster map <%s>"
 msgstr ""
-#: ../lib/python/pygrass/raster/abstract.py:234
-#, fuzzy
-msgid "Mode type: {0} not supported ('r', 'w')"
+#: ../lib/raster3d/close.c:169
+msgid "Error in cache"
+msgstr ""
-#: ../lib/python/pygrass/raster/abstract.py:245
-#, fuzzy
-msgid "Overwrite type: {0} not supported (True/False)"
+#: ../lib/raster3d/history.c:43
+#, c-format
+msgid "can't get history information for [%s] in mapset [%s]"
+msgstr "nevar iegūt vēstures informāciju priekš [%s] no karšu kopas [%s]"
-#: ../lib/python/pygrass/raster/abstract.py:258
-#: ../lib/python/pygrass/vector/abstract.py:110
-msgid "Map name {0} not valid"
+#: ../lib/raster3d/open.c:20
+msgid "Rast3d_open_cell_old_no_header: error in Rast3d_mask_open_old"
 msgstr ""
-#: ../lib/python/pygrass/raster/__init__.py:182
-#, fuzzy
-msgid "Raster type not defined"
-msgstr "Nevar ierakstīt līniju,karte nav atvērta"
-#: ../lib/python/pygrass/raster/__init__.py:185
-#, fuzzy
-msgid "Raster map <{0}> already exists"
-msgstr "Laukuma nummurs<%d> vai vārds <%s> jau eksistē"
-#: ../lib/python/pygrass/raster/__init__.py:191
-msgid "The map does not exist, I can't open in 'r' mode"
+#: ../lib/raster3d/open.c:26
+msgid "Rast3d_open_cell_old_no_header: error in Rast3d_malloc"
 msgstr ""
-#: ../lib/python/pygrass/raster/__init__.py:261
-msgid "Mode type: {0} not supported ('r', 'w','rw')"
+#: ../lib/raster3d/open.c:37
+msgid "Rast3d_open_cell_old_no_header: error in G_open_old"
 msgstr ""
-#: ../lib/python/pygrass/raster/__init__.py:280
-#, fuzzy, python-format
-msgid "Index out of range: %r."
-#: ../lib/python/pygrass/raster/__init__.py:393
-#, fuzzy
-msgid "Raster map <{0}> already exists. Use overwrite."
-msgstr "Vektors '%s' jau eksistē un tiks pārrakstīts."
-#: ../lib/python/pygrass/raster/__init__.py:424
-#, fuzzy
-msgid "Raster map <{0}> does not exists"
-#: ../lib/python/pygrass/raster/__init__.py:538
-#, fuzzy
-msgid "Mode type: {0} not supported."
-#: ../lib/python/pygrass/raster/__init__.py:572
-#, fuzzy
-msgid "Invalid type {0}"
-msgstr "neispējami mainīt direktoriju uz %s"
-#: ../lib/python/pygrass/raster/__init__.py:574
-#, fuzzy
-msgid "Invalid size {0}"
-#: ../lib/python/pygrass/errors.py:44
-msgid "The map is close!"
+#: ../lib/raster3d/open.c:93
+msgid "Rast3d_open_cell_old: error in Rast3d_open_cell_old_no_header"
 msgstr ""
-#: ../lib/python/pygrass/vector/table.py:874
-#, python-format
-msgid "Deleting table <%s> which is attached to following map(s):"
+#: ../lib/raster3d/open.c:98
+msgid "Rast3d_open_cell_old: can't rewind file"
 msgstr ""
-#: ../lib/python/pygrass/vector/table.py:878
-msgid "You must use the force flag to actually remove it. Exiting."
+#: ../lib/raster3d/open.c:111
+msgid "Rast3d_open_cell_old: error in Rast3d_read_header"
 msgstr ""
-#: ../lib/python/pygrass/functions.py:238
-msgid "Vector doesn't contain points"
+#: ../lib/raster3d/open.c:119
+msgid "Rast3d_open_cell_old: projection does not match window projection"
 msgstr ""
-#: ../lib/python/temporal/mapcalc.py:104
-msgid "Start spatio-temporal sampling"
+#: ../lib/raster3d/open.c:123
+msgid "Rast3d_open_cell_old: zone does not match window zone"
 msgstr ""
-#: ../lib/python/temporal/mapcalc.py:106
-msgid "Start temporal sampling"
+#: ../lib/raster3d/open.c:135 ../lib/raster3d/open.c:152
+msgid "Rast3d_open_cell_old: can't read header"
 msgstr ""
-#: ../lib/python/temporal/mapcalc.py:123
-msgid "No samples found for map calculation"
+#: ../lib/raster3d/open.c:141
+msgid "Rast3d_open_cell_old: index does not fit into long"
 msgstr ""
-#: ../lib/python/temporal/mapcalc.py:150
-msgid ""
-"Found more than a single map in a sample granule. Only the first map is used "
-"for computation. Use t.rast.aggregate.ds to create synchronous raster "
-"datasets."
+#: ../lib/raster3d/open.c:145
+msgid "Rast3d_open_cell_old: error in Rast3d_malloc"
 msgstr ""
-#: ../lib/python/temporal/mapcalc.py:168
-msgid "No maps in input dataset"
+#: ../lib/raster3d/open.c:172
+msgid "Rast3d_open_cell_old: error in Rast3d_fill_header"
 msgstr ""
-#: ../lib/python/temporal/mapcalc.py:184
-msgid "Start mapcalc computation"
+#: ../lib/raster3d/open.c:219
+msgid "Rast3d_open_cell_new: error in Rast3d_mask_open_old"
 msgstr ""
-#: ../lib/python/temporal/mapcalc.py:234 ../lib/python/temporal/extract.py:111
-#: ../lib/python/temporal/open.py:204
-msgid ""
-"Map <%s> is already in temporal database, use overwrite flag to overwrite"
-#: ../lib/python/temporal/mapcalc.py:273
-msgid "Error while mapcalc computation"
+#: ../lib/raster3d/open.c:228
+msgid "Rast3d_open_cell_new: error in Rast3d_malloc"
 msgstr ""
-#: ../lib/python/temporal/mapcalc.py:279
-#, fuzzy
-msgid "Start map registration in temporal database"
+#: ../lib/raster3d/open.c:233
+#, c-format
+msgid "map <%s> is not in the current mapset"
+msgstr "karte <%s> neatrodas šī brīža karšu kopā"
-#: ../lib/python/temporal/mapcalc.py:428 ../lib/python/temporal/mapcalc.py:434
-#: ../lib/python/temporal/mapcalc.py:440 ../lib/python/temporal/mapcalc.py:446
-#: ../lib/python/temporal/mapcalc.py:452 ../lib/python/temporal/mapcalc.py:458
-#: ../lib/python/temporal/mapcalc.py:464 ../lib/python/temporal/mapcalc.py:470
-#: ../lib/python/temporal/mapcalc.py:476 ../lib/python/temporal/mapcalc.py:510
-#: ../lib/python/temporal/mapcalc.py:519 ../lib/python/temporal/mapcalc.py:528
-#: ../lib/python/temporal/mapcalc.py:537 ../lib/python/temporal/mapcalc.py:546
-#: ../lib/python/temporal/mapcalc.py:555 ../lib/python/temporal/mapcalc.py:564
-#: ../lib/python/temporal/mapcalc.py:573 ../lib/python/temporal/mapcalc.py:582
-#, python-format
-msgid "The temporal operators <%s> supports only absolutetime."
+#: ../lib/raster3d/open.c:243
+msgid "Rast3d_open_cell_new: could not open file"
 msgstr ""
-#: ../lib/python/temporal/extract.py:53
-msgid "You need to specify the base name of new created maps"
+#: ../lib/raster3d/open.c:287 ../lib/raster3d/open.c:292
+msgid "Rast3d_open_cell_new: can't write header"
 msgstr ""
-#: ../lib/python/temporal/extract.py:157
-msgid "Error while computation"
+#: ../lib/raster3d/open.c:314
+msgid "Rast3d_open_cell_new: error in Rast3d_fill_header"
 msgstr ""
-#: ../lib/python/temporal/stds_import.py:84
-msgid "Unable to import/link raster map <%s> from file %s."
+#: ../lib/raster3d/color.c:354
+#, c-format
+msgid "mapset <%s> is not the current mapset"
+msgstr "karšu kopa <%s> nav aktīvā karšu kopa"
-#: ../lib/python/temporal/stds_import.py:94
-msgid "Unable to set the color rules for raster map <%s>."
+#: ../lib/raster3d/maskfn.c:77
+#, c-format
+msgid "Adding rule: %lf - %lf"
+msgstr ""
-#: ../lib/python/temporal/stds_import.py:114
-msgid "Unable to unpack raster map <%s> from file %s."
+#: ../lib/raster3d/maskfn.c:95
+#, c-format
+msgid "%s: illegal value spec"
+msgstr ""
-#: ../lib/python/temporal/stds_import.py:134
-msgid "Unable to import vector map <%s> from file %s."
-#: ../lib/python/temporal/stds_import.py:158
-msgid "Unable to unpack vector map <%s> from file %s."
-#: ../lib/python/temporal/stds_import.py:195
-msgid "Space time raster dataset archive <%s> not found"
-#: ../lib/python/temporal/stds_import.py:198
-msgid "Extraction directory <%s> not found"
-#: ../lib/python/temporal/stds_import.py:206
-msgid "Unable to find init file <%s>"
+#: ../lib/raster3d/range.c:73
+#, c-format
+msgid "Unable to open range file for [%s in %s]"
-#: ../lib/python/temporal/stds_import.py:208
-msgid "Unable to find list file <%s>"
-msgstr "Neiespējami atvērt failu %s iekš %s"
+#: ../lib/raster3d/range.c:88
+#, c-format
+msgid "Error reading range file for [%s in %s]"
+msgstr "Nederīgs diapazona fails priekš [%s iekš %s]"
-#: ../lib/python/temporal/stds_import.py:210
-msgid "Unable to find projection file <%s>"
+#: ../lib/raster3d/range.c:150
+#, c-format
+msgid "Unable to open range file for <%s>"
+msgstr "Nevar atvērt diapazona failu priekš <%s>"
-#: ../lib/python/temporal/stds_import.py:235
-msgid "Projection information does not match. Proceeding..."
+#: ../lib/raster3d/param.c:84
+msgid "Rast3d_get_standard3d_params: precision value invalid"
 msgstr ""
-#: ../lib/python/temporal/stds_import.py:239
-msgid ""
-"Difference between PROJ_INFO file of imported map and of current location:\n"
-"{diff}"
+#: ../lib/raster3d/param.c:105
+msgid "Rast3d_get_standard3d_params: tile dimension value invalid"
 msgstr ""
-#: ../lib/python/temporal/stds_import.py:241
-msgid "Projection information does not match. Aborting."
-msgstr ""
+#: ../lib/raster3d/param.c:129
+msgid "Window replacing the default"
+msgstr "Logs aizvieto noklusēto"
-#: ../lib/python/temporal/stds_import.py:257
-msgid "Unable to create location %(l)s. Reason: %(e)s"
+#: ../lib/raster/put_cellhd.c:34
+#, fuzzy, c-format
+msgid "Unable to create header file for <%s>"
+msgstr "Nevar atvērt vēsturi vektoram '%s'"
+#: ../lib/raster/quant_rw.c:88
+#, fuzzy, c-format
+msgid "Unable to read fp range for raster map <%s>"
-#: ../lib/python/temporal/stds_import.py:264
-msgid "Unable to switch to location %s"
-msgstr "nevar ierakstīt vēstures informāciju priekš [%s]"
+#: ../lib/raster/quant_rw.c:92
+#, fuzzy, c-format
+msgid "Raster map <%s> is empty"
-#: ../lib/python/temporal/stds_import.py:268
-msgid "Unable to create default temporal database in new location %s"
+#: ../lib/raster/quant_rw.c:157
+#, fuzzy, c-format
+msgid "Unable to write quant rules: raster map <%s> is integer"
-#: ../lib/python/temporal/stds_import.py:333
-#, python-format
-msgid "Key words %(t)s, %(s)s or %(n)s not found in init file."
-msgstr ""
+#: ../lib/raster/quant_rw.c:166
+#, fuzzy, c-format
+msgid "Unable to write quant rules for raster map <%s>"
-#: ../lib/python/temporal/stds_import.py:339
-msgid "Number of maps mismatch in init and list file."
+#: ../lib/raster/reclass.c:168
+#, c-format
+msgid "Too many reclass categories for <%s@%s>"
+msgstr "Pārāk daudz pārklasificēšanas kategorijas priekš <%s@%s>"
+#: ../lib/raster/reclass.c:171
+#, c-format
+msgid "Illegal reclass format in header file for <%s@%s>"
 msgstr ""
-#: ../lib/python/temporal/stds_import.py:350
-#, fuzzy
-msgid "The archive file is of wrong space time dataset type"
+#: ../lib/raster/reclass.c:273
+msgid "Illegal reclass request"
+msgstr "Netļauts pārklasificēšanas pieprasījums"
-#: ../lib/python/temporal/stds_import.py:357
-msgid "Unable to find geotiff raster file <%s> in archive."
+#: ../lib/raster/reclass.c:278
+msgid "Illegal reclass type"
+msgstr "Netļauts klases tips"
-#: ../lib/python/temporal/stds_import.py:363
-msgid "Unable to find AAIGrid raster file <%s> in archive."
+#: ../lib/raster/reclass.c:284
+#, c-format
+msgid "Unable to create header file for <%s@%s>"
+msgstr ""
-#: ../lib/python/temporal/stds_import.py:369
-msgid "Unable to find GML vector file <%s> in archive."
+#: ../lib/raster/reclass.c:332
+#, c-format
+msgid "Unable to create dependency file in <%s@%s>"
+msgstr "Niespējami izveidot atkarību failu <%s@%s>"
-#: ../lib/python/temporal/stds_import.py:378
-msgid "Unable to find GRASS package file <%s> in archive."
-msgstr "Neiespējami atvērt %s priekš rakstīšanas"
+#: ../lib/raster/close.c:74 ../lib/raster/close.c:107
+#, c-format
+msgid "Invalid descriptor: %d"
+msgstr "Nepareizs deskriptors: %d"
-#: ../lib/python/temporal/stds_import.py:381
-#, fuzzy
-msgid "Unsupported input format"
-msgstr "nezināns interpolācijas tips"
+#: ../lib/raster/close.c:373
+#, c-format
+msgid "Unable to rename null file '%s' to '%s'"
+msgstr ""
-#: ../lib/python/temporal/stds_import.py:387
-msgid ""
-"Space time %(t)s dataset <%(sp)s> is already in the database. Use the "
-"overwrite flag."
+#: ../lib/raster/close.c:439
+#, c-format
+msgid "Unable to rename cell file '%s' to '%s'"
+msgstr ""
-#: ../lib/python/temporal/stds_import.py:407
-msgid "Overwrite space time %(sp)s dataset <%(id)s> and unregister all maps."
-#: ../lib/python/temporal/stds_import.py:419
-msgid "Key word %s not found in init file."
-#: ../lib/python/temporal/stds_import.py:423
-msgid "Create space time %s dataset."
-msgstr "Ievades rastra failu nosaukumi"
-#: ../lib/python/temporal/list.py:100
-msgid "Empty map list."
+#: ../lib/raster/close.c:474
+msgid "unable to write f_format file for CELL maps"
 msgstr ""
-#: ../lib/python/temporal/list.py:111
-msgid "Empty entry in map list, this should not happen."
+#: ../lib/raster/color_write.c:81 ../lib/vector/Vlib/color_write.c:71
+#, c-format
+msgid "Qualified name <%s> doesn't match mapset <%s>"
 msgstr ""
-#: ../lib/python/temporal/core.py:146 ../lib/python/temporal/core.py:154
-msgid ""
-"Unable to initialize the temporal GIS DBMI interface. Use t.connect to "
-"specify the driver and the database string"
+#: ../lib/raster/color_write.c:96 ../lib/vector/Vlib/color_write.c:91
+#, c-format
+msgid "Unable to create <%s> file for map <%s>"
 msgstr ""
-#: ../lib/python/temporal/core.py:235
-msgid ""
-"Unable to initialize the temporal DBMI interface. Use t.connect to specify "
-"the driver and the database string"
+#: ../lib/raster/color_rand.c:33
+#, c-format
+msgid "Rast_make_random_colors: min (%d) > max (%d)"
 msgstr ""
-#: ../lib/python/temporal/core.py:365
-msgid "Create temporal database: %s"
-msgstr "Nevar atvērt datubāzi %s"
+#: ../lib/raster/histogram.c:55
+#, c-format
+msgid "Histogram for [%s in %s] missing (run r.support)"
+msgstr "Histogramma preikš [%s iekš %s] pietrūkst (palaist r.support)"
-#: ../lib/python/temporal/core.py:635
-msgid ""
-"Unable to execute transaction:\n"
-" %(sql)s"
-msgstr "neiespējami izpildīt komandu"
+#: ../lib/raster/histogram.c:62
+#, c-format
+msgid "Can't read histogram for [%s in %s]"
+msgstr "Nevar nolasīt histogrammu priekš [%s no %s]"
-#: ../lib/python/temporal/open.py:60 ../lib/python/temporal/open.py:114
-msgid "Unkown type: %s"
+#: ../lib/raster/histogram.c:66 ../lib/raster/histogram.c:73
+#, c-format
+msgid "Invalid histogram file for [%s in %s]"
+msgstr "Nederīgs histogrammas fails priekš [%s iekš %s]"
-#: ../lib/python/temporal/open.py:66
-msgid "Space time %(sp)s dataset <%(name)s> no found"
+#: ../lib/raster/histogram.c:331
+#, fuzzy, c-format
+msgid "Unable to create histogram file for <%s>"
-#: ../lib/python/temporal/open.py:103
-#, fuzzy
-msgid "Space time datasets can only be created in the current mapset"
+#: ../lib/raster/alloc_cell.c:151
+#, c-format
+msgid "Rast__null_bitstream_size: cols (%d) is negative"
+msgstr ""
-#: ../lib/python/temporal/open.py:120
-msgid ""
-"Space time %(sp)s dataset <%(name)s> is already in the database. Use the "
-"overwrite flag."
-#: ../lib/python/temporal/open.py:155
-msgid "Overwrite space time %(sp)s dataset <%(name)s> and unregister all maps."
-#: ../lib/python/temporal/open.py:163
-msgid "Create new space time %s dataset."
-#: ../lib/python/temporal/sampling.py:93 ../lib/python/temporal/sampling.py:97
-msgid "Dataset <%s> not found in temporal database"
-#: ../lib/python/temporal/aggregation.py:123
-msgid "Aggregate %s raster maps"
-msgstr "Bāzes rastra faila nosaukums"
-#: ../lib/python/temporal/aggregation.py:137
-msgid ""
-"Raster map <%s> is already in temporal database, use overwrite flag to "
-"overwrite"
-#: ../lib/python/temporal/aggregation.py:141
-#, python-format
-msgid "Compute aggregation of maps between %(st)s - %(end)s"
+#: ../lib/raster/history.c:115 ../lib/raster/history.c:123
+#, c-format
+msgid "Unable to get history information for <%s@%s>"
 msgstr ""
-#: ../lib/python/temporal/aggregation.py:160
-msgid "Error while r.series computation"
+#: ../lib/raster/history.c:162
+#, c-format
+msgid "Unable to write history information for <%s>"
 msgstr ""
-#: ../lib/python/temporal/factory.py:50
-msgid "Unknown dataset type: %s"
+#: ../lib/raster/history.c:235
+#, c-format
+msgid "generated by %s"
+msgstr "ģenerēts ar %s"
-#: ../lib/python/temporal/abstract_map_dataset.py:441
-msgid ""
-"Start time must be of type datetime for %(type)s map <%(id)s> with layer: "
-"%(l)s"
-msgstr ""
-"Nevar izveidot laikspiedola(timestamp) failu priekš %s kartes %s karšu "
-"biblitēkā %s"
+#: ../lib/raster/interp.c:211
+#, c-format
+msgid "Unknown interpolation method: %s"
+msgstr "Nezināma interpolācijas metode: %s"
-#: ../lib/python/temporal/abstract_map_dataset.py:447
-msgid "Start time must be of type datetime for %(type)s map <%(id)s>"
-msgstr ""
-"Nederīgs liakspiedola(timestamp) fails priekš %s kartes %s  karšu biblotēkā "
-"%s"
+#: ../lib/raster/color_read.c:103
+msgid "missing"
+msgstr "iztrūkst"
-#: ../lib/python/temporal/abstract_map_dataset.py:454
-msgid ""
-"End time must be of type datetime for %(type)s map <%(id)s> with layer: %(l)s"
-msgstr ""
-"%s"
+#: ../lib/raster/color_read.c:106
+msgid "invalid"
+msgstr "nederīgs"
-#: ../lib/python/temporal/abstract_map_dataset.py:460
-msgid "End time must be of type datetime for %(type)s map <%(id)s>"
-msgstr ""
-"%s"
+#: ../lib/raster/color_read.c:112
+#, c-format
+msgid "Color support for <%s@%s> %s"
+msgstr "Krāsu atbalsts priekš <%s@%s> %s"
-#: ../lib/python/temporal/abstract_map_dataset.py:468
+#: ../lib/raster/window.c:18
 msgid ""
-"End time must be greater than start time for %(type)s map <%(id)s> with "
-"layer: %(l)s"
-msgstr "Austrumiem ir jābūt lielākiem nekā Rietumiem"
+"Internal error: Rast_get_window() called with split window. Use "
+"Rast_get_input_window() or Rast_get_output_window() instead."
+msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:475
-#: ../lib/python/temporal/abstract_map_dataset.py:566
-msgid "End time must be greater than start time for %(type)s map <%(id)s>"
-#: ../lib/python/temporal/abstract_map_dataset.py:513
-#: ../lib/python/temporal/abstract_map_dataset.py:603
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2261
-#: ../lib/python/temporal/abstract_dataset.py:417
-#: ../lib/python/temporal/abstract_dataset.py:455
-#, python-format
+#: ../lib/raster/window.c:77
 msgid ""
-"Unable to update dataset <%(ds)s> of type %(type)s in the temporal database. "
-"The mapset of the dataset does not match the current mapset"
+"Internal error: Rast_window_rows() called with split window. Use "
+"Rast_input_window_rows() or Rast_output_window_rows() instead."
 msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:547
+#: ../lib/raster/window.c:112
 msgid ""
-"Unsupported relative time unit type for %(type)s map <%(id)s> with layer "
-"%(l)s: %(u)s"
+"Internal error: Rast_window_cols() called with split window. Use "
+"Rast_input_window_cols() or Rast_output_window_cols() instead."
 msgstr ""
-"biblitēkā %s"
-#: ../lib/python/temporal/abstract_map_dataset.py:552
-msgid "Unsupported relative time unit type for %(type)s map <%(id)s>: %(u)s"
+#: ../lib/raster/gdal.c:88
+#, c-format
+msgid "Unable to locate symbol <%s>"
+msgstr "Nevar atrast simbolu <%s>"
-#: ../lib/python/temporal/abstract_map_dataset.py:561
-msgid ""
-"layer %(l)s"
+#: ../lib/raster/gdal.c:140
+msgid "Unable to load GDAL library"
+msgstr "Nevar ielādēt GDAL bibliotēku"
-#: ../lib/python/temporal/abstract_map_dataset.py:870
-#, python-format
-msgid ""
-"Map <%(id)s> with layer %(layer)s has incorrect time interval, start time is "
-"greater than end time"
-msgstr ""
+#: ../lib/raster/gdal.c:370
+msgid "Unable to open GDAL file"
+msgstr "Nevar atvērt GDAL failu"
-#: ../lib/python/temporal/abstract_map_dataset.py:876
-#, python-format
-msgid ""
-"Map <%s> has incorrect time interval, start time is greater than end time"
-msgstr ""
+#: ../lib/raster/gdal.c:474 ../lib/raster/open.c:569
+#, c-format
+msgid "Invalid map type <%d>"
+msgstr "Nederīgs kartes tips <%d>"
-#: ../lib/python/temporal/abstract_map_dataset.py:881
-#, python-format
-msgid "Map <%s> has incorrect start time"
-msgstr ""
+#: ../lib/raster/gdal.c:480
+#, c-format
+msgid "Unable to get <%s> driver"
+msgstr "Nav iespējams saņemt <%s> dzinēju"
-#: ../lib/python/temporal/abstract_map_dataset.py:909
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1836
-#, python-format
-msgid ""
-"Unable to delete dataset <%(ds)s> of type %(type)s from the temporal "
-"database. The mapset of the dataset does not match the current mapset"
+#: ../lib/raster/gdal.c:489
+#, c-format
+msgid "Unable to create <%s> dataset using <%s> driver"
 msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:981
-#, python-format
+#: ../lib/raster/gdal.c:497
+#, c-format
 msgid ""
-"Unable to unregister dataset <%(ds)s> of type %(type)s from the temporal "
+"Driver <%s> does not support direct writing. Using MEM driver for "
+"intermediate dataset."
 msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:1035
-msgid "Unable to select space time dataset register table <%s>"
-#: ../lib/python/temporal/register.py:70
-#, python-format
-msgid "%(m)s= and %(f)s= are mutually exclusive"
+#: ../lib/raster/gdal.c:503
+msgid "Unable to get in-memory raster driver"
 msgstr ""
-#: ../lib/python/temporal/register.py:74
-#, python-format
-msgid "%(e)s= and %(i)s= are mutually exclusive"
+#: ../lib/raster/gdal.c:510
+#, c-format
+msgid "Unable to create <%s> dataset using memory driver"
 msgstr ""
-#: ../lib/python/temporal/register.py:78
-msgid "Please specify %(st)s= and %(e)s="
+#: ../lib/raster/gdal.c:514
+#, c-format
+msgid "Driver <%s> does not support creating rasters"
 msgstr ""
-"\n"
-"Lūdzu norādi datuma nosaukumu\n"
-#: ../lib/python/temporal/register.py:82
-msgid "Please specify %(m)s= or %(f)s="
+#: ../lib/raster/gdal.c:530
+msgid "Unable to set geo transform"
 msgstr ""
-"\n"
-"Lūdzu norādi elipsoīda nosaukumu\n"
-#: ../lib/python/temporal/register.py:95
-#, python-format
-msgid ""
-"Space time %(sp)s dataset <%(name)s> with relative time found, but no "
-"relative unit set for %(sp)s maps"
+#: ../lib/raster/gdal.c:534
+msgid "Unable to set projection"
 msgstr ""
-#: ../lib/python/temporal/register.py:161
-msgid "Gathering map informations"
+#: ../lib/raster/gdal.c:538
+#, c-format
+msgid "Unable to create cell_misc/%s/gdal file"
 msgstr ""
-#: ../lib/python/temporal/register.py:184
-msgid ""
-"Unable to register %(t)s map <%(id)s> with layer %(l)s. The map has "
-"timestamp and the start time is not set."
-msgstr "Ieejas vektors '%s' nav atrasts"
-#: ../lib/python/temporal/register.py:190
-msgid ""
-"Unable to register %(t)s map <%(id)s>. The map has no timestamp and the "
-"start time is not set."
-#: ../lib/python/temporal/register.py:205
-msgid ""
-"Map is already registered in temporal database. Unable to update %(t)s map <"
-"%(id)s> with layer %(l)s. Overwrite flag is not set."
-#: ../lib/python/temporal/register.py:212
-msgid ""
-"%(id)s>. Overwrite flag is not set."
-#: ../lib/python/temporal/register.py:235
-msgid ""
-"Unable to update %(t)s map <%(id)s> with layer %(l)s. The temporal types are "
-"different."
-#: ../lib/python/temporal/register.py:241
-msgid "Unable to update %(t)s map <%(id)s>. The temporal types are different."
-#: ../lib/python/temporal/register.py:287
-#, fuzzy
-msgid "Register maps in the temporal database"
-#: ../lib/python/temporal/register.py:294
-#, fuzzy
-msgid "Register maps in the space time raster dataset"
-#: ../lib/python/temporal/register.py:303
-msgid "Update space time raster dataset"
+#: ../lib/raster/gdal.c:554
+#, c-format
+msgid "Error writing cell_misc/%s/gdal file"
 msgstr ""
-#: ../lib/python/temporal/register.py:353
-#: ../lib/python/temporal/register.py:361
-msgid "Unable to convert string \"%s\"into a datetime object"
-msgstr "Izgāzusies konvertācija taksta (string) atribūtam."
-#: ../lib/python/temporal/register.py:369
-#: ../lib/python/temporal/register.py:374
-#, fuzzy
-msgid "Error in increment computation"
-msgstr "  formāts: %s\n"
-#: ../lib/python/temporal/base.py:378
-msgid "Object <%s> not found in the temporal database"
-#: ../lib/python/temporal/base.py:619
-#, fuzzy
-msgid "Wrong identifier, the mapset is missing"
-#: ../lib/python/temporal/univar_statistics.py:56
-#: ../lib/python/temporal/univar_statistics.py:147
-msgid "Space time %(sp)s dataset <%(i)s> is empty"
-#: ../lib/python/temporal/univar_statistics.py:137
-msgid "Space time %(sp)s dataset <%(i)s> not found"
-#: ../lib/python/temporal/gui_support.py:56 ../lib/python/script/core.py:1262
-#, python-format
-msgid "Invalid element '%s'"
+#: ../lib/raster/gdal.c:602
+#, c-format
+msgid "Unable to create output file <%s> using driver <%s>"
 msgstr ""
-#: ../lib/python/temporal/spatial_extent.py:125
+#: ../lib/raster/open.c:190
+#, fuzzy, c-format
 msgid ""
-"Projections are different. Unable to compute overlapping_2d for spatial "
-"extents"
+"Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@"
+"%s> which does not exist"
 msgstr ""
+"neiespējami atvērt [%s] iekš [%s] kopš tas ir pārklasificēts  [%s] iekš [%s] "
+"kas neeksistē"
-#: ../lib/python/temporal/spatial_extent.py:536
-msgid ""
-"Projections are different. Unable to compute is_in_2d for spatial extents"
-msgstr ""
+#: ../lib/raster/open.c:195
+#, fuzzy, c-format
+msgid "Error reading reclass file for raster map <%s>"
-#: ../lib/python/temporal/spatial_extent.py:676
-msgid ""
-"Projections are different. Unable to compute equivalent_2d for spatial "
-"extents"
-msgstr ""
+#: ../lib/raster/open.c:206
+#, fuzzy, c-format
+msgid "Error reading map type for raster map <%s>"
+msgstr "eksistējošām rastra kartēm %d"
-#: ../lib/python/temporal/spatial_extent.py:783
+#: ../lib/raster/open.c:214
+#, fuzzy, c-format
+msgid "Raster map <%s@%s>: format field in header file invalid"
+msgstr "[%s] karšu biblotēkā [%s]-formāta lauks faila galvā (header) ir nederīgs"
+#: ../lib/raster/open.c:219
+#, fuzzy, c-format
 msgid ""
-"Projections are different. Unable to compute cover_2d for spatial extents"
-msgstr ""
+"Raster map <%s> is in different projection than current region. Found <%s>, "
+"should be <%s>."
+msgstr "Defekts: atteikts papildināt karti,kura nav tekošajā karšu komplektā."
-#: ../lib/python/temporal/spatial_extent.py:854
-msgid "Projections are different. Unable to compute cover for spatial extents"
-msgstr ""
+#: ../lib/raster/open.c:226
+#, fuzzy, c-format
+msgid "Raster map <%s> is in different zone (%d) than current region (%d)"
-#: ../lib/python/temporal/spatial_extent.py:1704
-msgid "Volume computation is not supported for LL projections"
+#: ../lib/raster/open.c:231
+#, c-format
+msgid "Raster map <%s>: bytes per cell (%d) too large"
 msgstr ""
-#: ../lib/python/temporal/spatial_extent.py:1722
-msgid "Area computation is not supported for LL projections"
+#: ../lib/raster/open.c:256
+#, c-format
+msgid "Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
 msgstr ""
-#: ../lib/python/temporal/stds_export.py:96
-msgid "Unable to export raster map <%s>"
+#: ../lib/raster/open.c:264
+#, fuzzy, c-format
+msgid "Unable to open %s file for raster map <%s@%s>"
-#: ../lib/python/temporal/stds_export.py:106
-msgid "Unable to export color rules for raster map <%s> r.out.gdal"
+#: ../lib/raster/open.c:301
+#, fuzzy, c-format
+msgid "Error reading format for <%s@%s>"
+msgstr "kļūda nolasot %smap [%s] karšu biblotēkā [%s], līnija %d"
-#: ../lib/python/temporal/stds_export.py:128
-msgid "Unable to export raster map <%s> with r.pack"
+#: ../lib/raster/open.c:498
+#, fuzzy
+msgid "Unable to create GDAL link"
+msgstr "Neiespējami atvērt failu %s iekš %s"
-#: ../lib/python/temporal/stds_export.py:154
-msgid "Unable to export vector map <%s> as GML with v.out.ogr"
+#: ../lib/raster/open.c:574
+#, fuzzy, c-format
+msgid "Raster map <%s> is not in the current mapset (%s)"
-#: ../lib/python/temporal/stds_export.py:185
-msgid "Unable to export vector map <%s> with v.pack"
+#: ../lib/raster/open.c:581
+#, fuzzy, c-format
+msgid "<%s> is an illegal file name"
+msgstr "%s - ** neatļauts vārds/nosaukums **"
-#: ../lib/python/temporal/stds_export.py:210
-msgid "Unable to export raster map <%s> with r3.pack"
+#: ../lib/raster/open.c:595
+#, fuzzy
+msgid "No temp files available"
+msgstr "Krāsu fails priekš [%s] nav pieejams"
-#: ../lib/python/temporal/datetime_math.py:247
-#: ../lib/python/temporal/datetime_math.py:264
-msgid "Wrong increment format: %s"
+#: ../lib/raster/open.c:667
+#, fuzzy
+msgid "no temp files available"
+msgstr "nav %s faili pieejami karšu biblotēkā %s\n"
-#: ../lib/python/temporal/datetime_math.py:439
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1472
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1505
-msgid "Wrong granularity format: %s"
+#: ../lib/raster/open.c:720
+msgid "Rast_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
+msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:154
-#: ../lib/python/temporal/abstract_space_time_dataset.py:276
-msgid "Unknown temporal type \"%s\""
+#: ../lib/raster/open.c:778
+#, fuzzy, c-format
+msgid "Raster map <%s> not found in mapset <%s>"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:269
-#: ../lib/python/temporal/abstract_space_time_dataset.py:980
-msgid "Wrong granularity: \"%s\""
+#: ../lib/raster/open.c:839
+#, fuzzy, c-format
+msgid "Unable to find '%s'"
+msgstr "neiespējami atrast [%s]"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:297
-msgid "Unsupported temporal unit: %s"
+#: ../lib/raster/open.c:850
+#, fuzzy, c-format
+msgid "Invalid type: field '%s' in file '%s'"
+msgstr "nederīgs tips: lauks %s failā %s"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:604
-#: ../lib/python/temporal/abstract_space_time_dataset.py:850
-msgid "The space time datasets must be of the same temporal type"
-msgstr ""
+#: ../lib/raster/open.c:855
+#, fuzzy, c-format
+msgid "Missing type: field in file '%s'"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:609
-#: ../lib/python/temporal/abstract_space_time_dataset.py:855
-msgid "The temporal map type of the sample dataset must be interval"
-msgstr ""
+#: ../lib/raster/open.c:860
+#, fuzzy, c-format
+msgid "Raster map <%s> is not xdr: byte_order: %s"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1390
-msgid "Unable to get map ids from register table <%s>"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1500
-#, python-format
-msgid ""
-"Unable to shift dataset <%(ds)s> of type %(type)s in the temporal database. "
+#: ../lib/raster/open.c:929
+msgid "Rast_set_quant_rules() can be called only for raster maps opened for reading"
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1667
-#, python-format
-msgid ""
-"Unable to snap dataset <%(ds)s> of type %(type)s in the temporal database. "
+#: ../lib/raster/set_window.c:48
+msgid "Rast_set_window() called while window split"
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1767
-#, python-format
+#: ../lib/raster/set_window.c:131
 msgid ""
-"Unable to rename dataset <%(ds)s> of type %(type)s in the temporal database. "
+"Rast_set_read_window(): projection/zone differs from that of currently open "
+"raster maps"
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1847
-msgid "Drop map register table: %s"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1894
-msgid ""
-"Unable to register map in dataset <%(ds)s> of type %(type)s. The mapset of "
-"the dataset does not match the current mapset"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1902
-msgid "Only maps with absolute or relative valid time can be registered"
+#: ../lib/raster/set_window.c:158
+#, c-format
+msgid "Input window changed while maps are open for read. Map name <%s>"
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1923
-#, python-format
-msgid "Map <%(id)s> with layer %(l)s has invalid time"
+#: ../lib/raster/set_window.c:174
+#, c-format
+msgid "Output window changed while maps are open for write. Map name <%s>"
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1926
-#, python-format
-msgid "Map <%s> has invalid time"
-msgstr ""
+#: ../lib/raster/cats.c:109
+#, fuzzy, c-format
+msgid "Category support for <%s@%s> missing"
+msgstr "kategoriju atbalsts priekš [%s] karšu biblotēkā [%s] %s"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1949
-msgid ""
-"Temporal type of space time dataset <%(id)s> and map <%(map)s> with layer "
-"%(l)s are different"
+#: ../lib/raster/cats.c:112
+#, fuzzy, c-format
+msgid "Category support for <%s@%s> invalid"
+msgstr "kategorijas informācija priekš [%s] iekš [%s] ir nederīga"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1954
-msgid ""
-"Temporal type of space time dataset <%(id)s> and map <%(map)s> are different"
+#: ../lib/raster/cats.c:145
+#, fuzzy, c-format
+msgid "Category support for vector map <%s@%s> missing"
+msgstr "kategoriju atbalsts vektoru failam [%s] karšu biblotēkā [%s] %s"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1977
-#, python-format
-msgid ""
-"Relative time units of space time dataset <%(id)s> and map <%(map)s> with "
-"layer %(l)s are different"
-msgstr ""
+#: ../lib/raster/cats.c:149
+#, fuzzy, c-format
+msgid "Category support for vector map <%s@%s> invalid"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1983
-#, python-format
-msgid ""
-"Relative time units of space time dataset <%(id)s> and map <%(map)s> are "
-"different"
-msgstr ""
+#: ../lib/raster/cats.c:968
+#, fuzzy, c-format
+msgid "Unable to open %s file for map <%s>"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1989
-msgid "Only maps from the same mapset can be registered"
-msgstr ""
+#: ../lib/raster/format.c:154
+#, c-format
+msgid "Fail of initial read of compressed file [%s in %s]"
+msgstr "Izgāzusies arhivētā faila lasīšanas inicializācija [%s iekš %s]"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2003
-msgid "Error in strds_register_table request"
+#: ../lib/raster/get_row.c:36 ../lib/raster/get_row.c:838
+#, c-format
+msgid "Reading raster map <%s@%s> request for row %d is outside region"
 msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2011
-msgid "Map <%(map)s> with layer %(l)s is already registered."
-msgstr "Defekts: atteikts papildināt karti,kura nav tekošajā karšu komplektā."
+#: ../lib/raster/get_row.c:95 ../lib/raster/get_row.c:100
+#: ../lib/raster/get_row.c:133 ../lib/raster/get_row.c:139
+#: ../lib/raster/get_row.c:173 ../lib/raster/get_row.c:176
+msgid "Error reading raster data"
+msgstr "Kļūda nolasot rastra datus"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2015
-#, python-format
-msgid "Map <%s> is already registered."
-msgstr ""
+#: ../lib/raster/get_row.c:211
+msgid "Error reading raster data via GDAL"
+msgstr "Kļūda nolasot GDAL rastra datus"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2155
-#, python-format
-msgid ""
-"Unable to unregister map from dataset <%(ds)s> of type %(type)s in the "
-"temporal database. The mapset of the dataset does not match the current "
-"mapset"
-msgstr ""
+#: ../lib/raster/get_row.c:822 ../lib/raster/get_row.c:825
+#, c-format
+msgid "Error reading null row %d"
+msgstr "kļūda lasot NULL rindu %d"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2193
-msgid ""
-"Map <%(map)s> with layer %(l)s is not registered in space time dataset <"
-"%(base)s>"
+#: ../lib/raster/color_rules.c:125
+msgid "syntax error"
+msgstr "sintakses kļūda"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2199
-msgid "Map <%(map)s> is not registered in space time dataset <%(base)s>"
+#: ../lib/raster/color_rules.c:127
+msgid "R/G/B not in range 0-255"
+msgstr "R/G/B nav diapazonā no 0 līdz 255"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2265
-#, python-format
-msgid ""
-"Update metadata, spatial and temporal extent from all registered maps of <%s>"
-msgstr ""
+#: ../lib/raster/color_rules.c:129
+msgid "invalid color name"
+msgstr "nederīgs krāsas nosaukums"
-#: ../lib/python/temporal/abstract_dataset.py:382
-#, python-format
-msgid ""
-"Unable to insert dataset <%(ds)s> of type %(type)s in the temporal database. "
-msgstr ""
+#: ../lib/raster/color_rules.c:131
+msgid "percentage not in range 0-100"
+msgstr "procenti nav diapazonā 0 - 100"
-#: ../lib/python/temporal/space_time_datasets.py:232
-msgid "Unable to read timestamp file for raster map <%s>"
+#: ../lib/raster/color_rules.c:133
+msgid "invalid value"
+msgstr "nederīga vērtība"
-#: ../lib/python/temporal/space_time_datasets.py:251
-msgid "Unable to create timestamp file for raster map <%s>"
+#: ../lib/raster/color_rules.c:135
+msgid "unknown error"
+msgstr "nezināma kļūda"
-#: ../lib/python/temporal/space_time_datasets.py:255
-msgid "Invalid datetime in timestamp for raster map <%s>"
+#: ../lib/raster/color_rules.c:181
+#, c-format
+msgid "bad rule (%s): [%s]"
 msgstr ""
-"%s"
-#: ../lib/python/temporal/space_time_datasets.py:267
-msgid "Unable to remove timestamp for raster map <%s>"
-#: ../lib/python/temporal/space_time_datasets.py:326
-#: ../lib/python/temporal/space_time_datasets.py:342
-#, fuzzy
-msgid "Unable to read range file"
-msgstr "Nevar atvērt 'temp'/pagaidu failu"
-#: ../lib/python/temporal/space_time_datasets.py:614
-msgid "Unable to read timestamp file for 3D raster map <%s>"
-#: ../lib/python/temporal/space_time_datasets.py:633
-msgid "Unable to create timestamp file for raster3d map <%s>"
-#: ../lib/python/temporal/space_time_datasets.py:637
-msgid "Invalid datetime in timestamp for raster3d map <%s>"
+#: ../lib/raster/color_rules.c:328
+#, c-format
+msgid "Unable to load color rules <%s>"
 msgstr ""
-"%s"
-#: ../lib/python/temporal/space_time_datasets.py:648
-msgid "Unable to remove timestamp for raster3d map <%s>"
+#: ../lib/raster/raster_metadata.c:109
+#, fuzzy, c-format
+msgid "Unable to read <%s> for raster map <%s@%s>"
-#: ../lib/python/temporal/space_time_datasets.py:677
-msgid "Raster3d map <%s> not found"
-#: ../lib/python/temporal/space_time_datasets.py:720
-msgid "Unable to load range of 3D raster map <%s>"
+#: ../lib/raster/raster_metadata.c:119 ../lib/raster/raster_metadata.c:148
+#, fuzzy, c-format
+msgid "Error closing <%s> metadata file for raster map <%s@%s>"
-#: ../lib/python/temporal/space_time_datasets.py:964
-msgid "Unable to read timestamp file for vector map <%s>"
+#: ../lib/raster/raster_metadata.c:142
+#, fuzzy, c-format
+msgid "Unable to create <%s> metadata file for raster map <%s@%s>"
-#: ../lib/python/temporal/space_time_datasets.py:984
-msgid "Unable to create timestamp file for vector map <%s>"
+#: ../lib/raster/put_row.c:120
+#, fuzzy, c-format
+msgid "Error writing uncompressed FP data for row %d of <%s>"
-#: ../lib/python/temporal/space_time_datasets.py:988
-msgid "Invalid datetime in timestamp for vector map <%s>"
-msgstr ""
-"%s"
+#: ../lib/raster/put_row.c:130
+#, fuzzy, c-format
+msgid "Error writing compressed FP data for row %d of <%s>"
-#: ../lib/python/temporal/space_time_datasets.py:1001
-msgid "Unable to remove timestamp for vector map <%s>"
+#: ../lib/raster/put_row.c:389 ../lib/raster/put_row.c:395
+#, fuzzy, c-format
+msgid "Error writing compressed data for row %d of <%s>"
-#: ../lib/python/temporal/space_time_datasets.py:1046
-msgid "Open map without topology support"
-msgstr ""
+#: ../lib/raster/put_row.c:405
+#, fuzzy, c-format
+msgid "Error writing uncompressed data for row %d of <%s>"
-#: ../lib/python/script/raster.py:47
-msgid ""
-"Unable to write history for <%(map)s>. Raster map <%(map)s> not found in "
-"current mapset."
-msgstr ""
-"Nevar izdzēst līniju, karte '%s' karte nav atvērta rakstīšanas 'write' "
-"režijmā"
+#: ../lib/raster/put_row.c:464
+#, fuzzy, c-format
+msgid "Error writing data via GDAL for row %d of <%s>"
+msgstr "Kļūdu rakstīšana ārpus telpisko datu index faila.\n"
-#: ../lib/python/script/raster.py:105
-msgid "An error occurred while running r.mapcalc"
-msgstr ""
+#: ../lib/raster/put_row.c:488
+#, fuzzy, c-format
+msgid "No null file for <%s>"
-#: ../lib/python/script/raster.py:162
-#, fuzzy
-msgid "No data"
-#: ../lib/python/script/raster.py:170
-msgid "value"
+#: ../lib/raster/put_row.c:502
+msgid "GDAL output doesn't support writing null rows separately"
 msgstr ""
-msgid "label"
-msgstr ""
+#: ../lib/raster/put_row.c:522
+#, fuzzy, c-format
+msgid "Unable to find a temporary null file <%s>"
+msgstr "neispējami atrast pagaidu null failu: %s"
-msgid "color"
-msgstr ""
+#: ../lib/raster/put_row.c:527
+#, fuzzy, c-format
+msgid "Unable to open null file <%s>"
+msgstr "G_spawn: neispējami atvērt failu %s"
-#: ../lib/python/script/core.py:849
-msgid "Mixing value types. Will try to compare after integer conversion"
-msgstr ""
+#: ../lib/raster/put_row.c:554 ../lib/raster/put_row.c:557
+#, fuzzy, c-format
+msgid "Error writing null row %d"
+msgstr "Kļūdas rakstīšana null row %d"
-#: ../lib/python/script/core.py:864
-#, python-format
-msgid "Several keys (%(miss)i out of %(a)i) are missing in the target file"
-msgstr ""
+#: ../lib/raster/put_row.c:682
+#, fuzzy, c-format
+msgid "put_raster_row: raster map <%s> not open for write - request ignored"
-#: ../lib/python/script/core.py:1075
-#, python-format
-msgid "Element type should be \"cell\" and not \"%s\""
-msgstr ""
-#: ../lib/python/script/core.py:1104 ../lib/python/script/core.py:1194
-#: ../lib/python/script/core.py:1249
-#, python-format
-msgid "Element type should be \"rast\" and not \"%s\""
-msgstr ""
-#: ../lib/python/script/core.py:1450
+#: ../lib/raster/put_row.c:689
 #, fuzzy
-msgid "Unable to list mapsets"
-msgstr "Neisespējami atvērt %s"
+msgid "put_raster_row: unopened file descriptor - request ignored"
-#: ../lib/python/script/core.py:1486
-#, python-format
-msgid "Location <%s> already exists. Operation canceled."
-msgstr ""
+#: ../lib/raster/mask_info.c:43
+#, c-format
+msgid "<%s> in mapset <%s>"
+msgstr "<%s>karšu kopā <%s>"
-#: ../lib/python/script/core.py:1489
-msgid "Location <%s> already exists and will be overwritten"
+#: ../lib/raster/mask_info.c:46
+msgid "none"
+msgstr "neviens"
-#: ../lib/python/script/core.py:1621
-msgid "Illegal filename <%s>. Cannot be 'NULL' or start with '.'."
-msgstr "Neatļauts faila nosaukums.  Nevar būt '.' vai 'NULL'\n"
-#: ../lib/python/script/core.py:1630
-msgid "Illegal filename <%(s)s>. <%(il)s> not allowed.\n"
-msgstr "Neatļauts faila nosaukums. zīme <%c> nav atļauta.\n"
-#: ../lib/python/script/raster3d.py:89
-msgid "An error occurred while running r3.mapcalc"
-msgstr ""
-#: ../lib/python/script/task.py:52
-#, fuzzy
-msgid "unknown"
+#: ../lib/raster/mask_info.c:49
+msgid "not known"
 msgstr "nav zināms"
-#: ../lib/python/script/task.py:166
-#, python-format
-msgid "Parameter element '%(element)s' not found: '%(value)s'"
-msgstr ""
-#: ../lib/python/script/task.py:181
-msgid "Flag not found: %s"
-msgstr "%s nav atrasts"
-#: ../lib/python/script/task.py:200
-#, python-format
-msgid "Parameter '%(name)s' (%(desc)s) is missing."
-msgstr ""
-#: ../lib/python/script/task.py:231
+#: ../lib/raster/sample.c:70
 #, fuzzy
-msgid "<required>"
-msgstr "prasītais: %s\n"
+msgid "Unknown interpolation type"
+msgstr "nezināns interpolācijas tips"
-#: ../lib/python/script/task.py:485 ../lib/python/script/task.py:489
-#, python-format
-msgid ""
-"Unable to fetch interface description for command '%(cmd)s'.\n"
-"\n"
-"Details: %(det)s"
+#: ../lib/raster/sample.c:327
+msgid "\"no data\" label found; setting to zero"
 msgstr ""
-#: ../lib/python/script/db.py:48 ../lib/vector/Vlib/ascii.c:431
-#: ../lib/db/dbmi_client/column.c:136
-#, fuzzy, c-format, python-format
-msgid "Unable to describe table <%s>"
-#: ../lib/python/script/db.py:142
-#, python-format
+#: ../lib/raster/get_cellhd.c:66
+#, fuzzy, c-format
 msgid ""
-"Programmer error: '%(sql)s', '%(filename)s', or '%(table)s' must be provided"
+"Unable to read header file for raster map <%s@%s>.It is a reclass of raster "
+"map <%s@%s> %s"
 msgstr ""
+"kas neeksistē"
-#: ../lib/python/script/db.py:154
+#: ../lib/raster/get_cellhd.c:70
 #, fuzzy
-msgid "Fetching data failed"
+msgid "which is missing."
+msgstr "kurš ir trūkstošs"
-#: ../lib/python/script/vector.py:88
-#, python-format
-msgid "Database connection not defined for layer %s"
+#: ../lib/raster/get_cellhd.c:71
+msgid "whose header file can't be opened."
 msgstr ""
-#: ../lib/python/script/vector.py:238
-msgid "Missing layer %(layer)d in vector map <%(map)s>"
+#: ../lib/raster/get_cellhd.c:76
+#, fuzzy, c-format
+msgid "Unable to open header file for raster map <%s@%s>"
-#: ../lib/python/script/vector.py:256
-msgid "vector_db_select() failed"
+#: ../lib/raster/range.c:102 ../lib/raster/range.c:110
+#, c-format
+msgid "Unable to read fp range file for <%s>"
 msgstr ""
-#: ../lib/pngdriver/Graph_set.c:84
+#: ../lib/raster/range.c:169
 #, c-format
-msgid "png: truecolor status %s"
+msgid "Unable to read quant rules for raster map <%s>"
 msgstr ""
-#: ../lib/pngdriver/Graph_set.c:85 ../lib/psdriver/Graph_set.c:200
-msgid "enabled"
-msgstr ""
-msgid "disabled"
-msgstr ""
-#: ../lib/pngdriver/Graph_set.c:132
+#: ../lib/raster/range.c:206 ../lib/raster/range.c:226
 #, c-format
-msgid "png: collecting to file '%s'"
+msgid "Unable to read range file for <%s>"
 msgstr ""
-#: ../lib/pngdriver/Graph_set.c:133
+#: ../lib/raster/range.c:264 ../lib/raster/range.c:270
+#: ../lib/raster/range.c:300 ../lib/raster/range.c:314
 #, c-format
-msgid "png: image size %dx%d"
+msgid "Unable to write range file for <%s>"
 msgstr ""
-#: ../lib/manage/read_list.c:73
-#, fuzzy, c-format
-msgid "Unable to open data base element list '%s'"
-msgstr "neispējami atvērt datumu tabulas failu: %s"
+#: ../lib/raster/auto_mask.c:69
+msgid "Unable to open automatic MASK file"
+msgstr "Neiespējami atvērt automātisku MASK failu"
-#: ../lib/manage/read_list.c:134
+#: ../lib/raster/put_title.c:28
 #, c-format
-msgid "Format error: file ('%s') line (%d) - %s"
-msgstr ""
+msgid "category information for [%s] in [%s] missing or invalid"
+msgstr "kategorijas informācija priekš [%s] iekš [%s] trūkst vai ir nederīga"
-#: ../lib/manage/do_remove.c:42
-#, fuzzy, c-format
-msgid "Removing %s <%s>"
-msgstr "neiespējami atrast [%s]"
+#: ../lib/raster/put_title.c:37
+msgid "G_put_title - can't create a temp file"
+msgstr "G_put_title - nevar izveidot pagaidu failu"
-#: ../lib/manage/do_remove.c:65
-#, fuzzy
-msgid "Unable to delete vector map"
+#: ../lib/raster/put_title.c:53
+#, c-format
+msgid "category information for [%s] in [%s] invalid"
-#: ../lib/manage/do_remove.c:85
-#, fuzzy, c-format
-msgid "Unable to remove %s element"
+#: ../lib/raster/put_title.c:60
+msgid "G_put_title - can't reopen temp file"
+msgstr ""
-#: ../lib/manage/do_remove.c:89 ../lib/manage/do_remove.c:109
-#: ../lib/manage/do_copy.c:63 ../lib/manage/do_rename.c:87
-#: ../lib/manage/do_rename.c:107
-#, fuzzy, c-format
-msgid "%s is missing"
-msgstr "kurš ir trūkstošs"
-#: ../lib/manage/do_remove.c:92 ../lib/manage/do_remove.c:112
+#: ../lib/raster/put_title.c:67
 #, c-format
-msgid "%s removed"
+msgid "can't write category information for [%s] in [%s]"
+msgstr "nevar ierakstīt kategorijas informāciju priekš [%s] iekš [%s]"
+#: ../lib/raster/init.c:61
+msgid "Raster library not initialized. Programmer forgot to call Rast_init()."
 msgstr ""
-#: ../lib/manage/do_remove.c:105
+#: ../lib/raster/quant_io.c:43
 #, fuzzy, c-format
-msgid "Unable to remove %s"
+msgid "Floating data range for raster map <%s> is empty"
+msgstr "'Peldošo' datu dipazons priekš %s@%s ir tukšs"
-#: ../lib/manage/do_remove.c:121
-#, c-format
-msgid "<%s> nothing removed"
-msgstr ""
+#: ../lib/raster/quant_io.c:52
+#, fuzzy, c-format
+msgid "Integer data range for raster map <%s> is empty"
+msgstr "Veselo skaitļu datu diapazons priekš %s@%s ir tukšs"
-#: ../lib/manage/do_copy.c:43
+#: ../lib/raster/quant_io.c:105
 #, fuzzy, c-format
-msgid "Copy %s <%s> to current mapset as <%s>"
-msgstr "nav %s faili pieejami pašreizējā karšu biblotēkā\n"
+msgid "Attempt to open quantization table for CELL raster map <%s>"
+msgstr "neispējami mainīt direktoriju uz %s"
-#: ../lib/manage/do_copy.c:52
+#: ../lib/raster/quant_io.c:135
 #, fuzzy, c-format
-msgid "Unable to copy <%s> to current mapset as <%s>"
+msgid "Quantization file for raster map <%s> is missing"
-#: ../lib/manage/do_copy.c:72
-#, c-format
-msgid "%s copied"
-msgstr ""
-#: ../lib/manage/option.c:47
+#: ../lib/raster/quant_io.c:145
 #, fuzzy, c-format
-msgid "%s to be %s"
-msgstr "%s izpildīts. %s"
+msgid "Quantization file for raster map <%s> is empty"
-#: ../lib/manage/option.c:51
-msgid "Raster"
-msgstr ""
+#: ../lib/raster/null_val.c:64
+#, fuzzy
+msgid "EmbedGivenNulls: wrong data type"
+msgstr "EmbedGivenNulls: nepareizs datu tips!"
-#: ../lib/manage/option.c:55
-msgid "Vector"
-msgstr ""
+#: ../lib/raster/null_val.c:114
+#, fuzzy
+msgid "Rast_set_null_value: wrong data type!"
+msgstr "G_set_null_value: nepareizs datu tips!"
-#: ../lib/manage/option.c:57
-msgid "Region"
+#: ../lib/display/tran_colr.c:107 ../lib/display/tran_colr.c:109
+#, c-format
+msgid "[%s]: No such color"
 msgstr ""
-#: ../lib/manage/option.c:59
-msgid "Group"
+#: ../lib/display/r_raster.c:113
+#, c-format
+msgid "%s variable defined, %s ignored"
 msgstr ""
-#: ../lib/manage/do_list.c:30
+#: ../lib/display/r_raster.c:148
 #, fuzzy, c-format
-msgid "%s: invalid index %d"
-msgstr ""
-"\n"
-"%s nederīgs; Meiģini vēlreiz > "
+msgid "Unknown display driver <%s>"
-#: ../lib/manage/do_rename.c:42
+#: ../lib/display/r_raster.c:149
 #, fuzzy, c-format
-msgid "Rename %s <%s> to <%s>"
+msgid "Using display driver <%s>..."
-#: ../lib/manage/do_rename.c:62
+#: ../lib/display/r_raster.c:215
 #, fuzzy, c-format
-msgid "Unable to rename vector map <%s> to <%s>"
+msgid "Unable to open file '%s'"
-#: ../lib/manage/do_rename.c:83 ../lib/manage/do_rename.c:103
+#: ../lib/display/icon.c:80
 #, fuzzy, c-format
-msgid "Unable to rename %s"
+msgid "Unsupported icon %d"
-#: ../lib/manage/do_rename.c:90 ../lib/manage/do_rename.c:110
-#, c-format
-msgid "%s renamed"
-msgstr ""
-#: ../lib/manage/do_rename.c:119
-#, c-format
-msgid "<%s> nothing renamed"
-msgstr ""
-#: ../lib/gpde/N_parse_options.c:106
-msgid "The calculation time in seconds"
-msgstr ""
-#: ../lib/gpde/test/test_main.c:88
-msgid "Performs unit and integration tests for gpde library"
-msgstr ""
-#: ../lib/gpde/N_arrays_io.c:93
+#: ../lib/vector/diglib/port_init.c:158
 #, fuzzy, c-format
-msgid "Reading raster map <%s> into memory"
-msgstr " Rastra karte %s@%s ir tukša"
+msgid "Unable to find '%x' in %s"
-#: ../lib/gpde/N_arrays_io.c:183
-msgid "N_array_2d * array is empty"
-msgstr ""
-#: ../lib/gpde/N_arrays_io.c:202
+#: ../lib/vector/diglib/plus_area.c:217 ../lib/vector/diglib/plus_area.c:719
 #, c-format
-msgid "Write 2d array to raster map <%s>"
+msgid "Line %d already has area/isle %d to left"
 msgstr ""
-#: ../lib/gpde/N_arrays_io.c:309
+#: ../lib/vector/diglib/plus_area.c:227 ../lib/vector/diglib/plus_area.c:727
 #, c-format
-msgid "Read g3d map <%s> into the memory"
+msgid "Line %d already has area/isle %d to right"
 msgstr ""
-#: ../lib/gpde/N_arrays_io.c:364 ../lib/gpde/N_arrays_io.c:464
-msgid "Error closing g3d file"
+#: ../lib/vector/diglib/plus_area.c:281
+msgid "Isle already registered in area"
 msgstr ""
-#: ../lib/gpde/N_arrays_io.c:420
-#, c-format
-msgid "Error opening g3d map <%s>"
+#: ../lib/vector/diglib/plus_area.c:315
+msgid "Attempt to delete isle from dead area"
 msgstr ""
-#: ../lib/gpde/N_arrays_io.c:422
+#: ../lib/vector/diglib/plus_area.c:332
 #, c-format
-msgid "Write 3d array to g3d map <%s>"
+msgid "Attempt to delete not registered isle %d from area %d"
 msgstr ""
-#: ../lib/gpde/N_gwflow.c:436 ../lib/gpde/N_gwflow.c:715
-#, c-format
-msgid "The total sum of the water budget: %g\n"
+#: ../lib/vector/diglib/plus_area.c:371
+msgid "Attempt to delete dead area"
 msgstr ""
-#: ../lib/gpde/N_gwflow.c:438 ../lib/gpde/N_gwflow.c:717
+#: ../lib/vector/diglib/plus_area.c:412
 #, c-format
-msgid "The total sum of the water budget is significant larger then 0: %g\n"
+msgid "Dead centroid %d registered for area (bug in the vector library)"
 msgstr ""
-#: ../lib/arraystats/class.c:21
-msgid "Discont algorithm currently not available because of bugs"
-msgstr ""
-#: ../lib/arraystats/class.c:23
-#, c-format
-msgid "%s: Unknown algorithm"
-msgstr ""
-#: ../lib/arraystats/class.c:26
-#, c-format
-msgid "%s: Error in classification algorithm"
-msgstr ""
-#: ../lib/arraystats/class.c:221
-#, c-format
-msgid ""
-"There are classbreaks outside the range min-max. Number of classes reduced "
-"to %i, but using probabilities for %i classes."
-msgstr ""
-#: ../lib/vector/neta/utils.c:195
+#: ../lib/vector/diglib/plus_area.c:437
 #, fuzzy, c-format
-msgid "Point %d is not connected!"
+msgid "Attempt to delete area %d info from dead isle %d"
-#: ../lib/vector/neta/utils.c:230
-#, c-format
-msgid "'%s' must be > 0"
-msgstr ""
-#: ../lib/vector/neta/utils.c:239
-msgid "'where' and 'cats' parameters were supplied, cat will be ignored"
-msgstr ""
-#: ../lib/vector/neta/utils.c:242
-#, fuzzy
-msgid "Unable to load data from database"
-msgstr "Nevar pievienot datubāzes saiti"
-#: ../lib/vector/neta/utils.c:249
-#, fuzzy
-msgid "Problem loading category values"
-msgstr "eksistējošām rastra kartēm %d"
-#: ../lib/vector/neta/flow.c:310 ../lib/vector/Vlib/net.c:444
-#: ../lib/vector/Vlib/graph.c:105
-msgid "GngFlatten error"
-msgstr ""
-#: ../lib/vector/neta/timetables.c:46 ../lib/vector/neta/timetables.c:203
-#: ../lib/vector/neta/timetables.c:244 ../lib/vector/neta/timetables.c:286
+#: ../lib/vector/diglib/plus_area.c:787
 #, fuzzy, c-format
-msgid "Unable to open select cursor: %s"
+msgid "Attempt to delete isle %d info from dead area %d"
-#: ../lib/vector/neta/spanningtree.c:104
-msgid "Computing minimum spanning tree..."
-msgstr ""
-#: ../lib/vector/diglib/plus_node.c:214
-#, c-format
-msgid ""
-"Attempt to read line angle for the line which is not connected to the node: "
-"node %d, line %d"
-msgstr ""
-#: ../lib/vector/diglib/cindex_rw.c:156
-#, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this category index format. "
-"Try to rebuild topology or upgrade GRASS to at least version %d."
-msgstr ""
 #: ../lib/vector/diglib/file.c:159
 msgid "Writing to file loaded to memory not supported"
 msgstr ""
@@ -4247,47 +3584,11 @@
 msgid "Vector memory mode not supported, using 'AUTO'"
 msgstr ""
-#: ../lib/vector/diglib/spindex_rw.c:98 ../lib/vector/diglib/spindex_rw.c:106
-#, fuzzy
-msgid "Topology file must be written before spatial index file"
-msgstr "Kļūdu rakstīšana ārpus telpisko datu index faila.\n"
-#: ../lib/vector/diglib/spindex_rw.c:302
-#, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this spatial index format. "
+#: ../lib/vector/diglib/portable.c:208 ../lib/vector/diglib/portable.c:241
+#: ../lib/vector/diglib/portable.c:683 ../lib/vector/diglib/plus_struct.c:563
+msgid "Vector exceeds supported file size limit"
 msgstr ""
-#: ../lib/vector/diglib/spindex_rw.c:308
-#, c-format
-msgid ""
-"Your GRASS version does not fully support spatial index format %d.%d of the "
-"vector. Consider to rebuild topology or upgrade GRASS."
-msgstr ""
-#: ../lib/vector/diglib/spindex_rw.c:317
-#, c-format
-msgid ""
-"Spatial index format version %d.%d is not supported by this release. Please "
-"rebuild topology."
-msgstr ""
-#: ../lib/vector/diglib/frmt.c:45 ../lib/vector/diglib/frmt.c:70
-#, fuzzy, c-format
-msgid "Vector format not recognized: %s"
-#: ../lib/vector/diglib/frmt.c:79 ../lib/vector/diglib/frmt.c:88
-#, fuzzy, c-format
-msgid "Vector format '%s' not supported"
-msgstr "Vect_write_line() šim formātam/līmenim nav atbalstīta"
-#: ../lib/vector/diglib/frmt.c:97
-#, c-format
-msgid "Format definition is not correct: %s"
-msgstr ""
 #: ../lib/vector/diglib/plus.c:222
 #, fuzzy
 msgid "Unable read topology for nodes"
@@ -4353,11 +3654,98 @@
 msgid "Unable to write isles to plus file"
 msgstr "neiespējami rakstīt quant failu!"
-#: ../lib/vector/diglib/port_init.c:158
+#: ../lib/vector/diglib/cindex_rw.c:156
+#, c-format
+msgid ""
+"This version of GRASS (%d.%d) is too old to read this category index format. "
+"Try to rebuild topology or upgrade GRASS to at least version %d."
+msgstr ""
+#: ../lib/vector/diglib/test.c:58
+#, fuzzy
+msgid "Unable to open test.tmp file"
+#: ../lib/vector/diglib/test.c:75
+#, c-format
+msgid ""
+"Error in read/write portable double, byte_order = %d Written: %.16e3E Read: "
+"%.16e3E"
+msgstr ""
+#: ../lib/vector/diglib/test.c:89
+#, c-format
+msgid ""
+"Error in read/write portable float, byte_order = %d Written: %.8e3E Read: "
+"%.8e3E"
+msgstr ""
+#: ../lib/vector/diglib/test.c:104
+#, c-format
+msgid "Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
+msgstr ""
+#: ../lib/vector/diglib/test.c:119
+#, c-format
+msgid "Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
+msgstr ""
+#: ../lib/vector/diglib/test.c:134
+#, c-format
+msgid "Error in read/write portable int, byte_order = %d Written: %d Read: %d"
+msgstr ""
+#: ../lib/vector/diglib/test.c:150
+#, c-format
+msgid "Error in read/write portable short, byte_order = %d Written: %d Read: %d"
+msgstr ""
+#: ../lib/vector/diglib/test.c:165
+#, c-format
+msgid "Error in read/write portable char, byte_order = %d Written: %d Read: %d"
+msgstr ""
+#: ../lib/vector/diglib/spindex_rw.c:98 ../lib/vector/diglib/spindex_rw.c:106
+#, fuzzy
+msgid "Topology file must be written before spatial index file"
+#: ../lib/vector/diglib/spindex_rw.c:302
+#, c-format
+msgid ""
+"This version of GRASS (%d.%d) is too old to read this spatial index format. "
+msgstr ""
+#: ../lib/vector/diglib/spindex_rw.c:308
+#, c-format
+msgid ""
+"Your GRASS version does not fully support spatial index format %d.%d of the "
+"vector. Consider to rebuild topology or upgrade GRASS."
+msgstr ""
+#: ../lib/vector/diglib/spindex_rw.c:317
+#, c-format
+msgid ""
+"Spatial index format version %d.%d is not supported by this release. Please "
+"rebuild topology."
+msgstr ""
+#: ../lib/vector/diglib/frmt.c:45 ../lib/vector/diglib/frmt.c:70
 #, fuzzy, c-format
-msgid "Unable to find '%x' in %s"
+msgid "Vector format not recognized: %s"
+msgstr "Ieejas vektors '%s' nav atrasts"
+#: ../lib/vector/diglib/frmt.c:79 ../lib/vector/diglib/frmt.c:88
+#, fuzzy, c-format
+msgid "Vector format '%s' not supported"
+msgstr "Vect_write_line() šim formātam/līmenim nav atbalstīta"
+#: ../lib/vector/diglib/frmt.c:97
+#, c-format
+msgid "Format definition is not correct: %s"
+msgstr ""
 #: ../lib/vector/diglib/spindex.c:450
 #, fuzzy, c-format
 msgid "Unable to delete node %d from spatial index"
@@ -4383,256 +3771,499 @@
 msgid "Unable to delete isle %d from spatial index"
-#: ../lib/vector/diglib/plus_area.c:217 ../lib/vector/diglib/plus_area.c:719
+#: ../lib/vector/diglib/plus_node.c:214
 #, c-format
-msgid "Line %d already has area/isle %d to left"
+msgid ""
+"Attempt to read line angle for the line which is not connected to the node: "
+"node %d, line %d"
 msgstr ""
-#: ../lib/vector/diglib/plus_area.c:227 ../lib/vector/diglib/plus_area.c:727
+#: ../lib/vector/diglib/struct_alloc.c:491
+#, fuzzy
+msgid "Out of memmory"
+msgstr "Neiespējami piešķirt atmiņu\n"
+#: ../lib/vector/diglib/plus_struct.c:523
 #, c-format
-msgid "Line %d already has area/isle %d to right"
+msgid ""
+"This version of GRASS (%d.%d) is too old to read this topology format. Try "
+"to rebuild topology or upgrade GRASS to at least version %d."
 msgstr ""
-#: ../lib/vector/diglib/plus_area.c:281
-msgid "Isle already registered in area"
+#: ../lib/vector/diglib/plus_struct.c:529
+#, c-format
+msgid ""
+"Your GRASS version does not fully support topology format %d.%d of the "
 msgstr ""
-#: ../lib/vector/diglib/plus_area.c:315
-msgid "Attempt to delete isle from dead area"
+#: ../lib/vector/diglib/plus_struct.c:539
+#, c-format
+msgid ""
+"Old topology format version %d.%d is not supported by this release. Try to "
 msgstr ""
-#: ../lib/vector/diglib/plus_area.c:332
-#, c-format
-msgid "Attempt to delete not registered isle %d from area %d"
+#: ../lib/vector/Vlib/intersect.c:127
+msgid "3D not supported by Vect_segment_intersection()"
 msgstr ""
-#: ../lib/vector/diglib/plus_area.c:371
-msgid "Attempt to delete dead area"
+#: ../lib/vector/Vlib/intersect.c:313
+msgid "Vect_segment_intersection() ERROR (collinear vertical segments)"
 msgstr ""
-#: ../lib/vector/diglib/plus_area.c:412
-#, c-format
-msgid "Dead centroid %d registered for area (bug in the vector library)"
+#: ../lib/vector/Vlib/intersect.c:407
+msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
 msgstr ""
-#: ../lib/vector/diglib/plus_area.c:437
+#: ../lib/vector/Vlib/intersect.c:1157 ../lib/vector/Vlib/intersect.c:1163
+#: ../lib/vector/Vlib/intersect.c:1165 ../lib/vector/Vlib/intersect.c:1219
+#: ../lib/vector/Vlib/intersect.c:1228 ../lib/vector/Vlib/intersect.c:1249
+#: ../lib/vector/Vlib/intersect.c:1266
+msgid "Error while adding point to array. Out of memory"
+msgstr ""
+#: ../lib/vector/Vlib/read.c:25 ../lib/vector/Vlib/write.c:30
+#: ../lib/vector/Vlib/write.c:36 ../lib/vector/Vlib/write.c:42
+#: ../lib/vector/Vlib/write.c:49
+#, fuzzy
+msgid "for this format/level not supported"
+#: ../lib/vector/Vlib/read.c:32 ../lib/vector/Vlib/rewind.c:29
+#: ../lib/vector/Vlib/close.c:38 ../lib/vector/Vlib/build.c:37
+#: ../lib/vector/Vlib/open.c:59 ../lib/vector/Vlib/write.c:56
+#: ../lib/vector/Vlib/write.c:62
+msgid "Requested format is not compiled in this version"
+msgstr "Pieprasītais formāts nav pieejams/iekļauts šijā versijā"
+#: ../lib/vector/Vlib/read.c:93 ../lib/vector/Vlib/read.c:129
+#: ../lib/vector/Vlib/read.c:168
+#, fuzzy
+msgid "Vector map is not open for reading"
+#: ../lib/vector/Vlib/read.c:136 ../lib/vector/Vlib/read.c:180
 #, fuzzy, c-format
-msgid "Attempt to delete area %d info from dead isle %d"
-msgstr "Nevar nolasīt histogrammu priekš [%s no %s]"
+msgid "Unable to read feature %d from vector map <%s>"
-#: ../lib/vector/diglib/plus_area.c:787
+#: ../lib/vector/Vlib/read.c:173 ../lib/vector/Vlib/box.c:240
+#: ../lib/vector/Vlib/write_pg.c:236 ../lib/vector/Vlib/write_pg.c:376
+#: ../lib/vector/Vlib/write_pg.c:391 ../lib/vector/Vlib/write_sfa.c:155
+#: ../lib/vector/Vlib/write_sfa.c:204 ../lib/vector/Vlib/write.c:233
+#: ../lib/vector/Vlib/write.c:278 ../lib/vector/Vlib/write.c:319
+#: ../lib/vector/Vlib/write_nat.c:265 ../lib/vector/Vlib/write_nat.c:362
+#: ../lib/vector/Vlib/write_nat.c:595 ../lib/vector/Vlib/read_sfa.c:50
+#: ../lib/vector/Vlib/read_nat.c:144 ../lib/vector/Vlib/read_pg.c:331
 #, fuzzy, c-format
-msgid "Attempt to delete isle %d info from dead area %d"
+msgid "Attempt to access feature with invalid id (%d)"
-#: ../lib/vector/diglib/struct_alloc.c:491
-#, fuzzy
-msgid "Out of memmory"
-msgstr "Neiespējami piešķirt atmiņu\n"
+#: ../lib/vector/Vlib/remove_areas.c:109 ../lib/vector/Vlib/remove_areas.c:274
+msgid "Area is composed of dead boundary"
+msgstr ""
-#: ../lib/vector/diglib/portable.c:208 ../lib/vector/diglib/portable.c:241
-#: ../lib/vector/diglib/portable.c:683 ../lib/vector/diglib/plus_struct.c:563
-msgid "Vector exceeds supported file size limit"
+#: ../lib/vector/Vlib/remove_areas.c:196 ../lib/vector/Vlib/remove_areas.c:598
+#, c-format
+msgid "%d areas of total size %g removed"
 msgstr ""
-#: ../lib/vector/diglib/test.c:58
+#: ../lib/vector/Vlib/remove_areas.c:401
+msgid "Could not delete line from coor"
+msgstr ""
+#: ../lib/vector/Vlib/remove_areas.c:458 ../lib/vector/Vlib/remove_areas.c:492
+msgid "Failed to build new area"
+msgstr "Neizdevās izveidot jaunu laukumu"
+#: ../lib/vector/Vlib/remove_areas.c:463 ../lib/vector/Vlib/remove_areas.c:496
+msgid "Dissolve with neighbour area: corrupt topology"
+msgstr ""
+#: ../lib/vector/Vlib/remove_areas.c:477 ../lib/vector/Vlib/remove_areas.c:560
+msgid "Neighbor boundaries should be complete"
+msgstr ""
+#: ../lib/vector/Vlib/remove_areas.c:541 ../lib/vector/Vlib/remove_areas.c:568
+msgid "Failed to build new isle"
+msgstr "Neizdevās izveidot jaunu salu"
+#: ../lib/vector/Vlib/remove_areas.c:546 ../lib/vector/Vlib/remove_areas.c:573
+msgid "Dissolve with outer isle: corrupt topology"
+msgstr ""
+#: ../lib/vector/Vlib/remove_areas.c:579
+msgid "Area merging failed"
+msgstr "Laukumu apvienošana bija nesekmīga"
+#: ../lib/vector/Vlib/dgraph.c:432
+msgid ""
+"Trying to add more edges to the planar_graph than the initial allocation "
+"size allows"
+msgstr ""
+#: ../lib/vector/Vlib/net.c:117
+msgid "Building graph..."
+msgstr "Tiek veidots grafs..."
+#: ../lib/vector/Vlib/net.c:159
+msgid "Unable to build network graph"
+msgstr "Nav iespējams izveidot tīkla grafu"
+#: ../lib/vector/Vlib/net.c:165
+msgid "Forward costs column not specified"
+msgstr ""
+#: ../lib/vector/Vlib/net.c:172
+msgid "Arc field < 1"
+msgstr ""
+#: ../lib/vector/Vlib/net.c:186 ../lib/vector/Vlib/net.c:203
+#: ../lib/vector/Vlib/net.c:363 ../lib/vector/Vlib/ascii.c:730
+#, fuzzy, c-format
+msgid "Column <%s> not found in table <%s>"
+msgstr "Nevar atvērt datubāzi %s"
+#: ../lib/vector/Vlib/net.c:192 ../lib/vector/Vlib/net.c:209
+#: ../lib/vector/Vlib/net.c:369
+#, c-format
+msgid "Data type of column <%s> not supported (must be numeric)"
+msgstr ""
+#: ../lib/vector/Vlib/net.c:222
 #, fuzzy
-msgid "Unable to open test.tmp file"
+msgid "Registering arcs..."
+msgstr "Saglabājam/reģistrējam līnijas"
-#: ../lib/vector/diglib/test.c:75
+#: ../lib/vector/Vlib/net.c:251
 #, c-format
 msgid ""
-"Error in read/write portable double, byte_order = %d Written: %.16e3E Read: "
-"%.16e3E"
+"Database record for line %d (cat = %d, forward/both direction(s)) not found "
+"(forward/both direction(s) of line skipped)"
 msgstr ""
-#: ../lib/vector/diglib/test.c:89
+#: ../lib/vector/Vlib/net.c:270
 #, c-format
 msgid ""
-"Error in read/write portable float, byte_order = %d Written: %.8e3E Read: "
-"%.8e3E"
+"Database record for line %d (cat = %d, backword direction) not "
+"found(direction of line skipped)"
 msgstr ""
-#: ../lib/vector/diglib/test.c:104
+#: ../lib/vector/Vlib/net.c:319
+#, fuzzy
+msgid "Cannot add network arc"
+msgstr "Nevar atvērt topo failu rakstīšanai: %s\n"
+#: ../lib/vector/Vlib/net.c:349
+msgid "Setting node costs..."
+msgstr ""
+#: ../lib/vector/Vlib/net.c:412
 #, c-format
-msgid ""
-"Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
+msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
 msgstr ""
-#: ../lib/vector/diglib/test.c:119
+#: ../lib/vector/Vlib/net.c:441
+#, fuzzy
+msgid "Flattening the graph..."
+msgstr "Veidojam topoloģiju... \n"
+#: ../lib/vector/Vlib/net.c:444 ../lib/vector/Vlib/graph.c:105
+#: ../lib/vector/neta/flow.c:310
+msgid "GngFlatten error"
+msgstr ""
+#: ../lib/vector/Vlib/net.c:450
+msgid "Graph was built"
+msgstr "Grafs ir izveidots"
+#: ../lib/vector/Vlib/net.c:533 ../lib/vector/Vlib/graph.c:226
 #, c-format
-msgid ""
-"Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
+msgid "dglShortestPath error: %s"
+msgstr "dglShortestPath kļūda: %s"
+#: ../lib/vector/Vlib/net.c:633
+msgid "Wrong line direction in Vect_net_get_line_cost()"
 msgstr ""
-#: ../lib/vector/diglib/test.c:134
+#: ../lib/vector/Vlib/array.c:96
 #, c-format
-msgid "Error in read/write portable int, byte_order = %d Written: %d Read: %d"
+msgid "%d errors in category string"
 msgstr ""
-#: ../lib/vector/diglib/test.c:150
+#: ../lib/vector/Vlib/array.c:142 ../lib/vector/Vlib/array.c:267
+msgid "Mixed area and other type requested for vector array"
+msgstr ""
+#: ../lib/vector/Vlib/array.c:152 ../lib/vector/Vlib/array.c:175
+#: ../lib/vector/Vlib/array.c:304 ../lib/vector/Vlib/array.c:336
+msgid "Not enough space in vector array"
+msgstr ""
+#: ../lib/vector/Vlib/array.c:292
 #, c-format
-msgid ""
-"Error in read/write portable short, byte_order = %d Written: %d Read: %d"
+msgid "Unable to select record from table <%s> (key %s, where %s)"
 msgstr ""
-#: ../lib/vector/diglib/test.c:165
+#: ../lib/vector/Vlib/build_sfa.c:279 ../lib/vector/Vlib/build_sfa.c:546
 #, c-format
-msgid "Error in read/write portable char, byte_order = %d Written: %d Read: %d"
+msgid "Unable to calculate centroid for area %d"
 msgstr ""
-#: ../lib/vector/diglib/plus_struct.c:523
+#: ../lib/vector/Vlib/build_sfa.c:305
 #, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this topology format. Try "
-"to rebuild topology or upgrade GRASS to at least version %d."
+msgid "Feature type %d not supported"
+msgstr "Objekta tips %d nav atbalstīts"
+#: ../lib/vector/Vlib/build_sfa.c:339 ../lib/vector/Vlib/build_sfa.c:629
+#: ../lib/vector/Vlib/build_nat.c:74
+msgid "Registering primitives..."
+msgstr "Reģistrē primitīvus..."
+#: ../lib/vector/Vlib/build_sfa.c:354 ../lib/vector/Vlib/build_sfa.c:364
+#: ../lib/vector/Vlib/read_pg.c:378
+#, fuzzy, c-format
+msgid "Feature %d without geometry skipped"
+msgstr "Bez centroīdiem esošu laukumu skaits :   %d\n"
+#: ../lib/vector/Vlib/build_sfa.c:385 ../lib/vector/Vlib/build_sfa.c:661
+#: ../lib/vector/Vlib/build_nat.c:117
+#, c-format
+msgid "One primitive registered"
+msgid_plural "%d primitives registered"
+msgstr[0] "Ir reģistrēts %d primitīvs"
+msgstr[1] "Ir reģistrēti %d primitīvi"
+msgstr[2] "Ir reģistrēts %d primitīvu"
+#: ../lib/vector/Vlib/build_sfa.c:386 ../lib/vector/Vlib/build_sfa.c:662
+#: ../lib/vector/Vlib/build_nat.c:118
+#, c-format
+msgid "One vertex registered"
+msgid_plural "%d vertices registered"
+msgstr[0] "Reģistrēta %d virsotne"
+msgstr[1] "Reģistrētas %d virsotnes"
+msgstr[2] "Reģistrēts %d virsotņu"
+#: ../lib/vector/Vlib/build_sfa.c:603 ../lib/vector/Vlib/read_ogr.c:344
+#: ../lib/vector/Vlib/read_ogr.c:578
+#, c-format
+msgid "OGR feature type %d not supported"
 msgstr ""
-#: ../lib/vector/diglib/plus_struct.c:529
+#: ../lib/vector/Vlib/build_sfa.c:665
 #, c-format
-msgid ""
-"Your GRASS version does not fully support topology format %d.%d of the "
+msgid "One feature without geometry skipped"
+msgid_plural "%d features without geometry skipped"
+msgstr[0] "Ir izlaists %d objekts bez ģeometrijas"
+msgstr[1] "Ir izlaisti %d objekti bez ģeometrijas"
+msgstr[2] "Ir izlaists %d objektu bez ģeometrijas"
+#: ../lib/vector/Vlib/build_sfa.c:718 ../lib/vector/Vlib/simple_features.c:336
+#: ../lib/vector/Vlib/close.c:275 ../lib/vector/Vlib/build_pg.c:117
+#: ../lib/vector/Vlib/rewind_pg.c:56 ../lib/vector/Vlib/rewind_pg.c:81
+#: ../lib/vector/Vlib/header_finfo.c:47 ../lib/vector/Vlib/header_finfo.c:86
+#: ../lib/vector/Vlib/header_finfo.c:123 ../lib/vector/Vlib/header_finfo.c:171
+#: ../lib/vector/Vlib/copy.c:404 ../lib/vector/Vlib/close_pg.c:96
+#: ../lib/vector/Vlib/close_pg.c:144 ../lib/vector/Vlib/area.c:94
+#: ../lib/vector/Vlib/area.c:466 ../lib/vector/Vlib/write_pg.c:124
+#: ../lib/vector/Vlib/write_pg.c:158 ../lib/vector/Vlib/write_pg.c:197
+#: ../lib/vector/Vlib/write_pg.c:289 ../lib/vector/Vlib/write_pg.c:349
+#: ../lib/vector/Vlib/write_pg.c:467 ../lib/vector/Vlib/open_pg.c:150
+#: ../lib/vector/Vlib/open_pg.c:207 ../lib/vector/Vlib/open_pg.c:313
+#: ../lib/vector/Vlib/open_pg.c:363 ../lib/vector/Vlib/write_sfa.c:299
+#: ../lib/vector/Vlib/read_pg.c:91 ../lib/vector/Vlib/read_pg.c:214
+#: ../lib/vector/Vlib/read_pg.c:298 ../lib/vector/Vlib/read_pg.c:416
+msgid "GRASS is not compiled with PostgreSQL support"
 msgstr ""
-#: ../lib/vector/diglib/plus_struct.c:539
+#: ../lib/vector/Vlib/build_sfa.c:722
 #, c-format
-msgid ""
-"Old topology format version %d.%d is not supported by this release. Try to "
+msgid "%s: Native format unsupported"
 msgstr ""
-#: ../lib/vector/Vlib/write_nat.c:265 ../lib/vector/Vlib/write_nat.c:362
-#: ../lib/vector/Vlib/write_nat.c:595 ../lib/vector/Vlib/read_nat.c:144
-#: ../lib/vector/Vlib/read_pg.c:325 ../lib/vector/Vlib/box.c:213
-#: ../lib/vector/Vlib/read.c:173 ../lib/vector/Vlib/write_sfa.c:155
-#: ../lib/vector/Vlib/write_sfa.c:204 ../lib/vector/Vlib/read_sfa.c:50
-#: ../lib/vector/Vlib/write.c:233 ../lib/vector/Vlib/write.c:278
-#: ../lib/vector/Vlib/write.c:319 ../lib/vector/Vlib/write_pg.c:233
-#: ../lib/vector/Vlib/write_pg.c:372 ../lib/vector/Vlib/write_pg.c:387
-#, fuzzy, c-format
-msgid "Attempt to access feature with invalid id (%d)"
+#: ../lib/vector/Vlib/build_sfa.c:748
+msgid "Feature index is built only for non-native formats. Nothing to dump."
+msgstr ""
-#: ../lib/vector/Vlib/write_nat.c:271 ../lib/vector/Vlib/write_nat.c:601
-#: ../lib/vector/Vlib/read_nat.c:150 ../lib/vector/Vlib/read_pg.c:331
-#: ../lib/vector/Vlib/read_sfa.c:56 ../lib/vector/Vlib/write_pg.c:239
-#: ../lib/vector/Vlib/write_pg.c:393 ../lib/vector/Vlib/write_pg.c:2443
-#: ../lib/vector/Vlib/write_pg.c:2540
-#, fuzzy, c-format
-msgid "Attempt to access dead feature %d"
+#: ../lib/vector/Vlib/line.c:184 ../lib/vector/Vlib/line.c:217
+#: ../lib/vector/Vlib/line.c:250
+#, fuzzy
+msgid "Index out of range in"
+msgstr "Dubulto atribūtu indekss ārpus diapazona"
-#: ../lib/vector/Vlib/write_nat.c:368
-#, fuzzy, c-format
-msgid "Attempt to access alive feature %d"
+#: ../lib/vector/Vlib/line.c:550
+msgid "Segment outside line, no segment created"
+msgstr ""
-#: ../lib/vector/Vlib/write_nat.c:510 ../lib/vector/Vlib/write_nat.c:546
+#: ../lib/vector/Vlib/simple_features.c:225
 #, c-format
-msgid "%s: Area %d does not exist"
+msgid "Unknown Simple Features type (%d)"
 msgstr ""
-#: ../lib/vector/Vlib/write_nat.c:700
-#, fuzzy, c-format
-msgid "Attempt to access dead area %d"
+#: ../lib/vector/Vlib/simple_features.c:324 ../lib/vector/Vlib/write_pg.c:316
+#: ../lib/vector/Vlib/write_pg.c:1200 ../lib/vector/Vlib/write_pg.c:1350
+msgid "No connection defined"
+msgstr ""
-#: ../lib/vector/Vlib/legal_vname.c:43
+#: ../lib/vector/Vlib/simple_features.c:332
+#, fuzzy
+msgid "Unable to get number of simple features"
+msgstr "Nevar atvērt 'temp'/pagaidu failu"
+#: ../lib/vector/Vlib/simple_features.c:341
 #, fuzzy, c-format
-msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
+msgid "Unable to report simple features for vector map <%s>"
+msgstr "Nevar atvērt vēsturi vektoram '%s'"
+#: ../lib/vector/Vlib/level.c:34
+msgid "Map structure was never initialized"
 msgstr ""
-"Nepieņemams vektoru kartes nosaukums <%s>. Nedrīkst saturēt '.' vai 'NULL'.\n"
-#: ../lib/vector/Vlib/legal_vname.c:50
-#, fuzzy, c-format
-msgid "Illegal vector map name <%s>. Must start with a letter."
-msgstr "Nepieņemams vektoru kartes nosaukums <%s>. Jāsākas ar burtu.\n"
+#: ../lib/vector/Vlib/level.c:36
+msgid "Map structure has been closed"
+msgstr ""
-#: ../lib/vector/Vlib/legal_vname.c:58
+#: ../lib/vector/Vlib/close.c:91
 #, fuzzy, c-format
-msgid "Illegal vector map name <%s>. Character '%c' not allowed."
-msgstr "Nepieņemams vektoru kartes nosaukums <%s>. Zīme <%c> nav atļauta.\n"
+msgid "Unable to create vector map <%s>"
+msgstr "Nav iespējams nolasīt vektoru karti <%s>"
-#: ../lib/vector/Vlib/legal_vname.c:65
+#: ../lib/vector/Vlib/close.c:108
+#, fuzzy
+msgid "Copying features failed"
+#: ../lib/vector/Vlib/close.c:141
 #, fuzzy, c-format
-msgid ""
-"Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
+msgid "Unable to open %s file"
-#: ../lib/vector/Vlib/legal_vname.c:97 ../lib/vector/Vlib/legal_vname.c:101
+#: ../lib/vector/Vlib/close.c:226
 #, fuzzy, c-format
-msgid "Output vector map name <%s> is not valid map name"
-msgstr "Izejas vārds '%s' nav derīgs rastra nosaukums."
+msgid "Unable to close vector <%s>"
-#: ../lib/vector/Vlib/legal_vname.c:144 ../lib/vector/Vlib/legal_vname.c:148
+#: ../lib/vector/Vlib/close.c:257
+#, c-format
+msgid "Invalid request for writing frmt file - map format is %d"
+msgstr ""
+#: ../lib/vector/Vlib/close.c:289
 #, fuzzy, c-format
-msgid "Output vector map <%s> is used as input"
-msgstr "Izejas karte '%s' tiek lietota kā iejas karte"
+msgid "Link to vector map <%s> created"
-#: ../lib/vector/Vlib/rewind_pg.c:51 ../lib/vector/Vlib/rewind_pg.c:76
-#: ../lib/vector/Vlib/open_pg.c:148 ../lib/vector/Vlib/open_pg.c:205
-#: ../lib/vector/Vlib/open_pg.c:311 ../lib/vector/Vlib/open_pg.c:349
-#: ../lib/vector/Vlib/close.c:273 ../lib/vector/Vlib/read_pg.c:90
-#: ../lib/vector/Vlib/read_pg.c:208 ../lib/vector/Vlib/read_pg.c:292
-#: ../lib/vector/Vlib/read_pg.c:376 ../lib/vector/Vlib/write_sfa.c:299
-#: ../lib/vector/Vlib/area.c:93 ../lib/vector/Vlib/area.c:464
-#: ../lib/vector/Vlib/header_finfo.c:47 ../lib/vector/Vlib/header_finfo.c:86
-#: ../lib/vector/Vlib/header_finfo.c:123 ../lib/vector/Vlib/header_finfo.c:171
-#: ../lib/vector/Vlib/simple_features.c:336 ../lib/vector/Vlib/build_sfa.c:719
-#: ../lib/vector/Vlib/close_pg.c:100 ../lib/vector/Vlib/close_pg.c:148
-#: ../lib/vector/Vlib/write_pg.c:121 ../lib/vector/Vlib/write_pg.c:155
-#: ../lib/vector/Vlib/write_pg.c:194 ../lib/vector/Vlib/write_pg.c:286
-#: ../lib/vector/Vlib/write_pg.c:346 ../lib/vector/Vlib/write_pg.c:447
-#: ../lib/vector/Vlib/build_pg.c:113 ../lib/vector/Vlib/copy.c:404
-msgid "GRASS is not compiled with PostgreSQL support"
+#: ../lib/vector/Vlib/build_pg.c:88
+msgid "No DB connection"
 msgstr ""
-#: ../lib/vector/Vlib/merge_lines.c:238
+#: ../lib/vector/Vlib/build_pg.c:93 ../lib/vector/Vlib/build_ogr.c:80
 #, c-format
-msgid "%d boundaries merged"
+msgid "Feature table <%s> has no primary key defined"
 msgstr ""
-#: ../lib/vector/Vlib/merge_lines.c:239
+#: ../lib/vector/Vlib/build_pg.c:95
+msgid "Random read is not supported for this layer. Unable to build topology."
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:101 ../lib/vector/Vlib/build_ogr.c:88
 #, c-format
-msgid "%d new boundaries"
+msgid "Using external data format '%s' (feature type '%s')"
 msgstr ""
-#: ../lib/vector/Vlib/snap.c:213
-msgid "Snap vertices Pass 1: select points"
+#: ../lib/vector/Vlib/build_pg.c:105
+msgid "Building pseudo-topology over simple features..."
 msgstr ""
-#: ../lib/vector/Vlib/snap.c:267
-msgid "Snap vertices Pass 2: assign anchor vertices"
+#: ../lib/vector/Vlib/build_pg.c:107
+#, c-format
+msgid "Building topology from PostGIS topology schema <%s>..."
 msgstr ""
-#: ../lib/vector/Vlib/snap.c:336
-msgid "Snap vertices Pass 3: snap to assigned points"
+#: ../lib/vector/Vlib/build_pg.c:212 ../lib/vector/Vlib/open_pg.c:1439
+#, fuzzy, c-format
+msgid "Inconsistency in topology: number of nodes %d (should be %d)"
+#: ../lib/vector/Vlib/build_pg.c:237
+#, fuzzy
+msgid "Cleaning-up topology schema..."
+msgstr "Satīra pagaidu failus..."
+#: ../lib/vector/Vlib/build_pg.c:282
+#, fuzzy
+msgid "Updating faces..."
+msgstr "Eksportē laukumus..."
+#: ../lib/vector/Vlib/build_pg.c:314
+#, fuzzy
+msgid "Updating edges..."
+msgstr "Eksportē mezglus..."
+#: ../lib/vector/Vlib/build_pg.c:323
+#, fuzzy
+msgid "Inconsistency in topology detected. Dead line found."
+#: ../lib/vector/Vlib/build_pg.c:377
+msgid "Updating TopoGeometry data..."
 msgstr ""
-#: ../lib/vector/Vlib/snap.c:518
+#: ../lib/vector/Vlib/build_pg.c:411 ../lib/vector/Vlib/write_pg.c:602
+#: ../lib/vector/Vlib/write_pg.c:863 ../lib/vector/Vlib/open.c:1351
+msgid "Unable to open PG file"
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:462
 #, c-format
-msgid "Snapped vertices: %d"
+msgid "Unsupported topo geometry type %d"
 msgstr ""
-#: ../lib/vector/Vlib/snap.c:519
+#: ../lib/vector/Vlib/build_pg.c:491
 #, fuzzy, c-format
-msgid "New vertices: %d"
-msgstr "Pirmatnējo/vienkāršo datu skaits:   %d\n"
+msgid "Unable to create <%s.%s>"
-#: ../lib/vector/Vlib/snap.c:546
+#: ../lib/vector/Vlib/build_pg.c:642
 #, fuzzy
-msgid "Reading features..."
-msgstr "Veidojam topoloģiju... \n"
+msgid "Unable to write nodes, offset array mismatch"
+msgstr "neiespējami rakstīt quant failu!"
-#: ../lib/vector/Vlib/build.c:37 ../lib/vector/Vlib/close.c:38
-#: ../lib/vector/Vlib/rewind.c:29 ../lib/vector/Vlib/read.c:32
-#: ../lib/vector/Vlib/open.c:59 ../lib/vector/Vlib/write.c:56
-#: ../lib/vector/Vlib/write.c:62
-msgid "Requested format is not compiled in this version"
-msgstr "Pieprasītais formāts nav pieejams/iekļauts šijā versijā"
+#: ../lib/vector/Vlib/build_pg.c:671
+#, fuzzy
+msgid "Unable to write nodes"
+msgstr "Neisespējami atvērt %s"
+#: ../lib/vector/Vlib/build_pg.c:716
+#, fuzzy, c-format
+msgid "Inconsistency in topology: number of boundaries %d (should be %d)"
+#: ../lib/vector/Vlib/build_pg.c:739
+#, fuzzy
+msgid "Unable to write lines"
+#: ../lib/vector/Vlib/build_pg.c:790
+#, c-format
+msgid "Topology for centroid %d not available. Area %d skipped"
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:1000
+msgid "Create simple features topology from topogeometry data..."
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:1018
+#, c-format
+msgid "Unable to build simple features from topogeometry data. Unsupported type %d."
+msgstr ""
+#: ../lib/vector/Vlib/select.c:116
+#, fuzzy, c-format
+msgid "Unable to delete item %d from spatial index"
 #: ../lib/vector/Vlib/build.c:115
 #, fuzzy
 msgid "Area of size = 0.0 (less than 4 vertices) ignored"
@@ -4652,44 +4283,44 @@
 msgid "Area of size = 0.0 ignored"
 msgstr "Laukuma izmērs=0.0. Ignorēts!"
-#: ../lib/vector/Vlib/build.c:199
+#: ../lib/vector/Vlib/build.c:197
 msgid "Request to find area outside nonexistent isle"
 msgstr ""
-#: ../lib/vector/Vlib/build.c:342
+#: ../lib/vector/Vlib/build.c:338
 msgid "Larger bbox but smaller area!!!"
 msgstr ""
-#: ../lib/vector/Vlib/build.c:588
+#: ../lib/vector/Vlib/build.c:584
 msgid "Checking for topological errors..."
 msgstr ""
-#: ../lib/vector/Vlib/build.c:623
+#: ../lib/vector/Vlib/build.c:619
 #, fuzzy, c-format
 msgid "Number of lines of length zero: %d"
 msgstr "Līniju skaits     :   %d\n"
-#: ../lib/vector/Vlib/build.c:625
+#: ../lib/vector/Vlib/build.c:621
 #, fuzzy, c-format
 msgid "Number of boundaries of length zero: %d"
 msgstr "Robežu skaits:   %d\n"
-#: ../lib/vector/Vlib/build.c:634
+#: ../lib/vector/Vlib/build.c:630
 #, fuzzy, c-format
 msgid "Number of boundary intersections: %d"
-#: ../lib/vector/Vlib/build.c:658
+#: ../lib/vector/Vlib/build.c:654
 #, fuzzy
 msgid "Skipping further checks because of incorrect boundaries"
 msgstr "Nepareizu robežu skaits   :   %d\n"
-#: ../lib/vector/Vlib/build.c:708
+#: ../lib/vector/Vlib/build.c:704
 #, fuzzy, c-format
 msgid "Number of redundant holes: %d"
-#: ../lib/vector/Vlib/build.c:847
+#: ../lib/vector/Vlib/build.c:846
 #, fuzzy, c-format
 msgid "Building topology for vector map <%s>..."
 msgstr "Lūdzu pārveido topoloģiju vektoram '%s@%s'"
@@ -4699,528 +4330,263 @@
 msgid "Topology was built"
 msgstr "Topoloģija tika izveidota.\n"
-#: ../lib/vector/Vlib/build.c:876
+#: ../lib/vector/Vlib/build.c:875
 #, fuzzy, c-format
 msgid "Number of nodes: %d"
 msgstr "Posmu skaits     :   %d\n"
-#: ../lib/vector/Vlib/build.c:877
+#: ../lib/vector/Vlib/build.c:876
 #, fuzzy, c-format
 msgid "Number of primitives: %d"
-#: ../lib/vector/Vlib/build.c:878
+#: ../lib/vector/Vlib/build.c:877
 #, fuzzy, c-format
 msgid "Number of points: %d"
 msgstr "Punktu skaits    :   %d\n"
-#: ../lib/vector/Vlib/build.c:879
+#: ../lib/vector/Vlib/build.c:878
 #, fuzzy, c-format
 msgid "Number of lines: %d"
-#: ../lib/vector/Vlib/build.c:880
+#: ../lib/vector/Vlib/build.c:879
 #, fuzzy, c-format
 msgid "Number of boundaries: %d"
-#: ../lib/vector/Vlib/build.c:881
+#: ../lib/vector/Vlib/build.c:880
 #, fuzzy, c-format
 msgid "Number of centroids: %d"
 msgstr "Centroīdu skaits :   %d\n"
-#: ../lib/vector/Vlib/build.c:884
+#: ../lib/vector/Vlib/build.c:883
 #, fuzzy, c-format
 msgid "Number of faces: %d"
 msgstr "Plakņu skaits     :   %d\n"
-#: ../lib/vector/Vlib/build.c:887
+#: ../lib/vector/Vlib/build.c:886
 #, fuzzy, c-format
 msgid "Number of kernels: %d"
 msgstr "Kodolu skaits   :   %d\n"
-#: ../lib/vector/Vlib/build.c:933
+#: ../lib/vector/Vlib/build.c:932
 #, fuzzy, c-format
 msgid "Number of areas: %d"
 msgstr "Laukumu skaits     :   %d\n"
-#: ../lib/vector/Vlib/build.c:934
+#: ../lib/vector/Vlib/build.c:933
 #, fuzzy, c-format
 msgid "Number of isles: %d"
 msgstr "'Salu' skaits     :   %d\n"
-#: ../lib/vector/Vlib/build.c:939
+#: ../lib/vector/Vlib/build.c:938
 #, fuzzy, c-format
 msgid "Number of areas without centroid: %d"
-#: ../lib/vector/Vlib/build.c:944
+#: ../lib/vector/Vlib/build.c:943
 #, fuzzy, c-format
 msgid "Number of centroids exceeds number of areas: %d > %d"
 msgstr "Ārpus laukuma esošu centroīdu skaits :   %d\n"
-#: ../lib/vector/Vlib/build.c:948
+#: ../lib/vector/Vlib/build.c:947
 #, fuzzy, c-format
 msgid "Number of incorrect boundaries: %d"
-#: ../lib/vector/Vlib/build.c:952
+#: ../lib/vector/Vlib/build.c:951
 #, fuzzy, c-format
 msgid "Number of centroids outside area: %d"
-#: ../lib/vector/Vlib/build.c:956
+#: ../lib/vector/Vlib/build.c:955
 #, fuzzy, c-format
 msgid "Number of duplicate centroids: %d"
 msgstr "Dubultu centroīdu skaits    :   %d\n"
-#: ../lib/vector/Vlib/build.c:960
+#: ../lib/vector/Vlib/build.c:959
 #, fuzzy
 msgid "Number of areas: -"
 msgstr "Laukumu skaits     :   -\n"
-#: ../lib/vector/Vlib/build.c:961
+#: ../lib/vector/Vlib/build.c:960
 #, fuzzy
 msgid "Number of isles: -"
 msgstr "'Salu' skaits     :   -\n"
-#: ../lib/vector/Vlib/build.c:990
+#: ../lib/vector/Vlib/build.c:989
 #, fuzzy, c-format
 msgid "Unable to create topo file for vector map <%s>"
-#: ../lib/vector/Vlib/build.c:998
+#: ../lib/vector/Vlib/build.c:997
 #, fuzzy
 msgid "Error writing out topo file"
 msgstr "Kļūdu raskrīšana ārpus topo faila.\n"
-#: ../lib/vector/Vlib/build.c:1187
+#: ../lib/vector/Vlib/build.c:1186
 #, fuzzy
 msgid ""
 "Unable to build spatial index from topology, vector map is not opened at "
 "topology level 2"
 msgstr "Nevar izdzēst līniju, karte '%s' karte nav atvērta līmenī 2"
-#: ../lib/vector/Vlib/build.c:1210
+#: ../lib/vector/Vlib/build.c:1209
 #, c-format
 msgid "%s is no longer supported"
 msgstr ""
-#: ../lib/vector/Vlib/build.c:1233
+#: ../lib/vector/Vlib/build.c:1232
 msgid "Spatial index not available, can not be saved"
 msgstr ""
-#: ../lib/vector/Vlib/build.c:1246
+#: ../lib/vector/Vlib/build.c:1245
 #, fuzzy, c-format
 msgid "Unable to create spatial index file for vector map <%s>"
-#: ../lib/vector/Vlib/build.c:1255
+#: ../lib/vector/Vlib/build.c:1254
 #, fuzzy
 msgid "Error writing out spatial index file"
-#: ../lib/vector/Vlib/open_pg.c:83 ../lib/vector/Vlib/open_pg.c:237
-#: ../lib/vector/Vlib/write_pg.c:947
-#, fuzzy
-msgid "Connection string not defined"
-msgstr "Pieslēgšanās izgāzusies\n"
-#: ../lib/vector/Vlib/open_pg.c:88 ../lib/vector/Vlib/open_pg.c:242
-#: ../lib/vector/Vlib/write_pg.c:952 ../lib/vector/Vlib/write_pg.c:1087
-#: ../lib/vector/Vlib/write_pg.c:1237
-#, fuzzy
-msgid "PostGIS feature table not defined"
-msgstr "Nevar ierakstīt līniju,karte nav atvērta"
-#: ../lib/vector/Vlib/open_pg.c:102 ../lib/vector/Vlib/open_pg.c:255
-#, fuzzy
-msgid "Unable to get database name"
-#: ../lib/vector/Vlib/open_pg.c:114 ../lib/vector/Vlib/open_pg.c:279
-#, fuzzy
-msgid "No feature tables found in database."
-msgstr "neiespējami atvērt elipsoīda tabulas failu: %s"
-#: ../lib/vector/Vlib/open_pg.c:138
+#: ../lib/vector/Vlib/bridges.c:213
 #, fuzzy, c-format
-msgid "Feature table <%s> not found in 'geometry_columns'"
-msgstr "Ieejas vektors '%s' nav atrasts"
+msgid "Removed lines: %d"
+msgstr "Līniju skaits     :   %d\n"
-#: ../lib/vector/Vlib/open_pg.c:186
-msgid "Topology schema not found."
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:198 ../lib/vector/Vlib/open_ogr.c:145
+#: ../lib/vector/Vlib/bridges.c:214
 #, fuzzy, c-format
-msgid "Unable to open feature index file for vector map <%s>"
-msgstr "Nevar atvērt vēsturi vektoram '%s'"
+msgid "Removed bridges: %d"
+msgstr "Pirmatnējo/vienkāršo datu skaits:   %d\n"
-#: ../lib/vector/Vlib/open_pg.c:285
+#: ../lib/vector/Vlib/legal_vname.c:43
 #, fuzzy, c-format
-msgid "PostGIS layer <%s.%s> already exists and will be overwritten"
-msgstr "Vektors '%s' jau eksistē un tiks pārrakstīts."
+msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
+msgstr "Nepieņemams vektoru kartes nosaukums <%s>. Nedrīkst saturēt '.' vai 'NULL'.\n"
-#: ../lib/vector/Vlib/open_pg.c:288
+#: ../lib/vector/Vlib/legal_vname.c:50
 #, fuzzy, c-format
-msgid "Unable to delete PostGIS layer <%s>"
-msgstr "Neiespējami atvērt failu %s iekš %s"
+msgid "Illegal vector map name <%s>. Must start with a letter."
+msgstr "Nepieņemams vektoru kartes nosaukums <%s>. Jāsākas ar burtu.\n"
-#: ../lib/vector/Vlib/open_pg.c:294
+#: ../lib/vector/Vlib/legal_vname.c:58
 #, fuzzy, c-format
-msgid "PostGIS layer <%s.%s> already exists in database '%s'"
+msgid "Illegal vector map name <%s>. Character '%c' not allowed."
+msgstr "Nepieņemams vektoru kartes nosaukums <%s>. Zīme <%c> nav atļauta.\n"
-#: ../lib/vector/Vlib/open_pg.c:390
-#, fuzzy
-msgid "No key column detected."
-msgstr "Ieejas vektorkartes nosaukums"
-#: ../lib/vector/Vlib/open_pg.c:459 ../lib/vector/Vlib/open_pg.c:471
-#: ../lib/vector/Vlib/read_pg.c:1380 ../lib/vector/Vlib/read_pg.c:1410
-#: ../lib/vector/Vlib/write_pg.c:839 ../lib/vector/Vlib/write_pg.c:857
+#: ../lib/vector/Vlib/legal_vname.c:65
 #, fuzzy, c-format
-msgid "Execution failed: %s"
+msgid "Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
-#: ../lib/vector/Vlib/open_pg.c:473
-#, c-format
-msgid "PostGIS topology schema <%s> dropped"
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:502
-#, fuzzy
-msgid "Connection to PostgreSQL database failed."
-#: ../lib/vector/Vlib/open_pg.c:587
-msgid "Empty bounding box"
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:684
-#, c-format
-msgid "Inconsistency in topology: unable to read node %d"
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:747
+#: ../lib/vector/Vlib/legal_vname.c:97 ../lib/vector/Vlib/legal_vname.c:101
 #, fuzzy, c-format
-msgid "Inconsistency in topology: node %d - unexpected feature type %d"
-msgstr "nezināns interpolācijas tips"
+msgid "Output vector map name <%s> is not valid map name"
+msgstr "Izejas vārds '%s' nav derīgs rastra nosaukums."
-#: ../lib/vector/Vlib/open_pg.c:864
+#: ../lib/vector/Vlib/legal_vname.c:144 ../lib/vector/Vlib/legal_vname.c:148
 #, fuzzy, c-format
-msgid "Inconsistency in topology: line %d - unexpected feature type"
+msgid "Output vector map <%s> is used as input"
+msgstr "Izejas karte '%s' tiek lietota kā iejas karte"
-#: ../lib/vector/Vlib/open_pg.c:908
+#: ../lib/vector/Vlib/copy.c:81
 #, fuzzy, c-format
-msgid "Area %d without boundary detected"
-msgstr "Bez centroīdiem esošu laukumu skaits :   %d\n"
-#: ../lib/vector/Vlib/open_pg.c:966
-#, c-format
-msgid "Isle %d without boundary detected"
+msgid "Unable to copy features. Input vector map <%s> is not open"
 msgstr ""
+"Nevar pievienot datubāzes saiti,karte nav atvērta rakstīšanas 'WRITE' "
+"režijmā."
-#: ../lib/vector/Vlib/open_pg.c:1027
-#, fuzzy
-msgid "Unable to get map bounding box from topology"
+#: ../lib/vector/Vlib/copy.c:100 ../lib/vector/Vlib/write_pg.c:725
+#: ../lib/vector/Vlib/write_pg.c:1162 ../lib/vector/Vlib/write_pg.c:1268
+#: ../lib/vector/Vlib/write_pg.c:1779 ../lib/vector/Vlib/write_pg.c:1957
+#: ../lib/vector/Vlib/write_pg.c:2313 ../lib/vector/Vlib/read_pg.c:884
+#: ../lib/vector/Vlib/read_pg.c:1190 ../lib/vector/Vlib/read_pg.c:1345
+#: ../lib/vector/Vlib/read_pg.c:1438
+#, fuzzy, c-format
+msgid "Unsupported feature type %d"
-#: ../lib/vector/Vlib/open_pg.c:1034
+#: ../lib/vector/Vlib/copy.c:104
 #, fuzzy, c-format
-msgid ""
-"Unable to parse map bounding box:\n"
-"%s"
+msgid "Unable to create PostGIS layer <%s>"
-#: ../lib/vector/Vlib/open_pg.c:1058
+#: ../lib/vector/Vlib/copy.c:133
 #, c-format
-msgid "Different number of nodes detected (%d, %d)"
+msgid "Vector map <%s> not open on topological level. Areas will be skipped!"
 msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1086 ../lib/vector/Vlib/open_pg.c:1108
+#: ../lib/vector/Vlib/copy.c:168 ../lib/vector/Vlib/copy.c:245
+#: ../lib/ogsf/Gp3.c:92
 #, c-format
-msgid "Different number of areas detected (%d, %d)"
-msgstr ""
+msgid "Unable to read vector map <%s>"
-#: ../lib/vector/Vlib/open_pg.c:1222
-#, c-format
-msgid "Inconsistency in topology: number of nodes %d (should be %d)"
-msgstr ""
+#: ../lib/vector/Vlib/copy.c:229 ../lib/vector/Vlib/copy.c:234
+msgid "Copying features..."
+msgstr "Kopē objektus..."
-#: ../lib/vector/Vlib/open_pg.c:1276
+#: ../lib/vector/Vlib/copy.c:231
 #, c-format
-msgid "Inconsistency in topology: number of points %d (should be %d)"
+msgid "Copying features (%s)..."
 msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1306
-#, c-format
-msgid "Inconsistency in topology: number of lines %d (should be %d)"
+#: ../lib/vector/Vlib/copy.c:334
+msgid "Writing new feature failed"
 msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1352
-#, c-format
-msgid "Inconsistency in topology: number of centroids %d (should be %d)"
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1423
-msgid "To be implemented: isles not attached in Topo-Geo-only mode"
-msgstr ""
-#: ../lib/vector/Vlib/overlay.c:72
-#, fuzzy
-msgid "unknown operator"
-#: ../lib/vector/Vlib/overlay.c:124
-msgid "Overlay: line/boundary types not supported by AND operator"
-msgstr ""
-#: ../lib/vector/Vlib/overlay.c:127
-msgid "Overlay: area x area types not supported by AND operator"
-msgstr ""
-#: ../lib/vector/Vlib/level.c:34
-msgid "Map structure was never initialized"
-msgstr ""
-#: ../lib/vector/Vlib/level.c:36
-msgid "Map structure has been closed"
-msgstr ""
-#: ../lib/vector/Vlib/line.c:184 ../lib/vector/Vlib/line.c:217
-#: ../lib/vector/Vlib/line.c:250
-#, fuzzy
-msgid "Index out of range in"
-msgstr "Dubulto atribūtu indekss ārpus diapazona"
-#: ../lib/vector/Vlib/line.c:550
-msgid "Segment outside line, no segment created"
-msgstr ""
-#: ../lib/vector/Vlib/close.c:91
+#: ../lib/vector/Vlib/copy.c:340
 #, fuzzy, c-format
-msgid "Unable to create vector map <%s>"
-msgstr "neispējami mainīt direktoriju uz %s"
+msgid "%d features without category or from different layer skipped"
-#: ../lib/vector/Vlib/close.c:108
-#, fuzzy
-msgid "Copying features failed"
+#: ../lib/vector/Vlib/copy.c:372
+msgid "Exporting nodes..."
-#: ../lib/vector/Vlib/close.c:141
+#: ../lib/vector/Vlib/copy.c:400
 #, fuzzy, c-format
-msgid "Unable to open %s file"
+msgid "Writing node %d failed"
-#: ../lib/vector/Vlib/close.c:224
-#, fuzzy, c-format
-msgid "Unable to close vector <%s>"
+#: ../lib/vector/Vlib/copy.c:478
+msgid "Exporting areas..."
-#: ../lib/vector/Vlib/close.c:255
+#: ../lib/vector/Vlib/copy.c:505
 #, c-format
-msgid "Invalid request for writing frmt file - map format is %d"
+msgid "No centroid defined for area %d. Area not exported."
 msgstr ""
-#: ../lib/vector/Vlib/close.c:287
+#: ../lib/vector/Vlib/copy.c:534 ../lib/vector/Vlib/copy.c:542
 #, fuzzy, c-format
-msgid "Link to vector map <%s> created"
+msgid "Writing area %d failed"
+msgstr "Neiespējami atvērt failu %s iekš %s"
-#: ../lib/vector/Vlib/bridges.c:213
-#, fuzzy, c-format
-msgid "Removed lines: %d"
-msgstr "Līniju skaits     :   %d\n"
+#: ../lib/vector/Vlib/copy.c:550
+#, c-format
+msgid "%d areas without category or from different layer skipped"
+msgstr ""
-#: ../lib/vector/Vlib/bridges.c:214
-#, fuzzy, c-format
-msgid "Removed bridges: %d"
+#: ../lib/vector/Vlib/copy.c:611 ../lib/vector/Vlib/copy.c:752
+#, c-format
+msgid "Unable to add database link for vector map <%s>"
+msgstr ""
-#: ../lib/vector/Vlib/map.c:106 ../lib/vector/Vlib/map.c:251
-#, fuzzy
-msgid "Vector map name is not SQL compliant"
-msgstr "Kartes nosaukums nav SQL savietojams."
-#: ../lib/vector/Vlib/map.c:110
-#, fuzzy, c-format
-msgid "Unable to find vector map <%s> in <%s>"
-msgstr "neiespējami atvērt rastra karti [%s iekš %s]"
-#: ../lib/vector/Vlib/map.c:122 ../lib/vector/Vlib/map.c:255
-#: ../lib/vector/Vlib/open.c:809
-#, fuzzy, c-format
-msgid "Vector map <%s> already exists and will be overwritten"
-#: ../lib/vector/Vlib/map.c:126 ../lib/vector/Vlib/open.c:803
-#: ../lib/vector/Vlib/open.c:814
-#, fuzzy, c-format
-msgid "Unable to delete vector map <%s>"
-#: ../lib/vector/Vlib/map.c:146 ../lib/vector/Vlib/map.c:273
-#, fuzzy, c-format
-msgid "Unable to copy vector map <%s> to <%s>"
+#: ../lib/vector/Vlib/copy.c:620 ../lib/vector/Vlib/copy.c:767
 #: ../lib/vector/Vlib/map.c:195 ../lib/vector/Vlib/map.c:322
-#: ../lib/vector/Vlib/copy.c:606 ../lib/vector/Vlib/copy.c:753
 #, fuzzy, c-format
 msgid "Unable to copy table <%s>"
-#: ../lib/vector/Vlib/map.c:211 ../lib/vector/Vlib/map.c:351
-#: ../lib/vector/Vlib/copy.c:619
+#: ../lib/vector/Vlib/copy.c:633 ../lib/vector/Vlib/map.c:211
+#: ../lib/vector/Vlib/map.c:351
 #, fuzzy, c-format
 msgid "Unable to create index for table <%s>, key <%s>"
 msgstr "Niespējami izveidot atkarību failu [%s iekš %s]"
-#: ../lib/vector/Vlib/map.c:336 ../lib/vector/Vlib/map.c:461
-#, fuzzy, c-format
-msgid "Unable to delete table <%s>"
-#: ../lib/vector/Vlib/map.c:407
-#, c-format
-msgid "Ignoring invalid mapset: %s"
-msgstr ""
-#: ../lib/vector/Vlib/map.c:412
-#, fuzzy, c-format
-msgid "Invalid vector map name <%s>"
-#: ../lib/vector/Vlib/map.c:422
-#, fuzzy, c-format
-msgid "Unable to open header file for vector map <%s>"
-#: ../lib/vector/Vlib/map.c:451
-#, fuzzy, c-format
-msgid "Unable to find table <%s> linked to vector map <%s>"
-#: ../lib/vector/Vlib/map.c:468
-#, fuzzy, c-format
-msgid "Table <%s> linked to vector map <%s> does not exist"
-#: ../lib/vector/Vlib/map.c:482
-#, fuzzy, c-format
-msgid "Unable to open directory '%s'"
-#: ../lib/vector/Vlib/map.c:496
-#, fuzzy, c-format
-msgid "Unable to delete file '%s'"
-#: ../lib/vector/Vlib/map.c:510
-#, fuzzy, c-format
-msgid "Unable to rename directory '%s' to '%s'"
-#: ../lib/vector/Vlib/map.c:519
-#, fuzzy, c-format
-msgid "Unable to remove directory '%s'"
-#: ../lib/vector/Vlib/read_pg.c:186 ../lib/vector/Vlib/read_sfa.c:117
-#, fuzzy, c-format
-msgid "Unexpected feature type (%d) - should be (%d)"
-#: ../lib/vector/Vlib/read_pg.c:266 ../lib/vector/Vlib/read_pg.c:366
-#: ../lib/vector/Vlib/read_pg.c:425 ../lib/vector/Vlib/build_sfa.c:354
-#: ../lib/vector/Vlib/build_sfa.c:364
-#, fuzzy, c-format
-msgid "Feature %d without geometry skipped"
-#: ../lib/vector/Vlib/read_pg.c:433 ../lib/vector/Vlib/read_ogr.c:382
-msgid "Feature without geometry. Skipped."
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:500
-msgid "No geometry or topo geometry column defined"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:510
-msgid "Random access not supported. Primary key not defined."
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:577
-msgid "Inconsistency in topology: detected centroid (should be point)"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:587
-msgid "Inconsistency in topology: detected boundary (should be line)"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:694
-#, c-format
-msgid "Invalid WKB content: %d bytes"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:710
-msgid "Reading EWKB with 4-dimensional coordinates (XYZM) is not supported"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:787 ../lib/vector/Vlib/read_pg.c:1091
-#: ../lib/vector/Vlib/read_pg.c:1237 ../lib/vector/Vlib/read_pg.c:1330
-#: ../lib/vector/Vlib/write_pg.c:656 ../lib/vector/Vlib/write_pg.c:1045
-#: ../lib/vector/Vlib/write_pg.c:1151 ../lib/vector/Vlib/write_pg.c:1652
-#: ../lib/vector/Vlib/write_pg.c:1829 ../lib/vector/Vlib/write_pg.c:2184
-#: ../lib/vector/Vlib/copy.c:100
-#, fuzzy, c-format
-msgid "Unsupported feature type %d"
-#: ../lib/vector/Vlib/read_pg.c:897 ../lib/vector/Vlib/read_pg.c:965
-#: ../lib/vector/Vlib/read_pg.c:1036
-msgid "Length of input WKB is too small"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:976
-#, c-format
-msgid "Invalid cache index %d (max: %d)"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:1114
-#, c-format
-msgid "Corrupted data. %s."
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:1116
-msgid "Corrupted data"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:1295 ../lib/vector/Vlib/close_pg.c:65
-#, fuzzy, c-format
-msgid "Unable to close cursor %s"
-#: ../lib/vector/Vlib/read_pg.c:1539
-#, fuzzy, c-format
-msgid ""
-"Unable to read PostGIS features\n"
-"%s"
-#: ../lib/vector/Vlib/poly.c:222
-#, fuzzy
-msgid "Unable to find point in polygon"
-msgstr "neiespējami atrast [%s] iekš [%s]"
-#: ../lib/vector/Vlib/poly.c:640
-#, fuzzy
-msgid "conditions failed"
 #: ../lib/vector/Vlib/geos.c:52
 #, fuzzy
 msgid "vector map is not opened"
@@ -5268,527 +4634,691 @@
 msgid "Unable to read feature id %d"
-#: ../lib/vector/Vlib/box.c:228
+#: ../lib/vector/Vlib/buffer2.c:361
+msgid "Line is not looped"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:443
+#, c-format
+msgid "Unexpected result of line_intersection() res = %d"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:589
+msgid "Next edge was visited (right) but it is not the first one !!! breaking loop"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:600
+msgid "Next edge was visited (left) but it is not the first one !!! breaking loop"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:648
+msgid "side != 0 feature not implemented"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:890 ../lib/vector/Vlib/buffer2.c:937
+msgid "zero area size"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:896 ../lib/vector/Vlib/buffer2.c:943
+msgid "Line was not closed"
+msgstr "Līnija netika noslēgta"
+#: ../lib/vector/Vlib/buffer2.c:909 ../lib/vector/Vlib/buffer2.c:960
+msgid "Vect_get_point_in_poly() failed"
+msgstr ""
+#: ../lib/vector/Vlib/close_pg.c:66 ../lib/vector/Vlib/read_pg.c:1403
 #, fuzzy, c-format
+msgid "Unable to close cursor %s"
+#: ../lib/vector/Vlib/close_pg.c:137 ../lib/vector/Vlib/close_ogr.c:104
+#, c-format
+msgid "Unable to save feature index file for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/box.c:255
+#, fuzzy, c-format
 msgid "Unable to determine bbox for feature %d"
-#: ../lib/vector/Vlib/box.c:277 ../lib/vector/Vlib/box.c:323
+#: ../lib/vector/Vlib/box.c:304 ../lib/vector/Vlib/box.c:350
 #, fuzzy, c-format
 msgid "Attempt to access area with invalid id (%d)"
-#: ../lib/vector/Vlib/box.c:289
+#: ../lib/vector/Vlib/box.c:316
 #, fuzzy, c-format
 msgid "Unable to determine bbox for area %d"
-msgstr "Nevar atvērt 'temp'/pagaidu failu"
-#: ../lib/vector/Vlib/box.c:335
+#: ../lib/vector/Vlib/box.c:362
 #, fuzzy, c-format
 msgid "Unable to determine bbox for isle %d"
-#: ../lib/vector/Vlib/read.c:25 ../lib/vector/Vlib/write.c:30
-#: ../lib/vector/Vlib/write.c:36 ../lib/vector/Vlib/write.c:42
-#: ../lib/vector/Vlib/write.c:49
-#, fuzzy
-msgid "for this format/level not supported"
+#: ../lib/vector/Vlib/area.c:50
+msgid "Attempt to read points of nonexistent area"
+msgstr ""
-#: ../lib/vector/Vlib/read.c:93 ../lib/vector/Vlib/read.c:129
-#: ../lib/vector/Vlib/read.c:168
+#: ../lib/vector/Vlib/area.c:81
 #, fuzzy
-msgid "Vector map is not open for reading"
+msgid "Attempt to read points of nonexistent isle"
+msgstr "Nevar nolasīt histogrammu priekš [%s no %s]"
-#: ../lib/vector/Vlib/read.c:136 ../lib/vector/Vlib/read.c:180
+#: ../lib/vector/Vlib/area.c:121 ../lib/vector/Vlib/area.c:153
+#: ../lib/vector/Vlib/area.c:219 ../lib/vector/Vlib/area.c:248
+#, c-format
+msgid "Attempt to read topo for dead area (%d)"
+msgstr ""
+#: ../lib/vector/Vlib/area.c:189 ../lib/vector/Vlib/area.c:275
+#, c-format
+msgid "Attempt to read topo for dead isle (%d)"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:188 ../lib/vector/Vlib/write_pg.c:250
+#: ../lib/vector/Vlib/write_sfa.c:161 ../lib/vector/Vlib/write_ogr.c:96
+msgid "Unable to rewrite feature (incompatible feature types)"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:242 ../lib/vector/Vlib/write_pg.c:397
+#: ../lib/vector/Vlib/write_pg.c:2572 ../lib/vector/Vlib/write_pg.c:2669
+#: ../lib/vector/Vlib/write_nat.c:271 ../lib/vector/Vlib/write_nat.c:601
+#: ../lib/vector/Vlib/read_sfa.c:56 ../lib/vector/Vlib/read_nat.c:150
+#: ../lib/vector/Vlib/read_pg.c:337
 #, fuzzy, c-format
-msgid "Unable to read feature %d from vector map <%s>"
+msgid "Attempt to access dead feature %d"
-#: ../lib/vector/Vlib/build_ogr.c:69
-msgid "Empty OGR layer, nothing to build"
+#: ../lib/vector/Vlib/write_pg.c:280
+#, fuzzy, c-format
+msgid "Unable to rewrite feature %d"
+#: ../lib/vector/Vlib/write_pg.c:321
+#, fuzzy, c-format
+msgid "Invalid offset (%ld)"
+msgstr "Nederīgs mezgla ID: %d"
+#: ../lib/vector/Vlib/write_pg.c:342 ../lib/vector/Vlib/write_ogr.c:140
+msgid "Unable to delete feature"
 msgstr ""
-#: ../lib/vector/Vlib/build_ogr.c:80 ../lib/vector/Vlib/build_pg.c:89
+#: ../lib/vector/Vlib/write_pg.c:443
+#, fuzzy, c-format
+msgid "Unable to delete feature (%s) %d"
+#: ../lib/vector/Vlib/write_pg.c:545 ../lib/vector/Vlib/write_pg.c:1284
+#: ../lib/vector/Vlib/write_sfa.c:342
+msgid "Boundary is not closed. Skipping."
+msgstr "Robeža nav noslēgta. Izlaižam."
+#: ../lib/vector/Vlib/write_pg.c:654
+#, fuzzy, c-format
+msgid "Unable to desribe table <%s>"
+#: ../lib/vector/Vlib/write_pg.c:761
 #, c-format
-msgid "Feature table <%s> has no primary key defined"
+msgid "Building spatial index on <%s>..."
 msgstr ""
-#: ../lib/vector/Vlib/build_ogr.c:82
-msgid ""
-"Random read is not supported by OGR for this layer. Unable to build topology."
+#: ../lib/vector/Vlib/write_pg.c:824
+#, c-format
+msgid "Schema <%s> doesn't exist, created"
 msgstr ""
-#: ../lib/vector/Vlib/build_ogr.c:88 ../lib/vector/Vlib/build_pg.c:97
+#: ../lib/vector/Vlib/write_pg.c:903
 #, c-format
-msgid "Using external data format '%s' (feature type '%s')"
+msgid "Creating topology schema <%s>..."
 msgstr ""
-#: ../lib/vector/Vlib/build_ogr.c:132
-#, fuzzy, c-format
-msgid "Unable to open fidx file for write <%s>"
-msgstr "Nevar atvērt topo failu rakstīšanai: %s\n"
+#: ../lib/vector/Vlib/write_pg.c:917
+#, c-format
+msgid "Adding new topology column <%s>..."
+msgstr ""
-#: ../lib/vector/Vlib/net.c:117
+#: ../lib/vector/Vlib/write_pg.c:1058 ../lib/vector/Vlib/open_pg.c:85
+#: ../lib/vector/Vlib/open_pg.c:239
 #, fuzzy
-msgid "Building graph..."
+msgid "Connection string not defined"
+msgstr "Pieslēgšanās izgāzusies\n"
-#: ../lib/vector/Vlib/net.c:159
+#: ../lib/vector/Vlib/write_pg.c:1063 ../lib/vector/Vlib/write_pg.c:1204
+#: ../lib/vector/Vlib/write_pg.c:1354 ../lib/vector/Vlib/open_pg.c:90
+#: ../lib/vector/Vlib/open_pg.c:244
 #, fuzzy
-msgid "Unable to build network graph"
-msgstr "Nevar atrast vektoru %s"
+msgid "PostGIS feature table not defined"
+msgstr "Nevar ierakstīt līniju,karte nav atvērta"
-#: ../lib/vector/Vlib/net.c:165
-msgid "Forward costs column not specified"
+#: ../lib/vector/Vlib/write_pg.c:1089 ../lib/vector/Vlib/write_ogr.c:304
+#, c-format
+msgid "Unsupported geometry type (%d)"
+msgstr "Neatbalstīts ģeometrijas tips (%d)"
+#: ../lib/vector/Vlib/write_pg.c:1102 ../lib/vector/Vlib/write_ogr.c:338
+#, c-format
+msgid "More layers defined, using driver <%s> and database <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/net.c:172
-msgid "Arc field < 1"
+#: ../lib/vector/Vlib/write_pg.c:1106 ../lib/vector/Vlib/write_ogr.c:344
+msgid "Database connection not defined. Unable to write attributes."
 msgstr ""
-#: ../lib/vector/Vlib/net.c:186 ../lib/vector/Vlib/net.c:203
-#: ../lib/vector/Vlib/net.c:363 ../lib/vector/Vlib/ascii.c:730
-#, fuzzy, c-format
-msgid "Column <%s> not found in table <%s>"
-msgstr "Nevar atvērt datubāzi %s"
+#: ../lib/vector/Vlib/write_pg.c:1113
+msgid "Unable to create new PostGIS feature table"
+msgstr ""
-#: ../lib/vector/Vlib/net.c:192 ../lib/vector/Vlib/net.c:209
-#: ../lib/vector/Vlib/net.c:369
-#, c-format
-msgid "Data type of column <%s> not supported (must be numeric)"
+#: ../lib/vector/Vlib/write_pg.c:1127
+msgid "Unable to create new PostGIS topology schema"
 msgstr ""
-#: ../lib/vector/Vlib/net.c:222
-#, fuzzy
-msgid "Registering arcs..."
-msgstr "Saglabājam/reģistrējam līnijas"
-#: ../lib/vector/Vlib/net.c:251
+#: ../lib/vector/Vlib/write_pg.c:1227 ../lib/vector/Vlib/write_pg.c:1384
+#: ../lib/vector/Vlib/write_ogr.c:408
 #, c-format
-msgid ""
-"Database record for line %d (cat = %d, forward/both direction(s)) not found "
-"(forward/both direction(s) of line skipped)"
+msgid "No category defined for layer %d"
 msgstr ""
-#: ../lib/vector/Vlib/net.c:270
+#: ../lib/vector/Vlib/write_pg.c:1229 ../lib/vector/Vlib/write_pg.c:1386
+#: ../lib/vector/Vlib/write_ogr.c:410
 #, c-format
-msgid ""
-"Database record for line %d (cat = %d, backword direction) not "
-"found(direction of line skipped)"
+msgid "Feature has more categories, using category %d (from layer %d)"
 msgstr ""
-#: ../lib/vector/Vlib/net.c:319
-#, fuzzy
-msgid "Cannot add network arc"
+#: ../lib/vector/Vlib/write_pg.c:1240
+#, fuzzy, c-format
+msgid "Point skipped (output feature type: %s)"
+msgstr "Neatbalstīts objekta tips (%d)"
-#: ../lib/vector/Vlib/net.c:349
-msgid "Setting node costs..."
-msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1247
+#, fuzzy, c-format
+msgid "Line skipped (output feature type: %s)"
+msgstr "nezināns interpolācijas tips"
-#: ../lib/vector/Vlib/net.c:412
+#: ../lib/vector/Vlib/write_pg.c:1254
 #, c-format
-msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
+msgid "Boundary/centroid skipped (output feature type: %s)"
 msgstr ""
-#: ../lib/vector/Vlib/net.c:441
-#, fuzzy
-msgid "Flattening the graph..."
+#: ../lib/vector/Vlib/write_pg.c:1256 ../lib/vector/Vlib/write_ogr.c:439
+msgid "Feature is not a polygon. Skipping."
+msgstr ""
-#: ../lib/vector/Vlib/net.c:450
+#: ../lib/vector/Vlib/write_pg.c:1262
+#, fuzzy, c-format
+msgid "Face skipped (output feature type: %s)"
+#: ../lib/vector/Vlib/write_pg.c:1344
+#, fuzzy, c-format
+msgid "Invalid feature type (%d) for nodes"
+#: ../lib/vector/Vlib/write_pg.c:1358
 #, fuzzy
-msgid "Graph was built"
-msgstr "Topoloģija tika izveidota.\n"
+msgid "PostGIS topology schema not defined"
-#: ../lib/vector/Vlib/net.c:533 ../lib/vector/Vlib/graph.c:226
-#, c-format
-msgid "dglShortestPath error: %s"
+#: ../lib/vector/Vlib/write_pg.c:1863
+msgid "Trying to insert 3D data into feature table which store 2D data only"
 msgstr ""
-#: ../lib/vector/Vlib/net.c:633
-msgid "Wrong line direction in Vect_net_get_line_cost()"
+#: ../lib/vector/Vlib/write_pg.c:1868
+msgid "Trying to insert 2D data into feature table which store 3D data only"
 msgstr ""
-#: ../lib/vector/Vlib/dangles.c:148
-msgid "Changed"
+#: ../lib/vector/Vlib/write_pg.c:1893
+msgid "Unable to insert topological element into PostGIS Topology schema"
 msgstr ""
-#: ../lib/vector/Vlib/dangles.c:151
-msgid "Removed"
+#: ../lib/vector/Vlib/write_pg.c:1993 ../lib/vector/Vlib/write_ogr.c:579
+#, c-format
+msgid "Unable to select attributes for category %d"
 msgstr ""
-#: ../lib/vector/Vlib/dangles.c:154
-msgid "Selected"
+#: ../lib/vector/Vlib/write_pg.c:1997 ../lib/vector/Vlib/write_ogr.c:585
+#: ../lib/db/dbmi_client/copy_tab.c:314
+#, c-format
+msgid "Unable to fetch data from table <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/dangles.c:262
-#, fuzzy, c-format
-msgid "%s lines: %d"
+#: ../lib/vector/Vlib/write_pg.c:2002 ../lib/vector/Vlib/write_ogr.c:591
+#, c-format
+msgid "No database record for category %d, no attributes will be written"
+msgstr ""
-#: ../lib/vector/Vlib/dangles.c:263
+#: ../lib/vector/Vlib/write_pg.c:2028
 #, c-format
-msgid "%s dangles: %d"
+msgid "FID column must be integer, column <%s> ignored!"
 msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:74 ../lib/vector/Vlib/build_sfa.c:339
-#: ../lib/vector/Vlib/build_sfa.c:629
-#, fuzzy
-msgid "Registering primitives..."
+#: ../lib/vector/Vlib/write_pg.c:2062 ../lib/vector/Vlib/write_ogr.c:653
+#, c-format
+msgid "Unsupported column type %d"
+msgstr "Neatbalstīts kolonas tips %d"
-#: ../lib/vector/Vlib/build_nat.c:84
-#, fuzzy
-msgid "Unable to read vector map"
+#: ../lib/vector/Vlib/write_pg.c:2069
+msgid "Invalid value for FID column: NULL"
+msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:117 ../lib/vector/Vlib/build_sfa.c:385
-#: ../lib/vector/Vlib/build_sfa.c:661
+#: ../lib/vector/Vlib/write_pg.c:2161
 #, fuzzy, c-format
-msgid "%d primitives registered"
-msgstr "\r%d pirmatnējie dati reģistrēti      \n"
+msgid "Invalid feature %d (max: %d)"
-#: ../lib/vector/Vlib/build_nat.c:118 ../lib/vector/Vlib/build_sfa.c:386
-#: ../lib/vector/Vlib/build_sfa.c:662
+#: ../lib/vector/Vlib/write_pg.c:2175
 #, fuzzy, c-format
-msgid "%d vertices registered"
+msgid "Invalid feature type (%d) for node"
-#: ../lib/vector/Vlib/build_nat.c:129
-#, fuzzy
-msgid "Building areas..."
+#: ../lib/vector/Vlib/write_pg.c:2179
+#, fuzzy, c-format
+msgid "Invalid node %d (%d)"
-#: ../lib/vector/Vlib/build_nat.c:152
+#: ../lib/vector/Vlib/write_pg.c:2257
 #, fuzzy, c-format
-msgid "%d areas built"
+msgid "Unable to determine next left/right edge for edge %d"
-#: ../lib/vector/Vlib/build_nat.c:153
+#: ../lib/vector/Vlib/write_pg.c:2262
+#, fuzzy
+msgid "Unable to insert new edge. Topology not available."
+#: ../lib/vector/Vlib/write_pg.c:2361 ../lib/vector/Vlib/write_pg.c:2368
+msgid "Invalid topology"
+msgstr "Nederīga topoloģija"
+#: ../lib/vector/Vlib/write_pg.c:2567 ../lib/vector/Vlib/write_pg.c:2664
 #, fuzzy, c-format
-msgid "%d isles built"
+msgid "Attempt to access non-existing feature %d"
-#: ../lib/vector/Vlib/build_nat.c:162
+#: ../lib/vector/Vlib/write_pg.c:2598
 #, fuzzy
-msgid "Attaching islands..."
-msgstr "Pievienot salas"
+msgid "Unable to determine next left/right edge"
-#: ../lib/vector/Vlib/build_nat.c:178
+#: ../lib/vector/Vlib/write_pg.c:2684
 #, fuzzy
-msgid "Attaching centroids..."
-msgstr "Pievienot centroīdus"
+msgid "Unable to create new face"
+msgstr "neiespējami izveidot jaunu procesu"
-#: ../lib/vector/Vlib/level_two.c:23
+#: ../lib/vector/Vlib/write_pg.c:2823 ../lib/vector/Vlib/write_pg.c:2835
 #, fuzzy, c-format
-msgid "Vector map <%s> is not open at topological level"
+msgid "Unable to delete node %d"
-#: ../lib/vector/Vlib/level_two.c:284
+#: ../lib/vector/Vlib/write_pg.c:2888 ../lib/vector/Vlib/ascii.c:404
+#: ../lib/vector/Vlib/write_ogr.c:192 ../lib/db/dbmi_client/db.c:41
+#: ../lib/db/dbmi_client/copy_tab.c:107 ../lib/db/dbmi_client/copy_tab.c:127
+#, c-format
+msgid "Unable to start driver <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:106 ../lib/vector/Vlib/map.c:251
+#, fuzzy
+msgid "Vector map name is not SQL compliant"
+msgstr "Kartes nosaukums nav SQL savietojams."
+#: ../lib/vector/Vlib/map.c:110
 #, fuzzy, c-format
-msgid "Invalid node id: %d"
+msgid "Unable to find vector map <%s> in <%s>"
+msgstr "neiespējami atvērt rastra karti [%s iekš %s]"
-#: ../lib/vector/Vlib/level_two.c:316
+#: ../lib/vector/Vlib/map.c:122 ../lib/vector/Vlib/map.c:255
+#: ../lib/vector/Vlib/open.c:812
 #, fuzzy, c-format
-msgid "Nodes not available for line %d"
-msgstr "Nav pieejama palīdzība komandai [%s]\n"
+msgid "Vector map <%s> already exists and will be overwritten"
+msgstr "Vektors '%s' jau eksistē un tiks pārrakstīts."
-#: ../lib/vector/Vlib/level_two.c:357
+#: ../lib/vector/Vlib/map.c:126 ../lib/vector/Vlib/open.c:806
+#: ../lib/vector/Vlib/open.c:817
 #, fuzzy, c-format
-msgid "Areas not available for line %d"
+msgid "Unable to delete vector map <%s>"
+msgstr "neispējami mainīt direktoriju uz %s"
-#: ../lib/vector/Vlib/level_two.c:362
+#: ../lib/vector/Vlib/map.c:146 ../lib/vector/Vlib/map.c:273
 #, fuzzy, c-format
-msgid "Line %d is not a boundary"
+msgid "Unable to copy vector map <%s> to <%s>"
-#: ../lib/vector/Vlib/level_two.c:445
+#: ../lib/vector/Vlib/map.c:336 ../lib/vector/Vlib/map.c:461
 #, fuzzy, c-format
-msgid "Topology info not available for feature %d"
+msgid "Unable to delete table <%s>"
-#: ../lib/vector/Vlib/open_ogr.c:60
-msgid "OGR datasource not defined"
+#: ../lib/vector/Vlib/map.c:407
+#, c-format
+msgid "Ignoring invalid mapset: %s"
 msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:65 ../lib/vector/Vlib/write_ogr.c:129
-msgid "OGR layer not defined"
-msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:77 ../lib/vector/Vlib/field.c:675
+#: ../lib/vector/Vlib/map.c:412
 #, fuzzy, c-format
-msgid "Unable to open OGR data source '%s'"
+msgid "Invalid vector map name <%s>"
-#: ../lib/vector/Vlib/open_ogr.c:97
+#: ../lib/vector/Vlib/map.c:422
 #, fuzzy, c-format
-msgid "OGR layer <%s> not found"
+msgid "Unable to open header file for vector map <%s>"
-#: ../lib/vector/Vlib/open_ogr.c:191
+#: ../lib/vector/Vlib/map.c:451
 #, fuzzy, c-format
-msgid "Unable to get OGR driver <%s>"
+msgid "Unable to find table <%s> linked to vector map <%s>"
-#: ../lib/vector/Vlib/open_ogr.c:199
+#: ../lib/vector/Vlib/map.c:468
 #, fuzzy, c-format
-msgid "Unable to create OGR data source '%s'"
+msgid "Table <%s> linked to vector map <%s> does not exist"
-#: ../lib/vector/Vlib/open_ogr.c:211
+#: ../lib/vector/Vlib/map.c:482
 #, fuzzy, c-format
-msgid "OGR layer <%s> already exists and will be overwritten"
+msgid "Unable to open directory '%s'"
-#: ../lib/vector/Vlib/open_ogr.c:215
+#: ../lib/vector/Vlib/map.c:496
 #, fuzzy, c-format
-msgid "Unable to delete OGR layer <%s>"
+msgid "Unable to delete file '%s'"
-#: ../lib/vector/Vlib/open_ogr.c:221
+#: ../lib/vector/Vlib/map.c:510
 #, fuzzy, c-format
-msgid "OGR layer <%s> already exists in datasource '%s'"
+msgid "Unable to rename directory '%s' to '%s'"
-#: ../lib/vector/Vlib/open_ogr.c:279
-#, c-format
-msgid ""
-"Feature index format version %d.%d is not supported by this release. Try to "
-"rebuild topology or upgrade GRASS."
-msgstr ""
+#: ../lib/vector/Vlib/map.c:519
+#, fuzzy, c-format
+msgid "Unable to remove directory '%s'"
-#: ../lib/vector/Vlib/open_ogr.c:284
-#, c-format
-msgid ""
-"Your GRASS version does not fully support feature index format %d.%d of the "
-"vector. Consider to rebuild topology or upgrade GRASS."
-msgstr ""
+#: ../lib/vector/Vlib/dangles.c:148
+msgid "Changed"
+msgstr "Mainīts"
-#: ../lib/vector/Vlib/open_nat.c:57
-#, fuzzy, c-format
-msgid "Unable to open coor file for vector map <%s>"
+#: ../lib/vector/Vlib/dangles.c:151
+msgid "Removed"
+msgstr "Noņemts"
-#: ../lib/vector/Vlib/open_nat.c:154
+#: ../lib/vector/Vlib/dangles.c:154
+msgid "Selected"
+msgstr "Izvēlēts"
+#: ../lib/vector/Vlib/dangles.c:262
 #, c-format
-msgid ""
-"Coor file of vector map <%s@%s> is larger than it should be (%ld bytes "
-"excess)"
-msgstr ""
+msgid "%s lines: %d"
+msgstr "%s līnijas: %d"
-#: ../lib/vector/Vlib/open_nat.c:158
+#: ../lib/vector/Vlib/dangles.c:263
 #, c-format
-msgid ""
-"Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
+msgid "%s dangles: %d"
 msgstr ""
-#: ../lib/vector/Vlib/write_sfa.c:113
-#, fuzzy
-msgid "Unable to calculate centroid for area"
-#: ../lib/vector/Vlib/write_sfa.c:127 ../lib/vector/Vlib/write_sfa.c:170
-#: ../lib/vector/Vlib/write_sfa.c:266 ../lib/vector/Vlib/read_sfa.c:124
-msgid "GRASS is not compiled with OGR/PostgreSQL support"
-msgstr ""
-#: ../lib/vector/Vlib/write_sfa.c:161 ../lib/vector/Vlib/write_pg.c:185
-#: ../lib/vector/Vlib/write_pg.c:247 ../lib/vector/Vlib/write_ogr.c:96
-#, fuzzy
-msgid "Unable to rewrite feature (incompatible feature types)"
-msgstr "Nevar ierakstīt līniju (negatīva nobīde/offset)"
-#: ../lib/vector/Vlib/write_sfa.c:212
-#, fuzzy
-msgid "Attempt to delete dead feature"
-#: ../lib/vector/Vlib/write_sfa.c:304
-#, fuzzy, c-format
-msgid "Unsupported vector map format (%d)"
-#: ../lib/vector/Vlib/write_sfa.c:342 ../lib/vector/Vlib/write_pg.c:1167
-msgid "Boundary is not closed. Skipping."
-msgstr ""
 #: ../lib/vector/Vlib/open.c:138
-#, fuzzy, c-format
+#, c-format
 msgid "Programmer requested unknown access level %d"
 msgstr ""
-"Brīdinājums. Programma atklājusi nezināmu atvērtolīmeni (open_level) \n"
 #: ../lib/vector/Vlib/open.c:232
-#, fuzzy, c-format
+#, c-format
 msgid "Vector map <%s> not found in current mapset"
-msgstr "Defekts: atteikts papildināt karti,kura nav tekošajā karšu komplektā."
+msgstr "Vektoru karte <%s> pašreizējā karšu kopā nav atrasta"
-#: ../lib/vector/Vlib/open.c:252
+#: ../lib/vector/Vlib/open.c:250
 #, fuzzy
 msgid "Temporary vector maps can be accessed only in the current mapset"
-#: ../lib/vector/Vlib/open.c:266
-#, fuzzy
-msgid ""
-"Vector map which is not in the current mapset cannot be opened for update"
+#: ../lib/vector/Vlib/open.c:264
+msgid "Vector map which is not in the current mapset cannot be opened for update"
 msgstr ""
-"Karte kura nav iekļauta tekošajā karšu kolekcijā  nevar tikt atvērta "
-"papildināšanai."
-#: ../lib/vector/Vlib/open.c:300
-#, fuzzy, c-format
+#: ../lib/vector/Vlib/open.c:298
+#, c-format
 msgid "Unable to read header file of vector map <%s>"
+msgstr ""
-#: ../lib/vector/Vlib/open.c:340
-#, fuzzy, c-format
+#: ../lib/vector/Vlib/open.c:339
+#, c-format
 msgid "Unable to open topology file for vector map <%s>"
+msgstr ""
 #: ../lib/vector/Vlib/open.c:354
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open spatial index file for vector map <%s>"
+msgstr ""
-#: ../lib/vector/Vlib/open.c:377 ../lib/vector/Vlib/cindex.c:510
-#, fuzzy, c-format
+#: ../lib/vector/Vlib/open.c:380 ../lib/vector/Vlib/cindex.c:542
+#, c-format
 msgid "Unable to open category index file for vector map <%s>"
+msgstr ""
-#: ../lib/vector/Vlib/open.c:403 ../lib/vector/Vlib/open.c:425
-#, fuzzy, c-format
+#: ../lib/vector/Vlib/open.c:406 ../lib/vector/Vlib/open.c:428
+#, c-format
 msgid ""
 "Unable to open vector map <%s> on level %d. Try to rebuild vector topology "
 "by v.build."
-msgstr "Nevar atvērt veco vektoru %s līmenī %d"
+msgstr ""
-#: ../lib/vector/Vlib/open.c:434
-#, fuzzy, c-format
+#: ../lib/vector/Vlib/open.c:437
+#, c-format
 msgid "Building topology for OGR layer <%s> from datasource '%s'..."
-msgstr "Lūdzu pārveido topoloģiju vektoram '%s@%s'"
+msgstr ""
-#: ../lib/vector/Vlib/open.c:442
-#, fuzzy, c-format
+#: ../lib/vector/Vlib/open.c:445
+#, c-format
 msgid "Unable to open vector map <%s> on level %d"
+msgstr ""
-#: ../lib/vector/Vlib/open.c:496
-#, fuzzy, c-format
+#: ../lib/vector/Vlib/open.c:499
+#, c-format
 msgid "Unable to open history file for vector map <%s>"
+msgstr ""
-#: ../lib/vector/Vlib/open.c:768
+#: ../lib/vector/Vlib/open.c:771
 #, fuzzy, c-format
 msgid "Unable to create new vector map: <%s> is not the current mapset (%s)"
-#: ../lib/vector/Vlib/open.c:777
-#, fuzzy, c-format
+#: ../lib/vector/Vlib/open.c:780
+#, c-format
 msgid "Unable to create vector map <%s>. Name is not SQL compliant."
+msgstr "Nav iespējams izveidot vektoru karti <%s>. Nosaukums nav SQL savietojams"
-#: ../lib/vector/Vlib/open.c:835
-#, fuzzy, c-format
+#: ../lib/vector/Vlib/open.c:838
+#, c-format
 msgid "Unable to open history file of vector map <%s>"
+msgstr ""
-#: ../lib/vector/Vlib/open.c:874
+#: ../lib/vector/Vlib/open.c:877
 #, c-format
 msgid "Using OGR/%s format"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:878
+#: ../lib/vector/Vlib/open.c:881
 msgid "Using PostGIS Topology format"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:880
+#: ../lib/vector/Vlib/open.c:883
 msgid "Using PostGIS format"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:883
+#: ../lib/vector/Vlib/open.c:886
 #, fuzzy
 msgid "Using native format"
 msgstr "Vect_write_line() šim formātam/līmenim nav atbalstīta"
-#: ../lib/vector/Vlib/open.c:974
-#, fuzzy, c-format
+#: ../lib/vector/Vlib/open.c:977
+#, c-format
 msgid "Unable to stat file <%s>"
+msgstr ""
-#: ../lib/vector/Vlib/open.c:1038
+#: ../lib/vector/Vlib/open.c:1041
 #, c-format
 msgid "unknown %d (update Vect_maptype_info)"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:1130
-#, fuzzy
+#: ../lib/vector/Vlib/open.c:1133
 msgid "Size of 'coor' file differs from value saved in topology file"
 msgstr ""
-"Krāsas paremetru fails atšķiras no vērtībām kuras saglabātas topo failā."
-#: ../lib/vector/Vlib/open.c:1141 ../lib/vector/Vlib/open.c:1241
-#, fuzzy, c-format
+#: ../lib/vector/Vlib/open.c:1144 ../lib/vector/Vlib/open.c:1244
+#, c-format
 msgid "Please rebuild topology for vector map <%s@%s>"
+msgstr ""
-#: ../lib/vector/Vlib/open.c:1230
-#, fuzzy
+#: ../lib/vector/Vlib/open.c:1233
 msgid "Size of 'coor' file differs from value saved in sidx file"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:1310
-#, fuzzy
+#: ../lib/vector/Vlib/open.c:1313
 msgid "Unable to open OGR file"
+msgstr ""
-#: ../lib/vector/Vlib/open.c:1336
+#: ../lib/vector/Vlib/open.c:1339
 msgid "OGR output also detected, using OGR"
 msgstr ""
-#: ../lib/vector/Vlib/open.c:1348 ../lib/vector/Vlib/write_pg.c:527
-#: ../lib/vector/Vlib/write_pg.c:796
+#: ../lib/vector/Vlib/open_pg.c:104 ../lib/vector/Vlib/open_pg.c:257
 #, fuzzy
-msgid "Unable to open PG file"
+msgid "Unable to get database name"
+msgstr "Nevar pievienot datubāzes saiti"
+#: ../lib/vector/Vlib/open_pg.c:116 ../lib/vector/Vlib/open_pg.c:281
+#, fuzzy
+msgid "No feature tables found in database."
+msgstr "neiespējami atvērt elipsoīda tabulas failu: %s"
+#: ../lib/vector/Vlib/open_pg.c:140
+#, fuzzy, c-format
+msgid "Feature table <%s> not found in 'geometry_columns'"
+msgstr "Ieejas vektors '%s' nav atrasts"
+#: ../lib/vector/Vlib/open_pg.c:188
+msgid "Topology schema not found."
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:200 ../lib/vector/Vlib/open_ogr.c:145
+#, fuzzy, c-format
+msgid "Unable to open feature index file for vector map <%s>"
+#: ../lib/vector/Vlib/open_pg.c:287
+#, fuzzy, c-format
+msgid "PostGIS layer <%s.%s> already exists and will be overwritten"
+#: ../lib/vector/Vlib/open_pg.c:290
+#, fuzzy, c-format
+msgid "Unable to delete PostGIS layer <%s>"
-#: ../lib/vector/Vlib/dgraph.c:432
-msgid ""
-"Trying to add more edges to the planar_graph than the initial allocation "
-"size allows"
+#: ../lib/vector/Vlib/open_pg.c:296
+#, fuzzy, c-format
+msgid "PostGIS layer <%s.%s> already exists in database '%s'"
+#: ../lib/vector/Vlib/open_pg.c:404
+#, fuzzy
+msgid "No key column detected."
+msgstr "Ieejas vektorkartes nosaukums"
+#: ../lib/vector/Vlib/open_pg.c:473 ../lib/vector/Vlib/open_pg.c:485
+#, fuzzy, c-format
+msgid "Execution failed: %s"
+#: ../lib/vector/Vlib/open_pg.c:487
+#, c-format
+msgid "PostGIS topology schema <%s> dropped"
 msgstr ""
-#: ../lib/vector/Vlib/area.c:50
+#: ../lib/vector/Vlib/open_pg.c:520
 #, fuzzy
-msgid "Attempt to read points of nonexistent area"
-msgstr "Nevar nolasīt histogrammu priekš [%s no %s]"
+msgid "Connection to PostgreSQL database failed."
-#: ../lib/vector/Vlib/area.c:81
+#: ../lib/vector/Vlib/open_pg.c:526
+msgid "Spatial-enabled PostGIS database is required"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:534
 #, fuzzy
-msgid "Attempt to read points of nonexistent isle"
+msgid "PostGIS Topology extension not found in the database"
-#: ../lib/vector/Vlib/area.c:120 ../lib/vector/Vlib/area.c:152
-#: ../lib/vector/Vlib/area.c:218 ../lib/vector/Vlib/area.c:247
+#: ../lib/vector/Vlib/open_pg.c:620
+msgid "Empty bounding box"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:721
 #, fuzzy, c-format
-msgid "Attempt to read topo for dead area (%d)"
+msgid "Inconsistency in topology: unable to read node %d"
-#: ../lib/vector/Vlib/area.c:188 ../lib/vector/Vlib/area.c:274
+#: ../lib/vector/Vlib/open_pg.c:787
 #, fuzzy, c-format
-msgid "Attempt to read topo for dead isle (%d)"
+msgid "Inconsistency in topology: node %d - unexpected feature type %d"
-#: ../lib/vector/Vlib/cats.c:45
+#: ../lib/vector/Vlib/open_pg.c:957
+#, fuzzy, c-format
+msgid "Area %d without boundary detected"
+#: ../lib/vector/Vlib/open_pg.c:1015
+#, fuzzy, c-format
+msgid "Isle %d without boundary detected"
+#: ../lib/vector/Vlib/open_pg.c:1082
 #, fuzzy
+msgid "Unable to get map bounding box from topology"
+#: ../lib/vector/Vlib/open_pg.c:1089
+#, fuzzy, c-format
+msgid ""
+"Unable to parse map bounding box:\n"
+"%s"
+#: ../lib/vector/Vlib/open_pg.c:1113
+#, c-format
+msgid "Different number of nodes detected (%d, %d)"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:1141 ../lib/vector/Vlib/open_pg.c:1163
+#, c-format
+msgid "Different number of areas detected (%d, %d)"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:1334
+msgid "To be implemented: isles not attached in Topo-Geo-only mode"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:1523
+#, fuzzy, c-format
+msgid "Inconsistency in topology: number of points %d (should be %d)"
+#: ../lib/vector/Vlib/open_pg.c:1568
+#, fuzzy, c-format
+msgid "Inconsistency in topology: number of lines %d (should be %d)"
+#: ../lib/vector/Vlib/open_pg.c:1622
+#, fuzzy, c-format
+msgid "Inconsistency in topology: number of centroids %d (should be %d)"
+#: ../lib/vector/Vlib/cats.c:45
 msgid "Vect_new_cats_struct(): Out of memory"
-msgstr "Neiespējami piešķirt atmiņu\n"
+msgstr ""
 #: ../lib/vector/Vlib/cats.c:127
 #, c-format
@@ -5803,7 +5333,7 @@
 #: ../lib/vector/Vlib/cats.c:572 ../lib/vector/Vlib/cats.c:668
 #, fuzzy
 msgid "Layer number must be > 0 for category constraints"
-msgstr "Lauka nummuram ir jābūt 1 vai  lielākam."
+msgstr "Slāņa numuram ir jābūt 1 vai lielākam"
 #: ../lib/vector/Vlib/cats.c:585
 #, c-format
@@ -5811,19 +5341,22 @@
 msgstr ""
 #: ../lib/vector/Vlib/cats.c:593
-#, fuzzy, c-format
+#, c-format
 msgid "Loading categories from table <%s>..."
-msgstr " Rastra karte %s@%s ir tukša"
+msgstr "Ielādē kategorijas no tabulas <%s>..."
 #: ../lib/vector/Vlib/cats.c:603 ../lib/db/dbmi_client/select.c:317
-#, fuzzy, c-format
+#, c-format
 msgid "Unable select records from table <%s>"
-msgstr "Niespējami izveidot atkarību failu [%s iekš %s]"
+msgstr ""
 #: ../lib/vector/Vlib/cats.c:605
 #, c-format
-msgid "%d categories loaded"
-msgstr ""
+msgid "One category loaded"
+msgid_plural "%d categories loaded"
+msgstr[0] "Ielādēta %d kategorija"
+msgstr[1] "Ielādētas %d kategorijas"
+msgstr[2] "Ielādēts %d kategoriju"
 #: ../lib/vector/Vlib/cats.c:627
 #, c-format
@@ -5835,160 +5368,87 @@
 msgid "%d errors in '%s' option"
 msgstr ""
-#: ../lib/vector/Vlib/graph.c:138
-#, fuzzy
-msgid "Unable to add network arc"
-#: ../lib/vector/Vlib/intersect.c:127
-msgid "3D not supported by Vect_segment_intersection()"
+#: ../lib/vector/Vlib/header.c:87
+#, c-format
+msgid "Unable to create header file for vector map <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/intersect.c:313
-msgid "Vect_segment_intersection() ERROR (collinear vertical segments)"
+#: ../lib/vector/Vlib/header.c:131
+#, c-format
+msgid "Unable to open header file of vector <%s>"
 msgstr ""
-#: ../lib/vector/Vlib/intersect.c:407
-msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
+#: ../lib/vector/Vlib/header.c:139
+#, c-format
+msgid "Corrupted row in head: %s"
 msgstr ""
-#: ../lib/vector/Vlib/intersect.c:1157 ../lib/vector/Vlib/intersect.c:1163
-#: ../lib/vector/Vlib/intersect.c:1165 ../lib/vector/Vlib/intersect.c:1219
-#: ../lib/vector/Vlib/intersect.c:1228 ../lib/vector/Vlib/intersect.c:1249
-#: ../lib/vector/Vlib/intersect.c:1266
-msgid "Error while adding point to array. Out of memory"
+#: ../lib/vector/Vlib/header.c:177
+#, c-format
+msgid "Unknown keyword '%s' in vector head"
 msgstr ""
-#: ../lib/vector/Vlib/constraint.c:150
-msgid "Layer constraint ignored for non-native vector formats"
-msgstr ""
+#: ../lib/vector/Vlib/header.c:557 ../lib/gis/proj3.c:107
+msgid "Unknown projection"
+msgstr "Nezināma projekcija"
-#: ../lib/vector/Vlib/read_sfa.c:90
-#, fuzzy, c-format
-msgid "Unable to construct centroid for area %d. Skipped."
-#: ../lib/vector/Vlib/read_sfa.c:95
+#: ../lib/vector/Vlib/level_two.c:23
 #, c-format
-msgid "Centroid %d: invalid area %d"
+msgid "Vector map <%s> is not open at topological level"
 msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:102
-msgid "Break polygons: Bug in binary tree!"
-msgstr ""
+#: ../lib/vector/Vlib/level_two.c:284
+#, c-format
+msgid "Invalid node id: %d"
-#: ../lib/vector/Vlib/break_polygons.c:156
-msgid "Break polygons Pass 1: select break points"
-msgstr ""
+#: ../lib/vector/Vlib/level_two.c:316
+#, c-format
+msgid "Nodes not available for line %d"
+msgstr "%d līnijas mezgli nav pieejami"
-#: ../lib/vector/Vlib/break_polygons.c:286
-msgid "Break polygons Pass 2: break at selected points"
+#: ../lib/vector/Vlib/level_two.c:357
+#, c-format
+msgid "Areas not available for line %d"
 msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:398
-#: ../lib/vector/Vlib/break_polygons.c:650
+#: ../lib/vector/Vlib/level_two.c:362
 #, c-format
-msgid "Breaks: %d"
-msgstr ""
+msgid "Line %d is not a boundary"
+msgstr "%d līnija nav robeža"
-#: ../lib/vector/Vlib/break_polygons.c:435
-msgid "Breaking polygons (pass 1: select break points)..."
-msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:552
-msgid "Breaking polygons (pass 2: break at selected points)..."
-msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:592
-msgid "Point not in search tree!"
-msgstr ""
-#: ../lib/vector/Vlib/simple_features.c:225
-#, fuzzy, c-format
-msgid "Unknown Simple Features type (%d)"
-#: ../lib/vector/Vlib/simple_features.c:324 ../lib/vector/Vlib/write_pg.c:313
-#: ../lib/vector/Vlib/write_pg.c:1083 ../lib/vector/Vlib/write_pg.c:1233
-#, fuzzy
-msgid "No connection defined"
-#: ../lib/vector/Vlib/simple_features.c:332
-#, fuzzy
-msgid "Unable to get number of simple features"
-#: ../lib/vector/Vlib/simple_features.c:341
-#, fuzzy, c-format
-msgid "Unable to report simple features for vector map <%s>"
-#: ../lib/vector/Vlib/buffer2.c:361
-#, fuzzy
-msgid "Line is not looped"
-#: ../lib/vector/Vlib/buffer2.c:443
+#: ../lib/vector/Vlib/level_two.c:445
 #, c-format
-msgid "Unexpected result of line_intersection() res = %d"
+msgid "Topology info not available for feature %d"
 msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:589
-msgid ""
-"Next edge was visited (right) but it is not the first one !!! breaking loop"
+#: ../lib/vector/Vlib/write_sfa.c:113
+msgid "Unable to calculate centroid for area"
 msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:600
-msgid ""
-"Next edge was visited (left) but it is not the first one !!! breaking loop"
+#: ../lib/vector/Vlib/write_sfa.c:127 ../lib/vector/Vlib/write_sfa.c:170
+#: ../lib/vector/Vlib/write_sfa.c:266 ../lib/vector/Vlib/read_sfa.c:124
+msgid "GRASS is not compiled with OGR/PostgreSQL support"
 msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:648
-msgid "side != 0 feature not implemented"
-msgstr ""
+#: ../lib/vector/Vlib/write_sfa.c:212
+msgid "Attempt to delete dead feature"
+msgstr "Mēģinājums dzēst mirušu objektu"
-#: ../lib/vector/Vlib/buffer2.c:890 ../lib/vector/Vlib/buffer2.c:937
-msgid "zero area size"
-msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:896 ../lib/vector/Vlib/buffer2.c:943
-#, fuzzy
-msgid "Line was not closed"
-#: ../lib/vector/Vlib/buffer2.c:909 ../lib/vector/Vlib/buffer2.c:960
-msgid "Vect_get_point_in_poly() failed"
-msgstr ""
-#: ../lib/vector/Vlib/array.c:96
+#: ../lib/vector/Vlib/write_sfa.c:304
 #, c-format
-msgid "%d errors in category string"
-msgstr ""
+msgid "Unsupported vector map format (%d)"
+msgstr "Neatbalstīts vektoru kartes formāts (%d)"
-#: ../lib/vector/Vlib/array.c:142 ../lib/vector/Vlib/array.c:267
-msgid "Mixed area and other type requested for vector array"
-msgstr ""
-#: ../lib/vector/Vlib/array.c:152 ../lib/vector/Vlib/array.c:175
-#: ../lib/vector/Vlib/array.c:304 ../lib/vector/Vlib/array.c:336
-msgid "Not enough space in vector array"
-msgstr ""
-#: ../lib/vector/Vlib/array.c:292
-#, fuzzy, c-format
-msgid "Unable to select record from table <%s> (key %s, where %s)"
 #: ../lib/vector/Vlib/write.c:187 ../lib/vector/Vlib/write.c:339
-#, fuzzy, c-format
+#, c-format
 msgid "Vector map <%s> is not opened"
+msgstr "Vektoru karte <%s> nav atvērta"
 #: ../lib/vector/Vlib/write.c:200
 #, fuzzy, c-format
 msgid "Unable to write feature in vector map <%s>"
+msgstr "Nevar atvērt vēsturi vektoram '%s'"
 #: ../lib/vector/Vlib/write.c:250
 #, fuzzy, c-format
@@ -5998,7 +5458,7 @@
 #: ../lib/vector/Vlib/write.c:289
 #, fuzzy, c-format
 msgid "Unable to delete feature %d from vector map <%s>"
 #: ../lib/vector/Vlib/write.c:330
 #, fuzzy, c-format
@@ -6008,471 +5468,152 @@
 #: ../lib/vector/Vlib/write.c:344
 #, fuzzy, c-format
 msgid "Vector map <%s> is not opened on topology level"
 #: ../lib/vector/Vlib/write.c:350
 #, fuzzy, c-format
 msgid "Vector map <%s> is not opened in write mode"
-#: ../lib/vector/Vlib/build_sfa.c:279 ../lib/vector/Vlib/build_sfa.c:546
-#, fuzzy, c-format
-msgid "Unable to calculate centroid for area %d"
-#: ../lib/vector/Vlib/build_sfa.c:305
-#, fuzzy, c-format
-msgid "Feature type %d not supported"
-#: ../lib/vector/Vlib/build_sfa.c:603 ../lib/vector/Vlib/read_ogr.c:344
-#: ../lib/vector/Vlib/read_ogr.c:578
+#: ../lib/vector/Vlib/ascii.c:84
 #, c-format
-msgid "OGR feature type %d not supported"
+msgid "Error reading ASCII file: (bad type) [%s]"
 msgstr ""
-#: ../lib/vector/Vlib/build_sfa.c:665
-#, fuzzy, c-format
-msgid "%d %s without geometry skipped"
-#: ../lib/vector/Vlib/build_sfa.c:723
-#, fuzzy, c-format
-msgid "%s: Native format unsupported"
-msgstr "Vect_write_line() šim formātam/līmenim nav atbalstīta"
-#: ../lib/vector/Vlib/build_sfa.c:749
-msgid "Feature index is built only for non-native formats. Nothing to dump."
+#: ../lib/vector/Vlib/ascii.c:123
+#, c-format
+msgid "Error reading ASCII file: (unknown type) [%s]"
 msgstr ""
-#: ../lib/vector/Vlib/break_lines.c:559
-#, fuzzy, c-format
-msgid "Intersections: %d"
-msgstr "Cita Projekcija"
-#: ../lib/vector/Vlib/close_pg.c:141 ../lib/vector/Vlib/close_ogr.c:109
-#, fuzzy, c-format
-msgid "Unable to save feature index file for vector map <%s>"
-#: ../lib/vector/Vlib/cindex.c:29
-msgid "Category index is not up to date"
+#: ../lib/vector/Vlib/ascii.c:143
+msgid "End of ASCII file reached before end of coordinates"
 msgstr ""
-#: ../lib/vector/Vlib/cindex.c:61 ../lib/vector/Vlib/cindex.c:127
-#: ../lib/vector/Vlib/cindex.c:147 ../lib/vector/Vlib/cindex.c:169
-msgid "Invalid layer index (index >= number of layers)"
+#: ../lib/vector/Vlib/ascii.c:155
+#, c-format
+msgid "Error reading ASCII file: (bad point) [%s]"
 msgstr ""
-#: ../lib/vector/Vlib/cindex.c:109
-msgid "Invalid layer index (index < 0 or index >= number of layers)"
-msgstr ""
-#: ../lib/vector/Vlib/cindex.c:234
-#, fuzzy
-msgid "Layer or category index out of range"
-#: ../lib/vector/Vlib/cindex.c:302
-#, fuzzy
-msgid "Layer index out of range"
-#: ../lib/vector/Vlib/cindex.c:457
-#, fuzzy, c-format
-msgid "Unable to create category index file for vector map <%s>"
-#: ../lib/vector/Vlib/cindex.c:466
-#, fuzzy
-msgid "Error writing out category index file"
-msgstr "Kļūdu rakstīšana ārpus telpisko datu index faila.\n"
-#: ../lib/vector/Vlib/field.c:91
-#, fuzzy
-msgid "Layer number must be 1 or greater"
-#: ../lib/vector/Vlib/field.c:96
-#, fuzzy
-msgid "Unable to add attribute link, vector map is not opened in WRITE mode"
-msgstr ""
-"Nevar pievienot datubāzes saiti,karte nav atvērta rakstīšanas 'WRITE' "
-"režijmā."
-#: ../lib/vector/Vlib/field.c:103
-#, fuzzy
-msgid "Unable to add attribute link"
-msgstr "Nevar pievienot datubāzes saiti"
-#: ../lib/vector/Vlib/field.c:109
-#, fuzzy
-msgid "Unable to write attribute links"
-msgstr "Nevar ierakstīt datubāzes saites"
-#: ../lib/vector/Vlib/field.c:154
-#, fuzzy
-msgid "Unable to write database links"
-#: ../lib/vector/Vlib/field.c:178
-msgid "Database connection not defined. Skipping."
-msgstr ""
-#: ../lib/vector/Vlib/field.c:185
-msgid ""
-"More DB links defined for input vector map. Using only first DB link for "
-"output."
-msgstr ""
-#: ../lib/vector/Vlib/field.c:261
-#, fuzzy, c-format
-msgid "Layer number %d or name <%s> already exists"
-msgstr "Laukuma nummurs<%d> vai vārds <%s> jau eksistē"
-#: ../lib/vector/Vlib/field.c:345
-#, fuzzy, c-format
-msgid ""
-"Default driver / database set to:\n"
-"driver: %s\n"
-"database: %s"
-msgstr ""
-"Noklusēto draiveri / datubāzi likt uz:\n"
-"vietu: dbf\n"
-"datubāze: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/"
-#: ../lib/vector/Vlib/field.c:352
-msgid "Default driver is not set"
-msgstr "Noklusētais draiveris nav uzstādīts"
-#: ../lib/vector/Vlib/field.c:355
-msgid "Default database is not set"
-msgstr " Noklusētā datubāze nav uzstādīta"
-#: ../lib/vector/Vlib/field.c:412
+#: ../lib/vector/Vlib/ascii.c:160
 #, c-format
-msgid "Requested dblink %d, maximum link number %d"
-msgstr "RAtrastā dbsaite %d, maksimāli iespējamosaišu skaits %d"
-#: ../lib/vector/Vlib/field.c:599 ../lib/vector/Vlib/field.c:607
-#, fuzzy, c-format
-msgid "Error in rule on row %d in <%s>"
-msgstr "Kļūda noteikuma rindā %d iekš %s "
-#: ../lib/vector/Vlib/field.c:692
-#, fuzzy, c-format
-msgid "Unable to open OGR layer <%s>"
-#: ../lib/vector/Vlib/field.c:719
-#, fuzzy
-msgid "Unable to open OGR DBMI driver"
-msgstr "Nevar atvērt OGR DBMI draiveri."
-#: ../lib/vector/Vlib/field.c:758
-msgid ""
-"All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
-"available in OGR DB table"
+msgid "Unparsable longitude value: [%s]"
 msgstr ""
-#: ../lib/vector/Vlib/field.c:825
+#: ../lib/vector/Vlib/ascii.c:165
 #, c-format
-msgid ""
-"Feature table <%s> has no primary key defined. Unable to define DB links."
+msgid "Unparsable latitude value: [%s]"
 msgstr ""
-#: ../lib/vector/Vlib/field.c:845
-msgid "GRASS not compiled with PostgreSQL support"
+#: ../lib/vector/Vlib/ascii.c:201
+msgid "End of ASCII file reached before end of categories"
 msgstr ""
-#: ../lib/vector/Vlib/field.c:877
-#, fuzzy
-msgid "Unknown vector map format"
-#: ../lib/vector/Vlib/field.c:911
-#, fuzzy, c-format
-msgid "Unable to create database definition file for vector map <%s>"
-#: ../lib/vector/Vlib/field.c:1006
-#, fuzzy
-msgid "Bug: attempt to update map which is not in current mapset"
-#: ../lib/vector/Vlib/remove_areas.c:109 ../lib/vector/Vlib/remove_areas.c:274
-msgid "Area is composed of dead boundary"
-msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:196 ../lib/vector/Vlib/remove_areas.c:597
+#: ../lib/vector/Vlib/ascii.c:212
 #, c-format
-msgid "%d areas of total size %g removed"
+msgid "Error reading categories: [%s]"
 msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:401
-msgid "Could not delete line from coor"
-msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:458 ../lib/vector/Vlib/remove_areas.c:492
+#: ../lib/vector/Vlib/ascii.c:225
 #, fuzzy
-msgid "Failed to build new area"
-#: ../lib/vector/Vlib/remove_areas.c:463 ../lib/vector/Vlib/remove_areas.c:496
-msgid "Dissolve with neighbour area: corrupt topology"
-msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:477 ../lib/vector/Vlib/remove_areas.c:560
-msgid "Neighbor boundaries should be complete"
-msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:541 ../lib/vector/Vlib/remove_areas.c:567
-#, fuzzy
-msgid "Failed to build new isle"
-#: ../lib/vector/Vlib/remove_areas.c:546 ../lib/vector/Vlib/remove_areas.c:572
-msgid "Dissolve with outer isle: corrupt topology"
-msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:578
-#, fuzzy
-msgid "Area merging failed"
-#: ../lib/vector/Vlib/read_ogr.c:215 ../lib/vector/Vlib/read_ogr.c:224
-#, fuzzy, c-format
-msgid "Unable to get feature geometry, fid %ld"
+msgid "Unable to copy points"
-#: ../lib/vector/Vlib/read_ogr.c:390
-msgid "OGR feature without ID"
+#: ../lib/vector/Vlib/ascii.c:238
+#, c-format
+msgid "Vector map <%s> is 2D. %d 3D features (faces or kernels) skipped."
 msgstr ""
-#: ../lib/vector/Vlib/read_ogr.c:514
+#: ../lib/vector/Vlib/ascii.c:270
 #, c-format
-msgid "OGR feature type '%s' not supported"
+msgid ""
+"Unexpected data in vector header:\n"
+"[%s]"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:277
-#, fuzzy, c-format
-msgid "Unable to rewrite feature %d"
-#: ../lib/vector/Vlib/write_pg.c:318 ../lib/vector/Vlib/write_ogr.c:134
-#, fuzzy, c-format
-msgid "Invalid offset (%d)"
-#: ../lib/vector/Vlib/write_pg.c:339 ../lib/vector/Vlib/write_ogr.c:140
-#, fuzzy
-msgid "Unable to delete feature"
-#: ../lib/vector/Vlib/write_pg.c:437
-#, fuzzy, c-format
-msgid "Unable to delete feature (%s) %d"
-#: ../lib/vector/Vlib/write_pg.c:573 ../lib/vector/Vlib/write_ogr.c:192
-#: ../lib/vector/Vlib/ascii.c:404 ../lib/db/dbmi_client/db.c:41
-#: ../lib/db/dbmi_client/copy_tab.c:107 ../lib/db/dbmi_client/copy_tab.c:127
-#, fuzzy, c-format
-msgid "Unable to start driver <%s>"
-#: ../lib/vector/Vlib/write_pg.c:588
-#, fuzzy, c-format
-msgid "Unable to desribe table <%s>"
-#: ../lib/vector/Vlib/write_pg.c:692
-#, fuzzy, c-format
-msgid "Building spatial index on <%s>..."
-#: ../lib/vector/Vlib/write_pg.c:755
+#: ../lib/vector/Vlib/ascii.c:306
 #, c-format
-msgid "Schema <%s> doesn't exist, created"
+msgid "Unknown keyword <%s> in vector head"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:828
-#, fuzzy, c-format
-msgid "Creating topology schema <%s>..."
-#: ../lib/vector/Vlib/write_pg.c:847
-#, fuzzy, c-format
-msgid "Adding new topology column <%s>..."
-#: ../lib/vector/Vlib/write_pg.c:974 ../lib/vector/Vlib/write_ogr.c:304
+#: ../lib/vector/Vlib/ascii.c:486
 #, c-format
-msgid "Unsupported geometry type (%d)"
+msgid "Unknown type of column <%s>, export cancelled"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:987 ../lib/vector/Vlib/write_ogr.c:338
+#: ../lib/vector/Vlib/ascii.c:610
 #, c-format
-msgid "More layers defined, using driver <%s> and database <%s>"
+msgid "Unknown feature type %d"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:991 ../lib/vector/Vlib/write_ogr.c:344
-msgid "Database connection not defined. Unable to write attributes."
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:998
-#, fuzzy
-msgid "Unable to create new PostGIS feature table"
-#: ../lib/vector/Vlib/write_pg.c:1012
-#, fuzzy
-msgid "Unable to create new PostGIS topology schema"
-msgstr "neiespējami izveidot jaunu procesu"
-#: ../lib/vector/Vlib/write_pg.c:1110 ../lib/vector/Vlib/write_pg.c:1265
-#: ../lib/vector/Vlib/write_ogr.c:408
+#: ../lib/vector/Vlib/ascii.c:645
 #, c-format
-msgid "No category defined for layer %d"
+msgid "Unable to select record from table <%s> (key %s, column %s)"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1112 ../lib/vector/Vlib/write_pg.c:1267
-#: ../lib/vector/Vlib/write_ogr.c:410
+#: ../lib/vector/Vlib/ascii.c:675
 #, c-format
-msgid "Feature has more categories, using category %d (from layer %d)"
+msgid "Feature has more categories. Only one category (%d) is exported."
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1123
+#: ../lib/vector/Vlib/ascii.c:692
 #, fuzzy, c-format
-msgid "Point skipped (output feature type: %s)"
+msgid "Cannot select attributes for cat = %d"
+msgstr "Nevar dzēst līniju"
-#: ../lib/vector/Vlib/write_pg.c:1130
-#, fuzzy, c-format
-msgid "Line skipped (output feature type: %s)"
+#: ../lib/vector/Vlib/ascii.c:698
+#, fuzzy
+msgid "Unable to fetch data from table"
-#: ../lib/vector/Vlib/write_pg.c:1137
-#, c-format
-msgid "Boundary/centroid skipped (output feature type: %s)"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1139 ../lib/vector/Vlib/write_ogr.c:439
-msgid "Feature is not a polygon. Skipping."
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1145
+#: ../lib/vector/Vlib/ascii.c:732
 #, fuzzy, c-format
-msgid "Face skipped (output feature type: %s)"
+msgid "Column <%s>: unsupported data type"
+msgstr "Nevar atvērt datubāzi %s"
-#: ../lib/vector/Vlib/write_pg.c:1227
-#, fuzzy, c-format
-msgid "Invalid feature type (%d) for nodes"
-#: ../lib/vector/Vlib/write_pg.c:1241
+#: ../lib/vector/Vlib/ascii.c:813
 #, fuzzy
-msgid "PostGIS topology schema not defined"
+msgid "Unknown format"
-#: ../lib/vector/Vlib/write_pg.c:1736
-msgid "Trying to insert 3D data into feature table which store 2D data only"
+#: ../lib/vector/Vlib/ascii.c:823
+msgid "Topology not available, unable to process areas"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1741
-msgid "Trying to insert 2D data into feature table which store 3D data only"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1766
-#, fuzzy
-msgid "Unable to insert topological element into PostGIS Topology schema"
-#: ../lib/vector/Vlib/write_pg.c:1864 ../lib/vector/Vlib/write_ogr.c:579
+#: ../lib/vector/Vlib/ascii.c:836
 #, fuzzy, c-format
-msgid "Unable to select attributes for category %d"
+msgid "Unable to get boundary of area id %d"
+msgstr "Nevar atvērt 'temp'/pagaidu failu"
-#: ../lib/vector/Vlib/write_pg.c:1868 ../lib/vector/Vlib/write_ogr.c:585
-#: ../lib/db/dbmi_client/copy_tab.c:314
+#: ../lib/vector/Vlib/ascii.c:848
 #, fuzzy, c-format
-msgid "Unable to fetch data from table <%s>"
+msgid "Unable to get boundary of isle id %d (area id %d)"
-#: ../lib/vector/Vlib/write_pg.c:1873 ../lib/vector/Vlib/write_ogr.c:591
+#: ../lib/vector/Vlib/ascii.c:860
 #, c-format
-msgid "No database record for category %d, no attributes will be written"
+msgid ""
+"%d features without category skipped. To export also features without "
+"category use '%s=-1'."
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1899
-#, c-format
-msgid "FID column must be integer, column <%s> ignored!"
+#: ../lib/vector/Vlib/write_ogr.c:129 ../lib/vector/Vlib/open_ogr.c:65
+msgid "OGR layer not defined"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1933 ../lib/vector/Vlib/write_ogr.c:653
-#, fuzzy, c-format
-msgid "Unsupported column type %d"
-#: ../lib/vector/Vlib/write_pg.c:1940
-msgid "Invalid value for FID column: NULL"
+#: ../lib/vector/Vlib/write_ogr.c:134
+#, c-format
+msgid "Invalid offset (%d)"
 msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:2032
-#, fuzzy, c-format
-msgid "Invalid feature %d (max: %d)"
-#: ../lib/vector/Vlib/write_pg.c:2046
-#, fuzzy, c-format
-msgid "Invalid feature type (%d) for node"
-#: ../lib/vector/Vlib/write_pg.c:2050
-#, fuzzy, c-format
-msgid "Invalid node %d (%d)"
-#: ../lib/vector/Vlib/write_pg.c:2128
-#, fuzzy, c-format
-msgid "Unable to determine next left/right edge for edge %d"
-msgstr "Neiespējami atvērt failu %s iekš %s"
-#: ../lib/vector/Vlib/write_pg.c:2133
-#, fuzzy
-msgid "Unable to insert new edge. Topology not available."
-#: ../lib/vector/Vlib/write_pg.c:2232 ../lib/vector/Vlib/write_pg.c:2239
-#, fuzzy
-msgid "Invalid topology"
-msgstr "Veidojam topoloģiju... \n"
-#: ../lib/vector/Vlib/write_pg.c:2438 ../lib/vector/Vlib/write_pg.c:2535
-#, fuzzy, c-format
-msgid "Attempt to access non-existing feature %d"
-#: ../lib/vector/Vlib/write_pg.c:2469
-#, fuzzy
-msgid "Unable to determine next left/right edge"
-#: ../lib/vector/Vlib/write_pg.c:2555
-#, fuzzy
-msgid "Unable to create new face"
 #: ../lib/vector/Vlib/write_ogr.c:239
-#, fuzzy, c-format
+#, c-format
 msgid "Creating field <%s> failed"
+msgstr ""
 #: ../lib/vector/Vlib/write_ogr.c:326
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create OGR layer <%s> in '%s'"
+msgstr ""
 #: ../lib/vector/Vlib/write_ogr.c:424
 msgid "Feature is not a point. Skipping."
@@ -6487,18 +5628,19 @@
 msgstr ""
 #: ../lib/vector/Vlib/write_ogr.c:452
-#, fuzzy, c-format
+#, c-format
 msgid "Unsupported feature type (%d)"
-msgstr "nezināns interpolācijas tips"
 #: ../lib/vector/Vlib/write_ogr.c:471
+#, fuzzy
 msgid "Boundary is not closed. Feature skipped."
-msgstr ""
 #: ../lib/vector/Vlib/write_ogr.c:500
 #, fuzzy
 msgid "Unable to writes feature attributes"
+msgstr "Nevar ierakstīt atribūtu saiti"
 #: ../lib/vector/Vlib/write_ogr.c:565
 #, c-format
@@ -6506,1130 +5648,1092 @@
 msgstr ""
 #: ../lib/vector/Vlib/write_ogr.c:624
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create field <%s>"
+msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:84
-#, fuzzy
-msgid "No DB connection"
-msgstr "Nav pieslēdzies...\n"
+#: ../lib/vector/Vlib/constraint.c:150
+msgid "Layer constraint ignored for non-native vector formats"
+msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:91
-msgid "Random read is not supported for this layer. Unable to build topology."
+#: ../lib/vector/Vlib/snap.c:213
+msgid "Snap vertices Pass 1: select points"
 msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:101
-#, fuzzy
-msgid "Building pseudo-topology over simple features..."
+#: ../lib/vector/Vlib/snap.c:267
+msgid "Snap vertices Pass 2: assign anchor vertices"
+msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:103
+#: ../lib/vector/Vlib/snap.c:336
+msgid "Snap vertices Pass 3: snap to assigned points"
+msgstr ""
+#: ../lib/vector/Vlib/snap.c:518
+#, c-format
+msgid "Snapped vertices: %d"
+msgstr ""
+#: ../lib/vector/Vlib/snap.c:519
 #, fuzzy, c-format
-msgid "Building topology from PostGIS topology schema <%s>..."
+msgid "New vertices: %d"
+msgstr "Pirmatnējo/vienkāršo datu skaits:   %d\n"
-#: ../lib/vector/Vlib/build_pg.c:224
+#: ../lib/vector/Vlib/snap.c:546
 #, fuzzy
-msgid "Updating faces..."
+msgid "Reading features..."
-#: ../lib/vector/Vlib/build_pg.c:256
-#, fuzzy
-msgid "Updating edges..."
+#: ../lib/vector/Vlib/build_nat.c:84
+msgid "Unable to read vector map"
+msgstr "Nav iespējams nolasīt vektoru karti"
-#: ../lib/vector/Vlib/build_pg.c:265
-msgid "Inconsistency in topology detected. Dead line found."
-msgstr ""
+#: ../lib/vector/Vlib/build_nat.c:129
+msgid "Building areas..."
+msgstr "Veido poligonus..."
-#: ../lib/vector/Vlib/build_pg.c:319
-msgid "Updating TopoGeometry data..."
-msgstr ""
+#: ../lib/vector/Vlib/build_nat.c:152
+#, c-format
+msgid "One area built"
+msgid_plural "%d areas built"
+msgstr[0] "Izveidots %d laukums"
+msgstr[1] "Izveidoti %d laukumi"
+msgstr[2] "Izveidots %d laukumu"
-#: ../lib/vector/Vlib/build_pg.c:375
-#, fuzzy, c-format
-msgid "Unsupported topo geometry type %d"
+#: ../lib/vector/Vlib/build_nat.c:153
+#, c-format
+msgid "One isle built"
+msgid_plural "%d isles built"
+msgstr[0] "Izveidota %d sala"
+msgstr[1] "Izveidotas %d salas"
+msgstr[2] "Izveidots %d salu"
-#: ../lib/vector/Vlib/build_pg.c:404
-#, fuzzy, c-format
-msgid "Unable to create <%s.%s>"
+#: ../lib/vector/Vlib/build_nat.c:162
+msgid "Attaching islands..."
+msgstr "Pievieno salas..."
-#: ../lib/vector/Vlib/build_pg.c:632
-#, fuzzy, c-format
-msgid "Topology for centroid %d not available. Area %d skipped"
+#: ../lib/vector/Vlib/build_nat.c:178
+msgid "Attaching centroids..."
+msgstr "Pievieno centroīdus..."
-#: ../lib/vector/Vlib/header.c:87
+#: ../lib/vector/Vlib/write_nat.c:368
 #, fuzzy, c-format
-msgid "Unable to create header file for vector map <%s>"
-msgstr "Nevar atvērt vēsturi vektoram '%s'"
+msgid "Attempt to access alive feature %d"
-#: ../lib/vector/Vlib/header.c:131
-#, fuzzy, c-format
-msgid "Unable to open header file of vector <%s>"
-#: ../lib/vector/Vlib/header.c:139
+#: ../lib/vector/Vlib/write_nat.c:510 ../lib/vector/Vlib/write_nat.c:546
 #, c-format
-msgid "Corrupted row in head: %s"
+msgid "%s: Area %d does not exist"
 msgstr ""
-#: ../lib/vector/Vlib/header.c:177
+#: ../lib/vector/Vlib/write_nat.c:700
 #, fuzzy, c-format
-msgid "Unknown keyword '%s' in vector head"
+msgid "Attempt to access dead area %d"
-#: ../lib/vector/Vlib/header.c:557 ../lib/gis/proj3.c:105
-msgid "Unknown projection"
-msgstr "Nezināma projekcija"
+#: ../lib/vector/Vlib/build_ogr.c:69
+msgid "Empty OGR layer, nothing to build"
+msgstr ""
-#: ../lib/vector/Vlib/copy.c:82
-#, fuzzy, c-format
-msgid "Unable to copy features. Input vector map <%s> is not open"
-msgstr "Nevar ierakstīt līniju,karte nav atvērta"
+#: ../lib/vector/Vlib/build_ogr.c:82
+msgid "Random read is not supported by OGR for this layer. Unable to build topology."
+msgstr ""
-#: ../lib/vector/Vlib/copy.c:104
+#: ../lib/vector/Vlib/build_ogr.c:132
 #, fuzzy, c-format
-msgid "Unable to create PostGIS layer <%s>"
+msgid "Unable to open fidx file for write <%s>"
+msgstr "Nevar atvērt topo failu rakstīšanai: %s\n"
-#: ../lib/vector/Vlib/copy.c:133
-#, fuzzy, c-format
-msgid "Vector map <%s> not open on topological level. Areas will be skipped!"
-msgstr "Ieejas vektors '%s' nav atrasts"
+#: ../lib/vector/Vlib/graph.c:138
+msgid "Unable to add network arc"
+msgstr ""
-#: ../lib/vector/Vlib/copy.c:229 ../lib/vector/Vlib/copy.c:234
+#: ../lib/vector/Vlib/poly.c:222
 #, fuzzy
-msgid "Copying features..."
+msgid "Unable to find point in polygon"
+msgstr "neiespējami atrast [%s] iekš [%s]"
-#: ../lib/vector/Vlib/copy.c:231
-#, c-format
-msgid "Copying features (%s)..."
+#: ../lib/vector/Vlib/poly.c:640
+#, fuzzy
+msgid "conditions failed"
+#: ../lib/vector/Vlib/cindex.c:32
+msgid "Category index is not up to date"
 msgstr ""
-#: ../lib/vector/Vlib/copy.c:334
+#: ../lib/vector/Vlib/cindex.c:38
+msgid "Layer index out of range"
+msgstr "Slāņa indekss ārpus robežām"
+#: ../lib/vector/Vlib/cindex.c:268
 #, fuzzy
-msgid "Writing new feature failed"
+msgid "Category index out of range"
-#: ../lib/vector/Vlib/copy.c:340
+#: ../lib/vector/Vlib/cindex.c:489
 #, fuzzy, c-format
-msgid "%d features without category or from different layer skipped"
-msgstr "Bez centroīdiem esošu laukumu skaits :   %d\n"
+msgid "Unable to create category index file for vector map <%s>"
-#: ../lib/vector/Vlib/copy.c:372
+#: ../lib/vector/Vlib/cindex.c:498
 #, fuzzy
-msgid "Exporting nodes..."
+msgid "Error writing out category index file"
+msgstr "Kļūdu rakstīšana ārpus telpisko datu index faila.\n"
-#: ../lib/vector/Vlib/copy.c:400
-#, fuzzy, c-format
-msgid "Writing node %d failed"
+#: ../lib/vector/Vlib/open_ogr.c:60
+msgid "OGR datasource not defined"
+msgstr ""
-#: ../lib/vector/Vlib/copy.c:478
-#, fuzzy
-msgid "Exporting areas..."
+#: ../lib/vector/Vlib/open_ogr.c:77 ../lib/vector/Vlib/field.c:675
+#, c-format
+msgid "Unable to open OGR data source '%s'"
+msgstr ""
-#: ../lib/vector/Vlib/copy.c:502
+#: ../lib/vector/Vlib/open_ogr.c:97
 #, c-format
-msgid "No centroid defined for area %d. Area not exported."
+msgid "OGR layer <%s> not found"
 msgstr ""
-#: ../lib/vector/Vlib/copy.c:530
-#, fuzzy, c-format
-msgid "Writing area %d failed"
+#: ../lib/vector/Vlib/open_ogr.c:191
+#, c-format
+msgid "Unable to get OGR driver <%s>"
+msgstr ""
-#: ../lib/vector/Vlib/copy.c:536
+#: ../lib/vector/Vlib/open_ogr.c:199
 #, c-format
-msgid "%d areas without category or from different layer skipped"
+msgid "Unable to create OGR data source '%s'"
 msgstr ""
-#: ../lib/vector/Vlib/copy.c:597 ../lib/vector/Vlib/copy.c:738
-#, fuzzy, c-format
-msgid "Unable to add database link for vector map <%s>"
+#: ../lib/vector/Vlib/open_ogr.c:211
+#, c-format
+msgid "OGR layer <%s> already exists and will be overwritten"
+msgstr ""
-#: ../lib/vector/Vlib/ascii.c:84
-#, fuzzy, c-format
-msgid "Error reading ASCII file: (bad type) [%s]"
-msgstr "Nederīgs histogrammas fails priekš [%s iekš %s]"
+#: ../lib/vector/Vlib/open_ogr.c:215
+#, c-format
+msgid "Unable to delete OGR layer <%s>"
+msgstr ""
-#: ../lib/vector/Vlib/ascii.c:123
-#, fuzzy, c-format
-msgid "Error reading ASCII file: (unknown type) [%s]"
+#: ../lib/vector/Vlib/open_ogr.c:221
+#, c-format
+msgid "OGR layer <%s> already exists in datasource '%s'"
+msgstr ""
-#: ../lib/vector/Vlib/ascii.c:143
-msgid "End of ASCII file reached before end of coordinates"
+#: ../lib/vector/Vlib/open_ogr.c:279
+#, c-format
+msgid ""
+"Feature index format version %d.%d is not supported by this release. Try to "
+"rebuild topology or upgrade GRASS."
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:155
-#, fuzzy, c-format
-msgid "Error reading ASCII file: (bad point) [%s]"
+#: ../lib/vector/Vlib/open_ogr.c:284
+#, c-format
+msgid ""
+"Your GRASS version does not fully support feature index format %d.%d of the "
+"vector. Consider to rebuild topology or upgrade GRASS."
+msgstr ""
-#: ../lib/vector/Vlib/ascii.c:160
-#, fuzzy, c-format
-msgid "Unparsable longitude value: [%s]"
+#: ../lib/vector/Vlib/break_lines.c:563
+#, c-format
+msgid "Intersections: %d"
+msgstr "Krustojumi: %d"
-#: ../lib/vector/Vlib/ascii.c:165
+#: ../lib/vector/Vlib/merge_lines.c:240
 #, c-format
-msgid "Unparsable latitude value: [%s]"
+msgid "%d boundaries merged"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:201
-msgid "End of ASCII file reached before end of categories"
+#: ../lib/vector/Vlib/merge_lines.c:241
+#, c-format
+msgid "%d new boundaries"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:212
-#, fuzzy, c-format
-msgid "Error reading categories: [%s]"
+#: ../lib/vector/Vlib/read_ogr.c:215 ../lib/vector/Vlib/read_ogr.c:224
+#, c-format
+msgid "Unable to get feature geometry, fid %ld"
+msgstr ""
-#: ../lib/vector/Vlib/ascii.c:225
-#, fuzzy
-msgid "Unable to copy points"
+#: ../lib/vector/Vlib/read_ogr.c:382 ../lib/vector/Vlib/read_pg.c:482
+msgid "Feature without geometry. Skipped."
+msgstr ""
-#: ../lib/vector/Vlib/ascii.c:238
+#: ../lib/vector/Vlib/read_ogr.c:390
+msgid "OGR feature without ID"
+msgstr ""
+#: ../lib/vector/Vlib/read_ogr.c:514
 #, c-format
-msgid "Vector map <%s> is 2D. %d 3D features (faces or kernels) skipped."
+msgid "OGR feature type '%s' not supported"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:270
+#: ../lib/vector/Vlib/read_sfa.c:90
 #, c-format
-msgid ""
-"Unexpected data in vector header:\n"
-"[%s]"
+msgid "Unable to construct centroid for area %d. Skipped."
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:306
-#, fuzzy, c-format
-msgid "Unknown keyword <%s> in vector head"
-#: ../lib/vector/Vlib/ascii.c:486
+#: ../lib/vector/Vlib/read_sfa.c:95
 #, c-format
-msgid "Unknown type of column <%s>, export cancelled"
+msgid "Centroid %d: invalid area %d"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:610
+#: ../lib/vector/Vlib/read_sfa.c:117 ../lib/vector/Vlib/read_pg.c:192
 #, fuzzy, c-format
-msgid "Unknown feature type %d"
+msgid "Unexpected feature type (%d) - should be (%d)"
-#: ../lib/vector/Vlib/ascii.c:645
-#, fuzzy, c-format
-msgid "Unable to select record from table <%s> (key %s, column %s)"
+#: ../lib/vector/Vlib/break_polygons.c:102
+msgid "Break polygons: Bug in binary tree!"
+msgstr ""
-#: ../lib/vector/Vlib/ascii.c:675
+#: ../lib/vector/Vlib/break_polygons.c:156
+msgid "Break polygons Pass 1: select break points"
+msgstr ""
+#: ../lib/vector/Vlib/break_polygons.c:286
+msgid "Break polygons Pass 2: break at selected points"
+msgstr ""
+#: ../lib/vector/Vlib/break_polygons.c:398
+#: ../lib/vector/Vlib/break_polygons.c:650
 #, c-format
-msgid "Feature has more categories. Only one category (%d) is exported."
+msgid "Breaks: %d"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:692
-#, fuzzy, c-format
-msgid "Cannot select attributes for cat = %d"
-msgstr "Nevar dzēst līniju"
+#: ../lib/vector/Vlib/break_polygons.c:435
+msgid "Breaking polygons (pass 1: select break points)..."
+msgstr ""
-#: ../lib/vector/Vlib/ascii.c:698
-#, fuzzy
-msgid "Unable to fetch data from table"
+#: ../lib/vector/Vlib/break_polygons.c:552
+msgid "Breaking polygons (pass 2: break at selected points)..."
+msgstr ""
-#: ../lib/vector/Vlib/ascii.c:732
-#, fuzzy, c-format
-msgid "Column <%s>: unsupported data type"
+#: ../lib/vector/Vlib/break_polygons.c:592
+msgid "Point not in search tree!"
+msgstr ""
-#: ../lib/vector/Vlib/ascii.c:813
+#: ../lib/vector/Vlib/overlay.c:72
 #, fuzzy
-msgid "Unknown format"
+msgid "unknown operator"
-#: ../lib/vector/Vlib/ascii.c:823
-msgid "Topology not available, unable to process areas"
+#: ../lib/vector/Vlib/overlay.c:124
+msgid "Overlay: line/boundary types not supported by AND operator"
 msgstr ""
-#: ../lib/vector/Vlib/ascii.c:836
-#, fuzzy, c-format
-msgid "Unable to get boundary of area id %d"
-msgstr "Nevar atvērt 'temp'/pagaidu failu"
+#: ../lib/vector/Vlib/overlay.c:127
+msgid "Overlay: area x area types not supported by AND operator"
+msgstr ""
-#: ../lib/vector/Vlib/ascii.c:848
-#, fuzzy, c-format
-msgid "Unable to get boundary of isle id %d (area id %d)"
+#: ../lib/vector/Vlib/open_nat.c:57
+#, c-format
+msgid "Unable to open coor file for vector map <%s>"
+msgstr ""
-#: ../lib/vector/Vlib/ascii.c:860
+#: ../lib/vector/Vlib/open_nat.c:154
 #, c-format
 msgid ""
-"%d features without category skipped. To export also features without "
-"category use '%s=-1'."
+"Coor file of vector map <%s@%s> is larger than it should be (%ld bytes "
+"excess)"
 msgstr ""
-#: ../lib/vector/Vlib/select.c:116
-#, fuzzy, c-format
-msgid "Unable to delete item %d from spatial index"
+#: ../lib/vector/Vlib/open_nat.c:158
+#, c-format
+msgid "Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
+msgstr ""
-#: ../lib/vector/rtree/test_suite/test_basics.c:40
-#, fuzzy
-msgid ""
-"\n"
-"++ Running basic unit tests ++"
-#: ../lib/vector/rtree/test_suite/test_basics.c:48
-#, fuzzy
-msgid ""
-"\n"
-"-- Basic rtree unit tests failure --"
-#: ../lib/vector/rtree/test_suite/test_basics.c:50
-#, fuzzy
-msgid ""
-"\n"
-"-- Basic rtree unit tests finished successfully --"
-#: ../lib/vector/vedit/delete.c:40
+#: ../lib/vector/Vlib/read_pg.c:272 ../lib/vector/Vlib/read_pg.c:471
 #, fuzzy, c-format
-msgid "Attempt to delete dead feature (%d)"
-#: ../lib/vector/vedit/delete.c:72
-#, fuzzy, c-format
-msgid "No area found for centroid %d"
+msgid "Feature %ld without geometry skipped"
-#: ../lib/vector/vedit/delete.c:76
+#: ../lib/vector/Vlib/read_pg.c:365
 #, c-format
-msgid "Duplicate centroid %d, unable to delete area"
+msgid "Requesting invalid feature from cache (%d). Number of features in cache: %d"
 msgstr ""
-#: ../lib/vector/vedit/delete.c:105
+#: ../lib/vector/Vlib/read_pg.c:368
 #, fuzzy, c-format
-msgid "Area %d without centroid"
+msgid "Feature %d: unexpected type (%d) - should be %d"
-#: ../lib/vector/vedit/delete.c:121
-#, fuzzy, c-format
-msgid "Area %d has no boundaries"
+#: ../lib/vector/Vlib/read_pg.c:575
+msgid "No geometry or topo geometry column defined"
+msgstr ""
-#: ../lib/vector/vedit/cats.c:63
-#, fuzzy, c-format
-msgid "Unable to set category %d for (feature id %d)"
+#: ../lib/vector/Vlib/read_pg.c:585
+msgid "Random access not supported. Primary key not defined."
+msgstr ""
-#: ../lib/vector/vedit/select.c:231
+#: ../lib/vector/Vlib/read_pg.c:652
 #, fuzzy
-msgid "Unknown query tool"
+msgid "Inconsistency in topology: detected centroid (should be point)"
-#: ../lib/cluster/c_exec.c:44
+#: ../lib/vector/Vlib/read_pg.c:662
+#, fuzzy
+msgid "Inconsistency in topology: detected boundary (should be line)"
+#: ../lib/vector/Vlib/read_pg.c:787
 #, c-format
-msgid "Not enough data points (%d) in cluster"
+msgid "Invalid WKB content: %d bytes"
 msgstr ""
-#: ../lib/cluster/c_begin.c:57
-#, c-format
-msgid "produced by i.cluster"
+#: ../lib/vector/Vlib/read_pg.c:803
+msgid "Reading EWKB with 4-dimensional coordinates (XYZM) is not supported"
 msgstr ""
-#: ../lib/psdriver/Graph_set.c:199
-#, c-format
-msgid "ps: truecolor status %s"
+#: ../lib/vector/Vlib/read_pg.c:996 ../lib/vector/Vlib/read_pg.c:1064
+#: ../lib/vector/Vlib/read_pg.c:1135
+msgid "Length of input WKB is too small"
 msgstr ""
-#: ../lib/psdriver/Graph_set.c:214
+#: ../lib/vector/Vlib/read_pg.c:1075
 #, c-format
-msgid "ps: collecting to file '%s'"
+msgid "Invalid cache index %d (max: %d)"
 msgstr ""
-#: ../lib/psdriver/Graph_set.c:215
+#: ../lib/vector/Vlib/read_pg.c:1213
 #, c-format
-msgid "ps: image size %dx%d"
+msgid "Corrupted data. %s."
 msgstr ""
-#: ../lib/rst/interp_float/segmen2d.c:118
-msgid ""
-"Taking too long to find points for interpolation - please change the region "
-"to area where your points are. Continuing calculations..."
+#: ../lib/vector/Vlib/read_pg.c:1215
+msgid "Corrupted data"
 msgstr ""
-#: ../lib/rst/interp_float/interp2d.c:214
-#, c-format
+#: ../lib/vector/Vlib/read_pg.c:1508 ../lib/vector/Vlib/read_pg.c:1539
+#, fuzzy, c-format
 msgid ""
-"Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) "
-"cell. Z-value %f, zmin %f, zmax %f."
-msgstr ""
+"Execution failed: %s\n"
+"Reason: %s"
+msgstr "Pieslēgšanās izgāzusies\n"
-#: ../lib/rst/interp_float/input2d.c:48
+#: ../lib/vector/Vlib/read_pg.c:1668
 #, fuzzy, c-format
-msgid "Mask raster map <%s> not found"
+msgid ""
+"Unable to read features. Reason:\n"
+"%s"
+msgstr "Neiespējami atvērt failu %s iekš %s"
-#: ../lib/rst/interp_float/input2d.c:70
-msgid "Bitmap mask created"
-msgstr ""
+#: ../lib/vector/Vlib/field.c:91
+msgid "Layer number must be 1 or greater"
-#: ../lib/rst/interp_float/write2d.c:40 ../lib/rst/interp_float/write2d.c:51
-#: ../lib/rst/interp_float/write2d.c:66 ../lib/rst/interp_float/write2d.c:75
-#: ../lib/rst/interp_float/write2d.c:83 ../lib/rst/interp_float/write2d.c:91
+#: ../lib/vector/Vlib/field.c:96
 #, fuzzy
-msgid "Cannot write files"
-msgstr "Nevar pārrakstīt līniju"
-#: ../lib/rst/interp_float/output2d.c:106
-#, c-format
-msgid "First change your rows number to nsizr! %d %d"
+msgid "Unable to add attribute link, vector map is not opened in WRITE mode"
 msgstr ""
+"Nevar pievienot datubāzes saiti,karte nav atvērta rakstīšanas 'WRITE' "
+"režijmā."
-#: ../lib/rst/interp_float/output2d.c:113
-#, c-format
-msgid "First change your cols number to nsizc %d %d"
-msgstr ""
+#: ../lib/vector/Vlib/field.c:103
+msgid "Unable to add attribute link"
+msgstr "Nevar pievienot atribūtu saiti"
-#: ../lib/rst/interp_float/vinput2d.c:73
-#, fuzzy, c-format
-msgid "Vector map <%s> is not 3D"
+#: ../lib/vector/Vlib/field.c:109
+msgid "Unable to write attribute links"
-#: ../lib/rst/interp_float/vinput2d.c:76
-msgid "Loading data from attribute table ..."
+#: ../lib/vector/Vlib/field.c:154
+msgid "Unable to write database links"
+msgstr "Nevar ierakstīt datubāzes saites"
+#: ../lib/vector/Vlib/field.c:178
+msgid "Database connection not defined. Skipping."
 msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:94
-#: ../lib/rst/interp_float/vinput2d.c:108 ../lib/db/dbmi_client/copy_tab.c:267
-#, fuzzy, c-format
-msgid "Column <%s> not found"
-msgstr "Nevar atvērt datubāzi %s"
+#: ../lib/vector/Vlib/field.c:185
+msgid ""
+"More DB links defined for input vector map. Using only first DB link for "
+"output."
+msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:97
-#: ../lib/rst/interp_float/vinput2d.c:110
+#: ../lib/vector/Vlib/field.c:261
 #, c-format
-msgid "Data type of column <%s> must be numeric"
+msgid "Layer number %d or name <%s> already exists"
 msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:121
-#, fuzzy
-msgid "Reading features from vector map ..."
-msgstr "neispējami mainīt direktoriju uz %s"
-#: ../lib/rst/interp_float/vinput2d.c:153
+#: ../lib/vector/Vlib/field.c:345
 #, c-format
-msgid "Database record for cat %d not found"
+msgid ""
+"Default driver / database set to:\n"
+"driver: %s\n"
+"database: %s"
 msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:171
-msgid "Negative value of smoothing detected: sm must be >= 0"
-msgstr ""
+#: ../lib/vector/Vlib/field.c:352
+msgid "Default driver is not set"
+msgstr "Noklusējuma dzinējs nav iestatīts"
-#: ../lib/rst/interp_float/vinput2d.c:235
-msgid "Strip exists with insufficient data"
-msgstr ""
+#: ../lib/vector/Vlib/field.c:355
+msgid "Default database is not set"
+msgstr "Noklusējuma datubāze nav iestatīta"
-#: ../lib/rst/interp_float/vinput2d.c:249
+#: ../lib/vector/Vlib/field.c:412
 #, c-format
-msgid "There are points outside specified 2D/3D region - %d points ignored"
-msgstr ""
+msgid "Requested dblink %d, maximum link number %d"
+msgstr "Pieprasītā dbsaite %d, maksimāli iespējamo saišu skaits %d"
-#: ../lib/rst/interp_float/vinput2d.c:252
+#: ../lib/vector/Vlib/field.c:599 ../lib/vector/Vlib/field.c:607
 #, c-format
-msgid "Ignoring %d points (too dense)"
+msgid "Error in rule on row %d in <%s>"
 msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:256
+#: ../lib/vector/Vlib/field.c:692
 #, c-format
-msgid ""
-"%d points given for interpolation (after thinning) is less than given NPMIN="
-"%d"
+msgid "Unable to open OGR layer <%s>"
 msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:261
-msgid "Zero points in the given region"
-msgstr ""
+#: ../lib/vector/Vlib/field.c:719
+msgid "Unable to open OGR DBMI driver"
+msgstr "Nevar atvērt OGR DBMI dzinēju"
-#: ../lib/rst/interp_float/vinput2d.c:266
-#, c-format
+#: ../lib/vector/Vlib/field.c:758
 msgid ""
-"Segmentation parameters set to invalid values: npmin= %d, segmax= %d for "
-"smooth connection of segments, npmin > segmax (see manual)"
+"All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
+"available in OGR DB table"
 msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:272
+#: ../lib/vector/Vlib/field.c:825
 #, c-format
-msgid ""
-"There are less than %d points for interpolation. No segmentation is "
-"necessary, to run the program faster set segmax=%d (see manual)"
+msgid "Feature table <%s> has no primary key defined. Unable to define DB links."
 msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:276
-#, fuzzy, c-format
-msgid "Number of points from vector map %d"
-msgstr "Ieejas vektorkartes nosaukums"
+#: ../lib/vector/Vlib/field.c:845
+msgid "GRASS not compiled with PostgreSQL support"
+msgstr "GRASS nav kompilēts ar PostgreSQL atbalstu"
-#: ../lib/rst/interp_float/vinput2d.c:277
-#, fuzzy, c-format
-msgid "Number of points outside of 2D/3D region %d"
-msgstr "Ārpus laukuma esošu centroīdu skaits :   %d\n"
+#: ../lib/vector/Vlib/field.c:877
+msgid "Unknown vector map format"
+msgstr "Nezināms vektordatu kartes formāts"
-#: ../lib/rst/interp_float/vinput2d.c:279
+#: ../lib/vector/Vlib/field.c:911
 #, fuzzy, c-format
-msgid "Number of points being used %d"
-msgstr "Punktu skaits    :   %d\n"
+msgid "Unable to create database definition file for vector map <%s>"
-#: ../lib/rst/interp_float/vinput2d.c:312
-msgid "Some points outside of region (ignored)"
+#: ../lib/vector/Vlib/field.c:1006
+msgid "Bug: attempt to update map which is not in current mapset"
 msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:318
+#: ../lib/vector/vedit/select.c:231
 #, fuzzy
-msgid "Unable to allocate memory"
+msgid "Unknown query tool"
+msgstr "nezināns interpolācijas tips"
-#: ../lib/rst/interp_float/vinput2d.c:326
+#: ../lib/vector/vedit/cats.c:63
 #, fuzzy, c-format
-msgid "Unable to insert %f,%f,%f a = %d"
+msgid "Unable to set category %d for (feature id %d)"
-#: ../lib/rst/interp_float/resout2d.c:77
-msgid "Temporarily changing the region to desired resolution..."
-msgstr ""
+#: ../lib/vector/vedit/delete.c:40
+#, fuzzy, c-format
+msgid "Attempt to delete dead feature (%d)"
+msgstr "Nevar nolasīt histogrammu priekš [%s no %s]"
-#: ../lib/rst/interp_float/resout2d.c:103
-#, c-format
-msgid "First change your rows number(%d) to %d"
-msgstr ""
+#: ../lib/vector/vedit/delete.c:72
+#, fuzzy, c-format
+msgid "No area found for centroid %d"
+msgstr "Bez centroīdiem esošu laukumu skaits :   %d\n"
-#: ../lib/rst/interp_float/resout2d.c:110
+#: ../lib/vector/vedit/delete.c:76
 #, c-format
-msgid "First change your columns number(%d) to %d"
+msgid "Duplicate centroid %d, unable to delete area"
 msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:264
-msgid "No color table for input raster map -- will not create color table"
-msgstr ""
+#: ../lib/vector/vedit/delete.c:105
+#, fuzzy, c-format
+msgid "Area %d without centroid"
-#: ../lib/rst/interp_float/resout2d.c:458
-msgid "Changing the region back to initial..."
-msgstr ""
+#: ../lib/vector/vedit/delete.c:121
+#, fuzzy, c-format
+msgid "Area %d has no boundaries"
-#: ../lib/gis/rd_cellhd.c:139 ../lib/gis/rd_cellhd.c:150
-#: ../lib/gis/rd_cellhd.c:160 ../lib/gis/rd_cellhd.c:177
-#: ../lib/gis/rd_cellhd.c:193 ../lib/gis/rd_cellhd.c:201
-#: ../lib/gis/rd_cellhd.c:209 ../lib/gis/rd_cellhd.c:217
-#: ../lib/gis/rd_cellhd.c:225 ../lib/gis/rd_cellhd.c:233
-#: ../lib/gis/rd_cellhd.c:241 ../lib/gis/rd_cellhd.c:243
-#: ../lib/gis/rd_cellhd.c:251 ../lib/gis/rd_cellhd.c:253
-#: ../lib/gis/rd_cellhd.c:261 ../lib/gis/rd_cellhd.c:263
-#: ../lib/gis/rd_cellhd.c:271 ../lib/gis/rd_cellhd.c:273
-#: ../lib/gis/rd_cellhd.c:281 ../lib/gis/rd_cellhd.c:283
-#: ../lib/gis/rd_cellhd.c:291 ../lib/gis/rd_cellhd.c:293
-#: ../lib/gis/rd_cellhd.c:301 ../lib/gis/rd_cellhd.c:303
-#: ../lib/gis/rd_cellhd.c:311 ../lib/gis/rd_cellhd.c:313
-#: ../lib/gis/rd_cellhd.c:321 ../lib/gis/rd_cellhd.c:323
-#: ../lib/gis/rd_cellhd.c:331 ../lib/gis/rd_cellhd.c:333
-#: ../lib/gis/rd_cellhd.c:341 ../lib/gis/rd_cellhd.c:349
-#: ../lib/gis/rd_cellhd.c:353
-msgid "Syntax error in cell header"
-msgstr ""
+#: ../lib/vector/rtree/test_suite/test_basics.c:40
+#, fuzzy
+msgid ""
+"\n"
+"++ Running basic unit tests ++"
-#: ../lib/gis/rd_cellhd.c:147
+#: ../lib/vector/rtree/test_suite/test_basics.c:48
 #, fuzzy
-msgid "Duplicate projection field"
-msgstr "dubultot projekcijas lauku"
+msgid ""
+"\n"
+"-- Basic rtree unit tests failure --"
-#: ../lib/gis/rd_cellhd.c:157
+#: ../lib/vector/rtree/test_suite/test_basics.c:50
 #, fuzzy
-msgid "Duplicate zone field"
-msgstr "dubultot zonas lauku"
+msgid ""
+"\n"
+"-- Basic rtree unit tests finished successfully --"
-#: ../lib/gis/rd_cellhd.c:167 ../lib/gis/rd_cellhd.c:169
-#: ../lib/gis/rd_cellhd.c:358 ../lib/gis/rd_cellhd.c:360
-#: ../lib/gis/rd_cellhd.c:362 ../lib/gis/rd_cellhd.c:364
-#: ../lib/gis/rd_cellhd.c:366 ../lib/gis/rd_cellhd.c:368
-#: ../lib/gis/rd_cellhd.c:379 ../lib/gis/rd_cellhd.c:381
-#: ../lib/gis/rd_cellhd.c:383 ../lib/gis/rd_cellhd.c:385
+#: ../lib/vector/neta/timetables.c:46 ../lib/vector/neta/timetables.c:203
+#: ../lib/vector/neta/timetables.c:244 ../lib/vector/neta/timetables.c:286
 #, fuzzy, c-format
-msgid "Field <%s> missing"
-msgstr "trūkst zonas lauks"
+msgid "Unable to open select cursor: %s"
+msgstr "neispējami mainīt direktoriju uz %s"
-#: ../lib/gis/rd_cellhd.c:191
-#, fuzzy
-msgid "Duplicate north field"
-msgstr "dubultot ziemeļu laiku"
+#: ../lib/vector/neta/utils.c:195
+#, fuzzy, c-format
+msgid "Point %d is not connected!"
-#: ../lib/gis/rd_cellhd.c:199
-#, fuzzy
-msgid "Duplicate south field"
-msgstr "dubultot dienvidu lauku"
+#: ../lib/vector/neta/utils.c:230
+#, c-format
+msgid "'%s' must be > 0"
+msgstr ""
-#: ../lib/gis/rd_cellhd.c:207
-#, fuzzy
-msgid "Duplicate east field"
-msgstr "dubultot austrumu lauku"
+#: ../lib/vector/neta/utils.c:239
+msgid "'where' and 'cats' parameters were supplied, cat will be ignored"
+msgstr ""
-#: ../lib/gis/rd_cellhd.c:215
+#: ../lib/vector/neta/utils.c:242
 #, fuzzy
-msgid "Duplicate west field"
-msgstr "dubultot rietumu laiku"
+msgid "Unable to load data from database"
-#: ../lib/gis/rd_cellhd.c:223
+#: ../lib/vector/neta/utils.c:249
 #, fuzzy
-msgid "Duplicate top field"
-msgstr "dubultot virsskata/augšas lauku"
+msgid "Problem loading category values"
+msgstr "eksistējošām rastra kartēm %d"
-#: ../lib/gis/rd_cellhd.c:231
-#, fuzzy
-msgid "Duplicate bottom field"
-msgstr "dubultot apakšas lauku"
+#: ../lib/vector/neta/spanningtree.c:104
+msgid "Computing minimum spanning tree..."
+msgstr ""
-#: ../lib/gis/rd_cellhd.c:239
-#, fuzzy
-msgid "Duplicate e-w resolution field"
-msgstr "dubultot A-R izšķirtspējas lauku"
+#: ../lib/init/lock.c:38
+#, c-format
+msgid "Usage: %s file pid"
+msgstr ""
-#: ../lib/gis/rd_cellhd.c:249
-#, fuzzy
-msgid "Duplicate 3D e-w resolution field"
-msgstr "dubultot 3D A-R izšķirtspējas lauku"
+#: ../lib/init/lock.c:42
+msgid "Concurrent mapset locking is not supported on Windows"
+msgstr ""
-#: ../lib/gis/rd_cellhd.c:259
-#, fuzzy
-msgid "Duplicate n-s resolution field"
-msgstr "dubultot Z-D izšķirtspējas lauku"
+#: ../lib/init/lock.c:60
+#, fuzzy, c-format
+msgid "Unable to write lockfile %s (%s)"
-#: ../lib/gis/rd_cellhd.c:269
-#, fuzzy
-msgid "Duplicate 3D n-s resolution field"
-msgstr "dubultot 3D Z-D izšķirtspējas lauku"
+#: ../lib/init/prompt.py:20
+msgid "[Raster and Volume MASKs present]"
+msgstr ""
-#: ../lib/gis/rd_cellhd.c:279
-#, fuzzy
-msgid "Duplicate t-b resolution field"
-msgstr "dubultot t-b izšķirtspējas lauku"
+#: ../lib/init/prompt.py:22
+msgid "[Raster MASK present]"
+msgstr "[Ir rastra MASKa]"
-#: ../lib/gis/rd_cellhd.c:289
-#, fuzzy
-msgid "Duplicate rows field"
-msgstr "dubultot rindu lauku"
+#: ../lib/init/prompt.py:24
+msgid "[Volume MASK present]"
+msgstr "[Ir tilpuma MASKa]"
-#: ../lib/gis/rd_cellhd.c:299
-#, fuzzy
-msgid "Duplicate 3D rows field"
-msgstr "dubultot 3D rindu lauku"
+#: ../lib/init/grass.py:74
+msgid "WARNING"
+msgstr "BRĪDINĀJUMS"
-#: ../lib/gis/rd_cellhd.c:309
-#, fuzzy
-msgid "Duplicate cols field"
-msgstr "dubultot kolonu lauku"
+#: ../lib/init/grass.py:130
+msgid "Exiting..."
+msgstr "Iziet..."
-#: ../lib/gis/rd_cellhd.c:319
-#, fuzzy
-msgid "Duplicate 3D cols field"
-msgstr "dubultot 3D colonu lauku"
+#: ../lib/init/grass.py:200
+msgid "Usage"
+msgstr "Lietojums"
-#: ../lib/gis/rd_cellhd.c:329
-#, fuzzy
-msgid "Duplicate depths field"
-msgstr "dubultot dziļuma lauku"
+#: ../lib/init/grass.py:201 ../lib/gis/parser_html.c:143
+#: ../lib/gis/parser_rest.c:146
+msgid "Flags"
+msgstr "Karogi"
-#: ../lib/gis/rd_cellhd.c:339
-#, fuzzy
-msgid "Duplicate format field"
-msgstr "dubultot formāta lauku"
+#: ../lib/init/grass.py:202
+msgid "print this help message"
+msgstr "izdrukā šo palīdzības paziņojumu"
-#: ../lib/gis/rd_cellhd.c:347
-#, fuzzy
-msgid "Duplicate compressed field"
-msgstr "dubultot kompresēto lauku"
+#: ../lib/init/grass.py:203
+msgid "show version information and exit"
+msgstr "parāda versijas informāciju un iziet"
-#: ../lib/gis/parser_help.c:79
-#, fuzzy
-msgid "Description:"
+#: ../lib/init/grass.py:204
+msgid "create given database, location or mapset if it doesn't exist"
 msgstr ""
-"\n"
-"Apraksts:\n"
-#: ../lib/gis/parser_help.c:89
+#: ../lib/init/grass.py:205
+msgid "use text based interface"
+msgstr "lietot teksta bāzētu saskarni"
+#: ../lib/init/grass.py:206 ../lib/init/grass.py:208
 #, fuzzy
-msgid "Keywords:"
+msgid "and set as default"
+msgstr "lai apstiprinātu noklusēto"
+#: ../lib/init/grass.py:207
+msgid "use $DEFAULT_GUI graphical user interface"
 msgstr ""
-"\n"
-"Atslēgvārdi:\n"
-#: ../lib/gis/parser_help.c:97
-#, fuzzy
-msgid "Usage:"
+#: ../lib/init/grass.py:209
+msgid "print GRASS configuration parameters"
+msgstr "izdrukā GRASS konfigurācijas parametrus"
+#: ../lib/init/grass.py:210
+msgid "options: arch,build,compiler,path,revision"
 msgstr ""
-"\n"
-"Pieleitojums:\n"
-#: ../lib/gis/parser_help.c:127
-msgid "ERROR: Option key not defined"
+#: ../lib/init/grass.py:211 ../lib/gis/parser_html.c:186
+#: ../lib/gis/parser_rest.c:179
+msgid "Parameters"
+msgstr "Parametri"
+#: ../lib/init/grass.py:212
+msgid "initial database (path to GIS data)"
 msgstr ""
-#: ../lib/gis/parser_help.c:171
-#, fuzzy
-msgid "Flags:"
+#: ../lib/init/grass.py:213
+msgid "initial location"
 msgstr ""
-"\n"
-"Karogi:\n"
-#: ../lib/gis/parser_help.c:194 ../lib/gis/parser_interface.c:329
-#: ../lib/gis/parser_html.c:165 ../lib/gis/parser_rest.c:164
-msgid "Allow output files to overwrite existing files"
+#: ../lib/init/grass.py:214
+msgid "initial mapset"
 msgstr ""
-#: ../lib/gis/parser_help.c:196 ../lib/gis/parser_interface.c:337
-#: ../lib/gis/parser_html.c:169 ../lib/gis/parser_rest.c:168
-msgid "Verbose module output"
+#: ../lib/init/grass.py:215
+msgid "fully qualified initial mapset directory"
 msgstr ""
-#: ../lib/gis/parser_help.c:197 ../lib/gis/parser_interface.c:344
-#: ../lib/gis/parser_html.c:172 ../lib/gis/parser_rest.c:171
-msgid "Quiet module output"
+#: ../lib/init/grass.py:216
+msgid "Environment variables relevant for startup"
 msgstr ""
-#: ../lib/gis/parser_help.c:205
-#, fuzzy
-msgid "Parameters:"
+#: ../lib/init/grass.py:217
+msgid "select GUI (text, gui)"
 msgstr ""
-"\n"
-"Parametri:\n"
-#: ../lib/gis/parser_help.c:228
-#, c-format
-msgid "  %*s   default: %s\n"
-msgstr "  %*s   noklusētais: %s\n"
+#: ../lib/init/grass.py:218
+msgid "set html web browser for help pages"
+msgstr ""
-#: ../lib/gis/parser_help.c:254
-#, c-format
-msgid "  %*s   options: "
-msgstr "  %*s   opcijas: "
+#: ../lib/init/grass.py:219
+msgid "set additional path(s) to local GRASS modules or user scripts"
+msgstr ""
-#: ../lib/gis/get_ellipse.c:343 ../lib/gis/get_ellipse.c:366
-#, fuzzy, c-format
-msgid "Invalid a: field '%s' in file %s in <%s>"
-msgstr "nederīgs a: lauks %s failā %s pie %s"
+#: ../lib/init/grass.py:220
+msgid "set additional GISBASE for locally installed GRASS Addons"
+msgstr ""
-#: ../lib/gis/get_ellipse.c:355
-#, fuzzy, c-format
-msgid "Invalid ellipsoid '%s' in file %s in <%s>"
-msgstr "nederīgs elipsoīds %s failā"
+#: ../lib/init/grass.py:221
+msgid "shell script to be processed as batch job"
+msgstr ""
-#: ../lib/gis/get_ellipse.c:369
-#, fuzzy, c-format
-msgid "Invalid es: field '%s' in file %s in <%s>"
+#: ../lib/init/grass.py:222
+msgid "set python shell name to override 'python'"
+msgstr ""
-#: ../lib/gis/get_ellipse.c:382
-#, fuzzy, c-format
-msgid "No ellipsoid info given in file %s in <%s>"
-msgstr "Nav sneigta eleipsoīda infromācija failā %s pie %s"
+#: ../lib/init/grass.py:260
+#, fuzzy, python-format
+msgid "Unable to create temporary directory <grass7-%(user)s-%(lock)s>! Exiting."
-#: ../lib/gis/legal_name.c:39
-#, fuzzy, c-format
-msgid "Illegal filename <%s>. Cannot be '.' or 'NULL'."
-msgstr "Neatļauts faila nosaukums.  Nevar būt '.' vai 'NULL'\n"
+#: ../lib/init/grass.py:344
+#, python-format
+msgid "GUI <%s> not supported in this version"
+msgstr ""
-#: ../lib/gis/legal_name.c:46
-#, fuzzy, c-format
-msgid "Illegal filename <%s>. Character <%c> not allowed.\n"
-msgstr "Neatļauts faila nosaukums. zīme <%c> nav atļauta.\n"
+#: ../lib/init/grass.py:488
+msgid "Searched for a web browser, but none found"
+msgstr ""
-#: ../lib/gis/legal_name.c:77 ../lib/gis/legal_name.c:81
-#, fuzzy, c-format
-msgid "Output raster map name <%s> is not valid map name"
-msgstr "Izejas vārds '%s' nav derīgs rastra nosaukums."
+#: ../lib/init/grass.py:512
+msgid "Hit RETURN to continue"
+msgstr "Spied ENTER, lai turpinātu"
-#: ../lib/gis/legal_name.c:118 ../lib/gis/legal_name.c:122
-#, fuzzy, c-format
-msgid "Output raster map <%s> is used as input"
-msgstr "Izejas karte '%s' tiek lietota kā iejas karte"
+#: ../lib/init/grass.py:541
+msgid ""
+"The python command does not work as expected!\n"
+"Please check your GRASS_PYTHON environment variable.\n"
+"Use the -help option for details.\n"
+"Switching to text based interface mode.\n"
+"\n"
+"Hit RETURN to continue.\n"
+msgstr ""
-#: ../lib/gis/ls.c:103
-#, fuzzy, c-format
-msgid "Unable to open directory %s"
+#: ../lib/init/grass.py:553
+msgid ""
+"It appears that the X Windows system is not active.\n"
+"A graphical based user interface is not supported.\n"
+"\n"
+"Hit RETURN to continue"
+msgstr ""
-#: ../lib/gis/env.c:260
-msgid "GISRC - variable not set"
-msgstr "GISRC - mainīgais nav norādīts"
+#: ../lib/init/grass.py:600 ../lib/gis/make_mapset.c:66
+#, c-format, python-format
+msgid "Location <%s> doesn't exist"
+msgstr "Novietojums <%s> neeksistē"
-#: ../lib/gis/env.c:292 ../lib/gis/env.c:318
-#, fuzzy, c-format
-msgid "Variable '%s' not set"
+#: ../lib/init/grass.py:605
+msgid "ERROR: <%s> is not a valid GRASS location"
+msgstr "KĻŪDA: <%s> nav derīgs GRASS novietojums"
-#: ../lib/gis/gisinit.c:51 ../lib/gis/gisinit.c:83
+#: ../lib/init/grass.py:608
+#, python-format
 msgid ""
-"Incompatible library version for module. You need to rebuild GRASS or "
-"untangle multiple installations."
+"Mapset <%s> doesn't exist in GRASS location <%s>. A new mapset can be "
+"created by '-c' switch."
 msgstr ""
+"Karšu kopa <%s> GRASS novietojumā <%s> neeksistē. Jaunu karšu kopu var "
+"izveidot ar '-c' parametru."
-#: ../lib/gis/gisinit.c:61
-#, c-format
-msgid "MAPSET %s - permission denied"
-msgstr "KARŠU BIBLOTĒKA%s - pieeja liegta"
+#: ../lib/init/grass.py:627
+#, python-format
+msgid "Failed to create new location. The location <%s> already exists."
+msgstr "Nebija iespējams izveidot jaunu novietojumu. Novietojums <%s> jau eksistē."
-#: ../lib/gis/gisinit.c:64
-#, fuzzy, c-format
-msgid "MAPSET %s not found at %s"
-msgstr "KARŠU KOPA %s nav atrasta"
+#: ../lib/init/grass.py:655
+msgid "Missing WIND file fixed"
+msgstr ""
-#: ../lib/gis/gisinit.c:97
-#, fuzzy
-msgid "System not initialized. Programmer forgot to call G_gisinit()."
+#: ../lib/init/grass.py:667
+msgid ""
+"GISDBASE, LOCATION_NAME and MAPSET variables not set properly.\n"
+"Interactive startup needed."
 msgstr ""
-"\aKĻŪDA: Sistēma nav inicializēta. Programmētājs aizmirsis izsaukt "
-"G_gisinit()\n"
-#: ../lib/gis/seek.c:52 ../lib/gis/seek.c:58
-#, fuzzy
-msgid "Unable to seek"
-msgstr "Neisespējami atvērt %s"
+#: ../lib/init/grass.py:682
+#, python-format
+msgid ""
+"Invalid user interface specified - <%s>.\n"
+"Use the --help option to see valid interface names."
+msgstr ""
-#: ../lib/gis/seek.c:56
-#, fuzzy
-msgid "Seek offset out of range"
-msgstr "Dubulto atribūtu indekss ārpus diapazona"
+#: ../lib/init/grass.py:696
+msgid ""
+"Error in GUI startup. If necessary, please report this error to the GRASS "
+"developers.\n"
+"Switching to text mode now.\n"
+"\n"
+"Hit RETURN to continue..."
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:42 ../lib/gis/adj_cellhd.c:191
-msgid "Illegal n-s resolution value"
-msgstr "Neatļauta n-s izšķirtspējas vērtība"
+#: ../lib/init/grass.py:706
+msgid ""
+"Received EXIT message from GUI.\n"
+"GRASS is not started. Bye."
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:46 ../lib/gis/adj_cellhd.c:197
-msgid "Illegal row value"
-msgstr "Neatļauta līnijas vērtība"
+#: ../lib/init/grass.py:709
+msgid ""
+"Invalid return code from GUI startup script.\n"
+"Please advise GRASS developers of this error."
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:50 ../lib/gis/adj_cellhd.c:203
-msgid "Illegal e-w resolution value"
-msgstr "Neatļauta e-w izšķirtspējas vērtība"
+#: ../lib/init/grass.py:720
+msgid ""
+"Error reading data path information from g.gisenv.\n"
+"GISDBASE=%(gisbase)s\n"
+"LOCATION_NAME=%(location)s\n"
+"MAPSET=%(mapset)s\n"
+"\n"
+"Check the <%s(file)> file."
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:54 ../lib/gis/adj_cellhd.c:209
-msgid "Illegal col value"
-msgstr "Neatļauta kolonas vērtība"
+#: ../lib/init/grass.py:818
+#, python-format
+msgid "Path '%s' doesn't exist"
+msgstr "Ceļš '%s' neeksitē"
-#: ../lib/gis/adj_cellhd.c:74 ../lib/gis/adj_cellhd.c:239
-#, c-format
-msgid "Fixing subtle input data rounding error of north boundary (%g>%g)"
+#: ../lib/init/grass.py:826
+#, python-format
+msgid ""
+"%(user)s is currently running GRASS in selected mapset (file %(file)s "
+"found). Concurrent use not allowed."
 msgstr ""
-#: ../lib/gis/adj_cellhd.c:79 ../lib/gis/adj_cellhd.c:244
-msgid "Illegal latitude for North"
-msgstr "Neatļauta platuma vērtība Ziemeļiem"
+#: ../lib/init/grass.py:830
+#, python-format
+msgid ""
+"Unable to properly access '%s'.\n"
+"Please notify system personel."
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:85 ../lib/gis/adj_cellhd.c:250
-#, c-format
-msgid "Fixing subtle input data rounding error of south boundary (%g>%g)"
+#: ../lib/init/grass.py:847
+msgid "Building user fontcap..."
 msgstr ""
-#: ../lib/gis/adj_cellhd.c:90 ../lib/gis/adj_cellhd.c:255
-msgid "Illegal latitude for South"
-msgstr "Neatļauta platuma vērtība Dienvidiem"
+#: ../lib/init/grass.py:892
+#, python-format
+msgid "Unsupported shell <%(sh)s>: %(env)s"
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:102 ../lib/gis/adj_cellhd.c:267
-#, c-format
-msgid "Fixing subtle input data rounding error of west boundary (%g>%g)"
+#: ../lib/init/grass.py:897
+msgid "The SHELL variable is not set"
 msgstr ""
-#: ../lib/gis/adj_cellhd.c:113 ../lib/gis/adj_cellhd.c:278
-#, c-format
-msgid "Fixing subtle input data rounding error of east boundary (%g>%g)"
+#: ../lib/init/grass.py:908
+#, python-format
+msgid ""
+"Job file '%s' has been defined in the 'GRASS_BATCH_JOB' variable but not "
+"found. Exiting.\n"
+"\n"
+"Use 'unset GRASS_BATCH_JOB' to disable batch job processing."
 msgstr ""
-#: ../lib/gis/adj_cellhd.c:126 ../lib/gis/adj_cellhd.c:291
-msgid "North must be north of South"
+#: ../lib/init/grass.py:913
+#, python-format
+msgid "Change file permission to 'executable' for '%s'"
 msgstr ""
-#: ../lib/gis/adj_cellhd.c:128 ../lib/gis/adj_cellhd.c:293
-msgid "North must be larger than South"
-msgstr "Ziemeļiem ir jābūt lielākiem nekā Dienvidiem"
+#: ../lib/init/grass.py:915
+#, python-format
+msgid "Executing '%s' ..."
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:131 ../lib/gis/adj_cellhd.c:296
-msgid "East must be larger than West"
-msgstr "Austrumiem ir jābūt lielākiem nekā Rietumiem"
+#: ../lib/init/grass.py:920
+#, python-format
+msgid "Execution of '%s' finished."
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:150 ../lib/gis/adj_cellhd.c:340
-msgid "Invalid coordinates"
-msgstr "Nederīgas koordinātes"
+#: ../lib/init/grass.py:926
+#, python-format
+msgid "GRASS GUI should be <%s>"
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:193
-msgid "Illegal n-s3 resolution value"
-msgstr "Nederīga n-s3 izšķirtspējas vērtība"
+#: ../lib/init/grass.py:955
+#, python-format
+msgid "Welcome to GRASS %s"
+msgstr "Laipni lūdzam GRASS %s"
-#: ../lib/gis/adj_cellhd.c:199
-msgid "Illegal row3 value"
-msgstr "Neatļauta row3 vērtība"
+#: ../lib/init/grass.py:965
+msgid "GRASS homepage:"
+msgstr "GRASS mājas lapa:"
-#: ../lib/gis/adj_cellhd.c:205
-msgid "Illegal e-w3 resolution value"
-msgstr "Neatļauta e-w3 izšķirtspējas vērtība"
+#: ../lib/init/grass.py:966
+msgid "This version running through:"
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:211
-msgid "Illegal col3 value"
-msgstr "Neatļauta col3 vērtība"
+#: ../lib/init/grass.py:968
+msgid "Help is available with the command:"
+msgstr "Palīdzība ir pieejama ar komandu:"
-#: ../lib/gis/adj_cellhd.c:215
-msgid "Illegal t-b3 resolution value"
-msgstr "Neatļauta t-b3 izšķirtspējas vērtība"
+#: ../lib/init/grass.py:969
+msgid "See the licence terms with:"
+msgstr "Licences informācija ir pieejama:"
-#: ../lib/gis/adj_cellhd.c:219
-msgid "Illegal depths value"
-msgstr "Neatļauta dziļuma vērtība"
+#: ../lib/init/grass.py:972
+msgid "If required, restart the GUI with:"
+msgstr ""
-#: ../lib/gis/adj_cellhd.c:299
-msgid "Top must be larger than Bottom"
-msgstr "Augšai ir jābūt lielākai par Apakšu"
+#: ../lib/init/grass.py:974
+msgid "Start the GUI with:"
+msgstr "Grafiskās vides startēšana: "
-#: ../lib/gis/color_rules.c:88
-#, fuzzy
-msgid "no description"
+#: ../lib/init/grass.py:976
+msgid "When ready to quit enter:"
+msgstr "Lai izietu, izpildiet:"
+#: ../lib/init/grass.py:1089
+#, python-format
+msgid "Failed to start shell '%s'"
 msgstr ""
-"\n"
-"Apraksts:\n"
-#: ../lib/gis/error.c:344
-msgid "WARNING: "
-msgstr "BRĪDINĀJUMS:"
+#: ../lib/init/grass.py:1094
+#, python-format
+msgid "Batch job '%s' (defined in GRASS_BATCH_JOB variable) was executed."
+msgstr ""
-#: ../lib/gis/error.c:345
-msgid "ERROR: "
-msgstr "KĻŪDA:"
+#: ../lib/init/grass.py:1095 ../lib/init/grass.py:1100
+msgid "Goodbye from GRASS GIS"
+msgstr "Uz redzēšanos"
-#: ../lib/gis/mapset_msc.c:61
-#, fuzzy, c-format
-msgid "Unable to make mapset element %s (%s): %s"
-msgstr "nevar izvaidot karšu biblotēkas elemntut %s (%s)"
+#: ../lib/init/grass.py:1098
+msgid "Done."
+msgstr "Pabeigts."
-#: ../lib/gis/mapset_msc.c:65
-#, fuzzy, c-format
-msgid "Unable to access mapset element %s (%s): %s"
+#: ../lib/init/grass.py:1105
+msgid "Cleaning up temporary files..."
+msgstr "Satīra pagaidu failus..."
-#: ../lib/gis/parser.c:376
-#, c-format
-msgid "BUG in descriptions, option '%s' in <%s> does not exist"
-msgstr ""
+#: ../lib/init/grass.py:1149
+#, python-format
+msgid "Parameter <%s> not supported"
+msgstr "Parametrs <%s> nav atbalstīts"
-#: ../lib/gis/parser.c:491
-msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
+#: ../lib/init/grass.py:1296
+#, python-format
+msgid ""
+"Unable to start GRASS. You can:\n"
+" - Launch GRASS with '-gui' switch (`grass70 -gui`)\n"
+" - Create manually GISRC file (%s)\n"
+" - Launch GRASS with path to the location/mapset as an argument (`grass70 /"
+"path/to/location/mapset`)"
 msgstr ""
-#: ../lib/gis/parser.c:505
-msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
-msgstr ""
+#: ../lib/init/grass.py:1305
+msgid "Starting GRASS GIS..."
+msgstr "Startē GRASS GIS..."
-#: ../lib/gis/parser.c:536
+#: ../lib/init/grass.py:1362
+#, python-format
+msgid "Launching <%s> GUI in the background, please wait..."
+msgstr "Startē <%s> grafisko vidi fona režīmā. Lūdzu uzgaidiet..."
+#: ../lib/gis/debug.c:80
 #, fuzzy, c-format
-msgid "Sorry <%s> is not a valid option"
-msgstr "Atvainojiet, <%s> ir nedrīgs parametrs\n"
+msgid "Cannot open debug file '%s'"
-#: ../lib/gis/parser.c:569
-#, fuzzy
-msgid "ERROR"
-msgstr "KĻŪDA:"
+#: ../lib/gis/gisinit.c:51 ../lib/gis/gisinit.c:83
+msgid ""
+"Incompatible library version for module. You need to rebuild GRASS or "
+"untangle multiple installations."
+msgstr ""
-#: ../lib/gis/parser.c:806
-#, fuzzy
-msgid "Unable to determine program name"
-msgstr "neiespējami noteikt lietotāja mājas direktoriju"
+#: ../lib/gis/gisinit.c:61
+#, c-format
+msgid "MAPSET %s - permission denied"
+msgstr "Karšu kopa %s - piekļuve ir liegta"
-#: ../lib/gis/parser.c:822 ../lib/gis/parser.c:839
+#: ../lib/gis/gisinit.c:64
 #, fuzzy, c-format
-msgid "Sorry, <%c> is not a valid flag"
-msgstr "Atvainojiet, <%c> ir nedrīgs karogs\n"
+msgid "MAPSET %s not found at %s"
+msgstr "Karšu kopa %s nav atrasta iekš %s"
-#: ../lib/gis/parser.c:939
-#, fuzzy, c-format
-msgid "Sorry, <%s=> is ambiguous"
-msgstr "Atvainojiet, <%s=> ir pārāk lielas prasības\n"
+#: ../lib/gis/gisinit.c:97
+msgid "System not initialized. Programmer forgot to call G_gisinit()."
+msgstr "Sistēma nav inicializēta. Programmētājs aizmirsis izsaukt G_gisinit()."
-#: ../lib/gis/parser.c:946
-#, fuzzy, c-format
-msgid "Sorry, <%s> is not a valid parameter"
-#: ../lib/gis/parser.c:954
+#: ../lib/gis/distance.c:154
 #, c-format
-msgid "Option <%s> does not accept multiple answers"
+msgid "%s: shouldn't happen: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
 msgstr ""
-#: ../lib/gis/parser.c:1025
-#, fuzzy, c-format
-msgid ""
-"Illegal range syntax for parameter <%s>\n"
-"\tPresented as: %s"
+#: ../lib/gis/mkstemp.c:132
+#, fuzzy
+msgid "Attempt to create read-only temporary file"
+msgstr "Mēģinājums dzēst mirušu objektu"
+#: ../lib/gis/mkstemp.c:138
+#, c-format
+msgid "Unrecognised access mode: %o"
 msgstr ""
-"\n"
-"Kļūda: nepieņemama parametra sintakse <%s>\n"
-#: ../lib/gis/parser.c:1031
-#, fuzzy, c-format
-msgid ""
-"Value <%s> out of range for parameter <%s>\n"
-"\tLegal range: %s"
+#: ../lib/gis/parser_html.c:55 ../lib/gis/parser_rest.c:60
+msgid "NAME"
 msgstr ""
-"\n"
-"Kļūda: vērtība <%s> ir ārpus apgabala parametram  <%s>\n"
-#: ../lib/gis/parser.c:1037
-#, fuzzy, c-format
-msgid "Missing value for parameter <%s>"
+#: ../lib/gis/parser_html.c:68 ../lib/gis/parser_rest.c:73
+msgid "KEYWORDS"
 msgstr ""
-"\n"
-"Kļūda: Trūkst vērtība parametram <%s>\n"
-#: ../lib/gis/parser.c:1043
-#, fuzzy, c-format
-msgid ""
-"Value <%s> ambiguous for parameter <%s>\n"
-"\tValid options: %s"
+#: ../lib/gis/parser_html.c:73 ../lib/gis/parser_rest.c:78
+msgid "SYNOPSIS"
 msgstr ""
-"\n"
-#: ../lib/gis/parser.c:1198
-#, fuzzy, c-format
-msgid ""
-"Required parameter <%s> not set:\n"
-"\t(%s)"
+#: ../lib/gis/parser_html.c:166 ../lib/gis/parser_interface.c:329
+#: ../lib/gis/parser_help.c:197 ../lib/gis/parser_rest.c:164
+msgid "Allow output files to overwrite existing files"
+msgstr "Atļaut izvades failiem pārrakstīt eksistējošus failus"
+#: ../lib/gis/parser_html.c:170 ../lib/gis/parser_interface.c:337
+#: ../lib/gis/parser_help.c:199
+msgid "Print usage summary"
 msgstr ""
-"\n"
-"KĻŪDA: Prasītais parametrs <%s> nav iestatīts:\n"
-"    (%s).\n"
-#: ../lib/gis/parser.c:1290
-#, fuzzy, c-format
-msgid ""
-"Option <%s> must be provided in multiples of %d\n"
-"\tYou provided %d item(s): %s"
+#: ../lib/gis/parser_html.c:173 ../lib/gis/parser_interface.c:344
+#: ../lib/gis/parser_help.c:200 ../lib/gis/parser_rest.c:168
+msgid "Verbose module output"
 msgstr ""
-"\n"
-"Kļūda: opcija/pazīme <%s> ir jabūt paredzētai daudzskaitlīgi no %d\n"
-#: ../lib/gis/parser.c:1365
-#, fuzzy, c-format
-msgid "ERROR: option <%s>: <%s> exists.\n"
-msgstr "Kļūda: opcija/pazīme <%s>: <%s> jau eksistē.\n"
-#: ../lib/gis/parser.c:1449
-msgid "No separator given"
+#: ../lib/gis/parser_html.c:176 ../lib/gis/parser_interface.c:351
+#: ../lib/gis/parser_help.c:201 ../lib/gis/parser_rest.c:171
+msgid "Quiet module output"
 msgstr ""
-#: ../lib/gis/home.c:35
+#: ../lib/gis/parser_html.c:230 ../lib/gis/parser_rest.c:223
 #, fuzzy
-msgid "Unable to determine user's home directory"
+msgid "Options"
+msgstr " opcijas: %s\n"
-#: ../lib/gis/home.c:112
-#, fuzzy, c-format
-msgid "Failed to create directory [%s]"
-#: ../lib/gis/list.c:83
-#, fuzzy, c-format
-msgid "no %s files available in current mapset\n"
-msgstr "nav %s faili pieejami pašreizējā karšu biblotēkā\n"
-#: ../lib/gis/list.c:86
-#, fuzzy, c-format
-msgid "no %s files available in mapset <%s>\n"
-msgstr "nav %s faili pieejami karšu biblotēkā %s\n"
-#: ../lib/gis/list.c:132
-#, fuzzy, c-format
-msgid "%s files available in mapset <%s>:\n"
-msgstr "%s failu ir pieejami karšu biblotēkā %s:\n"
-#: ../lib/gis/list.c:204
+#: ../lib/gis/parser_html.c:236 ../lib/gis/parser_rest.c:230
 #, fuzzy
-msgid "G_list: Unknown element type"
+msgid "Default"
+msgstr " noklusēts: %s\n"
-#: ../lib/gis/timestamp.c:292
-#, fuzzy, c-format
-msgid "Unable to create timestamp file for %s map <%s@%s>"
-#: ../lib/gis/timestamp.c:301
-#, fuzzy, c-format
-msgid "Invalid timestamp specified for %s map <%s@%s>"
+#: ../lib/gis/spawn.c:386
+#, c-format
+msgid "CreateProcess() failed: error = %d"
 msgstr ""
-"Nederīgs laikspiedols(timestamp) norādīts priekš %s kartes %s karšu "
-"biblotēkā %s"
-#: ../lib/gis/timestamp.c:331
+#: ../lib/gis/spawn.c:421
 #, fuzzy, c-format
-msgid "Unable to open timestamp file for %s map <%s@%s>"
+msgid "G_spawn: unable to redirect descriptor %d"
+msgstr "G_spawn: neiespējami dubultot deskriptoru %d to %d"
-#: ../lib/gis/timestamp.c:340
-#, fuzzy, c-format
-msgid "Invalid timestamp file for %s map <%s@%s>"
-msgstr ""
-"Nederīgs liakspiedola(timestamp) fails priekš %s kartes %s  karšu biblotēkā "
-"%s"
+#: ../lib/gis/spawn.c:429 ../lib/gis/spawn.c:619
+#, c-format
+msgid "G_spawn: unable to open file %s"
+msgstr "G_spawn: neispējami atvērt failu %s"
-#: ../lib/gis/timestamp.c:479
-#, fuzzy, c-format
-msgid "Unable to open timestamp file for vector map <%s@%s>"
-#: ../lib/gis/timestamp.c:488
-#, fuzzy, c-format
-msgid "Invalid timestamp file for vector map <%s@%s>"
+#: ../lib/gis/spawn.c:503 ../lib/gis/spawn.c:689
+msgid "Unable to execute command"
 msgstr ""
-"%s"
-#: ../lib/gis/timestamp.c:524
-#, fuzzy, c-format
-msgid "Unable to create timestamp file for vector map <%s@%s>"
+#: ../lib/gis/spawn.c:528 ../lib/gis/spawn.c:536
+#, c-format
+msgid "G_spawn: unable to restore signal %d"
+msgstr "G_spawn: neiespējami atjaunot signālu %d"
-#: ../lib/gis/timestamp.c:533
-#, fuzzy, c-format
-msgid "Invalid timestamp specified for vector map <%s@%s>"
-msgstr ""
-"biblotēkā %s"
+#: ../lib/gis/spawn.c:567
+#, c-format
+msgid "G_spawn: unable to reset signal %d"
+msgstr "G_spawn: neiespējami pārlikt signālu %d"
-#: ../lib/gis/datum.c:160
+#: ../lib/gis/spawn.c:576
 #, c-format
-msgid "unable to open datum table file: %s"
-msgstr "neispējami atvērt datumu tabulas failu: %s"
+msgid "G_spawn: unable to ignore signal %d"
+msgstr "G_spawn: neiespējami ignorēt signālu %d"
-#: ../lib/gis/datum.c:182
+#: ../lib/gis/spawn.c:587
 #, c-format
-msgid "error in datum table file, line %d"
-msgstr "kļūda datumu tabulas failā, līnija  %d"
+msgid "G_spawn: unable to block signal %d"
+msgstr "G_spawn: neiespējami bloķēt signālu %d"
-#: ../lib/gis/open.c:62
+#: ../lib/gis/spawn.c:595
 #, c-format
-msgid "G__open(read): mapset <%s> doesn't match xmapset <%s>"
-msgstr ""
+msgid "G_spawn: unable to unblock signal %d"
+msgstr "G_spawn: neiespējami atbloķēt signālu %d"
-#: ../lib/gis/open.c:84
+#: ../lib/gis/spawn.c:624 ../lib/gis/spawn.c:633
 #, c-format
-msgid "G__open(write): xmapset <%s> != G_mapset() <%s>"
+msgid "G_spawn: unable to duplicate descriptor %d to %d"
+#: ../lib/gis/spawn.c:666
+#, fuzzy
+msgid "Unable to create a new process"
+msgstr "neiespējami izveidot jaunu procesu"
+#: ../lib/gis/spawn.c:681
+#, fuzzy, c-format
+msgid "Unable to change directory to %s"
+#: ../lib/gis/proj2.c:64
+msgid "State Plane"
 msgstr ""
+#: ../lib/gis/proj2.c:66
+msgid "Latitude-Longitude"
+msgstr "Platums-Garums"
+#: ../lib/gis/proj2.c:68
+msgid "Other Projection"
+msgstr "Cita Projekcija"
 #: ../lib/gis/units.c:196
 msgid "square units"
 msgstr ""
@@ -7647,99 +6751,84 @@
 msgstr ""
 #: ../lib/gis/units.c:203
-#, fuzzy
 msgid "square meters"
-msgstr ""
-"\n"
-"Parametri:\n"
+msgstr "kvadrātmetri"
-#, fuzzy
 msgid "square meter"
-msgstr ""
-"\n"
-"Parametri:\n"
+msgstr "kvadrātmetrs"
 #: ../lib/gis/units.c:205
-#, fuzzy
 msgid "meters"
-msgstr ""
-"\n"
-"Parametri:\n"
+msgstr "metri"
-#, fuzzy
 msgid "meter"
-msgstr ""
-"\n"
-"Parametri:\n"
+msgstr "metrs"
 #: ../lib/gis/units.c:210
 msgid "square kilometers"
-msgstr ""
+msgstr "kvadrātkilometri"
 msgid "square kilometer"
-msgstr ""
+msgstr "kvadrātkilometrs"
 #: ../lib/gis/units.c:212
-#, fuzzy
 msgid "kilometers"
-msgstr ""
-"\n"
-"Parametri:\n"
+msgstr "kilometri"
 msgid "kilometer"
-msgstr ""
+msgstr "kilometrs"
 #: ../lib/gis/units.c:217
 msgid "acres"
-msgstr ""
+msgstr "akri"
 msgid "acre"
-msgstr ""
+msgstr "akrs"
 #: ../lib/gis/units.c:225
 msgid "hectares"
-msgstr ""
+msgstr "hektāri"
 msgid "hectare"
-msgstr ""
+msgstr "hektārs"
 #: ../lib/gis/units.c:233
 msgid "square miles"
-msgstr ""
+msgstr "kvadrātjūdzes"
 msgid "square mile"
-msgstr ""
+msgstr "kvadrātjūdze"
 #: ../lib/gis/units.c:235
 msgid "miles"
-msgstr ""
+msgstr "jūdzes"
 msgid "mile"
-msgstr ""
+msgstr "jūdze"
 #: ../lib/gis/units.c:240
 msgid "square feet"
-msgstr ""
+msgstr "kvadrātpēdas"
 msgid "square foot"
-msgstr ""
+msgstr "kvadrātpēda"
 #: ../lib/gis/units.c:242
 msgid "feet"
-msgstr ""
+msgstr "pēdas"
 msgid "foot"
-msgstr ""
+msgstr "pēda"
 #: ../lib/gis/units.c:247
 msgid "square degrees"
@@ -7751,621 +6840,514 @@
 #: ../lib/gis/units.c:249
 msgid "degrees"
-msgstr ""
+msgstr "grādi"
 msgid "degree"
-msgstr ""
+msgstr "grāds"
 #: ../lib/gis/units.c:253
 msgid "years"
-msgstr ""
+msgstr "gadi"
 msgid "year"
-msgstr ""
+msgstr "gads"
 #: ../lib/gis/units.c:257
 msgid "months"
-msgstr ""
+msgstr "mēneši"
 msgid "month"
-msgstr ""
+msgstr "mēnesis"
 #: ../lib/gis/units.c:261
 msgid "days"
-msgstr ""
+msgstr "dienas"
 msgid "day"
-msgstr ""
+msgstr "diena"
 #: ../lib/gis/units.c:265
 msgid "hours"
-msgstr ""
+msgstr "stundas"
 msgid "hour"
-msgstr ""
+msgstr "stunda"
 #: ../lib/gis/units.c:269
 msgid "minutes"
-msgstr ""
+msgstr "minūtes"
 msgid "minute"
-msgstr ""
+msgstr "minūte"
 #: ../lib/gis/units.c:273
 msgid "seconds"
-msgstr ""
+msgstr "sekundes"
 msgid "second"
-msgstr ""
+msgstr "sekunde"
-#: ../lib/gis/spawn.c:386
-#, c-format
-msgid "CreateProcess() failed: error = %d"
+#: ../lib/gis/parser_wps.c:490
+msgid "Multiple outputs are not supported by WPS 1.0.0"
 msgstr ""
-#: ../lib/gis/spawn.c:421
-#, fuzzy, c-format
-msgid "G_spawn: unable to redirect descriptor %d"
-msgstr "G_spawn: neiespējami dubultot deskriptoru %d to %d"
-#: ../lib/gis/spawn.c:429 ../lib/gis/spawn.c:619
+#: ../lib/gis/ls.c:103
 #, c-format
-msgid "G_spawn: unable to open file %s"
-msgstr "G_spawn: neispējami atvērt failu %s"
+msgid "Unable to open directory %s"
+msgstr "Nevar atvērt mapi %s"
-#: ../lib/gis/spawn.c:503 ../lib/gis/spawn.c:689
-#, fuzzy
-msgid "Unable to execute command"
-msgstr "neiespējami izpildīt komandu"
-#: ../lib/gis/spawn.c:528 ../lib/gis/spawn.c:536
+#: ../lib/gis/open_misc.c:45
 #, c-format
-msgid "G_spawn: unable to restore signal %d"
-msgstr "G_spawn: neiespējami atjaunot signālu %d"
-#: ../lib/gis/spawn.c:567
-#, c-format
-msgid "G_spawn: unable to reset signal %d"
-msgstr "G_spawn: neiespējami pārlikt signālu %d"
-#: ../lib/gis/spawn.c:576
-#, c-format
-msgid "G_spawn: unable to ignore signal %d"
-msgstr "G_spawn: neiespējami ignorēt signālu %d"
-#: ../lib/gis/spawn.c:587
-#, c-format
-msgid "G_spawn: unable to block signal %d"
-msgstr "G_spawn: neiespējami bloķēt signālu %d"
-#: ../lib/gis/spawn.c:595
-#, c-format
-msgid "G_spawn: unable to unblock signal %d"
-msgstr "G_spawn: neiespējami atbloķēt signālu %d"
-#: ../lib/gis/spawn.c:624 ../lib/gis/spawn.c:633
-#, c-format
-msgid "G_spawn: unable to duplicate descriptor %d to %d"
-#: ../lib/gis/spawn.c:666
-#, fuzzy
-msgid "Unable to create a new process"
-msgstr "neiespējami izveidot jaunu procesu"
-#: ../lib/gis/spawn.c:681
-#, fuzzy, c-format
-msgid "Unable to change directory to %s"
-#: ../lib/gis/key_value3.c:34
-#, fuzzy, c-format
-msgid "Error writing file <%s>"
-msgstr "Kļūdu raskrīšana ārpus topo faila.\n"
-#: ../lib/gis/key_value3.c:37
-#, fuzzy, c-format
-msgid "Error closing output file <%s>"
-#: ../lib/gis/key_value3.c:62
-#, fuzzy, c-format
-msgid "Error reading file <%s>"
-#: ../lib/gis/key_value3.c:65
-#, fuzzy, c-format
-msgid "Error closing input file <%s>"
-msgstr "Nevar atrast ieejas karti '%s'"
-#: ../lib/gis/paths.c:201
-#, fuzzy, c-format
-msgid "Unable to open file <%s> for reading"
-msgstr "Neiespējami atvērt %s priekš rakstīšanas"
-#: ../lib/gis/paths.c:217
-#, fuzzy, c-format
-msgid "Unable to fetch security info for <%s>"
-msgstr "nevar ierakstīt vēstures informāciju priekš [%s]"
-#: ../lib/gis/location.c:61
-#, fuzzy, c-format
-msgid "LOCATION <%s> not available"
-msgstr "ATRAŠANĀS VIETA  << %s >>  nav pieejama"
-#: ../lib/gis/myname.c:46
-msgid "This location has no description."
+msgid "G__open_misc(read): mapset <%s> doesn't match xmapset <%s>"
 msgstr ""
-#: ../lib/gis/proj2.c:64
-msgid "State Plane"
-msgstr ""
-#: ../lib/gis/proj2.c:66
-msgid "Latitude-Longitude"
-msgstr "Platums-Garums"
-#: ../lib/gis/proj2.c:68
-msgid "Other Projection"
-msgstr "Cita Projekcija"
-#: ../lib/gis/alloc.c:44 ../lib/gis/alloc.c:86 ../lib/gis/alloc.c:132
+#: ../lib/gis/open_misc.c:67
 #, c-format
-msgid "Current region rows: %d, cols: %d"
+msgid "G__open_misc(write): xmapset <%s> != G_mapset() <%s>"
 msgstr ""
-#: ../lib/gis/alloc.c:47
-#, c-format
-msgid "G_malloc: unable to allocate %lu bytes of memory at %s:%d"
-msgstr ""
+#: ../lib/gis/get_projinfo.c:34 ../lib/gis/get_projinfo.c:60
+#, fuzzy, c-format
+msgid "<%s> file not found for location <%s>"
+msgstr "%s pēc adreses nav atrasts fails %s\n"
-#: ../lib/gis/alloc.c:89
+#: ../lib/gis/datum.c:160
 #, c-format
-msgid "G_calloc: unable to allocate %lu * %lu bytes of memory at %s:%d"
-msgstr ""
+msgid "unable to open datum table file: %s"
+msgstr "neispējami atvērt datumu tabulas failu: %s"
-#: ../lib/gis/alloc.c:135
+#: ../lib/gis/datum.c:182
 #, c-format
-msgid "G_realloc: unable to allocate %lu bytes of memory at %s:%d"
-msgstr ""
+msgid "error in datum table file, line %d"
+msgstr "kļūda datumu tabulas failā, līnija  %d"
-#: ../lib/gis/open_misc.c:45
-#, c-format
-msgid "G__open_misc(read): mapset <%s> doesn't match xmapset <%s>"
-msgstr ""
-#: ../lib/gis/open_misc.c:67
-#, c-format
-msgid "G__open_misc(write): xmapset <%s> != G_mapset() <%s>"
-msgstr ""
 #: ../lib/gis/get_window.c:117
 #, fuzzy, c-format
 msgid "Unable to open element file <%s> for <%s@%s>"
-#: ../lib/gis/get_projinfo.c:34 ../lib/gis/get_projinfo.c:60
-#, fuzzy, c-format
-msgid "<%s> file not found for location <%s>"
-msgstr "%s pēc adreses nav atrasts fails %s\n"
-#: ../lib/gis/parser_standard_options.c:139
+#: ../lib/gis/parser_standard_options.c:140
 msgid "SQL select statement"
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:141
+#: ../lib/gis/parser_standard_options.c:142
 msgid "For example: 'select * from rybniky where kapri = 'hodne'"
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:148
+#: ../lib/gis/parser_standard_options.c:149
 #, fuzzy
 msgid "WHERE conditions of SQL statement without 'where' keyword"
 msgstr ""
 "KUR  SQL pieprasījuma nosacījumi bez 'where' atslēgvārda. (piemērs: income < "
 "1000 and inhab >= 10000)"
-#: ../lib/gis/parser_standard_options.c:149
+#: ../lib/gis/parser_standard_options.c:150
 msgid "Example: income < 1000 and inhab >= 10000"
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:157
+#: ../lib/gis/parser_standard_options.c:158
 #, fuzzy
 msgid "Name of attribute table"
-#: ../lib/gis/parser_standard_options.c:166
+#: ../lib/gis/parser_standard_options.c:167
 #, fuzzy
 msgid "Name of database driver"
 msgstr "Bāzes rastra faila nosaukums"
-#: ../lib/gis/parser_standard_options.c:175
+#: ../lib/gis/parser_standard_options.c:176
 #, fuzzy
 msgid "Name of database"
-#: ../lib/gis/parser_standard_options.c:184
+#: ../lib/gis/parser_standard_options.c:185
 msgid "Database schema"
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:185
-msgid ""
-"Do not use this option if schemas are not supported by driver/database server"
+#: ../lib/gis/parser_standard_options.c:186
+msgid "Do not use this option if schemas are not supported by driver/database server"
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:194
+#: ../lib/gis/parser_standard_options.c:195
 #, fuzzy
 msgid "Name of attribute column"
-#: ../lib/gis/parser_standard_options.c:203
+#: ../lib/gis/parser_standard_options.c:204
 #, fuzzy
 msgid "Name of attribute column(s)"
-#: ../lib/gis/parser_standard_options.c:212
+#: ../lib/gis/parser_standard_options.c:213
 #, fuzzy
 msgid "Name of key column"
-#: ../lib/gis/parser_standard_options.c:213
+#: ../lib/gis/parser_standard_options.c:214
 msgid "Must refer to an integer column"
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:225
+#: ../lib/gis/parser_standard_options.c:226
 #, fuzzy
 msgid "Name of input imagery group"
 msgstr "Ievades rastra faila nosaukums"
-#: ../lib/gis/parser_standard_options.c:233
+#: ../lib/gis/parser_standard_options.c:234
 #, fuzzy
 msgid "Name of input imagery subgroup"
-#: ../lib/gis/parser_standard_options.c:243
+#: ../lib/gis/parser_standard_options.c:244
 msgid "Name of input raster map"
-#: ../lib/gis/parser_standard_options.c:252
+#: ../lib/gis/parser_standard_options.c:253
 msgid "Name of input raster map(s)"
 msgstr "Ievades rastra failu nosaukumi"
-#: ../lib/gis/parser_standard_options.c:260
+#: ../lib/gis/parser_standard_options.c:261
 msgid "Name for output raster map"
 msgstr "Izvades rastra faila nosaukums"
-#: ../lib/gis/parser_standard_options.c:268
+#: ../lib/gis/parser_standard_options.c:269
 #, fuzzy
 msgid "Name of raster map"
-#: ../lib/gis/parser_standard_options.c:277
+#: ../lib/gis/parser_standard_options.c:278
 #, fuzzy
 msgid "Name of raster map(s)"
-#: ../lib/gis/parser_standard_options.c:285
+#: ../lib/gis/parser_standard_options.c:286
 msgid "Name of base raster map"
-#: ../lib/gis/parser_standard_options.c:293
+#: ../lib/gis/parser_standard_options.c:294
 msgid "Name of cover raster map"
 msgstr "Pārklājuma rastra faila nosaukums"
-#: ../lib/gis/parser_standard_options.c:301
+#: ../lib/gis/parser_standard_options.c:302
 #, fuzzy
 msgid "Name of input elevation raster map"
 msgstr "Reljefa rastra faila nosaukums"
-#: ../lib/gis/parser_standard_options.c:310
+#: ../lib/gis/parser_standard_options.c:311
 #, fuzzy
 msgid "Name of input elevation raster map(s)"
 msgstr "Reljefa rastra faila(u) nosaukums(i)"
-#: ../lib/gis/parser_standard_options.c:316
+#: ../lib/gis/parser_standard_options.c:317
 #, fuzzy
 msgid "Sampling interpolation method"
-#: ../lib/gis/parser_standard_options.c:320
-msgid "Nearest-neighbor interpolation"
-msgstr ""
 #: ../lib/gis/parser_standard_options.c:321
 #, fuzzy
-msgid "Linear interpolation"
+msgid "Nearest-neighbor interpolation"
 #: ../lib/gis/parser_standard_options.c:322
 #, fuzzy
-msgid "Cubic interpolation"
+msgid "Bilinear interpolation"
-#: ../lib/gis/parser_standard_options.c:332
+#: ../lib/gis/parser_standard_options.c:323
 #, fuzzy
+msgid "Bicubic interpolation"
+#: ../lib/gis/parser_standard_options.c:333
+#, fuzzy
 msgid "Name of input 3D raster map"
-#: ../lib/gis/parser_standard_options.c:341
+#: ../lib/gis/parser_standard_options.c:342
 #, fuzzy
 msgid "Name of input 3D raster map(s)"
-#: ../lib/gis/parser_standard_options.c:349
+#: ../lib/gis/parser_standard_options.c:350
 #, fuzzy
 msgid "Name for output 3D raster map"
-#: ../lib/gis/parser_standard_options.c:357
+#: ../lib/gis/parser_standard_options.c:358
 #, fuzzy
 msgid "Name of 3D raster map"
-#: ../lib/gis/parser_standard_options.c:366
+#: ../lib/gis/parser_standard_options.c:367
 #, fuzzy
 msgid "Name of 3D raster map(s)"
-#: ../lib/gis/parser_standard_options.c:375
+#: ../lib/gis/parser_standard_options.c:376
 #, fuzzy
 msgid "Data type used in the output raster3d map"
 msgstr "Izejas 3drastra faila nosaukums"
-#: ../lib/gis/parser_standard_options.c:384
+#: ../lib/gis/parser_standard_options.c:385
 msgid ""
 "Number of digits used as mantissa in the internal map storage, 0 -23 for "
 "float, 0 - 52 for double, max or default"
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:394
+#: ../lib/gis/parser_standard_options.c:395
 msgid "The compression method used in the output raster3d map"
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:404
+#: ../lib/gis/parser_standard_options.c:405
 msgid ""
 "The dimensions of the tiles used in the output raster3d map (XxYxZ or "
 "default: 16x16x8)"
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:414
+#: ../lib/gis/parser_standard_options.c:415
 msgid "Name of input vector map"
-#: ../lib/gis/parser_standard_options.c:415
-#: ../lib/gis/parser_standard_options.c:442
+#: ../lib/gis/parser_standard_options.c:416
+#: ../lib/gis/parser_standard_options.c:443
 msgid "Or data source for direct OGR access"
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:424
+#: ../lib/gis/parser_standard_options.c:425
 #, fuzzy
 msgid "Name of input vector map(s)"
-#: ../lib/gis/parser_standard_options.c:425
+#: ../lib/gis/parser_standard_options.c:426
 msgid "Or data source(s) for direct OGR access"
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:433
+#: ../lib/gis/parser_standard_options.c:434
 msgid "Name for output vector map"
 msgstr "Izejas vektorkartes nosaukums"
-#: ../lib/gis/parser_standard_options.c:441
+#: ../lib/gis/parser_standard_options.c:442
 #, fuzzy
 msgid "Name of vector map"
-#: ../lib/gis/parser_standard_options.c:451
+#: ../lib/gis/parser_standard_options.c:452
 #, fuzzy
 msgid "Name of vector map(s)"
-#: ../lib/gis/parser_standard_options.c:460
-#: ../lib/gis/parser_standard_options.c:469
+#: ../lib/gis/parser_standard_options.c:461
+#: ../lib/gis/parser_standard_options.c:470
 msgid "Feature type"
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:476
+#: ../lib/gis/parser_standard_options.c:477
 #, fuzzy
 msgid "Layer number or name"
 msgstr "Līmeņa numurs"
-#: ../lib/gis/parser_standard_options.c:478
+#: ../lib/gis/parser_standard_options.c:479
 msgid ""
 "Vector features can have category values in different layers. This number "
 "determines which layer to use. When used with direct OGR access this is the "
 "layer name."
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:488
+#: ../lib/gis/parser_standard_options.c:489
 #, fuzzy
 msgid "Layer number or name ('-1' for all layers)"
 msgstr "Laukuma nummurs<%d> vai vārds <%s> jau eksistē"
-#: ../lib/gis/parser_standard_options.c:490
+#: ../lib/gis/parser_standard_options.c:491
 msgid ""
 "A single vector map can be connected to multiple database tables. This "
 "number determines which table to use. When used with direct OGR access this "
 "is the layer name."
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:499
+#: ../lib/gis/parser_standard_options.c:500
 msgid "Category value"
 msgstr "Kategorijas vērtība"
-#: ../lib/gis/parser_standard_options.c:506
+#: ../lib/gis/parser_standard_options.c:507
 msgid "Category values"
 msgstr "Kategoriju vērtības"
-#: ../lib/gis/parser_standard_options.c:507
-#: ../lib/gis/parser_standard_options.c:521
+#: ../lib/gis/parser_standard_options.c:508
+#: ../lib/gis/parser_standard_options.c:522
 msgid "Example: 1,3,7-9,13"
 msgstr "Piemēram: 1,3,7-9,13"
-#: ../lib/gis/parser_standard_options.c:513
+#: ../lib/gis/parser_standard_options.c:514
 msgid "Feature id"
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:520
+#: ../lib/gis/parser_standard_options.c:521
 msgid "Feature ids"
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:531
+#: ../lib/gis/parser_standard_options.c:532
 #, fuzzy
 msgid "Name of input file"
 msgstr "Atvērtā faila nosaukums %s"
-#: ../lib/gis/parser_standard_options.c:539
+#: ../lib/gis/parser_standard_options.c:540
 #, fuzzy
 msgid "Name for output file"
-#: ../lib/gis/parser_standard_options.c:547
+#: ../lib/gis/parser_standard_options.c:548
 msgid "Field separator"
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:548
+#: ../lib/gis/parser_standard_options.c:549
 msgid "Special characters: newline, space, comma, tab"
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:559
+#: ../lib/gis/parser_standard_options.c:560
 msgid "Color"
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:560
+#: ../lib/gis/parser_standard_options.c:561
 msgid "Either a standard color name or R:G:B triplet"
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:569
+#: ../lib/gis/parser_standard_options.c:570
 msgid "Background color"
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:571
+#: ../lib/gis/parser_standard_options.c:572
 msgid "Either a standard GRASS color, R:G:B triplet, or \"none\""
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:582
+#: ../lib/gis/parser_standard_options.c:583
 #, fuzzy
 msgid "Name to input directory"
-#: ../lib/gis/parser_standard_options.c:592
+#: ../lib/gis/parser_standard_options.c:593
 msgid "Units"
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:601
+#: ../lib/gis/parser_standard_options.c:602
 msgid "Data type(s)"
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:611
+#: ../lib/gis/parser_standard_options.c:612
 msgid "Name of mapset (default: current search path)"
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:612
+#: ../lib/gis/parser_standard_options.c:613
 msgid "'.' for current mapset"
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:622
+#: ../lib/gis/parser_standard_options.c:623
 #, fuzzy
 msgid "Coordinates"
-#: ../lib/gis/parser_standard_options.c:631
+#: ../lib/gis/parser_standard_options.c:632
 #, fuzzy
 msgid "Name of color table"
 #: ../lib/gis/parser_standard_options.c:643
 #, fuzzy
+msgid "Name of saved region"
+msgstr "Ieejas vektorkartes nosaukums"
+#: ../lib/gis/parser_standard_options.c:653
+#, fuzzy
 msgid "Name of the input space time dataset"
-#: ../lib/gis/parser_standard_options.c:652
+#: ../lib/gis/parser_standard_options.c:662
 #, fuzzy
 msgid "Name of the input space time datasets"
 msgstr "Defekts: atteikts papildināt karti,kura nav tekošajā karšu komplektā."
-#: ../lib/gis/parser_standard_options.c:660
+#: ../lib/gis/parser_standard_options.c:670
 #, fuzzy
 msgid "Name of the output space time dataset"
-#: ../lib/gis/parser_standard_options.c:668
+#: ../lib/gis/parser_standard_options.c:678
 #, fuzzy
 msgid "Name of the input space time raster dataset"
-#: ../lib/gis/parser_standard_options.c:677
+#: ../lib/gis/parser_standard_options.c:687
 #, fuzzy
 msgid "Name of the input space time raster datasets"
-#: ../lib/gis/parser_standard_options.c:685
+#: ../lib/gis/parser_standard_options.c:695
 #, fuzzy
 msgid "Name of the output space time raster dataset"
-#: ../lib/gis/parser_standard_options.c:693
+#: ../lib/gis/parser_standard_options.c:703
 #, fuzzy
 msgid "Name of the input space time vector dataset"
-#: ../lib/gis/parser_standard_options.c:702
+#: ../lib/gis/parser_standard_options.c:712
 #, fuzzy
 msgid "Name of the input space time vector datasets"
-#: ../lib/gis/parser_standard_options.c:710
+#: ../lib/gis/parser_standard_options.c:720
 #, fuzzy
 msgid "Name of the output space time vector dataset"
-#: ../lib/gis/parser_standard_options.c:718
+#: ../lib/gis/parser_standard_options.c:728
 #, fuzzy
 msgid "Name of the input space time raster3d dataset"
 msgstr "Ieejas 3drastra faila nosaukums"
-#: ../lib/gis/parser_standard_options.c:727
+#: ../lib/gis/parser_standard_options.c:737
 #, fuzzy
 msgid "Name of the input space time raster3d datasets"
-#: ../lib/gis/parser_standard_options.c:735
+#: ../lib/gis/parser_standard_options.c:745
 #, fuzzy
 msgid "Name of the output space time raster3d dataset"
-#: ../lib/gis/parser_standard_options.c:744
+#: ../lib/gis/parser_standard_options.c:754
 #, fuzzy
 msgid "Type of the input space time dataset"
-#: ../lib/gis/parser_standard_options.c:752
+#: ../lib/gis/parser_standard_options.c:762
 #, fuzzy
 msgid "Name of the input map"
-#: ../lib/gis/parser_standard_options.c:761
+#: ../lib/gis/parser_standard_options.c:771
 #, fuzzy
 msgid "Name of the input maps"
-#: ../lib/gis/parser_standard_options.c:770
+#: ../lib/gis/parser_standard_options.c:780
 #, fuzzy
 msgid "Type of the input map"
-#: ../lib/gis/parser_standard_options.c:779
+#: ../lib/gis/parser_standard_options.c:789
 #, fuzzy
 msgid "The temporal type of the space time dataset"
 msgstr "Ieejas vektors '%s' nav atrasts"
-#: ../lib/gis/parser_standard_options.c:786
+#: ../lib/gis/parser_standard_options.c:796
 #, fuzzy
 msgid ""
 "WHERE conditions of SQL statement without 'where' keyword used in the "
@@ -8374,29 +7356,365 @@
-#: ../lib/gis/parser_standard_options.c:787
+#: ../lib/gis/parser_standard_options.c:797
 msgid "Example: start_time > '2001-01-01 12:30:00'"
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:797
+#: ../lib/gis/parser_standard_options.c:807
 msgid "The method to be used for sampling the input dataset"
 msgstr ""
-#: ../lib/gis/parser_standard_options.c:831
+#: ../lib/gis/parser_standard_options.c:841
 #, fuzzy
 msgid "Do not create attribute table"
 msgstr "Nevar dzēst līniju"
-#: ../lib/gis/parser_standard_options.c:835
+#: ../lib/gis/parser_standard_options.c:845
 #, fuzzy
 msgid "Do not build topology"
 msgstr "Veidojam topoloģiju... \n"
+#: ../lib/gis/worker.c:72
+msgid "Task already has a worker"
+msgstr ""
+#: ../lib/gis/home.c:35
+#, fuzzy
+msgid "Unable to determine user's home directory"
+msgstr "neiespējami noteikt lietotāja mājas direktoriju"
+#: ../lib/gis/home.c:112
+#, c-format
+msgid "Failed to create directory [%s]"
+msgstr ""
+#: ../lib/gis/myname.c:46
+msgid "This location has no description."
+msgstr ""
+#: ../lib/gis/error.c:344
+msgid "WARNING: "
+msgstr "BRĪDINĀJUMS:"
+#: ../lib/gis/error.c:345
+msgid "ERROR: "
+msgstr "KĻŪDA: "
+#: ../lib/gis/key_value3.c:33
+#, fuzzy, c-format
+msgid "Unable to open output file <%s>: %s"
+#: ../lib/gis/key_value3.c:36
+#, fuzzy, c-format
+msgid "Error writing file <%s>: %s"
+msgstr "Kļūdu raskrīšana ārpus topo faila.\n"
+#: ../lib/gis/key_value3.c:39
+#, fuzzy, c-format
+msgid "Error closing output file <%s>: %s"
+#: ../lib/gis/key_value3.c:60
+#, fuzzy, c-format
+msgid "Unable to open input file <%s>: %s"
+#: ../lib/gis/key_value3.c:64
+#, fuzzy, c-format
+msgid "Error reading file <%s>: %s"
+msgstr "Nederīgs histogrammas fails priekš [%s iekš %s]"
+#: ../lib/gis/key_value3.c:67
+#, fuzzy, c-format
+msgid "Error closing input file <%s>: %s"
+msgstr "Nevar atrast ieejas karti '%s'"
 #: ../lib/gis/done_msg.c:38
 #, c-format
 msgid "%s complete. %s"
 msgstr "%s izpildīts. %s"
+#: ../lib/gis/open.c:62
+#, c-format
+msgid "G__open(read): mapset <%s> doesn't match xmapset <%s>"
+msgstr ""
+#: ../lib/gis/open.c:84
+#, c-format
+msgid "G__open(write): xmapset <%s> != G_mapset() <%s>"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:139 ../lib/gis/rd_cellhd.c:150
+#: ../lib/gis/rd_cellhd.c:160 ../lib/gis/rd_cellhd.c:177
+#: ../lib/gis/rd_cellhd.c:193 ../lib/gis/rd_cellhd.c:201
+#: ../lib/gis/rd_cellhd.c:209 ../lib/gis/rd_cellhd.c:217
+#: ../lib/gis/rd_cellhd.c:225 ../lib/gis/rd_cellhd.c:233
+#: ../lib/gis/rd_cellhd.c:241 ../lib/gis/rd_cellhd.c:243
+#: ../lib/gis/rd_cellhd.c:251 ../lib/gis/rd_cellhd.c:253
+#: ../lib/gis/rd_cellhd.c:261 ../lib/gis/rd_cellhd.c:263
+#: ../lib/gis/rd_cellhd.c:271 ../lib/gis/rd_cellhd.c:273
+#: ../lib/gis/rd_cellhd.c:281 ../lib/gis/rd_cellhd.c:283
+#: ../lib/gis/rd_cellhd.c:291 ../lib/gis/rd_cellhd.c:293
+#: ../lib/gis/rd_cellhd.c:301 ../lib/gis/rd_cellhd.c:303
+#: ../lib/gis/rd_cellhd.c:311 ../lib/gis/rd_cellhd.c:313
+#: ../lib/gis/rd_cellhd.c:321 ../lib/gis/rd_cellhd.c:323
+#: ../lib/gis/rd_cellhd.c:331 ../lib/gis/rd_cellhd.c:333
+#: ../lib/gis/rd_cellhd.c:341 ../lib/gis/rd_cellhd.c:349
+#: ../lib/gis/rd_cellhd.c:353
+msgid "Syntax error in cell header"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:147
+#, fuzzy
+msgid "Duplicate projection field"
+msgstr "dubultot projekcijas lauku"
+#: ../lib/gis/rd_cellhd.c:157
+#, fuzzy
+msgid "Duplicate zone field"
+msgstr "dubultot zonas lauku"
+#: ../lib/gis/rd_cellhd.c:167 ../lib/gis/rd_cellhd.c:169
+#: ../lib/gis/rd_cellhd.c:358 ../lib/gis/rd_cellhd.c:360
+#: ../lib/gis/rd_cellhd.c:362 ../lib/gis/rd_cellhd.c:364
+#: ../lib/gis/rd_cellhd.c:366 ../lib/gis/rd_cellhd.c:368
+#: ../lib/gis/rd_cellhd.c:379 ../lib/gis/rd_cellhd.c:381
+#: ../lib/gis/rd_cellhd.c:383 ../lib/gis/rd_cellhd.c:385
+#, fuzzy, c-format
+msgid "Field <%s> missing"
+msgstr "trūkst zonas lauks"
+#: ../lib/gis/rd_cellhd.c:191
+#, fuzzy
+msgid "Duplicate north field"
+msgstr "dubultot ziemeļu laiku"
+#: ../lib/gis/rd_cellhd.c:199
+#, fuzzy
+msgid "Duplicate south field"
+msgstr "dubultot dienvidu lauku"
+#: ../lib/gis/rd_cellhd.c:207
+#, fuzzy
+msgid "Duplicate east field"
+msgstr "dubultot austrumu lauku"
+#: ../lib/gis/rd_cellhd.c:215
+#, fuzzy
+msgid "Duplicate west field"
+msgstr "dubultot rietumu laiku"
+#: ../lib/gis/rd_cellhd.c:223
+#, fuzzy
+msgid "Duplicate top field"
+msgstr "dubultot virsskata/augšas lauku"
+#: ../lib/gis/rd_cellhd.c:231
+#, fuzzy
+msgid "Duplicate bottom field"
+msgstr "dubultot apakšas lauku"
+#: ../lib/gis/rd_cellhd.c:239
+#, fuzzy
+msgid "Duplicate e-w resolution field"
+msgstr "dubultot A-R izšķirtspējas lauku"
+#: ../lib/gis/rd_cellhd.c:249
+#, fuzzy
+msgid "Duplicate 3D e-w resolution field"
+msgstr "dubultot 3D A-R izšķirtspējas lauku"
+#: ../lib/gis/rd_cellhd.c:259
+#, fuzzy
+msgid "Duplicate n-s resolution field"
+msgstr "dubultot Z-D izšķirtspējas lauku"
+#: ../lib/gis/rd_cellhd.c:269
+#, fuzzy
+msgid "Duplicate 3D n-s resolution field"
+msgstr "dubultot 3D Z-D izšķirtspējas lauku"
+#: ../lib/gis/rd_cellhd.c:279
+#, fuzzy
+msgid "Duplicate t-b resolution field"
+msgstr "dubultot t-b izšķirtspējas lauku"
+#: ../lib/gis/rd_cellhd.c:289
+#, fuzzy
+msgid "Duplicate rows field"
+msgstr "dubultot rindu lauku"
+#: ../lib/gis/rd_cellhd.c:299
+#, fuzzy
+msgid "Duplicate 3D rows field"
+msgstr "dubultot 3D rindu lauku"
+#: ../lib/gis/rd_cellhd.c:309
+#, fuzzy
+msgid "Duplicate cols field"
+msgstr "dubultot kolonu lauku"
+#: ../lib/gis/rd_cellhd.c:319
+#, fuzzy
+msgid "Duplicate 3D cols field"
+msgstr "dubultot 3D colonu lauku"
+#: ../lib/gis/rd_cellhd.c:329
+#, fuzzy
+msgid "Duplicate depths field"
+msgstr "dubultot dziļuma lauku"
+#: ../lib/gis/rd_cellhd.c:339
+#, fuzzy
+msgid "Duplicate format field"
+msgstr "dubultot formāta lauku"
+#: ../lib/gis/rd_cellhd.c:347
+#, fuzzy
+msgid "Duplicate compressed field"
+msgstr "dubultot kompresēto lauku"
+#: ../lib/gis/color_rules.c:88
+msgid "no description"
+msgstr "nav apraksta"
+#: ../lib/gis/env.c:260
+msgid "GISRC - variable not set"
+msgstr "GISRC - mainīgais nav norādīts"
+#: ../lib/gis/env.c:292 ../lib/gis/env.c:318
+#, c-format
+msgid "Variable '%s' not set"
+msgstr "Mainīgais '%s' nav iestatīts"
+#: ../lib/gis/parser_help.c:79
+msgid "Description:"
+msgstr "Apraksts:"
+#: ../lib/gis/parser_help.c:89
+msgid "Keywords:"
+msgstr "Atslēgvārdi:"
+#: ../lib/gis/parser_help.c:97
+msgid "Usage:"
+msgstr "Pieleitojums:"
+#: ../lib/gis/parser_help.c:127
+msgid "ERROR: Option key not defined"
+msgstr ""
+#: ../lib/gis/parser_help.c:174
+msgid "Flags:"
+msgstr "Karogi:"
+#: ../lib/gis/parser_help.c:209
+msgid "Parameters:"
+msgstr "Parametri:"
+#: ../lib/gis/parser_help.c:232
+#, c-format
+msgid "  %*s   default: %s\n"
+msgstr "  %*s   noklusētais: %s\n"
+#: ../lib/gis/parser_help.c:258
+#, c-format
+msgid "  %*s   options: "
+msgstr "  %*s   opcijas: "
+#: ../lib/gis/adj_cellhd.c:42 ../lib/gis/adj_cellhd.c:191
+msgid "Illegal n-s resolution value"
+msgstr "Neatļauta n-s izšķirtspējas vērtība"
+#: ../lib/gis/adj_cellhd.c:46 ../lib/gis/adj_cellhd.c:197
+msgid "Illegal row value"
+msgstr "Neatļauta rindas vērtība"
+#: ../lib/gis/adj_cellhd.c:50 ../lib/gis/adj_cellhd.c:203
+msgid "Illegal e-w resolution value"
+msgstr "Neatļauta e-w izšķirtspējas vērtība"
+#: ../lib/gis/adj_cellhd.c:54 ../lib/gis/adj_cellhd.c:209
+msgid "Illegal col value"
+msgstr "Neatļauta kolonas vērtība"
+#: ../lib/gis/adj_cellhd.c:74 ../lib/gis/adj_cellhd.c:239
+#, c-format
+msgid "Fixing subtle input data rounding error of north boundary (%g>%g)"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:79 ../lib/gis/adj_cellhd.c:244
+msgid "Illegal latitude for North"
+msgstr "Neatļauta platuma vērtība Ziemeļiem"
+#: ../lib/gis/adj_cellhd.c:85 ../lib/gis/adj_cellhd.c:250
+#, c-format
+msgid "Fixing subtle input data rounding error of south boundary (%g>%g)"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:90 ../lib/gis/adj_cellhd.c:255
+msgid "Illegal latitude for South"
+msgstr "Neatļauta platuma vērtība Dienvidiem"
+#: ../lib/gis/adj_cellhd.c:102 ../lib/gis/adj_cellhd.c:267
+#, c-format
+msgid "Fixing subtle input data rounding error of west boundary (%g>%g)"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:113 ../lib/gis/adj_cellhd.c:278
+#, c-format
+msgid "Fixing subtle input data rounding error of east boundary (%g>%g)"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:126 ../lib/gis/adj_cellhd.c:291
+msgid "North must be north of South"
+msgstr "Ziemeļiem ir jāatrodas uz ziemeļiem no dienvidiem"
+#: ../lib/gis/adj_cellhd.c:128 ../lib/gis/adj_cellhd.c:293
+msgid "North must be larger than South"
+msgstr "Ziemeļiem ir jābūt lielākiem nekā Dienvidiem"
+#: ../lib/gis/adj_cellhd.c:131 ../lib/gis/adj_cellhd.c:296
+msgid "East must be larger than West"
+msgstr "Austrumiem ir jābūt lielākiem nekā Rietumiem"
+#: ../lib/gis/adj_cellhd.c:150 ../lib/gis/adj_cellhd.c:340
+msgid "Invalid coordinates"
+msgstr "Nederīgas koordinātes"
+#: ../lib/gis/adj_cellhd.c:193
+msgid "Illegal n-s3 resolution value"
+msgstr "Nederīga n-s3 izšķirtspējas vērtība"
+#: ../lib/gis/adj_cellhd.c:199
+msgid "Illegal row3 value"
+msgstr "Neatļauta row3 vērtība"
+#: ../lib/gis/adj_cellhd.c:205
+msgid "Illegal e-w3 resolution value"
+msgstr "Neatļauta e-w3 izšķirtspējas vērtība"
+#: ../lib/gis/adj_cellhd.c:211
+msgid "Illegal col3 value"
+msgstr "Neatļauta col3 vērtība"
+#: ../lib/gis/adj_cellhd.c:215
+msgid "Illegal t-b3 resolution value"
+msgstr "Neatļauta t-b3 izšķirtspējas vērtība"
+#: ../lib/gis/adj_cellhd.c:219
+msgid "Illegal depths value"
+msgstr "Neatļauta dziļuma vērtība"
+#: ../lib/gis/adj_cellhd.c:299
+msgid "Top must be larger than Bottom"
+msgstr "Augšai ir jābūt lielākai par Apakšu"
+#: ../lib/gis/location.c:61
+#, fuzzy, c-format
+msgid "LOCATION <%s> not available"
+msgstr "ATRAŠANĀS VIETA  << %s >>  nav pieejama"
 #: ../lib/gis/view.c:176
 #, c-format
 msgid "Unable to open %s for writing"
@@ -8419,33 +7737,49 @@
 #: ../lib/gis/view.c:549
 #, c-format
-msgid ""
-" Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
+msgid " Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
+msgstr " Tikai %d%% no loga ir saglabāts \"%s\" pārklājuma ar tekošo GRASS logu."
+#: ../lib/gis/get_ellipse.c:344 ../lib/gis/get_ellipse.c:367
+#, fuzzy, c-format
+msgid "Invalid a: field '%s' in file %s in <%s>"
+msgstr "nederīgs a: lauks %s failā %s pie %s"
+#: ../lib/gis/get_ellipse.c:356
+#, fuzzy, c-format
+msgid "Invalid ellipsoid '%s' in file %s in <%s>"
+msgstr "nederīgs elipsoīds %s failā"
+#: ../lib/gis/get_ellipse.c:370
+#, fuzzy, c-format
+msgid "Invalid es: field '%s' in file %s in <%s>"
+#: ../lib/gis/get_ellipse.c:383
+#, fuzzy, c-format
+msgid "No ellipsoid info given in file %s in <%s>"
+msgstr "Nav sneigta eleipsoīda infromācija failā %s pie %s"
+#: ../lib/gis/alloc.c:44 ../lib/gis/alloc.c:86 ../lib/gis/alloc.c:132
+#, c-format
+msgid "Current region rows: %d, cols: %d"
 msgstr ""
-" Tikai %d%% no loga ir saglabāts \"%s\" pārklājuma ar tekošo GRASS logu."
-#: ../lib/gis/parser_html.c:55 ../lib/gis/parser_rest.c:60
-msgid "NAME"
+#: ../lib/gis/alloc.c:47
+#, c-format
+msgid "G_malloc: unable to allocate %lu bytes of memory at %s:%d"
 msgstr ""
-#: ../lib/gis/parser_html.c:68 ../lib/gis/parser_rest.c:73
-msgid "KEYWORDS"
+#: ../lib/gis/alloc.c:89
+#, c-format
+msgid "G_calloc: unable to allocate %lu * %lu bytes of memory at %s:%d"
 msgstr ""
-#: ../lib/gis/parser_html.c:73 ../lib/gis/parser_rest.c:78
-msgid "SYNOPSIS"
+#: ../lib/gis/alloc.c:135
+#, c-format
+msgid "G_realloc: unable to allocate %lu bytes of memory at %s:%d"
 msgstr ""
-#: ../lib/gis/parser_html.c:226 ../lib/gis/parser_rest.c:223
-#, fuzzy
-msgid "Options"
-msgstr " opcijas: %s\n"
-#: ../lib/gis/parser_html.c:232 ../lib/gis/parser_rest.c:230
-#, fuzzy
-msgid "Default"
-msgstr " noklusēts: %s\n"
 #: ../lib/gis/mapset.c:38
 msgid "MAPSET is not set"
 msgstr "KARŠU KOPA nav noteikta"
@@ -8455,16 +7789,141 @@
 msgid "MAPSET <%s> not available"
-#: ../lib/gis/distance.c:154
+#: ../lib/gis/parser.c:376
 #, c-format
-msgid "%s: shouldn't happen: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
+msgid "BUG in descriptions, option '%s' in <%s> does not exist"
 msgstr ""
-#: ../lib/gis/debug.c:80
+#: ../lib/gis/parser.c:491
+msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
+msgstr ""
+#: ../lib/gis/parser.c:505
+msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
+msgstr ""
+#: ../lib/gis/parser.c:536
+#, c-format
+msgid "Sorry <%s> is not a valid option"
+msgstr "Atvainojiet, <%s> nav derīgs parametrs"
+#: ../lib/gis/parser.c:569
+msgid "ERROR"
+msgstr "KĻŪDA"
+#: ../lib/gis/parser.c:806
+msgid "Unable to determine program name"
+msgstr "Nav iespējams noteikt programmas nosaukumu"
+#: ../lib/gis/parser.c:822 ../lib/gis/parser.c:839
+#, c-format
+msgid "Sorry, <%c> is not a valid flag"
+msgstr "Atvainojiet, <%c> ir nedrīgs karogs"
+#: ../lib/gis/parser.c:939
+#, c-format
+msgid "Sorry, <%s=> is ambiguous"
+msgstr "Atvainojiet, <%s=> nav viennozīmīgi"
+#: ../lib/gis/parser.c:946
+#, c-format
+msgid "Sorry, <%s> is not a valid parameter"
+msgstr "Atvainojiet, <%s> ir nedrīgs parametrs"
+#: ../lib/gis/parser.c:954
+#, c-format
+msgid "Option <%s> does not accept multiple answers"
+msgstr "<%s> opcija nepieņem vairākus parametrus"
+#: ../lib/gis/parser.c:1025
 #, fuzzy, c-format
-msgid "Cannot open debug file '%s'"
-msgstr "Nevar atvērt 'temp'/pagaidu failu"
+msgid ""
+"Illegal range syntax for parameter <%s>\n"
+"\tPresented as: %s"
+msgstr ""
+"\n"
+"Kļūda: nepieņemama parametra sintakse <%s>\n"
+#: ../lib/gis/parser.c:1031
+#, fuzzy, c-format
+msgid ""
+"Value <%s> out of range for parameter <%s>\n"
+"\tLegal range: %s"
+msgstr ""
+"\n"
+"Kļūda: vērtība <%s> ir ārpus apgabala parametram  <%s>\n"
+#: ../lib/gis/parser.c:1037
+#, fuzzy, c-format
+msgid "Missing value for parameter <%s>"
+msgstr ""
+"\n"
+"Kļūda: Trūkst vērtība parametram <%s>\n"
+#: ../lib/gis/parser.c:1043
+#, fuzzy, c-format
+msgid ""
+"Value <%s> ambiguous for parameter <%s>\n"
+"\tValid options: %s"
+msgstr ""
+"\n"
+#: ../lib/gis/parser.c:1198
+#, fuzzy, c-format
+msgid ""
+"Required parameter <%s> not set:\n"
+"\t(%s)"
+msgstr ""
+"\n"
+"KĻŪDA: Prasītais parametrs <%s> nav iestatīts:\n"
+"    (%s).\n"
+#: ../lib/gis/parser.c:1290
+#, fuzzy, c-format
+msgid ""
+"Option <%s> must be provided in multiples of %d\n"
+"\tYou provided %d item(s): %s"
+msgstr ""
+"\n"
+"Kļūda: opcija/pazīme <%s> ir jabūt paredzētai daudzskaitlīgi no %d\n"
+#: ../lib/gis/parser.c:1365
+#, fuzzy, c-format
+msgid "ERROR: option <%s>: <%s> exists.\n"
+msgstr "Kļūda: opcija/pazīme <%s>: <%s> jau eksistē.\n"
+#: ../lib/gis/parser.c:1449
+msgid "No separator given"
+msgstr "Nav norādīts atdalītājs"
+#: ../lib/gis/seek.c:52 ../lib/gis/seek.c:58
+msgid "Unable to seek"
+msgstr ""
+#: ../lib/gis/seek.c:56
+msgid "Seek offset out of range"
+msgstr ""
+#: ../lib/gis/list.c:83
+#, fuzzy, c-format
+msgid "no %s files available in current mapset\n"
+msgstr "nav %s faili pieejami pašreizējā karšu biblotēkā\n"
+#: ../lib/gis/list.c:86
+#, fuzzy, c-format
+msgid "no %s files available in mapset <%s>\n"
+msgstr "nav %s faili pieejami karšu biblotēkā %s\n"
+#: ../lib/gis/list.c:132
+#, fuzzy, c-format
+msgid "%s files available in mapset <%s>:\n"
+msgstr "%s failu ir pieejami karšu biblotēkā %s:\n"
+#: ../lib/gis/list.c:204
+msgid "G_list: Unknown element type"
+msgstr ""
 #: ../lib/gis/find_file.c:79
 #, c-format
 msgid "'%s/%s' was found in more mapsets (also found in <%s>)"
@@ -8475,136 +7934,432 @@
 msgid "Using <%s@%s>"
 msgstr "neiespējami atrast [%s]"
-#: ../lib/gis/worker.c:72
-msgid "Task already has a worker"
+#: ../lib/gis/mapset_msc.c:61
+#, c-format
+msgid "Unable to make mapset element %s (%s): %s"
 msgstr ""
-#: ../lib/db/dbmi_client/delete_tab.c:40 ../lib/db/dbmi_client/table.c:46
+#: ../lib/gis/mapset_msc.c:65
+#, c-format
+msgid "Unable to access mapset element %s (%s): %s"
+msgstr ""
+#: ../lib/gis/paths.c:201
 #, fuzzy, c-format
-msgid "Unable open database <%s> by driver <%s>"
-msgstr "Nevar atvērt datubāzi %s"
+msgid "Unable to open file <%s> for reading"
+msgstr "Neiespējami atvērt %s priekš rakstīšanas"
-#: ../lib/db/dbmi_client/delete_tab.c:53
+#: ../lib/gis/paths.c:217
 #, fuzzy, c-format
-msgid "Unable to drop table: '%s'"
-msgstr "Neiespējami atvērt failu %s iekš %s"
+msgid "Unable to fetch security info for <%s>"
+msgstr "nevar ierakstīt vēstures informāciju priekš [%s]"
-#: ../lib/db/dbmi_client/copy_tab.c:91
+#: ../lib/gis/timestamp.c:292
 #, c-format
-msgid "Array of values to select from column <%s> is empty"
+msgid "Unable to create timestamp file for %s map <%s@%s>"
 msgstr ""
-#: ../lib/db/dbmi_client/copy_tab.c:151
+#: ../lib/gis/timestamp.c:301
 #, fuzzy, c-format
-msgid "Unable to get list tables in database <%s>"
-msgstr "neiespējami atvērt elipsoīda tabulas failu: %s"
+msgid "Invalid timestamp specified for %s map <%s@%s>"
+msgstr ""
+"Nederīgs laikspiedols(timestamp) norādīts priekš %s kartes %s karšu "
+"biblotēkā %s"
-#: ../lib/db/dbmi_client/copy_tab.c:167
+#: ../lib/gis/timestamp.c:331
 #, fuzzy, c-format
-msgid "Table <%s> already exists in database and will be overwritten"
-msgstr "Vektors '%s' jau eksistē un tiks pārrakstīts."
+msgid "Unable to open timestamp file for %s map <%s@%s>"
+msgstr "Nevar atvērt vēsturi vektoram '%s'"
-#: ../lib/db/dbmi_client/copy_tab.c:172
+#: ../lib/gis/timestamp.c:340
 #, fuzzy, c-format
-msgid "Table <%s> already exists in database <%s>"
+msgid "Invalid timestamp file for %s map <%s@%s>"
+msgstr ""
+"Nederīgs liakspiedola(timestamp) fails priekš %s kartes %s  karšu biblotēkā "
+"%s"
-#: ../lib/db/dbmi_client/copy_tab.c:250
+#: ../lib/gis/timestamp.c:479
 #, fuzzy, c-format
-msgid "Column <%s> is not integer"
+msgid "Unable to open timestamp file for vector map <%s@%s>"
-#: ../lib/db/dbmi_client/copy_tab.c:270
+#: ../lib/gis/timestamp.c:488
 #, fuzzy, c-format
-msgid "Unable to create table <%s>"
+msgid "Invalid timestamp file for vector map <%s@%s>"
+msgstr ""
+"%s"
+#: ../lib/gis/timestamp.c:524
+#, fuzzy, c-format
+msgid "Unable to create timestamp file for vector map <%s@%s>"
+msgstr "neispējami mainīt direktoriju uz %s"
+#: ../lib/gis/timestamp.c:533
+#, fuzzy, c-format
+msgid "Invalid timestamp specified for vector map <%s@%s>"
+msgstr ""
+"biblotēkā %s"
+#: ../lib/gis/legal_name.c:39
+#, c-format
+msgid "Illegal filename <%s>. Cannot be '.' or 'NULL'."
+msgstr "Neatļauts faila nosaukums <%s>. Nevar būt '.' vai 'NULL'."
+#: ../lib/gis/legal_name.c:46
+#, c-format
+msgid "Illegal filename <%s>. Character <%c> not allowed.\n"
+msgstr "Neatļauts faila nosaukums <%s>. Rakstzīme <%c> nav atļauta.\n"
+#: ../lib/gis/legal_name.c:77 ../lib/gis/legal_name.c:81
+#, c-format
+msgid "Output raster map name <%s> is not valid map name"
+msgstr ""
+#: ../lib/gis/legal_name.c:118 ../lib/gis/legal_name.c:122
+#, c-format
+msgid "Output raster map <%s> is used as input"
+msgstr ""
+#: ../lib/imagery/target.c:38
+#, fuzzy, c-format
+msgid "Unable to read target file for group [%s]"
+msgstr "Niespējami izveidot atkarību failu [%s iekš %s]"
+#: ../lib/imagery/sigsetfile.c:41
+#, fuzzy, c-format
+msgid ""
+"Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> "
+"is not current mapset"
-#: ../lib/db/dbmi_client/copy_tab.c:370
+#: ../lib/imagery/sigsetfile.c:57
+#, fuzzy, c-format
+msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s>"
+msgstr "Neiespējami atvērt failu %s iekš %s"
+#: ../lib/imagery/points.c:124
+#, fuzzy, c-format
+msgid "Unable to open control point file for group [%s in %s]"
+#: ../lib/imagery/points.c:132
+#, fuzzy, c-format
+msgid "Bad format in control point file for group [%s in %s]"
+#: ../lib/imagery/points.c:159
+#, fuzzy, c-format
+msgid "Unable to create control point file for group [%s in %s]"
+#: ../lib/imagery/iclass.c:83
+#, fuzzy, c-format
+msgid "No areas in category %d"
+#: ../lib/imagery/iclass.c:127
+#, fuzzy, c-format
+msgid "Raster map <%s@%s> in subgroup <%s> does not exist"
+#: ../lib/imagery/iclass.c:131
+#, fuzzy, c-format
+msgid "Raster map <%s@%s> in group <%s> does not exist"
+#: ../lib/imagery/iclass.c:143
 #, c-format
-msgid "Unknown column type (column <%s>)"
+msgid "Subgroup <%s> does not have enough files (it has %d files)"
 msgstr ""
-#: ../lib/db/dbmi_client/select.c:119 ../lib/db/dbmi_client/select.c:221
-#: ../lib/db/dbmi_client/select.c:288
-msgid "Missing column name"
+#: ../lib/imagery/iclass.c:147
+#, c-format
+msgid "Group <%s> does not have enough files (it has %d files)"
 msgstr ""
-#: ../lib/db/dbmi_client/select.c:216 ../lib/db/dbmi_client/select.c:283
-msgid "Missing key column name"
+#: ../lib/imagery/fopen.c:23
+#, fuzzy, c-format
+msgid "Unable to create file [%s] of group [%s in %s]"
+#: ../lib/imagery/fopen.c:36 ../lib/imagery/fopen.c:57
+#, fuzzy, c-format
+msgid "Unable to open file [%s] of group [%s in %s]"
+#: ../lib/imagery/fopen.c:49
+#, fuzzy, c-format
+msgid "Unable to find file [%s] of group [%s in %s]"
+msgstr "neiespējami atrast [%s] iekš [%s]"
+#: ../lib/imagery/fopen.c:79
+#, c-format
+msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
 msgstr ""
-#: ../lib/db/dbmi_client/select.c:333
+#: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
+#, fuzzy, c-format
+msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
+#: ../lib/imagery/fopen.c:116
+#, c-format
+msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:81
+#, fuzzy, c-format
+msgid "Unable to write header into category raster condition file <%s>."
+#: ../lib/imagery/iscatt_core.c:98
+#, fuzzy, c-format
+msgid "Unable to write into category raster condition file <%s>."
+#: ../lib/imagery/iscatt_core.c:255
+#, fuzzy, c-format
+msgid "Unable to open category raster condtions file <%s>."
+#: ../lib/imagery/iscatt_core.c:263
+#, fuzzy, c-format
+msgid "Unable to find patch raster <%s>."
+#: ../lib/imagery/iscatt_core.c:280
+#, c-format
+msgid "Resolutions of patch <%s> and patched file <%s> are not same."
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:307 ../lib/imagery/iscatt_core.c:349
+#, fuzzy, c-format
+msgid "Corrupted  category raster conditions file <%s> (fseek failed)"
+#: ../lib/imagery/iscatt_core.c:338
+#, fuzzy, c-format
+msgid "Unable to write into category raster conditions file <%s>"
+#: ../lib/imagery/iscatt_core.c:526
 #, fuzzy
-msgid "Key column type is not integer"
+msgid "Unable to read from category raster condtition file."
-#: ../lib/db/dbmi_driver/d_error.c:35
+#: ../lib/imagery/iscatt_core.c:533
+#, fuzzy
+msgid "Invalid size of category raster conditions file."
+#: ../lib/imagery/iscatt_core.c:579
+msgid ""
+"Data inconsistent. Value computed for scatter plot is out of initialized "
+"range."
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:745
+#, fuzzy, c-format
+msgid "Unbale to read find raster <%s>"
+#: ../lib/imagery/iscatt_core.c:755
+#, fuzzy, c-format
+msgid "Unbale to open raster <%s>"
+#: ../lib/imagery/iscatt_core.c:761
+#, fuzzy, c-format
+msgid "Raster <%s> type is not <%s>"
+msgstr "Ieejas vektors '%s' nav atrasts"
+#: ../lib/imagery/iscatt_core.c:775
+#, fuzzy, c-format
+msgid "Unable to read range of raster <%s>"
+#: ../lib/imagery/iscatt_core.c:803
+#, fuzzy, c-format
+msgid "Unable to open category raster condtition file <%s>"
+#: ../lib/imagery/iscatt_core.c:817
+#, fuzzy
+msgid "Corrupted category raster conditions file (fseek failed)"
+#: ../lib/imagery/iscatt_core.c:972 ../lib/imagery/iclass_statistics.c:227
 #, c-format
-msgid "DBMI-%s driver error:"
+msgid "prepare_signature: scan line %d has odd number of points."
 msgstr ""
-#: ../lib/db/dbmi_base/valuefmt.c:52
-msgid "db_convert_Cstring_to_value(): unrecognized sqltype"
+#: ../lib/imagery/iscatt_core.c:981 ../lib/imagery/iclass_statistics.c:237
+msgid "signature: perimeter points out of order."
 msgstr ""
-#: ../lib/db/dbmi_base/valuefmt.c:91
-msgid "db_convert_value_into_string(): unrecongized sqltype-type"
+#: ../lib/imagery/list_subgp.c:72
+#, c-format
+msgid "subgroup <%s> of group <%s> is empty\n"
 msgstr ""
-#: ../lib/db/dbmi_base/login.c:111
-msgid "Login file corrupted"
+#: ../lib/imagery/list_subgp.c:85
+#, c-format
+msgid "subgroup <%s> of group <%s> references the following raster maps\n"
 msgstr ""
-#: ../lib/db/dbmi_base/error.c:72
-msgid "<NULL error message>"
+#: ../lib/imagery/list_gp.c:34
+#, c-format
+msgid "group <%s> is empty\n"
 msgstr ""
-#: ../lib/db/dbmi_base/error.c:91
-msgid "dbmi: Protocol error"
+#: ../lib/imagery/list_gp.c:44
+#, c-format
+msgid "group <%s> references the following raster maps\n"
 msgstr ""
-#: ../lib/db/dbmi_base/error.c:136
+#: ../lib/imagery/iclass_statistics.c:218
+msgid "prepare_signature: outline has odd number of points."
+msgstr ""
+#: ../lib/imagery/iclass_statistics.c:248
+#, c-format
+msgid "Data error preparing signatures: value (%d) > num of cats (%d)"
+msgstr ""
+#: ../lib/imagery/iclass_statistics.c:561
+#: ../lib/imagery/iclass_statistics.c:584
+#: ../lib/imagery/iclass_statistics.c:607
+#: ../lib/imagery/iclass_statistics.c:630
+#: ../lib/imagery/iclass_statistics.c:653
+#: ../lib/imagery/iclass_statistics.c:680
+#: ../lib/imagery/iclass_statistics.c:712
+#: ../lib/imagery/iclass_statistics.c:735
+#: ../lib/imagery/iclass_statistics.c:758
 #, fuzzy
-msgid "dbmi: Out of Memory"
+msgid "Band index out of range"
+msgstr "Dubulto atribūtu indekss ārpus diapazona"
+#: ../lib/imagery/iclass_statistics.c:684
+#, fuzzy
+msgid "Cell category value out of range"
+#: ../lib/imagery/georef_tps.c:219
+msgid "Calculating forward transformation coefficients"
+msgstr ""
+#: ../lib/imagery/georef_tps.c:236
+msgid "Calculating backward transformation coefficients"
+msgstr ""
+#: ../lib/imagery/georef_tps.c:279 ../lib/imagery/georef_tps.c:282
+#: ../lib/imagery/georef_tps.c:285 ../lib/imagery/georef_tps.c:290
+#: ../lib/imagery/georef_tps.c:293
+#, fuzzy, c-format
+msgid "%s: out of memory"
 msgstr "Neiespējami piešķirt atmiņu\n"
-#: ../lib/db/dbmi_base/error.c:149
+#: ../lib/imagery/iclass_perimeter.c:109
 #, c-format
-msgid "dbmi: %s() not implemented"
+msgid "Get area %d failed"
 msgstr ""
-#: ../lib/db/dbmi_base/error.c:163
+#: ../lib/imagery/iclass_perimeter.c:116
+msgid "Perimeter computation failed"
+msgstr ""
+#: ../lib/imagery/iclass_perimeter.c:208
+msgid "Absurd polygon."
+msgstr ""
+#: ../lib/imagery/iclass_perimeter.c:253
+msgid "Outlined area is too large."
+msgstr ""
+#: ../lib/imagery/iclass_signatures.c:120
+#, fuzzy, c-format
+msgid "Unable to open output signature file '%s'"
+#: ../lib/cluster/c_exec.c:44
 #, c-format
-msgid "dbmi: Invalid procedure %d"
+msgid "Not enough data points (%d) in cluster"
 msgstr ""
-#: ../lib/db/dbmi_base/index.c:180
-msgid "db_set_index_column_name(): invalid column number"
+#: ../lib/cluster/c_begin.c:57
+#, c-format
+msgid "produced by i.cluster"
 msgstr ""
-#: ../lib/db/dbmi_base/index.c:197
-msgid "db_get_index_column_name(): invalid column number"
+#: ../lib/db/dbmi_driver/d_error.c:35
+#, c-format
+msgid "DBMI-%s driver error:"
 msgstr ""
-#: ../lib/db/dbmi_base/test/test_table.c:38
-#, fuzzy
-msgid ""
-"\n"
-"++ Running table unit tests ++"
-msgstr "nezināns interpolācijas tips"
+#: ../lib/db/dbmi_client/select.c:119 ../lib/db/dbmi_client/select.c:221
+#: ../lib/db/dbmi_client/select.c:288
+msgid "Missing column name"
+msgstr ""
-#: ../lib/db/dbmi_base/test/test_table.c:43
+#: ../lib/db/dbmi_client/select.c:216 ../lib/db/dbmi_client/select.c:283
+msgid "Missing key column name"
+msgstr ""
+#: ../lib/db/dbmi_client/select.c:333
 #, fuzzy
-msgid ""
-"\n"
-"-- Table unit tests failure --"
+msgid "Key column type is not integer"
+msgstr "Nevar atvērt datubāzi %s"
-#: ../lib/db/dbmi_base/test/test_table.c:45
+#: ../lib/db/dbmi_client/copy_tab.c:91
+#, c-format
+msgid "Array of values to select from column <%s> is empty"
+msgstr ""
+#: ../lib/db/dbmi_client/copy_tab.c:151
+#, fuzzy, c-format
+msgid "Unable to get list tables in database <%s>"
+msgstr "neiespējami atvērt elipsoīda tabulas failu: %s"
+#: ../lib/db/dbmi_client/copy_tab.c:167
+#, fuzzy, c-format
+msgid "Table <%s> already exists in database and will be overwritten"
+msgstr "Vektors '%s' jau eksistē un tiks pārrakstīts."
+#: ../lib/db/dbmi_client/copy_tab.c:172
+#, fuzzy, c-format
+msgid "Table <%s> already exists in database <%s>"
+#: ../lib/db/dbmi_client/copy_tab.c:250
+#, fuzzy, c-format
+msgid "Column <%s> is not integer"
+#: ../lib/db/dbmi_client/copy_tab.c:270
+#, fuzzy, c-format
+msgid "Unable to create table <%s>"
+#: ../lib/db/dbmi_client/copy_tab.c:370
+#, c-format
+msgid "Unknown column type (column <%s>)"
+msgstr ""
+#: ../lib/db/dbmi_client/table.c:46 ../lib/db/dbmi_client/delete_tab.c:40
+#, fuzzy, c-format
+msgid "Unable open database <%s> by driver <%s>"
+#: ../lib/db/dbmi_client/delete_tab.c:53
+#, fuzzy, c-format
+msgid "Unable to drop table: '%s'"
+#: ../lib/db/dbmi_base/test/test_main.c:83
 #, fuzzy
-msgid ""
-"\n"
-"-- Table unit tests finished successfully --"
+msgid "Performs unit and integration tests for the dbmi base library"
 #: ../lib/db/dbmi_base/test/test_columns.c:37
@@ -8640,362 +8395,360 @@
 "++ Test copy column finished ++"
 msgstr ""
-#: ../lib/db/dbmi_base/test/test_main.c:83
+#: ../lib/db/dbmi_base/test/test_table.c:38
 #, fuzzy
-msgid "Performs unit and integration tests for the dbmi base library"
+msgid ""
+"\n"
+"++ Running table unit tests ++"
-#: ../lib/db/dbmi_base/xdrtable.c:109
-msgid "fetch: table has wrong number of columns"
+#: ../lib/db/dbmi_base/test/test_table.c:43
+#, fuzzy
+msgid ""
+"\n"
+"-- Table unit tests failure --"
+msgstr "nezināns interpolācijas tips"
+#: ../lib/db/dbmi_base/test/test_table.c:45
+#, fuzzy
+msgid ""
+"\n"
+"-- Table unit tests finished successfully --"
+#: ../lib/db/dbmi_base/valuefmt.c:52
+msgid "db_convert_Cstring_to_value(): unrecognized sqltype"
 msgstr ""
-#: ../lib/db/dbmi_base/legal_dbname.c:38
-#, fuzzy, c-format
-msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'."
+#: ../lib/db/dbmi_base/valuefmt.c:91
+msgid "db_convert_value_into_string(): unrecongized sqltype-type"
 msgstr ""
-"Nepieņemams vektoru kartes nosaukums <%s>. Nedrīkst saturēt '.' vai 'NULL'.\n"
-#: ../lib/db/dbmi_base/legal_dbname.c:45
-#, fuzzy, c-format
-msgid "Illegal table map name <%s>. Must start with a letter."
-msgstr "Nepieņemams vektoru kartes nosaukums <%s>. J;as;akas ar burtu.\n"
+#: ../lib/db/dbmi_base/index.c:180
+msgid "db_set_index_column_name(): invalid column number"
+msgstr ""
-#: ../lib/db/dbmi_base/legal_dbname.c:54
-#, fuzzy, c-format
-msgid "Illegal table map name <%s>. Character <%c> not allowed."
-msgstr "Nepieņemams vektoru kartes nosaukums <%s>. Zīme <%c> nav atļauta.\n"
+#: ../lib/db/dbmi_base/index.c:197
+msgid "db_get_index_column_name(): invalid column number"
+msgstr ""
+#: ../lib/db/dbmi_base/login.c:111
+msgid "Login file corrupted"
+msgstr ""
 #: ../lib/db/dbmi_base/default_name.c:136
 msgid "Programmer error"
-msgstr ""
+msgstr "Programmētāja kļūda"
 #: ../lib/db/dbmi_base/xdrvalue.c:82
 msgid "send data: invalid C-type"
 msgstr ""
-#, fuzzy
-#~ msgid "Performs unit and integration tests for the g3d library"
-#~ msgstr "nezināns interpolācijas tips"
+#: ../lib/db/dbmi_base/error.c:72
+msgid "<NULL error message>"
+msgstr ""
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "++ Running g3d coordinate transform unit tests ++"
+#: ../lib/db/dbmi_base/error.c:91
+msgid "dbmi: Protocol error"
+msgstr ""
+#: ../lib/db/dbmi_base/error.c:136
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "-- g3d coordinate transform unit tests failure --"
+msgid "dbmi: Out of Memory"
+msgstr "Neiespējami piešķirt atmiņu\n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "-- g3d coordinate transform unit tests finished successfully --"
+#: ../lib/db/dbmi_base/error.c:149
+#, c-format
+msgid "dbmi: %s() not implemented"
+msgstr ""
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "++ Running g3d put/get value large file unit tests ++"
+#: ../lib/db/dbmi_base/error.c:163
+#, c-format
+msgid "dbmi: Invalid procedure %d"
+msgstr ""
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "-- g3d put/get value large file unit tests failure --"
+#: ../lib/db/dbmi_base/legal_dbname.c:38
+#, fuzzy, c-format
+msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'."
+msgstr "Nepieņemams vektoru kartes nosaukums <%s>. Nedrīkst saturēt '.' vai 'NULL'.\n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "-- g3d put/get value large file unit tests finished successfully --"
+#: ../lib/db/dbmi_base/legal_dbname.c:45
+#, fuzzy, c-format
+msgid "Illegal table map name <%s>. Must start with a letter."
+msgstr "Nepieņemams vektoru kartes nosaukums <%s>. J;as;akas ar burtu.\n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "++ Running g3d put/get value unit tests ++"
+#: ../lib/db/dbmi_base/legal_dbname.c:54
+#, fuzzy, c-format
+msgid "Illegal table map name <%s>. Character <%c> not allowed."
+msgstr "Nepieņemams vektoru kartes nosaukums <%s>. Zīme <%c> nav atļauta.\n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "-- g3d put/get value unit tests failure --"
+#: ../lib/db/dbmi_base/xdrtable.c:109
+msgid "fetch: table has wrong number of columns"
+msgstr ""
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "-- g3d put/get value unit tests finished successfully --"
+#: ../lib/ogsf/trans.c:180
+msgid "Out of matrix stack space"
+msgstr ""
-#, fuzzy
-#~ msgid "Registering maps in the temporal database"
-#~ msgstr "neiespējami atvērt rastra karti [%s iekš %s]"
+#: ../lib/ogsf/trans.c:200
+msgid "Tried to pop an empty stack"
+msgstr ""
-#, fuzzy
-#~ msgid "Space time %(t)s dataset <%(i)s> not found"
-#~ msgstr "Ieejas vektors '%s' nav atrasts"
+#: ../lib/ogsf/GK2.c:216 ../lib/ogsf/gsd_img_tif.c:64
+#: ../lib/ogsf/gsd_img_ppm.c:52 ../lib/ogsf/gsd_img_ppm.c:95
+#, c-format
+msgid "Unable to open file <%s> for writing"
+msgstr "Nav iespējams atvērt failu <%s> rakstīšanai"
-#, fuzzy
-#~ msgid "Space time %(t)s dataset <%(i)s> not found in temporal database"
+#: ../lib/ogsf/GK2.c:272 ../lib/ogsf/GK2.c:285
+msgid "Check no. of frames requested and keyframes marked"
+msgstr ""
-#, fuzzy
-#~ msgid ""
-#~ "Space time %(t)s dataset <%(i)s> is already in database, use overwrite "
-#~ "flag to overwrite"
-#~ msgstr "Vektors '%s' jau eksistē un tiks pārrakstīts."
+#: ../lib/ogsf/gs_bm.c:124
+msgid "Bitmap mismatch"
+msgstr ""
-#, fuzzy
-#~ msgid "Space time %(type)s dataset <%(id)s> not found"
+#: ../lib/ogsf/gsd_legend.c:246
+#, c-format
+msgid "Unable to read color file of raster map <%s>"
+msgstr "Nav iespējams nolasīt rastra kartes <%s> krāsu failu"
-#, fuzzy
-#~ msgid "Please specify base="
-#~ msgstr ""
-#~ "\n"
-#~ "Lūdzu norādi datuma nosaukumu\n"
+#: ../lib/ogsf/gsd_legend.c:252
+#, c-format
+msgid "Unable to read category file of raster map <%s>"
+msgstr ""
-#, fuzzy
-#~ msgid ""
-#~ "Space time %(type)s dataset <%(id)s> is already in database, use "
-#~ "overwrite flag to overwrite"
+#: ../lib/ogsf/gsd_legend.c:269
+#, c-format
+msgid "Unable to read fp range of raster map <%s>"
+msgstr ""
-#, fuzzy
-#~ msgid ""
-#~ "Default TGIS driver / database set to:\n"
-#~ "driver: %s\n"
-#~ "database: %s"
-#~ msgstr ""
-#~ "Noklusēto draiveri / datubāzi likt uz:\n"
-#~ "vietu: dbf\n"
-#~ "datubāze: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/"
+#: ../lib/ogsf/gsd_legend.c:281
+#, c-format
+msgid "Unable to read range of raster map <%s>"
+msgstr ""
-#, fuzzy
-#~ msgid "Default TGIS driver is not set"
-#~ msgstr "Noklusētais draiveris nav uzstādīts"
+#: ../lib/ogsf/gsd_legend.c:295
+msgid "Range request error for legend"
+msgstr ""
+#: ../lib/ogsf/gsd_legend.c:385
 #, fuzzy
-#~ msgid "Default TGIS database is not set"
-#~ msgstr " Noklusētā datubāze nav uzstādīta"
+msgid "Unable to show discrete FP range (use list)"
+msgstr "Nevar ierakstīt datubāzes saites"
-#, fuzzy
-#~ msgid ""
-#~ "Set absolute valid time for map <%(id)s> with layer %(layer)s to "
-#~ "%(start)s - %(end)s"
+#: ../lib/ogsf/gsd_legend.c:501
+msgid "Too many categories to show as discrete!"
+msgstr ""
-#, fuzzy
-#~ msgid ""
-#~ "Set relative valid time for map <%s> with layer %s to %i - %s with unit %s"
+#: ../lib/ogsf/gsd_legend.c:503
+msgid "Try using smaller font!"
+msgstr ""
-#, fuzzy
-#~ msgid "Set relative valid time for map <%s> to %i - %s with unit %s"
+#: ../lib/ogsf/gsd_prim.c:146
+#, c-format
+msgid "Color Material: %d"
+msgstr ""
-#, fuzzy
-#~ msgid "Unregister %(type)s map <%(map)s> from space time datasets"
+#: ../lib/ogsf/gsd_prim.c:630
+#, c-format
+msgid ""
+"gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please "
+"advise GRASS developers of this error"
+msgstr ""
-#, fuzzy
-#~ msgid "Register %s map <%s> with layer %s in space time %s dataset <%s>"
+#: ../lib/ogsf/gsd_img_mpeg.c:76
+msgid "Unable to allocate stream"
+msgstr ""
-#, fuzzy
-#~ msgid "Register %s map <%s> in space time %s dataset <%s>"
+#: ../lib/ogsf/gsd_img_mpeg.c:179
+msgid "Video codec not found"
+msgstr "Video kodeks nav atrasts"
-#, fuzzy
-#~ msgid "Created register table <%s> for %s map <%s> with layer %s"
-#~ msgstr "neispējami mainīt direktoriju uz %s"
+#: ../lib/ogsf/gsd_img_mpeg.c:189
+msgid "Unable to open codec"
+msgstr "Nav iespējams atvērt kodeku"
-#, fuzzy
-#~ msgid "Created register table <%s> for %s map <%s>"
+#: ../lib/ogsf/gsd_img_mpeg.c:208
+msgid "Unable to allocate picture"
+msgstr ""
-#, fuzzy
-#~ msgid "Unregister %s map <%s> with layer %s"
-#~ msgstr " Rastra karte %s@%s ir tukša"
+#: ../lib/ogsf/gsd_img_mpeg.c:219
+msgid "Unable to allocate temporary picture"
+msgstr ""
-#, fuzzy
-#~ msgid "Unregister %s map <%s>"
+#: ../lib/ogsf/gsd_img_mpeg.c:286
+msgid "Error while writing video frame"
+msgstr ""
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "++ Running gwflow integration tests ++"
+#: ../lib/ogsf/gsd_img_mpeg.c:332
+#, c-format
+msgid "Opening MPEG stream <%s>..."
+msgstr ""
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "-- gwflow integration tests failure --"
+#: ../lib/ogsf/gsd_img_mpeg.c:344
+msgid "Unable to deduce output format from file extension: using MPEG"
+msgstr ""
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "++ Running math tool unit tests ++"
+#: ../lib/ogsf/gsd_img_mpeg.c:352
+msgid "Unable to find suitable output format"
+msgstr ""
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "-- math tool unit tests failure --"
+#: ../lib/ogsf/gsd_img_mpeg.c:383
+msgid "Invalid output format parameters"
+msgstr "Nederīgi izvades formāta parametri"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "++ Running solute_transport integration tests ++"
+#: ../lib/ogsf/gsd_img_mpeg.c:405
+#, c-format
+msgid "Unable to open <%s>"
+msgstr "Nav iespējams atvērt <%s>"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "++ Running heat flow integration tests ++"
+#: ../lib/ogsf/gsd_img_mpeg.c:418
+msgid "OGSF library has not been built with MPEG output support"
+msgstr ""
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "-- heat flow integration tests failure --"
+#: ../lib/ogsf/gk.c:320
+msgid "Need at least 3 keyframes for spline"
+msgstr ""
-#, fuzzy
-#~ msgid "Unable open spatial index file for write <%s>"
-#~ msgstr "Nevar atvērt telpisko datu index failu rakstīšanai: %s\n"
+#: ../lib/ogsf/gk.c:622
+msgid "Need at least 2 keyframes for interpolation"
+msgstr ""
-#, fuzzy
-#~ msgid "Attempt to read dead feature %d"
-#~ msgstr "Nevar nolasīt histogrammu priekš [%s no %s]"
+#: ../lib/ogsf/GVL2.c:267
+#, c-format
+msgid "Loading 3d raster map <%s>..."
+msgstr ""
-#, fuzzy
-#~ msgid "Reading failed: %s"
-#~ msgstr "Pieslēgšanās izgāzusies\n"
+#: ../lib/ogsf/GS2.c:1211
+#, c-format
+msgid "no category info"
+msgstr "nav kategoriju informācijas"
-#, fuzzy
-#~ msgid "Unable to get features"
-#~ msgstr "Neiespējami atvērt failu %s iekš %s"
+#: ../lib/ogsf/GS2.c:1230
+#, c-format
+msgid "no data"
+msgstr "nav datu"
-#, fuzzy
-#~ msgid "Could not find isle box"
-#~ msgstr "Nevar palaist failu '%s'"
+#: ../lib/ogsf/GS2.c:1655
+#, c-format
+msgid "Raster map <%s> is outside of current region. Load failed."
+msgstr "Rastra karte <%s> atrodas ārpus reģiona. Ielāde nav veikta."
-#, fuzzy
-#~ msgid "<%s> is not the current mapset (%s)"
-#~ msgstr "nav %s faili pieejami pašreizējā karšu biblotēkā\n"
+#: ../lib/ogsf/GS2.c:1733 ../lib/ogsf/GS2.c:1739 ../lib/ogsf/GS2.c:1747
+#: ../lib/ogsf/GS2.c:1756 ../lib/ogsf/GS2.c:1764 ../lib/ogsf/GS2.c:1774
+#: ../lib/ogsf/GS2.c:1822
+msgid "GS_load_att_map(): Out of memory. Unable to load map"
+msgstr ""
-#, fuzzy
-#~ msgid "Unable to read line %d"
-#~ msgstr "Nevar atvērt 'temp'/pagaidu failu"
+#: ../lib/ogsf/GS2.c:1850
+msgid "Loading failed"
+msgstr "Nesekmīga ielāde"
-#, fuzzy
-#~ msgid "Unable to get feature type"
+#: ../lib/ogsf/GS2.c:1854
+msgid "Error finding range"
+msgstr ""
-#, fuzzy
-#~ msgid "Unable to rewrite feature, vector map is not opened"
-#~ msgstr "Nevar pārrakstīt līniju,karte nav atvērta"
+#: ../lib/ogsf/gvl_file.c:103
+msgid "Maximum number of datafiles exceeded"
+msgstr ""
-#, fuzzy
-#~ msgid ""
-#~ "Unable to delete feature %d, vector map <%s> is not opened on topology "
-#~ "level"
-#~ msgstr "Nevar izdzēst līniju, karte '%s' karte nav atvērta līmenī 2"
+#: ../lib/ogsf/gvl_file.c:442
+#, c-format
+msgid "Unable to read range of 3D raster map <%s>"
+msgstr ""
-#, fuzzy
-#~ msgid ""
-#~ "Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
-#~ msgstr ""
-#~ "Nevar izdzēst līniju, karte '%s' karte nav atvērta rakstīšanas 'write' "
-#~ "režijmā"
+#: ../lib/ogsf/gsds.c:109
+msgid "Maximum number of datasets exceeded"
+msgstr ""
-#, fuzzy
-#~ msgid ""
-#~ "Unable to restore feature %d, vector map <%s> is not opened on topology "
-#~ "level"
+#: ../lib/ogsf/Gs3.c:132 ../lib/ogsf/Gs3.c:196 ../lib/ogsf/Gs3.c:348
+#: ../lib/ogsf/Gs3.c:454 ../lib/ogsf/Gs3.c:540
+#, c-format
+msgid "Loading raster map <%s>..."
+msgstr ""
-#, fuzzy
-#~ msgid ""
-#~ "Unable to restore feature %d, vector map <%s> is not opened in 'write' "
-#~ "mode"
-#~ msgstr ""
-#~ "režijmā"
+#: ../lib/ogsf/Gs3.c:596
+#, c-format
+msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
+msgstr ""
-#, fuzzy
-#~ msgid "Unable to open cidx file <%s> for write"
-#~ msgstr "Neiespējami atvērt %s priekš rakstīšanas"
+#: ../lib/ogsf/Gs3.c:658 ../lib/ogsf/Gs3.c:730
+#, c-format
+msgid "Translating colors from raster map <%s>..."
+msgstr ""
-#, fuzzy
-#~ msgid "Topology not available. Unable to insert new edge."
-#~ msgstr "Nav pieejama palīdzība komandai [%s]\n"
+#: ../lib/ogsf/Gs3.c:967
+msgid "View not saved by this program,there may be some inconsistancies"
+msgstr ""
-#, fuzzy
-#~ msgid "input vector map is not open"
+#: ../lib/ogsf/GP2.c:705
+msgid "Unknown icon marker, using \"sphere\""
+msgstr ""
-#, fuzzy
-#~ msgid ""
-#~ "Unable to open signature file <%s> for subgroup <%s> of group <%s@%s>"
+#: ../lib/ogsf/gsd_label.c:58
+msgid "Max. number of labels reached!"
+msgstr ""
-#, fuzzy
-#~ msgid "The space time %(type)s dataset <%(name)s> must have interval time"
+#: ../lib/ogsf/Gp3.c:146
+#, c-format
+msgid "No points from vector map <%s> fall within current region"
+msgstr ""
-#, fuzzy
-#~ msgid "Unable to open topo file for write <%s>"
-#~ msgstr "Nevar atvērt topo failu rakstīšanai: %s\n"
+#: ../lib/ogsf/Gp3.c:151
+#, c-format
+msgid "Vector map <%s> loaded (%d points)"
+msgstr ""
-#, fuzzy
-#~ msgid "Unable to read node %d"
+#: ../lib/ogsf/Gp3.c:209
+#, c-format
+msgid "Loading thematic points layer <%s>..."
+msgstr ""
-#, fuzzy
-#~ msgid "Unable to read nodes"
+#: ../lib/ogsf/Gp3.c:233 ../lib/ogsf/Gv3.c:370
+#, c-format
+msgid "No color rule defined for category %d"
+msgstr ""
-#, fuzzy
-#~ msgid "Unable to read lines"
+#: ../lib/ogsf/Gp3.c:247 ../lib/ogsf/Gv3.c:385
+#, c-format
+msgid "Invalid color definition (%s)"
+msgstr ""
-#, fuzzy
-#~ msgid "Unable to attach centroids"
-#~ msgstr "Neiespējami piešķirt atmiņu\n"
+#: ../lib/ogsf/Gp3.c:286
+#, c-format
+msgid ""
+"%d points without category. Unable to determine color rules for features "
+"without category."
+msgstr ""
-#, fuzzy
-#~ msgid "Unexpected feature type (%s) - should be (%d)"
+#: ../lib/ogsf/Gv3.c:262
+#, c-format
+msgid "No features from vector map <%s> fall within current region"
+msgstr ""
-#, fuzzy
-#~ msgid "Unable to read centroid %d: %s"
+#: ../lib/ogsf/Gv3.c:267
+#, c-format
+msgid "Vector map <%s> loaded (%d features)"
+msgstr ""
-#, fuzzy
-#~ msgid "Unable to export node %d. Exiting."
+#: ../lib/ogsf/Gv3.c:346
+#, c-format
+msgid "Loading thematic vector layer <%s>..."
+msgstr ""
-#, fuzzy
-#~ msgid "Unable to look up account id"
-#~ msgstr "Neisespējami atvērt %s"
+#: ../lib/ogsf/Gv3.c:407
+#, c-format
+msgid ""
+"%d features without category. Unable to determine color rules for features "
+msgstr ""
-#, fuzzy
-#~ msgid "Unable to allocate memory for account name"
+#: ../lib/ogsf/gsd_surf.c:1742
+msgid "Cut-plane points mis-match between surfaces. Check resolution(s)."
+msgstr ""
-#, fuzzy
-#~ msgid "Unable to allocate memory for domain name"
+#: ../lib/ogsf/gsdrape.c:207
+msgid "Unable to process vector map - out of memory"
+msgstr ""
-#, fuzzy
-#~ msgid "Unable to get area bounding box. No feature id given."
Modified: grass/trunk/locale/po/grasswxpy_lv.po
--- grass/trunk/locale/po/grasswxpy_lv.po	2014-03-01 18:00:14 UTC (rev 59158)
+++ grass/trunk/locale/po/grasswxpy_lv.po	2014-03-01 18:02:38 UTC (rev 59159)
@@ -7,7 +7,7 @@
 msgstr ""
 "Project-Id-Version: grasswxpy_lv\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2012-11-14 12:30+0200\n"
+"POT-Creation-Date: 2014-03-01 19:19+0200\n"
 "PO-Revision-Date: 2014-03-01 14:25+0200\n"
 "Last-Translator: Maris Nartiss <maris.gis at gmail.com>\n"
 "Language-Team: Latvian\n"
@@ -16,1247 +16,973 @@
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
 "X-Generator: KBabel 1.11.4\n"
-"Plural-Forms:  nplurals=3; plural=(n%10==1 && n%100!=11 ? 0 : n != 0 ? 1 : 2);\n"
+"Plural-Forms:  nplurals=3; plural=(n%10==1 && n%100!=11 ? 0 : n != 0 ? 1 : "
+"2);\n"
-#: ../gui/wxpython/psmap/toolbars.py:52
+#: ../gui/wxpython/psmap/toolbars.py:61 ../gui/wxpython/menustrings.py:1724
 msgid "Generate text file with mapping instructions"
 msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:54
+#: ../gui/wxpython/psmap/toolbars.py:63 ../gui/wxpython/menustrings.py:1722
 msgid "Load text file with mapping instructions"
 msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:56
+#: ../gui/wxpython/psmap/toolbars.py:65 ../gui/wxpython/menustrings.py:1726
 msgid "Generate PostScript output"
 msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:58
+#: ../gui/wxpython/psmap/toolbars.py:67 ../gui/wxpython/menustrings.py:1728
 msgid "Generate PDF output"
 msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:60 ../gui/wxpython/gcp/mapdisplay.py:479
-#: ../gui/wxpython/gui_modules/gcpmapdisp.py:511
-#: ../gui/wxpython/gui_modules/wxplot.py:511
-#: ../gui/wxpython/gui_modules/histogram.py:433
-#: ../gui/wxpython/gui_modules/mapdisp.py:918
-#: ../gui/wxpython/modules/histogram.py:443 ../gui/wxpython/wxplot/base.py:504
-#: ../gui/wxpython/mapdisp/frame.py:595
+#: ../gui/wxpython/psmap/toolbars.py:69 ../gui/wxpython/gcp/mapdisplay.py:412
+#: ../gui/wxpython/menustrings.py:1719
+#: ../gui/wxpython/modules/histogram.py:449 ../gui/wxpython/wxplot/base.py:539
+#: ../gui/wxpython/mapdisp/frame.py:657
 msgid "Page setup"
 msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:61
+#: ../gui/wxpython/psmap/toolbars.py:70 ../gui/wxpython/menustrings.py:1720
 msgid "Specify paper size, margins and orientation"
 msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:63
+#: ../gui/wxpython/psmap/toolbars.py:72
 msgid "Full extent"
 msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:64
+#: ../gui/wxpython/psmap/toolbars.py:73
 msgid "Zoom to full extent"
 msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:66 ../gui/wxpython/psmap/dialogs.py:618
-#: ../gui/wxpython/psmap/dialogs.py:673
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2243
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2298
+#: ../gui/wxpython/psmap/toolbars.py:75 ../gui/wxpython/psmap/dialogs.py:619
+#: ../gui/wxpython/psmap/dialogs.py:674 ../gui/wxpython/menustrings.py:1734
 msgid "Map frame"
 msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:67
+#: ../gui/wxpython/psmap/toolbars.py:76
 msgid "Click and drag to place map frame"
 msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:69
+#: ../gui/wxpython/psmap/toolbars.py:78 ../gui/wxpython/menustrings.py:1753
 msgid "Delete selected object"
 msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:71
+#: ../gui/wxpython/psmap/toolbars.py:80
 msgid "Show preview"
 msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:73
+#: ../gui/wxpython/psmap/toolbars.py:82
 msgid "Quit Cartographic Composer"
 msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:75 ../gui/wxpython/psmap/dialogs.py:3705
-#: ../gui/wxpython/psmap/dialogs.py:3710
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5302
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5307
+#: ../gui/wxpython/psmap/toolbars.py:84 ../gui/wxpython/psmap/dialogs.py:3705
+#: ../gui/wxpython/psmap/dialogs.py:3710 ../gui/wxpython/menustrings.py:1746
+#: ../gui/wxpython/animation/dialogs.py:1196
 msgid "Text"
 msgstr "Teksts"
-#: ../gui/wxpython/psmap/toolbars.py:77
+#: ../gui/wxpython/psmap/toolbars.py:86 ../gui/wxpython/menustrings.py:1742
 msgid "Map info"
 msgstr "Kartes informācija"
-#: ../gui/wxpython/psmap/toolbars.py:79
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:873
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:916
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:967
-#: ../gui/wxpython/wxplot/dialogs.py:874 ../gui/wxpython/wxplot/dialogs.py:917
-#: ../gui/wxpython/wxplot/dialogs.py:968
+#: ../gui/wxpython/psmap/toolbars.py:88 ../gui/wxpython/wxplot/dialogs.py:898
+#: ../gui/wxpython/wxplot/dialogs.py:941 ../gui/wxpython/wxplot/dialogs.py:991
 msgid "Legend"
 msgstr "Leģenda"
-#: ../gui/wxpython/psmap/toolbars.py:81 ../gui/wxpython/nviz/tools.py:1957
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2116
+#: ../gui/wxpython/psmap/toolbars.py:90 ../gui/wxpython/menustrings.py:1744
+#: ../gui/wxpython/nviz/tools.py:1991
 msgid "Scale bar"
 msgstr "Mērogjosla"
-#: ../gui/wxpython/psmap/toolbars.py:83 ../gui/wxpython/psmap/dialogs.py:4061
-#: ../gui/wxpython/psmap/dialogs.py:4109
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5658
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5706
+#: ../gui/wxpython/psmap/toolbars.py:92 ../gui/wxpython/psmap/dialogs.py:4061
+#: ../gui/wxpython/psmap/dialogs.py:4109 ../gui/wxpython/menustrings.py:1748
 msgid "Image"
 msgstr "Attēls"
-#: ../gui/wxpython/psmap/toolbars.py:85 ../gui/wxpython/psmap/dialogs.py:4490
-#: ../gui/wxpython/nviz/tools.py:1912
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:6085
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2074
-#: ../gui/wxpython/mapdisp/toolbars.py:35
+#: ../gui/wxpython/psmap/toolbars.py:94 ../gui/wxpython/psmap/dialogs.py:4494
+#: ../gui/wxpython/menustrings.py:1750 ../gui/wxpython/nviz/tools.py:1946
 msgid "North Arrow"
 msgstr "Ziemeļu bulta"
-#: ../gui/wxpython/psmap/toolbars.py:87
-msgid "Add simple graphics"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:89 ../gui/wxpython/psmap/dialogs.py:4522
-#: ../gui/wxpython/gui_modules/gselect.py:1810
-#: ../gui/wxpython/gui_modules/vdigit.py:548
-#: ../gui/wxpython/gui_core/gselect.py:1885
-#: ../gui/wxpython/vdigit/preferences.py:516
+#: ../gui/wxpython/psmap/toolbars.py:96 ../gui/wxpython/psmap/dialogs.py:4526
+#: ../gui/wxpython/gui_core/gselect.py:2085
+#: ../gui/wxpython/vdigit/preferences.py:536
 msgid "Point"
 msgstr "Punkts"
-#: ../gui/wxpython/psmap/toolbars.py:91
-#: ../gui/wxpython/gui_modules/vdigit.py:549
-#: ../gui/wxpython/vdigit/preferences.py:517
+#: ../gui/wxpython/psmap/toolbars.py:98
+#: ../gui/wxpython/vdigit/preferences.py:537
 msgid "Line"
 msgstr "Līnija"
-#: ../gui/wxpython/psmap/toolbars.py:93
+#: ../gui/wxpython/psmap/toolbars.py:100
+#: ../gui/wxpython/rlisetup/wizard.py:720
+#: ../gui/wxpython/rlisetup/wizard.py:868
 msgid "Rectangle"
 msgstr "Taisnstūris"
+#: ../gui/wxpython/psmap/toolbars.py:102
+#, fuzzy
+msgid "Add overlays"
+msgstr "Pievienot slāni"
+#: ../gui/wxpython/psmap/toolbars.py:104 ../gui/wxpython/lmgr/layertree.py:98
+msgid "Add labels"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:192
+msgid "Add simple graphics: points"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:204
+msgid "Add simple graphics: lines"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:216
+msgid "Add simple graphics: rectangles"
+msgstr ""
 #: ../gui/wxpython/psmap/instructions.py:133
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:337
 #, python-format
 msgid ""
 "Unable to open file\n"
 "%s"
 msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:460
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:643
+#: ../gui/wxpython/psmap/instructions.py:467
 #, python-format
 msgid "Instruction file will be loaded with following region: %s\n"
 msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:465
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:648
+#: ../gui/wxpython/psmap/instructions.py:472
 #, python-format
 msgid ""
 "Region cannot be set\n"
 "%s"
 msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:604
-#: ../gui/wxpython/psmap/instructions.py:754
-#: ../gui/wxpython/psmap/instructions.py:870
-#: ../gui/wxpython/psmap/instructions.py:928
-#: ../gui/wxpython/psmap/instructions.py:1069
-#: ../gui/wxpython/psmap/instructions.py:1124
-#: ../gui/wxpython/psmap/instructions.py:1183
-#: ../gui/wxpython/psmap/instructions.py:1252
-#: ../gui/wxpython/psmap/instructions.py:1358
-#: ../gui/wxpython/psmap/instructions.py:1483
-#: ../gui/wxpython/psmap/instructions.py:1534
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:779
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:929
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1043
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1107
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1256
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1362
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1487
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1538
+#: ../gui/wxpython/psmap/instructions.py:611
+#: ../gui/wxpython/psmap/instructions.py:761
+#: ../gui/wxpython/psmap/instructions.py:877
+#: ../gui/wxpython/psmap/instructions.py:935
+#: ../gui/wxpython/psmap/instructions.py:1076
+#: ../gui/wxpython/psmap/instructions.py:1131
+#: ../gui/wxpython/psmap/instructions.py:1190
+#: ../gui/wxpython/psmap/instructions.py:1259
+#: ../gui/wxpython/psmap/instructions.py:1365
+#: ../gui/wxpython/psmap/instructions.py:1490
+#: ../gui/wxpython/psmap/instructions.py:1541
+#: ../gui/wxpython/psmap/instructions.py:1850
 #, python-format
 msgid "Failed to read instruction %s"
 msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:618
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:793
+#: ../gui/wxpython/psmap/instructions.py:625
 #, python-format
 msgid ""
 "Scale has changed, old value: %(old)s\n"
 "new value: %(new)s"
 msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:621
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:796
+#: ../gui/wxpython/psmap/instructions.py:628
 #, python-format
 msgid ""
 "Failed to read instruction %s.\n"
 "Use 1:25000 notation."
 msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:629
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:804
+#: ../gui/wxpython/psmap/instructions.py:636
 #, python-format
 msgid ""
 "Map frame position changed, old value: %(old1)s %(old2)s\n"
 "new value: %(new1)s %(new2)s"
 msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:637
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:812
+#: ../gui/wxpython/psmap/instructions.py:644
 #, python-format
 msgid ""
 "Map frame size changed, old value: %(old1)s %(old2)s\n"
 msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:684
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:859
+#: ../gui/wxpython/psmap/instructions.py:691
 #, python-format
 msgid ""
 "Failed to read instruction %(file)s.\n"
 "Unknown format %(for)s"
 msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:697
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:872
+#: ../gui/wxpython/psmap/instructions.py:704
 #, python-format
 msgid "Failed to read instruction %s."
 msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:811
-#: ../gui/wxpython/psmap/instructions.py:1693
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:967
+#: ../gui/wxpython/psmap/instructions.py:818
+#: ../gui/wxpython/psmap/instructions.py:1700
 #, python-format
 msgid ""
 "Characters on position %s are not supported by ISO-8859-1 (Latin 1) encoding "
 "which is required by module ps.map."
 msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:815
-#: ../gui/wxpython/psmap/instructions.py:1697
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:971
+#: ../gui/wxpython/psmap/instructions.py:822
+#: ../gui/wxpython/psmap/instructions.py:1704
 msgid ""
 "Not all characters are supported by ISO-8859-1 (Latin 1) encoding which is "
 "required by module ps.map."
 msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:931
+#: ../gui/wxpython/psmap/instructions.py:938
 #, python-format
 msgid "Failed to read instruction %(inst)s: file %(file)s not found."
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:197
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1822
+#: ../gui/wxpython/psmap/dialogs.py:198
 msgid "Units:"
 msgstr "Mērvienības:"
-#: ../gui/wxpython/psmap/dialogs.py:206
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1831
+#: ../gui/wxpython/psmap/dialogs.py:207
 msgid ""
 "Position of the top left corner\n"
 "from the top left edge of the paper"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:207
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1832
+#: ../gui/wxpython/psmap/dialogs.py:208
+#: ../gui/wxpython/animation/dialogs.py:889
 msgid "X:"
 msgstr "X:"
-#: ../gui/wxpython/psmap/dialogs.py:208
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1833
+#: ../gui/wxpython/psmap/dialogs.py:209
+#: ../gui/wxpython/animation/dialogs.py:891
 msgid "Y:"
 msgstr "Y:"
-#: ../gui/wxpython/psmap/dialogs.py:220
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1845
+#: ../gui/wxpython/psmap/dialogs.py:221
 msgid "Position is given:"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:221
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1846
-msgid "relatively to paper"
+#: ../gui/wxpython/psmap/dialogs.py:222
+msgid "relative to paper"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:222
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1847
+#: ../gui/wxpython/psmap/dialogs.py:223
 msgid "by map coordinates"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:238
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1863
+#: ../gui/wxpython/psmap/dialogs.py:237
 msgid ""
 "Position from the top left\n"
 "edge of the paper"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:290
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1915
+#: ../gui/wxpython/psmap/dialogs.py:291
 msgid "Font:"
 msgstr "Fonts:"
-#: ../gui/wxpython/psmap/dialogs.py:291 ../gui/wxpython/psmap/dialogs.py:3555
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1916
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5152
-#: ../gui/wxpython/gui_modules/preferences.py:2319
-#: ../gui/wxpython/gui_core/preferences.py:1516
+#: ../gui/wxpython/psmap/dialogs.py:292 ../gui/wxpython/psmap/dialogs.py:3555
+#: ../gui/wxpython/gui_core/preferences.py:1588
 msgid "Font size:"
 msgstr "Fonta izmērs:"
-#: ../gui/wxpython/psmap/dialogs.py:304
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1929
+#: ../gui/wxpython/psmap/dialogs.py:305
 msgid "Choose color:"
 msgstr "Izvēlieties krāsu:"
-#: ../gui/wxpython/psmap/dialogs.py:352
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1977
+#: ../gui/wxpython/psmap/dialogs.py:353
 msgid "Close dialog and apply changes"
 msgstr "Pielietot izmaiņas un aizvērt dialogu"
-#: ../gui/wxpython/psmap/dialogs.py:354
-#: ../gui/wxpython/gmodeler/preferences.py:452
-#: ../gui/wxpython/gui_modules/gmodeler.py:3819
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1979
-#: ../gui/wxpython/gui_modules/preferences.py:1111
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:672
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:1114
-#: ../gui/wxpython/gui_modules/vdigit.py:92
-#: ../gui/wxpython/gui_core/preferences.py:93
-#: ../gui/wxpython/wxplot/dialogs.py:673
-#: ../gui/wxpython/wxplot/dialogs.py:1115
-#: ../gui/wxpython/vdigit/preferences.py:58
+#: ../gui/wxpython/psmap/dialogs.py:355
+#: ../gui/wxpython/gmodeler/preferences.py:539
+#: ../gui/wxpython/gui_core/preferences.py:95
+#: ../gui/wxpython/wxplot/dialogs.py:693
+#: ../gui/wxpython/wxplot/dialogs.py:1138
+#: ../gui/wxpython/vdigit/preferences.py:62
 msgid "Close dialog and ignore changes"
 msgstr "Ignorēt izmaiņas un aizvērt dialogu"
-#: ../gui/wxpython/psmap/dialogs.py:358
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1983
-#: ../gui/wxpython/gui_modules/vdigit.py:929
-#: ../gui/wxpython/vdigit/dialogs.py:142
+#: ../gui/wxpython/psmap/dialogs.py:359
+#: ../gui/wxpython/web_services/dialogs.py:626
+#: ../gui/wxpython/vdigit/dialogs.py:144
 msgid "Apply changes"
 msgstr "Pielietot izmaiņas"
-#: ../gui/wxpython/psmap/dialogs.py:383
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2008
+#: ../gui/wxpython/psmap/dialogs.py:384 ../gui/wxpython/rlisetup/wizard.py:705
+#: ../gui/wxpython/rlisetup/wizard.py:858
 msgid "Units"
 msgstr "Mērvienības"
+#: ../gui/wxpython/animation/dialogs.py:761
 msgid "Format"
 msgstr "Formāts"
 msgid "Orientation"
 msgstr "Orientācija"
-#: ../gui/wxpython/psmap/dialogs.py:383 ../gui/wxpython/psmap/dialogs.py:2084
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3698
+#: ../gui/wxpython/psmap/dialogs.py:384 ../gui/wxpython/psmap/dialogs.py:2085
 msgid "Width"
 msgstr "Platums"
 msgid "Height"
 msgstr "Augstums"
-#: ../gui/wxpython/psmap/dialogs.py:384
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2009
+#: ../gui/wxpython/psmap/dialogs.py:385
 msgid "Left"
 msgstr "Pa kreisi"
 msgid "Right"
 msgstr "Pa labi"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2287
-#: ../gui/wxpython/location_wizard/dialogs.py:231
+#: ../gui/wxpython/location_wizard/dialogs.py:238
 msgid "Top"
 msgstr "Augšā"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2295
-#: ../gui/wxpython/location_wizard/dialogs.py:239
+#: ../gui/wxpython/location_wizard/dialogs.py:246
 msgid "Bottom"
 msgstr "Lejā"
-#: ../gui/wxpython/psmap/dialogs.py:439
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2064
+#: ../gui/wxpython/psmap/dialogs.py:440
 msgid "Literal is not allowed!"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:439 ../gui/wxpython/psmap/dialogs.py:1034
-#: ../gui/wxpython/psmap/dialogs.py:1056 ../gui/wxpython/psmap/dialogs.py:1106
-#: ../gui/wxpython/psmap/dialogs.py:3637
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2659
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2681
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2731
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5234
-#: ../gui/wxpython/wxplot/dialogs.py:477
+#: ../gui/wxpython/psmap/dialogs.py:440 ../gui/wxpython/psmap/dialogs.py:1035
+#: ../gui/wxpython/psmap/dialogs.py:1057 ../gui/wxpython/psmap/dialogs.py:1107
+#: ../gui/wxpython/psmap/dialogs.py:3637 ../gui/wxpython/wxplot/dialogs.py:496
+#: ../gui/wxpython/animation/dialogs.py:601
+#: ../gui/wxpython/animation/controller.py:272
 msgid "Invalid input"
 msgstr "Nederīga ievade"
-#: ../gui/wxpython/psmap/dialogs.py:448
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2073
+#: ../gui/wxpython/psmap/dialogs.py:449
 msgid "Page size"
 msgstr "Lapas izmērs"
-#: ../gui/wxpython/psmap/dialogs.py:450
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2075
+#: ../gui/wxpython/psmap/dialogs.py:451
 msgid "Margins"
 msgstr "Malas"
-#: ../gui/wxpython/psmap/dialogs.py:454
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2079
+#: ../gui/wxpython/psmap/dialogs.py:455
 msgid "Portrait"
 msgstr "Portrets"
 msgid "Landscape"
 msgstr "Ainava"
-#: ../gui/wxpython/psmap/dialogs.py:506 ../gui/wxpython/psmap/dialogs.py:527
-#: ../gui/wxpython/gui_modules/location_wizard.py:1703
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2131
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2152
-#: ../gui/wxpython/location_wizard/wizard.py:1713
+#: ../gui/wxpython/psmap/dialogs.py:507 ../gui/wxpython/psmap/dialogs.py:528
+#: ../gui/wxpython/location_wizard/wizard.py:1780
 msgid "custom"
 msgstr "pielāgots"
-#: ../gui/wxpython/psmap/dialogs.py:556
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2181
+#: ../gui/wxpython/psmap/dialogs.py:557
 msgid "Map settings"
 msgstr "Kartes iestatījumi"
-#: ../gui/wxpython/psmap/dialogs.py:562
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2187
+#: ../gui/wxpython/psmap/dialogs.py:563
 msgid "Map frame settings"
 msgstr "Kartes rāmja iestatījumi"
-#: ../gui/wxpython/psmap/dialogs.py:679
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2304
+#: ../gui/wxpython/psmap/dialogs.py:680
 msgid "Map frame options:"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:680
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2305
+#: ../gui/wxpython/psmap/dialogs.py:681
 msgid "fit frame to match selected map"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:681
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2306
+#: ../gui/wxpython/psmap/dialogs.py:682
 msgid "fit frame to match saved region"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:682
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2307
+#: ../gui/wxpython/psmap/dialogs.py:683
 msgid "fit frame to match current computational region"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:683
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2308
+#: ../gui/wxpython/psmap/dialogs.py:684
 msgid "fixed scale and map center"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:691 ../gui/wxpython/psmap/dialogs.py:859
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2316
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2484
+#: ../gui/wxpython/psmap/dialogs.py:692 ../gui/wxpython/psmap/dialogs.py:860
 msgid "Map selection"
 msgstr "Kartes izvēle"
-#: ../gui/wxpython/psmap/dialogs.py:695 ../gui/wxpython/gcp/manager.py:325
-#: ../gui/wxpython/gmodeler/frame.py:1284
-#: ../gui/wxpython/lmgr/layertree.py:824
-#: ../gui/wxpython/gui_modules/gmodeler.py:4052
-#: ../gui/wxpython/gui_modules/gdialogs.py:1278
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2320
-#: ../gui/wxpython/gui_modules/layertree.py:806
-#: ../gui/wxpython/gui_modules/gcpmanager.py:329
-#: ../gui/wxpython/gui_core/dialogs.py:1299
-#: ../gui/wxpython/gui_core/dialogs.py:1526
+#: ../gui/wxpython/psmap/dialogs.py:696 ../gui/wxpython/gcp/manager.py:329
+#: ../gui/wxpython/gmodeler/frame.py:1445
+#: ../gui/wxpython/gui_core/dialogs.py:1312
+#: ../gui/wxpython/gui_core/dialogs.py:1543
 msgid "raster"
 msgstr "rastrs"
-#: ../gui/wxpython/psmap/dialogs.py:696 ../gui/wxpython/gcp/manager.py:325
-#: ../gui/wxpython/gmodeler/frame.py:1285
-#: ../gui/wxpython/lmgr/layertree.py:845
-#: ../gui/wxpython/gui_modules/gmodeler.py:4053
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2321
-#: ../gui/wxpython/gui_modules/layertree.py:827
+#: ../gui/wxpython/psmap/dialogs.py:697 ../gui/wxpython/gcp/manager.py:329
+#: ../gui/wxpython/gmodeler/frame.py:1446
 msgid "vector"
 msgstr "vektori"
-#: ../gui/wxpython/psmap/dialogs.py:699 ../gui/wxpython/psmap/dialogs.py:1283
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2324
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2908
+#: ../gui/wxpython/psmap/dialogs.py:700 ../gui/wxpython/psmap/dialogs.py:1284
 msgid "Map:"
 msgstr "Karte:"
 msgid "Region:"
 msgstr "Reģions:"
-#: ../gui/wxpython/psmap/dialogs.py:718
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2343
+#: ../gui/wxpython/psmap/dialogs.py:719
 msgid "Map scale and center"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:723
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2348
+#: ../gui/wxpython/psmap/dialogs.py:724
 msgid "Center:"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:724
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2349
+#: ../gui/wxpython/psmap/dialogs.py:725
 msgid "E:"
 msgstr "E:"
-#: ../gui/wxpython/psmap/dialogs.py:725
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2350
+#: ../gui/wxpython/psmap/dialogs.py:726
 msgid "N:"
 msgstr "N:"
-#: ../gui/wxpython/psmap/dialogs.py:728 ../gui/wxpython/psmap/dialogs.py:4166
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2353
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5763
+#: ../gui/wxpython/psmap/dialogs.py:729 ../gui/wxpython/psmap/dialogs.py:4166
 msgid "Scale:"
 msgstr "Mērogs:"
-#: ../gui/wxpython/psmap/dialogs.py:729
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2354
+#: ../gui/wxpython/psmap/dialogs.py:730
 msgid "1 :"
 msgstr "1 :"
-#: ../gui/wxpython/psmap/dialogs.py:749
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2374
+#: ../gui/wxpython/psmap/dialogs.py:750
 msgid "Map max resolution (dpi):"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:762 ../gui/wxpython/psmap/dialogs.py:2653
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2387
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4250
+#: ../gui/wxpython/psmap/dialogs.py:763 ../gui/wxpython/psmap/dialogs.py:2654
 msgid "Border"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:766
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2391
+#: ../gui/wxpython/psmap/dialogs.py:767
 msgid "draw border around map frame"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:772
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2397
+#: ../gui/wxpython/psmap/dialogs.py:773
 msgid "border color:"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:773
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2398
+#: ../gui/wxpython/psmap/dialogs.py:774
 msgid "border width (pts):"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:867
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2492
+#: ../gui/wxpython/psmap/dialogs.py:868
 msgid ""
 "Region is set to match this map,\n"
 "raster or vector map must be added later"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:874
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2499
+#: ../gui/wxpython/psmap/dialogs.py:875
 msgid "Region selection"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1033
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2658
+#: ../gui/wxpython/psmap/dialogs.py:1034
 msgid "No map selected!"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1055
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2680
+#: ../gui/wxpython/psmap/dialogs.py:1056
 msgid "No region selected!"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1105
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2730
+#: ../gui/wxpython/psmap/dialogs.py:1106
 msgid "Invalid scale or map center!"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1143 ../gui/wxpython/nviz/tools.py:636
-#: ../gui/wxpython/nviz/mapwindow.py:1624
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2768
-#: ../gui/wxpython/gui_modules/nviz_tools.py:806
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1613
+#: ../gui/wxpython/psmap/dialogs.py:1144 ../gui/wxpython/menustrings.py:1736
+#: ../gui/wxpython/lmgr/layertree.py:763 ../gui/wxpython/nviz/tools.py:652
+#: ../gui/wxpython/nviz/mapwindow.py:1672
 msgid "Raster map"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1165
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2790
+#: ../gui/wxpython/psmap/dialogs.py:1166
 msgid "Choose raster map"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1169
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2794
+#: ../gui/wxpython/psmap/dialogs.py:1170
 msgid "no raster map"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1170
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2795
+#: ../gui/wxpython/psmap/dialogs.py:1171
 msgid "raster:"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1210 ../gui/wxpython/psmap/frame.py:548
-#: ../gui/wxpython/psmap/frame.py:571 ../gui/wxpython/gui_modules/psmap.py:549
-#: ../gui/wxpython/gui_modules/psmap.py:572
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2835
+#: ../gui/wxpython/psmap/dialogs.py:1211 ../gui/wxpython/psmap/frame.py:565
+#: ../gui/wxpython/psmap/frame.py:588
 msgid "Please, create map frame first."
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1270 ../gui/wxpython/gmodeler/model.py:669
-#: ../gui/wxpython/gui_modules/gmodeler.py:696
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2895
+#: ../gui/wxpython/psmap/dialogs.py:1271 ../gui/wxpython/gmodeler/model.py:742
 msgid "Vector maps"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1279
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2904
+#: ../gui/wxpython/psmap/dialogs.py:1280
 msgid "Add map"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1287 ../gui/wxpython/psmap/dialogs.py:1651
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2912
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3272
+#: ../gui/wxpython/psmap/dialogs.py:1288 ../gui/wxpython/psmap/dialogs.py:1652
 msgid "points"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1287 ../gui/wxpython/psmap/dialogs.py:1653
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3274
+#: ../gui/wxpython/psmap/dialogs.py:1288 ../gui/wxpython/psmap/dialogs.py:1654
 msgid "lines"
 msgstr ""
 msgid "areas"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1289
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2913
+#: ../gui/wxpython/psmap/dialogs.py:1290
 msgid "Data Type"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1292
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2915
-#: ../gui/wxpython/gui_modules/dbm.py:915
+#: ../gui/wxpython/psmap/dialogs.py:1293 ../gui/wxpython/dbmgr/base.py:2064
+#: ../gui/wxpython/animation/dialogs.py:627
 msgid "Add"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1304
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2927
+#: ../gui/wxpython/psmap/dialogs.py:1305
 msgid "Manage vector maps"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1312
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2935
+#: ../gui/wxpython/psmap/dialogs.py:1311
 msgid "The topmost vector map overlaps the others"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1314 ../gui/wxpython/psmap/dialogs.py:2636
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2937
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4233
+#: ../gui/wxpython/psmap/dialogs.py:1313 ../gui/wxpython/psmap/dialogs.py:2635
+#: ../gui/wxpython/web_services/widgets.py:223
 msgid "Up"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1315 ../gui/wxpython/psmap/dialogs.py:2637
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2938
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4234
+#: ../gui/wxpython/psmap/dialogs.py:1314 ../gui/wxpython/psmap/dialogs.py:2636
+#: ../gui/wxpython/web_services/widgets.py:224
 msgid "Down"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1316 ../gui/wxpython/menustrings.py:171
-#: ../gui/wxpython/nviz/tools.py:1078 ../gui/wxpython/nviz/tools.py:1942
-#: ../gui/wxpython/nviz/tools.py:1990
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2939
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1248
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2104
+#: ../gui/wxpython/psmap/dialogs.py:1315 ../gui/wxpython/menustrings.py:176
+#: ../gui/wxpython/menustrings.py:1752 ../gui/wxpython/nviz/tools.py:1098
+#: ../gui/wxpython/nviz/tools.py:1976 ../gui/wxpython/nviz/tools.py:2024
 msgid "Delete"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1317
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2940
+#: ../gui/wxpython/psmap/dialogs.py:1316
 msgid "Properties..."
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1517
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3139
+#: ../gui/wxpython/psmap/dialogs.py:1518
 msgid "Raster map settings"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1554
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3176
+#: ../gui/wxpython/psmap/dialogs.py:1555
 msgid "Vector maps settings"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1589
+#: ../gui/wxpython/psmap/dialogs.py:1590
 #, python-format
 msgid "%s properties"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1640
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3261
+#: ../gui/wxpython/psmap/dialogs.py:1641
 msgid "Data selection"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1647
-#: ../gui/wxpython/gui_modules/gdialogs.py:1505
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3268
-#: ../gui/wxpython/gui_core/dialogs.py:1595
+#: ../gui/wxpython/psmap/dialogs.py:1648
+#: ../gui/wxpython/gui_core/dialogs.py:1617
 msgid "Feature type"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1651
+#: ../gui/wxpython/psmap/dialogs.py:1652
 msgid "centroids"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1653
+#: ../gui/wxpython/psmap/dialogs.py:1654
 msgid "boundaries"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1669
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3290
+#: ../gui/wxpython/psmap/dialogs.py:1670
 msgid "Layer selection"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1675
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3296
+#: ../gui/wxpython/psmap/dialogs.py:1676
 msgid "Database connection is not defined in DB file."
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1676
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3297
+#: ../gui/wxpython/psmap/dialogs.py:1677
 msgid "Select layer:"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1699
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3320
+#: ../gui/wxpython/psmap/dialogs.py:1700
 msgid "list of categories (e.g. 1,3,5-7)"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1726 ../gui/wxpython/menustrings.py:322
-#: ../gui/wxpython/nviz/tools.py:774 ../gui/wxpython/nviz/tools.py:2340
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3347
-#: ../gui/wxpython/gui_modules/nviz_tools.py:944
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2492
+#: ../gui/wxpython/psmap/dialogs.py:1727 ../gui/wxpython/menustrings.py:325
+#: ../gui/wxpython/menustrings.py:990 ../gui/wxpython/nviz/tools.py:789
+#: ../gui/wxpython/nviz/tools.py:2400
 msgid "Mask"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1729
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3350
+#: ../gui/wxpython/psmap/dialogs.py:1730
 msgid "Use current mask"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1746 ../gui/wxpython/psmap/dialogs.py:1845
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3367
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3466
+#: ../gui/wxpython/psmap/dialogs.py:1747 ../gui/wxpython/psmap/dialogs.py:1846
 msgid "Colors"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1751 ../gui/wxpython/psmap/dialogs.py:1850
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3372
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3471
+#: ../gui/wxpython/psmap/dialogs.py:1752 ../gui/wxpython/psmap/dialogs.py:1851
 msgid "Outline"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1755 ../gui/wxpython/psmap/dialogs.py:1859
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3376
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3480
+#: ../gui/wxpython/psmap/dialogs.py:1756 ../gui/wxpython/psmap/dialogs.py:1860
 msgid "draw outline"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1758 ../gui/wxpython/psmap/dialogs.py:1863
+#: ../gui/wxpython/psmap/dialogs.py:1759 ../gui/wxpython/psmap/dialogs.py:1864
 #: ../gui/wxpython/psmap/dialogs.py:3750 ../gui/wxpython/psmap/dialogs.py:3755
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3379
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3484
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5347
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5352
 msgid "Width (pts):"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1776 ../gui/wxpython/psmap/dialogs.py:1879
-#: ../gui/wxpython/gcp/manager.py:2447 ../gui/wxpython/nviz/tools.py:1127
-#: ../gui/wxpython/nviz/tools.py:1757 ../gui/wxpython/nviz/tools.py:1876
-#: ../gui/wxpython/nviz/preferences.py:333
-#: ../gui/wxpython/nviz/preferences.py:490
-#: ../gui/wxpython/nviz/preferences.py:544
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3397
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3500
-#: ../gui/wxpython/gui_modules/preferences.py:1874
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:331
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:488
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:542
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1297
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1919
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2038
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2450
-#: ../gui/wxpython/gui_core/preferences.py:1048
+#: ../gui/wxpython/psmap/dialogs.py:1777 ../gui/wxpython/psmap/dialogs.py:1880
+#: ../gui/wxpython/gcp/manager.py:2472 ../gui/wxpython/nviz/tools.py:1147
+#: ../gui/wxpython/nviz/tools.py:1789 ../gui/wxpython/nviz/tools.py:1910
+#: ../gui/wxpython/nviz/preferences.py:334
+#: ../gui/wxpython/nviz/preferences.py:491
+#: ../gui/wxpython/nviz/preferences.py:545
+#: ../gui/wxpython/mapswipe/dialogs.py:242
+#: ../gui/wxpython/gui_core/preferences.py:1070
 msgid "Color:"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1795 ../gui/wxpython/psmap/dialogs.py:1899
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3416
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3520
+#: ../gui/wxpython/psmap/dialogs.py:1796 ../gui/wxpython/psmap/dialogs.py:1900
+#: ../gui/wxpython/wxplot/dialogs.py:933 ../gui/wxpython/wxplot/dialogs.py:983
 msgid "Fill"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1799
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3420
+#: ../gui/wxpython/psmap/dialogs.py:1800
 msgid "fill color"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1802 ../gui/wxpython/psmap/dialogs.py:1905
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3423
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3526
+#: ../gui/wxpython/psmap/dialogs.py:1803 ../gui/wxpython/psmap/dialogs.py:1906
 msgid "choose color:"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1814 ../gui/wxpython/psmap/dialogs.py:1918
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3435
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3539
+#: ../gui/wxpython/psmap/dialogs.py:1815 ../gui/wxpython/psmap/dialogs.py:1919
 msgid "color from map table column:"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1861
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3482
+#: ../gui/wxpython/psmap/dialogs.py:1862
 msgid "No effect for fill color from table column"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1903
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3524
+#: ../gui/wxpython/psmap/dialogs.py:1904
 msgid "Color of lines:"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1948 ../gui/wxpython/psmap/dialogs.py:2079
-#: ../gui/wxpython/psmap/dialogs.py:2148
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3569
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3693
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3762
+#: ../gui/wxpython/psmap/dialogs.py:1949 ../gui/wxpython/psmap/dialogs.py:2080
+#: ../gui/wxpython/psmap/dialogs.py:2149
 msgid "Size and style"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1953 ../gui/wxpython/gcp/manager.py:2406
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3574
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2409
-#: ../gui/wxpython/gui_modules/vdigit.py:114
-#: ../gui/wxpython/vdigit/preferences.py:80
+#: ../gui/wxpython/psmap/dialogs.py:1954 ../gui/wxpython/gcp/manager.py:2432
+#: ../gui/wxpython/vdigit/preferences.py:84
 msgid "Symbology"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1958 ../gui/wxpython/nviz/tools.py:1396
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3579
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1566
+#: ../gui/wxpython/psmap/dialogs.py:1958 ../gui/wxpython/nviz/tools.py:1419
 msgid "symbol:"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:1967
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3585
 msgid "eps file:"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:1971 ../gui/wxpython/psmap/dialogs.py:2160
-#: ../gui/wxpython/psmap/dialogs.py:4121 ../gui/wxpython/nviz/tools.py:467
-#: ../gui/wxpython/gui_modules/gselect.py:882
-#: ../gui/wxpython/gui_modules/gselect.py:1170
-#: ../gui/wxpython/gui_modules/gselect.py:1179
-#: ../gui/wxpython/gui_modules/gselect.py:1188
-#: ../gui/wxpython/gui_modules/gselect.py:1459
-#: ../gui/wxpython/gui_modules/gselect.py:1643
-#: ../gui/wxpython/gui_modules/location_wizard.py:134
-#: ../gui/wxpython/gui_modules/location_wizard.py:1138
-#: ../gui/wxpython/gui_modules/location_wizard.py:1212
-#: ../gui/wxpython/gui_modules/location_wizard.py:1295
-#: ../gui/wxpython/gui_modules/gdialogs.py:1910
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3589
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3774
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5718
-#: ../gui/wxpython/gui_modules/menuform.py:1367
-#: ../gui/wxpython/gui_modules/menuform.py:1422
-#: ../gui/wxpython/gui_modules/nviz_tools.py:634
-#: ../gui/wxpython/location_wizard/wizard.py:98
-#: ../gui/wxpython/location_wizard/wizard.py:1148
-#: ../gui/wxpython/location_wizard/wizard.py:1222
-#: ../gui/wxpython/location_wizard/wizard.py:1305
-#: ../gui/wxpython/gui_core/gselect.py:881
-#: ../gui/wxpython/gui_core/gselect.py:1191
-#: ../gui/wxpython/gui_core/gselect.py:1200
-#: ../gui/wxpython/gui_core/gselect.py:1209
-#: ../gui/wxpython/gui_core/gselect.py:1527
-#: ../gui/wxpython/gui_core/gselect.py:1725
-#: ../gui/wxpython/gui_core/forms.py:1351
-#: ../gui/wxpython/gui_core/forms.py:1407
-#: ../gui/wxpython/gui_core/dialogs.py:2014
+#: ../gui/wxpython/psmap/dialogs.py:4121 ../gui/wxpython/nviz/tools.py:483
+#: ../gui/wxpython/location_wizard/wizard.py:102
+#: ../gui/wxpython/location_wizard/wizard.py:1168
+#: ../gui/wxpython/location_wizard/wizard.py:1242
+#: ../gui/wxpython/location_wizard/wizard.py:1328
+#: ../gui/wxpython/gui_core/gselect.py:1071
+#: ../gui/wxpython/gui_core/gselect.py:1363
+#: ../gui/wxpython/gui_core/gselect.py:1376
+#: ../gui/wxpython/gui_core/gselect.py:1415
+#: ../gui/wxpython/gui_core/gselect.py:1438
+#: ../gui/wxpython/gui_core/forms.py:1485
+#: ../gui/wxpython/gui_core/forms.py:1541
+#: ../gui/wxpython/gui_core/dialogs.py:2027
+#: ../gui/wxpython/animation/dialogs.py:400
+#: ../gui/wxpython/animation/dialogs.py:860
+#: ../gui/wxpython/animation/dialogs.py:931
+#: ../gui/wxpython/animation/dialogs.py:954
+#: ../gui/wxpython/animation/dialogs.py:971
+#: ../gui/wxpython/animation/dialogs.py:994
 msgid "Browse"
 msgstr ""
 msgid "Type filename or click browse to choose file"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:1972 ../gui/wxpython/psmap/dialogs.py:2161
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3590
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3775
 msgid "Choose a file"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1995 ../gui/wxpython/psmap/dialogs.py:2706
-#: ../gui/wxpython/psmap/dialogs.py:3471
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3609
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4303
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5068
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:899
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:950
-#: ../gui/wxpython/wxplot/dialogs.py:900 ../gui/wxpython/wxplot/dialogs.py:951
+#: ../gui/wxpython/psmap/dialogs.py:1996 ../gui/wxpython/psmap/dialogs.py:2707
+#: ../gui/wxpython/psmap/dialogs.py:3471 ../gui/wxpython/wxplot/dialogs.py:924
+#: ../gui/wxpython/wxplot/dialogs.py:974
 msgid "Size"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2000 ../gui/wxpython/nviz/tools.py:1346
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3614
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1516
+#: ../gui/wxpython/psmap/dialogs.py:2000 ../gui/wxpython/nviz/tools.py:1362
 msgid "size:"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:2002
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3616
 msgid "size from map table column:"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:2004
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3618
 msgid "scale:"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2036
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3650
+#: ../gui/wxpython/psmap/dialogs.py:2037
 msgid "Rotation"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:2042
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3656
 msgid "rotate symbols:"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:2043
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3657
 msgid "counterclockwise in degrees:"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:2045
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3659
 msgid "from map table column:"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2088
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3702
+#: ../gui/wxpython/psmap/dialogs.py:2089
 msgid "Set width (pts):"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2097
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3711
+#: ../gui/wxpython/psmap/dialogs.py:2098
 msgid "multiply width by category value"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2114 ../gui/wxpython/psmap/dialogs.py:4893
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3728
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:864
-#: ../gui/wxpython/wxplot/dialogs.py:865
+#: ../gui/wxpython/psmap/dialogs.py:2115 ../gui/wxpython/psmap/dialogs.py:4897
+#: ../gui/wxpython/wxplot/dialogs.py:889
 msgid "Line style"
 msgstr "Līnijas stils"
-#: ../gui/wxpython/psmap/dialogs.py:2118
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3732
+#: ../gui/wxpython/psmap/dialogs.py:2119
 msgid "Choose line style:"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2128
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3742
+#: ../gui/wxpython/psmap/dialogs.py:2129
 msgid "Choose linecap:"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2153
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3767
+#: ../gui/wxpython/psmap/dialogs.py:2154
 msgid "Pattern"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:2158
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3772
 msgid "use pattern:"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:2159
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3773
 msgid "Choose pattern file:"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:2163
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3777
 msgid "pattern line width (pts):"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:2165
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3779
 msgid "pattern scale factor:"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2481
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4078
+#: ../gui/wxpython/psmap/dialogs.py:2482
 msgid "Raster legend"
 msgstr "Rastra leģenda"
-#: ../gui/wxpython/psmap/dialogs.py:2485
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4082
+#: ../gui/wxpython/psmap/dialogs.py:2486
+#: ../gui/wxpython/animation/dialogs.py:371
 msgid "Show raster legend"
 msgstr "Rādīt rastra leģendu"
-#: ../gui/wxpython/psmap/dialogs.py:2491
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4088
+#: ../gui/wxpython/psmap/dialogs.py:2492
 msgid "Source raster"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2496
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4093
+#: ../gui/wxpython/psmap/dialogs.py:2497
 msgid "current raster"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2497
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4094
+#: ../gui/wxpython/psmap/dialogs.py:2498
 msgid "select raster"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2504 ../gui/wxpython/psmap/dialogs.py:3190
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4101
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4787
+#: ../gui/wxpython/psmap/dialogs.py:2505 ../gui/wxpython/psmap/dialogs.py:3190
 #, python-format
 msgid "%(rast)s: type %(type)s"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2523
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4120
+#: ../gui/wxpython/psmap/dialogs.py:2524
 msgid "Type of legend"
 msgstr "Leģendas tips"
-#: ../gui/wxpython/psmap/dialogs.py:2527
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4124
+#: ../gui/wxpython/psmap/dialogs.py:2528
 msgid "discrete legend (categorical maps)"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2529
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4126
+#: ../gui/wxpython/psmap/dialogs.py:2530
 msgid "continuous color gradient legend (floating point map)"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2540
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4137
+#: ../gui/wxpython/psmap/dialogs.py:2541
 msgid "Advanced legend settings"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2544
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4141
+#: ../gui/wxpython/psmap/dialogs.py:2545
 msgid "draw \"no data\" box"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2550
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4147
+#: ../gui/wxpython/psmap/dialogs.py:2551
 msgid "draw ticks across color table"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2561
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4158
-#: ../gui/wxpython/gui_modules/colorrules.py:831
-#: ../gui/wxpython/modules/colorrules.py:838
-#: ../gui/wxpython/modules/colorrules.py:1455
-#: ../gui/wxpython/modules/colorrules.py:1458
+#: ../gui/wxpython/psmap/dialogs.py:2562
+#: ../gui/wxpython/modules/colorrules.py:875
+#: ../gui/wxpython/modules/colorrules.py:1497
+#: ../gui/wxpython/modules/colorrules.py:1500
 msgid "range"
 msgstr "diapazons"
-#: ../gui/wxpython/psmap/dialogs.py:2598
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4195
+#: ../gui/wxpython/psmap/dialogs.py:2599
 msgid "Vector legend"
 msgstr "Vektoru leģenda"
-#: ../gui/wxpython/psmap/dialogs.py:2602
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4199
+#: ../gui/wxpython/psmap/dialogs.py:2603
 msgid "Show vector legend"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2608
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4205
+#: ../gui/wxpython/psmap/dialogs.py:2609
 msgid "Source vector maps"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2614
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4211
+#: ../gui/wxpython/psmap/dialogs.py:2613
 msgid "Choose vector maps and their order in legend"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2618 ../gui/wxpython/nviz/tools.py:1157
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4215
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1327
+#: ../gui/wxpython/psmap/dialogs.py:2617 ../gui/wxpython/menustrings.py:1738
+#: ../gui/wxpython/lmgr/layertree.py:766 ../gui/wxpython/nviz/tools.py:1177
 msgid "Vector map"
 msgstr "Vektoru karte"
-#: ../gui/wxpython/psmap/dialogs.py:2619
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4216
+#: ../gui/wxpython/psmap/dialogs.py:2618
+#: ../gui/wxpython/gmodeler/dialogs.py:436
+#: ../gui/wxpython/gmodeler/dialogs.py:539
+#: ../gui/wxpython/gmodeler/frame.py:1579
 msgid "Label"
 msgstr "Birka"
-#: ../gui/wxpython/psmap/dialogs.py:2638 ../gui/wxpython/psmap/dialogs.py:2944
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4235
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4541
+#: ../gui/wxpython/psmap/dialogs.py:2637 ../gui/wxpython/psmap/dialogs.py:2945
 msgid "Edit label"
 msgstr "Rediģēt birku"
-#: ../gui/wxpython/psmap/dialogs.py:2657
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4254
+#: ../gui/wxpython/psmap/dialogs.py:2658
 msgid "draw border around legend"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2694
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4291
+#: ../gui/wxpython/psmap/dialogs.py:2695
 msgid "Size and position"
 msgstr "Novietojums un izmērs"
-#: ../gui/wxpython/psmap/dialogs.py:2704 ../gui/wxpython/psmap/dialogs.py:3246
+#: ../gui/wxpython/psmap/dialogs.py:2705 ../gui/wxpython/psmap/dialogs.py:3246
 #: ../gui/wxpython/psmap/dialogs.py:3441 ../gui/wxpython/psmap/dialogs.py:3815
 #: ../gui/wxpython/psmap/dialogs.py:3819 ../gui/wxpython/psmap/dialogs.py:4221
-#: ../gui/wxpython/psmap/dialogs.py:4226 ../gui/wxpython/psmap/dialogs.py:4675
-#: ../gui/wxpython/psmap/dialogs.py:4680 ../gui/wxpython/nviz/tools.py:841
-#: ../gui/wxpython/nviz/tools.py:1645
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4301
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4843
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5038
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5412
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5416
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5818
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5823
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1011
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1807
+#: ../gui/wxpython/psmap/dialogs.py:4226 ../gui/wxpython/psmap/dialogs.py:4679
+#: ../gui/wxpython/psmap/dialogs.py:4684 ../gui/wxpython/nviz/tools.py:857
+#: ../gui/wxpython/nviz/tools.py:1676
 msgid "Position"
 msgstr "Novietojums"
-#: ../gui/wxpython/psmap/dialogs.py:2722
-#: ../gui/wxpython/gmodeler/preferences.py:158
-#: ../gui/wxpython/gmodeler/preferences.py:277
-#: ../gui/wxpython/gmodeler/preferences.py:362
-#: ../gui/wxpython/nviz/preferences.py:475
-#: ../gui/wxpython/gui_modules/gmodeler.py:3525
-#: ../gui/wxpython/gui_modules/gmodeler.py:3644
-#: ../gui/wxpython/gui_modules/gmodeler.py:3729
-#: ../gui/wxpython/gui_modules/gdialogs.py:2308
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4319
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:473
-#: ../gui/wxpython/gui_core/dialogs.py:2381
+#: ../gui/wxpython/psmap/dialogs.py:2723
+#: ../gui/wxpython/gmodeler/preferences.py:159
+#: ../gui/wxpython/gmodeler/preferences.py:278
+#: ../gui/wxpython/gmodeler/preferences.py:363
+#: ../gui/wxpython/gmodeler/preferences.py:448
+#: ../gui/wxpython/nviz/preferences.py:476
+#: ../gui/wxpython/gui_core/dialogs.py:2347
 msgid "Width:"
 msgstr "Platums:"
-#: ../gui/wxpython/psmap/dialogs.py:2728
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4325
+#: ../gui/wxpython/psmap/dialogs.py:2729
 msgid "Leave the edit field empty, to use default values."
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2734 ../gui/wxpython/psmap/dialogs.py:2872
-#: ../gui/wxpython/psmap/dialogs.py:3477
-#: ../gui/wxpython/gmodeler/preferences.py:176
-#: ../gui/wxpython/gmodeler/preferences.py:295
-#: ../gui/wxpython/gmodeler/preferences.py:380
-#: ../gui/wxpython/nviz/tools.py:272 ../gui/wxpython/nviz/tools.py:1021
-#: ../gui/wxpython/nviz/tools.py:1735
-#: ../gui/wxpython/gui_modules/gmodeler.py:3543
-#: ../gui/wxpython/gui_modules/gmodeler.py:3662
-#: ../gui/wxpython/gui_modules/gmodeler.py:3747
-#: ../gui/wxpython/gui_modules/gdialogs.py:2312
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4331
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4469
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5074
-#: ../gui/wxpython/gui_modules/nviz_tools.py:439
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1191
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1897
-#: ../gui/wxpython/gui_core/dialogs.py:2385
+#: ../gui/wxpython/psmap/dialogs.py:2735 ../gui/wxpython/psmap/dialogs.py:2873
+#: ../gui/wxpython/psmap/dialogs.py:3476
+#: ../gui/wxpython/gmodeler/preferences.py:177
+#: ../gui/wxpython/gmodeler/preferences.py:296
+#: ../gui/wxpython/gmodeler/preferences.py:381
+#: ../gui/wxpython/gmodeler/preferences.py:466
+#: ../gui/wxpython/nviz/tools.py:284 ../gui/wxpython/nviz/tools.py:1040
+#: ../gui/wxpython/nviz/tools.py:1767 ../gui/wxpython/gui_core/dialogs.py:2351
 msgid "Height:"
 msgstr "Augstums:"
-#: ../gui/wxpython/psmap/dialogs.py:2750
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4347
+#: ../gui/wxpython/psmap/dialogs.py:2751
 msgid ""
 "Width of the color symbol (for lines)\n"
 "in front of the legend text"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2756 ../gui/wxpython/psmap/dialogs.py:2861
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4353
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4458
+#: ../gui/wxpython/psmap/dialogs.py:2757 ../gui/wxpython/psmap/dialogs.py:2862
 msgid "Columns:"
 msgstr "Kolonas:"
-#: ../gui/wxpython/psmap/dialogs.py:2760
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4357
+#: ../gui/wxpython/psmap/dialogs.py:2761
 msgid "column span:"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2762
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4359
+#: ../gui/wxpython/psmap/dialogs.py:2763
 msgid ""
 "Column separation distance between the left edges\n"
 "of two columns in a multicolumn legend"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2787 ../gui/wxpython/psmap/dialogs.py:3265
+#: ../gui/wxpython/psmap/dialogs.py:2788 ../gui/wxpython/psmap/dialogs.py:3265
 #: ../gui/wxpython/psmap/dialogs.py:3721
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4384
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4862
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5318
-#: ../gui/wxpython/gui_modules/preferences.py:1407
-#: ../gui/wxpython/gui_modules/preferences.py:1550
-#: ../gui/wxpython/gui_modules/preferences.py:2270
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:599
-#: ../gui/wxpython/gui_core/preferences.py:409
-#: ../gui/wxpython/gui_core/preferences.py:585
-#: ../gui/wxpython/gui_core/preferences.py:1467
-#: ../gui/wxpython/wxplot/dialogs.py:600
+#: ../gui/wxpython/gui_core/preferences.py:380
+#: ../gui/wxpython/gui_core/preferences.py:576
+#: ../gui/wxpython/gui_core/preferences.py:1540
+#: ../gui/wxpython/wxplot/dialogs.py:620
 msgid "Font settings"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2944
+#: ../gui/wxpython/psmap/dialogs.py:2945
 msgid "Edit legend label:"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2985
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4582
+#: ../gui/wxpython/psmap/dialogs.py:2986
 msgid "No raster map selected!"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2986
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4583
+#: ../gui/wxpython/psmap/dialogs.py:2987
 msgid "No raster"
 msgstr ""
@@ -1265,454 +991,369 @@
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:3283
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4880
 msgid "Color settings"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:3289
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4886
 msgid "use border color:"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:3290
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4887
 msgid "use background color:"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:3430
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5027
 msgid ""
 "Units of current projection are not supported,\n"
 " meters will be used!"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:3431
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5028
 msgid "Unsupported units"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3476
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5073
+#: ../gui/wxpython/psmap/dialogs.py:3475
 msgid "Length:"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3480
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5077
+#: ../gui/wxpython/psmap/dialogs.py:3479
 msgid "Scalebar length is given in map units"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3483
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5080
+#: ../gui/wxpython/psmap/dialogs.py:3482
 msgid "Scalebar height is real height on paper"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3485
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5082
+#: ../gui/wxpython/psmap/dialogs.py:3484
 msgid "default"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3524
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5121
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:908
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:959
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:1007
-#: ../gui/wxpython/wxplot/dialogs.py:909 ../gui/wxpython/wxplot/dialogs.py:960
-#: ../gui/wxpython/wxplot/dialogs.py:1008
+#: ../gui/wxpython/psmap/dialogs.py:3524 ../gui/wxpython/wxplot/dialogs.py:948
+#: ../gui/wxpython/wxplot/dialogs.py:998
 msgid "Style"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:3529
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5126
 msgid "Type:"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:3545
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5142
 msgid "Number of segments:"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:3549
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5146
 msgid "Label every "
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:3550
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5147
 msgid "segments"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:3559
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5156
 msgid "transparent text background"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:3636
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5233
 msgid "Length of scale bar is not defined"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:3713
-#: ../gui/wxpython/gui_modules/gdialogs.py:794
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5310
-#: ../gui/wxpython/gui_core/dialogs.py:798
+#: ../gui/wxpython/mapwin/decorations.py:331
 msgid "Enter text:"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:3739
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5336
 msgid "Text effects"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:3744
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5341
 msgid "text background"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:3747
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5344
 msgid "highlight"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:3752
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5349
 msgid "text border"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:3829
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5426
 msgid "Offset"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:3832
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5429
 msgid "horizontal (pts):"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:3833
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5430
 msgid "vertical (pts):"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:3846
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5443
 msgid " Reference point"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:3872
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5469
 msgid "Text rotation"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:3875
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5472
 msgid "rotate text (counterclockwise)"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:3951
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5548
 msgid "No text entered!"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3951 ../gui/wxpython/gmodeler/frame.py:881
-#: ../gui/wxpython/lmgr/layertree.py:548
-#: ../gui/wxpython/gui_modules/workspace.py:1367
-#: ../gui/wxpython/gui_modules/gcmd.py:65
-#: ../gui/wxpython/gui_modules/gmodeler.py:1623
-#: ../gui/wxpython/gui_modules/location_wizard.py:561
-#: ../gui/wxpython/gui_modules/location_wizard.py:746
-#: ../gui/wxpython/gui_modules/location_wizard.py:1468
-#: ../gui/wxpython/gui_modules/location_wizard.py:1526
-#: ../gui/wxpython/gui_modules/location_wizard.py:2170
-#: ../gui/wxpython/gui_modules/location_wizard.py:2187
-#: ../gui/wxpython/gui_modules/location_wizard.py:2494
-#: ../gui/wxpython/gui_modules/dbm.py:161
-#: ../gui/wxpython/gui_modules/dbm.py:1408
-#: ../gui/wxpython/gui_modules/dbm.py:1517
-#: ../gui/wxpython/gui_modules/dbm.py:1603
-#: ../gui/wxpython/gui_modules/dbm.py:1615
-#: ../gui/wxpython/gui_modules/dbm.py:1630
-#: ../gui/wxpython/gui_modules/dbm.py:1947
-#: ../gui/wxpython/gui_modules/dbm.py:2767
-#: ../gui/wxpython/gui_modules/dbm.py:2865
-#: ../gui/wxpython/gui_modules/dbm.py:2872
-#: ../gui/wxpython/gui_modules/dbm.py:2912
-#: ../gui/wxpython/gui_modules/preferences.py:1216
-#: ../gui/wxpython/gui_modules/preferences.py:2139
-#: ../gui/wxpython/gui_modules/preferences.py:2168
-#: ../gui/wxpython/gui_modules/preferences.py:2177
-#: ../gui/wxpython/gui_modules/preferences.py:2187
-#: ../gui/wxpython/gui_modules/layertree.py:514
-#: ../gui/wxpython/gui_modules/layertree.py:550
-#: ../gui/wxpython/gui_modules/wxplot.py:1042
-#: ../gui/wxpython/gui_modules/mapdisp_window.py:1824
-#: ../gui/wxpython/gui_modules/vdigit.py:1028
-#: ../gui/wxpython/gui_modules/vdigit.py:1220
-#: ../gui/wxpython/location_wizard/wizard.py:525
-#: ../gui/wxpython/location_wizard/wizard.py:710
-#: ../gui/wxpython/location_wizard/wizard.py:1478
-#: ../gui/wxpython/location_wizard/wizard.py:1536
-#: ../gui/wxpython/location_wizard/dialogs.py:114
-#: ../gui/wxpython/location_wizard/dialogs.py:131
-#: ../gui/wxpython/location_wizard/dialogs.py:438
+#: ../gui/wxpython/psmap/dialogs.py:3951 ../gui/wxpython/gmodeler/frame.py:952
+#: ../gui/wxpython/lmgr/layertree.py:722
+#: ../gui/wxpython/location_wizard/wizard.py:539
+#: ../gui/wxpython/location_wizard/wizard.py:723
+#: ../gui/wxpython/location_wizard/wizard.py:1501
+#: ../gui/wxpython/location_wizard/wizard.py:1567
+#: ../gui/wxpython/location_wizard/dialogs.py:120
+#: ../gui/wxpython/location_wizard/dialogs.py:137
+#: ../gui/wxpython/location_wizard/dialogs.py:445
 #: ../gui/wxpython/gui_core/preferences.py:216
-#: ../gui/wxpython/gui_core/preferences.py:1314
-#: ../gui/wxpython/gui_core/preferences.py:1343
-#: ../gui/wxpython/gui_core/preferences.py:1352
-#: ../gui/wxpython/gui_core/preferences.py:1361
-#: ../gui/wxpython/wxplot/profile.py:346
-#: ../gui/wxpython/core/workspace.py:1038 ../gui/wxpython/core/gcmd.py:109
-#: ../gui/wxpython/mapdisp/mapwindow.py:1716 ../gui/wxpython/gis_set.py:207
-#: ../gui/wxpython/gis_set.py:448 ../gui/wxpython/gis_set.py:484
-#: ../gui/wxpython/gis_set.py:550 ../gui/wxpython/vdigit/dialogs.py:241
-#: ../gui/wxpython/vdigit/dialogs.py:433
-#: ../gui/wxpython/scripts/r.li.setup.py:337
+#: ../gui/wxpython/gui_core/preferences.py:1387
+#: ../gui/wxpython/gui_core/preferences.py:1416
+#: ../gui/wxpython/gui_core/preferences.py:1425
+#: ../gui/wxpython/gui_core/preferences.py:1434
+#: ../gui/wxpython/core/workspace.py:1313 ../gui/wxpython/core/gcmd.py:115
+#: ../gui/wxpython/gis_set.py:228 ../gui/wxpython/gis_set.py:596
+#: ../gui/wxpython/gis_set.py:633 ../gui/wxpython/vdigit/dialogs.py:243
+#: ../gui/wxpython/vdigit/dialogs.py:435
 msgid "Error"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4119 ../gui/wxpython/nviz/tools.py:465
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5716
-#: ../gui/wxpython/gui_modules/nviz_tools.py:632
+#: ../gui/wxpython/psmap/dialogs.py:4119 ../gui/wxpython/nviz/tools.py:481
 msgid "Choose a directory:"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:4120
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5717
 msgid "Choose a directory with images"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:4152
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5749
 msgid "Note: only EPS format supported"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:4161
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5758
 msgid "Scale And Rotation"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4192 ../gui/wxpython/psmap/dialogs.py:4650
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5789
+#: ../gui/wxpython/psmap/dialogs.py:4192 ../gui/wxpython/psmap/dialogs.py:4654
 msgid "Rotation angle (deg):"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4201 ../gui/wxpython/psmap/dialogs.py:4659
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5798
+#: ../gui/wxpython/psmap/dialogs.py:4201 ../gui/wxpython/psmap/dialogs.py:4663
 msgid "Counterclockwise rotation in degrees"
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:4299
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5896
 msgid ""
 "PIL\n"
 "missing"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4316
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5913
+#: ../gui/wxpython/psmap/dialogs.py:4319
 #, python-format
 msgid "Unable to read file %s"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4374
+#: ../gui/wxpython/psmap/dialogs.py:4378
 #, python-format
 msgid "size: %(width)s x %(height)s pts"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4396
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5991
+#: ../gui/wxpython/psmap/dialogs.py:4400
 msgid "No image selected."
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4493
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:6088
+#: ../gui/wxpython/psmap/dialogs.py:4497
 msgid "North Arrow settings"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4504
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:6099
+#: ../gui/wxpython/psmap/dialogs.py:4508
 msgid "Compute convergence"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4560
+#: ../gui/wxpython/psmap/dialogs.py:4564
 msgid "Symbol"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4566
+#: ../gui/wxpython/psmap/dialogs.py:4569
 msgid "Select symbol:"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4580
+#: ../gui/wxpython/psmap/dialogs.py:4583
 msgid ""
 "Note: Selected symbol is not displayed\n"
 "in draft mode (only in preview mode)"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4593 ../gui/wxpython/psmap/dialogs.py:4848
-#: ../gui/wxpython/gmodeler/preferences.py:88
-#: ../gui/wxpython/gmodeler/preferences.py:326
-#: ../gui/wxpython/nviz/tools.py:773 ../gui/wxpython/nviz/tools.py:2339
-#: ../gui/wxpython/gui_modules/gmodeler.py:3455
-#: ../gui/wxpython/gui_modules/gmodeler.py:3693
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:893
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:944
-#: ../gui/wxpython/gui_modules/nviz_tools.py:943
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2491
-#: ../gui/wxpython/iclass/dialogs.py:226 ../gui/wxpython/wxplot/dialogs.py:894
-#: ../gui/wxpython/wxplot/dialogs.py:945
+#: ../gui/wxpython/psmap/dialogs.py:4597 ../gui/wxpython/psmap/dialogs.py:4852
+#: ../gui/wxpython/gmodeler/preferences.py:90
+#: ../gui/wxpython/gmodeler/preferences.py:328
+#: ../gui/wxpython/gmodeler/preferences.py:413
+#: ../gui/wxpython/nviz/tools.py:788 ../gui/wxpython/nviz/tools.py:2399
+#: ../gui/wxpython/iclass/dialogs.py:357 ../gui/wxpython/wxplot/dialogs.py:918
+#: ../gui/wxpython/wxplot/dialogs.py:968
 msgid "Color"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4598 ../gui/wxpython/psmap/dialogs.py:4852
+#: ../gui/wxpython/psmap/dialogs.py:4602 ../gui/wxpython/psmap/dialogs.py:4856
 msgid "Outline color:"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4600 ../gui/wxpython/psmap/dialogs.py:4615
-#: ../gui/wxpython/psmap/dialogs.py:4854 ../gui/wxpython/psmap/dialogs.py:4875
-#: ../gui/wxpython/gui_modules/gdialogs.py:2138
-#: ../gui/wxpython/gui_core/dialogs.py:2242
+#: ../gui/wxpython/psmap/dialogs.py:4604 ../gui/wxpython/psmap/dialogs.py:4619
+#: ../gui/wxpython/psmap/dialogs.py:4858 ../gui/wxpython/psmap/dialogs.py:4879
+#: ../gui/wxpython/gui_core/dialogs.py:2200
 msgid "transparent"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4613 ../gui/wxpython/psmap/dialogs.py:4873
+#: ../gui/wxpython/psmap/dialogs.py:4617 ../gui/wxpython/psmap/dialogs.py:4877
 msgid "Fill color:"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4636
+#: ../gui/wxpython/psmap/dialogs.py:4640
 msgid "Size and Rotation"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4641
+#: ../gui/wxpython/psmap/dialogs.py:4645
 msgid "Size (pt):"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4643
+#: ../gui/wxpython/psmap/dialogs.py:4647
 msgid "Symbol size in points"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4817
+#: ../gui/wxpython/psmap/dialogs.py:4821
 msgid "Rectangle settings"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4819
+#: ../gui/wxpython/psmap/dialogs.py:4823
 msgid "Line settings"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4896 ../gui/wxpython/gcp/manager.py:2538
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2541
-#: ../gui/wxpython/gui_core/preferences.py:987
+#: ../gui/wxpython/psmap/dialogs.py:4900 ../gui/wxpython/gcp/manager.py:2563
+#: ../gui/wxpython/mapswipe/dialogs.py:270
+#: ../gui/wxpython/gui_core/preferences.py:1006
+#: ../gui/wxpython/vnet/dialogs.py:1162
 msgid "Line width:"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4905
+#: ../gui/wxpython/psmap/dialogs.py:4909
 msgid "Line width in points"
 msgstr ""
-#: ../gui/wxpython/psmap/utils.py:91
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:98
+#: ../gui/wxpython/psmap/dialogs.py:4977
+#, fuzzy
+msgid "Vector labels"
+msgstr "Vektoru karte"
+#: ../gui/wxpython/psmap/dialogs.py:4996
+msgid "Vector label files created beforehand by v.label module"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:5004
+msgid "You can select multiple label files."
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:93
 msgid "inch"
 msgstr ""
-#: ../gui/wxpython/psmap/utils.py:92
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:99
-#: ../gui/wxpython/gui_modules/vclean.py:204
-#: ../gui/wxpython/modules/vclean.py:194
+#: ../gui/wxpython/psmap/utils.py:94 ../gui/wxpython/modules/vclean.py:202
 msgid "point"
 msgstr ""
-#: ../gui/wxpython/psmap/utils.py:93
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:100
+#: ../gui/wxpython/psmap/utils.py:95
 msgid "centimeter"
 msgstr ""
-#: ../gui/wxpython/psmap/utils.py:94
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:101
+#: ../gui/wxpython/psmap/utils.py:96
 msgid "millimeter"
 msgstr ""
-#: ../gui/wxpython/psmap/utils.py:95
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:102
+#: ../gui/wxpython/psmap/utils.py:97
 msgid "meters"
 msgstr ""
-#: ../gui/wxpython/psmap/utils.py:96
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:103
+#: ../gui/wxpython/psmap/utils.py:98
 msgid "kilometers"
 msgstr ""
-#: ../gui/wxpython/psmap/utils.py:97
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:104
+#: ../gui/wxpython/psmap/utils.py:99
 msgid "feet"
 msgstr ""
-#: ../gui/wxpython/psmap/utils.py:98
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:105
+#: ../gui/wxpython/psmap/utils.py:100
 msgid "miles"
 msgstr ""
-#: ../gui/wxpython/psmap/utils.py:99 ../gui/wxpython/psmap/utils.py:103
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:106
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:110
+#: ../gui/wxpython/psmap/utils.py:101 ../gui/wxpython/psmap/utils.py:105
 msgid "nautical miles"
 msgstr ""
-#: ../gui/wxpython/psmap/utils.py:101
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:108
+#: ../gui/wxpython/psmap/utils.py:103
 msgid "pixel"
 msgstr ""
-#: ../gui/wxpython/psmap/utils.py:102
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:109
+#: ../gui/wxpython/psmap/utils.py:104
 msgid "meter"
 msgstr ""
-#: ../gui/wxpython/psmap/utils.py:104
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:111
+#: ../gui/wxpython/psmap/utils.py:106
 msgid "degree"
 msgstr ""
-#: ../gui/wxpython/psmap/utils.py:344
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:6330
+#: ../gui/wxpython/psmap/utils.py:346
 msgid "Unable to run `ps.map -b`"
 msgstr ""
-#: ../gui/wxpython/psmap/frame.py:50 ../gui/wxpython/gui_modules/psmap.py:55
+#: ../gui/wxpython/psmap/frame.py:51
 msgid "GRASS GIS Cartographic Composer"
 msgstr ""
-#: ../gui/wxpython/psmap/frame.py:179 ../gui/wxpython/gui_modules/psmap.py:180
+#: ../gui/wxpython/psmap/frame.py:182
 msgid ""
 "Python Imaging Library is not available.\n"
 "'Preview' functionality won't work."
 msgstr ""
-#: ../gui/wxpython/psmap/frame.py:230 ../gui/wxpython/gui_modules/psmap.py:231
+#: ../gui/wxpython/psmap/frame.py:234
 msgid "Program ps2pdf is not available. Please install it first to create PDF."
 msgstr ""
-#: ../gui/wxpython/psmap/frame.py:274 ../gui/wxpython/gui_modules/psmap.py:275
+#: ../gui/wxpython/psmap/frame.py:278
 msgid "Generating PDF..."
 msgstr ""
-#: ../gui/wxpython/psmap/frame.py:276 ../gui/wxpython/gui_modules/psmap.py:277
+#: ../gui/wxpython/psmap/frame.py:280
 msgid "Generating PostScript..."
 msgstr ""
-#: ../gui/wxpython/psmap/frame.py:278 ../gui/wxpython/gui_modules/psmap.py:279
+#: ../gui/wxpython/psmap/frame.py:282
 msgid "Generating preview..."
 msgstr ""
-#: ../gui/wxpython/psmap/frame.py:288 ../gui/wxpython/gui_modules/psmap.py:289
+#: ../gui/wxpython/psmap/frame.py:292
 #, python-format
 msgid "Ps.map exited with return code %s"
 msgstr ""
-#: ../gui/wxpython/psmap/frame.py:303 ../gui/wxpython/gui_modules/psmap.py:304
+#: ../gui/wxpython/psmap/frame.py:322
 #, python-format
-msgid "ps2pdf exited with return code %s"
+msgid "%(prg)s exited with return code %(code)s"
 msgstr ""
-#: ../gui/wxpython/psmap/frame.py:307 ../gui/wxpython/gui_modules/psmap.py:308
+#: ../gui/wxpython/psmap/frame.py:325
+msgid "PDF generated"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:328
 #, python-format
 msgid ""
 "Program ps2pdf is not available. Please install it to create PDF.\n"
@@ -1720,303 +1361,293 @@
 " %s"
 msgstr ""
-#: ../gui/wxpython/psmap/frame.py:324 ../gui/wxpython/gui_modules/psmap.py:325
-#, fuzzy, python-format
-msgid "Unable to generate preview. %s"
-msgstr "Jauna vektoru karte"
+#: ../gui/wxpython/psmap/frame.py:331
+msgid "PostScript file generated"
+msgstr ""
-#: ../gui/wxpython/psmap/frame.py:333 ../gui/wxpython/gui_modules/psmap.py:334
+#: ../gui/wxpython/psmap/frame.py:337
+msgid "Generating preview, wait please"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:351
+msgid "Preview not available"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:352
+msgid "Preview is not available probably due to missing Ghostscript."
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:354
+msgid "Please follow instructions on GRASS Trac Wiki."
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:365
 msgid "Preview generated"
 msgstr ""
-#: ../gui/wxpython/psmap/frame.py:361 ../gui/wxpython/gui_modules/psmap.py:362
+#: ../gui/wxpython/psmap/frame.py:395
 msgid "Save file as"
 msgstr ""
-#: ../gui/wxpython/psmap/frame.py:399 ../gui/wxpython/gui_modules/psmap.py:400
+#: ../gui/wxpython/psmap/frame.py:437
 #, python-format
 msgid "Failed to read file %s."
 msgstr ""
-#: ../gui/wxpython/psmap/frame.py:587 ../gui/wxpython/gui_modules/psmap.py:628
+#: ../gui/wxpython/psmap/frame.py:604
 msgid "Scalebar is not appropriate for this projection"
 msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1018
-#: ../gui/wxpython/gui_modules/psmap.py:959
+#: ../gui/wxpython/psmap/frame.py:1024
+msgid "Press button with green triangle icon to generate preview."
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:1048
 msgid "wxGUI Cartographic Composer"
 msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1020
-#: ../gui/wxpython/gui_modules/psmap.py:961
-msgid ""
-"(C) 2011 by the GRASS Development Team\n"
-"\n"
+#: ../gui/wxpython/psmap/frame.py:1099
+msgid "MAP FRAME"
 msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1021 ../gui/wxpython/gmodeler/frame.py:707
-#: ../gui/wxpython/gui_modules/gmodeler.py:1449
-#: ../gui/wxpython/gui_modules/psmap.py:962
-msgid ""
-"This program is free software under the GNU General Public License(>=v2). "
-"Read the file COPYING that comes with GRASS for details."
+#: ../gui/wxpython/psmap/frame.py:1100
+msgid "RASTER LEGEND"
 msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1324
-#: ../gui/wxpython/gui_modules/psmap.py:1197
+#: ../gui/wxpython/psmap/frame.py:1101
+msgid "VECTOR LEGEND"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:1102
+msgid "MAP INFO"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:1103
+msgid "SCALE BAR"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:1104
+msgid "IMAGE"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:1105
+msgid "NORTH ARROW"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:1353
 msgid "Click and drag to resize object"
 msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:45
-#: ../gui/wxpython/gui_modules/gcpmapdisp.py:72
+#: ../gui/wxpython/psmap/frame.py:2173
+#, fuzzy
+msgid "labels: "
+msgstr "Birka"
+#: ../gui/wxpython/gcp/mapdisplay.py:48
 msgid "GRASS GIS Manage Ground Control Points"
 msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:149
-#: ../gui/wxpython/gui_modules/gcpmapdisp.py:178
+#: ../gui/wxpython/gcp/mapdisplay.py:163
 msgid "GCP List"
 msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:154
-#: ../gui/wxpython/gui_modules/gcpmapdisp.py:183
+#: ../gui/wxpython/gcp/mapdisplay.py:168
 msgid "Source Display"
 msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:158
-#: ../gui/wxpython/gui_modules/gcpmapdisp.py:187
+#: ../gui/wxpython/gcp/mapdisplay.py:172
 msgid "Target Display"
 msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:220
-#: ../gui/wxpython/gui_modules/gcpmapdisp.py:249
-#: ../gui/wxpython/gui_modules/mapdisp.py:704
-#: ../gui/wxpython/iclass/frame.py:247 ../gui/wxpython/mapdisp/frame.py:380
+#: ../gui/wxpython/gcp/mapdisplay.py:248 ../gui/wxpython/mapswipe/frame.py:266
+#: ../gui/wxpython/iclass/frame.py:294 ../gui/wxpython/mapdisp/frame.py:456
+#: ../gui/wxpython/rlisetup/sampling_frame.py:74
 msgid "Map Toolbar"
 msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:233
-#: ../gui/wxpython/gui_modules/gcpmapdisp.py:262
+#: ../gui/wxpython/gcp/mapdisplay.py:261
 msgid "GCP Display toolbar"
 msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:246
-#: ../gui/wxpython/gui_modules/gcpmapdisp.py:275
+#: ../gui/wxpython/gcp/mapdisplay.py:274
 msgid "GCP Manager toolbar"
 msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:435
-#: ../gui/wxpython/gui_modules/gcpmapdisp.py:467
-#: ../gui/wxpython/gui_modules/mapdisp.py:874
-#: ../gui/wxpython/mapdisp/frame.py:551
+#: ../gui/wxpython/gcp/mapdisplay.py:368 ../gui/wxpython/mapswipe/frame.py:509
+#: ../gui/wxpython/mapdisp/frame.py:646
 msgid "Nothing to render (empty map). Operation canceled."
 msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:450 ../gui/wxpython/gmodeler/frame.py:543
-#: ../gui/wxpython/gui_modules/gcpmapdisp.py:482
-#: ../gui/wxpython/gui_modules/gmodeler.py:1249
-#: ../gui/wxpython/gui_modules/histogram.py:404
-#: ../gui/wxpython/gui_modules/mapdisp.py:889
-#: ../gui/wxpython/modules/histogram.py:414
-#: ../gui/wxpython/mapdisp/frame.py:566
+#: ../gui/wxpython/gcp/mapdisplay.py:383 ../gui/wxpython/gmodeler/frame.py:570
+#: ../gui/wxpython/mapswipe/frame.py:515
+#: ../gui/wxpython/modules/histogram.py:420
+#: ../gui/wxpython/mapdisp/frame.py:569
 msgid "Choose a file name to save the image (no need to add extension)"
 msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:483
-#: ../gui/wxpython/gui_modules/gcpmapdisp.py:515
-#: ../gui/wxpython/gui_modules/wxplot.py:512
-#: ../gui/wxpython/gui_modules/histogram.py:437
-#: ../gui/wxpython/gui_modules/mapdisp.py:922
-#: ../gui/wxpython/modules/histogram.py:447 ../gui/wxpython/wxplot/base.py:505
-#: ../gui/wxpython/mapdisp/frame.py:599
+#: ../gui/wxpython/gcp/mapdisplay.py:416
+#: ../gui/wxpython/modules/histogram.py:453 ../gui/wxpython/wxplot/base.py:540
+#: ../gui/wxpython/mapdisp/frame.py:661
 msgid "Print preview"
 msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:487
-#: ../gui/wxpython/gui_modules/gcpmapdisp.py:519
-#: ../gui/wxpython/gui_modules/wxplot.py:513
-#: ../gui/wxpython/gui_modules/histogram.py:441
-#: ../gui/wxpython/gui_modules/mapdisp.py:926
-#: ../gui/wxpython/gui_core/toolbars.py:60
-#: ../gui/wxpython/modules/histogram.py:451 ../gui/wxpython/wxplot/base.py:506
-#: ../gui/wxpython/mapdisp/frame.py:603
+#: ../gui/wxpython/gcp/mapdisplay.py:420
+#: ../gui/wxpython/gui_core/toolbars.py:67
+#: ../gui/wxpython/modules/histogram.py:457 ../gui/wxpython/wxplot/base.py:541
+#: ../gui/wxpython/mapdisp/frame.py:665
 msgid "Print display"
 msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:573
-#: ../gui/wxpython/gui_modules/gcpmapdisp.py:605
+#: ../gui/wxpython/gcp/mapdisplay.py:459
 msgid "Zoom to computational region (set with g.region)"
 msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:577
-#: ../gui/wxpython/gui_modules/gcpmapdisp.py:609
-#: ../gui/wxpython/gui_modules/mapdisp.py:1672
-#: ../gui/wxpython/mapdisp/frame.py:1275
+#: ../gui/wxpython/gcp/mapdisplay.py:463 ../gui/wxpython/mapdisp/frame.py:1238
 msgid "Zoom to default region"
 msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:581
-#: ../gui/wxpython/gui_modules/gcpmapdisp.py:613
-#: ../gui/wxpython/gui_modules/mapdisp.py:1676
-#: ../gui/wxpython/mapdisp/frame.py:1279
+#: ../gui/wxpython/gcp/mapdisplay.py:467 ../gui/wxpython/mapdisp/frame.py:1239
 msgid "Zoom to saved region"
 msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:585
-#: ../gui/wxpython/gui_modules/gcpmapdisp.py:617
+#: ../gui/wxpython/gcp/mapdisplay.py:471
 msgid "Set computational region from display"
 msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:589
-#: ../gui/wxpython/gui_modules/gcpmapdisp.py:621
-#: ../gui/wxpython/gui_modules/mapdisp.py:1684
-#: ../gui/wxpython/mapdisp/frame.py:1287
+#: ../gui/wxpython/gcp/mapdisplay.py:475 ../gui/wxpython/mapdisp/frame.py:1244
 msgid "Save display geometry to named region"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:133
-#: ../gui/wxpython/gui_modules/gcpmanager.py:144
+#: ../gui/wxpython/gcp/statusbar.py:36
+msgid "Go to GCP No."
+msgstr ""
+#: ../gui/wxpython/gcp/statusbar.py:53
+msgid "Valid Range:"
+msgstr "Derīgs diapazons:"
+#: ../gui/wxpython/gcp/statusbar.py:118
+msgid "RMS error"
+msgstr ""
+#: ../gui/wxpython/gcp/statusbar.py:122
+#, python-format
+msgid "Forward: %(forw)s, Backward: %(back)s"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:136
 msgid "Setup for georectification"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:166 ../gui/wxpython/gcp/manager.py:170
-#: ../gui/wxpython/gui_modules/gcpmanager.py:177
-#: ../gui/wxpython/gui_modules/gcpmanager.py:181
+#: ../gui/wxpython/gcp/manager.py:169 ../gui/wxpython/gcp/manager.py:173
 msgid "Georectifying setup canceled."
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:310
-#: ../gui/wxpython/gui_modules/gcpmanager.py:314
+#: ../gui/wxpython/gcp/manager.py:315
 msgid "Select map type and location/mapset"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:324
-#: ../gui/wxpython/gui_modules/gcpmanager.py:328
+#: ../gui/wxpython/gcp/manager.py:328
 msgid "Map type to georectify"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:332
-#: ../gui/wxpython/gui_modules/gcpmanager.py:336
+#: ../gui/wxpython/gcp/manager.py:336
 msgid "Select source location:"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:341
-#: ../gui/wxpython/gui_modules/gcpmanager.py:345
+#: ../gui/wxpython/gcp/manager.py:345
 msgid "Select source mapset:"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:394
-#: ../gui/wxpython/gui_modules/gcpmanager.py:398
+#: ../gui/wxpython/gcp/manager.py:399
 msgid "You must select a valid location before selecting a mapset"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:407
-#: ../gui/wxpython/gui_modules/gcpmanager.py:411
+#: ../gui/wxpython/gcp/manager.py:412
 msgid "You must select a valid location and mapset in order to continue"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:426
-#: ../gui/wxpython/gui_modules/gcpmanager.py:430
+#: ../gui/wxpython/gcp/manager.py:431
 msgid "Select image/map group to georectify"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:445
-#: ../gui/wxpython/gui_modules/gcpmanager.py:449
+#: ../gui/wxpython/gcp/manager.py:449
 msgid "Select group:"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:456
-#: ../gui/wxpython/gui_modules/gcpmanager.py:460
+#: ../gui/wxpython/gcp/manager.py:460
 msgid "Create group if none exists"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:460
-#: ../gui/wxpython/gui_modules/gcpmanager.py:464
-#: ../gui/wxpython/iclass/dialogs.py:53
+#: ../gui/wxpython/gcp/manager.py:464 ../gui/wxpython/iclass/dialogs.py:72
 msgid "Create/edit group..."
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:461
-#: ../gui/wxpython/gui_modules/gcpmanager.py:465
+#: ../gui/wxpython/gcp/manager.py:465
 msgid "Add vector map to group..."
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:473 ../gui/wxpython/gcp/manager.py:2639
-#: ../gui/wxpython/gui_modules/gcpmanager.py:477
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2631
+#: ../gui/wxpython/gcp/manager.py:477 ../gui/wxpython/gcp/manager.py:2665
 msgid "Extension for output maps:"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:532
-#: ../gui/wxpython/gui_modules/gcpmanager.py:536
+#: ../gui/wxpython/gcp/manager.py:537
 msgid "You must select a valid image/map group in order to continue"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:539
-#: ../gui/wxpython/gui_modules/gcpmanager.py:543
+#: ../gui/wxpython/gcp/manager.py:544
 msgid "You must enter an map name extension in order to continue"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:605
-#: ../gui/wxpython/gui_modules/gcpmanager.py:609
+#: ../gui/wxpython/gcp/manager.py:610
 msgid "Select maps to display for ground control point (GCP) creation"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:613 ../gui/wxpython/gcp/manager.py:2575
-#: ../gui/wxpython/gui_modules/gcpmanager.py:617
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2573
+#: ../gui/wxpython/gcp/manager.py:618 ../gui/wxpython/gcp/manager.py:2601
 msgid "Select source map to display:"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:624 ../gui/wxpython/gcp/manager.py:2580
+#: ../gui/wxpython/gcp/manager.py:629 ../gui/wxpython/gcp/manager.py:2606
 msgid "Select target raster map to display:"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:635 ../gui/wxpython/gcp/manager.py:2585
+#: ../gui/wxpython/gcp/manager.py:640 ../gui/wxpython/gcp/manager.py:2611
 msgid "Select target vector map to display:"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:698
-#: ../gui/wxpython/gui_modules/gcpmanager.py:684
+#: ../gui/wxpython/gcp/manager.py:703
 msgid "You must select a source map in order to continue"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:724 ../gui/wxpython/gcp/manager.py:754
-#: ../gui/wxpython/gui_modules/gcpmanager.py:708
+#: ../gui/wxpython/gcp/manager.py:729 ../gui/wxpython/gcp/manager.py:759
 #, python-format
 msgid ""
 "No maps in selected group <%s>.\n"
 "Please edit group or select another group."
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:782
-#: ../gui/wxpython/gui_modules/gcpmanager.py:734
+#: ../gui/wxpython/gcp/manager.py:787
 msgid "Manage Ground Control Points"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1026
+#: ../gui/wxpython/gcp/manager.py:1040
 #, python-format
 msgid "At least %d GCPs required. Operation canceled."
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1158
-#: ../gui/wxpython/gui_modules/toolbars.py:441
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1122
+#: ../gui/wxpython/gcp/manager.py:1172
 msgid "source"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1160
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1124
+#: ../gui/wxpython/gcp/manager.py:1174
 msgid "target"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1162
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1126
+#: ../gui/wxpython/gcp/manager.py:1176
 msgid "Set GCP coordinates"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1163
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1127
+#: ../gui/wxpython/gcp/manager.py:1177
 #, python-format
 msgid ""
 "Set %(coor)s coordinates for GCP No. %(key)s? \n"
@@ -2025,34 +1656,28 @@
 "North: %(coor1)s"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1229
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1191
+#: ../gui/wxpython/gcp/manager.py:1243
 msgid "Writing POINTS file failed"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1238
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1200
+#: ../gui/wxpython/gcp/manager.py:1252
 #, python-format
 msgid "POINTS file saved for group <%s>"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1254
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1216
+#: ../gui/wxpython/gcp/manager.py:1267
 msgid "source mapwin not defined"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1259
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1221
+#: ../gui/wxpython/gcp/manager.py:1272
 msgid "target mapwin not defined"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1287
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1249
+#: ../gui/wxpython/gcp/manager.py:1300
 msgid "Reading POINTS file failed"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1358
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1320
+#: ../gui/wxpython/gcp/manager.py:1382
 msgid ""
 "Insufficient points defined and active (checked) for selected rectification "
 "method.\n"
@@ -2061,321 +1686,256 @@
 "10+ points for 3rd order."
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1385
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1347
+#: ../gui/wxpython/gcp/manager.py:1409
 msgid "Rectifying images, please wait..."
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1426
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1399
+#: ../gui/wxpython/gcp/manager.py:1449
 #, python-format
 msgid "Transforming <%s>..."
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1430
+#: ../gui/wxpython/gcp/manager.py:1453
 #, python-format
 msgid "Rectifying vector map <%s>, please wait..."
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1463
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1416
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1487
+#: ../gui/wxpython/gcp/manager.py:1486
 #, python-format
 msgid "Georectification of vector map <%s> failed"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1469
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1493
+#: ../gui/wxpython/gcp/manager.py:1493
 msgid "GCP Manager settings"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1514
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1538
+#: ../gui/wxpython/gcp/manager.py:1538
 msgid "Quit GCP Manager"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1515
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1539
+#: ../gui/wxpython/gcp/manager.py:1539
 msgid "Save ground control points?"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1594
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1618
+#: ../gui/wxpython/gcp/manager.py:1618
 msgid ""
 "Could not calculate RMS Error.\n"
 "Possible error with m.transform."
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1719
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1743
+#: ../gui/wxpython/gcp/manager.py:1742
 msgid ""
 "Could not calculate new extends.\n"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1850
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1874
+#: ../gui/wxpython/gcp/manager.py:1871
 msgid "Adjust source display to target display"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1854
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1878
+#: ../gui/wxpython/gcp/manager.py:1875
 msgid "Adjust target display to source display"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1926 ../gui/wxpython/gcp/manager.py:1943
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1939
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1956
+#: ../gui/wxpython/gcp/manager.py:1948 ../gui/wxpython/gcp/manager.py:1965
+#: ../gui/wxpython/vnet/widgets.py:85 ../gui/wxpython/vnet/vnet_data.py:237
 msgid "use"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1927 ../gui/wxpython/gcp/manager.py:1944
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1940
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1957
+#: ../gui/wxpython/gcp/manager.py:1949 ../gui/wxpython/gcp/manager.py:1966
 msgid "source E"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1928 ../gui/wxpython/gcp/manager.py:1945
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1941
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1958
+#: ../gui/wxpython/gcp/manager.py:1950 ../gui/wxpython/gcp/manager.py:1967
 msgid "source N"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1929 ../gui/wxpython/gcp/manager.py:1946
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1942
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1959
+#: ../gui/wxpython/gcp/manager.py:1951 ../gui/wxpython/gcp/manager.py:1968
 msgid "target E"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1930 ../gui/wxpython/gcp/manager.py:1947
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1943
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1960
+#: ../gui/wxpython/gcp/manager.py:1952 ../gui/wxpython/gcp/manager.py:1969
 msgid "target N"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1931 ../gui/wxpython/gcp/manager.py:1948
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1944
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1961
+#: ../gui/wxpython/gcp/manager.py:1953 ../gui/wxpython/gcp/manager.py:1970
 msgid "Forward error"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1932 ../gui/wxpython/gcp/manager.py:1949
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1945
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1962
+#: ../gui/wxpython/gcp/manager.py:1954 ../gui/wxpython/gcp/manager.py:1971
 msgid "Backward error"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2080
+#: ../gui/wxpython/gcp/manager.py:2106
 msgid "Invalid coordinate value. Operation canceled."
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2124
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2128
+#: ../gui/wxpython/gcp/manager.py:2150
 msgid "Create vector map group"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2197
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2201
+#: ../gui/wxpython/gcp/manager.py:2223
 msgid "Select vector map(s) to add to group:"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2244
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2248
+#: ../gui/wxpython/gcp/manager.py:2270
 msgid "Edit GCP"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2255
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2259
+#: ../gui/wxpython/gcp/manager.py:2281
 msgid "Ground Control Point No."
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2274
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2278
+#: ../gui/wxpython/gcp/manager.py:2300
 msgid "source E:"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2275
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2279
+#: ../gui/wxpython/gcp/manager.py:2301
 msgid "target E:"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2276
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2280
+#: ../gui/wxpython/gcp/manager.py:2302
 msgid "source N:"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2277
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2281
+#: ../gui/wxpython/gcp/manager.py:2303
 msgid "target N:"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2380
-#: ../gui/wxpython/gui_modules/preferences.py:1106
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:665
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:1111
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2383
-#: ../gui/wxpython/gui_core/preferences.py:88
-#: ../gui/wxpython/wxplot/dialogs.py:666
-#: ../gui/wxpython/wxplot/dialogs.py:1112
+#: ../gui/wxpython/gcp/manager.py:2406 ../gui/wxpython/iscatt/dialogs.py:357
+#: ../gui/wxpython/gui_core/preferences.py:90
+#: ../gui/wxpython/wxplot/dialogs.py:686
+#: ../gui/wxpython/wxplot/dialogs.py:1135 ../gui/wxpython/vnet/dialogs.py:1184
 msgid "Apply changes for the current session"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2382
-#: ../gui/wxpython/gui_modules/preferences.py:1108
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:670
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:1112
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2385
-#: ../gui/wxpython/gui_core/preferences.py:90
-#: ../gui/wxpython/wxplot/dialogs.py:671
-#: ../gui/wxpython/wxplot/dialogs.py:1113
-msgid "Apply and save changes to user settings file (default for next sessions)"
+#: ../gui/wxpython/gcp/manager.py:2408 ../gui/wxpython/iscatt/dialogs.py:359
+#: ../gui/wxpython/gui_core/preferences.py:92
+#: ../gui/wxpython/wxplot/dialogs.py:691
+#: ../gui/wxpython/wxplot/dialogs.py:1137 ../gui/wxpython/vnet/dialogs.py:1186
+msgid ""
+"Apply and save changes to user settings file (default for next sessions)"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2384 ../gui/wxpython/ogc_services/wms.py:76
-#: ../gui/wxpython/gui_modules/gdialogs.py:1546
-#: ../gui/wxpython/gui_modules/gdialogs.py:1834
-#: ../gui/wxpython/gui_modules/ogc_services.py:77
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2387
-#: ../gui/wxpython/gui_core/dialogs.py:1636
-#: ../gui/wxpython/gui_core/dialogs.py:1938
+#: ../gui/wxpython/gcp/manager.py:2410
+#: ../gui/wxpython/web_services/dialogs.py:131
+#: ../gui/wxpython/web_services/dialogs.py:817
+#: ../gui/wxpython/iscatt/dialogs.py:361
+#: ../gui/wxpython/gui_core/dialogs.py:1663
+#: ../gui/wxpython/gui_core/dialogs.py:1955
+#: ../gui/wxpython/vnet/dialogs.py:1188
 msgid "Close dialog"
 msgstr "Aizvērt dialogu"
-#: ../gui/wxpython/gcp/manager.py:2415
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2418
+#: ../gui/wxpython/gcp/manager.py:2440
 msgid "Highlight highest RMS error only"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2421
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2424
+#: ../gui/wxpython/gcp/manager.py:2446
 msgid "Highlight RMS error > M + SD * factor:"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2422
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2425
+#: ../gui/wxpython/gcp/manager.py:2447
 msgid ""
 "Highlight GCPs with an RMS error larger than \n"
 "mean + standard deviation * given factor. \n"
 "Recommended values for this factor are between 1 and 2."
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2438
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2441
+#: ../gui/wxpython/gcp/manager.py:2464
 msgid "Symbol settings"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2464
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2467
+#: ../gui/wxpython/gcp/manager.py:2489
 msgid "Color for high RMS error:"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2481
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2484
+#: ../gui/wxpython/gcp/manager.py:2506
 msgid "Color for selected GCP:"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2498
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2501
+#: ../gui/wxpython/gcp/manager.py:2523
 msgid "Color for unused GCPs:"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2514
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2517
+#: ../gui/wxpython/gcp/manager.py:2539
 msgid "Show unused GCPs"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2523
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2526
-#: ../gui/wxpython/gui_core/preferences.py:999
+#: ../gui/wxpython/gcp/manager.py:2548
+#: ../gui/wxpython/gui_core/preferences.py:1018
 msgid "Symbol size:"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2606
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2598
+#: ../gui/wxpython/gcp/manager.py:2632
 msgid "Rectification"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2612
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2604
+#: ../gui/wxpython/gcp/manager.py:2638
 msgid "Select rectification order"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2613
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2605
+#: ../gui/wxpython/gcp/manager.py:2639
 msgid "1st order"
 msgstr ""
 msgid "2nd order"
 msgstr ""
 msgid "3rd order"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2622
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2614
+#: ../gui/wxpython/gcp/manager.py:2647
 msgid "Select interpolation method:"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2633
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2625
+#: ../gui/wxpython/gcp/manager.py:2659
 msgid "clip to computational region in target location"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2672
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2664
+#: ../gui/wxpython/gcp/manager.py:2699
 msgid "RMS threshold factor must be > 0"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2675
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2667
+#: ../gui/wxpython/gcp/manager.py:2702
 msgid ""
 "RMS threshold factor is < 1\n"
 "Too many points might be highlighted"
 msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2826
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2786
+#: ../gui/wxpython/gcp/manager.py:2849
 #, python-format
 msgid "GCP Manager settings saved to file '%s'."
 msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:58
-#: ../gui/wxpython/gui_modules/gmodeler.py:90
+#: ../gui/wxpython/gmodeler/model.py:63
 msgid "model"
 msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:59
-#: ../gui/wxpython/gui_modules/gmodeler.py:91
+#: ../gui/wxpython/gmodeler/model.py:64
 msgid "Script generated by wxGUI Graphical Modeler."
 msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:388 ../gui/wxpython/gmodeler/model.py:450
+#: ../gui/wxpython/gmodeler/model.py:460 ../gui/wxpython/gmodeler/model.py:522
 #, python-format
 msgid "undefined variable '%s'"
 msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:483
-#: ../gui/wxpython/gui_modules/gmodeler.py:515
+#: ../gui/wxpython/gmodeler/model.py:555
 msgid "Running model..."
 msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:502
-#: ../gui/wxpython/gui_modules/gmodeler.py:534
+#: ../gui/wxpython/gmodeler/model.py:574
 msgid "Model is empty. Nothing to run."
 msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:511 ../gui/wxpython/gmodeler/frame.py:501
-#: ../gui/wxpython/gui_modules/gmodeler.py:543
-#: ../gui/wxpython/gui_modules/gmodeler.py:1207
+#: ../gui/wxpython/gmodeler/model.py:583 ../gui/wxpython/gmodeler/frame.py:528
 msgid "Validating model..."
 msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:517
-#: ../gui/wxpython/gui_modules/gmodeler.py:549
+#: ../gui/wxpython/gmodeler/model.py:589
 #, python-format
 msgid ""
 "Model is not valid. Do you want to run the model anyway?\n"
@@ -2383,290 +1943,247 @@
 "%s"
 msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:519
-#: ../gui/wxpython/gui_modules/gmodeler.py:551
+#: ../gui/wxpython/gmodeler/model.py:591
 msgid "Run model?"
 msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:554
-#: ../gui/wxpython/gui_modules/gmodeler.py:582
+#: ../gui/wxpython/gmodeler/model.py:626
 msgid "Variables below not defined:"
 msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:663
-#: ../gui/wxpython/gui_modules/gmodeler.py:690
+#: ../gui/wxpython/gmodeler/model.py:736
 msgid "Raster maps"
 msgstr "Rastra kartes"
-#: ../gui/wxpython/gmodeler/model.py:666
-#: ../gui/wxpython/gui_modules/gmodeler.py:693
+#: ../gui/wxpython/gmodeler/model.py:739
 msgid "3D raster maps"
 msgstr "3D rastra kartes"
-#: ../gui/wxpython/gmodeler/model.py:925 ../gui/wxpython/gmodeler/model.py:992
-#: ../gui/wxpython/gui_modules/gmodeler.py:1917
-#: ../gui/wxpython/gui_modules/gmodeler.py:1984
-#: ../gui/wxpython/gui_core/goutput.py:869
+#: ../gui/wxpython/gmodeler/model.py:1055
+#: ../gui/wxpython/gmodeler/model.py:1152
+#: ../gui/wxpython/gui_core/ghelp.py:206 ../gui/wxpython/core/gconsole.py:622
 msgid "unknown"
 msgstr "nezināms"
-#: ../gui/wxpython/gmodeler/model.py:1240
-#: ../gui/wxpython/gui_modules/gmodeler.py:2231
+#: ../gui/wxpython/gmodeler/model.py:1397
 msgid "<not defined>"
 msgstr "<nav definēts>"
-#: ../gui/wxpython/gmodeler/model.py:1350
-#: ../gui/wxpython/gui_modules/gmodeler.py:4328
+#: ../gui/wxpython/gmodeler/model.py:1506
 msgid "Condition: "
 msgstr "Nosacījums: "
-#: ../gui/wxpython/gmodeler/model.py:1352
-#: ../gui/wxpython/gui_modules/gmodeler.py:4330
+#: ../gui/wxpython/gmodeler/model.py:1508
 msgid "Condition: not defined"
 msgstr "Nosacījums: nav definēts"
-#: ../gui/wxpython/gmodeler/model.py:1413
-#: ../gui/wxpython/gui_modules/gmodeler.py:4426
-msgid "loop"
-msgstr "cilpa"
-#: ../gui/wxpython/gmodeler/model.py:1454
-#: ../gui/wxpython/gui_modules/gmodeler.py:4803
+#: ../gui/wxpython/gmodeler/model.py:1627
 msgid "if-else"
 msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:2148
-#: ../gui/wxpython/gui_modules/gmodeler.py:3898
+#: ../gui/wxpython/gmodeler/model.py:2510
 msgid "Model parameters"
 msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:2165
+#: ../gui/wxpython/gmodeler/model.py:2527
 msgid "Delete intermediate data when finish"
 msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:2173
-#: ../gui/wxpython/gmodeler/frame.py:1454
-#: ../gui/wxpython/gui_modules/gmodeler.py:3916
-#: ../gui/wxpython/gui_modules/vclean.py:165
-#: ../gui/wxpython/gui_modules/menuform.py:503
-#: ../gui/wxpython/gui_modules/ghelp.py:229
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:131
-#: ../gui/wxpython/gui_core/forms.py:460 ../gui/wxpython/gui_core/ghelp.py:212
-#: ../gui/wxpython/modules/vclean.py:156
-#: ../gui/wxpython/modules/mcalc_builder.py:127
-#: ../gui/wxpython/scripts/vkrige.py:152
+#: ../gui/wxpython/gmodeler/model.py:2535
+#: ../gui/wxpython/gmodeler/frame.py:1665
+#: ../gui/wxpython/gui_core/forms.py:507 ../gui/wxpython/gui_core/menu.py:156
+#: ../gui/wxpython/modules/vclean.py:164
+#: ../gui/wxpython/modules/mcalc_builder.py:141
+#: ../gui/wxpython/scripts/vkrige.py:155
 msgid "&Run"
 msgstr "&Darbināt"
-#: ../gui/wxpython/gmodeler/model.py:2217
-#: ../gui/wxpython/gmodeler/frame.py:112
-#: ../gui/wxpython/gui_modules/gmodeler.py:837
-#: ../gui/wxpython/gui_modules/gmodeler.py:3951
+#: ../gui/wxpython/gmodeler/model.py:2579
+#: ../gui/wxpython/gmodeler/frame.py:127
 msgid "Variables"
 msgstr "Mainīgie"
-#: ../gui/wxpython/gmodeler/preferences.py:28
-#: ../gui/wxpython/menustrings.py:936
-#: ../gui/wxpython/gui_modules/gmodeler.py:3395
+#: ../gui/wxpython/menustrings.py:1687
 msgid "Modeler settings"
 msgstr "Modelētāja iestatījumi"
-#: ../gui/wxpython/gmodeler/preferences.py:45
-#: ../gui/wxpython/gui_modules/gmodeler.py:3412
-#: ../gui/wxpython/gui_modules/preferences.py:1272
-#: ../gui/wxpython/gui_modules/vdigit.py:151
-#: ../gui/wxpython/gui_core/preferences.py:274
-#: ../gui/wxpython/vdigit/preferences.py:118
+#: ../gui/wxpython/gmodeler/preferences.py:47
+#: ../gui/wxpython/gui_core/preferences.py:250
+#: ../gui/wxpython/animation/dialogs.py:289
+#: ../gui/wxpython/animation/dialogs.py:1487
+#: ../gui/wxpython/vdigit/preferences.py:122
 msgid "General"
 msgstr "Vispārēji"
-#: ../gui/wxpython/gmodeler/preferences.py:50
-#: ../gui/wxpython/gui_modules/gmodeler.py:3417
+#: ../gui/wxpython/gmodeler/preferences.py:52
 msgid "Item properties"
 msgstr "Vienuma īpašības"
-#: ../gui/wxpython/gmodeler/preferences.py:58
-#: ../gui/wxpython/gui_modules/gmodeler.py:3425
+#: ../gui/wxpython/gmodeler/preferences.py:59
 msgid "Disabled:"
 msgstr "Atslēgts:"
-#: ../gui/wxpython/gmodeler/preferences.py:83
-#: ../gui/wxpython/gui_modules/gmodeler.py:3450
-msgid "Action"
-msgstr "Darbība"
+#: ../gui/wxpython/gmodeler/preferences.py:85
+#: ../gui/wxpython/gmodeler/dialogs.py:160
+#: ../gui/wxpython/gmodeler/dialogs.py:437
+#: ../gui/wxpython/gmodeler/dialogs.py:540
+#: ../gui/wxpython/gmodeler/frame.py:1580
+msgid "Command"
+msgstr "Komanda"
-#: ../gui/wxpython/gmodeler/preferences.py:96
-#: ../gui/wxpython/gmodeler/preferences.py:334
-#: ../gui/wxpython/gui_modules/gmodeler.py:3463
-#: ../gui/wxpython/gui_modules/gmodeler.py:3701
+#: ../gui/wxpython/gmodeler/preferences.py:97
+#: ../gui/wxpython/gmodeler/preferences.py:335
+#: ../gui/wxpython/gmodeler/preferences.py:420
 msgid "Valid:"
 msgstr "Derīgs:"
-#: ../gui/wxpython/gmodeler/preferences.py:113
-#: ../gui/wxpython/gui_modules/gmodeler.py:3480
+#: ../gui/wxpython/gmodeler/preferences.py:114
 msgid "Invalid:"
 msgstr "Nederīgs:"
-#: ../gui/wxpython/gmodeler/preferences.py:130
-#: ../gui/wxpython/gui_modules/gmodeler.py:3497
+#: ../gui/wxpython/gmodeler/preferences.py:131
 msgid "Running:"
 msgstr "Darbojas:"
-#: ../gui/wxpython/gmodeler/preferences.py:150
-#: ../gui/wxpython/gmodeler/preferences.py:269
-#: ../gui/wxpython/gmodeler/preferences.py:354
-#: ../gui/wxpython/gui_modules/gmodeler.py:3517
-#: ../gui/wxpython/gui_modules/gmodeler.py:3636
-#: ../gui/wxpython/gui_modules/gmodeler.py:3721
+#: ../gui/wxpython/gmodeler/preferences.py:152
+#: ../gui/wxpython/gmodeler/preferences.py:271
+#: ../gui/wxpython/gmodeler/preferences.py:356
+#: ../gui/wxpython/gmodeler/preferences.py:441
 msgid "Shape size"
 msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:202
-#: ../gui/wxpython/nviz/tools.py:88
-#: ../gui/wxpython/gui_modules/gmodeler.py:3569
-#: ../gui/wxpython/gui_modules/nviz_tools.py:255
+#: ../gui/wxpython/gmodeler/preferences.py:204
+#: ../gui/wxpython/nviz/tools.py:92
 msgid "Data"
 msgstr "Dati"
-#: ../gui/wxpython/gmodeler/preferences.py:207
-#: ../gui/wxpython/gui_modules/gmodeler.py:3574
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:923
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:974
-#: ../gui/wxpython/dbmgr/manager.py:896 ../gui/wxpython/wxplot/dialogs.py:924
-#: ../gui/wxpython/wxplot/dialogs.py:975
+#: ../gui/wxpython/gmodeler/preferences.py:209
+#: ../gui/wxpython/web_services/widgets.py:845
+#: ../gui/wxpython/dbmgr/base.py:2045 ../gui/wxpython/dbmgr/dialogs.py:757
 msgid "Type"
 msgstr "Tips"
-#: ../gui/wxpython/gmodeler/preferences.py:215
-#: ../gui/wxpython/gui_modules/gmodeler.py:3582
+#: ../gui/wxpython/gmodeler/preferences.py:216
 msgid "Raster:"
 msgstr "Rastrs:"
-#: ../gui/wxpython/gmodeler/preferences.py:232
-#: ../gui/wxpython/gui_modules/gmodeler.py:3599
+#: ../gui/wxpython/gmodeler/preferences.py:233
 msgid "3D raster:"
 msgstr "3D rastrs:"
-#: ../gui/wxpython/gmodeler/preferences.py:249
-#: ../gui/wxpython/gui_modules/gmodeler.py:3616
+#: ../gui/wxpython/gmodeler/preferences.py:250
 msgid "Vector:"
 msgstr "Vektori:"
-#: ../gui/wxpython/gmodeler/preferences.py:321
-#: ../gui/wxpython/gui_modules/gmodeler.py:3688
+#: ../gui/wxpython/gmodeler/preferences.py:323
 msgid "Loop"
 msgstr "Cilpa"
-#: ../gui/wxpython/gmodeler/preferences.py:421
-#: ../gui/wxpython/menustrings.py:950
-#: ../gui/wxpython/gui_modules/gmodeler.py:3788
+#: ../gui/wxpython/gmodeler/preferences.py:408
+#, fuzzy
+msgid "Comment"
+msgstr "Komanda"
+#: ../gui/wxpython/gmodeler/preferences.py:508
+#: ../gui/wxpython/menustrings.py:1703
 msgid "Model properties"
 msgstr "Modeļa īpašības"
-#: ../gui/wxpython/gmodeler/preferences.py:428
-#: ../gui/wxpython/lmgr/layertree.py:417 ../gui/wxpython/lmgr/layertree.py:450
-#: ../gui/wxpython/gui_modules/gmodeler.py:3795
-#: ../gui/wxpython/gui_modules/layertree.py:383
-#: ../gui/wxpython/gui_modules/layertree.py:416
+#: ../gui/wxpython/gmodeler/preferences.py:515
+#: ../gui/wxpython/lmgr/layertree.py:539 ../gui/wxpython/lmgr/layertree.py:593
+#: ../gui/wxpython/lmgr/layertree.py:609
 msgid "Metadata"
 msgstr "Metadati"
-#: ../gui/wxpython/gmodeler/preferences.py:430
-#: ../gui/wxpython/gui_modules/gmodeler.py:3797
+#: ../gui/wxpython/gmodeler/preferences.py:517
 msgid "Commands"
 msgstr "Komandas"
-#: ../gui/wxpython/gmodeler/preferences.py:442
-#: ../gui/wxpython/gui_modules/gmodeler.py:3809
-#: ../gui/wxpython/gui_modules/gdialogs.py:1536
-#: ../gui/wxpython/gui_modules/vclean.py:144
-#: ../gui/wxpython/gui_modules/preferences.py:1724
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:228
-#: ../gui/wxpython/gui_core/preferences.py:798
-#: ../gui/wxpython/gui_core/dialogs.py:1626
-#: ../gui/wxpython/modules/vclean.py:135
-#: ../gui/wxpython/modules/mcalc_builder.py:224
-#: ../gui/wxpython/scripts/vkrige.py:139
+#: ../gui/wxpython/gmodeler/preferences.py:529
+#: ../gui/wxpython/gui_core/preferences.py:818
+#: ../gui/wxpython/gui_core/dialogs.py:1650
+#: ../gui/wxpython/modules/vclean.py:143
+#: ../gui/wxpython/modules/mcalc_builder.py:235
+#: ../gui/wxpython/scripts/vkrige.py:141
 msgid "Allow output files to overwrite existing files"
 msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:450
-#: ../gui/wxpython/gui_modules/gmodeler.py:3817
+#: ../gui/wxpython/gmodeler/preferences.py:537
 msgid "Apply properties"
 msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:464
-#: ../gui/wxpython/gui_modules/gselect.py:1224
-#: ../gui/wxpython/gui_modules/gselect.py:1227
-#: ../gui/wxpython/gui_modules/gselect.py:1236
-#: ../gui/wxpython/gui_modules/gselect.py:1373
-#: ../gui/wxpython/gui_modules/gmodeler.py:3831
-#: ../gui/wxpython/gui_core/gselect.py:1245
-#: ../gui/wxpython/gui_core/gselect.py:1248
-#: ../gui/wxpython/gui_core/gselect.py:1257
-#: ../gui/wxpython/gui_core/gselect.py:1258
-#: ../gui/wxpython/gui_core/gselect.py:1400
+#: ../gui/wxpython/gmodeler/preferences.py:549
+#: ../gui/wxpython/gui_core/gselect.py:1413
+#: ../gui/wxpython/gui_core/gselect.py:1423
+#: ../gui/wxpython/gui_core/gselect.py:1424
+#: ../gui/wxpython/gui_core/widgets.py:1043
+#: ../gui/wxpython/vnet/dialogs.py:1474
+#: ../gui/wxpython/animation/dialogs.py:333
 msgid "Name:"
 msgstr "Nosaukums:"
-#: ../gui/wxpython/gmodeler/preferences.py:473
-#: ../gui/wxpython/gui_modules/gmodeler.py:3840
+#: ../gui/wxpython/gmodeler/preferences.py:558
 msgid "Description:"
 msgstr "Apraksts:"
-#: ../gui/wxpython/gmodeler/preferences.py:482
-#: ../gui/wxpython/gui_modules/gmodeler.py:3849
+#: ../gui/wxpython/gmodeler/preferences.py:567
 msgid "Author(s):"
 msgstr "Autors:"
 #: ../gui/wxpython/gmodeler/dialogs.py:47
-#: ../gui/wxpython/gui_modules/gmodeler.py:2241
 msgid "Data properties"
 msgstr "Datu īpašības"
-#: ../gui/wxpython/gmodeler/dialogs.py:73
-#: ../gui/wxpython/gui_modules/gmodeler.py:2268
-#: ../gui/wxpython/iclass/dialogs.py:93
+#: ../gui/wxpython/gmodeler/dialogs.py:76
+#: ../gui/wxpython/iclass/dialogs.py:239
 msgid "Name of raster map:"
 msgstr "Rastra kartes nosaukums:"
-#: ../gui/wxpython/gmodeler/dialogs.py:75
-#: ../gui/wxpython/gui_modules/gmodeler.py:2270
-#: ../gui/wxpython/iclass/dialogs.py:95
+#: ../gui/wxpython/gmodeler/dialogs.py:78
+#: ../gui/wxpython/gui_core/dialogs.py:211
+#: ../gui/wxpython/iclass/dialogs.py:241
 msgid "Name of vector map:"
 msgstr "Vektoru kartes nosaukums:"
-#: ../gui/wxpython/gmodeler/dialogs.py:78
-#: ../gui/wxpython/gui_modules/gmodeler.py:2273
+#: ../gui/wxpython/gmodeler/dialogs.py:81
+#: ../gui/wxpython/gmodeler/dialogs.py:94
 msgid "Name of element:"
 msgstr "Elementa nosaukums:"
-#: ../gui/wxpython/gmodeler/dialogs.py:117
-#: ../gui/wxpython/gui_modules/gmodeler.py:2565
-msgid "Add new GRASS module to the model"
+#: ../gui/wxpython/gmodeler/dialogs.py:89
+msgid "Type of element:"
 msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:135
-#: ../gui/wxpython/gmodeler/dialogs.py:391
-#: ../gui/wxpython/gmodeler/dialogs.py:493
-#: ../gui/wxpython/gui_modules/gmodeler.py:2583
-#: ../gui/wxpython/gui_modules/gmodeler.py:4359
-#: ../gui/wxpython/gui_modules/gmodeler.py:4839
-#: ../gui/wxpython/gui_modules/preferences.py:1709
-#: ../gui/wxpython/gui_core/preferences.py:783
-msgid "Command"
-msgstr "Komanda"
+#: ../gui/wxpython/gmodeler/dialogs.py:141
+msgid "Add GRASS command to the model"
+msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:204
-#: ../gui/wxpython/gui_modules/gmodeler.py:2652
+#: ../gui/wxpython/gmodeler/dialogs.py:162
+msgid "Label and comment"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:199
+#: ../gui/wxpython/gmodeler/frame.py:1345
+#, fuzzy
+msgid "Label:"
+msgstr "Birka"
+#: ../gui/wxpython/gmodeler/dialogs.py:203
+#: ../gui/wxpython/gmodeler/frame.py:734
+#: ../gui/wxpython/gmodeler/frame.py:1357
+#, fuzzy
+msgid "Comment:"
+msgstr "Komanda:"
+#: ../gui/wxpython/gmodeler/dialogs.py:254
 msgid ""
 "Command not defined.\n"
 "\n"
 "Unable to add new action to the model."
 msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:210
-#: ../gui/wxpython/gui_modules/gmodeler.py:2658
+#: ../gui/wxpython/gmodeler/dialogs.py:260
 #, python-format
 msgid ""
 "'%s' is not a GRASS module.\n"
@@ -2674,345 +2191,243 @@
 msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:245
-#: ../gui/wxpython/gui_modules/gmodeler.py:2766
+#: ../gui/wxpython/gmodeler/dialogs.py:292
 msgid "Relation properties"
 msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:262
-#: ../gui/wxpython/gui_modules/gmodeler.py:2783
+#: ../gui/wxpython/gmodeler/dialogs.py:309
 msgid "From"
 msgstr "No"
-#: ../gui/wxpython/gmodeler/dialogs.py:264
-#: ../gui/wxpython/gui_modules/gmodeler.py:2785
-#: ../gui/wxpython/gui_modules/dbm.py:935 ../gui/wxpython/dbmgr/manager.py:944
+#: ../gui/wxpython/gmodeler/dialogs.py:311 ../gui/wxpython/dbmgr/base.py:2093
 msgid "To"
 msgstr "Uz"
-#: ../gui/wxpython/gmodeler/dialogs.py:306
-#: ../gui/wxpython/gui_modules/gmodeler.py:2827
+#: ../gui/wxpython/gmodeler/dialogs.py:353
 #, python-format
 msgid "Data: %s"
 msgstr "Dati: %s"
-#: ../gui/wxpython/gmodeler/dialogs.py:312
-#: ../gui/wxpython/gui_modules/gmodeler.py:2833
+#: ../gui/wxpython/gmodeler/dialogs.py:359
 msgid "Command:"
 msgstr "Komanda:"
-#: ../gui/wxpython/gmodeler/dialogs.py:318
-#: ../gui/wxpython/gui_modules/gmodeler.py:2839
+#: ../gui/wxpython/gmodeler/dialogs.py:365
 msgid "Option:"
 msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:333
-#: ../gui/wxpython/gui_modules/gmodeler.py:2854
+#: ../gui/wxpython/gmodeler/dialogs.py:380
 msgid ""
 "Relation doesn't start with data item.\n"
 "Unable to add relation."
 msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:340
-#: ../gui/wxpython/gui_modules/gmodeler.py:2861
+#: ../gui/wxpython/gmodeler/dialogs.py:387
 msgid ""
 "Relation doesn't point to GRASS command.\n"
 msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:353
-#: ../gui/wxpython/gui_modules/gmodeler.py:2874
+#: ../gui/wxpython/gmodeler/dialogs.py:400
 msgid ""
 "No relevant option found.\n"
 msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:384
-#: ../gui/wxpython/gui_modules/gmodeler.py:4352
+#: ../gui/wxpython/gmodeler/dialogs.py:431
 msgid "Condition"
 msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:390
-#: ../gui/wxpython/gmodeler/dialogs.py:492
-#: ../gui/wxpython/gmodeler/frame.py:1417
-#: ../gui/wxpython/gui_modules/gmodeler.py:4358
-#: ../gui/wxpython/gui_modules/gmodeler.py:4514
-#: ../gui/wxpython/gui_modules/gmodeler.py:4838
-msgid "ID"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1272
-#: ../gui/wxpython/gmodeler/frame.py:1315
-#: ../gui/wxpython/gui_modules/gmodeler.py:4040
-#: ../gui/wxpython/gui_modules/gmodeler.py:4083
-#: ../gui/wxpython/gui_modules/ghelp.py:705
-#: ../gui/wxpython/gui_modules/ghelp.py:707
-#: ../gui/wxpython/gui_modules/ghelp.py:768
-#: ../gui/wxpython/gui_core/ghelp.py:647 ../gui/wxpython/gui_core/ghelp.py:649
-#: ../gui/wxpython/gui_core/ghelp.py:712
-msgid "Name"
-msgstr "Nosaukums"
-#: ../gui/wxpython/gmodeler/dialogs.py:409
-#: ../gui/wxpython/gui_modules/gmodeler.py:4434
+#: ../gui/wxpython/gmodeler/dialogs.py:457
 msgid "Loop properties"
 msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:415
-#: ../gui/wxpython/gui_modules/gmodeler.py:4440
+#: ../gui/wxpython/gmodeler/dialogs.py:463
 msgid "List of items in loop"
 msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:418
-#: ../gui/wxpython/gui_modules/gmodeler.py:4443
+#: ../gui/wxpython/gmodeler/dialogs.py:466
 msgid "Series"
 msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:419
-#: ../gui/wxpython/gui_modules/gmodeler.py:4444
+#: ../gui/wxpython/gmodeler/dialogs.py:467
 msgid "Define map series as condition for the loop"
 msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:463
-#: ../gui/wxpython/gui_modules/gmodeler.py:4488
+#: ../gui/wxpython/gmodeler/dialogs.py:511
 msgid "Define series of maps"
 msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:478
-#: ../gui/wxpython/gui_modules/gmodeler.py:4824
+#: ../gui/wxpython/gmodeler/dialogs.py:526
 msgid "If-else properties"
 msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:484
-#: ../gui/wxpython/gui_modules/gmodeler.py:4830
+#: ../gui/wxpython/gmodeler/dialogs.py:532
 msgid "List of items in 'if' block"
 msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:489
-#: ../gui/wxpython/gui_modules/gmodeler.py:4835
+#: ../gui/wxpython/gmodeler/dialogs.py:537
 msgid "List of items in 'else' block"
 msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:653
-#: ../gui/wxpython/gui_modules/gmodeler.py:4217
+#: ../gui/wxpython/gmodeler/dialogs.py:700
 #, python-format
 msgid "Variable <%s> already exists in the model. Adding variable failed."
 msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:682
-#: ../gui/wxpython/gui_modules/gmodeler.py:4246
+#: ../gui/wxpython/gmodeler/dialogs.py:729
 msgid "Do you want to delete all variables from the model?"
 msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:684
-#: ../gui/wxpython/gui_modules/gmodeler.py:4248
+#: ../gui/wxpython/gmodeler/dialogs.py:731
 msgid "Delete variables"
 msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:723
-#: ../gui/wxpython/gmodeler/dialogs.py:897
-#: ../gui/wxpython/gui_modules/gmodeler.py:4287
-#: ../gui/wxpython/gui_modules/gmodeler.py:4698
-#: ../gui/wxpython/gui_modules/vdigit.py:1059
-#: ../gui/wxpython/vdigit/dialogs.py:272
+#: ../gui/wxpython/gmodeler/dialogs.py:770
+#: ../gui/wxpython/gmodeler/dialogs.py:921
+#: ../gui/wxpython/vdigit/dialogs.py:274
 msgid "Delete selected"
 msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:724
-#: ../gui/wxpython/gmodeler/dialogs.py:898
-#: ../gui/wxpython/gui_modules/gmodeler.py:4288
-#: ../gui/wxpython/gui_modules/gmodeler.py:4699
-#: ../gui/wxpython/gui_modules/vdigit.py:1063
-#: ../gui/wxpython/vdigit/dialogs.py:276
+#: ../gui/wxpython/gmodeler/dialogs.py:771
+#: ../gui/wxpython/vdigit/dialogs.py:278
 msgid "Delete all"
 msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:730
-#: ../gui/wxpython/gmodeler/dialogs.py:905
-#: ../gui/wxpython/gui_modules/gmodeler.py:4294
-#: ../gui/wxpython/gui_modules/gmodeler.py:4706
-#: ../gui/wxpython/gui_modules/dbm.py:1145
-#: ../gui/wxpython/gui_modules/dbm.py:1660
-#: ../gui/wxpython/gui_modules/vdigit.py:1065
-#: ../gui/wxpython/dbmgr/manager.py:1149 ../gui/wxpython/dbmgr/manager.py:1675
-#: ../gui/wxpython/vdigit/dialogs.py:278
+#: ../gui/wxpython/gmodeler/dialogs.py:777
+#: ../gui/wxpython/gmodeler/dialogs.py:925 ../gui/wxpython/dbmgr/base.py:1258
+#: ../gui/wxpython/dbmgr/base.py:2249 ../gui/wxpython/vdigit/dialogs.py:280
 msgid "Reload"
 msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:847
-#: ../gui/wxpython/gui_modules/gmodeler.py:4648
-#: ../gui/wxpython/gui_modules/dbm.py:1177
-#, python-format
-msgid ""
-"Selected data records (%d) will permanently deleted from table. Do you want "
-"to delete them?"
-msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:836
+#: ../gui/wxpython/location_wizard/wizard.py:776
+#: ../gui/wxpython/gui_core/gselect.py:1904
+msgid "No"
+msgstr "Nē"
-#: ../gui/wxpython/gmodeler/dialogs.py:850
-#: ../gui/wxpython/gui_modules/gmodeler.py:4651
-#: ../gui/wxpython/gui_modules/dbm.py:1180
-#: ../gui/wxpython/gui_modules/dbm.py:1226
-#: ../gui/wxpython/dbmgr/manager.py:1184 ../gui/wxpython/dbmgr/manager.py:1230
-msgid "Delete records"
-msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:838
+#: ../gui/wxpython/gui_core/gselect.py:1906
+msgid "Yes"
+msgstr "Jā"
-#: ../gui/wxpython/gmodeler/dialogs.py:904
-#: ../gui/wxpython/gui_modules/gmodeler.py:4705
-msgid "Normalize"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:59
-#: ../gui/wxpython/gui_modules/gmodeler.py:786
+#: ../gui/wxpython/gmodeler/frame.py:62
 msgid "GRASS GIS Graphical Modeler"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:110
-#: ../gui/wxpython/gui_modules/gmodeler.py:835
+#: ../gui/wxpython/gmodeler/frame.py:125
 msgid "Model"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:111
-#: ../gui/wxpython/gui_modules/gmodeler.py:836
+#: ../gui/wxpython/gmodeler/frame.py:126
 msgid "Items"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:113
+#: ../gui/wxpython/gmodeler/frame.py:128
 msgid "Python editor"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:114
-#: ../gui/wxpython/gui_modules/gmodeler.py:838
-#: ../gui/wxpython/gui_modules/menuform.py:842
-#: ../gui/wxpython/gui_core/forms.py:801 ../gui/wxpython/scripts/vkrige.py:108
+#: ../gui/wxpython/gmodeler/frame.py:129
+#: ../gui/wxpython/gui_core/forms.py:1782
+#: ../gui/wxpython/scripts/vkrige.py:106
 msgid "Command output"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:179
-#: ../gui/wxpython/gui_core/goutput.py:1358
+#: ../gui/wxpython/gmodeler/frame.py:198
 msgid "Python script contains local modifications"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:181
-#: ../gui/wxpython/gmodeler/frame.py:1601
+#: ../gui/wxpython/gmodeler/frame.py:200
+#: ../gui/wxpython/gmodeler/frame.py:1812
 msgid "Python script is up-to-date"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:196
-#: ../gui/wxpython/gui_modules/gmodeler.py:905
+#: ../gui/wxpython/gmodeler/frame.py:215
 msgid "Redrawing model..."
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:231
-#: ../gui/wxpython/gui_modules/gmodeler.py:937
+#: ../gui/wxpython/gmodeler/frame.py:251
 msgid "Do you want to save changes in the model?"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:233
-#: ../gui/wxpython/gui_modules/gmodeler.py:939
+#: ../gui/wxpython/gmodeler/frame.py:253
 msgid "Do you want to store current model settings to model file?"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:239
-#: ../gui/wxpython/gui_modules/gmodeler.py:945
+#: ../gui/wxpython/gmodeler/frame.py:259
 msgid "Quit Graphical Modeler"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:300
+#: ../gui/wxpython/gmodeler/frame.py:313
 msgid "No intermediate data to delete."
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:304
-#: ../gui/wxpython/gui_modules/gmodeler.py:1010
+#: ../gui/wxpython/gmodeler/frame.py:317
 #, python-format
 msgid "Do you want to permanently delete data?%s"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:305
-#: ../gui/wxpython/gui_modules/gmodeler.py:1011
+#: ../gui/wxpython/gmodeler/frame.py:318
 msgid "Delete intermediate data?"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:319
-#: ../gui/wxpython/gui_modules/gmodeler.py:1025
+#: ../gui/wxpython/gmodeler/frame.py:332
 #, python-format
 msgid "%d maps deleted from current mapset"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:334 ../gui/wxpython/gmodeler/frame.py:449
-#: ../gui/wxpython/gui_modules/gmodeler.py:1040
-#: ../gui/wxpython/gui_modules/gmodeler.py:1155
+#: ../gui/wxpython/gmodeler/frame.py:347 ../gui/wxpython/gmodeler/frame.py:473
 msgid ""
 "Current model is not empty. Do you want to store current settings to model "
 "file?"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:337 ../gui/wxpython/gmodeler/frame.py:452
-#: ../gui/wxpython/gui_modules/gmodeler.py:1043
-#: ../gui/wxpython/gui_modules/gmodeler.py:1158
+#: ../gui/wxpython/gmodeler/frame.py:350 ../gui/wxpython/gmodeler/frame.py:476
 msgid "Create new model?"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:364
-#: ../gui/wxpython/gui_modules/gmodeler.py:1070
+#: ../gui/wxpython/gmodeler/frame.py:388
 msgid "Choose model file"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:366 ../gui/wxpython/gmodeler/frame.py:410
-#: ../gui/wxpython/lmgr/frame.py:392
-#: ../gui/wxpython/gui_modules/gmodeler.py:1072
-#: ../gui/wxpython/gui_modules/gmodeler.py:1116
+#: ../gui/wxpython/gmodeler/frame.py:390 ../gui/wxpython/gmodeler/frame.py:434
+#: ../gui/wxpython/lmgr/frame.py:492
 msgid "GRASS Model File (*.gxm)|*.gxm"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:382
-#: ../gui/wxpython/gui_modules/gmodeler.py:1088
+#: ../gui/wxpython/gmodeler/frame.py:406
 #, python-format
 msgid "%(items)d items (%(actions)d actions) loaded into model"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:389 ../gui/wxpython/gmodeler/frame.py:426
-#: ../gui/wxpython/gui_modules/gmodeler.py:1095
-#: ../gui/wxpython/gui_modules/gmodeler.py:1132
+#: ../gui/wxpython/gmodeler/frame.py:413 ../gui/wxpython/gmodeler/frame.py:450
 #, python-format
 msgid "Model file <%s> already exists. Do you want to overwrite this file?"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:392 ../gui/wxpython/menustrings.py:923
-#: ../gui/wxpython/gui_modules/gmodeler.py:1098
+#: ../gui/wxpython/gmodeler/frame.py:416 ../gui/wxpython/menustrings.py:1674
 msgid "Save model"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:399 ../gui/wxpython/gmodeler/frame.py:439
-#: ../gui/wxpython/gui_modules/gmodeler.py:1105
-#: ../gui/wxpython/gui_modules/gmodeler.py:1145
+#: ../gui/wxpython/gmodeler/frame.py:423 ../gui/wxpython/gmodeler/frame.py:463
 #, python-format
 msgid "File <%s> saved"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:408
-#: ../gui/wxpython/gui_modules/gmodeler.py:1114
+#: ../gui/wxpython/gmodeler/frame.py:432
 msgid "Choose file to save current model"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:428
-#: ../gui/wxpython/gui_modules/gmodeler.py:1134
-#: ../gui/wxpython/iclass/frame.py:892
+#: ../gui/wxpython/gmodeler/frame.py:452 ../gui/wxpython/iclass/frame.py:1012
 msgid "File already exists"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:497
-#: ../gui/wxpython/gui_modules/gmodeler.py:1203
+#: ../gui/wxpython/gmodeler/frame.py:524
 msgid "Model is empty. Nothing to validate."
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:507
-#: ../gui/wxpython/gui_modules/gmodeler.py:1213
+#: ../gui/wxpython/gmodeler/frame.py:534
 #, python-format
 msgid ""
 "Model is not valid.\n"
@@ -3020,596 +2435,579 @@
 "%s"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:510
-#: ../gui/wxpython/gui_modules/gmodeler.py:1216
+#: ../gui/wxpython/gmodeler/frame.py:537
 msgid "Model is valid."
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:571 ../gui/wxpython/gmodeler/frame.py:578
-#: ../gui/wxpython/gui_modules/gmodeler.py:1277
-#: ../gui/wxpython/gui_modules/gmodeler.py:1320
+#: ../gui/wxpython/gmodeler/frame.py:598 ../gui/wxpython/gmodeler/frame.py:605
 #, python-format
 msgid "Model exported to <%s>"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:703
-#: ../gui/wxpython/gui_modules/gmodeler.py:1445
-msgid "wxGUI Graphical Modeler"
+#: ../gui/wxpython/gmodeler/frame.py:734 ../gui/wxpython/menustrings.py:1699
+#, fuzzy
+msgid "Add comment"
+msgstr "Pievienot kolonu"
+#: ../gui/wxpython/gmodeler/frame.py:739
+msgid "Empty comment. Nothing to add to the model."
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:706
-#: ../gui/wxpython/gui_modules/gmodeler.py:1448
-#, python-format
-msgid ""
-"(C) 2010-%s by the GRASS Development Team\n"
-"\n"
+#: ../gui/wxpython/gmodeler/frame.py:771
+msgid "wxGUI Graphical Modeler"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:804
-#: ../gui/wxpython/gui_modules/gmodeler.py:1546
+#: ../gui/wxpython/gmodeler/frame.py:866
 #, python-format
 msgid ""
 "Reading model file <%s> failed.\n"
-"Invalid file, unable to parse XML document."
+"Invalid file, unable to parse XML document.\n"
+"\n"
+"%s"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:810
-#: ../gui/wxpython/gui_modules/gmodeler.py:1552
+#: ../gui/wxpython/gmodeler/frame.py:875
 msgid "Please wait, loading model..."
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:870
-#: ../gui/wxpython/gui_modules/gmodeler.py:1612
+#: ../gui/wxpython/gmodeler/frame.py:941
 msgid "Writing current settings to model file failed."
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:880 ../gui/wxpython/lmgr/frame.py:1078
-#: ../gui/wxpython/gui_modules/gmodeler.py:1622
-#: ../gui/wxpython/gui_modules/wxplot.py:1041
-#: ../gui/wxpython/wxplot/profile.py:345
+#: ../gui/wxpython/gmodeler/frame.py:951 ../gui/wxpython/lmgr/frame.py:1340
 #, python-format
 msgid "Unable to open file <%s> for writing."
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1176
-#: ../gui/wxpython/lmgr/layertree.py:310
-#: ../gui/wxpython/gui_modules/gmodeler.py:2481
-#: ../gui/wxpython/gui_modules/layertree.py:277
+#: ../gui/wxpython/gmodeler/frame.py:1283 ../gui/wxpython/menustrings.py:1585
+#: ../gui/wxpython/lmgr/layertree.py:394
+#: ../gui/wxpython/gui_core/simplelmgr.py:417
+#: ../gui/wxpython/animation/dialogs.py:631
+#: ../gui/wxpython/animation/dialogs.py:822
+#: ../gui/wxpython/rlisetup/frame.py:45
 msgid "Remove"
 msgstr "Noņemt"
-#: ../gui/wxpython/gmodeler/frame.py:1180
-#: ../gui/wxpython/gui_modules/gmodeler.py:2485
+#: ../gui/wxpython/gmodeler/frame.py:1287
 msgid "Disable"
 msgstr "Atslēgt"
-#: ../gui/wxpython/gmodeler/frame.py:1183
-#: ../gui/wxpython/gui_modules/gmodeler.py:2488
+#: ../gui/wxpython/gmodeler/frame.py:1290
 msgid "Enable"
 msgstr "Ieslēgt"
-#: ../gui/wxpython/gmodeler/frame.py:1188
-#: ../gui/wxpython/gui_modules/gmodeler.py:2493
+#: ../gui/wxpython/gmodeler/frame.py:1295
+#, fuzzy
+msgid "Set label"
+msgstr "Rediģēt birku"
+#: ../gui/wxpython/gmodeler/frame.py:1298
+#, fuzzy
+msgid "Set comment"
+msgstr "Iestatīt fontu"
+#: ../gui/wxpython/gmodeler/frame.py:1303
 msgid "Add control point"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1190
-#: ../gui/wxpython/gui_modules/gmodeler.py:2495
+#: ../gui/wxpython/gmodeler/frame.py:1305
 msgid "Remove control point"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1197
-#: ../gui/wxpython/gui_modules/gmodeler.py:2502
+#: ../gui/wxpython/gmodeler/frame.py:1312
 msgid "Intermediate"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1208
-#: ../gui/wxpython/lmgr/layertree.py:324
-#: ../gui/wxpython/gui_modules/gmodeler.py:2513
-#: ../gui/wxpython/gui_modules/layertree.py:291
+#: ../gui/wxpython/gmodeler/frame.py:1323
+#: ../gui/wxpython/lmgr/layertree.py:422
 msgid "Properties"
 msgstr "Īpašības"
-#: ../gui/wxpython/gmodeler/frame.py:1269
-#: ../gui/wxpython/gui_modules/gmodeler.py:4037
+#: ../gui/wxpython/gmodeler/frame.py:1429
 msgid "List of variables - right-click to delete"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1322
-#: ../gui/wxpython/gui_modules/gmodeler.py:4090
-#: ../gui/wxpython/gui_modules/dbm.py:881
-#: ../gui/wxpython/gui_modules/dbm.py:2235
-#: ../gui/wxpython/dbmgr/manager.py:2260
+#: ../gui/wxpython/gmodeler/frame.py:1432
+#: ../gui/wxpython/gmodeler/frame.py:1476
+#: ../gui/wxpython/web_services/widgets.py:844
+#: ../gui/wxpython/gui_core/ghelp.py:337 ../gui/wxpython/gui_core/ghelp.py:339
+#: ../gui/wxpython/gui_core/ghelp.py:402
+msgid "Name"
+msgstr "Nosaukums"
+#: ../gui/wxpython/gmodeler/frame.py:1483 ../gui/wxpython/dbmgr/base.py:2522
 msgid "Data type"
 msgstr "Datu tips"
-#: ../gui/wxpython/gmodeler/frame.py:1273
-#: ../gui/wxpython/gmodeler/frame.py:1328
-#: ../gui/wxpython/gui_modules/gmodeler.py:4041
-#: ../gui/wxpython/gui_modules/gmodeler.py:4096
+#: ../gui/wxpython/gmodeler/frame.py:1433
+#: ../gui/wxpython/gmodeler/frame.py:1489
 msgid "Default value"
 msgstr "Noklusējuma vērtība"
-#: ../gui/wxpython/gmodeler/frame.py:1335
-#: ../gui/wxpython/gui_modules/gmodeler.py:4103
-#: ../gui/wxpython/gui_modules/location_wizard.py:373
-#: ../gui/wxpython/gui_modules/location_wizard.py:874
-#: ../gui/wxpython/gui_modules/location_wizard.py:1037
-#: ../gui/wxpython/gui_modules/location_wizard.py:1302
-#: ../gui/wxpython/location_wizard/wizard.py:337
-#: ../gui/wxpython/location_wizard/wizard.py:838
-#: ../gui/wxpython/location_wizard/wizard.py:1007
-#: ../gui/wxpython/location_wizard/wizard.py:1312
+#: ../gui/wxpython/gmodeler/frame.py:1496
+#: ../gui/wxpython/location_wizard/wizard.py:351
+#: ../gui/wxpython/location_wizard/wizard.py:852
+#: ../gui/wxpython/location_wizard/wizard.py:1024
+#: ../gui/wxpython/location_wizard/wizard.py:1335
 msgid "Description"
 msgstr "Apraksts"
-#: ../gui/wxpython/gmodeler/frame.py:1277
-#: ../gui/wxpython/gui_modules/gmodeler.py:4045
+#: ../gui/wxpython/gmodeler/frame.py:1438
 msgid "Add new variable"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1281
-#: ../gui/wxpython/gui_modules/gmodeler.py:4049
+#: ../gui/wxpython/gmodeler/frame.py:1442
 msgid "integer"
 msgstr "vesels skaitlis"
-#: ../gui/wxpython/gmodeler/frame.py:1282
-#: ../gui/wxpython/gui_modules/gmodeler.py:4050
+#: ../gui/wxpython/gmodeler/frame.py:1443
 msgid "float"
 msgstr "daļskaitlis"
-#: ../gui/wxpython/gmodeler/frame.py:1283
-#: ../gui/wxpython/gui_modules/gmodeler.py:4051
+#: ../gui/wxpython/gmodeler/frame.py:1444
 msgid "string"
 msgstr "teksts"
-#: ../gui/wxpython/gmodeler/frame.py:1286
-#: ../gui/wxpython/gui_modules/gmodeler.py:4054
+#: ../gui/wxpython/gmodeler/frame.py:1447
+#, fuzzy
+msgid "region"
+msgstr "Reģions"
+#: ../gui/wxpython/gmodeler/frame.py:1448
 msgid "mapset"
 msgstr "karšu kopa"
-#: ../gui/wxpython/gmodeler/frame.py:1287
-#: ../gui/wxpython/gui_modules/gmodeler.py:4055
+#: ../gui/wxpython/gmodeler/frame.py:1449
+#: ../gui/wxpython/gui_core/forms.py:1484
 msgid "file"
 msgstr "fails"
-#: ../gui/wxpython/gmodeler/frame.py:1294
-#: ../gui/wxpython/gui_modules/gmodeler.py:4062
+#: ../gui/wxpython/gmodeler/frame.py:1456
 msgid "Add new variable to the model"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1414
-#: ../gui/wxpython/gui_modules/gmodeler.py:4511
+#: ../gui/wxpython/gmodeler/frame.py:1576
 msgid "List of items - right-click to delete"
 msgstr ""
-msgid "In block"
-msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1579
+#, fuzzy
+msgid "In loop"
+msgstr "cilpa"
-#: ../gui/wxpython/gmodeler/frame.py:1418
-#: ../gui/wxpython/gui_modules/gmodeler.py:4515
-msgid "Command / Condition"
-msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1628
+#, fuzzy
+msgid "No items to selected."
+msgstr "Tuvināt līdz izvēlētajām kartēm"
-#: ../gui/wxpython/gmodeler/frame.py:1451
+#: ../gui/wxpython/gmodeler/frame.py:1662
 msgid "Python script"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1455
+#: ../gui/wxpython/gmodeler/frame.py:1666
 msgid "Run python script"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1458
+#: ../gui/wxpython/gmodeler/frame.py:1669
 msgid "Save python script to file"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1461
+#: ../gui/wxpython/gmodeler/frame.py:1672
 msgid ""
 "Refresh python script based on the model.\n"
 "It will discards all local changes."
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1499
+#: ../gui/wxpython/gmodeler/frame.py:1710
 #, python-format
 msgid "Unable to launch Python script. %s"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1524
-#: ../gui/wxpython/gui_modules/gmodeler.py:1285
+#: ../gui/wxpython/gmodeler/frame.py:1734
 msgid "Choose file to save"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1526
-#: ../gui/wxpython/gui_modules/gmodeler.py:1287
+#: ../gui/wxpython/gmodeler/frame.py:1737
 msgid "Python script (*.py)|*.py"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1540
-#: ../gui/wxpython/gui_modules/gmodeler.py:1301
+#: ../gui/wxpython/gmodeler/frame.py:1751
+#: ../gui/wxpython/wxplot/profile.py:348
 #, python-format
 msgid "File <%s> already exists. Do you want to overwrite this file?"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1542
-#: ../gui/wxpython/gui_modules/gmodeler.py:1303
+#: ../gui/wxpython/gmodeler/frame.py:1753
 msgid "Save file"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1577
+#: ../gui/wxpython/gmodeler/frame.py:1788
 msgid ""
 "Python script is locally modificated. Refresh will discard all changes. Do "
 "you really want to continue?"
 msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1580
+#: ../gui/wxpython/gmodeler/frame.py:1791
 msgid "Update"
 msgstr "Atjaunināt"
-#: ../gui/wxpython/menustrings.py:2 ../gui/wxpython/menustrings.py:917
+#: ../gui/wxpython/menustrings.py:3 ../gui/wxpython/menustrings.py:1668
+#: ../gui/wxpython/menustrings.py:1718
 msgid "&File"
 msgstr "&Fails"
-#: ../gui/wxpython/menustrings.py:3
+#: ../gui/wxpython/menustrings.py:4
 msgid "Workspace"
 msgstr "Darbtelpa"
-#: ../gui/wxpython/menustrings.py:4 ../gui/wxpython/menustrings.py:918
-#: ../gui/wxpython/nviz/tools.py:1074
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1244
+#: ../gui/wxpython/menustrings.py:5 ../gui/wxpython/menustrings.py:1669
+#: ../gui/wxpython/nviz/tools.py:1094
 msgid "New"
 msgstr "Jauns"
-#: ../gui/wxpython/menustrings.py:5
+#: ../gui/wxpython/menustrings.py:6
 msgid "Create new workspace"
 msgstr "Izveidot jaunu darbtelpu"
-#: ../gui/wxpython/menustrings.py:6 ../gui/wxpython/menustrings.py:920
+#: ../gui/wxpython/menustrings.py:7 ../gui/wxpython/menustrings.py:1671
 msgid "Open"
 msgstr "Atvērt"
-#: ../gui/wxpython/menustrings.py:7
+#: ../gui/wxpython/menustrings.py:8
 msgid "Load workspace from file"
 msgstr "Ielādēt darbtelpu no faila"
-#: ../gui/wxpython/menustrings.py:8 ../gui/wxpython/menustrings.py:922
-#: ../gui/wxpython/gui_modules/colorrules.py:407
-#: ../gui/wxpython/modules/colorrules.py:410
+#: ../gui/wxpython/menustrings.py:9 ../gui/wxpython/menustrings.py:1673
+#: ../gui/wxpython/modules/colorrules.py:416
 msgid "Save"
 msgstr "Saglabāt"
-#: ../gui/wxpython/menustrings.py:9 ../gui/wxpython/lmgr/frame.py:1029
-#: ../gui/wxpython/lmgr/frame.py:1046
+#: ../gui/wxpython/menustrings.py:10 ../gui/wxpython/lmgr/frame.py:1291
+#: ../gui/wxpython/lmgr/frame.py:1308
 msgid "Save workspace"
 msgstr "Saglabāt darbtelpu"
-#: ../gui/wxpython/menustrings.py:10 ../gui/wxpython/menustrings.py:924
+#: ../gui/wxpython/menustrings.py:11 ../gui/wxpython/menustrings.py:1675
 msgid "Save as"
 msgstr "Saglabāt kā"
-#: ../gui/wxpython/menustrings.py:11
+#: ../gui/wxpython/menustrings.py:12
 msgid "Save workspace to file"
 msgstr "Saglabāt darbtelpu failā"
-#: ../gui/wxpython/menustrings.py:12 ../gui/wxpython/menustrings.py:926
+#: ../gui/wxpython/menustrings.py:13 ../gui/wxpython/menustrings.py:1677
+#: ../gui/wxpython/mapswipe/dialogs.py:162
 msgid "Close"
 msgstr "Aizvērt"
-#: ../gui/wxpython/menustrings.py:13
+#: ../gui/wxpython/menustrings.py:14
 msgid "Close workspace file"
 msgstr "Aizvērt darbtelpas failu"
-#: ../gui/wxpython/menustrings.py:14
+#: ../gui/wxpython/menustrings.py:15
 msgid "Load GRC file (Tcl/Tk GUI)"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:15
 msgid "Load map layers from GRC file to layer tree"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:16
 msgid "Map display"
 msgstr "Kartes skats"
-#: ../gui/wxpython/menustrings.py:17
+#: ../gui/wxpython/menustrings.py:18
 msgid "Add raster"
 msgstr "Pievienot rastru"
-#: ../gui/wxpython/menustrings.py:18
+#: ../gui/wxpython/menustrings.py:19
 msgid "Add raster map layer to current display"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:19
+#: ../gui/wxpython/menustrings.py:20
 msgid "Add vector"
 msgstr "Pievienot vektorus"
-#: ../gui/wxpython/menustrings.py:20
+#: ../gui/wxpython/menustrings.py:21
 msgid "Add vector map layer to current display"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:21
+#: ../gui/wxpython/menustrings.py:22
 msgid "Add multiple rasters or vectors"
 msgstr "Pievienot vairākas rastra vai vektoru kartes"
-#: ../gui/wxpython/menustrings.py:22
+#: ../gui/wxpython/menustrings.py:23
 msgid "Add multiple raster or vector map layers to current display"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:23
+#: ../gui/wxpython/menustrings.py:24
 msgid "New map display window"
 msgstr "Jauns kartes skata logs"
-#: ../gui/wxpython/menustrings.py:24
+#: ../gui/wxpython/menustrings.py:25
 msgid "Open new map display window"
 msgstr "Atver jaunu kartes skata logu"
-#: ../gui/wxpython/menustrings.py:25 ../gui/wxpython/menustrings.py:26
+#: ../gui/wxpython/menustrings.py:26 ../gui/wxpython/menustrings.py:27
 msgid "Close current map display window"
 msgstr "Aizvērt pašreizējo kartes skata logu"
-#: ../gui/wxpython/menustrings.py:27 ../gui/wxpython/menustrings.py:28
+#: ../gui/wxpython/menustrings.py:28 ../gui/wxpython/menustrings.py:29
 msgid "Close all open map display windows"
 msgstr "Aizvērt visus šobrīd atvērtos kartes skata logus"
-#: ../gui/wxpython/menustrings.py:29 ../gui/wxpython/lmgr/layertree.py:51
-#: ../gui/wxpython/gui_modules/gdialogs.py:1705
-#: ../gui/wxpython/gui_core/dialogs.py:1795
+#: ../gui/wxpython/menustrings.py:30 ../gui/wxpython/lmgr/layertree.py:56
+#: ../gui/wxpython/gui_core/dialogs.py:1820
 msgid "Import raster data"
 msgstr "Rastra datu importēšana"
-#: ../gui/wxpython/menustrings.py:30
+#: ../gui/wxpython/menustrings.py:31
 msgid "Common formats import"
 msgstr "Biežāk sastopamie formāti"
-#: ../gui/wxpython/menustrings.py:31
+#: ../gui/wxpython/menustrings.py:32
 msgid "Import raster data into a GRASS map layer using GDAL."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:32
+#: ../gui/wxpython/menustrings.py:33
 msgid "ASCII x,y,z point import and gridding"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:33
+#: ../gui/wxpython/menustrings.py:34
 msgid ""
-"Create a raster map from an assemblage of many coordinates using univariate "
+"Creates a raster map from an assemblage of many coordinates using univariate "
 "statistics."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:34
+#: ../gui/wxpython/menustrings.py:35
 msgid "ASCII grid import"
 msgstr "ASCII tīkla imports"
-#: ../gui/wxpython/menustrings.py:35
+#: ../gui/wxpython/menustrings.py:36
 msgid "Converts a GRASS ASCII raster file to binary raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:36
+#: ../gui/wxpython/menustrings.py:37
 msgid "ASCII polygons, lines, and point import"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:37
+#: ../gui/wxpython/menustrings.py:38
 msgid "Creates raster maps from ASCII polygon/line/point data files."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:38
+#: ../gui/wxpython/menustrings.py:39
 msgid "Raw binary array import"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:39
+#: ../gui/wxpython/menustrings.py:40
 msgid "Import a binary raster file into a GRASS raster map layer."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:40
+#: ../gui/wxpython/menustrings.py:41
 msgid "ESRI ASCII grid import"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:41
-msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a GRASS raster map."
+#: ../gui/wxpython/menustrings.py:42
+msgid ""
+"Converts an ESRI ARC/INFO ascii raster file (GRID) into a GRASS raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:42
+#: ../gui/wxpython/menustrings.py:43
 msgid "GRIDATB.FOR import"
 msgstr "GRIDATB.FOR importēšana"
-#: ../gui/wxpython/menustrings.py:43
-msgid "Imports GRIDATB.FOR map file (TOPMODEL) into GRASS raster map"
+#: ../gui/wxpython/menustrings.py:44
+msgid "Imports GRIDATB.FOR map file (TOPMODEL) into a GRASS raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:44
+#: ../gui/wxpython/menustrings.py:45
 msgid "Matlab 2D array import"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:45
+#: ../gui/wxpython/menustrings.py:46
 msgid "Imports a binary MAT-File(v4) to a GRASS raster."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:46
+#: ../gui/wxpython/menustrings.py:47
 msgid "PNG import"
 msgstr "PNG importēšana"
-#: ../gui/wxpython/menustrings.py:47
+#: ../gui/wxpython/menustrings.py:48
 msgid "Imports non-georeferenced PNG format image."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:48
+#: ../gui/wxpython/menustrings.py:49
 msgid "SPOT NDVI import"
 msgstr "SPOT NDVI importēšana"
-#: ../gui/wxpython/menustrings.py:49
+#: ../gui/wxpython/menustrings.py:50
 msgid "Imports SPOT VGT NDVI data into a raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:50
+#: ../gui/wxpython/menustrings.py:51
 msgid "SRTM HGT import"
 msgstr "SRTM HGT importēšana"
-#: ../gui/wxpython/menustrings.py:51
+#: ../gui/wxpython/menustrings.py:52
 msgid "Imports SRTM HGT files into raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:52
+#: ../gui/wxpython/menustrings.py:53
 msgid "Terra ASTER HDF import"
 msgstr "Terra ASTER HDF importēšana"
-#: ../gui/wxpython/menustrings.py:53
+#: ../gui/wxpython/menustrings.py:54
 msgid ""
 "Georeference, rectify, and import Terra-ASTER imagery and relative DEMs "
 "using gdalwarp."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:54 ../gui/wxpython/menustrings.py:85
+#: ../gui/wxpython/menustrings.py:55 ../gui/wxpython/menustrings.py:82
 msgid "LAS LiDAR points import"
 msgstr "LAS LiDAR punktu importēšana"
-#: ../gui/wxpython/menustrings.py:55
-msgid "Create a raster map from LAS LiDAR points using univariate statistics."
-msgstr ""
 #: ../gui/wxpython/menustrings.py:56
-msgid "WMS import"
-msgstr "WMS importēšana"
-#: ../gui/wxpython/menustrings.py:57
-msgid "Download and import data from WMS servers."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:58
 msgid "Unpack raster map"
 msgstr "Atpakot rastra karti"
-#: ../gui/wxpython/menustrings.py:59
+#: ../gui/wxpython/menustrings.py:57
 msgid "Unpacks a raster map packed with r.pack."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:60 ../gui/wxpython/lmgr/layertree.py:57
-#: ../gui/wxpython/gui_modules/gdialogs.py:1699
-#: ../gui/wxpython/gui_core/dialogs.py:1789
+#: ../gui/wxpython/menustrings.py:58 ../gui/wxpython/lmgr/layertree.py:62
+#: ../gui/wxpython/gui_core/dialogs.py:1814
 msgid "Import vector data"
 msgstr "Vektordatu importēšana"
-#: ../gui/wxpython/menustrings.py:61
+#: ../gui/wxpython/menustrings.py:59
 msgid "Common import formats"
-#: ../gui/wxpython/menustrings.py:62
+#: ../gui/wxpython/menustrings.py:60
 msgid "Converts vector layers into a GRASS vector map using OGR."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:63
+#: ../gui/wxpython/menustrings.py:61
 msgid "ASCII points or GRASS ASCII format"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:64
+#: ../gui/wxpython/menustrings.py:62
 msgid "Creates a vector map from an ASCII points file or ASCII vector file."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:65
+#: ../gui/wxpython/menustrings.py:63
 msgid "ASCII points as a vector lines"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:66
+#: ../gui/wxpython/menustrings.py:64
 msgid "Imports ASCII x,y[,z] coordinates as a series of lines."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:67
+#: ../gui/wxpython/menustrings.py:65
 msgid "Historical GRASS vector import"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:68
+#: ../gui/wxpython/menustrings.py:66
 msgid "Imports older versions of GRASS vector maps."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:69
+#: ../gui/wxpython/menustrings.py:67
 msgid "Historical GRASS vector import (all maps)"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:70
+#: ../gui/wxpython/menustrings.py:68
 msgid ""
 "Converts all older versions of GRASS vector maps in current mapset to "
 "current format."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:71
+#: ../gui/wxpython/menustrings.py:69
 msgid "DXF import"
 msgstr "DXF imports"
-#: ../gui/wxpython/menustrings.py:72
+#: ../gui/wxpython/menustrings.py:70
 msgid "Converts files in DXF format to GRASS vector map format."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:73
+#: ../gui/wxpython/menustrings.py:71
 msgid "WFS"
 msgstr "WFS"
-#: ../gui/wxpython/menustrings.py:74
-msgid "Imports GetFeature from WFS."
+#: ../gui/wxpython/menustrings.py:72
+msgid "Imports GetFeature from a WFS server."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:75
+#: ../gui/wxpython/menustrings.py:73
 msgid "ESRI e00 import"
 msgstr "ESRI e00 imports"
-#: ../gui/wxpython/menustrings.py:76
+#: ../gui/wxpython/menustrings.py:74
 msgid "Imports E00 file into a vector map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:77
+#: ../gui/wxpython/menustrings.py:75
 msgid "GPS data import"
 msgstr "GPS datu imports"
-#: ../gui/wxpython/menustrings.py:78
-msgid ""
-"Import waypoints, routes, and tracks from a GPS receiver or many common GPS "
-"file formats."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:79
+#: ../gui/wxpython/menustrings.py:76
 msgid "Geonames import"
 msgstr "Geonames imports"
-#: ../gui/wxpython/menustrings.py:80
+#: ../gui/wxpython/menustrings.py:77
 msgid "Imports geonames.org country files into a vector points map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:81
+#: ../gui/wxpython/menustrings.py:78
 msgid "GEOnet import"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:82
+#: ../gui/wxpython/menustrings.py:79
 msgid ""
 "Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
 "points map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:83
+#: ../gui/wxpython/menustrings.py:80
 msgid "Matlab array or Mapgen format import"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:84
+#: ../gui/wxpython/menustrings.py:81
 msgid "Imports Mapgen or Matlab-ASCII vector maps into GRASS."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:86
-msgid "Converts LAS LiDAR point clouds to a GRASS vector map with libLAS."
+#: ../gui/wxpython/menustrings.py:83
+#, fuzzy
+msgid "Unpack vector map"
+msgstr "Atpakot rastra karti"
+#: ../gui/wxpython/menustrings.py:84
+msgid "Unpacks a vector map packed with v.pack."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:87
+#: ../gui/wxpython/menustrings.py:85
 msgid "Import 3D raster data"
 msgstr "Importēt 3D rastra datus"
-#: ../gui/wxpython/menustrings.py:88
+#: ../gui/wxpython/menustrings.py:86
 msgid "ASCII 3D import"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:89
+#: ../gui/wxpython/menustrings.py:87
 msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map."
 msgstr ""
+#: ../gui/wxpython/menustrings.py:88
+msgid "Raw binary array 3D import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:89
+msgid "Imports a binary raster file into a GRASS 3D raster map."
+msgstr ""
 #: ../gui/wxpython/menustrings.py:90
 msgid "Vis5D import"
 msgstr ""
@@ -3655,7 +3053,8 @@
 msgstr ""
 #: ../gui/wxpython/menustrings.py:101
-msgid "Exports a raster map to a text file as x,y,z values based on cell centers."
+msgid ""
+"Exports a raster map to a text file as x,y,z values based on cell centers."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:102
@@ -3722,7 +3121,7 @@
 msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:118 ../gui/wxpython/menustrings.py:137
+#: ../gui/wxpython/menustrings.py:118 ../gui/wxpython/menustrings.py:138
 msgid "POV-Ray export"
 msgstr ""
@@ -3746,8 +3145,8 @@
 msgid "Exports a raster map to the Virtual Reality Modeling Language (VRML)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:124 ../gui/wxpython/menustrings.py:141
-#: ../gui/wxpython/menustrings.py:148
+#: ../gui/wxpython/menustrings.py:124 ../gui/wxpython/menustrings.py:142
+#: ../gui/wxpython/menustrings.py:153
 msgid "VTK export"
 msgstr "VTK eksports"
@@ -3768,7 +3167,9 @@
 msgstr "Eksportēt vektrodatus"
 #: ../gui/wxpython/menustrings.py:130
-msgid "Converts a vector map to any of the supported OGR vector formats."
+msgid ""
+"Exports a vector map layer to any of the supported OGR vector formats. By "
+"default a vector map layer is exported to Esri Shapefile format."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:131
@@ -3776,7 +3177,9 @@
 msgstr ""
 #: ../gui/wxpython/menustrings.py:132
-msgid "Exports a vector map to a GRASS ASCII vector representation."
+msgid ""
+"Exports a vector map to a GRASS ASCII vector representation. By default only "
+"features with category are exported. To export all features use 'layer=-1'."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:133
@@ -3792,3330 +3195,3989 @@
 msgstr ""
 #: ../gui/wxpython/menustrings.py:136
-msgid "Exports a vector map to a GPS receiver or file format supported by GPSBabel."
+msgid ""
+"Exports a vector map to a GPS receiver or file format supported by GPSBabel."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:138
+#: ../gui/wxpython/menustrings.py:137
+#, fuzzy
+msgid "PostGIS export"
+msgstr "PNG eksports"
+#: ../gui/wxpython/menustrings.py:139
 msgid "Converts GRASS x,y,z points to POV-Ray x,z,y format."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:139
+#: ../gui/wxpython/menustrings.py:140
 msgid "SVG export"
 msgstr "SVG eksports"
-#: ../gui/wxpython/menustrings.py:140
+#: ../gui/wxpython/menustrings.py:141
 msgid "Exports a vector map to SVG file."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:142
+#: ../gui/wxpython/menustrings.py:143
 msgid "Converts a vector map to VTK ASCII output."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:143
+#: ../gui/wxpython/menustrings.py:144
+#, fuzzy
+msgid "Pack vector map"
+msgstr "Jauna vektoru karte"
+#: ../gui/wxpython/menustrings.py:145
+msgid "Packs up a vector map and support files for copying."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:146
 msgid "Export 3D raster maps"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:144
+#: ../gui/wxpython/menustrings.py:147
 msgid "ASCII 3D export"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:145
+#: ../gui/wxpython/menustrings.py:148
 msgid "Converts a 3D raster map layer into a ASCII text file."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:146
+#: ../gui/wxpython/menustrings.py:149
+msgid "Raw binary array 3D export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:150
+msgid "Exports a GRASS 3D raster map to a binary array."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:151
 msgid "Vis5D export"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:147
+#: ../gui/wxpython/menustrings.py:152
 msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:149
+#: ../gui/wxpython/menustrings.py:154
 msgid "Converts 3D raster maps into the VTK-ASCII format."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:150
+#: ../gui/wxpython/menustrings.py:155
 msgid "Export database table"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:151
+#: ../gui/wxpython/menustrings.py:156
 msgid "Common export formats using OGR"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:152
+#: ../gui/wxpython/menustrings.py:157
 msgid "Exports attribute tables into various formats."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:153
-msgid "Link external formats"
+#: ../gui/wxpython/menustrings.py:158
+msgid "External formats"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:154 ../gui/wxpython/lmgr/layertree.py:53
-#: ../gui/wxpython/gui_modules/gdialogs.py:1703
-#: ../gui/wxpython/gui_core/dialogs.py:1793
+#: ../gui/wxpython/menustrings.py:159 ../gui/wxpython/lmgr/layertree.py:58
+#: ../gui/wxpython/gui_core/dialogs.py:1818
 msgid "Link external raster data"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:155
+#: ../gui/wxpython/menustrings.py:160
 msgid "Link GDAL supported raster data as a pseudo GRASS raster map layer."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:156 ../gui/wxpython/lmgr/layertree.py:59
-#: ../gui/wxpython/gui_modules/gdialogs.py:1697
-#: ../gui/wxpython/gui_core/dialogs.py:1787
+#: ../gui/wxpython/menustrings.py:161 ../gui/wxpython/lmgr/layertree.py:64
+#: ../gui/wxpython/gui_core/dialogs.py:1812
 msgid "Link external vector data"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:157
+#: ../gui/wxpython/menustrings.py:162
 msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:158
+#: ../gui/wxpython/menustrings.py:163
 msgid "Output format for raster data"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:159
+#: ../gui/wxpython/menustrings.py:164
 msgid "Defines raster output format utilizing GDAL library."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:160
+#: ../gui/wxpython/menustrings.py:165
 msgid "Output format for vector data"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:161
+#: ../gui/wxpython/menustrings.py:166
 msgid "Defines vector output format utilizing OGR library."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:162
+#: ../gui/wxpython/menustrings.py:167
 msgid "Manage maps and volumes"
 msgstr "Pārvaldīt kartes un tilpumus"
-#: ../gui/wxpython/menustrings.py:163
 msgid "Copy"
 msgstr "Kopēt"
-#: ../gui/wxpython/menustrings.py:164
+#: ../gui/wxpython/menustrings.py:169
 msgid ""
 "Copies available data files in the current mapset search path to the user's "
 "current mapset."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:165
+#: ../gui/wxpython/menustrings.py:170 ../gui/wxpython/menustrings.py:1595
 msgid "List"
 msgstr "Parādīt"
-#: ../gui/wxpython/menustrings.py:166
 msgid "Lists available GRASS data base files of the user-specified data type."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:167
+#: ../gui/wxpython/menustrings.py:172
 msgid "List filtered"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:168
+#: ../gui/wxpython/menustrings.py:173
 msgid ""
 "Lists available GRASS data base files of the user-specified data type "
 "optionally using the search pattern."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:169 ../gui/wxpython/lmgr/layertree.py:314
-#: ../gui/wxpython/gui_modules/layertree.py:281
+#: ../gui/wxpython/menustrings.py:174 ../gui/wxpython/menustrings.py:1583
+#: ../gui/wxpython/lmgr/layertree.py:400 ../gui/wxpython/rlisetup/frame.py:51
 msgid "Rename"
 msgstr "Pārsaukt"
-#: ../gui/wxpython/menustrings.py:170
+#: ../gui/wxpython/menustrings.py:175
 msgid "Renames data base element files in the user's current mapset."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:172
+#: ../gui/wxpython/menustrings.py:177
 msgid "Removes data base element files from the user's current mapset."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:173
+#: ../gui/wxpython/menustrings.py:178
 msgid "Delete filtered"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:174
+#: ../gui/wxpython/menustrings.py:179
 msgid ""
 "Removes data base element files from the user's current mapset using regular "
 "expressions."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:175 ../gui/wxpython/menustrings.py:309
-#: ../gui/wxpython/menustrings.py:593 ../gui/wxpython/menustrings.py:825
+#: ../gui/wxpython/menustrings.py:180 ../gui/wxpython/menustrings.py:312
+#: ../gui/wxpython/menustrings.py:599 ../gui/wxpython/menustrings.py:833
+#: ../gui/wxpython/menustrings.py:977 ../gui/wxpython/menustrings.py:1264
+#: ../gui/wxpython/menustrings.py:1498
 msgid "Map type conversions"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:176 ../gui/wxpython/menustrings.py:310
+#: ../gui/wxpython/menustrings.py:181 ../gui/wxpython/menustrings.py:313
+#: ../gui/wxpython/menustrings.py:978
 msgid "Raster to vector"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:177 ../gui/wxpython/menustrings.py:311
+#: ../gui/wxpython/menustrings.py:182 ../gui/wxpython/menustrings.py:314
+#: ../gui/wxpython/menustrings.py:979
 msgid "Converts a raster map into a vector map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:178 ../gui/wxpython/menustrings.py:312
+#: ../gui/wxpython/menustrings.py:183 ../gui/wxpython/menustrings.py:315
+#: ../gui/wxpython/menustrings.py:980
 msgid "Raster series to volume"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:179 ../gui/wxpython/menustrings.py:313
+#: ../gui/wxpython/menustrings.py:184 ../gui/wxpython/menustrings.py:316
+#: ../gui/wxpython/menustrings.py:981
 msgid "Converts 2D raster map slices to one 3D raster volume map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:180 ../gui/wxpython/menustrings.py:314
+#: ../gui/wxpython/menustrings.py:185 ../gui/wxpython/menustrings.py:317
+#: ../gui/wxpython/menustrings.py:982
 msgid "Raster 2.5D to volume"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:181 ../gui/wxpython/menustrings.py:315
+#: ../gui/wxpython/menustrings.py:186 ../gui/wxpython/menustrings.py:318
+#: ../gui/wxpython/menustrings.py:983
 msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:182 ../gui/wxpython/menustrings.py:594
+#: ../gui/wxpython/menustrings.py:187 ../gui/wxpython/menustrings.py:600
+#: ../gui/wxpython/menustrings.py:1265
 msgid "Vector to raster"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:183 ../gui/wxpython/menustrings.py:595
+#: ../gui/wxpython/menustrings.py:188 ../gui/wxpython/menustrings.py:601
+#: ../gui/wxpython/menustrings.py:1266
 msgid "Converts (rasterize) a vector map into a raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:184 ../gui/wxpython/menustrings.py:596
+#: ../gui/wxpython/menustrings.py:189 ../gui/wxpython/menustrings.py:602
+#: ../gui/wxpython/menustrings.py:1267
 msgid "Vector to volume"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:185 ../gui/wxpython/menustrings.py:597
+#: ../gui/wxpython/menustrings.py:190 ../gui/wxpython/menustrings.py:603
+#: ../gui/wxpython/menustrings.py:1268
 msgid "Converts a vector map (only points) into a 3D raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:186 ../gui/wxpython/menustrings.py:598
+#: ../gui/wxpython/menustrings.py:191 ../gui/wxpython/menustrings.py:604
+#: ../gui/wxpython/menustrings.py:1269
 msgid "2D vector to 3D vector"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:187 ../gui/wxpython/menustrings.py:599
+#: ../gui/wxpython/menustrings.py:192 ../gui/wxpython/menustrings.py:605
+#: ../gui/wxpython/menustrings.py:1270
 msgid "Performs transformation of 2D vector features to 3D."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:188 ../gui/wxpython/menustrings.py:600
+#: ../gui/wxpython/menustrings.py:193 ../gui/wxpython/menustrings.py:606
+#: ../gui/wxpython/menustrings.py:1271
 msgid "Sites to vector"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:189 ../gui/wxpython/menustrings.py:601
+#: ../gui/wxpython/menustrings.py:194 ../gui/wxpython/menustrings.py:607
+#: ../gui/wxpython/menustrings.py:1272
 msgid "Converts a GRASS site_lists file into a vector map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:190 ../gui/wxpython/menustrings.py:826
+#: ../gui/wxpython/menustrings.py:195 ../gui/wxpython/menustrings.py:834
+#: ../gui/wxpython/menustrings.py:1499
 msgid "Volume to raster series"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:191 ../gui/wxpython/menustrings.py:827
+#: ../gui/wxpython/menustrings.py:196 ../gui/wxpython/menustrings.py:835
+#: ../gui/wxpython/menustrings.py:1500
 msgid "Converts 3D raster maps to 2D raster maps"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:192
+#: ../gui/wxpython/menustrings.py:197
 msgid "Georectify"
 msgstr "Ģeoreferencēt"
-#: ../gui/wxpython/menustrings.py:193
+#: ../gui/wxpython/menustrings.py:198
 msgid "Manage Ground Control Points for Georectification"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:194
+#: ../gui/wxpython/menustrings.py:199
 msgid "Graphical modeler"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:195
+#: ../gui/wxpython/menustrings.py:200
 msgid "Launch Graphical modeler"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:196 ../gui/wxpython/menustrings.py:954
+#: ../gui/wxpython/menustrings.py:201 ../gui/wxpython/menustrings.py:1707
 msgid "Run model"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:197
+#: ../gui/wxpython/menustrings.py:202
 msgid "Run model prepared by Graphical modeler"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:198
+#: ../gui/wxpython/menustrings.py:203
 msgid "3D image rendering"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:199
-msgid "Creates a 3D rendering of GIS data."
+#: ../gui/wxpython/menustrings.py:204
+msgid ""
+"Creates a 3D rendering of GIS data. Renders surfaces (raster data), 2D/3D "
+"vector data, and volumes (3D raster data) in 3D."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:200
-msgid "Animation tool (experimental - addons)"
-msgstr ""
+#: ../gui/wxpython/menustrings.py:205 ../gui/wxpython/animation/frame.py:52
+#, fuzzy
+msgid "Animation tool"
+msgstr "Animācija"
-#: ../gui/wxpython/menustrings.py:201
+#: ../gui/wxpython/menustrings.py:206
 msgid "Launch animation tool."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:202
+#: ../gui/wxpython/menustrings.py:207
 msgid "Bearing/distance to coordinates"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:203
+#: ../gui/wxpython/menustrings.py:208
 msgid ""
 "A simple utility for converting bearing and distance measurements to "
-"coordinates and vice versa."
+"coordinates and vice versa. It assumes a cartesian coordinate system"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:204 ../gui/wxpython/lmgr/toolbars.py:144
+#: ../gui/wxpython/menustrings.py:209 ../gui/wxpython/lmgr/toolbars.py:144
 msgid "Cartographic Composer"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:205
+#: ../gui/wxpython/menustrings.py:210
 msgid "Launch Cartographic Composer"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:206
+#: ../gui/wxpython/menustrings.py:211
 #, fuzzy
 msgid "Map Swipe"
-#: ../gui/wxpython/menustrings.py:207
+#: ../gui/wxpython/menustrings.py:212
 msgid "Launch Map Swipe"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:208
+#: ../gui/wxpython/menustrings.py:213
 msgid "Launch script"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:209
+#: ../gui/wxpython/menustrings.py:214
 msgid "Launches script file."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:210
+#: ../gui/wxpython/menustrings.py:215
 msgid "Exit GUI"
 msgstr "Iziet no GUI"
-#: ../gui/wxpython/menustrings.py:211
-msgid "Quit wxGUI session"
+#: ../gui/wxpython/menustrings.py:216
+#, fuzzy
+msgid "Quit the GRASS wxGUI session."
 msgstr "Pabeigt wxGUI sesiju"
-#: ../gui/wxpython/menustrings.py:212 ../gui/wxpython/menustrings.py:934
+#: ../gui/wxpython/menustrings.py:217 ../gui/wxpython/menustrings.py:1685
 msgid "&Settings"
 msgstr "Ie&statījumi"
-#: ../gui/wxpython/menustrings.py:213
+#: ../gui/wxpython/menustrings.py:218
+#: ../gui/wxpython/web_services/dialogs.py:797
 msgid "Region"
 msgstr "Reģions"
-#: ../gui/wxpython/menustrings.py:214
+#: ../gui/wxpython/menustrings.py:219
 msgid "Display region"
 msgstr "Attēlot reģionu"
-#: ../gui/wxpython/menustrings.py:215 ../gui/wxpython/menustrings.py:217
+#: ../gui/wxpython/menustrings.py:220 ../gui/wxpython/menustrings.py:222
 msgid "Manages the boundary definitions for the geographic region."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:216
+#: ../gui/wxpython/menustrings.py:221
 msgid "Set region"
 msgstr "Iestatīt reģionu"
-#: ../gui/wxpython/menustrings.py:218
+#: ../gui/wxpython/menustrings.py:223
 msgid "GRASS working environment"
 msgstr "GRASS darba vide"
-#: ../gui/wxpython/menustrings.py:219
+#: ../gui/wxpython/menustrings.py:224
 msgid "Mapset access"
 msgstr "Karšu kopu piekļuve"
-#: ../gui/wxpython/menustrings.py:220
+#: ../gui/wxpython/menustrings.py:225
 msgid "Set/unset access to other mapsets in current location"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:221
+#: ../gui/wxpython/menustrings.py:226
 msgid "User access"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:222
-msgid "Controls access to the current mapset for other users on the system."
+#: ../gui/wxpython/menustrings.py:227
+msgid ""
+"Controls access to the current mapset for other users on the system. If no "
+"option given, prints current status."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:223
+#: ../gui/wxpython/menustrings.py:228
 msgid "Change working environment"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:224
-msgid "Changes/reports current mapset."
+#: ../gui/wxpython/menustrings.py:229
+msgid ""
+"Changes/reports current mapset. Optionally create new mapset or list "
+"available mapsets in given location."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:225
+#: ../gui/wxpython/menustrings.py:230
 msgid "Change location and mapset"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:226
+#: ../gui/wxpython/menustrings.py:231
 msgid "Change current location and mapset."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:227
+#: ../gui/wxpython/menustrings.py:232
 msgid "Change mapset"
 msgstr "Mainīt karšu kopu"
-#: ../gui/wxpython/menustrings.py:228
+#: ../gui/wxpython/menustrings.py:233
 msgid "Change current mapset."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:229 ../gui/wxpython/menustrings.py:230
+#: ../gui/wxpython/menustrings.py:234 ../gui/wxpython/menustrings.py:235
 msgid "Change working directory"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:231
+#: ../gui/wxpython/menustrings.py:236
 msgid "Show settings"
 msgstr "Rādīt iestatījumus"
-#: ../gui/wxpython/menustrings.py:232 ../gui/wxpython/menustrings.py:234
+#: ../gui/wxpython/menustrings.py:237
 msgid "Outputs and modifies the user's current GRASS variable settings."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:233
+#: ../gui/wxpython/menustrings.py:238
 msgid "Change settings"
 msgstr "Mainīt iestatījumus"
-#: ../gui/wxpython/menustrings.py:235
+#: ../gui/wxpython/menustrings.py:239
+msgid ""
+"Outputs and modifies the user's current GRASS variable settings. Prints all "
+"defined GRASS variables if no option is given."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:240
 msgid "Create new location"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:236
+#: ../gui/wxpython/menustrings.py:241
 msgid "Launches location wizard to create new GRASS location."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:237 ../gui/wxpython/lmgr/frame.py:674
-#: ../gui/wxpython/gis_set.py:694
+#: ../gui/wxpython/menustrings.py:242 ../gui/wxpython/lmgr/frame.py:898
+#: ../gui/wxpython/gis_set.py:477 ../gui/wxpython/gis_set.py:847
 msgid "Create new mapset"
 msgstr "Izveidot jaunu karšu kopu"
-#: ../gui/wxpython/menustrings.py:238
+#: ../gui/wxpython/menustrings.py:243
 msgid "Creates new mapset in the current location, changes current mapset."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:239
+#: ../gui/wxpython/menustrings.py:244
 msgid "Version and copyright"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:240
+#: ../gui/wxpython/menustrings.py:245
 msgid "Displays version and copyright information."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:241
+#: ../gui/wxpython/menustrings.py:246
 msgid "Map projections"
 msgstr "Kartes projekcijas"
-#: ../gui/wxpython/menustrings.py:242
+#: ../gui/wxpython/menustrings.py:247
 msgid "Display map projection"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:243
+#: ../gui/wxpython/menustrings.py:248
 msgid ""
 "Converts co-ordinate system descriptions (i.e. projection information) "
 "between various formats (including GRASS format)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:244
+#: ../gui/wxpython/menustrings.py:249
 msgid "Manage projections"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:245
+#: ../gui/wxpython/menustrings.py:250
 msgid ""
 "Prints and manipulates GRASS projection information files (in various co-"
-"ordinate system descriptions)."
+"ordinate system descriptions). Can also be used to create new GRASS "
+"locations."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:246
+#: ../gui/wxpython/menustrings.py:251
 msgid "Convert coordinates"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:247
+#: ../gui/wxpython/menustrings.py:252
 msgid "Converts coordinates from one projection to another (cs2cs frontend)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:248
+#: ../gui/wxpython/menustrings.py:253
 msgid "Addons extensions"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:249
+#: ../gui/wxpython/menustrings.py:254
 msgid "Install extension from addons"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:250
+#: ../gui/wxpython/menustrings.py:255
 msgid "Installs new extension from GRASS AddOns SVN repository."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:251
-msgid "Update installed extensions"
-msgstr ""
+#: ../gui/wxpython/menustrings.py:256
+#, fuzzy
+msgid "Manage installed extension"
+msgstr "Pārvaldīt tabulas"
-#: ../gui/wxpython/menustrings.py:252
-msgid "Rebuilds all locally installed GRASS Addons extensions."
+#: ../gui/wxpython/menustrings.py:257
+msgid "Updates or removes installed GRASS AddOns extension(s)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:253
-msgid "Uninstall extension"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:254
-msgid "Removes installed GRASS AddOns extension."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:255 ../gui/wxpython/menustrings.py:935
+#: ../gui/wxpython/menustrings.py:258 ../gui/wxpython/menustrings.py:1686
 msgid "Preferences"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:256
+#: ../gui/wxpython/menustrings.py:259
 msgid "User GUI preferences (display font, commands, digitizer, etc.)"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:257
+#: ../gui/wxpython/menustrings.py:260 ../gui/wxpython/menustrings.py:925
 msgid "&Raster"
 msgstr "&Rastrs"
-#: ../gui/wxpython/menustrings.py:258
+#: ../gui/wxpython/menustrings.py:261 ../gui/wxpython/menustrings.py:926
 msgid "Develop raster map"
 msgstr "Veidot rastra karti"
-#: ../gui/wxpython/menustrings.py:259
+#: ../gui/wxpython/menustrings.py:262 ../gui/wxpython/menustrings.py:927
 msgid "Compress/decompress"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:260
+#: ../gui/wxpython/menustrings.py:263 ../gui/wxpython/menustrings.py:928
 msgid "Compresses and decompresses raster maps."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:261
+#: ../gui/wxpython/menustrings.py:264 ../gui/wxpython/menustrings.py:929
 msgid "Region boundaries"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:262
+#: ../gui/wxpython/menustrings.py:265 ../gui/wxpython/menustrings.py:930
 msgid "Sets the boundary definitions for a raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:263
+#: ../gui/wxpython/menustrings.py:266 ../gui/wxpython/menustrings.py:931
 msgid "Manage NULL values"
 msgstr "Pārvaldīt NULL vērtības"
-#: ../gui/wxpython/menustrings.py:264
+#: ../gui/wxpython/menustrings.py:267 ../gui/wxpython/menustrings.py:932
 msgid "Manages NULL-values of given raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:265
+#: ../gui/wxpython/menustrings.py:268 ../gui/wxpython/menustrings.py:933
 msgid "Quantization"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:266
+#: ../gui/wxpython/menustrings.py:269 ../gui/wxpython/menustrings.py:934
 msgid "Produces the quantization file for a floating-point map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:267
+#: ../gui/wxpython/menustrings.py:270 ../gui/wxpython/menustrings.py:935
 msgid "Timestamp"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:268
-msgid "Modifies a timestamp for a raster map."
+#: ../gui/wxpython/menustrings.py:271 ../gui/wxpython/menustrings.py:936
+msgid ""
+"Modifies a timestamp for a raster map. Print/add/remove a timestamp for a "
+"raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:269
+#: ../gui/wxpython/menustrings.py:272 ../gui/wxpython/menustrings.py:937
 msgid "Resample using aggregate statistics"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:270
+#: ../gui/wxpython/menustrings.py:273 ../gui/wxpython/menustrings.py:938
 msgid "Resamples raster map layers to a coarser grid using aggregation."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:271
+#: ../gui/wxpython/menustrings.py:274 ../gui/wxpython/menustrings.py:939
 msgid "Resample using multiple methods"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:272
-msgid "Resamples raster map layers to a finer grid using interpolation."
+#: ../gui/wxpython/menustrings.py:275 ../gui/wxpython/menustrings.py:940
+msgid "Resamples raster map to a finer grid using interpolation."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:273
+#: ../gui/wxpython/menustrings.py:276 ../gui/wxpython/menustrings.py:941
 msgid "Resample using nearest neighbor"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:274
+#: ../gui/wxpython/menustrings.py:277 ../gui/wxpython/menustrings.py:942
 msgid "GRASS raster map layer data resampling capability."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:275
+#: ../gui/wxpython/menustrings.py:278 ../gui/wxpython/menustrings.py:943
 msgid "Resample using spline tension"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:276
+#: ../gui/wxpython/menustrings.py:279 ../gui/wxpython/menustrings.py:944
 msgid ""
 "Reinterpolates and optionally computes topographic analysis from input "
 "raster map to a new raster map (possibly with different resolution) using "
 "regularized spline with tension and smoothing."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:277
+#: ../gui/wxpython/menustrings.py:280 ../gui/wxpython/menustrings.py:945
 msgid "Resample using bspline"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:278 ../gui/wxpython/menustrings.py:487
-msgid "Bicubic or bilinear spline interpolation with Tykhonov regularization."
+#: ../gui/wxpython/menustrings.py:281 ../gui/wxpython/menustrings.py:946
+msgid ""
+"Performs bilinear or bicubic spline interpolation with Tykhonov "
+"regularization."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:279
+#: ../gui/wxpython/menustrings.py:282 ../gui/wxpython/menustrings.py:947
 msgid "Resample using analytic kernel"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:280
+#: ../gui/wxpython/menustrings.py:283 ../gui/wxpython/menustrings.py:948
 msgid "Resamples raster map layers using an analytic kernel."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:281 ../gui/wxpython/menustrings.py:557
+#: ../gui/wxpython/menustrings.py:284 ../gui/wxpython/menustrings.py:563
+#: ../gui/wxpython/menustrings.py:949 ../gui/wxpython/menustrings.py:1228
 msgid "Support file maintenance"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:282
+#: ../gui/wxpython/menustrings.py:285 ../gui/wxpython/menustrings.py:950
 msgid "Allows creation and/or modification of raster map layer support files."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:283
+#: ../gui/wxpython/menustrings.py:286 ../gui/wxpython/menustrings.py:951
 msgid "Update map statistics"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:284
+#: ../gui/wxpython/menustrings.py:287 ../gui/wxpython/menustrings.py:952
 msgid "Update raster map statistics"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:285
-msgid "Reproject raster map"
+#: ../gui/wxpython/menustrings.py:288 ../gui/wxpython/menustrings.py:953
+msgid "Reproject raster map from different location"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:286
+#: ../gui/wxpython/menustrings.py:289 ../gui/wxpython/menustrings.py:954
 msgid "Re-projects a raster map from given location to the current location."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:287
+#: ../gui/wxpython/menustrings.py:290 ../gui/wxpython/menustrings.py:955
 msgid "Tiling"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:288
+#: ../gui/wxpython/menustrings.py:291 ../gui/wxpython/menustrings.py:956
 msgid ""
 "Produces tilings of the source projection for use in the destination region "
 "and projection."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:289 ../gui/wxpython/menustrings.py:576
+#: ../gui/wxpython/menustrings.py:292 ../gui/wxpython/menustrings.py:582
+#: ../gui/wxpython/menustrings.py:957 ../gui/wxpython/menustrings.py:1247
 msgid "Manage colors"
 msgstr "Pārvaldīt krāsas"
-#: ../gui/wxpython/menustrings.py:290 ../gui/wxpython/menustrings.py:577
+#: ../gui/wxpython/menustrings.py:293 ../gui/wxpython/menustrings.py:583
+#: ../gui/wxpython/menustrings.py:958 ../gui/wxpython/menustrings.py:1248
 msgid "Color tables"
 msgstr "Krāsu tabulas"
-#: ../gui/wxpython/menustrings.py:291
+#: ../gui/wxpython/menustrings.py:294 ../gui/wxpython/menustrings.py:959
 msgid "Creates/modifies the color table associated with a raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:292
+#: ../gui/wxpython/menustrings.py:295 ../gui/wxpython/menustrings.py:960
 msgid "Color tables (stddev)"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:293
+#: ../gui/wxpython/menustrings.py:296 ../gui/wxpython/menustrings.py:961
 msgid "Sets color rules based on stddev from a raster map's mean value."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:294
-msgid "Create color rules"
+#: ../gui/wxpython/menustrings.py:297 ../gui/wxpython/menustrings.py:585
+#: ../gui/wxpython/menustrings.py:962 ../gui/wxpython/menustrings.py:1250
+msgid "Manage color rules interactively"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:295
+#: ../gui/wxpython/menustrings.py:298 ../gui/wxpython/menustrings.py:963
 msgid "Interactive management of raster color tables."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:296 ../gui/wxpython/menustrings.py:581
+#: ../gui/wxpython/menustrings.py:299 ../gui/wxpython/menustrings.py:587
+#: ../gui/wxpython/menustrings.py:964 ../gui/wxpython/menustrings.py:1252
 msgid "Export color table"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:297
+#: ../gui/wxpython/menustrings.py:300 ../gui/wxpython/menustrings.py:965
 msgid "Exports the color table associated with a raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:298
+#: ../gui/wxpython/menustrings.py:301 ../gui/wxpython/menustrings.py:966
 msgid "Blend 2 color rasters"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:299
+#: ../gui/wxpython/menustrings.py:302 ../gui/wxpython/menustrings.py:967
 msgid "Blends color components of two raster maps by a given ratio."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:300
+#: ../gui/wxpython/menustrings.py:303 ../gui/wxpython/menustrings.py:968
 msgid "Create RGB"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:301
-msgid "Combines red, green and blue raster maps into a single composite raster map."
+#: ../gui/wxpython/menustrings.py:304 ../gui/wxpython/menustrings.py:969
+msgid ""
+"Combines red, green and blue raster maps into a single composite raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:302 ../gui/wxpython/menustrings.py:730
+#: ../gui/wxpython/menustrings.py:305 ../gui/wxpython/menustrings.py:740
+#: ../gui/wxpython/menustrings.py:970 ../gui/wxpython/menustrings.py:1405
 msgid "RGB to HIS"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:303
+#: ../gui/wxpython/menustrings.py:306 ../gui/wxpython/menustrings.py:971
 msgid ""
 "Generates red, green and blue raster map layers combining hue, intensity and "
 "saturation (HIS) values from user-specified input raster map layers."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:304
+#: ../gui/wxpython/menustrings.py:307 ../gui/wxpython/menustrings.py:972
 msgid "Query raster maps"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:305
+#: ../gui/wxpython/menustrings.py:308 ../gui/wxpython/menustrings.py:973
 msgid "Query values by coordinates"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:306
+#: ../gui/wxpython/menustrings.py:309 ../gui/wxpython/menustrings.py:974
 msgid "Queries raster maps on their category values and category labels."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:307
+#: ../gui/wxpython/menustrings.py:310 ../gui/wxpython/menustrings.py:975
 msgid "Query colors by value"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:308
+#: ../gui/wxpython/menustrings.py:311 ../gui/wxpython/menustrings.py:976
 msgid "Queries colors for a raster map layer."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:316
+#: ../gui/wxpython/menustrings.py:319 ../gui/wxpython/menustrings.py:984
 msgid "Buffer rasters"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:317
+#: ../gui/wxpython/menustrings.py:320 ../gui/wxpython/menustrings.py:985
 msgid ""
 "Creates a raster map showing buffer zones surrounding cells that contain non-"
 "NULL category values."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:318
+#: ../gui/wxpython/menustrings.py:321 ../gui/wxpython/menustrings.py:986
 msgid "Concentric circles"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:319
+#: ../gui/wxpython/menustrings.py:322 ../gui/wxpython/menustrings.py:987
 msgid "Creates a raster map containing concentric rings around a given point."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:320
+#: ../gui/wxpython/menustrings.py:323 ../gui/wxpython/menustrings.py:988
 msgid "Closest points"
 msgstr "Tuvākie punkti"
-#: ../gui/wxpython/menustrings.py:321
+#: ../gui/wxpython/menustrings.py:324 ../gui/wxpython/menustrings.py:989
 msgid "Locates the closest points between objects in two raster maps."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:323
+#: ../gui/wxpython/menustrings.py:326 ../gui/wxpython/menustrings.py:991
 msgid "Creates a MASK for limiting raster operation."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:324
+#: ../gui/wxpython/menustrings.py:327 ../gui/wxpython/menustrings.py:992
 msgid "Raster map calculator"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:325
+#: ../gui/wxpython/menustrings.py:328 ../gui/wxpython/menustrings.py:993
 msgid "Raster map calculator."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:326
+#: ../gui/wxpython/menustrings.py:329 ../gui/wxpython/menustrings.py:994
 msgid "Neighborhood analysis"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:327
+#: ../gui/wxpython/menustrings.py:330 ../gui/wxpython/menustrings.py:995
+#: ../gui/wxpython/rlisetup/wizard.py:603
 msgid "Moving window"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:328
+#: ../gui/wxpython/menustrings.py:331 ../gui/wxpython/menustrings.py:996
 msgid ""
 "Makes each cell category value a function of the category values assigned to "
 "the cells around it, and stores new cell values in an output raster map "
 "layer."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:329
+#: ../gui/wxpython/menustrings.py:332 ../gui/wxpython/menustrings.py:997
 msgid "Neighborhood points"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:330
-msgid "Neighborhood analysis tool for vector point maps."
+#: ../gui/wxpython/menustrings.py:333 ../gui/wxpython/menustrings.py:998
+msgid ""
+"Neighborhood analysis tool for vector point maps. Makes each cell value a "
+"function of the attribute values assigned to the vector points or centroids "
+"around it, and stores new cell values in an output raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:331
+#: ../gui/wxpython/menustrings.py:334 ../gui/wxpython/menustrings.py:999
 msgid "Overlay rasters"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:332
+#: ../gui/wxpython/menustrings.py:335 ../gui/wxpython/menustrings.py:1000
 msgid "Cross product"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:333
+#: ../gui/wxpython/menustrings.py:336 ../gui/wxpython/menustrings.py:1001
 msgid ""
 "Creates a cross product of the category values from multiple raster map "
 "layers."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:334
+#: ../gui/wxpython/menustrings.py:337 ../gui/wxpython/menustrings.py:1002
 msgid "Raster series"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:335
+#: ../gui/wxpython/menustrings.py:338 ../gui/wxpython/menustrings.py:1003
 msgid ""
 "Makes each output cell value a function of the values assigned to the "
 "corresponding cells in the input raster map layers."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:336
+#: ../gui/wxpython/menustrings.py:339 ../gui/wxpython/menustrings.py:1004
 msgid "Patch raster maps"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:337
+#: ../gui/wxpython/menustrings.py:340 ../gui/wxpython/menustrings.py:1005
 msgid ""
 "Creates a composite raster map layer by using known category values from one "
 "(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:338
+#: ../gui/wxpython/menustrings.py:341 ../gui/wxpython/menustrings.py:1006
 msgid "Statistical overlay"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:339
+#: ../gui/wxpython/menustrings.py:342 ../gui/wxpython/menustrings.py:1007
 msgid ""
 "Calculates category or object oriented statistics (accumulator-based "
 "statistics)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:340
+#: ../gui/wxpython/menustrings.py:343 ../gui/wxpython/menustrings.py:1008
 msgid "Quantiles overlay"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:341
+#: ../gui/wxpython/menustrings.py:344 ../gui/wxpython/menustrings.py:1009
 msgid "Compute category quantiles using two passes."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:342
+#: ../gui/wxpython/menustrings.py:345 ../gui/wxpython/menustrings.py:1010
 msgid "Solar radiance and shadows"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:343
+#: ../gui/wxpython/menustrings.py:346 ../gui/wxpython/menustrings.py:1011
+msgid "LatLong map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:347 ../gui/wxpython/menustrings.py:1012
+#, fuzzy
+msgid "Creates a latitude/longitude raster map."
+msgstr "Izveidot rastra kartes histogrammu"
+#: ../gui/wxpython/menustrings.py:348 ../gui/wxpython/menustrings.py:1013
 msgid "Solar irradiance and irradiation"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:344
-msgid "Solar irradiance and irradiation model."
+#: ../gui/wxpython/menustrings.py:349 ../gui/wxpython/menustrings.py:1014
+msgid ""
+"Solar irradiance and irradiation model. Computes direct (beam), diffuse and "
+"reflected solar irradiation raster maps for given day, latitude, surface and "
+"atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, "
+"declination, extraterrestrial irradiance, daylight length) are saved in the "
+"map history file. Alternatively, a local time can be specified to compute "
+"solar incidence angle and/or irradiance raster maps. The shadowing effect of "
+"the topography is optionally incorporated."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:345
+#: ../gui/wxpython/menustrings.py:350 ../gui/wxpython/menustrings.py:1015
 msgid "Shadows map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:346
-msgid "Calculates cast shadow areas from sun position and elevation raster map."
+#: ../gui/wxpython/menustrings.py:351 ../gui/wxpython/menustrings.py:1016
+msgid ""
+"Calculates cast shadow areas from sun position and elevation raster map. "
+"Either exact sun position (A) is specified, or date/time to calculate the "
+"sun position (B) by r.sunmask itself."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:347
+#: ../gui/wxpython/menustrings.py:352 ../gui/wxpython/menustrings.py:1017
+msgid "Sunshine hours and solar angles"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:353 ../gui/wxpython/menustrings.py:1018
+msgid ""
+"Calculates solar elevation, solar azimuth, and sun hours. Solar elevation: "
+"the angle between the direction of the geometric center of the sun's "
+"apparent disk and the (idealized) horizon. Solar azimuth: the angle from due "
+"north in clockwise direction."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:354 ../gui/wxpython/menustrings.py:1019
 msgid "Terrain analysis"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:348
+#: ../gui/wxpython/menustrings.py:355 ../gui/wxpython/menustrings.py:1020
 msgid "Generate contour lines"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:349
+#: ../gui/wxpython/menustrings.py:356 ../gui/wxpython/menustrings.py:1021
 msgid "Produces a vector map of specified contours from a raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:350
+#: ../gui/wxpython/menustrings.py:357 ../gui/wxpython/menustrings.py:1022
 msgid "Cost surface"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:351
+#: ../gui/wxpython/menustrings.py:358 ../gui/wxpython/menustrings.py:1023
 msgid ""
 "Creates a raster map showing the cumulative cost of moving between different "
 "geographic locations on an input raster map whose cell category values "
 "represent cost."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:352
+#: ../gui/wxpython/menustrings.py:359 ../gui/wxpython/menustrings.py:1024
 msgid "Cumulative movement costs"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:353
+#: ../gui/wxpython/menustrings.py:360 ../gui/wxpython/menustrings.py:1025
 msgid ""
-"Outputs a raster map layer showing the anisotropic cumulative cost of moving "
-"between different geographic locations on an input elevation raster map "
-"layer whose cell category values represent elevation combined with an input "
-"raster map layer whose cell values represent friction cost."
+"Outputs a raster map showing the anisotropic cumulative cost. Computes "
+"anisotropic cumulative cost of moving between different geographic locations "
+"on an input elevation raster map whose cell category values represent "
+"elevation combined with an input raster map layer whose cell values "
+"represent friction cost."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:354
+#: ../gui/wxpython/menustrings.py:361 ../gui/wxpython/menustrings.py:1026
 msgid "Least cost route or flow"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:355
-msgid "Traces a flow through an elevation model on a raster map."
+#: ../gui/wxpython/menustrings.py:362 ../gui/wxpython/menustrings.py:1027
+msgid ""
+"Traces a flow through an elevation model or cost surface on a raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:356
+#: ../gui/wxpython/menustrings.py:363 ../gui/wxpython/menustrings.py:1028
 msgid "Shaded relief"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:357
-msgid "Creates shaded relief map from an elevation map (DEM)."
+#: ../gui/wxpython/menustrings.py:364 ../gui/wxpython/menustrings.py:1029
+msgid "Creates shaded relief map from an elevation map (DEM). "
 msgstr ""
-#: ../gui/wxpython/menustrings.py:358
+#: ../gui/wxpython/menustrings.py:365 ../gui/wxpython/menustrings.py:1030
 msgid "Slope and aspect"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:359
+#: ../gui/wxpython/menustrings.py:366 ../gui/wxpython/menustrings.py:1031
 msgid ""
 "Generates raster maps of slope, aspect, curvatures and partial derivatives "
-"from a elevation raster map."
+"from a elevation raster map. Aspect is calculated counterclockwise from east."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:360
+#: ../gui/wxpython/menustrings.py:367 ../gui/wxpython/menustrings.py:1032
 msgid "Terrain parameters"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:361
-msgid "Extracts terrain parameters from a DEM."
+#: ../gui/wxpython/menustrings.py:368 ../gui/wxpython/menustrings.py:1033
+msgid ""
+"Extracts terrain parameters from a DEM. Uses a multi-scale approach by "
+"taking fitting quadratic parameters to any size window (via least squares)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:362
+#: ../gui/wxpython/menustrings.py:369 ../gui/wxpython/menustrings.py:1034
 msgid "Textural features"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:363
+#: ../gui/wxpython/menustrings.py:370 ../gui/wxpython/menustrings.py:1035
 msgid "Generate images with textural features from a raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:364
+#: ../gui/wxpython/menustrings.py:371 ../gui/wxpython/menustrings.py:1036
 msgid "Visibility"
 msgstr "Redzamība"
-#: ../gui/wxpython/menustrings.py:365
-msgid "Computes the viewshed of a point on a raster terrain."
+#: ../gui/wxpython/menustrings.py:372 ../gui/wxpython/menustrings.py:1037
+msgid ""
+"Computes the viewshed of a point on an elevation raster map. Default format: "
+"NULL (invisible), vertical angle wrt viewpoint (visible)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:366
+#: ../gui/wxpython/menustrings.py:373 ../gui/wxpython/menustrings.py:1038
 msgid "Visibility [DEPRECATED]"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:367
+#: ../gui/wxpython/menustrings.py:374 ../gui/wxpython/menustrings.py:1039
 msgid "Line-of-sight raster analysis program."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:368
+#: ../gui/wxpython/menustrings.py:375 ../gui/wxpython/menustrings.py:1040
 msgid "Distance to features"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:369
-msgid "Generates a raster map of distance to features in input raster map."
+#: ../gui/wxpython/menustrings.py:376 ../gui/wxpython/menustrings.py:1041
+msgid "Generates a raster map containing distances to nearest raster features."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:370
+#: ../gui/wxpython/menustrings.py:377 ../gui/wxpython/menustrings.py:1042
 msgid "Horizon angle"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:371
-msgid "Horizon angle computation from a digital elevation model."
+#: ../gui/wxpython/menustrings.py:378 ../gui/wxpython/menustrings.py:1043
+msgid ""
+"Horizon angle computation from a digital elevation model. Computes horizon "
+"angle height from a digital elevation model. The module has two different "
+"modes of operation: 1. Computes the entire horizon around a single point "
+"whose coordinates are given with the 'coord' option. The horizon height (in "
+"radians). 2. Computes one or more raster maps of the horizon height in a "
+"single direction. The input for this is the angle (in degrees), which is "
+"measured counterclockwise with east=0, north=90 etc. The output is the "
+"horizon height in radians."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:372
+#: ../gui/wxpython/menustrings.py:379 ../gui/wxpython/menustrings.py:1044
 msgid "Transform features"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:373
+#: ../gui/wxpython/menustrings.py:380 ../gui/wxpython/menustrings.py:1045
 msgid "Clump"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:374
+#: ../gui/wxpython/menustrings.py:381 ../gui/wxpython/menustrings.py:1046
 msgid ""
 "Recategorizes data in a raster map by grouping cells that form physically "
 "discrete areas into unique categories."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:375
+#: ../gui/wxpython/menustrings.py:382 ../gui/wxpython/menustrings.py:1047
 msgid "Grow"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:376
+#: ../gui/wxpython/menustrings.py:383 ../gui/wxpython/menustrings.py:1048
 msgid "Generates a raster map layer with contiguous areas grown by one cell."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:377
+#: ../gui/wxpython/menustrings.py:384 ../gui/wxpython/menustrings.py:1049
 msgid "Thin"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:378
+#: ../gui/wxpython/menustrings.py:385 ../gui/wxpython/menustrings.py:1050
 msgid "Thins non-zero cells that denote linear features in a raster map layer."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:379
+#: ../gui/wxpython/menustrings.py:386 ../gui/wxpython/menustrings.py:1051
 msgid "Hydrologic modeling"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:380
+#: ../gui/wxpython/menustrings.py:387 ../gui/wxpython/menustrings.py:1052
 msgid "Carve stream channels"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:381
-msgid "Generates stream channels."
+#: ../gui/wxpython/menustrings.py:388 ../gui/wxpython/menustrings.py:1053
+msgid ""
+"Generates stream channels. Takes vector stream data, transforms it to raster "
+"and subtracts depth from the output DEM."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:382
+#: ../gui/wxpython/menustrings.py:389 ../gui/wxpython/menustrings.py:1054
 msgid "Fill lake"
 msgstr "Ezera aizpildīšana"
-#: ../gui/wxpython/menustrings.py:383
+#: ../gui/wxpython/menustrings.py:390 ../gui/wxpython/menustrings.py:1055
 msgid "Fills lake at given point to given level."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:384
+#: ../gui/wxpython/menustrings.py:391 ../gui/wxpython/menustrings.py:1056
 msgid "Depressionless map and flowlines"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:385
+#: ../gui/wxpython/menustrings.py:392 ../gui/wxpython/menustrings.py:1057
 msgid ""
 "Filters and generates a depressionless elevation map and a flow direction "
 "map from a given elevation raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:386
+#: ../gui/wxpython/menustrings.py:393 ../gui/wxpython/menustrings.py:1058
 msgid "Flow accumulation"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:387
+#: ../gui/wxpython/menustrings.py:394 ../gui/wxpython/menustrings.py:1059
 msgid "Flow computation for massive grids (float version)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:388
+#: ../gui/wxpython/menustrings.py:395 ../gui/wxpython/menustrings.py:1060
 msgid "Flow lines"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:389
-msgid "Constructs flowlines."
+#: ../gui/wxpython/menustrings.py:396 ../gui/wxpython/menustrings.py:1061
+msgid ""
+"Constructs flowlines. Computes flowlines, flowpath lengths, and "
+"flowaccumulation (contributing areas) from a elevation raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:390
+#: ../gui/wxpython/menustrings.py:397 ../gui/wxpython/menustrings.py:1062
 msgid "Watershed analysis"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:391
+#: ../gui/wxpython/menustrings.py:398 ../gui/wxpython/menustrings.py:1063
 msgid "Calculates hydrological parameters and RUSLE factors."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:392
+#: ../gui/wxpython/menustrings.py:399 ../gui/wxpython/menustrings.py:1064
 msgid "Watershed subbasins"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:393
+#: ../gui/wxpython/menustrings.py:400 ../gui/wxpython/menustrings.py:1065
 msgid "Generates watershed subbasins raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:394
+#: ../gui/wxpython/menustrings.py:401 ../gui/wxpython/menustrings.py:1066
 msgid "Watershed basin creation"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:395
-msgid "Creates watershed basins."
+#: ../gui/wxpython/menustrings.py:402 ../gui/wxpython/menustrings.py:1067
+msgid "Creates watershed basins from a drainage direction map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:396
+#: ../gui/wxpython/menustrings.py:403 ../gui/wxpython/menustrings.py:1068
 msgid "SIMWE Overland flow modeling"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:397
+#: ../gui/wxpython/menustrings.py:404 ../gui/wxpython/menustrings.py:1069
 msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:398
+#: ../gui/wxpython/menustrings.py:405 ../gui/wxpython/menustrings.py:1070
 msgid "SIMWE Sediment flux modeling"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:399
+#: ../gui/wxpython/menustrings.py:406 ../gui/wxpython/menustrings.py:1071
 msgid ""
 "Sediment transport and erosion/deposition simulation using path sampling "
 "method (SIMWE)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:400
+#: ../gui/wxpython/menustrings.py:407 ../gui/wxpython/menustrings.py:1072
 msgid "Topographic index map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:401
+#: ../gui/wxpython/menustrings.py:408 ../gui/wxpython/menustrings.py:1073
 msgid "Creates topographic index map from elevation raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:402
+#: ../gui/wxpython/menustrings.py:409 ../gui/wxpython/menustrings.py:1074
 msgid "TOPMODEL simulation"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:403
+#: ../gui/wxpython/menustrings.py:410 ../gui/wxpython/menustrings.py:1075
 msgid "Simulates TOPMODEL which is a physically based hydrologic model."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:404
+#: ../gui/wxpython/menustrings.py:411 ../gui/wxpython/menustrings.py:1076
 msgid "USLE K-factor"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:405
+#: ../gui/wxpython/menustrings.py:412 ../gui/wxpython/menustrings.py:1077
 msgid "Computes USLE Soil Erodibility Factor (K)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:406
+#: ../gui/wxpython/menustrings.py:413 ../gui/wxpython/menustrings.py:1078
 msgid "USLE R-factor"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:407
+#: ../gui/wxpython/menustrings.py:414 ../gui/wxpython/menustrings.py:1079
 msgid "Computes USLE R factor, Rainfall erosivity index."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:408 ../gui/wxpython/menustrings.py:838
+#: ../gui/wxpython/menustrings.py:415 ../gui/wxpython/menustrings.py:846
+#: ../gui/wxpython/menustrings.py:1080 ../gui/wxpython/menustrings.py:1511
 msgid "Groundwater modeling"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:409
+#: ../gui/wxpython/menustrings.py:416 ../gui/wxpython/menustrings.py:1081
 msgid "Groundwater flow"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:410
+#: ../gui/wxpython/menustrings.py:417 ../gui/wxpython/menustrings.py:1082
 msgid ""
 "Numerical calculation program for transient, confined and unconfined "
 "groundwater flow in two dimensions."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:411
+#: ../gui/wxpython/menustrings.py:418 ../gui/wxpython/menustrings.py:1083
 msgid "Groundwater solute transport"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:412
+#: ../gui/wxpython/menustrings.py:419 ../gui/wxpython/menustrings.py:1084
 msgid ""
 "Numerical calculation program for transient, confined and unconfined solute "
 "transport in two dimensions"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:413
+#: ../gui/wxpython/menustrings.py:420 ../gui/wxpython/menustrings.py:1085
 msgid "Landscape structure modeling"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:414
+#: ../gui/wxpython/menustrings.py:421 ../gui/wxpython/menustrings.py:1086
 msgid "Analyze landscape"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:415
-msgid ""
-"Contains a set of measures for attributes, diversity, texture, "
-"juxtaposition, and edge."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:416
+#: ../gui/wxpython/menustrings.py:422 ../gui/wxpython/menustrings.py:1087
 msgid "Analyze patches"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:417
-msgid ""
-"Calculates attribute, patch size, core (interior) size, shape, fractal "
-"dimension, and perimeter measures for sets of patches in a landscape."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:418
+#: ../gui/wxpython/menustrings.py:423 ../gui/wxpython/menustrings.py:1088
 msgid "Landscape patch analysis"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:419
+#: ../gui/wxpython/menustrings.py:424 ../gui/wxpython/menustrings.py:1089
 msgid "Set up sampling and analysis framework"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:420
+#: ../gui/wxpython/menustrings.py:425 ../gui/wxpython/menustrings.py:1090
 msgid "Configuration editor for r.li.'index'"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:421
+#: ../gui/wxpython/menustrings.py:426 ../gui/wxpython/menustrings.py:1091
 msgid "Edge density"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:422
-msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+#: ../gui/wxpython/menustrings.py:427 ../gui/wxpython/menustrings.py:1092
+msgid ""
+"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:423
+#: ../gui/wxpython/menustrings.py:428 ../gui/wxpython/menustrings.py:1093
 msgid "Contrast weighted edge density"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:424
+#: ../gui/wxpython/menustrings.py:429 ../gui/wxpython/menustrings.py:1094
 msgid "Calculates contrast weighted edge density index on a raster map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:425
+#: ../gui/wxpython/menustrings.py:430 ../gui/wxpython/menustrings.py:1095
 msgid "Patch area mean"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:426
+#: ../gui/wxpython/menustrings.py:431 ../gui/wxpython/menustrings.py:1096
 msgid ""
 "Calculates mean patch size index on a raster map, using a 4 neighbour "
 "algorithm"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:427
+#: ../gui/wxpython/menustrings.py:432 ../gui/wxpython/menustrings.py:1097
 msgid "Patch area range"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:428
+#: ../gui/wxpython/menustrings.py:433 ../gui/wxpython/menustrings.py:1098
 msgid "Calculates range of patch area size on a raster map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:429
+#: ../gui/wxpython/menustrings.py:434 ../gui/wxpython/menustrings.py:1099
 msgid "Patch area Std Dev"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:430
+#: ../gui/wxpython/menustrings.py:435 ../gui/wxpython/menustrings.py:1100
 msgid "Calculates standard deviation of patch area a raster map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:431
+#: ../gui/wxpython/menustrings.py:436 ../gui/wxpython/menustrings.py:1101
 msgid "Patch area Coeff Var"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:432
+#: ../gui/wxpython/menustrings.py:437 ../gui/wxpython/menustrings.py:1102
 msgid "Calculates coefficient of variation of patch area on a raster map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:433
+#: ../gui/wxpython/menustrings.py:438 ../gui/wxpython/menustrings.py:1103
 msgid "Patch density"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:434
-msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+#: ../gui/wxpython/menustrings.py:439 ../gui/wxpython/menustrings.py:1104
+msgid ""
+"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:435
+#: ../gui/wxpython/menustrings.py:440 ../gui/wxpython/menustrings.py:1105
 msgid "Patch number"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:436
-msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+#: ../gui/wxpython/menustrings.py:441 ../gui/wxpython/menustrings.py:1106
+msgid ""
+"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:437
+#: ../gui/wxpython/menustrings.py:442 ../gui/wxpython/menustrings.py:1107
 msgid "Dominance's diversity"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:438 ../gui/wxpython/menustrings.py:444
+#: ../gui/wxpython/menustrings.py:443 ../gui/wxpython/menustrings.py:449
+#: ../gui/wxpython/menustrings.py:1108 ../gui/wxpython/menustrings.py:1114
 msgid "Calculates dominance's diversity index on a raster map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:439
+#: ../gui/wxpython/menustrings.py:444 ../gui/wxpython/menustrings.py:1109
 msgid "Shannon's diversity"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:440
+#: ../gui/wxpython/menustrings.py:445 ../gui/wxpython/menustrings.py:1110
 msgid "Calculates Shannon's diversity index on a raster map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:441
+#: ../gui/wxpython/menustrings.py:446 ../gui/wxpython/menustrings.py:1111
 msgid "Simpson's diversity"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:442
+#: ../gui/wxpython/menustrings.py:447 ../gui/wxpython/menustrings.py:1112
 msgid "Calculates Simpson's diversity index on a raster map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:443
+#: ../gui/wxpython/menustrings.py:448 ../gui/wxpython/menustrings.py:1113
 msgid "Richness"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:445
+#: ../gui/wxpython/menustrings.py:450 ../gui/wxpython/menustrings.py:1115
 msgid "Shape index"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:446
+#: ../gui/wxpython/menustrings.py:451 ../gui/wxpython/menustrings.py:1116
 msgid "Calculates shape index on a raster map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:447
+#: ../gui/wxpython/menustrings.py:452 ../gui/wxpython/menustrings.py:1117
 msgid "Wildfire modeling"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:448
+#: ../gui/wxpython/menustrings.py:453 ../gui/wxpython/menustrings.py:1118
 msgid "Rate of spread"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:449
-msgid "Generates rate of spread raster map layers."
+#: ../gui/wxpython/menustrings.py:454 ../gui/wxpython/menustrings.py:1119
+msgid ""
+"Generates rate of spread raster map layers. Generates three, or four raster "
+"map layers showing 1) the base (perpendicular) rate of spread (ROS), 2) the "
+"maximum (forward) ROS, 3) the direction of the maximum ROS, and optionally "
+"4) the maximum potential spotting distance."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:450
+#: ../gui/wxpython/menustrings.py:455 ../gui/wxpython/menustrings.py:1120
 msgid "Least-cost spread paths"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:451
+#: ../gui/wxpython/menustrings.py:456 ../gui/wxpython/menustrings.py:1121
 msgid ""
 "Recursively traces the least cost path backwards to cells from which the "
 "cumulative cost was determined."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:452
+#: ../gui/wxpython/menustrings.py:457 ../gui/wxpython/menustrings.py:1122
 msgid "Anisotropic spread simulation"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:453
+#: ../gui/wxpython/menustrings.py:458 ../gui/wxpython/menustrings.py:1123
 msgid ""
 "Simulates elliptically anisotropic spread on a graphics window and generates "
 "a raster map of the cumulative time of spread, given raster maps containing "
-"the rates of spread (ROS), the ROS directions and the spread origins."
+"the rates of spread (ROS), the ROS directions and the spread origins. It "
+"optionally produces raster maps to contain backlink UTM coordinates for "
+"tracing spread paths."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:454
+#: ../gui/wxpython/menustrings.py:459 ../gui/wxpython/menustrings.py:1124
 msgid "Change category values and labels"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:455
+#: ../gui/wxpython/menustrings.py:460 ../gui/wxpython/menustrings.py:1125
 msgid "Interactively edit category values"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:456
+#: ../gui/wxpython/menustrings.py:461 ../gui/wxpython/menustrings.py:1126
 msgid "Edits cell values in a raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:457
+#: ../gui/wxpython/menustrings.py:462 ../gui/wxpython/menustrings.py:1127
 msgid "Reclassify by size"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:458
+#: ../gui/wxpython/menustrings.py:463 ../gui/wxpython/menustrings.py:1128
 msgid ""
 "Reclasses a raster map greater or less than user specified area size (in "
 "hectares)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:459 ../gui/wxpython/menustrings.py:663
+#: ../gui/wxpython/menustrings.py:464 ../gui/wxpython/menustrings.py:673
+#: ../gui/wxpython/menustrings.py:1129 ../gui/wxpython/menustrings.py:1338
 msgid "Reclassify"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:460
-msgid "Reclassify raster map based on category values."
+#: ../gui/wxpython/menustrings.py:465 ../gui/wxpython/menustrings.py:1130
+msgid ""
+"Reclassify raster map based on category values. Creates a new raster map "
+"whose category values are based upon a reclassification of the categories in "
+"an existing raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:461
+#: ../gui/wxpython/menustrings.py:466 ../gui/wxpython/menustrings.py:1131
 msgid "Recode"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:462
+#: ../gui/wxpython/menustrings.py:467 ../gui/wxpython/menustrings.py:1132
 msgid "Recodes categorical raster maps."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:463
+#: ../gui/wxpython/menustrings.py:468 ../gui/wxpython/menustrings.py:1133
 msgid "Rescale"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:464
+#: ../gui/wxpython/menustrings.py:469 ../gui/wxpython/menustrings.py:1134
 msgid "Rescales the range of category values in a raster map layer."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:465
+#: ../gui/wxpython/menustrings.py:470 ../gui/wxpython/menustrings.py:1135
 msgid "Rescale with histogram"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:466
+#: ../gui/wxpython/menustrings.py:471 ../gui/wxpython/menustrings.py:1136
 msgid ""
 "Rescales histogram equalized the range of category values in a raster map "
 "layer."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:467
+#: ../gui/wxpython/menustrings.py:472 ../gui/wxpython/menustrings.py:1137
 msgid "Generate random cells"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:468
+#: ../gui/wxpython/menustrings.py:473 ../gui/wxpython/menustrings.py:1138
 msgid "Random cells"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:469
+#: ../gui/wxpython/menustrings.py:474 ../gui/wxpython/menustrings.py:1139
 msgid "Generates random cell values with spatial dependence."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:470
+#: ../gui/wxpython/menustrings.py:475 ../gui/wxpython/menustrings.py:1140
 msgid "Random cells and vector points"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:471
+#: ../gui/wxpython/menustrings.py:476 ../gui/wxpython/menustrings.py:1141
 msgid ""
 "Creates a raster map layer and vector point map containing randomly located "
 "points."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:472
+#: ../gui/wxpython/menustrings.py:477 ../gui/wxpython/menustrings.py:1142
 msgid "Generate surfaces"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:473
+#: ../gui/wxpython/menustrings.py:478 ../gui/wxpython/menustrings.py:1143
 msgid "Fractal surface"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:474
+#: ../gui/wxpython/menustrings.py:479 ../gui/wxpython/menustrings.py:1144
 msgid "Creates a fractal surface of a given fractal dimension."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:475
+#: ../gui/wxpython/menustrings.py:480 ../gui/wxpython/menustrings.py:1145
 msgid "Gaussian kernel density surface"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:476
+#: ../gui/wxpython/menustrings.py:481 ../gui/wxpython/menustrings.py:1146
 msgid ""
-"Generates a raster density map from vector point data using a moving kernel "
-"or optionally generates a vector density map on a vector network."
+"Generates a raster density map from vector points map. Density is computed "
+"using a moving kernel. Optionally generates a vector density map on a vector "
+"network."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:477
+#: ../gui/wxpython/menustrings.py:482 ../gui/wxpython/menustrings.py:1147
 msgid "Gaussian deviates surface"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:478
+#: ../gui/wxpython/menustrings.py:483 ../gui/wxpython/menustrings.py:1148
 msgid ""
-"GRASS module to produce a raster map layer of gaussian deviates whose mean "
-"and standard deviation can be expressed by the user. It uses a gaussian "
-"random number generator."
+"Generates a raster map using gaussian random number generator. Mean and "
+"standard deviation of gaussian deviates can be expressed by the user."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:479 ../gui/wxpython/nviz/tools.py:4476
-#: ../gui/wxpython/gui_modules/nviz_tools.py:4590
+#: ../gui/wxpython/menustrings.py:484 ../gui/wxpython/menustrings.py:1149
+#: ../gui/wxpython/nviz/tools.py:4587
 msgid "Plane"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:480
+#: ../gui/wxpython/menustrings.py:485 ../gui/wxpython/menustrings.py:1150
 msgid ""
 "Creates raster plane map given dip (inclination), aspect (azimuth) and one "
 "point."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:481
+#: ../gui/wxpython/menustrings.py:486 ../gui/wxpython/menustrings.py:1151
 msgid "Random deviates surface"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:482
+#: ../gui/wxpython/menustrings.py:487 ../gui/wxpython/menustrings.py:1152
 msgid ""
-"Produces a raster map of uniform random deviates whose range can be "
-"expressed by the user."
+"Produces a raster surface map of uniform random deviates with defined range."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:483
+#: ../gui/wxpython/menustrings.py:488 ../gui/wxpython/menustrings.py:1153
 msgid "Random surface with spatial dependence"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:484
+#: ../gui/wxpython/menustrings.py:489 ../gui/wxpython/menustrings.py:1154
 msgid "Generates random surface(s) with spatial dependence."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:485
+#: ../gui/wxpython/menustrings.py:490 ../gui/wxpython/menustrings.py:1155
 msgid "Interpolate surfaces"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:486
+#: ../gui/wxpython/menustrings.py:491 ../gui/wxpython/menustrings.py:1156
 msgid "Bilinear and bicubic from vector points"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:488
+#: ../gui/wxpython/menustrings.py:492 ../gui/wxpython/menustrings.py:1157
+msgid ""
+"Performs bicubic or bilinear spline interpolation with Tykhonov "
+"regularization."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:493 ../gui/wxpython/menustrings.py:1158
 msgid "IDW from raster points"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:489
+#: ../gui/wxpython/menustrings.py:494 ../gui/wxpython/menustrings.py:1159
 msgid "Surface interpolation utility for raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:490
+#: ../gui/wxpython/menustrings.py:495 ../gui/wxpython/menustrings.py:1160
 msgid "IDW from raster points (alternate method for sparse points)"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:491
+#: ../gui/wxpython/menustrings.py:496 ../gui/wxpython/menustrings.py:1161
 msgid "Surface generation program."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:492
+#: ../gui/wxpython/menustrings.py:497 ../gui/wxpython/menustrings.py:1162
 msgid "IDW from vector points"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:493
+#: ../gui/wxpython/menustrings.py:498 ../gui/wxpython/menustrings.py:1163
 msgid ""
 "Surface interpolation from vector point data by Inverse Distance Squared "
 "Weighting."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:494
+#: ../gui/wxpython/menustrings.py:499 ../gui/wxpython/menustrings.py:1164
 msgid "Raster contours"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:495
+#: ../gui/wxpython/menustrings.py:500 ../gui/wxpython/menustrings.py:1165
 msgid "Generates surface raster map from rasterized contours."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:496
+#: ../gui/wxpython/menustrings.py:501 ../gui/wxpython/menustrings.py:1166
 msgid "Regularized spline tension"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:497
+#: ../gui/wxpython/menustrings.py:502 ../gui/wxpython/menustrings.py:1167
 msgid ""
-"Spatial approximation and topographic analysis from given point or isoline "
-"data in vector format to floating point raster format using regularized "
-"spline with tension."
+"Performs surface interpolation from vector points map by splines. Spatial "
+"approximation and topographic analysis from given point or isoline data in "
+"vector format to floating point raster format using regularized spline with "
+"tension."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:498
+#: ../gui/wxpython/menustrings.py:503 ../gui/wxpython/menustrings.py:1168
 msgid "Ordinary or block kriging"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:499
+#: ../gui/wxpython/menustrings.py:504 ../gui/wxpython/menustrings.py:1169
 msgid "Performs ordinary or block kriging."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:500
+#: ../gui/wxpython/menustrings.py:505 ../gui/wxpython/menustrings.py:1170
 msgid "Fill NULL cells"
 msgstr "Aizpildīt NULL šūnas"
-#: ../gui/wxpython/menustrings.py:501
+#: ../gui/wxpython/menustrings.py:506 ../gui/wxpython/menustrings.py:1171
 msgid "Fills no-data areas in raster maps using spline interpolation."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:502 ../gui/wxpython/menustrings.py:812
-msgid "Report and statistics"
-msgstr "Atskaites un statistika"
+#: ../gui/wxpython/menustrings.py:507 ../gui/wxpython/menustrings.py:712
+#: ../gui/wxpython/menustrings.py:820 ../gui/wxpython/menustrings.py:1172
+#: ../gui/wxpython/menustrings.py:1377 ../gui/wxpython/menustrings.py:1485
+#: ../gui/wxpython/menustrings.py:1655
+msgid "Reports and statistics"
+msgstr ""
-#: ../gui/wxpython/menustrings.py:503
+#: ../gui/wxpython/menustrings.py:508 ../gui/wxpython/menustrings.py:1173
 msgid "Basic raster metadata"
 msgstr "Rastra metadati"
-#: ../gui/wxpython/menustrings.py:504
+#: ../gui/wxpython/menustrings.py:509 ../gui/wxpython/menustrings.py:1174
 msgid "Outputs basic information about a raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:505
+#: ../gui/wxpython/menustrings.py:510 ../gui/wxpython/menustrings.py:1175
 msgid "Manage category information"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:506
+#: ../gui/wxpython/menustrings.py:511 ../gui/wxpython/menustrings.py:1176
 msgid ""
 "Manages category values and labels associated with user-specified raster map "
 "layers."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:507
+#: ../gui/wxpython/menustrings.py:512 ../gui/wxpython/menustrings.py:1177
 msgid "General statistics"
 msgstr "Vispārēja statistika"
-#: ../gui/wxpython/menustrings.py:508
-msgid "Generates area statistics for raster map layers."
-msgstr ""
+#: ../gui/wxpython/menustrings.py:513 ../gui/wxpython/menustrings.py:1178
+#, fuzzy
+msgid "Generates area statistics for raster map."
+msgstr "Ievietot eksistējošu 3D rastra karti"
-#: ../gui/wxpython/menustrings.py:509
+#: ../gui/wxpython/menustrings.py:514 ../gui/wxpython/menustrings.py:1179
 msgid "Quantiles for large data sets"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:510
+#: ../gui/wxpython/menustrings.py:515 ../gui/wxpython/menustrings.py:1180
 msgid "Compute quantiles using two passes."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:511
+#: ../gui/wxpython/menustrings.py:516 ../gui/wxpython/menustrings.py:1181
 msgid "Range of category values"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:512
+#: ../gui/wxpython/menustrings.py:517 ../gui/wxpython/menustrings.py:1182
 msgid "Prints terse list of category values found in a raster map layer."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:513
+#: ../gui/wxpython/menustrings.py:518 ../gui/wxpython/menustrings.py:1183
 msgid "Sum area by raster map and category"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:514
+#: ../gui/wxpython/menustrings.py:519 ../gui/wxpython/menustrings.py:1184
 msgid "Reports statistics for raster maps."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:515
+#: ../gui/wxpython/menustrings.py:520 ../gui/wxpython/menustrings.py:1185
 msgid "Statistics for clumped cells"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:516
+#: ../gui/wxpython/menustrings.py:521 ../gui/wxpython/menustrings.py:1186
 msgid ""
-"Calculates the volume of data \"clumps\", and (optionally) produces a GRASS "
-"vector points map containing the calculated centroids of these clumps."
+"Calculates the volume of data \"clumps\". Optionally produces a GRASS vector "
+"points map containing the calculated centroids of these clumps."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:517
+#: ../gui/wxpython/menustrings.py:522 ../gui/wxpython/menustrings.py:1187
 msgid "Total corrected area"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:518
+#: ../gui/wxpython/menustrings.py:523 ../gui/wxpython/menustrings.py:1188
 msgid "Prints estimation of surface area for raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:519 ../gui/wxpython/lmgr/layertree.py:446
-#: ../gui/wxpython/gui_modules/layertree.py:412
+#: ../gui/wxpython/menustrings.py:524 ../gui/wxpython/menustrings.py:1189
+#: ../gui/wxpython/lmgr/layertree.py:577 ../gui/wxpython/lmgr/layertree.py:604
 msgid "Univariate raster statistics"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:520
-msgid "Calculates univariate statistics from the non-null cells of a raster map."
+#: ../gui/wxpython/menustrings.py:525 ../gui/wxpython/menustrings.py:1190
+msgid ""
+"Calculates univariate statistics from the non-null cells of a raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:521
+#: ../gui/wxpython/menustrings.py:526 ../gui/wxpython/menustrings.py:1191
 msgid "Sample transects"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:522
+#: ../gui/wxpython/menustrings.py:527 ../gui/wxpython/menustrings.py:1192
 msgid "Outputs the raster map layer values lying on user-defined line(s)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:523
+#: ../gui/wxpython/menustrings.py:528 ../gui/wxpython/menustrings.py:1193
 msgid "Sample transects (bearing/distance)"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:524
-msgid "Outputs raster map layer values lying along user defined transect line(s)."
+#: ../gui/wxpython/menustrings.py:529 ../gui/wxpython/menustrings.py:1194
+msgid ""
+"Outputs raster map layer values lying along user defined transect line(s)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:525
+#: ../gui/wxpython/menustrings.py:530 ../gui/wxpython/menustrings.py:1195
 msgid "Covariance/correlation"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:526
+#: ../gui/wxpython/menustrings.py:531 ../gui/wxpython/menustrings.py:1196
 msgid ""
 "Outputs a covariance/correlation matrix for user-specified raster map "
 "layer(s)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:527
+#: ../gui/wxpython/menustrings.py:532 ../gui/wxpython/menustrings.py:1197
 msgid "Linear regression"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:528
+#: ../gui/wxpython/menustrings.py:533 ../gui/wxpython/menustrings.py:1198
 msgid "Calculates linear regression from two raster maps: y = a + b*x."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:529
+#: ../gui/wxpython/menustrings.py:534 ../gui/wxpython/menustrings.py:1199
+#, fuzzy
+msgid "Multiple regression"
+msgstr "Importēt vairākus"
+#: ../gui/wxpython/menustrings.py:535 ../gui/wxpython/menustrings.py:1200
+msgid "Calculates multiple linear regression from raster maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:536 ../gui/wxpython/menustrings.py:1201
 msgid "Mutual category occurrences"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:530
+#: ../gui/wxpython/menustrings.py:537 ../gui/wxpython/menustrings.py:1202
 msgid ""
 "Tabulates the mutual occurrence (coincidence) of categories for two raster "
 "map layers."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:531
+#: ../gui/wxpython/menustrings.py:538 ../gui/wxpython/menustrings.py:1203
 msgid "&Vector"
 msgstr "&Vektors"
-#: ../gui/wxpython/menustrings.py:532
+#: ../gui/wxpython/menustrings.py:539 ../gui/wxpython/menustrings.py:1204
 msgid "Develop vector map"
 msgstr "Izveidot vektordatu karti"
-#: ../gui/wxpython/menustrings.py:533
-#: ../gui/wxpython/gui_modules/gdialogs.py:224
-#: ../gui/wxpython/gui_modules/gdialogs.py:366
-#: ../gui/wxpython/gui_core/dialogs.py:227
-#: ../gui/wxpython/gui_core/dialogs.py:369
+#: ../gui/wxpython/menustrings.py:540 ../gui/wxpython/menustrings.py:1205
+#: ../gui/wxpython/gui_core/dialogs.py:234
+#: ../gui/wxpython/gui_core/dialogs.py:353
 msgid "Create new vector map"
 msgstr "Izveidot jaunu vektordatu karti"
-#: ../gui/wxpython/menustrings.py:534
+#: ../gui/wxpython/menustrings.py:541 ../gui/wxpython/menustrings.py:1206
 msgid "Create new empty vector map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:535
+#: ../gui/wxpython/menustrings.py:542 ../gui/wxpython/menustrings.py:1207
 msgid "Edit vector map (non-interactively)"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:536
+#: ../gui/wxpython/menustrings.py:543 ../gui/wxpython/menustrings.py:1208
 msgid ""
 "Edits a vector map, allows adding, deleting and modifying selected vector "
 "features."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:537
+#: ../gui/wxpython/menustrings.py:544 ../gui/wxpython/menustrings.py:1209
 msgid "Convert object types"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:538
+#: ../gui/wxpython/menustrings.py:545 ../gui/wxpython/menustrings.py:1210
 msgid "Changes type of vector features."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:539
+#: ../gui/wxpython/menustrings.py:546 ../gui/wxpython/menustrings.py:1211
 msgid "Parallel lines"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:540
+#: ../gui/wxpython/menustrings.py:547 ../gui/wxpython/menustrings.py:1212
 msgid "Creates parallel line to input vector lines."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:541
+#: ../gui/wxpython/menustrings.py:548 ../gui/wxpython/menustrings.py:1213
 msgid "Dissolve boundaries"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:542
+#: ../gui/wxpython/menustrings.py:549 ../gui/wxpython/menustrings.py:1214
 msgid ""
 "Dissolves boundaries between adjacent areas sharing a common category number "
 "or attribute."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:543
+#: ../gui/wxpython/menustrings.py:550 ../gui/wxpython/menustrings.py:1215
 msgid "Create 3D vector over raster"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:544
-msgid "Converts vector map to 3D by sampling of elevation raster map."
+#: ../gui/wxpython/menustrings.py:551 ../gui/wxpython/menustrings.py:1216
+msgid "Converts 2D vector features to 3D by sampling of elevation raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:545
+#: ../gui/wxpython/menustrings.py:552 ../gui/wxpython/menustrings.py:1217
 msgid "Extrude 3D vector map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:546
-msgid "Extrudes flat vector features to 3D with defined height."
+#: ../gui/wxpython/menustrings.py:553 ../gui/wxpython/menustrings.py:1218
+msgid ""
+"Extrudes flat vector features to 3D vector features with defined height. "
+"Optionally the height can be derived from sampling of elevation raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:547
+#: ../gui/wxpython/menustrings.py:554 ../gui/wxpython/menustrings.py:1219
 msgid "Create labels"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:548
+#: ../gui/wxpython/menustrings.py:555 ../gui/wxpython/menustrings.py:1220
 msgid "Creates paint labels for a vector map from attached attributes."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:549
+#: ../gui/wxpython/menustrings.py:556 ../gui/wxpython/menustrings.py:1221
 msgid "Create optimally placed labels"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:550
-msgid "Create optimally placed labels for vector map(s)"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:551
+#: ../gui/wxpython/menustrings.py:557 ../gui/wxpython/menustrings.py:1222
 msgid "Reposition vector map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:552
+#: ../gui/wxpython/menustrings.py:558 ../gui/wxpython/menustrings.py:1223
 msgid ""
-"Performs an affine transformation (shift, scale and rotate, or GPCs) on "
-"vector map."
+"Performs an affine transformation (shift, scale and rotate) on vector map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:553
+#: ../gui/wxpython/menustrings.py:559 ../gui/wxpython/menustrings.py:1224
 msgid "Rectify vector map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:554
+#: ../gui/wxpython/menustrings.py:560 ../gui/wxpython/menustrings.py:1225
 msgid ""
 "Rectifies a vector by computing a coordinate transformation for each object "
 "in the vector based on the control points."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:555
-msgid "Reproject vector map"
+#: ../gui/wxpython/menustrings.py:561 ../gui/wxpython/menustrings.py:1226
+msgid "Reproject vector map from different location"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:556
+#: ../gui/wxpython/menustrings.py:562 ../gui/wxpython/menustrings.py:1227
 msgid "Re-projects a vector map from one location to the current location."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:558
+#: ../gui/wxpython/menustrings.py:564 ../gui/wxpython/menustrings.py:1229
 msgid "Updates vector map metadata."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:559
+#: ../gui/wxpython/menustrings.py:565 ../gui/wxpython/menustrings.py:1230
 msgid "Topology maintenance"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:560
+#: ../gui/wxpython/menustrings.py:566 ../gui/wxpython/menustrings.py:1231
 msgid "Create or rebuild topology"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:561
-msgid "Creates topology for vector map."
+#: ../gui/wxpython/menustrings.py:567 ../gui/wxpython/menustrings.py:1232
+msgid ""
+"Creates topology for vector map. Optionaly also checks for topological "
+"errors."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:562
+#: ../gui/wxpython/menustrings.py:568 ../gui/wxpython/menustrings.py:1233
 msgid "Rebuild topology on all vector maps"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:563
+#: ../gui/wxpython/menustrings.py:569 ../gui/wxpython/menustrings.py:1234
 msgid "Rebuilds topology on all vector maps in the current mapset."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:564
+#: ../gui/wxpython/menustrings.py:570 ../gui/wxpython/menustrings.py:1235
 msgid "Build polylines"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:565
+#: ../gui/wxpython/menustrings.py:571 ../gui/wxpython/menustrings.py:1236
 msgid "Builds polylines from lines or boundaries."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:566
+#: ../gui/wxpython/menustrings.py:572 ../gui/wxpython/menustrings.py:1237
 msgid "Split lines"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:567
+#: ../gui/wxpython/menustrings.py:573 ../gui/wxpython/menustrings.py:1238
 msgid "Splits vector lines to shorter segments."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:568
+#: ../gui/wxpython/menustrings.py:574 ../gui/wxpython/menustrings.py:1239
 msgid "Split polylines"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:569
+#: ../gui/wxpython/menustrings.py:575 ../gui/wxpython/menustrings.py:1240
 msgid "Creates points/segments from input vector lines and positions."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:570
+#: ../gui/wxpython/menustrings.py:576 ../gui/wxpython/menustrings.py:1241
 msgid "Clean vector map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:571
+#: ../gui/wxpython/menustrings.py:577 ../gui/wxpython/menustrings.py:1242
 msgid "Toolset for cleaning topology of vector map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:572
+#: ../gui/wxpython/menustrings.py:578 ../gui/wxpython/menustrings.py:1243
 msgid "Smooth or simplify"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:573
-msgid "Tool for vector based generalization."
+#: ../gui/wxpython/menustrings.py:579 ../gui/wxpython/menustrings.py:1244
+msgid "Performs vector based generalization."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:574
+#: ../gui/wxpython/menustrings.py:580 ../gui/wxpython/menustrings.py:1245
 msgid "Add centroids"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:575
+#: ../gui/wxpython/menustrings.py:581 ../gui/wxpython/menustrings.py:1246
 msgid "Adds missing centroids to closed boundaries."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:578
+#: ../gui/wxpython/menustrings.py:584 ../gui/wxpython/menustrings.py:1249
 msgid "Creates/modifies the color table associated with a vector map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:579
-msgid "Color rules"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:580
+#: ../gui/wxpython/menustrings.py:586 ../gui/wxpython/menustrings.py:1251
 msgid "Interactive management of vector color tables."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:582
+#: ../gui/wxpython/menustrings.py:588 ../gui/wxpython/menustrings.py:1253
 msgid "Exports the color table associated with a vector map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:583
+#: ../gui/wxpython/menustrings.py:589 ../gui/wxpython/menustrings.py:1254
 msgid "Query vector map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:584
+#: ../gui/wxpython/menustrings.py:590 ../gui/wxpython/menustrings.py:1255
 msgid "Query with coordinate(s)"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:585
+#: ../gui/wxpython/menustrings.py:591 ../gui/wxpython/menustrings.py:1256
 msgid "Queries a vector map at given locations."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:586 ../gui/wxpython/menustrings.py:881
+#: ../gui/wxpython/menustrings.py:592 ../gui/wxpython/menustrings.py:889
+#: ../gui/wxpython/menustrings.py:1257 ../gui/wxpython/menustrings.py:1554
 msgid "Query vector attribute data"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:587 ../gui/wxpython/menustrings.py:882
+#: ../gui/wxpython/menustrings.py:593 ../gui/wxpython/menustrings.py:890
+#: ../gui/wxpython/menustrings.py:1258 ../gui/wxpython/menustrings.py:1555
 msgid "Prints vector map attributes."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:588
+#: ../gui/wxpython/menustrings.py:594 ../gui/wxpython/menustrings.py:1259
 msgid "Feature selection"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:589
+#: ../gui/wxpython/menustrings.py:595 ../gui/wxpython/menustrings.py:1260
 msgid "Select by attributes"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:590
+#: ../gui/wxpython/menustrings.py:596 ../gui/wxpython/menustrings.py:1261
 msgid ""
 "Selects vector features from an existing vector map and creates a new vector "
 "map containing only the selected features."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:591
+#: ../gui/wxpython/menustrings.py:597 ../gui/wxpython/menustrings.py:1262
 msgid "Select by another map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:592
-msgid "Selects features from vector map (A) by features from other vector map (B)."
+#: ../gui/wxpython/menustrings.py:598 ../gui/wxpython/menustrings.py:1263
+msgid ""
+"Selects features from vector map (A) by features from other vector map (B)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:602
+#: ../gui/wxpython/menustrings.py:608 ../gui/wxpython/menustrings.py:1273
 msgid "Buffer vectors"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:603
+#: ../gui/wxpython/menustrings.py:609 ../gui/wxpython/menustrings.py:1274
 msgid "Creates a buffer around vector features of given type."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:604
+#: ../gui/wxpython/menustrings.py:610 ../gui/wxpython/menustrings.py:1275
 msgid "Lidar analysis"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:605
+#: ../gui/wxpython/menustrings.py:611 ../gui/wxpython/menustrings.py:1276
+msgid "Identify and remove outliers"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:612 ../gui/wxpython/menustrings.py:709
+#: ../gui/wxpython/menustrings.py:1277 ../gui/wxpython/menustrings.py:1374
+msgid "Removes outliers from vector point data."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:613 ../gui/wxpython/menustrings.py:1278
 msgid "Detect edges"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:606
+#: ../gui/wxpython/menustrings.py:614 ../gui/wxpython/menustrings.py:1279
 msgid "Detects the object's edges from a LIDAR data set."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:607
+#: ../gui/wxpython/menustrings.py:615 ../gui/wxpython/menustrings.py:1280
 msgid "Detect interiors"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:608
+#: ../gui/wxpython/menustrings.py:616 ../gui/wxpython/menustrings.py:1281
 msgid ""
 "Building contour determination and Region Growing algorithm for determining "
 "the building inside"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:609
+#: ../gui/wxpython/menustrings.py:617 ../gui/wxpython/menustrings.py:1282
 msgid "Correct and reclassify objects"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:610
+#: ../gui/wxpython/menustrings.py:618 ../gui/wxpython/menustrings.py:1283
 msgid ""
 "Correction of the v.lidar.growing output. It is the last of the three "
 "algorithms for LIDAR filtering."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:611
+#: ../gui/wxpython/menustrings.py:619 ../gui/wxpython/menustrings.py:1284
 msgid "Linear referencing"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:612
+#: ../gui/wxpython/menustrings.py:620 ../gui/wxpython/menustrings.py:1285
 msgid "Create LRS"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:613
-msgid "Create Linear Reference System"
+#: ../gui/wxpython/menustrings.py:621 ../gui/wxpython/menustrings.py:1286
+msgid "Creates a linear reference system."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:614
+#: ../gui/wxpython/menustrings.py:622 ../gui/wxpython/menustrings.py:1287
 msgid "Create stationing"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:615
-msgid "Create stationing from input lines, and linear reference system"
+#: ../gui/wxpython/menustrings.py:623 ../gui/wxpython/menustrings.py:1288
+msgid "Creates stationing from input lines, and linear reference system."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:616
+#: ../gui/wxpython/menustrings.py:624 ../gui/wxpython/menustrings.py:1289
 msgid "Create points/segments"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:617
+#: ../gui/wxpython/menustrings.py:625 ../gui/wxpython/menustrings.py:1290
 msgid ""
 "Creates points/segments from input lines, linear reference system and "
 "positions read from stdin or a file."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:618
+#: ../gui/wxpython/menustrings.py:626 ../gui/wxpython/menustrings.py:1291
 msgid "Find line id and offset"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:619
+#: ../gui/wxpython/menustrings.py:627 ../gui/wxpython/menustrings.py:1292
 msgid ""
 "Finds line id and real km+offset for given points in vector map using linear "
 "reference system."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:620
+#: ../gui/wxpython/menustrings.py:628 ../gui/wxpython/menustrings.py:1293
 msgid "Nearest features"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:621
+#: ../gui/wxpython/menustrings.py:629 ../gui/wxpython/menustrings.py:1294
 msgid ""
 "Finds the nearest element in vector map 'to' for elements in vector map "
 "'from'."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:622
+#: ../gui/wxpython/menustrings.py:630 ../gui/wxpython/menustrings.py:1295
 msgid "Network analysis"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:623
+#: ../gui/wxpython/menustrings.py:631 ../gui/wxpython/menustrings.py:1296
+#: ../gui/wxpython/mapdisp/toolbars.py:53
+msgid "Vector network analysis tool"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:632 ../gui/wxpython/menustrings.py:1297
+msgid "Tool for interactive vector network analysis."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:633 ../gui/wxpython/menustrings.py:1298
 msgid "Network preparation"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:624
+#: ../gui/wxpython/menustrings.py:634 ../gui/wxpython/menustrings.py:1299
 msgid "Performs network maintenance."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:625
+#: ../gui/wxpython/menustrings.py:635 ../gui/wxpython/menustrings.py:1300
 msgid "Allocate subnets"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:626
-msgid "Allocate subnets for nearest centers (direction from center)."
+#: ../gui/wxpython/menustrings.py:636 ../gui/wxpython/menustrings.py:1301
+msgid ""
+"Allocate subnets for nearest centers (direction from center). center node "
+"must be opened (costs >= 0). Costs of center node are used in calculation"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:627
+#: ../gui/wxpython/menustrings.py:637 ../gui/wxpython/menustrings.py:1302
 msgid "Split net"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:628
-msgid "Splits net by cost isolines."
+#: ../gui/wxpython/menustrings.py:638 ../gui/wxpython/menustrings.py:1303
+msgid ""
+"Splits net by cost isolines. Splits net to bands between cost isolines "
+"(direction from centre). Centre node must be opened (costs >= 0). Costs of "
+"centre node are used in calculation."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:629
+#: ../gui/wxpython/menustrings.py:639 ../gui/wxpython/menustrings.py:1304
 msgid "Shortest path"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:630
+#: ../gui/wxpython/menustrings.py:640 ../gui/wxpython/menustrings.py:1305
 msgid "Finds shortest path on vector network."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:631
+#: ../gui/wxpython/menustrings.py:641 ../gui/wxpython/menustrings.py:1306
 msgid "Shortest path for sets of features"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:632
+#: ../gui/wxpython/menustrings.py:642 ../gui/wxpython/menustrings.py:1307
 msgid ""
 "Computes shortest distance via the network between the given sets of "
-"features."
+"features. Finds the shortest paths from each 'from' point to the nearest "
+"'to' feature and various information about this relation are uploaded to the "
+"attribute table."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:633
+#: ../gui/wxpython/menustrings.py:643 ../gui/wxpython/menustrings.py:1308
 msgid "Shortest path using timetables"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:634
+#: ../gui/wxpython/menustrings.py:644 ../gui/wxpython/menustrings.py:1309
 msgid "Finds shortest path using timetables."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:635
+#: ../gui/wxpython/menustrings.py:645 ../gui/wxpython/menustrings.py:1310
 msgid "Shortest path for all pairs"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:636
+#: ../gui/wxpython/menustrings.py:646 ../gui/wxpython/menustrings.py:1311
 msgid "Computes the shortest path between all pairs of nodes in the network."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:637
+#: ../gui/wxpython/menustrings.py:647 ../gui/wxpython/menustrings.py:1312
 msgid "Visibility network"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:638
-msgid "Visibility graph construction."
+#: ../gui/wxpython/menustrings.py:648 ../gui/wxpython/menustrings.py:1313
+msgid "Performs visibility graph construction."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:639
+#: ../gui/wxpython/menustrings.py:649 ../gui/wxpython/menustrings.py:1314
 msgid "Bridges and articulation points"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:640
+#: ../gui/wxpython/menustrings.py:650 ../gui/wxpython/menustrings.py:1315
 msgid "Computes bridges and articulation points in the network."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:641
+#: ../gui/wxpython/menustrings.py:651 ../gui/wxpython/menustrings.py:1316
 msgid "Maximum flow"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:642
+#: ../gui/wxpython/menustrings.py:652 ../gui/wxpython/menustrings.py:1317
 msgid "Computes the maximum flow between two sets of nodes in the network."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:643
+#: ../gui/wxpython/menustrings.py:653 ../gui/wxpython/menustrings.py:1318
 msgid "Vertex connectivity"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:644
+#: ../gui/wxpython/menustrings.py:654 ../gui/wxpython/menustrings.py:1319
 msgid "Computes vertex connectivity between two sets of nodes in the network."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:645
+#: ../gui/wxpython/menustrings.py:655 ../gui/wxpython/menustrings.py:1320
 msgid "Components"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:646
+#: ../gui/wxpython/menustrings.py:656 ../gui/wxpython/menustrings.py:1321
 msgid "Computes strongly and weakly connected components in the network."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:647
+#: ../gui/wxpython/menustrings.py:657 ../gui/wxpython/menustrings.py:1322
 msgid "Centrality"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:648
+#: ../gui/wxpython/menustrings.py:658 ../gui/wxpython/menustrings.py:1323
 msgid ""
 "Computes degree, centrality, betweeness, closeness and eigenvector "
 "centrality measures in the network."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:649
+#: ../gui/wxpython/menustrings.py:659 ../gui/wxpython/menustrings.py:1324
 msgid "Steiner tree"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:650
-msgid "Create Steiner tree for the network and given terminals"
+#: ../gui/wxpython/menustrings.py:660 ../gui/wxpython/menustrings.py:1325
+msgid ""
+"Creates Steiner tree for the network and given terminals. Note that 'Minimum "
+"Steiner Tree' problem is NP-hard and heuristic algorithm is used in this "
+"module so the result may be sub optimal."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:651
+#: ../gui/wxpython/menustrings.py:661 ../gui/wxpython/menustrings.py:1326
 msgid "Minimum spanning tree"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:652
+#: ../gui/wxpython/menustrings.py:662 ../gui/wxpython/menustrings.py:1327
 msgid "Computes minimum spanning tree for the network."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:653
+#: ../gui/wxpython/menustrings.py:663 ../gui/wxpython/menustrings.py:1328
 msgid "Traveling salesman analysis"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:654
-msgid "Creates a cycle connecting given nodes (Traveling salesman problem)."
+#: ../gui/wxpython/menustrings.py:664 ../gui/wxpython/menustrings.py:1329
+msgid ""
+"Creates a cycle connecting given nodes (Traveling salesman problem). Note "
+"that TSP is NP-hard, heuristic algorithm is used by this module and created "
+"cycle may be sub optimal"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:655 ../gui/wxpython/menustrings.py:656
+#: ../gui/wxpython/menustrings.py:665 ../gui/wxpython/menustrings.py:666
+#: ../gui/wxpython/menustrings.py:1330 ../gui/wxpython/menustrings.py:1331
 msgid "Overlay vector maps"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:657
+#: ../gui/wxpython/menustrings.py:667 ../gui/wxpython/menustrings.py:1332
 msgid "Overlays two vector maps."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:658
+#: ../gui/wxpython/menustrings.py:668 ../gui/wxpython/menustrings.py:1333
 msgid "Patch vector maps"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:659
+#: ../gui/wxpython/menustrings.py:669 ../gui/wxpython/menustrings.py:1334
 msgid "Creates a new vector map by combining other vector maps."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:660
+#: ../gui/wxpython/menustrings.py:670 ../gui/wxpython/menustrings.py:1335
 msgid "Manage categories"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:661
+#: ../gui/wxpython/menustrings.py:671 ../gui/wxpython/menustrings.py:1336
 msgid "Change or report categories"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:662
+#: ../gui/wxpython/menustrings.py:672 ../gui/wxpython/menustrings.py:1337
 msgid "Attaches, deletes or reports vector categories to map geometry."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:664
+#: ../gui/wxpython/menustrings.py:674 ../gui/wxpython/menustrings.py:1339
 msgid ""
 "Changes vector category values for an existing vector map according to "
 "results of SQL queries or a value in attribute table column."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:665
-#: ../gui/wxpython/gui_modules/dbm_dialogs.py:111
-#: ../gui/wxpython/dbmgr/dialogs.py:112
+#: ../gui/wxpython/menustrings.py:675 ../gui/wxpython/menustrings.py:1340
+#: ../gui/wxpython/dbmgr/dialogs.py:115
 msgid "Update attributes"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:666
+#: ../gui/wxpython/menustrings.py:676 ../gui/wxpython/menustrings.py:1341
 msgid "Update area attributes from raster"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:667
+#: ../gui/wxpython/menustrings.py:677 ../gui/wxpython/menustrings.py:1342
 msgid ""
 "Calculates univariate statistics from a raster map based on vector polygon "
 "map and uploads statistics to new attribute columns."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:668
+#: ../gui/wxpython/menustrings.py:678 ../gui/wxpython/menustrings.py:1343
 msgid "Update area attributes from vector"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:669
+#: ../gui/wxpython/menustrings.py:679 ../gui/wxpython/menustrings.py:1344
 msgid "Count points in areas, calculate statistics from point attributes."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:670
+#: ../gui/wxpython/menustrings.py:680 ../gui/wxpython/menustrings.py:1345
 msgid "Update point attributes from areas"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:671
+#: ../gui/wxpython/menustrings.py:681 ../gui/wxpython/menustrings.py:1346
 msgid "Uploads vector values at positions of vector points to the table."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:672
+#: ../gui/wxpython/menustrings.py:682 ../gui/wxpython/menustrings.py:1347
 msgid "Update database values from vector"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:673
-msgid "Populates database values from vector features."
+#: ../gui/wxpython/menustrings.py:683 ../gui/wxpython/menustrings.py:1348
+msgid "Populates attribute values from vector features."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:674
+#: ../gui/wxpython/menustrings.py:684 ../gui/wxpython/menustrings.py:1349
 msgid "Sample raster maps at point locations"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:675
+#: ../gui/wxpython/menustrings.py:685 ../gui/wxpython/menustrings.py:1350
 msgid "Uploads raster values at positions of vector points to the table."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:676
+#: ../gui/wxpython/menustrings.py:686 ../gui/wxpython/menustrings.py:1351
 msgid "Sample raster neighborhood around points"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:677
+#: ../gui/wxpython/menustrings.py:687 ../gui/wxpython/menustrings.py:1352
 msgid "Samples a raster map at vector point locations."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:678
+#: ../gui/wxpython/menustrings.py:688 ../gui/wxpython/menustrings.py:1353
 msgid "Generate area for current region"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:679
+#: ../gui/wxpython/menustrings.py:689 ../gui/wxpython/menustrings.py:1354
 msgid "Creates a vector polygon from the current region extent."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:680
+#: ../gui/wxpython/menustrings.py:690 ../gui/wxpython/menustrings.py:1355
 msgid "Generate areas from points"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:681
+#: ../gui/wxpython/menustrings.py:691 ../gui/wxpython/menustrings.py:1356
 msgid "Convex hull"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:682
-msgid "Produces a convex hull for a given vector map."
+#: ../gui/wxpython/menustrings.py:692 ../gui/wxpython/menustrings.py:1357
+msgid "Produces a 2D/3D convex hull for a given vector map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:683
+#: ../gui/wxpython/menustrings.py:693 ../gui/wxpython/menustrings.py:1358
 msgid "Delaunay triangles"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:684
+#: ../gui/wxpython/menustrings.py:694 ../gui/wxpython/menustrings.py:1359
 msgid ""
 "Creates a Delaunay triangulation from an input vector map containing points "
 "or centroids."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:685
+#: ../gui/wxpython/menustrings.py:695 ../gui/wxpython/menustrings.py:1360
 msgid "Voronoi diagram/Thiessen polygons"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:686
+#: ../gui/wxpython/menustrings.py:696 ../gui/wxpython/menustrings.py:1361
 msgid ""
 "Creates a Voronoi diagram in current region from an input vector map "
 "containing points or centroids."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:687
+#: ../gui/wxpython/menustrings.py:697 ../gui/wxpython/menustrings.py:1362
 msgid "Generate grid"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:688
+#: ../gui/wxpython/menustrings.py:698 ../gui/wxpython/menustrings.py:1363
 msgid "Creates a vector map of a user-defined grid."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:689
+#: ../gui/wxpython/menustrings.py:699 ../gui/wxpython/menustrings.py:1364
 msgid "Generate points"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:690
+#: ../gui/wxpython/menustrings.py:700 ../gui/wxpython/menustrings.py:1365
 msgid "Generate from database"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:691
-msgid "Creates new vector (points) map from database table containing coordinates."
+#: ../gui/wxpython/menustrings.py:701 ../gui/wxpython/menustrings.py:1366
+msgid ""
+"Creates new vector (points) map from database table containing coordinates."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:692
+#: ../gui/wxpython/menustrings.py:702 ../gui/wxpython/menustrings.py:1367
 msgid "Generate points along lines"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:693
+#: ../gui/wxpython/menustrings.py:703 ../gui/wxpython/menustrings.py:1368
 msgid "Creates points along input lines in new vector map with 2 layers."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:694
+#: ../gui/wxpython/menustrings.py:704 ../gui/wxpython/menustrings.py:1369
 msgid "Generate random points"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:695
+#: ../gui/wxpython/menustrings.py:705 ../gui/wxpython/menustrings.py:1370
 msgid "Generates randomly 2D/3D vector points map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:696
+#: ../gui/wxpython/menustrings.py:706 ../gui/wxpython/menustrings.py:1371
 msgid "Perturb points"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:697
+#: ../gui/wxpython/menustrings.py:707 ../gui/wxpython/menustrings.py:1372
 msgid "Random location perturbations of vector points."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:698
+#: ../gui/wxpython/menustrings.py:708 ../gui/wxpython/menustrings.py:1373
 msgid "Remove outliers in point sets"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:699
-msgid "Removes outliers from vector point data."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:700
+#: ../gui/wxpython/menustrings.py:710 ../gui/wxpython/menustrings.py:1375
 msgid "Test/training point sets"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:701
+#: ../gui/wxpython/menustrings.py:711 ../gui/wxpython/menustrings.py:1376
 msgid "Randomly partition points into test/train sets."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:702
-msgid "Reports and statistics"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:703
+#: ../gui/wxpython/menustrings.py:713 ../gui/wxpython/menustrings.py:1378
 msgid "Basic vector metadata"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:704
+#: ../gui/wxpython/menustrings.py:714 ../gui/wxpython/menustrings.py:1379
 msgid "Outputs basic information about a vector map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:705
+#: ../gui/wxpython/menustrings.py:715 ../gui/wxpython/menustrings.py:1380
 msgid "Classify attribute data"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:706
+#: ../gui/wxpython/menustrings.py:716 ../gui/wxpython/menustrings.py:1381
 msgid "Classifies attribute data, e.g. for thematic mapping"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:707
+#: ../gui/wxpython/menustrings.py:717 ../gui/wxpython/menustrings.py:1382
 msgid "Report topology by category"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:708
+#: ../gui/wxpython/menustrings.py:718 ../gui/wxpython/menustrings.py:1383
 msgid "Reports geometry statistics for vector maps."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:709
+#: ../gui/wxpython/menustrings.py:719 ../gui/wxpython/menustrings.py:1384
 msgid "Univariate attribute statistics for points"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:710
-msgid "Calculates univariate statistics for attribute."
+#: ../gui/wxpython/menustrings.py:720 ../gui/wxpython/menustrings.py:1385
+msgid ""
+"Calculates univariate statistics for attribute. Variance and standard "
+"deviation is calculated only for points if specified."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:711
+#: ../gui/wxpython/menustrings.py:721 ../gui/wxpython/menustrings.py:1386
 msgid "Univariate statistics for attribute columns"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:712
+#: ../gui/wxpython/menustrings.py:722 ../gui/wxpython/menustrings.py:1387
 msgid ""
 "Calculates univariate statistics on selected table column for a GRASS vector "
 "map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:713
+#: ../gui/wxpython/menustrings.py:723 ../gui/wxpython/menustrings.py:1388
 msgid "Quadrat indices"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:714
+#: ../gui/wxpython/menustrings.py:724 ../gui/wxpython/menustrings.py:1389
 msgid "Indices for quadrat counts of sites lists."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:715
+#: ../gui/wxpython/menustrings.py:725 ../gui/wxpython/menustrings.py:1390
 msgid "Test normality"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:716
+#: ../gui/wxpython/menustrings.py:726 ../gui/wxpython/menustrings.py:1391
 msgid "Tests for normality for vector points."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:717
+#: ../gui/wxpython/menustrings.py:727 ../gui/wxpython/menustrings.py:1392
 msgid "&Imagery"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:718
+#: ../gui/wxpython/menustrings.py:728 ../gui/wxpython/menustrings.py:1393
 msgid "Develop images and groups"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:719
+#: ../gui/wxpython/menustrings.py:729 ../gui/wxpython/menustrings.py:1394
 msgid "Create/edit group"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:720
+#: ../gui/wxpython/menustrings.py:730 ../gui/wxpython/menustrings.py:1395
 msgid "Creates, edits, and lists groups of imagery files."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:721
+#: ../gui/wxpython/menustrings.py:731 ../gui/wxpython/menustrings.py:1396
 msgid "Target group"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:722
+#: ../gui/wxpython/menustrings.py:732 ../gui/wxpython/menustrings.py:1397
 msgid "Targets an imagery group to a GRASS location and mapset."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:723
+#: ../gui/wxpython/menustrings.py:733 ../gui/wxpython/menustrings.py:1398
 msgid "Mosaic images"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:724
+#: ../gui/wxpython/menustrings.py:734 ../gui/wxpython/menustrings.py:1399
 msgid "Mosaics several images and extends colormap."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:725
+#: ../gui/wxpython/menustrings.py:735 ../gui/wxpython/menustrings.py:1400
 msgid "Manage image colors"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:726
+#: ../gui/wxpython/menustrings.py:736 ../gui/wxpython/menustrings.py:1401
 msgid "Color balance for RGB"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:727
+#: ../gui/wxpython/menustrings.py:737 ../gui/wxpython/menustrings.py:1402
 msgid "Performs auto-balancing of colors for LANDSAT images."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:728
+#: ../gui/wxpython/menustrings.py:738 ../gui/wxpython/menustrings.py:1403
 msgid "HIS to RGB"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:729
+#: ../gui/wxpython/menustrings.py:739 ../gui/wxpython/menustrings.py:1404
 msgid ""
 "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
 "RGB (Red-Green-Blue) color space."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:731
+#: ../gui/wxpython/menustrings.py:741 ../gui/wxpython/menustrings.py:1406
 msgid ""
 "Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
 "Intensity-Saturation) color space."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:732
+#: ../gui/wxpython/menustrings.py:742 ../gui/wxpython/menustrings.py:1407
 msgid "Rectify image or raster"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:733
+#: ../gui/wxpython/menustrings.py:743 ../gui/wxpython/menustrings.py:1408
 msgid ""
 "Rectifies an image by computing a coordinate transformation for each pixel "
 "in the image based on the control points."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:734 ../gui/wxpython/lmgr/layertree.py:444
-#: ../gui/wxpython/gui_modules/layertree.py:410
+#: ../gui/wxpython/menustrings.py:744 ../gui/wxpython/menustrings.py:1409
+#: ../gui/wxpython/lmgr/layertree.py:572
 msgid "Histogram"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:735
+#: ../gui/wxpython/menustrings.py:745 ../gui/wxpython/menustrings.py:1410
 msgid "Generate histogram of image"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:736
+#: ../gui/wxpython/menustrings.py:746 ../gui/wxpython/menustrings.py:1411
 msgid "Spectral response"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:737
-msgid "Displays spectral response at user specified locations in group or images."
+#: ../gui/wxpython/menustrings.py:747 ../gui/wxpython/menustrings.py:1412
+msgid ""
+"Displays spectral response at user specified locations in group or images."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:738
+#: ../gui/wxpython/menustrings.py:748 ../gui/wxpython/menustrings.py:1413
 msgid "Pan sharpening"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:739
-msgid "Sharpen image by merging multispectral and high-res panchromatic channels"
+#: ../gui/wxpython/menustrings.py:749 ../gui/wxpython/menustrings.py:1414
+msgid ""
+"Image fusion algorithms to sharpen multispectral with high-res panchromatic "
+"channels"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:740
+#: ../gui/wxpython/menustrings.py:750 ../gui/wxpython/menustrings.py:1415
 msgid "Classify image"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:741
+#: ../gui/wxpython/menustrings.py:751 ../gui/wxpython/menustrings.py:1416
 msgid "Clustering input for unsupervised classification"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:742
+#: ../gui/wxpython/menustrings.py:752 ../gui/wxpython/menustrings.py:1417
 msgid ""
 "Generates spectral signatures for land cover types in an image using a "
-"clustering algorithm."
+"clustering algorithm. The resulting signature file is used as input for i."
+"maxlik, to generate an unsupervised image classification."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:743
+#: ../gui/wxpython/menustrings.py:753 ../gui/wxpython/menustrings.py:1418
 msgid "Input for supervised MLC"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:744
+#: ../gui/wxpython/menustrings.py:754 ../gui/wxpython/menustrings.py:1419
 msgid "Generates statistics for i.maxlik from raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:745
+#: ../gui/wxpython/menustrings.py:755 ../gui/wxpython/menustrings.py:1420
 msgid "Maximum likelihood classification (MLC)"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:746
-msgid "Classifies the cell spectral reflectances in imagery data."
+#: ../gui/wxpython/menustrings.py:756 ../gui/wxpython/menustrings.py:1421
+msgid ""
+"Classifies the cell spectral reflectances in imagery data. Classification is "
+"based on the spectral signature information generated by either i.cluster, i."
+"class, or i.gensig."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:747
+#: ../gui/wxpython/menustrings.py:757 ../gui/wxpython/menustrings.py:1422
 msgid "Interactive input for supervised classification"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:748
-msgid "Generates spectral signatures by allowing the user to outline training areas."
+#: ../gui/wxpython/menustrings.py:758 ../gui/wxpython/menustrings.py:1423
+msgid ""
+"Generates spectral signatures by allowing the user to outline training areas."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:749
+#: ../gui/wxpython/menustrings.py:759 ../gui/wxpython/menustrings.py:1424
 msgid "Input for supervised SMAP"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:750
+#: ../gui/wxpython/menustrings.py:760 ../gui/wxpython/menustrings.py:1425
 msgid "Generates statistics for i.smap from raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:751
+#: ../gui/wxpython/menustrings.py:761 ../gui/wxpython/menustrings.py:1426
 msgid "Sequential maximum a posteriori classification (SMAP)"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:752
+#: ../gui/wxpython/menustrings.py:762 ../gui/wxpython/menustrings.py:1427
 msgid ""
 "Performs contextual image classification using sequential maximum a "
 "posteriori (SMAP) estimation."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:753
+#: ../gui/wxpython/menustrings.py:763 ../gui/wxpython/menustrings.py:1428
+#, fuzzy
+msgid "Object segmentation"
+msgstr "Orientācija"
+#: ../gui/wxpython/menustrings.py:764 ../gui/wxpython/menustrings.py:1429
+msgid "Identifies segments (objects) from imagery data."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:765 ../gui/wxpython/menustrings.py:1430
 msgid "Filter image"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:754
+#: ../gui/wxpython/menustrings.py:766 ../gui/wxpython/menustrings.py:1431
 msgid "Edge detection"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:755
+#: ../gui/wxpython/menustrings.py:767 ../gui/wxpython/menustrings.py:1432
 msgid "Zero-crossing \"edge detection\" raster function for image processing."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:756
+#: ../gui/wxpython/menustrings.py:768 ../gui/wxpython/menustrings.py:1433
 msgid "Matrix/convolving filter"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:757
+#: ../gui/wxpython/menustrings.py:769 ../gui/wxpython/menustrings.py:1434
 msgid "Performs raster map matrix filter."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:758
+#: ../gui/wxpython/menustrings.py:770 ../gui/wxpython/menustrings.py:1435
 msgid "Transform image"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:759
+#: ../gui/wxpython/menustrings.py:771 ../gui/wxpython/menustrings.py:1436
 msgid "Canonical correlation"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:760
-msgid "Canonical components analysis (cca) program for image processing."
+#: ../gui/wxpython/menustrings.py:772 ../gui/wxpython/menustrings.py:1437
+msgid "Canonical components analysis (CCA) program for image processing."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:761
+#: ../gui/wxpython/menustrings.py:773 ../gui/wxpython/menustrings.py:1438
 msgid "Principal components"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:762
+#: ../gui/wxpython/menustrings.py:774 ../gui/wxpython/menustrings.py:1439
 msgid "Principal components analysis (PCA) for image processing."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:763
+#: ../gui/wxpython/menustrings.py:775 ../gui/wxpython/menustrings.py:1440
 msgid "Fast Fourier"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:764
+#: ../gui/wxpython/menustrings.py:776 ../gui/wxpython/menustrings.py:1441
 msgid "Fast Fourier Transform (FFT) for image processing."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:765
+#: ../gui/wxpython/menustrings.py:777 ../gui/wxpython/menustrings.py:1442
 msgid "Inverse Fast Fourier"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:766
+#: ../gui/wxpython/menustrings.py:778 ../gui/wxpython/menustrings.py:1443
 msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:767
+#: ../gui/wxpython/menustrings.py:779 ../gui/wxpython/menustrings.py:1444
 msgid "Satellite images tools"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:768
+#: ../gui/wxpython/menustrings.py:780 ../gui/wxpython/menustrings.py:1445
 msgid "Aster DN to radiance/reflectance"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:769
+#: ../gui/wxpython/menustrings.py:781 ../gui/wxpython/menustrings.py:1446
 msgid ""
 "Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature "
 "from ASTER DN."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:770
+#: ../gui/wxpython/menustrings.py:782 ../gui/wxpython/menustrings.py:1447
 msgid "Landsat DN to radiance/reflectance"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:771
+#: ../gui/wxpython/menustrings.py:783 ../gui/wxpython/menustrings.py:1448
 msgid ""
 "Calculates top-of-atmosphere radiance or reflectance and temperature for "
-"Landsat MSS/TM/ETM+."
+"Landsat MSS/TM/ETM+/OLI"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:772
+#: ../gui/wxpython/menustrings.py:784 ../gui/wxpython/menustrings.py:1449
 msgid "Landsat cloud cover assessment"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:773
+#: ../gui/wxpython/menustrings.py:785 ../gui/wxpython/menustrings.py:1450
 msgid "Performs Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:774
+#: ../gui/wxpython/menustrings.py:786 ../gui/wxpython/menustrings.py:1451
 msgid "Modis quality control"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:775
+#: ../gui/wxpython/menustrings.py:787 ../gui/wxpython/menustrings.py:1452
 msgid "Extracts quality control parameters from Modis QC layers."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:776
+#: ../gui/wxpython/menustrings.py:788 ../gui/wxpython/menustrings.py:1453
 msgid "Atmospheric correction"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:777
-msgid "Performs atmospheric correction using the 6S algorithm."
+#: ../gui/wxpython/menustrings.py:789 ../gui/wxpython/menustrings.py:1454
+msgid ""
+"Performs atmospheric correction using the 6S algorithm. 6S - Second "
+"Simulation of Satellite Signal in the Solar Spectrum."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:778
-msgid "LatLong map"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:779
-msgid "Creates a latitude/longitude map."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:780
-msgid "Sunshine hours"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:781
-msgid "Creates a sunshine hours map."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:782
+#: ../gui/wxpython/menustrings.py:790 ../gui/wxpython/menustrings.py:1455
 msgid "Satellite images products"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:783
+#: ../gui/wxpython/menustrings.py:791 ../gui/wxpython/menustrings.py:1456
 msgid "Vegetation indices"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:784
-msgid "Calculates different types of vegetation indices."
+#: ../gui/wxpython/menustrings.py:792 ../gui/wxpython/menustrings.py:1457
+msgid ""
+"Calculates different types of vegetation indices. Uses red and nir bands "
+"mostly, and some indices require additional bands."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:785
+#: ../gui/wxpython/menustrings.py:793 ../gui/wxpython/menustrings.py:1458
 msgid "Tasseled cap vegetation index"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:786
-msgid "Performs Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data."
+#: ../gui/wxpython/menustrings.py:794 ../gui/wxpython/menustrings.py:1459
+msgid ""
+"Performs Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:787
+#: ../gui/wxpython/menustrings.py:795 ../gui/wxpython/menustrings.py:1460
 msgid "Albedo"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:788
+#: ../gui/wxpython/menustrings.py:796 ../gui/wxpython/menustrings.py:1461
 msgid "Computes broad band albedo from surface reflectance."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:789
+#: ../gui/wxpython/menustrings.py:797 ../gui/wxpython/menustrings.py:1462
 msgid "Emissivity"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:790
-msgid "Computes emissivity from NDVI, generic method for spares land."
+#: ../gui/wxpython/menustrings.py:798 ../gui/wxpython/menustrings.py:1463
+msgid "Computes emissivity from NDVI, generic method for sparse land."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:791
+#: ../gui/wxpython/menustrings.py:799 ../gui/wxpython/menustrings.py:1464
 msgid "Biomass growth"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:792
+#: ../gui/wxpython/menustrings.py:800 ../gui/wxpython/menustrings.py:1465
 msgid "Computes biomass growth, precursor of crop yield calculation."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:793
+#: ../gui/wxpython/menustrings.py:801 ../gui/wxpython/menustrings.py:1466
 msgid "Evapotranspiration calculation"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:794
+#: ../gui/wxpython/menustrings.py:802 ../gui/wxpython/menustrings.py:1467
 msgid "Instantaneaous Net Radiation"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:795
+#: ../gui/wxpython/menustrings.py:803 ../gui/wxpython/menustrings.py:1468
 msgid "Net radiation approximation (Bastiaanssen, 1995)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:796
+#: ../gui/wxpython/menustrings.py:804 ../gui/wxpython/menustrings.py:1469
 msgid "Soil heat flux"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:797
+#: ../gui/wxpython/menustrings.py:805 ../gui/wxpython/menustrings.py:1470
 msgid "Soil heat flux approximation (Bastiaanssen, 1995)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:798
+#: ../gui/wxpython/menustrings.py:806 ../gui/wxpython/menustrings.py:1471
 msgid "Sensible heat flux"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:799
+#: ../gui/wxpython/menustrings.py:807 ../gui/wxpython/menustrings.py:1472
 msgid "Computes sensible heat flux iteration SEBAL 01."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:800
+#: ../gui/wxpython/menustrings.py:808 ../gui/wxpython/menustrings.py:1473
 msgid "Evaporative fraction"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:801
+#: ../gui/wxpython/menustrings.py:809 ../gui/wxpython/menustrings.py:1474
 msgid ""
 "Computes evaporative fraction (Bastiaanssen, 1995) and root zone soil "
 "moisture (Makin, Molden and Bastiaanssen, 2001)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:802
+#: ../gui/wxpython/menustrings.py:810 ../gui/wxpython/menustrings.py:1475
 msgid "Actual Evapotranspiration"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:803
+#: ../gui/wxpython/menustrings.py:811 ../gui/wxpython/menustrings.py:1476
 msgid "Actual evapotranspiration for diurnal period (Bastiaanssen, 1995)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:804
+#: ../gui/wxpython/menustrings.py:812 ../gui/wxpython/menustrings.py:1477
 msgid "Temporal integration of ETa"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:805
+#: ../gui/wxpython/menustrings.py:813 ../gui/wxpython/menustrings.py:1478
 msgid ""
 "Computes temporal integration of satellite ET actual (ETa) following the "
 "daily ET reference (ETo) from meteorological station(s)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:806
+#: ../gui/wxpython/menustrings.py:814 ../gui/wxpython/menustrings.py:1479
 msgid "Hargreaves methods Evapotranspiration"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:807
+#: ../gui/wxpython/menustrings.py:815 ../gui/wxpython/menustrings.py:1480
 msgid ""
 "Computes evapotranspiration calculation modified or original Hargreaves "
 "formulation, 2001."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:808
+#: ../gui/wxpython/menustrings.py:816 ../gui/wxpython/menustrings.py:1481
 msgid "Penman-Monteith Evapotranspiration"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:809
+#: ../gui/wxpython/menustrings.py:817 ../gui/wxpython/menustrings.py:1482
 msgid ""
 "Computes potential evapotranspiration calculation with hourly Penman-"
 "Monteith."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:810
+#: ../gui/wxpython/menustrings.py:818 ../gui/wxpython/menustrings.py:1483
 msgid "Priestley-Taylor Evapotranspiration"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:811
+#: ../gui/wxpython/menustrings.py:819 ../gui/wxpython/menustrings.py:1484
 msgid ""
 "Computes evapotranspiration calculation Prestley and Taylor formulation, "
 "1972."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:813
+#: ../gui/wxpython/menustrings.py:821 ../gui/wxpython/menustrings.py:1486
 msgid "Bit pattern comparison "
 msgstr ""
-#: ../gui/wxpython/menustrings.py:814
+#: ../gui/wxpython/menustrings.py:822 ../gui/wxpython/menustrings.py:1487
 msgid "Compares bit patterns with a raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:815
+#: ../gui/wxpython/menustrings.py:823 ../gui/wxpython/menustrings.py:1488
 msgid "Kappa analysis"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:816
+#: ../gui/wxpython/menustrings.py:824 ../gui/wxpython/menustrings.py:1489
 msgid ""
-"Calculate error matrix and kappa parameter for accuracy assessment of "
+"Calculates error matrix and kappa parameter for accuracy assessment of "
 "classification result."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:817
+#: ../gui/wxpython/menustrings.py:825 ../gui/wxpython/menustrings.py:1490
 msgid "OIF for LandSat TM"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:818
+#: ../gui/wxpython/menustrings.py:826 ../gui/wxpython/menustrings.py:1491
 msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:819
+#: ../gui/wxpython/menustrings.py:827 ../gui/wxpython/menustrings.py:1492
 msgid "V&olumes"
 msgstr "&Tilpumi"
-#: ../gui/wxpython/menustrings.py:820
+#: ../gui/wxpython/menustrings.py:828 ../gui/wxpython/menustrings.py:1493
 msgid "Develop volumes"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:821
+#: ../gui/wxpython/menustrings.py:829 ../gui/wxpython/menustrings.py:1494
 msgid "Manage 3D NULL values"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:822
+#: ../gui/wxpython/menustrings.py:830 ../gui/wxpython/menustrings.py:1495
 msgid "Explicitly create the 3D NULL-value bitmap file."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:823
+#: ../gui/wxpython/menustrings.py:831 ../gui/wxpython/menustrings.py:1496
 msgid "Manage timestamp"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:824
+#: ../gui/wxpython/menustrings.py:832 ../gui/wxpython/menustrings.py:1497
 msgid "Print/add/remove a timestamp for a 3D raster map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:828
+#: ../gui/wxpython/menustrings.py:836 ../gui/wxpython/menustrings.py:1501
 msgid "3D color tables"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:829
+#: ../gui/wxpython/menustrings.py:837 ../gui/wxpython/menustrings.py:1502
 msgid "Creates/modifies the color table associated with a 3D raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:830
+#: ../gui/wxpython/menustrings.py:838 ../gui/wxpython/menustrings.py:1503
 msgid "Export 3D color table"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:831
+#: ../gui/wxpython/menustrings.py:839 ../gui/wxpython/menustrings.py:1504
 msgid "Exports the color table associated with a 3D raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:832
+#: ../gui/wxpython/menustrings.py:840 ../gui/wxpython/menustrings.py:1505
 msgid "3D Mask"
 msgstr "3D maska"
-#: ../gui/wxpython/menustrings.py:833
+#: ../gui/wxpython/menustrings.py:841 ../gui/wxpython/menustrings.py:1506
 msgid "Establishes the current working 3D raster mask."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:834
+#: ../gui/wxpython/menustrings.py:842 ../gui/wxpython/menustrings.py:1507
 msgid "Volume calculator"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:835
+#: ../gui/wxpython/menustrings.py:843 ../gui/wxpython/menustrings.py:1508
 msgid "3D raster map calculator."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:836
+#: ../gui/wxpython/menustrings.py:844 ../gui/wxpython/menustrings.py:1509
 msgid "Cross section"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:837
+#: ../gui/wxpython/menustrings.py:845 ../gui/wxpython/menustrings.py:1510
 msgid ""
 "Creates cross section 2D raster map from 3D raster map based on 2D elevation "
 "map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:839
+#: ../gui/wxpython/menustrings.py:847 ../gui/wxpython/menustrings.py:1512
 msgid ""
 "Numerical calculation program for transient, confined groundwater flow in "
-"three dimensions"
+"three dimensions."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:840
+#: ../gui/wxpython/menustrings.py:848 ../gui/wxpython/menustrings.py:1513
 msgid "Interpolate volume from points"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:841
+#: ../gui/wxpython/menustrings.py:849 ../gui/wxpython/menustrings.py:1514
 msgid ""
 "Interpolates point data to a 3D raster map using regularized spline with "
 "tension (RST) algorithm."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:842
+#: ../gui/wxpython/menustrings.py:850 ../gui/wxpython/menustrings.py:1515
 #, fuzzy
-msgid "Report and Statistics"
+msgid "Reports and Statistics"
 msgstr "Vispārēja statistika"
-#: ../gui/wxpython/menustrings.py:843
+#: ../gui/wxpython/menustrings.py:851 ../gui/wxpython/menustrings.py:1516
 msgid "Basic volume metadata"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:844
+#: ../gui/wxpython/menustrings.py:852 ../gui/wxpython/menustrings.py:1517
 msgid "Outputs basic information about a user-specified 3D raster map layer."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:845
+#: ../gui/wxpython/menustrings.py:853 ../gui/wxpython/menustrings.py:1518
 msgid "Voxel statistics"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:846
+#: ../gui/wxpython/menustrings.py:854 ../gui/wxpython/menustrings.py:1519
 msgid "Generates volume statistics for 3D raster maps."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:847
+#: ../gui/wxpython/menustrings.py:855 ../gui/wxpython/menustrings.py:1520
 msgid "Univariate statistics for volumes"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:848
+#: ../gui/wxpython/menustrings.py:856 ../gui/wxpython/menustrings.py:1521
 msgid ""
 "Calculates univariate statistics from the non-null 3d cells of a raster3d "
 "map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:849
+#: ../gui/wxpython/menustrings.py:857 ../gui/wxpython/menustrings.py:1522
 msgid "&Database"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:850
+#: ../gui/wxpython/menustrings.py:858 ../gui/wxpython/menustrings.py:1523
 msgid "Database information"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:851
+#: ../gui/wxpython/menustrings.py:859 ../gui/wxpython/menustrings.py:1524
 msgid "List databases"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:852
-msgid "List all databases for a given driver and location."
+#: ../gui/wxpython/menustrings.py:860 ../gui/wxpython/menustrings.py:1525
+msgid "Lists all databases for a given driver and location."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:853
+#: ../gui/wxpython/menustrings.py:861 ../gui/wxpython/menustrings.py:1526
 msgid "List drivers"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:854
+#: ../gui/wxpython/menustrings.py:862 ../gui/wxpython/menustrings.py:1527
 msgid "Lists all database drivers."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:855
+#: ../gui/wxpython/menustrings.py:863 ../gui/wxpython/menustrings.py:1528
 msgid "List tables"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:856
+#: ../gui/wxpython/menustrings.py:864 ../gui/wxpython/menustrings.py:1529
 msgid "Lists all tables for a given database."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:857
+#: ../gui/wxpython/menustrings.py:865 ../gui/wxpython/menustrings.py:1530
 msgid "Describe table"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:858
+#: ../gui/wxpython/menustrings.py:866 ../gui/wxpython/menustrings.py:1531
 msgid "Describes a table in detail."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:859
+#: ../gui/wxpython/menustrings.py:867 ../gui/wxpython/menustrings.py:1532
 msgid "List columns"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:860
+#: ../gui/wxpython/menustrings.py:868 ../gui/wxpython/menustrings.py:1533
 msgid "List all columns for a given table."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:861
+#: ../gui/wxpython/menustrings.py:869 ../gui/wxpython/menustrings.py:1534
 msgid "Manage databases"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:862
+#: ../gui/wxpython/menustrings.py:870 ../gui/wxpython/menustrings.py:1535
 msgid "Connect"
 msgstr "Pieslēgties"
-#: ../gui/wxpython/menustrings.py:863
+#: ../gui/wxpython/menustrings.py:871 ../gui/wxpython/menustrings.py:1536
 msgid "Prints/sets general DB connection for current mapset."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:864
+#: ../gui/wxpython/menustrings.py:872 ../gui/wxpython/menustrings.py:1537
 msgid "Login"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:865
+#: ../gui/wxpython/menustrings.py:873 ../gui/wxpython/menustrings.py:1538
 msgid "Sets user/password for DB driver/database."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:866
+#: ../gui/wxpython/menustrings.py:874 ../gui/wxpython/menustrings.py:1539
 msgid "Create database"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:867
+#: ../gui/wxpython/menustrings.py:875 ../gui/wxpython/menustrings.py:1540
 msgid "Creates an empty database."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:868
+#: ../gui/wxpython/menustrings.py:876 ../gui/wxpython/menustrings.py:1541
 msgid "Drop database"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:869
-msgid "Removes a database."
+#: ../gui/wxpython/menustrings.py:877 ../gui/wxpython/menustrings.py:1542
+msgid "Removes an existing database."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:870
+#: ../gui/wxpython/menustrings.py:878 ../gui/wxpython/menustrings.py:1543
 msgid "Drop table"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:871
+#: ../gui/wxpython/menustrings.py:879 ../gui/wxpython/menustrings.py:1544
 msgid "Drops an attribute table."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:872
+#: ../gui/wxpython/menustrings.py:880 ../gui/wxpython/menustrings.py:1545
 msgid "Copy table"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:873
-#, fuzzy
-msgid "Copy a table."
-msgstr "Rindas:"
+#: ../gui/wxpython/menustrings.py:881 ../gui/wxpython/menustrings.py:1546
+msgid ""
+"Copy a table. Either 'from_table' (optionally with 'where') can be used or "
+"'select' option, but not 'from_table' and 'select' at the same time."
+msgstr ""
-#: ../gui/wxpython/menustrings.py:874 ../gui/wxpython/menustrings.py:894
+#: ../gui/wxpython/menustrings.py:882 ../gui/wxpython/menustrings.py:902
+#: ../gui/wxpython/menustrings.py:1547 ../gui/wxpython/menustrings.py:1567
 msgid "Drop column"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:875
+#: ../gui/wxpython/menustrings.py:883 ../gui/wxpython/menustrings.py:1548
 msgid "Drops a column from selected attribute table."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:876
+#: ../gui/wxpython/menustrings.py:884 ../gui/wxpython/menustrings.py:1549
 msgid "Test"
 msgstr "Testēt"
-#: ../gui/wxpython/menustrings.py:877
+#: ../gui/wxpython/menustrings.py:885 ../gui/wxpython/menustrings.py:1550
 msgid "Test database driver, database must exist and set by db.connect."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:878
-#: ../gui/wxpython/gui_modules/sqlbuilder.py:99
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:99
+#: ../gui/wxpython/menustrings.py:886 ../gui/wxpython/menustrings.py:1551
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:100
 msgid "Query"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:879
+#: ../gui/wxpython/menustrings.py:887 ../gui/wxpython/menustrings.py:1552
 msgid "Query any table"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:880
-msgid "Selects data from attribute table (performs SQL query statement(s))."
+#: ../gui/wxpython/menustrings.py:888 ../gui/wxpython/menustrings.py:1553
+msgid "Selects data from attribute table. Performs SQL query statement(s)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:883
+#: ../gui/wxpython/menustrings.py:891 ../gui/wxpython/menustrings.py:1556
 msgid "SQL statement"
 msgstr "SQL izteikums"
-#: ../gui/wxpython/menustrings.py:884
-#, fuzzy
-msgid "Executes any SQL statement."
-msgstr "SQL izteikums"
+#: ../gui/wxpython/menustrings.py:892 ../gui/wxpython/menustrings.py:1557
+msgid "Executes any SQL statement. For SELECT statements use 'db.select'."
+msgstr ""
-#: ../gui/wxpython/menustrings.py:885
+#: ../gui/wxpython/menustrings.py:893 ../gui/wxpython/menustrings.py:1558
 msgid "Vector database connections"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:886
+#: ../gui/wxpython/menustrings.py:894 ../gui/wxpython/menustrings.py:1559
 msgid "New table"
 msgstr "Jauna tabula"
-#: ../gui/wxpython/menustrings.py:887
+#: ../gui/wxpython/menustrings.py:895 ../gui/wxpython/menustrings.py:1560
 msgid ""
 "Creates and connects a new attribute table to a given layer of an existing "
 "vector map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:888
+#: ../gui/wxpython/menustrings.py:896 ../gui/wxpython/menustrings.py:1561
 msgid "Remove table"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:889
+#: ../gui/wxpython/menustrings.py:897 ../gui/wxpython/menustrings.py:1562
 msgid "Removes existing attribute table of a vector map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:890
+#: ../gui/wxpython/menustrings.py:898 ../gui/wxpython/menustrings.py:1563
 msgid "Join table"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:891
-msgid "Allows to join a table to a vector map table."
+#: ../gui/wxpython/menustrings.py:899 ../gui/wxpython/menustrings.py:1564
+msgid "Joins a database table to a vector map table."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:892
+#: ../gui/wxpython/menustrings.py:900 ../gui/wxpython/menustrings.py:1565
 msgid "Add columns"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:893
+#: ../gui/wxpython/menustrings.py:901 ../gui/wxpython/menustrings.py:1566
 msgid ""
 "Adds one or more columns to the attribute table connected to a given vector "
 "map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:895
-msgid "Drops a column from the attribute table connected to a given vector map."
+#: ../gui/wxpython/menustrings.py:903 ../gui/wxpython/menustrings.py:1568
+msgid ""
+"Drops a column from the attribute table connected to a given vector map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:896 ../gui/wxpython/gui_modules/dbm.py:925
-#: ../gui/wxpython/dbmgr/manager.py:924
+#: ../gui/wxpython/menustrings.py:904 ../gui/wxpython/menustrings.py:1569
+#: ../gui/wxpython/dbmgr/base.py:2073
 msgid "Rename column"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:897
-msgid "Renames a column in the attribute table connected to a given vector map."
+#: ../gui/wxpython/menustrings.py:905 ../gui/wxpython/menustrings.py:1570
+msgid ""
+"Renames a column in the attribute table connected to a given vector map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:898
+#: ../gui/wxpython/menustrings.py:906 ../gui/wxpython/menustrings.py:1571
 msgid "Change values"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:899
-msgid "Allows to update a column in the attribute table connected to a vector map."
+#: ../gui/wxpython/menustrings.py:907 ../gui/wxpython/menustrings.py:1572
+msgid "Updates a column in the attribute table connected to a vector map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:900
+#: ../gui/wxpython/menustrings.py:908 ../gui/wxpython/menustrings.py:1573
 msgid "Drop row"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:901
+#: ../gui/wxpython/menustrings.py:909 ../gui/wxpython/menustrings.py:1574
 msgid "Removes a vector feature from a vector map through attribute selection."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:902
+#: ../gui/wxpython/menustrings.py:910 ../gui/wxpython/menustrings.py:1575
 msgid "Reconnect vectors to database"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:903
-msgid "Reconnects vectors to a new database."
+#: ../gui/wxpython/menustrings.py:911 ../gui/wxpython/menustrings.py:1576
+msgid ""
+"Reconnects attribute tables for all vector maps from the current mapset to a "
+"new database."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:904
+#: ../gui/wxpython/menustrings.py:912 ../gui/wxpython/menustrings.py:1577
 msgid "Set vector map - database connection"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:905
+#: ../gui/wxpython/menustrings.py:913 ../gui/wxpython/menustrings.py:1578
 msgid "Prints/sets DB connection for a vector map to attribute table."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:906 ../gui/wxpython/menustrings.py:958
+#: ../gui/wxpython/menustrings.py:914 ../gui/wxpython/menustrings.py:1711
+#: ../gui/wxpython/menustrings.py:1754
 msgid "&Help"
 msgstr "&Palīdzība"
-#: ../gui/wxpython/menustrings.py:907
+#: ../gui/wxpython/menustrings.py:915
 msgid "GRASS help"
 msgstr "GRASS palīdzība"
-#: ../gui/wxpython/menustrings.py:908 ../gui/wxpython/menustrings.py:910
+#: ../gui/wxpython/menustrings.py:916 ../gui/wxpython/menustrings.py:918
 msgid "Display the HTML man pages of GRASS GIS"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:909
+#: ../gui/wxpython/menustrings.py:917
 msgid "GUI help"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:911
+#: ../gui/wxpython/menustrings.py:919
 msgid "About system"
 msgstr "Par sistēmu"
-#: ../gui/wxpython/menustrings.py:912
+#: ../gui/wxpython/menustrings.py:920
 msgid "Prints system information"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:913 ../gui/wxpython/menustrings.py:914
-#: ../gui/wxpython/gui_modules/ghelp.py:484
-#: ../gui/wxpython/gui_core/ghelp.py:386
+#: ../gui/wxpython/menustrings.py:921 ../gui/wxpython/menustrings.py:922
+#: ../gui/wxpython/gui_core/ghelp.py:46
 msgid "About GRASS GIS"
 msgstr "Par GRASS GIS"
-#: ../gui/wxpython/menustrings.py:919
+#: ../gui/wxpython/menustrings.py:1579
+msgid "Temporal"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1580
+#, fuzzy
+msgid "Manage datasets"
+msgstr "Pārvaldīt tabulas"
+#: ../gui/wxpython/menustrings.py:1581 ../gui/wxpython/rlisetup/frame.py:48
+#, fuzzy
+msgid "Create"
+msgstr "Izveidot tabulu?"
+#: ../gui/wxpython/menustrings.py:1582
+#, fuzzy
+msgid "Creates a space time dataset."
+msgstr "Izveidot jaunu karšu kopu"
+#: ../gui/wxpython/menustrings.py:1584
+#, fuzzy
+msgid "Renames a space time dataset"
+msgstr "Pārsaukt izvēlēto karšu kopu"
+#: ../gui/wxpython/menustrings.py:1586
+msgid "Removes space time datasets from temporal database."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1587
+#, fuzzy
+msgid "Update metadata"
+msgstr "Rastra metadati"
+#: ../gui/wxpython/menustrings.py:1588
+msgid "Modifies the metadata of a space time dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1589
+msgid "Merge"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1590
+msgid "Merge several space time datasets into a single one"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1591
+msgid "Temporally shift"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1592
+msgid "Temporally shift the maps of a space time dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1593
+msgid "Snap maps of dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1594
+msgid "Temporally snap the maps of a space time dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1596
+msgid "List space time datasets and maps registered in the temporal database."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1597
+#, fuzzy
+msgid "Manage maps in datasets"
+msgstr "Pārvaldīt kartes un tilpumus"
+#: ../gui/wxpython/menustrings.py:1598
+#, fuzzy
+msgid "Register maps in datasets"
+msgstr "Rezervēts karšu kopas nosaukums"
+#: ../gui/wxpython/menustrings.py:1599
+msgid "Registers raster, vector and raster3d maps in a space time datasets."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1600
+msgid "Unregister maps from datasets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1601
+msgid ""
+"Unregisters raster, vector and raster3d maps from the temporal database or a "
+"specific space time dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1602
+#, fuzzy
+msgid "List raster dataset maps"
+msgstr "3D rastra kartes"
+#: ../gui/wxpython/menustrings.py:1603
+msgid "Lists registered maps of a space time raster dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1604
+#, fuzzy
+msgid "List vector dataset maps"
+msgstr "Jauna vektoru karte"
+#: ../gui/wxpython/menustrings.py:1605
+msgid "Lists registered maps of a space time vector dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1606
+#, fuzzy
+msgid "List raster3D dataset maps"
+#: ../gui/wxpython/menustrings.py:1607
+msgid "Lists registered maps of a space time raster3d dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1608
+#, fuzzy
+msgid "Import"
+msgstr "&Importēt"
+#: ../gui/wxpython/menustrings.py:1609
+#, fuzzy
+msgid "Import raster dataset"
+msgstr "Rastra datu importēšana"
+#: ../gui/wxpython/menustrings.py:1610
+#, fuzzy
+msgid "Imports space time raster dataset."
+#: ../gui/wxpython/menustrings.py:1611
+#, fuzzy
+msgid "Import vector dataset"
+msgstr "Vektordatu importēšana"
+#: ../gui/wxpython/menustrings.py:1612
+msgid "Import a space time vector dataset archive file"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1613 ../gui/wxpython/lmgr/layertree.py:555
+#: ../gui/wxpython/animation/dialogs.py:767
+msgid "Export"
+msgstr "Eksportēt"
+#: ../gui/wxpython/menustrings.py:1614
+#, fuzzy
+msgid "Export raster dataset"
+#: ../gui/wxpython/menustrings.py:1615
+#, fuzzy
+msgid "Exports space time raster dataset."
+msgstr "Importēt 3D rastra datus"
+#: ../gui/wxpython/menustrings.py:1616
+msgid "Export raster dataset as VTK time series"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1617
+msgid "Exports space time raster dataset as VTK time series."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1618
+#, fuzzy
+msgid "Export vector dataset"
+#: ../gui/wxpython/menustrings.py:1619
+msgid "Export a space time vector dataset.as GRASS specific archive file"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1620
+#, fuzzy
+msgid "Convert raster dataset to volume"
+#: ../gui/wxpython/menustrings.py:1621
+msgid "Converts a space time raster dataset into a raster3d map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1622
+#, fuzzy
+msgid "Extraction"
+msgstr "Virziens"
+#: ../gui/wxpython/menustrings.py:1623
+msgid "Extract subset of raster dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1624
+msgid "Extracts a subset of a space time raster datasets."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1625
+msgid "Extract subset of vector dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1626
+msgid "Extracts a subset of a space time vector dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1627
+msgid "Extract subset of raster3D dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1628
+msgid "Extracts a subset of a space time raster3d dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1629
+#, fuzzy
+msgid "Query vector dataset attribute data"
+msgstr "Izveidot atribūtu tabulu"
+#: ../gui/wxpython/menustrings.py:1630
+msgid ""
+"Prints attributes of vector maps registered in a space time vector dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1631
+msgid "Raster dataset color table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1632
+msgid ""
+"Creates/modifies the color table associated with each raster map of the "
+"space time raster dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1633
+#, fuzzy
+msgid "Raster calculations"
+msgstr "Rastra iestatījumi"
+#: ../gui/wxpython/menustrings.py:1634
+msgid ""
+"Perform spatio-temporal mapcalc expressions on temporal sampled maps of "
+"space time raster datasets."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1635
+#, fuzzy
+msgid "Raster3D calculations"
+#: ../gui/wxpython/menustrings.py:1636
+msgid ""
+"Performs r3.mapcalc expressions on maps of sampled space time raster3d "
+"datasets."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1637
+#, fuzzy
+msgid "Interpolate gaps in raster datasets"
+#: ../gui/wxpython/menustrings.py:1638
+msgid ""
+"Replace gaps in a space time raster dataset with interpolated raster maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1639
+#, fuzzy
+msgid "Aggregation"
+#: ../gui/wxpython/menustrings.py:1640
+msgid "Neighborhood analysis in raster dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1641
+msgid ""
+"Performs a neighborhood analysis for each map in a space time raster dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1642
+msgid "Aggregation in raster datasets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1643
+msgid ""
+"Performs different aggregation algorithms from r.series on all or a subset "
+"of raster maps in a space time raster dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1644
+msgid "Temporal aggregation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1645
+msgid ""
+"Temporally aggregates the maps of a space time raster dataset by a user "
+"defined granularity."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1646
+msgid "Temporal aggregation by dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1647
+msgid ""
+"Aggregated data of an existing space time raster dataset using the time "
+"intervals of a second space time dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1648
+msgid "Sampling"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1649
+msgid "Temporal sampling"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1650
+msgid ""
+"Samples the input space time dataset(s) with a sample space time dataset and "
+"print the result to stdout."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1651
+msgid "Query raster dataset by vector points dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1652
+msgid ""
+"Store raster map values at spatial and temporal positions of vector points "
+"as vector attributes."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1653
+msgid "Observe specific locations in raster dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1654
+msgid ""
+"Observes specific locations in a space time raster dataset over a period of "
+"time using vector points."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1656
+#, fuzzy
+msgid "Space time datasets metadata"
+#: ../gui/wxpython/menustrings.py:1657
+msgid "Lists information about space time datasets and maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1658
+msgid "Univariate raster dataset statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1659
+msgid ""
+"Calculates univariate statistics from the non-null cells for each registered "
+"raster map of a space time raster dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1660
+msgid "Univariate vector dataset statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1661
+msgid ""
+"Calculates univariate statistics of attributes for each registered vector "
+"map of a space time vector dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1662
+msgid "Univariate raster3D dataset statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1663
+msgid ""
+"raster3d map of a space time raster3d dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1664
+msgid "Report temporal topology"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1665
+msgid "Lists temporal topology of a space time dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1670
 msgid "Create new model"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:921
+#: ../gui/wxpython/menustrings.py:1672
 msgid "Load model from file"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:925
+#: ../gui/wxpython/menustrings.py:1676
 msgid "Save model to file"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:927
+#: ../gui/wxpython/menustrings.py:1678
 msgid "Close model file"
 msgstr "Aizvērt modeļa failu"
-#: ../gui/wxpython/menustrings.py:928
+#: ../gui/wxpython/menustrings.py:1679
 msgid "Export to image"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:929
+#: ../gui/wxpython/menustrings.py:1680
 msgid "Export model to image"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:930
+#: ../gui/wxpython/menustrings.py:1681
 msgid "Export to Python"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:931
+#: ../gui/wxpython/menustrings.py:1682
 msgid "Export model to Python script"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:932
+#: ../gui/wxpython/menustrings.py:1683
 msgid "Quit modeler"
 msgstr "Iziet no modelētāja"
-#: ../gui/wxpython/menustrings.py:933
+#: ../gui/wxpython/menustrings.py:1684
 msgid "Close modeler window"
 msgstr "Aizver modelēšanas logu"
-#: ../gui/wxpython/menustrings.py:937
+#: ../gui/wxpython/menustrings.py:1688
 msgid "&Model"
 msgstr "&Modelis"
-#: ../gui/wxpython/menustrings.py:938
+#: ../gui/wxpython/menustrings.py:1689
 msgid "Add command"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:939
+#: ../gui/wxpython/menustrings.py:1690
 msgid "Add action (GRASS command) to model"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:940
+#: ../gui/wxpython/menustrings.py:1691
 msgid "Add data"
 msgstr "Pievienot datus"
-#: ../gui/wxpython/menustrings.py:941
+#: ../gui/wxpython/menustrings.py:1692
 msgid "Add data item to model"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:942
+#: ../gui/wxpython/menustrings.py:1693
 msgid "Define relation"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:943
+#: ../gui/wxpython/menustrings.py:1694
 msgid "Define relation between data and action items"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:944
+#: ../gui/wxpython/menustrings.py:1695
 msgid "Add loop / series"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:945
+#: ../gui/wxpython/menustrings.py:1696
 msgid "Adds loop (series) to model"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:946
+#: ../gui/wxpython/menustrings.py:1697
 msgid "Add condition"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:947
+#: ../gui/wxpython/menustrings.py:1698
 msgid "Adds condition (if/else) to model"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:948
+#: ../gui/wxpython/menustrings.py:1700
+msgid "Adds comment to model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1701
 msgid "Remove item"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:949
+#: ../gui/wxpython/menustrings.py:1702
 msgid "Remove action/data from model"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:951
+#: ../gui/wxpython/menustrings.py:1704
 msgid "Model properties (name, purpose, etc.)"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:952
+#: ../gui/wxpython/menustrings.py:1705
 msgid "Delete intermediate data"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:953
+#: ../gui/wxpython/menustrings.py:1706
 msgid "Delete intermediate data defined in the model"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:955
+#: ../gui/wxpython/menustrings.py:1708
 msgid "Run entire model"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:956
+#: ../gui/wxpython/menustrings.py:1709
 msgid "Validate model"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:957
+#: ../gui/wxpython/menustrings.py:1710
 msgid "Validate entire model"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:959
+#: ../gui/wxpython/menustrings.py:1712 ../gui/wxpython/menustrings.py:1755
+#: ../gui/wxpython/timeline/frame.py:131
 msgid "Help"
 msgstr "Palīdzība"
-#: ../gui/wxpython/menustrings.py:960
+#: ../gui/wxpython/menustrings.py:1713
 msgid "Display the HTML man pages of Graphical modeler"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:961
+#: ../gui/wxpython/menustrings.py:1714
 msgid "About Graphical Modeler"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:962
+#: ../gui/wxpython/menustrings.py:1715
 msgid "Display information about Graphical Modeler"
 msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:50
+#: ../gui/wxpython/menustrings.py:1721
+#, fuzzy
+msgid "Load instruction file"
+msgstr "Novietojuma nosaukums"
+#: ../gui/wxpython/menustrings.py:1723
+#, fuzzy
+msgid "Export instruction file"
+msgstr "Eksportēt atribūtu tabulu"
+#: ../gui/wxpython/menustrings.py:1725
+msgid "Export to PostScript"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1727
+#, fuzzy
+msgid "Export to PDF"
+msgstr "Eksportēt vektrodatus"
+#: ../gui/wxpython/menustrings.py:1729 ../gui/wxpython/menustrings.py:1730
+msgid "Launch ps.map dialog"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1731 ../gui/wxpython/lmgr/layertree.py:72
+#: ../gui/wxpython/gui_core/toolbars.py:73
+msgid "Quit"
+msgstr "Iziet"
+#: ../gui/wxpython/menustrings.py:1732
+msgid "Close Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1733
+#, fuzzy
+msgid "&Insert"
+msgstr "&Instalēt"
+#: ../gui/wxpython/menustrings.py:1735
+#, fuzzy
+msgid "Add or edit map frame"
+msgstr "Pievienot rastra karti"
+#: ../gui/wxpython/menustrings.py:1737
+#, fuzzy
+msgid "Add or edit raster map"
+msgstr "Eksportēt rastra karti"
+#: ../gui/wxpython/menustrings.py:1739
+#, fuzzy
+msgid "Add or edit vector map"
+#: ../gui/wxpython/menustrings.py:1740
+#, fuzzy
+msgid "Map legend"
+msgstr "Pievienot leģendu"
+#: ../gui/wxpython/menustrings.py:1741
+#, fuzzy
+msgid "Add or edit raster and vector legend"
+msgstr "Pievienot izveidoto rastra karti projekta slāņu sarakstam"
+#: ../gui/wxpython/menustrings.py:1743
+msgid "Add or edit map info"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1745
+msgid "Add or edit scale bar"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1747
+#: ../gui/wxpython/animation/dialogs.py:813
+#, fuzzy
+msgid "Add text"
+msgstr "Pievienot teksta slāni"
+#: ../gui/wxpython/menustrings.py:1749
+#, fuzzy
+msgid "Add image"
+msgstr "Pievienot slāni"
+#: ../gui/wxpython/menustrings.py:1751
+#, fuzzy
+msgid "Add north arrow"
+msgstr "Ziemeļu bulta"
+#: ../gui/wxpython/menustrings.py:1756
+msgid "Display the HTML man pages of Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1757
+msgid "About Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1758
+msgid "Display information about Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:46
 msgid "Start new map display"
 msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:52
+#: ../gui/wxpython/lmgr/toolbars.py:48
 msgid "Create new workspace (Ctrl+N)"
 msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:54
+#: ../gui/wxpython/lmgr/toolbars.py:50
 msgid "Open existing workspace file (Ctrl+O)"
 msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:56
+#: ../gui/wxpython/lmgr/toolbars.py:52
 msgid "Save current workspace to file (Ctrl+S)"
 msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:85
+#: ../gui/wxpython/lmgr/toolbars.py:81
 msgid "Add multiple raster or vector map layers (Ctrl+Shift+L)"
 msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:86
+#: ../gui/wxpython/lmgr/toolbars.py:82
 msgid "Add raster map layer (Ctrl+Shift+R)"
 msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:88
+#: ../gui/wxpython/lmgr/toolbars.py:84
 msgid "Add various raster map layers (RGB, HIS, shaded relief...)"
 msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:89
+#: ../gui/wxpython/lmgr/toolbars.py:85
 msgid "Add vector map layer (Ctrl+Shift+V)"
 msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:91
+#: ../gui/wxpython/lmgr/toolbars.py:87
 msgid "Add various vector map layers (thematic, chart...)"
 msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:93
-msgid "Add group"
+#: ../gui/wxpython/lmgr/toolbars.py:89
+msgid "Add web service layer (WMS, WMTS, NASA OnEarth)"
 msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:95
-msgid "Add grid or vector labels overlay"
+#: ../gui/wxpython/lmgr/toolbars.py:91
+msgid "Add group"
 msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:97 ../gui/wxpython/iclass/toolbars.py:41
-msgid "Delete selected map layer"
+#: ../gui/wxpython/lmgr/toolbars.py:93
+msgid "Add various overlays"
 msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:134
+#: ../gui/wxpython/lmgr/toolbars.py:95
+#, fuzzy
+msgid "Remove selected map layer(s) from layer tree"
+#: ../gui/wxpython/lmgr/toolbars.py:136
 msgid "Import/link raster or vector data"
 msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:136 ../gui/wxpython/ogc_services/wms.py:37
-#: ../gui/wxpython/gui_modules/ogc_services.py:38
-msgid "Import data from WMS server"
-msgstr ""
 #: ../gui/wxpython/lmgr/toolbars.py:138
 msgid "Raster Map Calculator"
 msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:140
+#: ../gui/wxpython/lmgr/toolbars.py:140 ../gui/wxpython/gui_core/forms.py:1188
 msgid "Graphical Modeler"
 msgstr ""
@@ -7123,450 +7185,434 @@
 msgid "Georectifier"
 msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:177
+#: ../gui/wxpython/lmgr/toolbars.py:146
+msgid "Launch user-defined script"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:180
 msgid "GUI settings"
 msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:178
+#: ../gui/wxpython/lmgr/toolbars.py:181
 msgid "GRASS manual"
 msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:203
+#: ../gui/wxpython/lmgr/toolbars.py:206
 #, fuzzy
-msgid "Edit vector maps"
+msgid "Edit selected vector map"
-#: ../gui/wxpython/lmgr/toolbars.py:205
-msgid "Show attribute table"
-msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:208
+#, fuzzy
+msgid "Show attribute data for selected vector map"
+msgstr "Rādīt atribūtu datus"
-#: ../gui/wxpython/lmgr/toolbars.py:234
+#: ../gui/wxpython/lmgr/toolbars.py:237
 msgid "Generate command for m.nviz.image"
 msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:235
+#: ../gui/wxpython/lmgr/toolbars.py:238
 msgid "Generate command for m.nviz.image based on current state"
 msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:237
+#: ../gui/wxpython/lmgr/toolbars.py:240
 msgid "3D view mode settings"
 msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:238
+#: ../gui/wxpython/lmgr/toolbars.py:241
 msgid "Show 3D view mode settings dialog"
 msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:240
+#: ../gui/wxpython/lmgr/toolbars.py:243
 msgid "Show 3D view mode manual"
 msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:35
-#: ../gui/wxpython/gui_modules/gpyshell.py:36
+#: ../gui/wxpython/lmgr/menudata.py:42
+msgid ""
+"Unable to parse user toolboxes XML files. Default main menu will be loaded."
+msgstr ""
+#: ../gui/wxpython/lmgr/menudata.py:64
+msgid ""
+"Unable to parse user toolboxes XML files. Default module tree will be loaded."
+msgstr ""
+#: ../gui/wxpython/lmgr/pyshell.py:36
 #, python-format
 msgid "Welcome to wxGUI Interactive Python Shell %s"
 msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:36
-#: ../gui/wxpython/gui_modules/gpyshell.py:37
+#: ../gui/wxpython/lmgr/pyshell.py:37
 #, python-format
 msgid "Type %s for more GRASS scripting related information."
 msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:37
-#: ../gui/wxpython/gui_modules/gpyshell.py:38
+#: ../gui/wxpython/lmgr/pyshell.py:38
 #, python-format
 msgid "Type %s to add raster or vector to the layer tree."
 msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:46
-#: ../gui/wxpython/gui_modules/gpyshell.py:47
+#: ../gui/wxpython/lmgr/pyshell.py:48
 msgid "Delete all text from the shell"
 msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:96
-#: ../gui/wxpython/gui_modules/gpyshell.py:97
+#: ../gui/wxpython/lmgr/pyshell.py:98
 #, python-format
 msgid "Raster or vector map <%s> not found"
 msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:103
-#: ../gui/wxpython/gui_modules/gpyshell.py:104
+#: ../gui/wxpython/lmgr/pyshell.py:105
 #, python-format
 msgid "Raster map <%s> added"
 msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:105
-#: ../gui/wxpython/gui_modules/gpyshell.py:106
+#: ../gui/wxpython/lmgr/pyshell.py:107
 #, python-format
 msgid "Vector map <%s> added"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:55
+#: ../gui/wxpython/lmgr/layertree.py:60
 msgid "Set raster output format"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:61
+#: ../gui/wxpython/lmgr/layertree.py:66
 msgid "Set vector output format"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:63
+#: ../gui/wxpython/lmgr/layertree.py:68
+msgid "Import data from WMS server"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:70
 msgid "Add command layer"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:65
-#: ../gui/wxpython/gui_core/toolbars.py:66
-msgid "Quit"
-msgstr "Iziet"
+#: ../gui/wxpython/lmgr/layertree.py:74
+#: ../gui/wxpython/gui_core/toolbars.py:75
+msgid "Add raster map layer"
-#: ../gui/wxpython/lmgr/layertree.py:67
+#: ../gui/wxpython/lmgr/layertree.py:76 ../gui/wxpython/iclass/toolbars.py:49
 msgid "Add RGB map layer"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:69
+#: ../gui/wxpython/lmgr/layertree.py:78
 msgid "Add HIS map layer"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:71
+#: ../gui/wxpython/lmgr/layertree.py:80
 msgid "Add shaded relief map layer"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:73
+#: ../gui/wxpython/lmgr/layertree.py:82
 msgid "Add raster flow arrows"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:75
+#: ../gui/wxpython/lmgr/layertree.py:84
 msgid "Add raster cell numbers"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:77
+#: ../gui/wxpython/lmgr/layertree.py:86
+#: ../gui/wxpython/gui_core/toolbars.py:77
+msgid "Add vector map layer"
+msgstr "Pievienot vektoru karti"
+#: ../gui/wxpython/lmgr/layertree.py:88
 msgid "Add thematic area (choropleth) map layer"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:79
+#: ../gui/wxpython/lmgr/layertree.py:90
 msgid "Add thematic chart layer"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:81
+#: ../gui/wxpython/lmgr/layertree.py:92
 msgid "Add grid layer"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:83
+#: ../gui/wxpython/lmgr/layertree.py:94
 msgid "Add geodesic line layer"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:85
+#: ../gui/wxpython/lmgr/layertree.py:96
 msgid "Add rhumbline layer"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:87
-msgid "Add labels"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:89
+#: ../gui/wxpython/lmgr/layertree.py:100
+#: ../gui/wxpython/gui_core/simplelmgr.py:432
+#: ../gui/wxpython/gui_core/simplelmgr.py:433
 msgid "Add 3D raster map layer"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:90
+#: ../gui/wxpython/lmgr/layertree.py:101
 msgid "Note that 3D raster data are rendered only in 3D view mode"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:92
-#: ../gui/wxpython/gui_modules/gdialogs.py:580
-#: ../gui/wxpython/gui_core/dialogs.py:583
+#: ../gui/wxpython/lmgr/layertree.py:103
+#, fuzzy
+msgid "Add WMS layer."
+#: ../gui/wxpython/lmgr/layertree.py:105
+#: ../gui/wxpython/animation/dialogs.py:373
 msgid "Set options"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:155
-#: ../gui/wxpython/gui_modules/layertree.py:121
+#: ../gui/wxpython/lmgr/layertree.py:107
+#, fuzzy
+msgid "Editing mode"
+msgstr "Krīginga modulis"
+#: ../gui/wxpython/lmgr/layertree.py:109
+#, fuzzy
+msgid "Background vector map"
+msgstr "Vektoru kartes slāņi"
+#: ../gui/wxpython/lmgr/layertree.py:179
 #, python-format
 msgid "GRASS GIS Map Display: %(id)d  - Location: %(loc)s"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:165
-#: ../gui/wxpython/gui_modules/layertree.py:131
+#: ../gui/wxpython/lmgr/layertree.py:189
 msgid "Map Layers"
 msgstr "Kartes slāņi"
-#: ../gui/wxpython/lmgr/layertree.py:322
-#: ../gui/wxpython/gui_modules/layertree.py:289
+#: ../gui/wxpython/lmgr/layertree.py:418 ../gui/wxpython/iscatt/frame.py:543
 msgid "Change opacity level"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:332
-#: ../gui/wxpython/gui_modules/layertree.py:299
+#: ../gui/wxpython/lmgr/layertree.py:428
 msgid "3D view properties"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:336
-#: ../gui/wxpython/gui_modules/layertree.py:303
+#: ../gui/wxpython/lmgr/layertree.py:433
 msgid "Zoom to selected map(s)"
 msgstr "Tuvināt līdz izvēlētajām kartēm"
-#: ../gui/wxpython/lmgr/layertree.py:338
-#: ../gui/wxpython/gui_modules/layertree.py:305
+#: ../gui/wxpython/lmgr/layertree.py:438
 msgid "Set computational region from selected map(s)"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:350 ../gui/wxpython/lmgr/layertree.py:436
-#: ../gui/wxpython/gui_modules/layertree.py:317
-#: ../gui/wxpython/gui_modules/layertree.py:402
-msgid "Export"
+#: ../gui/wxpython/lmgr/layertree.py:452
+#, fuzzy
+msgid "Export common formats"
+#: ../gui/wxpython/lmgr/layertree.py:461
+#, fuzzy
+msgid "Export PostGIS"
 msgstr "Eksportēt"
-#: ../gui/wxpython/lmgr/layertree.py:357 ../gui/wxpython/lmgr/layertree.py:442
-#: ../gui/wxpython/gui_modules/layertree.py:324
-#: ../gui/wxpython/gui_modules/layertree.py:408
+#: ../gui/wxpython/lmgr/layertree.py:470 ../gui/wxpython/lmgr/layertree.py:564
+msgid "Make a copy in the current mapset"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:475 ../gui/wxpython/lmgr/layertree.py:569
+#: ../gui/wxpython/lmgr/layertree.py:601
 msgid "Set color table"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:360
-#: ../gui/wxpython/gui_modules/layertree.py:327
+#: ../gui/wxpython/lmgr/layertree.py:478
 msgid "Show attribute data"
-#: ../gui/wxpython/lmgr/layertree.py:363
-#: ../gui/wxpython/gui_modules/layertree.py:330
+#: ../gui/wxpython/lmgr/layertree.py:490
 msgid "Start editing"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:364
-#: ../gui/wxpython/gui_modules/layertree.py:331
+#: ../gui/wxpython/lmgr/layertree.py:493
 msgid "Stop editing"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:375
-#: ../gui/wxpython/gui_modules/layertree.py:342
-msgid "Use as background vector map for digitizer"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:382
-#: ../gui/wxpython/gui_modules/layertree.py:349
+#: ../gui/wxpython/lmgr/layertree.py:509
 msgid "Rebuild topology"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:395
-#: ../gui/wxpython/gui_modules/layertree.py:361
-msgid "SQL Spatial Query"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:430
-#: ../gui/wxpython/gui_modules/layertree.py:396
+#: ../gui/wxpython/lmgr/layertree.py:547
 msgid "Zoom to selected map(s) (ignore NULLs)"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:432
-#: ../gui/wxpython/gui_modules/layertree.py:398
+#: ../gui/wxpython/lmgr/layertree.py:549
 msgid "Set computational region from selected map(s) (ignore NULLs)"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:448
-#: ../gui/wxpython/gui_modules/layertree.py:414
+#: ../gui/wxpython/lmgr/layertree.py:582
+#, fuzzy
+msgid "Report raster statistics"
+msgstr "Atskaites un statistika"
+#: ../gui/wxpython/lmgr/layertree.py:588
 msgid "Profile"
 msgstr "Profils"
-#: ../gui/wxpython/lmgr/layertree.py:546
-#: ../gui/wxpython/gui_modules/layertree.py:512
-msgid "Unable to create profile of raster map."
+#: ../gui/wxpython/lmgr/layertree.py:616
+msgid "Save web service layer"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:581
-msgid "Unable to display histogram of raster map. No map name defined."
+#: ../gui/wxpython/lmgr/layertree.py:720
+msgid "Unable to create profile of raster map."
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:610
-#: ../gui/wxpython/gui_modules/layertree.py:592
-#: ../gui/wxpython/gui_modules/mapdisp.py:520
-#: ../gui/wxpython/mapdisp/frame.py:197
+#: ../gui/wxpython/lmgr/layertree.py:750
 #, python-format
 msgid ""
-"Unable to start wxGUI vector digitizer.\n"
-"Do you want to start TCL/TK digitizer (v.digit) instead?\n"
-"\n"
-"Details: %s"
+"Name <%(name)s> is not a valid name for GRASS map. Please use only ASCII "
+"characters excluding %(chars)s and space."
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:614
-#: ../gui/wxpython/gui_modules/toolbars.py:222
-#: ../gui/wxpython/gui_modules/layertree.py:596
-#: ../gui/wxpython/gui_modules/mapdisp.py:524
-#: ../gui/wxpython/gui_modules/mapdisp.py:535
-#: ../gui/wxpython/gui_modules/mapdisp.py:587
-#: ../gui/wxpython/gui_modules/mapdisp.py:735
-#: ../gui/wxpython/mapdisp/toolbars.py:80 ../gui/wxpython/mapdisp/frame.py:201
-#: ../gui/wxpython/mapdisp/frame.py:212 ../gui/wxpython/mapdisp/frame.py:264
-#: ../gui/wxpython/mapdisp/frame.py:411
-msgid "2D view"
-msgstr "2D skats"
-#: ../gui/wxpython/lmgr/layertree.py:617
-#: ../gui/wxpython/gui_modules/layertree.py:599
-#: ../gui/wxpython/gui_modules/mapdisp.py:527
-#: ../gui/wxpython/mapdisp/frame.py:204
+#: ../gui/wxpython/lmgr/layertree.py:753 ../gui/wxpython/gis_set.py:983
 #, fuzzy
-msgid "Vector digitizer failed"
-msgstr "GRASS GIS slāņu pārvaldnieks"
+msgid "Invalid name"
+msgstr "Nederīga ievade"
-#: ../gui/wxpython/lmgr/layertree.py:679
+#: ../gui/wxpython/lmgr/layertree.py:769 ../gui/wxpython/nviz/tools.py:1529
+msgid "3D raster map"
+msgstr "3D rastra karte"
+#: ../gui/wxpython/lmgr/layertree.py:771
 #, python-format
-msgid "Set opacity of <%s>"
+msgid "Unsupported map type <%s>"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:775
-#: ../gui/wxpython/gui_modules/layertree.py:757
-msgid "Layer group:"
-msgstr "Slāņu grupa:"
+#: ../gui/wxpython/lmgr/layertree.py:776
+#, python-format
+msgid "Enter name for the new %s in the current mapset:"
+msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:780
-#: ../gui/wxpython/lmgr/layertree.py:1345
-#: ../gui/wxpython/gui_modules/layertree.py:762
-#: ../gui/wxpython/gui_modules/layertree.py:1347
-msgid "Click to edit layer settings"
+#: ../gui/wxpython/lmgr/layertree.py:777
+#, python-format
+msgid "Make a copy of %s <%s>"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:821
-#: ../gui/wxpython/gui_modules/layertree.py:803
-msgid "(double click to set properties)"
+#: ../gui/wxpython/lmgr/layertree.py:791
+#, python-format
+msgid ""
+"%s <%s> already exists in the current mapset. Do you want to overwrite it?"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:827
-#: ../gui/wxpython/gui_modules/gdialogs.py:1278
-#: ../gui/wxpython/gui_modules/layertree.py:809
-#: ../gui/wxpython/gui_core/dialogs.py:1299
-msgid "3D raster"
-msgstr "3D rastrs"
+#: ../gui/wxpython/lmgr/layertree.py:794
+#: ../gui/wxpython/gui_core/dialogs.py:421
+msgid "Overwrite?"
+msgstr "Pārrakstīt?"
-#: ../gui/wxpython/lmgr/layertree.py:830
-#: ../gui/wxpython/gui_modules/layertree.py:812
-msgid "RGB"
-msgstr "RGB"
+#: ../gui/wxpython/lmgr/layertree.py:801
+#, fuzzy, python-format
+msgid "Unable to make copy of <%s>"
-#: ../gui/wxpython/lmgr/layertree.py:833
-#: ../gui/wxpython/gui_modules/layertree.py:815
-msgid "HIS"
-msgstr "HIS"
-#: ../gui/wxpython/lmgr/layertree.py:836
-#: ../gui/wxpython/gui_modules/layertree.py:818
-msgid "shaded relief"
+#: ../gui/wxpython/lmgr/layertree.py:808
+#, python-format
+msgid "Unable to make copy of <%s>. Mapset <%s> is not current mapset."
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:839
-#: ../gui/wxpython/gui_modules/layertree.py:821
-msgid "raster cell numbers"
+#: ../gui/wxpython/lmgr/layertree.py:825
+msgid "Unable to display histogram of raster map. No map name defined."
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:842
-#: ../gui/wxpython/gui_modules/layertree.py:824
-msgid "raster flow arrows"
-msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:867
+#: ../gui/wxpython/mapdisp/toolbars.py:82 ../gui/wxpython/mapdisp/frame.py:253
+#: ../gui/wxpython/mapdisp/frame.py:312 ../gui/wxpython/mapdisp/frame.py:492
+#: ../gui/wxpython/animation/data.py:43
+msgid "2D view"
+msgstr "2D skats"
-#: ../gui/wxpython/lmgr/layertree.py:848
-#: ../gui/wxpython/gui_modules/layertree.py:830
-msgid "thematic area (choropleth) map"
+#: ../gui/wxpython/lmgr/layertree.py:869 ../gui/wxpython/mapdisp/frame.py:255
+#, python-format
+msgid ""
+"Unable to start wxGUI vector digitizer.\n"
+"Details: %s"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:851
-#: ../gui/wxpython/gui_modules/layertree.py:833
-msgid "thematic charts"
+#: ../gui/wxpython/lmgr/layertree.py:926
+#: ../gui/wxpython/gui_core/simplelmgr.py:265
+#, python-format
+msgid "Set opacity of <%s>"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:854
-#: ../gui/wxpython/gui_modules/layertree.py:836
-msgid "grid"
-msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:1029
+msgid "Layer group:"
+msgstr "Slāņu grupa:"
-#: ../gui/wxpython/lmgr/layertree.py:857
-#: ../gui/wxpython/gui_modules/layertree.py:839
-msgid "geodesic line"
+#: ../gui/wxpython/lmgr/layertree.py:1034
+#: ../gui/wxpython/lmgr/layertree.py:1517
+msgid "Click to edit layer settings"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:860
-#: ../gui/wxpython/gui_modules/layertree.py:842
-msgid "rhumbline"
+#: ../gui/wxpython/lmgr/layertree.py:1086
+msgid "(double click to set properties)"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:863
-#: ../gui/wxpython/gui_modules/layertree.py:845
-msgid "vector labels"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1098
-#: ../gui/wxpython/lmgr/layertree.py:1147
-#: ../gui/wxpython/gui_modules/layertree.py:1100
-#: ../gui/wxpython/gui_modules/layertree.py:1149
+#: ../gui/wxpython/lmgr/layertree.py:1321
 msgid "Please wait, updating data..."
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1432
-#: ../gui/wxpython/gui_modules/layertree.py:1434
+#: ../gui/wxpython/lmgr/layertree.py:1592
 msgid "opacity:"
 msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1450
-#: ../gui/wxpython/gui_modules/layertree.py:1452
+#: ../gui/wxpython/lmgr/layertree.py:1610
+#: ../gui/wxpython/mapswipe/frame.py:392 ../gui/wxpython/animation/utils.py:93
+#: ../gui/wxpython/animation/utils.py:101 ../gui/wxpython/gis_set.py:537
 #, python-format
 msgid "Map <%s> not found."
 msgstr "Karte <%s> nav atrasta."
-#: ../gui/wxpython/lmgr/frame.py:74
+#: ../gui/wxpython/lmgr/frame.py:85
 msgid "GRASS GIS Layer Manager"
-#: ../gui/wxpython/lmgr/frame.py:115
+#: ../gui/wxpython/lmgr/frame.py:132
 msgid "Workspace Toolbar"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:118
+#: ../gui/wxpython/lmgr/frame.py:135
 msgid "Data Toolbar"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:121
+#: ../gui/wxpython/lmgr/frame.py:138 ../gui/wxpython/mapswipe/frame.py:290
+#: ../gui/wxpython/animation/frame.py:168
 msgid "Misc Toolbar"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:124
+#: ../gui/wxpython/lmgr/frame.py:141
 msgid "Tools Toolbar"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:127
+#: ../gui/wxpython/lmgr/frame.py:144
 msgid "Vector Toolbar"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:130
+#: ../gui/wxpython/lmgr/frame.py:147
 msgid "3D view Toolbar"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:224 ../gui/wxpython/lmgr/frame.py:1119
+#: ../gui/wxpython/lmgr/frame.py:251 ../gui/wxpython/lmgr/frame.py:1377
 msgid "Rename Map Display"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:252
+#: ../gui/wxpython/lmgr/frame.py:279
 msgid "Map layers"
-#: ../gui/wxpython/lmgr/frame.py:256 ../gui/wxpython/lmgr/frame.py:436
+#: ../gui/wxpython/lmgr/frame.py:289
 msgid "Command console"
 msgstr "Komandu konsole"
-#: ../gui/wxpython/lmgr/frame.py:262
-#: ../gui/wxpython/gui_modules/preferences.py:1309
-#: ../gui/wxpython/gui_core/preferences.py:311
-msgid "Search module"
+#: ../gui/wxpython/lmgr/frame.py:306
+#, fuzzy
+msgid "Search modules"
 msgstr "Meklēt moduli"
-#: ../gui/wxpython/lmgr/frame.py:269
-#: ../gui/wxpython/gui_modules/preferences.py:1319
-#: ../gui/wxpython/gui_core/preferences.py:321
+#: ../gui/wxpython/lmgr/frame.py:313
+#: ../gui/wxpython/gui_core/preferences.py:296
 msgid "Python shell"
 msgstr "Python čaula"
-#: ../gui/wxpython/lmgr/frame.py:299
-#: ../gui/wxpython/gui_modules/toolbars.py:228
-#: ../gui/wxpython/mapdisp/toolbars.py:86
+#: ../gui/wxpython/lmgr/frame.py:346 ../gui/wxpython/mapdisp/toolbars.py:88
+#: ../gui/wxpython/animation/data.py:44
 msgid "3D view"
 msgstr "3D skats"
-#: ../gui/wxpython/lmgr/frame.py:333
+#: ../gui/wxpython/lmgr/frame.py:385
 #, python-format
 msgid ""
 "Location <%s> created.\n"
@@ -7574,167 +7620,205 @@
 "Do you want to switch to the new location?"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:336
+#: ../gui/wxpython/lmgr/frame.py:388
 msgid "Switch to new location?"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:349 ../gui/wxpython/lmgr/frame.py:666
+#: ../gui/wxpython/lmgr/frame.py:404 ../gui/wxpython/lmgr/frame.py:890
 #, python-format
 msgid ""
 "Current location is <%(loc)s>.\n"
 "Current mapset is <%(mapset)s>."
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:390
+#: ../gui/wxpython/lmgr/frame.py:410 ../gui/wxpython/gis_set.py:490
+msgid "Do you want to set the default region extents and resolution now?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:412 ../gui/wxpython/gis_set.py:489
+#, python-format
+msgid "Location <%s> created"
+msgstr "Novietojums <%s> ir izveidots:"
+#: ../gui/wxpython/lmgr/frame.py:490
 msgid "Choose model to run"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:450 ../gui/wxpython/lmgr/frame.py:1711
+#: ../gui/wxpython/lmgr/frame.py:548 ../gui/wxpython/lmgr/frame.py:2059
 msgid "Do you want to save changes in the workspace?"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:452 ../gui/wxpython/lmgr/frame.py:1713
+#: ../gui/wxpython/lmgr/frame.py:550 ../gui/wxpython/lmgr/frame.py:2061
 msgid "Do you want to store current settings to workspace file?"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:460
+#: ../gui/wxpython/lmgr/frame.py:558
 #, python-format
 msgid "Close Map Display %s"
 msgstr "Aizvērt kartes skatu %s"
-#: ../gui/wxpython/lmgr/frame.py:568 ../gui/wxpython/lmgr/frame.py:1328
+#: ../gui/wxpython/lmgr/frame.py:632
+#, python-format
+msgid ""
+"Command '%s' not yet implemented in the WxGUI. Try adding it as a command "
+"layer instead."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:783 ../gui/wxpython/lmgr/frame.py:1599
 msgid "Selected map layer is not vector."
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:573
+#: ../gui/wxpython/lmgr/frame.py:788
 msgid "Editing is allowed only for vector maps from the current mapset."
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:588
+#: ../gui/wxpython/lmgr/frame.py:812
 msgid "Choose script file to run"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:590
+#: ../gui/wxpython/lmgr/frame.py:814
 msgid "Python script (*.py)|*.py|Bash script (*.sh)|*.sh"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:601
+#: ../gui/wxpython/lmgr/frame.py:825
 #, python-format
 msgid "Script file '%s' doesn't exist. Operation canceled."
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:608
+#: ../gui/wxpython/lmgr/frame.py:832
 #, python-format
 msgid ""
 "Script <%s> is not executable. Do you want to set the permissions that "
 "allows you to run this script (note that you must be the owner of the file)?"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:613
+#: ../gui/wxpython/lmgr/frame.py:837
 msgid "Set permission?"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:622
+#: ../gui/wxpython/lmgr/frame.py:846
 msgid "Unable to set permission. Operation canceled."
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:633
+#: ../gui/wxpython/lmgr/frame.py:857
 #, python-format
 msgid ""
 "Directory '%s' is not defined in GRASS_ADDON_PATH. Do you want add this "
 "directory to GRASS_ADDON_PATH?"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:636
+#: ../gui/wxpython/lmgr/frame.py:860
 msgid "Update Addons path?"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:642
+#: ../gui/wxpython/lmgr/frame.py:866
 #, python-format
 msgid "Launching script '%s'..."
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:654
+#: ../gui/wxpython/lmgr/frame.py:878
 msgid "No location/mapset provided. Operation canceled."
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:673 ../gui/wxpython/gis_set.py:693
+#: ../gui/wxpython/lmgr/frame.py:897 ../gui/wxpython/gis_set.py:846
 msgid "Enter name for new mapset:"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:680 ../gui/wxpython/lmgr/frame.py:701
+#: ../gui/wxpython/lmgr/frame.py:904 ../gui/wxpython/lmgr/frame.py:925
 msgid "No mapset provided. Operation canceled."
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:689 ../gui/wxpython/lmgr/frame.py:708
+#: ../gui/wxpython/lmgr/frame.py:913 ../gui/wxpython/lmgr/frame.py:932
 #, python-format
 msgid "Current mapset is <%s>."
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:713
+#: ../gui/wxpython/lmgr/frame.py:937
 msgid "Choose a working directory"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:793
+#: ../gui/wxpython/lmgr/frame.py:976
+msgid "System Info"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:990
+#, fuzzy
+msgid "GRASS version"
+msgstr "Sākt GRASS sesiju"
+#: ../gui/wxpython/lmgr/frame.py:991
+#, fuzzy
+msgid "GRASS SVN Revision"
+msgstr "SVN revīzija:"
+#: ../gui/wxpython/lmgr/frame.py:992 ../gui/wxpython/gui_core/ghelp.py:146
+msgid "Build Date"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:997
+msgid "Platform"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1053
 msgid ""
 "Current workspace is not empty. Do you want to store current settings to "
 "workspace file?"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:796
+#: ../gui/wxpython/lmgr/frame.py:1056
 msgid "Create new workspace?"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:822
+#: ../gui/wxpython/lmgr/frame.py:1082
 msgid "Choose workspace file"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:823 ../gui/wxpython/lmgr/frame.py:1013
+#: ../gui/wxpython/lmgr/frame.py:1083 ../gui/wxpython/lmgr/frame.py:1275
 msgid "GRASS Workspace File (*.gxw)|*.gxw"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:858
+#: ../gui/wxpython/lmgr/frame.py:1118 ../gui/wxpython/animation/nviztask.py:45
 #, python-format
 msgid ""
 "Reading workspace file <%s> failed.\n"
 "Invalid file, unable to parse XML document."
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:862 ../gui/wxpython/lmgr/frame.py:990
+#: ../gui/wxpython/lmgr/frame.py:1122 ../gui/wxpython/lmgr/frame.py:1252
 msgid "Please wait, loading workspace..."
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:974
+#: ../gui/wxpython/lmgr/frame.py:1236
 msgid "Choose GRC file to load"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:975
+#: ../gui/wxpython/lmgr/frame.py:1237
 msgid "Old GRASS Workspace File (*.grc)|*.grc"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1012
+#: ../gui/wxpython/lmgr/frame.py:1274
 msgid "Choose file to save current workspace"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1027 ../gui/wxpython/lmgr/frame.py:1043
+#: ../gui/wxpython/lmgr/frame.py:1289 ../gui/wxpython/lmgr/frame.py:1305
 #, python-format
 msgid "Workspace file <%s> already exists. Do you want to overwrite this file?"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1067
+#: ../gui/wxpython/lmgr/frame.py:1329
 msgid "Writing current settings to workspace file failed."
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1118
+#: ../gui/wxpython/lmgr/frame.py:1376
 msgid "Enter new name:"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1124
+#: ../gui/wxpython/lmgr/frame.py:1382
 #, python-format
 msgid "GRASS GIS Map Display: %(name)s  - Location: %(loc)s"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1182
+#: ../gui/wxpython/lmgr/frame.py:1459
 #, python-format
 msgid ""
 "Unable to launch \"Supervised Classification Tool\".\n"
@@ -7742,30 +7826,22 @@
 "Reason: %s"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1301
-msgid "Nothing to import. No WMS layer selected."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1337
-msgid "Please wait, loading attribute data..."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1412
+#: ../gui/wxpython/lmgr/frame.py:1707
 msgid "Add selected map layers into layer tree"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1443
+#: ../gui/wxpython/lmgr/frame.py:1741 ../gui/wxpython/lmgr/frame.py:1785
 #, python-format
 msgid "Unsupported map layer type <%s>."
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1566
+#: ../gui/wxpython/lmgr/frame.py:1914
 msgid ""
 "Note that cell values can only be displayed for regions of less than 10,000 "
 "cells."
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1648
+#: ../gui/wxpython/lmgr/frame.py:1996
 #, python-format
 msgid ""
 "Do you want to remove map layer(s)\n"
@@ -7773,1110 +7849,1151 @@
 "from layer tree?"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1651
+#: ../gui/wxpython/lmgr/frame.py:1999
 msgid "Do you want to remove selected map layer(s) from layer tree?"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1655
+#: ../gui/wxpython/lmgr/frame.py:2003
 msgid "Remove map layer"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1720
+#: ../gui/wxpython/lmgr/frame.py:2068
 msgid "Quit GRASS GUI"
 msgstr "Iziet no GRASS GUI"
-#: ../gui/wxpython/lmgr/frame.py:1749
+#: ../gui/wxpython/lmgr/frame.py:2099
 msgid "No map layer selected. Operation canceled."
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1750 ../gui/wxpython/gui_modules/gcmd.py:99
-#: ../gui/wxpython/gui_modules/dbm.py:2065
-#: ../gui/wxpython/gui_modules/dbm.py:2096
-#: ../gui/wxpython/gui_modules/ghelp.py:293
-#: ../gui/wxpython/gui_core/ghelp.py:276 ../gui/wxpython/core/gcmd.py:143
-#: ../gui/wxpython/gis_set.py:436 ../gui/wxpython/gis_set.py:471
+#: ../gui/wxpython/lmgr/frame.py:2100 ../gui/wxpython/core/gcmd.py:149
+#: ../gui/wxpython/gis_set.py:584 ../gui/wxpython/gis_set.py:620
 msgid "Message"
 msgstr "Paziņojums"
-#: ../gui/wxpython/lmgr/frame.py:1759
+#: ../gui/wxpython/lmgr/frame.py:2109
 msgid ""
 "Display resolution is currently not constrained to computational settings. "
 "It's suggested to constrain map to region geometry. Do you want to constrain "
 "the resolution?"
 msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1768
+#: ../gui/wxpython/lmgr/frame.py:2118
 msgid "Constrain map to region geometry?"
 msgstr ""
-#: ../gui/wxpython/ogc_services/wms.py:53
-#: ../gui/wxpython/gui_modules/ogc_services.py:54
+#: ../gui/wxpython/web_services/dialogs.py:90
 msgid " Server settings "
 msgstr ""
-#: ../gui/wxpython/ogc_services/wms.py:55
-#: ../gui/wxpython/gui_modules/ogc_services.py:56
+#: ../gui/wxpython/web_services/dialogs.py:93
 msgid "Server:"
 msgstr ""
-#: ../gui/wxpython/ogc_services/wms.py:62
-#: ../gui/wxpython/gui_modules/ogc_services.py:63
-msgid " List of layers "
+#: ../gui/wxpython/web_services/dialogs.py:97
+msgid "&Connect"
+msgstr "&Pieslēgties"
+#: ../gui/wxpython/web_services/dialogs.py:98
+msgid "Connect to the server"
 msgstr ""
-#: ../gui/wxpython/ogc_services/wms.py:68
-#: ../gui/wxpython/gui_modules/gdialogs.py:1712
-#: ../gui/wxpython/gui_modules/gdialogs.py:1915
-#: ../gui/wxpython/gui_modules/ogc_services.py:69
-#: ../gui/wxpython/gui_core/dialogs.py:1803
-#: ../gui/wxpython/gui_core/dialogs.py:2019
-msgid "Add imported layers into layer tree"
+#: ../gui/wxpython/web_services/dialogs.py:102
+#, fuzzy
+msgid "Show advanced connection settings"
+msgstr "Saglabāt pašreizējos iestatījumus"
+#: ../gui/wxpython/web_services/dialogs.py:103
+#, fuzzy
+msgid "Hide advanced connection settings"
+msgstr "Tīkla un leģendas iestatījumi"
+#: ../gui/wxpython/web_services/dialogs.py:118
+#, fuzzy
+msgid " Layer Manager Settings "
+msgstr "Slāņu pārvaldnieka iestatījumi"
+#: ../gui/wxpython/web_services/dialogs.py:121
+#, fuzzy
+msgid "Output layer name:"
+msgstr "Slāņa nosaukums"
+#: ../gui/wxpython/web_services/dialogs.py:231
+#, fuzzy
+msgid "Username:"
+msgstr "Pārsaukt"
+#: ../gui/wxpython/web_services/dialogs.py:235
+msgid "Password:"
 msgstr ""
-#: ../gui/wxpython/ogc_services/wms.py:78
-#: ../gui/wxpython/gui_modules/ogc_services.py:79
-msgid "&Connect"
-msgstr "&Pieslēgties"
+#: ../gui/wxpython/web_services/dialogs.py:276
+#: ../gui/wxpython/gui_core/gselect.py:1770
+msgid "No data source defined, settings are not saved."
+msgstr ""
-#: ../gui/wxpython/ogc_services/wms.py:79
-#: ../gui/wxpython/gui_modules/ogc_services.py:80
-msgid "Connect to the server"
+#: ../gui/wxpython/web_services/dialogs.py:354
+#, python-format
+msgid "Connecting to <%s>..."
 msgstr ""
-#: ../gui/wxpython/ogc_services/wms.py:84
-#: ../gui/wxpython/gui_modules/gdialogs.py:1549
-#: ../gui/wxpython/gui_modules/gdialogs.py:1724
-#: ../gui/wxpython/gui_modules/ogc_services.py:85
-#: ../gui/wxpython/gui_core/dialogs.py:1639
-#: ../gui/wxpython/gui_core/dialogs.py:1815
-msgid "&Import"
-msgstr "&Importēt"
+#: ../gui/wxpython/web_services/dialogs.py:420
+msgid "Available web services"
+msgstr ""
-#: ../gui/wxpython/ogc_services/wms.py:85
-#: ../gui/wxpython/gui_modules/gdialogs.py:1550
-#: ../gui/wxpython/gui_modules/gdialogs.py:1725
-#: ../gui/wxpython/gui_modules/ogc_services.py:86
-#: ../gui/wxpython/gui_core/dialogs.py:1640
-#: ../gui/wxpython/gui_core/dialogs.py:1816
-msgid "Import selected layers"
+#: ../gui/wxpython/web_services/dialogs.py:428
+#, python-format
+msgid "Connected to <%s>"
 msgstr ""
-#: ../gui/wxpython/ogc_services/wms.py:239
-#: ../gui/wxpython/gui_modules/ogc_services.py:240
-msgid "Layer / Style"
+#: ../gui/wxpython/web_services/dialogs.py:433
+msgid "Unable to connect to <%s>"
+msgstr "Nav iespējams izveidot jaunu karšu kopu: %s"
+#: ../gui/wxpython/web_services/dialogs.py:477
+#, fuzzy
+msgid "Add web service layer"
+#: ../gui/wxpython/web_services/dialogs.py:487
+#: ../gui/wxpython/dbmgr/base.py:2762
+msgid "&Add layer"
 msgstr ""
-#: ../gui/wxpython/ogc_services/wms.py:240
-#: ../gui/wxpython/gui_modules/ogc_services.py:241
-msgid "Title"
+#: ../gui/wxpython/web_services/dialogs.py:488
+#, fuzzy
+msgid "Add selected web service layers as map layer into layer tree"
+#: ../gui/wxpython/web_services/dialogs.py:580
+msgid "Web service layer properties"
 msgstr ""
-#: ../gui/wxpython/ogc_services/wms.py:250
-#: ../gui/wxpython/gui_modules/ogc_services.py:251
-#: ../gui/wxpython/gui_core/preferences.py:863
-msgid "Layers"
-msgstr "Slāņi"
+#: ../gui/wxpython/web_services/dialogs.py:625
+msgid "&Apply"
+msgstr ""
-#: ../gui/wxpython/nviz/tools.py:84 ../gui/wxpython/nviz/preferences.py:55
-#: ../gui/wxpython/nviz/preferences.py:60
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:53
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:58
-#: ../gui/wxpython/gui_modules/nviz_tools.py:251
+#: ../gui/wxpython/web_services/dialogs.py:630
+msgid "&OK"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:631
+#: ../gui/wxpython/vdigit/dialogs.py:148
+msgid "Apply changes and close dialog"
+msgstr "Pielietot izmaiņas un aizvērt dialogu"
+#: ../gui/wxpython/web_services/dialogs.py:791
+#, fuzzy
+msgid "Name for output raster map:"
+msgstr "Rastra kartes nosaukums:"
+#: ../gui/wxpython/web_services/dialogs.py:806
+#, fuzzy
+msgid "Overwrite existing raster map"
+msgstr "Ievietot eksistējošu rastra karti"
+#: ../gui/wxpython/web_services/dialogs.py:810
+#, fuzzy
+msgid "Choose named region:"
+msgstr "Ielādēt reģionu:"
+#: ../gui/wxpython/web_services/dialogs.py:819
+#, fuzzy
+msgid "&Save layer"
+msgstr "Pārvaldīt slāņus"
+#: ../gui/wxpython/web_services/dialogs.py:820
+msgid "Save web service layer as raster map"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:935
+msgid "Missing output raster."
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:939
+msgid "Output map can be added only to current mapset."
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:943
+msgid "Output map <%s> already exists"
+msgstr "Karšu kopa <%s> jau eksistē."
+#: ../gui/wxpython/web_services/dialogs.py:964
+msgid "Region <%s> does not exists."
+msgstr "Īpašība %s neeksistē"
+#: ../gui/wxpython/web_services/dialogs.py:988
+#, fuzzy
+msgid "Downloading data..."
+msgstr "Datu ielāde..."
+#: ../gui/wxpython/web_services/dialogs.py:1015
+#, fuzzy
+msgid "Unable to fetch data.\n"
+msgstr "Nav iespējams dzēst karšu kopu"
+#: ../gui/wxpython/web_services/widgets.py:137
+#, fuzzy
+msgid " Requested data settings "
+#: ../gui/wxpython/web_services/widgets.py:147
+#, fuzzy
+msgid "Request"
+msgstr "Obilgāti"
+#: ../gui/wxpython/web_services/widgets.py:152
+#, fuzzy
+msgid "List of layers "
+msgstr "Slāņu saraksts"
+#: ../gui/wxpython/web_services/widgets.py:168
+#, fuzzy
+msgid "Source projection:"
+msgstr "Projekcija:"
+#: ../gui/wxpython/web_services/widgets.py:213
+#, fuzzy
+msgid "Advanced request settings"
+#: ../gui/wxpython/web_services/widgets.py:220
+msgid "Order of layers in raster"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:230
+#, fuzzy
+msgid "Reprojection method:"
+msgstr "Projekcijas kods:"
+#: ../gui/wxpython/web_services/widgets.py:234
+msgid "Nearest neighbor"
+msgstr ""
+#, fuzzy
+msgid "Linear interpolation"
+msgstr "Meklēt pēc apraksta:"
+#: ../gui/wxpython/web_services/widgets.py:235
+msgid "Cubic interpolation"
+msgstr ""
+msgid "Cubic spline interpolation"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:238
+msgid "Maximum columns to request from server at time:"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:242
+msgid "Maximum rows to request from server at time:"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:257
+msgid "Do not request transparent data"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:261
+#: ../gui/wxpython/nviz/tools.py:354 ../gui/wxpython/nviz/preferences.py:178
+#: ../gui/wxpython/gui_core/preferences.py:654
+#: ../gui/wxpython/animation/dialogs.py:1495
+msgid "Background color:"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:270
+#, fuzzy
+msgid "Additional query parameters for server:"
+msgstr "Pievienot vairākas rastra vai vektoru kartes"
+#: ../gui/wxpython/web_services/widgets.py:472
+#, python-format
+msgid ""
+"Unable to download %s capabilities file\n"
+"from <%s>:\n"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:486
+#, python-format
+msgid ""
+"%s web service was not found in fetched capabilities file from <%s>:\n"
+"%s\n"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:760
+msgid "Source image format"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:793
+msgid "Select layer in layer list.\n"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:798
+msgid "Select source image format.\n"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:803
+#, fuzzy
+msgid "Select source projection.\n"
+msgstr "Dzēst izvēlēto novietojumu"
+#: ../gui/wxpython/web_services/widgets.py:807
+msgid "Choose output layer name.\n"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:847
+#: ../gui/wxpython/gui_core/dialogs.py:1614
+msgid "Layer name"
+#: ../gui/wxpython/web_services/widgets.py:881
+#, fuzzy
+msgid "layer"
+msgstr "Slānis"
+#: ../gui/wxpython/web_services/widgets.py:901
+#, fuzzy
+msgid "style"
+msgstr "Stils:"
+#: ../gui/wxpython/nviz/tools.py:88 ../gui/wxpython/nviz/preferences.py:56
+#: ../gui/wxpython/nviz/preferences.py:61
 msgid "View"
 msgstr "Skats"
-#: ../gui/wxpython/nviz/tools.py:92
-#: ../gui/wxpython/gui_modules/preferences.py:1403
-#: ../gui/wxpython/gui_modules/nviz_tools.py:259
-#: ../gui/wxpython/gui_core/preferences.py:405
+#: ../gui/wxpython/nviz/tools.py:96
+#: ../gui/wxpython/gui_core/preferences.py:376
 msgid "Appearance"
 msgstr "Izskats"
-#: ../gui/wxpython/nviz/tools.py:96
-#: ../gui/wxpython/gui_modules/nviz_tools.py:263
+#: ../gui/wxpython/nviz/tools.py:100
 msgid "Analysis"
 msgstr "Analīze"
-#: ../gui/wxpython/nviz/tools.py:99 ../gui/wxpython/nviz/tools.py:369
-#: ../gui/wxpython/gui_modules/nviz_tools.py:266
-#: ../gui/wxpython/gui_modules/nviz_tools.py:536
+#: ../gui/wxpython/nviz/tools.py:103 ../gui/wxpython/nviz/tools.py:385
 msgid "Animation"
 msgstr "Animācija"
-#: ../gui/wxpython/nviz/tools.py:219
-#: ../gui/wxpython/gui_modules/nviz_tools.py:386
+#: ../gui/wxpython/nviz/tools.py:226
 msgid "Control View"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:244 ../gui/wxpython/nviz/preferences.py:68
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:66
-#: ../gui/wxpython/gui_modules/nviz_tools.py:411
+#: ../gui/wxpython/nviz/tools.py:247
+msgid "Adjusts the distance and angular perspective of the image viewpoint"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:252 ../gui/wxpython/nviz/preferences.py:69
 msgid "Perspective:"
 msgstr "Perspektīva:"
-#: ../gui/wxpython/nviz/tools.py:255 ../gui/wxpython/nviz/preferences.py:131
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:129
-#: ../gui/wxpython/gui_modules/nviz_tools.py:422
-msgid "Twist:"
+#: ../gui/wxpython/nviz/tools.py:260
+msgid "Tilts the plane of the surface from the horizontal"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:278 ../gui/wxpython/nviz/preferences.py:149
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:147
-#: ../gui/wxpython/gui_modules/nviz_tools.py:445
+#: ../gui/wxpython/nviz/tools.py:264 ../gui/wxpython/nviz/tools.py:1024
+msgid "Tilt:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:271
+msgid ""
+"Adjusts the viewing height above the surface (angle of view automatically "
+"adjusts to maintain the same center of view)"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:276
+msgid "Adjusts the relative height of features above the plane of the surface"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:290 ../gui/wxpython/nviz/preferences.py:150
 msgid "Z-exag:"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:291
-#: ../gui/wxpython/gui_modules/nviz_tools.py:458
+#: ../gui/wxpython/nviz/tools.py:303
 msgid "Look:"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:294
-#: ../gui/wxpython/gui_modules/nviz_tools.py:461
+#: ../gui/wxpython/nviz/tools.py:306
 msgid "here"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:300
-#: ../gui/wxpython/gui_modules/nviz_tools.py:467
+#: ../gui/wxpython/nviz/tools.py:309
+msgid ""
+"Allows you to select a point on the surface that becomes the new center of "
+"view. Click on the button and then on the surface."
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:315
 msgid "center"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:306
-#: ../gui/wxpython/gui_modules/nviz_tools.py:473
+#: ../gui/wxpython/nviz/tools.py:318
+msgid "Resets the view to the original default center of view"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:322
 msgid "top"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:312
-#: ../gui/wxpython/gui_modules/nviz_tools.py:479
+#: ../gui/wxpython/nviz/tools.py:325
+msgid ""
+"Sets the viewer directly over the scene's center position. This top view "
+"orients approximately north south."
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:329
 msgid "reset"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:313
-#: ../gui/wxpython/gui_modules/nviz_tools.py:480
+#: ../gui/wxpython/nviz/tools.py:330
 msgid "Reset to default view"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:331 ../gui/wxpython/nviz/preferences.py:171
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:169
-#: ../gui/wxpython/gui_modules/nviz_tools.py:498
+#: ../gui/wxpython/nviz/tools.py:347 ../gui/wxpython/nviz/preferences.py:172
 msgid "Image Appearance"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:339 ../gui/wxpython/nviz/preferences.py:178
-#: ../gui/wxpython/gui_modules/preferences.py:1630
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:176
-#: ../gui/wxpython/gui_modules/nviz_tools.py:506
-#: ../gui/wxpython/gui_core/preferences.py:665
-msgid "Background color:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:376
-#: ../gui/wxpython/gui_modules/nviz_tools.py:543
+#: ../gui/wxpython/nviz/tools.py:392
 msgid ""
 "Press 'Record' button and start changing the view. It is recommended to use "
 "fly-through mode (Map Display toolbar) to achieve smooth motion."
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:387
-#: ../gui/wxpython/gui_modules/nviz_tools.py:554
+#: ../gui/wxpython/nviz/tools.py:403
 msgid "Record"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:389
-#: ../gui/wxpython/gui_modules/nviz_tools.py:556
+#: ../gui/wxpython/nviz/tools.py:405
 msgid "Play"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:391
-#: ../gui/wxpython/gui_modules/nviz_tools.py:558
+#: ../gui/wxpython/nviz/tools.py:407 ../gui/wxpython/animation/toolbars.py:32
 msgid "Pause"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:393
-#: ../gui/wxpython/gui_modules/nviz_tools.py:560
+#: ../gui/wxpython/nviz/tools.py:409 ../gui/wxpython/animation/toolbars.py:31
 msgid "Stop"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:405
-#: ../gui/wxpython/gui_modules/nviz_tools.py:572
+#: ../gui/wxpython/nviz/tools.py:421
 msgid "Total number of frames :"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:409
-#: ../gui/wxpython/gui_modules/nviz_tools.py:576
+#: ../gui/wxpython/nviz/tools.py:425
 msgid "Frame rate (FPS):"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:415
-#: ../gui/wxpython/gui_modules/nviz_tools.py:582
+#: ../gui/wxpython/nviz/tools.py:431
 msgid "Frames are recorded with given frequency (FPS). "
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:458
-#: ../gui/wxpython/gui_modules/nviz_tools.py:625
+#: ../gui/wxpython/nviz/tools.py:474
 msgid "Save image sequence"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:466
-#: ../gui/wxpython/gui_modules/nviz_tools.py:633
+#: ../gui/wxpython/nviz/tools.py:482
 msgid "Choose a directory for images"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:470
-#: ../gui/wxpython/gui_modules/nviz_tools.py:637
+#: ../gui/wxpython/nviz/tools.py:486 ../gui/wxpython/animation/dialogs.py:922
 msgid "File prefix:"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:474
-#: ../gui/wxpython/gui_modules/nviz_tools.py:641
-msgid "Generated files names will look like this: prefix_1.ppm, prefix_2.ppm, ..."
+#: ../gui/wxpython/nviz/tools.py:490
+msgid ""
+"Generated files names will look like this: prefix_1.ppm, prefix_2.ppm, ..."
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:475
-#: ../gui/wxpython/gui_modules/nviz_tools.py:642
+#: ../gui/wxpython/nviz/tools.py:491 ../gui/wxpython/animation/dialogs.py:924
 msgid "File format:"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:530 ../gui/wxpython/nviz/tools.py:1825
-#: ../gui/wxpython/nviz/preferences.py:360
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:358
-#: ../gui/wxpython/gui_modules/nviz_tools.py:700
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1987
+#: ../gui/wxpython/nviz/tools.py:546 ../gui/wxpython/nviz/tools.py:1859
+#: ../gui/wxpython/nviz/preferences.py:361
 msgid "Surface"
 msgstr "Virsma"
-#: ../gui/wxpython/nviz/tools.py:536 ../gui/wxpython/nviz/tools.py:1063
-#: ../gui/wxpython/gui_modules/nviz_tools.py:706
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1233
+#: ../gui/wxpython/nviz/tools.py:552 ../gui/wxpython/nviz/tools.py:1083
 msgid "Constant surface"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:541 ../gui/wxpython/nviz/preferences.py:462
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:460
-#: ../gui/wxpython/gui_modules/nviz_tools.py:711
+#: ../gui/wxpython/nviz/tools.py:557 ../gui/wxpython/nviz/preferences.py:463
 msgid "Vector"
 msgstr "Vektors"
-#: ../gui/wxpython/nviz/tools.py:547
-#: ../gui/wxpython/gui_modules/nviz_tools.py:717
+#: ../gui/wxpython/nviz/tools.py:563
 msgid "Volume"
 msgstr "Tilpums"
-#: ../gui/wxpython/nviz/tools.py:582 ../gui/wxpython/nviz/preferences.py:252
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:250
-#: ../gui/wxpython/gui_modules/nviz_tools.py:752
+#: ../gui/wxpython/nviz/tools.py:598 ../gui/wxpython/nviz/preferences.py:253
 msgid "Lighting"
 msgstr "Apgaismojums"
-#: ../gui/wxpython/nviz/tools.py:587
-#: ../gui/wxpython/gui_modules/nviz_tools.py:757
+#: ../gui/wxpython/nviz/tools.py:603
 msgid "Fringe"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:594
-#: ../gui/wxpython/gui_modules/nviz_tools.py:764
+#: ../gui/wxpython/nviz/tools.py:610 ../gui/wxpython/animation/dialogs.py:762
 msgid "Decorations"
 msgstr "Dekorācijas"
-#: ../gui/wxpython/nviz/tools.py:614 ../gui/wxpython/nviz/tools.py:926
-#: ../gui/wxpython/gui_modules/nviz_tools.py:784
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1096
+#: ../gui/wxpython/nviz/tools.py:630 ../gui/wxpython/nviz/tools.py:941
 msgid "Cutting planes"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:659 ../gui/wxpython/nviz/tools.py:1521
-#: ../gui/wxpython/nviz/preferences.py:367
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:365
-#: ../gui/wxpython/gui_modules/nviz_tools.py:829
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1691
+#: ../gui/wxpython/nviz/tools.py:675 ../gui/wxpython/nviz/tools.py:1552
+#: ../gui/wxpython/nviz/preferences.py:368
+#: ../gui/wxpython/timeline/frame.py:129
 msgid "Draw"
 msgstr "Zīmēt"
-#: ../gui/wxpython/nviz/tools.py:666 ../gui/wxpython/nviz/tools.py:1528
-#: ../gui/wxpython/nviz/preferences.py:373
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:371
-#: ../gui/wxpython/gui_modules/nviz_tools.py:836
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1698
+#: ../gui/wxpython/nviz/tools.py:681 ../gui/wxpython/nviz/tools.py:1559
+#: ../gui/wxpython/nviz/preferences.py:374
 msgid "Mode:"
 msgstr "Režīms:"
-#: ../gui/wxpython/nviz/tools.py:669 ../gui/wxpython/nviz/preferences.py:376
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:374
-#: ../gui/wxpython/gui_modules/nviz_tools.py:839
+#: ../gui/wxpython/nviz/tools.py:684 ../gui/wxpython/nviz/preferences.py:377
 msgid "coarse"
 msgstr "rupjš"
-#: ../gui/wxpython/nviz/tools.py:670 ../gui/wxpython/nviz/preferences.py:377
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:375
-#: ../gui/wxpython/gui_modules/nviz_tools.py:840
+#: ../gui/wxpython/nviz/tools.py:685 ../gui/wxpython/nviz/preferences.py:378
 msgid "fine"
 msgstr "smalks"
-#: ../gui/wxpython/nviz/tools.py:671 ../gui/wxpython/nviz/preferences.py:378
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:376
-#: ../gui/wxpython/gui_modules/nviz_tools.py:841
+#: ../gui/wxpython/nviz/tools.py:686 ../gui/wxpython/nviz/preferences.py:379
 msgid "both"
 msgstr "abi"
-#: ../gui/wxpython/nviz/tools.py:680 ../gui/wxpython/nviz/tools.py:942
-#: ../gui/wxpython/nviz/tools.py:1542
-#: ../gui/wxpython/gui_modules/nviz_tools.py:850
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1112
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1712
+#: ../gui/wxpython/nviz/tools.py:695 ../gui/wxpython/nviz/tools.py:957
+#: ../gui/wxpython/nviz/tools.py:1573
 msgid "Shading:"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:683 ../gui/wxpython/nviz/tools.py:1279
-#: ../gui/wxpython/nviz/tools.py:1545
-#: ../gui/wxpython/gui_modules/nviz_tools.py:853
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1449
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1715
+#: ../gui/wxpython/nviz/tools.py:698 ../gui/wxpython/nviz/tools.py:1298
+#: ../gui/wxpython/nviz/tools.py:1576
 msgid "flat"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:684 ../gui/wxpython/nviz/tools.py:1546
-#: ../gui/wxpython/gui_modules/nviz_tools.py:854
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1716
+#: ../gui/wxpython/nviz/tools.py:699 ../gui/wxpython/nviz/tools.py:1577
 msgid "gouraud"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:692
-#: ../gui/wxpython/gui_modules/nviz_tools.py:862
+#: ../gui/wxpython/nviz/tools.py:707
 msgid "Set to all"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:693
-#: ../gui/wxpython/gui_modules/nviz_tools.py:863
+#: ../gui/wxpython/nviz/tools.py:708
 msgid "Use draw settings for all loaded surfaces"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:701 ../gui/wxpython/nviz/preferences.py:405
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:403
-#: ../gui/wxpython/gui_modules/nviz_tools.py:871
+#: ../gui/wxpython/nviz/tools.py:716 ../gui/wxpython/nviz/preferences.py:406
 msgid "Coarse mode:"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:704 ../gui/wxpython/nviz/tools.py:744
-#: ../gui/wxpython/nviz/preferences.py:392
-#: ../gui/wxpython/nviz/preferences.py:409
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:390
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:407
-#: ../gui/wxpython/gui_modules/nviz_tools.py:874
-#: ../gui/wxpython/gui_modules/nviz_tools.py:914
+#: ../gui/wxpython/nviz/tools.py:719 ../gui/wxpython/nviz/tools.py:759
+#: ../gui/wxpython/nviz/preferences.py:393
+#: ../gui/wxpython/nviz/preferences.py:410
 msgid "resolution:"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:717 ../gui/wxpython/nviz/preferences.py:421
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:419
-#: ../gui/wxpython/gui_modules/nviz_tools.py:887
+#: ../gui/wxpython/nviz/tools.py:732 ../gui/wxpython/nviz/preferences.py:422
 msgid "style:"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:720 ../gui/wxpython/nviz/preferences.py:424
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:422
-#: ../gui/wxpython/gui_modules/nviz_tools.py:890
+#: ../gui/wxpython/nviz/tools.py:735 ../gui/wxpython/nviz/preferences.py:425
 msgid "wire"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:721 ../gui/wxpython/nviz/preferences.py:425
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:423
-#: ../gui/wxpython/gui_modules/nviz_tools.py:891
+#: ../gui/wxpython/nviz/tools.py:736 ../gui/wxpython/nviz/preferences.py:426
 msgid "surface"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:733
-#: ../gui/wxpython/gui_modules/nviz_tools.py:903
+#: ../gui/wxpython/nviz/tools.py:748
 msgid "Change wire color"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:740 ../gui/wxpython/nviz/preferences.py:388
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:386
-#: ../gui/wxpython/gui_modules/nviz_tools.py:910
+#: ../gui/wxpython/nviz/tools.py:755 ../gui/wxpython/nviz/preferences.py:389
 msgid "Fine mode:"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:765
-#: ../gui/wxpython/gui_modules/nviz_tools.py:935
+#: ../gui/wxpython/nviz/tools.py:781
 msgid "Surface attributes"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:775 ../gui/wxpython/nviz/tools.py:2341
-#: ../gui/wxpython/gui_modules/nviz_tools.py:945
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2493
+#: ../gui/wxpython/nviz/tools.py:790 ../gui/wxpython/nviz/tools.py:2401
 msgid "Transparency"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:776 ../gui/wxpython/nviz/tools.py:2342
-#: ../gui/wxpython/gui_modules/nviz_tools.py:946
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2494
+#: ../gui/wxpython/nviz/tools.py:791 ../gui/wxpython/nviz/tools.py:2402
 msgid "Shininess"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:782 ../gui/wxpython/nviz/tools.py:2353
-#: ../gui/wxpython/gui_modules/nviz_tools.py:952
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2505
+#: ../gui/wxpython/nviz/tools.py:797 ../gui/wxpython/nviz/tools.py:2413
 msgid "map"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:785 ../gui/wxpython/nviz/tools.py:2358
-#: ../gui/wxpython/gui_modules/nviz_tools.py:955
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2510
+#: ../gui/wxpython/nviz/tools.py:800 ../gui/wxpython/nviz/tools.py:2418
 msgid "unset"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:790 ../gui/wxpython/nviz/tools.py:2363
-#: ../gui/wxpython/gui_modules/nviz_tools.py:960
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2515
+#: ../gui/wxpython/nviz/tools.py:805 ../gui/wxpython/nviz/tools.py:2423
 msgid "constant"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:856 ../gui/wxpython/nviz/tools.py:1039
-#: ../gui/wxpython/nviz/tools.py:1660 ../gui/wxpython/nviz/tools.py:2523
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1026
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1209
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1822
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2675
+#: ../gui/wxpython/nviz/tools.py:862
+msgid "Changes the x, y, and z position of the current surface"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:872 ../gui/wxpython/nviz/tools.py:1059
+#: ../gui/wxpython/nviz/tools.py:1690 ../gui/wxpython/nviz/tools.py:2583
 msgid "Reset"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:857 ../gui/wxpython/nviz/tools.py:1661
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1027
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1823
+#: ../gui/wxpython/nviz/tools.py:873 ../gui/wxpython/nviz/tools.py:1691
 msgid "Reset to default position"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:932
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1102
+#: ../gui/wxpython/nviz/tools.py:947
 msgid "Active cutting plane:"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:944
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1114
+#: ../gui/wxpython/nviz/tools.py:959
 msgid "clear"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:945
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1115
+#: ../gui/wxpython/nviz/tools.py:960
 msgid "top color"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:946
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1116
+#: ../gui/wxpython/nviz/tools.py:961
 msgid "bottom color"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:947
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1117
+#: ../gui/wxpython/nviz/tools.py:962
 msgid "blend"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:948
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1118
+#: ../gui/wxpython/nviz/tools.py:963
 msgid "shaded"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:960
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1130
+#: ../gui/wxpython/nviz/tools.py:975
 msgid "Horizontal X:"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:975
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1145
+#: ../gui/wxpython/nviz/tools.py:977
+msgid "Sets the X coordinate of the current cutting plane"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:991
 msgid "Horizontal Y:"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:991
-#: ../gui/wxpython/gui_modules/gdialogs.py:810
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1161
-#: ../gui/wxpython/gui_core/dialogs.py:814
+#: ../gui/wxpython/nviz/tools.py:993
+msgid "Sets the Y coordinate of the current cutting plane"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1008
+#: ../gui/wxpython/mapwin/decorations.py:348
 msgid "Rotation:"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1006
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1176
-msgid "Tilt:"
+#: ../gui/wxpython/nviz/tools.py:1010
+msgid "Rotates the current cutting plane about vertical axis"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1091
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1261
+#: ../gui/wxpython/nviz/tools.py:1026
+msgid "Rotates the current cutting plane about horizontal axis"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1042
+msgid ""
+"Sets the Z coordinate of the current cutting plane (only meaningful when "
+"tilt is not 0)"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1111
 msgid "Fine resolution:"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1103
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1273
+#: ../gui/wxpython/nviz/tools.py:1123
 msgid "Value:"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1115 ../gui/wxpython/nviz/tools.py:2512
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1285
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2664
+#: ../gui/wxpython/nviz/tools.py:1135 ../gui/wxpython/nviz/tools.py:2572
 msgid "Transparency:"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1181
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1351
+#: ../gui/wxpython/nviz/tools.py:1201
 msgid "Show vector lines"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1191 ../gui/wxpython/nviz/preferences.py:468
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:466
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1361
+#: ../gui/wxpython/nviz/tools.py:1211 ../gui/wxpython/nviz/preferences.py:469
 msgid "Vector lines"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1198
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1368
+#: ../gui/wxpython/nviz/tools.py:1217
 msgid "Line:"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1201
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1371
+#: ../gui/wxpython/nviz/tools.py:1220
 msgid "width:"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1217 ../gui/wxpython/nviz/tools.py:1364
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1387
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1534
+#: ../gui/wxpython/nviz/tools.py:1236 ../gui/wxpython/nviz/tools.py:1387
 msgid "color:"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1233 ../gui/wxpython/nviz/tools.py:1409
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1403
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1579
+#: ../gui/wxpython/nviz/tools.py:1252 ../gui/wxpython/nviz/tools.py:1432
 msgid "use color for thematic mapping"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1235
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1405
+#: ../gui/wxpython/nviz/tools.py:1254
 msgid "use width for thematic mapping"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1248 ../gui/wxpython/nviz/tools.py:1260
-#: ../gui/wxpython/nviz/tools.py:1422 ../gui/wxpython/nviz/tools.py:1431
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1418
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1430
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1592
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1601
+#: ../gui/wxpython/nviz/tools.py:1267 ../gui/wxpython/nviz/tools.py:1279
+#: ../gui/wxpython/nviz/tools.py:1445 ../gui/wxpython/nviz/tools.py:1454
 msgid "Set options..."
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1273
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1443
-#: ../gui/wxpython/gui_modules/vdigit.py:158
-#: ../gui/wxpython/vdigit/preferences.py:125
+#: ../gui/wxpython/nviz/tools.py:1292 ../gui/wxpython/nviz/tools.py:1466
+#: ../gui/wxpython/vdigit/preferences.py:129
 msgid "Display"
 msgstr "Rādīt"
-#: ../gui/wxpython/nviz/tools.py:1278
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1448
+#: ../gui/wxpython/nviz/tools.py:1297 ../gui/wxpython/nviz/tools.py:4848
 msgid "on surface(s):"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1288 ../gui/wxpython/nviz/tools.py:1444
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1458
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1614
+#: ../gui/wxpython/nviz/tools.py:1307 ../gui/wxpython/nviz/tools.py:1474
 msgid "Height above surface:"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1323
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1493
+#: ../gui/wxpython/nviz/tools.py:1343
 msgid "Show vector points"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1332 ../gui/wxpython/nviz/preferences.py:508
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:506
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1502
+#: ../gui/wxpython/nviz/tools.py:1352 ../gui/wxpython/nviz/preferences.py:509
 msgid "Vector points"
 msgstr "Vektoru punktus"
-#: ../gui/wxpython/nviz/tools.py:1343
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1513
+#: ../gui/wxpython/nviz/tools.py:1359
 msgid "Icon:"
 msgstr "Ikona:"
-#: ../gui/wxpython/nviz/tools.py:1411
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1581
+#: ../gui/wxpython/nviz/tools.py:1434
 msgid "use size for thematic mapping"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1441
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1611
-msgid "Display on surface(s):"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1498
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1668
-msgid "3D raster map"
-msgstr "3D rastra karte"
-#: ../gui/wxpython/nviz/tools.py:1531
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1701
+#: ../gui/wxpython/nviz/tools.py:1562
 msgid "isosurfaces"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1532
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1702
+#: ../gui/wxpython/nviz/tools.py:1563
 msgid "slices"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1555
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1725
+#: ../gui/wxpython/nviz/tools.py:1586
 msgid "Resolution:"
 msgstr "Izšķirtspēja:"
-#: ../gui/wxpython/nviz/tools.py:1569
+#: ../gui/wxpython/nviz/tools.py:1600
 msgid "Draw wire box"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1585 ../gui/wxpython/nviz/tools.py:3657
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1747
-#: ../gui/wxpython/gui_modules/nviz_tools.py:3809
+#: ../gui/wxpython/nviz/tools.py:1616 ../gui/wxpython/nviz/tools.py:3754
 msgid "List of isosurfaces"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1701
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1863
+#: ../gui/wxpython/nviz/tools.py:1732
 msgid "Show light model"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1714
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1876
+#: ../gui/wxpython/nviz/tools.py:1745
 msgid "Light source position"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1753
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1915
+#: ../gui/wxpython/nviz/tools.py:1761
+msgid "Adjusts the light height"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1785
 msgid "Light color and intensity"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1767 ../gui/wxpython/nviz/preferences.py:306
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:304
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1929
+#: ../gui/wxpython/nviz/tools.py:1799 ../gui/wxpython/nviz/preferences.py:307
 msgid "Brightness:"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1777 ../gui/wxpython/nviz/preferences.py:320
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:318
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1939
+#: ../gui/wxpython/nviz/tools.py:1801
+msgid "Adjusts the brightness of the light"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1810 ../gui/wxpython/nviz/preferences.py:321
 msgid "Ambient:"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1839
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2001
+#: ../gui/wxpython/nviz/tools.py:1812
+msgid "Adjusts the ambient light"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1873
 msgid "Edges with fringe"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1841
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2003
+#: ../gui/wxpython/nviz/tools.py:1875
 msgid "N && W"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1842
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2004
+#: ../gui/wxpython/nviz/tools.py:1876
 msgid "N && E"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1843
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2005
+#: ../gui/wxpython/nviz/tools.py:1877
 msgid "S && W"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1844
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2006
+#: ../gui/wxpython/nviz/tools.py:1878
 msgid "S && E"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1858
-#: ../gui/wxpython/gui_modules/gselect.py:1100
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2020
-#: ../gui/wxpython/gui_core/gselect.py:1109
-#: ../gui/wxpython/gui_core/toolbars.py:77
+#: ../gui/wxpython/nviz/tools.py:1892 ../gui/wxpython/iscatt/toolbars.py:44
+#: ../gui/wxpython/iscatt/toolbars.py:135
+#: ../gui/wxpython/gui_core/toolbars.py:84
+#: ../gui/wxpython/gui_core/widgets.py:986 ../gui/wxpython/vnet/dialogs.py:867
 msgid "Settings"
 msgstr "Iestatījumi"
-#: ../gui/wxpython/nviz/tools.py:1864
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2026
+#: ../gui/wxpython/nviz/tools.py:1898
 msgid "Elevation of fringe from bottom:"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1917
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2079
+#: ../gui/wxpython/nviz/tools.py:1951
 msgid "Arrow length (in map units):"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1927
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2089
+#: ../gui/wxpython/nviz/tools.py:1961
 msgid "Arrow color:"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1936
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2098
+#: ../gui/wxpython/nviz/tools.py:1970
 msgid "Place arrow"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1962
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2121
+#: ../gui/wxpython/nviz/tools.py:1996
 msgid "Scale bar length (in map units):"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1972
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2131
+#: ../gui/wxpython/nviz/tools.py:2006
 msgid "Scale bar color:"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1981
+#: ../gui/wxpython/nviz/tools.py:2015
 msgid "Place new scale bar"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2027
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2179
+#: ../gui/wxpython/nviz/tools.py:2087
 msgid "Do you want to record new animation without saving the previous one?"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2030
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2182
+#: ../gui/wxpython/nviz/tools.py:2090
 msgid "Animation already axists"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2192
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2344
+#: ../gui/wxpython/nviz/tools.py:2252
 msgid "No file prefix given."
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2196
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2348
+#: ../gui/wxpython/nviz/tools.py:2256
 #, python-format
 msgid "Directory %s does not exist."
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2215 ../gui/wxpython/nviz/tools.py:2260
-#: ../gui/wxpython/nviz/tools.py:4468 ../gui/wxpython/nviz/mapwindow.py:2160
-#: ../gui/wxpython/nviz/mapwindow.py:2178
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2367
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2412
-#: ../gui/wxpython/gui_modules/nviz_tools.py:4582
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:2138
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:2156
+#: ../gui/wxpython/nviz/tools.py:2275 ../gui/wxpython/nviz/tools.py:2320
+#: ../gui/wxpython/nviz/tools.py:4579 ../gui/wxpython/nviz/mapwindow.py:2214
+#: ../gui/wxpython/nviz/mapwindow.py:2232
 msgid "constant#"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2326
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2478
+#: ../gui/wxpython/nviz/tools.py:2386
 msgid "Isosurface attributes"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2332
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2484
+#: ../gui/wxpython/nviz/tools.py:2392
 msgid "toggle normal direction"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2338
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2490
+#: ../gui/wxpython/nviz/tools.py:2398
 msgid "Isosurface value"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2441
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2593
+#: ../gui/wxpython/nviz/tools.py:2501
 msgid "Slice attributes"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2447
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2599
+#: ../gui/wxpython/nviz/tools.py:2507
 msgid "Slice parallel to axis:"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2578
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2730
+#: ../gui/wxpython/nviz/tools.py:2640
 msgid "W"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2579
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2731
+#: ../gui/wxpython/nviz/tools.py:2641
 msgid "N"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2580
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2732
+#: ../gui/wxpython/nviz/tools.py:2642
 msgid "S"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2581
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2733
+#: ../gui/wxpython/nviz/tools.py:2643
 msgid "E"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2582
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2734
+#: ../gui/wxpython/nviz/tools.py:2644
 msgid "NW"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2583
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2735
+#: ../gui/wxpython/nviz/tools.py:2645
 msgid "NE"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2584
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2736
+#: ../gui/wxpython/nviz/tools.py:2646
 msgid "SE"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2585
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2737
+#: ../gui/wxpython/nviz/tools.py:2647
 msgid "SW"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:3067 ../gui/wxpython/nviz/tools.py:3855
-#: ../gui/wxpython/nviz/tools.py:3857 ../gui/wxpython/nviz/tools.py:4813
-#: ../gui/wxpython/gui_modules/nviz_tools.py:3219
-#: ../gui/wxpython/gui_modules/nviz_tools.py:3996
-#: ../gui/wxpython/gui_modules/nviz_tools.py:3998
-#: ../gui/wxpython/gui_modules/nviz_tools.py:4925
+#: ../gui/wxpython/nviz/tools.py:3136 ../gui/wxpython/nviz/tools.py:4905
 msgid "Level"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:3663
-#: ../gui/wxpython/gui_modules/nviz_tools.py:3815
+#: ../gui/wxpython/nviz/tools.py:3760
 msgid "List of slices"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:3864 ../gui/wxpython/nviz/tools.py:3866
-#: ../gui/wxpython/nviz/tools.py:4143 ../gui/wxpython/nviz/tools.py:4826
-#: ../gui/wxpython/gui_modules/nviz_tools.py:4005
-#: ../gui/wxpython/gui_modules/nviz_tools.py:4007
-#: ../gui/wxpython/gui_modules/nviz_tools.py:4284
-#: ../gui/wxpython/gui_modules/nviz_tools.py:4937
+#: ../gui/wxpython/nviz/tools.py:3952 ../gui/wxpython/nviz/tools.py:3954
+#, python-brace-format
+msgid "Level {level}"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:3961 ../gui/wxpython/nviz/tools.py:3963
+msgid "Slice parallel to {axis}"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4240 ../gui/wxpython/nviz/tools.py:4918
 msgid "Slice parallel to"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4348
+#: ../gui/wxpython/nviz/tools.py:4450
 #, python-format
 msgid "Scalebar %d"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4474
-#: ../gui/wxpython/gui_modules/nviz_tools.py:4588
+#: ../gui/wxpython/nviz/tools.py:4585
 msgid "None"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4664
-#: ../gui/wxpython/gui_modules/nviz_tools.py:4778
+#: ../gui/wxpython/nviz/tools.py:4747
 msgid "Vector map is 3D"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4667
-#: ../gui/wxpython/gui_modules/nviz_tools.py:4781
+#: ../gui/wxpython/nviz/tools.py:4750
 msgid "Vector map is 2D"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4669
-#: ../gui/wxpython/gui_modules/nviz_tools.py:4783
+#: ../gui/wxpython/nviz/tools.py:4752
 #, python-format
 msgid "%(features)d features (%(points)d points)"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4846
-#: ../gui/wxpython/gui_modules/nviz_tools.py:4956
+#: ../gui/wxpython/nviz/tools.py:4848
+msgid "as 3D"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4850
+#, fuzzy
+msgid "on surface"
+msgstr "Virsma"
+#: ../gui/wxpython/nviz/tools.py:4938
 msgid "range:"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4914 ../gui/wxpython/nviz/tools.py:4925
-#: ../gui/wxpython/gui_modules/nviz_tools.py:5024
-#: ../gui/wxpython/gui_modules/nviz_tools.py:5035
+#: ../gui/wxpython/nviz/tools.py:5006 ../gui/wxpython/nviz/tools.py:5017
 msgid "North edge:"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4915 ../gui/wxpython/nviz/tools.py:4926
-#: ../gui/wxpython/gui_modules/nviz_tools.py:5025
-#: ../gui/wxpython/gui_modules/nviz_tools.py:5036
+#: ../gui/wxpython/nviz/tools.py:5007 ../gui/wxpython/nviz/tools.py:5018
 msgid "South edge:"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4916 ../gui/wxpython/nviz/tools.py:4923
-#: ../gui/wxpython/nviz/tools.py:4932
-#: ../gui/wxpython/gui_modules/nviz_tools.py:5026
-#: ../gui/wxpython/gui_modules/nviz_tools.py:5033
-#: ../gui/wxpython/gui_modules/nviz_tools.py:5042
+#: ../gui/wxpython/nviz/tools.py:5008 ../gui/wxpython/nviz/tools.py:5015
+#: ../gui/wxpython/nviz/tools.py:5024
 msgid "West edge:"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4917 ../gui/wxpython/nviz/tools.py:4924
-#: ../gui/wxpython/nviz/tools.py:4933
-#: ../gui/wxpython/gui_modules/nviz_tools.py:5027
-#: ../gui/wxpython/gui_modules/nviz_tools.py:5034
-#: ../gui/wxpython/gui_modules/nviz_tools.py:5043
+#: ../gui/wxpython/nviz/tools.py:5009 ../gui/wxpython/nviz/tools.py:5016
+#: ../gui/wxpython/nviz/tools.py:5025
 msgid "East edge:"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4919 ../gui/wxpython/nviz/tools.py:4930
-#: ../gui/wxpython/nviz/tools.py:4938
-#: ../gui/wxpython/gui_modules/nviz_tools.py:5029
-#: ../gui/wxpython/gui_modules/nviz_tools.py:5040
-#: ../gui/wxpython/gui_modules/nviz_tools.py:5048
+#: ../gui/wxpython/nviz/tools.py:5011 ../gui/wxpython/nviz/tools.py:5022
+#: ../gui/wxpython/nviz/tools.py:5030
 msgid "Northing (Y):"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4920 ../gui/wxpython/nviz/tools.py:4929
-#: ../gui/wxpython/nviz/tools.py:4939
-#: ../gui/wxpython/gui_modules/nviz_tools.py:5030
-#: ../gui/wxpython/gui_modules/nviz_tools.py:5039
-#: ../gui/wxpython/gui_modules/nviz_tools.py:5049
+#: ../gui/wxpython/nviz/tools.py:5012 ../gui/wxpython/nviz/tools.py:5021
+#: ../gui/wxpython/nviz/tools.py:5031
 msgid "Height (Z):"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4921 ../gui/wxpython/nviz/tools.py:4928
-#: ../gui/wxpython/nviz/tools.py:4937
-#: ../gui/wxpython/gui_modules/nviz_tools.py:5031
-#: ../gui/wxpython/gui_modules/nviz_tools.py:5038
-#: ../gui/wxpython/gui_modules/nviz_tools.py:5047
+#: ../gui/wxpython/nviz/tools.py:5013 ../gui/wxpython/nviz/tools.py:5020
+#: ../gui/wxpython/nviz/tools.py:5029
 msgid "Easting (X):"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4934
-#: ../gui/wxpython/gui_modules/nviz_tools.py:5044
+#: ../gui/wxpython/nviz/tools.py:5026
 msgid "Bottom edge:"
 msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4935
-#: ../gui/wxpython/gui_modules/nviz_tools.py:5045
+#: ../gui/wxpython/nviz/tools.py:5027
 msgid "Top edge:"
 msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:504
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:509
+#: ../gui/wxpython/nviz/tools.py:5132
+msgid "Adjusts the distance and direction of the image viewpoint"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:5164
+msgid ""
+"Adjusts the light direction. Click and drag the puck to change the light "
+"direction."
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:224
+msgid ""
+"Opening 3D view was not successful. Please try to change the value of depth "
+"buffer in GUI Settings dialog > tab Map Display > Advanced and restart GUI."
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:559
 #, python-format
 msgid ""
 "Image is too large, your OpenGL implementation supports maximum texture size "
 "%d px."
 msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1018
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1006
+#: ../gui/wxpython/nviz/mapwindow.py:1057
 msgid "Easting"
 msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1019
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1007
+#: ../gui/wxpython/nviz/mapwindow.py:1058
 msgid "Northing"
 msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1020
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1008
+#: ../gui/wxpython/nviz/mapwindow.py:1059
 msgid "Elevation"
 msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1027
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1015
+#: ../gui/wxpython/nviz/mapwindow.py:1065
 msgid "Surface map name"
 msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1028
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1016
+#: ../gui/wxpython/nviz/mapwindow.py:1066
 msgid "Surface map elevation"
 msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1029
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1017
+#: ../gui/wxpython/nviz/mapwindow.py:1067
 msgid "Surface map color"
 msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1038
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1026
+#: ../gui/wxpython/nviz/mapwindow.py:1076
 msgid "XY distance from previous"
 msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1039
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1027
+#: ../gui/wxpython/nviz/mapwindow.py:1077
 msgid "XYZ distance from previous"
 msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1040
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1028
+#: ../gui/wxpython/nviz/mapwindow.py:1078
 msgid "Distance along surface"
 msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1045
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1033
+#: ../gui/wxpython/nviz/mapwindow.py:1083
 msgid "Distance along exag. surface"
 msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1052
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1040
+#: ../gui/wxpython/nviz/mapwindow.py:1090
 msgid "No point on surface"
 msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1502
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1491
+#: ../gui/wxpython/nviz/mapwindow.py:1547
 msgid "Loading raster map"
 msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1506
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1495
+#: ../gui/wxpython/nviz/mapwindow.py:1551
 msgid "Loading 3d raster map"
 msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1512
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1501
+#: ../gui/wxpython/nviz/mapwindow.py:1557
 msgid "failed"
 msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1514
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1503
+#: ../gui/wxpython/nviz/mapwindow.py:1559
 #, python-format
 msgid "Unsupported layer type '%s'"
 msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1623
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1612
+#: ../gui/wxpython/nviz/mapwindow.py:1671
 msgid "Unable to unload raster map"
 msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1628
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1617
+#: ../gui/wxpython/nviz/mapwindow.py:1676
 msgid "Unable to unload 3d raster map"
 msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1629
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1618
+#: ../gui/wxpython/nviz/mapwindow.py:1677
 msgid "3d raster map"
 msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1639
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1628
+#: ../gui/wxpython/nviz/mapwindow.py:1687
 msgid "unloaded successfully"
 msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1691
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1680
+#: ../gui/wxpython/nviz/mapwindow.py:1739
 #, python-format
 msgid "Loading vector map <%(name)s> (%(type)s) failed"
 msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1750
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1739
+#: ../gui/wxpython/nviz/mapwindow.py:1798
 #, python-format
 msgid "Unable to unload vector map <%(name)s> (%(type)s)"
 msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1753
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1742
+#: ../gui/wxpython/nviz/mapwindow.py:1801
 #, python-format
 msgid "Vector map <%(name)s> (%(type)s) unloaded successfully"
 msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:2104
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:2082
+#: ../gui/wxpython/nviz/mapwindow.py:2154
 #, python-format
 msgid "Vector point layer not found (id = %d)"
 msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:2106
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:2084
+#: ../gui/wxpython/nviz/mapwindow.py:2156
 #, python-format
 msgid "Unable to set data layer properties (id = %d)"
 msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:2109
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:2087
+#: ../gui/wxpython/nviz/mapwindow.py:2159
 #, python-format
 msgid ""
 "Setting data layer properties failed.\n"
@@ -8884,104 +9001,83 @@
 "%s"
 msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:2235
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:2213
-msgid "At least one raster map required"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:31
+#: ../gui/wxpython/nviz/preferences.py:32
 #, fuzzy
-msgid "3D view settings"
+msgid "3D view default settings"
 msgstr "Mainīt iestatījumus"
-#: ../gui/wxpython/nviz/preferences.py:48
+#: ../gui/wxpython/nviz/preferences.py:49
 msgid "Revert settings to default, changes are not applied"
 msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:71
-#: ../gui/wxpython/nviz/preferences.py:134
-#: ../gui/wxpython/nviz/preferences.py:152
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:69
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:132
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:150
+#: ../gui/wxpython/nviz/preferences.py:72
+#: ../gui/wxpython/nviz/preferences.py:135
+#: ../gui/wxpython/nviz/preferences.py:153
 msgid "value:"
 msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:83
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:81
+#: ../gui/wxpython/nviz/preferences.py:84
 msgid "step:"
 msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:98
-#: ../gui/wxpython/nviz/preferences.py:265
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:96
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:263
+#: ../gui/wxpython/nviz/preferences.py:99
+#: ../gui/wxpython/nviz/preferences.py:266
 msgid "Position:"
 msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:101
-#: ../gui/wxpython/nviz/preferences.py:268
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:99
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:266
+#: ../gui/wxpython/nviz/preferences.py:102
+#: ../gui/wxpython/nviz/preferences.py:269
 msgid "x:"
 msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:204
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:202
+#: ../gui/wxpython/nviz/preferences.py:132
+msgid "Twist:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:205
 msgid "Fly-through"
 msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:208
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:206
-#: ../gui/wxpython/mapdisp/toolbars.py:58
+#: ../gui/wxpython/nviz/preferences.py:209
+#: ../gui/wxpython/mapdisp/toolbars.py:61
 msgid "Fly-through mode"
 msgstr ""
 #: ../gui/wxpython/nviz/preferences.py:215
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:213
 msgid "Move exag:"
 msgstr ""
 #: ../gui/wxpython/nviz/preferences.py:227
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:225
 msgid "Turn exag:"
 msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:257
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:255
+#: ../gui/wxpython/nviz/preferences.py:258
 msgid "Light"
 msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:292
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:290
+#: ../gui/wxpython/nviz/preferences.py:293
 msgid "z:"
 msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:436
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:434
+#: ../gui/wxpython/nviz/preferences.py:437
 msgid "wire color:"
 msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:515
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:513
+#: ../gui/wxpython/nviz/preferences.py:516
+#: ../gui/wxpython/mapswipe/dialogs.py:283
 msgid "Size:"
 msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:530
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:528
+#: ../gui/wxpython/nviz/preferences.py:531
 msgid "Marker:"
 msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:628
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:626
+#: ../gui/wxpython/nviz/preferences.py:629
 #, python-format
 msgid "3D view settings saved to file <%s>."
 msgstr ""
-#: ../gui/wxpython/nviz/wxnviz.py:32 ../gui/wxpython/gui_modules/wxplot.py:43
-#: ../gui/wxpython/wxplot/profile.py:31
+#: ../gui/wxpython/nviz/wxnviz.py:32 ../gui/wxpython/wxplot/profile.py:34
 msgid ""
 "This module requires the NumPy module, which could not be imported. It "
 "probably is not installed (it's not part of the standard Python "
@@ -8989,2093 +9085,2531 @@
 "information on downloading source or binaries."
 msgstr ""
-#: ../gui/wxpython/nviz/wxnviz.py:50 ../gui/wxpython/gui_modules/wxnviz.py:41
+#: ../gui/wxpython/nviz/wxnviz.py:329 ../gui/wxpython/nviz/wxnviz.py:340
+#: ../gui/wxpython/mapswipe/g.gui.mapswipe.py:82
+#: ../gui/wxpython/iclass/g.gui.iclass.py:86
+#: ../gui/wxpython/modules/histogram.py:349
 #, python-format
-msgid "3D view mode: %s\n"
-msgstr ""
-#: ../gui/wxpython/nviz/wxnviz.py:326 ../gui/wxpython/nviz/wxnviz.py:337
-#: ../gui/wxpython/gui_modules/histogram.py:333
-#: ../gui/wxpython/gui_modules/wxnviz.py:313
-#: ../gui/wxpython/gui_modules/wxnviz.py:324
-#: ../gui/wxpython/modules/histogram.py:343
-#, python-format
 msgid "Raster map <%s> not found"
 msgstr ""
-#: ../gui/wxpython/nviz/wxnviz.py:414
-#: ../gui/wxpython/gui_modules/wxnviz.py:401
+#: ../gui/wxpython/nviz/wxnviz.py:417 ../gui/wxpython/dbmgr/g.gui.dbmgr.py:49
+#: ../gui/wxpython/iclass/g.gui.iclass.py:91
 #, python-format
 msgid "Vector map <%s> not found"
 msgstr ""
-#: ../gui/wxpython/nviz/wxnviz.py:479 ../gui/wxpython/nviz/wxnviz.py:491
-#: ../gui/wxpython/gui_modules/wxnviz.py:466
-#: ../gui/wxpython/gui_modules/wxnviz.py:478
+#: ../gui/wxpython/nviz/wxnviz.py:482 ../gui/wxpython/nviz/wxnviz.py:494
 #, python-format
 msgid "3d raster map <%s> not found"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm_base.py:43
-#: ../gui/wxpython/gui_modules/dbm.py:293 ../gui/wxpython/dbmgr/manager.py:297
-#: ../gui/wxpython/dbmgr/vinfo.py:42
-msgid "Unable to decode value. Set encoding in GUI preferences ('Attributes')."
+#: ../gui/wxpython/iscatt/iscatt_core.py:107
+#: ../gui/wxpython/iscatt/iscatt_core.py:157
+msgid "Select category for editing."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gselect.py:324
-#: ../gui/wxpython/gui_core/gselect.py:325
-msgid "Not selectable element"
+#: ../gui/wxpython/iscatt/iscatt_core.py:148
+msgid "Computing of scatter plots failed."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gselect.py:345
-#: ../gui/wxpython/gui_modules/preferences.py:2506
-#: ../gui/wxpython/gui_core/gselect.py:346
-#: ../gui/wxpython/gui_core/preferences.py:1703
-msgid "Mapset"
-msgstr "Karšu kopa"
+#: ../gui/wxpython/iscatt/iscatt_core.py:286
+msgid "Patching category raster conditions file failed."
+msgstr ""
-#: ../gui/wxpython/gui_modules/gselect.py:369
-#: ../gui/wxpython/gui_core/gselect.py:370
+#: ../gui/wxpython/iscatt/iscatt_core.py:310
 #, python-format
-msgid "GSelect: invalid item: %s"
+msgid ""
+"v.build failed:\n"
+"%s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gselect.py:881
-#: ../gui/wxpython/gui_core/gselect.py:880 ../gui/wxpython/gis_set.py:677
-msgid "Choose GIS Data Directory"
-msgstr "Izvēlieties ĢIS datu mapi"
-#: ../gui/wxpython/gui_modules/gselect.py:1104
-#: ../gui/wxpython/gui_core/gselect.py:1113
-msgid "Output settings"
+#: ../gui/wxpython/iscatt/iscatt_core.py:328
+#, python-format
+msgid ""
+"v.to.rast failed:\n"
+"%s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gselect.py:1106
-#: ../gui/wxpython/gui_core/gselect.py:1115
-msgid "Source settings"
+#: ../gui/wxpython/iscatt/core_c.py:23
+msgid "Loading ctypes libs failed"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gselect.py:1117
-#: ../gui/wxpython/gui_core/gselect.py:1131
-msgid "Native"
+#: ../gui/wxpython/iscatt/toolbars.py:43 ../gui/wxpython/iclass/toolbars.py:37
+#: ../gui/wxpython/iclass/dialogs.py:42
+msgid "Select imagery group"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gselect.py:1121
-#: ../gui/wxpython/gui_modules/menuform.py:1366
-#: ../gui/wxpython/gui_core/gselect.py:1135
-#: ../gui/wxpython/gui_core/forms.py:1350
-msgid "File"
-msgstr "Fails"
+#: ../gui/wxpython/iscatt/toolbars.py:46
+#: ../gui/wxpython/gui_core/toolbars.py:71
+#: ../gui/wxpython/vnet/toolbars.py:121
+msgid "Show manual"
+msgstr "Rādīt pamācību"
-#: ../gui/wxpython/gui_modules/gselect.py:1125
-#: ../gui/wxpython/gui_modules/menuform.py:1421
-#: ../gui/wxpython/gui_core/gselect.py:1139
-#: ../gui/wxpython/gui_core/forms.py:1406
-msgid "Directory"
-msgstr "Mape"
+#: ../gui/wxpython/iscatt/toolbars.py:48
+#, fuzzy
+msgid "Add scatter plot"
+msgstr "Pievienot rastru"
-#: ../gui/wxpython/gui_modules/gselect.py:1129
-#: ../gui/wxpython/gui_modules/dbm.py:2288
-#: ../gui/wxpython/gui_modules/dbm.py:2414
-#: ../gui/wxpython/gui_modules/dbm.py:2666
-#: ../gui/wxpython/gui_core/gselect.py:1143
-#: ../gui/wxpython/dbmgr/manager.py:2314 ../gui/wxpython/dbmgr/manager.py:2438
-#: ../gui/wxpython/dbmgr/manager.py:2692
-msgid "Database"
-msgstr "Datubāze"
-#: ../gui/wxpython/gui_modules/gselect.py:1133
-#: ../gui/wxpython/gui_core/gselect.py:1147
-msgid "Protocol"
-msgstr "Protokols"
-#: ../gui/wxpython/gui_modules/gselect.py:1152
-#: ../gui/wxpython/gui_core/gselect.py:1173
-msgid "Output type"
+#: ../gui/wxpython/iscatt/toolbars.py:50
+msgid "Select area with polygon"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gselect.py:1154
-#: ../gui/wxpython/gui_core/gselect.py:1175
-msgid "Source type"
+#: ../gui/wxpython/iscatt/toolbars.py:52
+msgid "Pan mode for scatter plots"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gselect.py:1162
-#: ../gui/wxpython/gui_modules/gselect.py:1165
-#: ../gui/wxpython/gui_modules/gselect.py:1452
-#: ../gui/wxpython/gui_modules/gselect.py:1454
-#: ../gui/wxpython/gui_modules/gselect.py:1636
-#: ../gui/wxpython/gui_modules/gselect.py:1638
-#: ../gui/wxpython/gui_core/gselect.py:1183
-#: ../gui/wxpython/gui_core/gselect.py:1186
-#: ../gui/wxpython/gui_core/gselect.py:1520
-#: ../gui/wxpython/gui_core/gselect.py:1522
-#: ../gui/wxpython/gui_core/gselect.py:1718
-#: ../gui/wxpython/gui_core/gselect.py:1720
-msgid "All files"
-msgstr "Visi faili"
-#: ../gui/wxpython/gui_modules/gselect.py:1169
-#: ../gui/wxpython/gui_modules/gselect.py:1458
-#: ../gui/wxpython/gui_core/gselect.py:1190
-#: ../gui/wxpython/gui_core/gselect.py:1526
-msgid "Choose file to import"
+#: ../gui/wxpython/iscatt/toolbars.py:54
+msgid "Zoom mode for scatter plots (left mouse button, wheel)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gselect.py:1178
-#: ../gui/wxpython/gui_core/gselect.py:1199
-msgid "Choose input directory"
+#: ../gui/wxpython/iscatt/toolbars.py:56
+msgid ""
+"Zoom to scatter plot data extend mode (click on scatter plot for zooming to "
+"extend)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gselect.py:1187
-#: ../gui/wxpython/gui_modules/gselect.py:1642
-#: ../gui/wxpython/gui_core/gselect.py:1208
-#: ../gui/wxpython/gui_core/gselect.py:1724
-msgid "Choose file"
-msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:58
+#, fuzzy
+msgid "Show/hide class manager"
+msgstr "Ziemeļu bulta"
-#: ../gui/wxpython/gui_modules/gselect.py:1221
-#: ../gui/wxpython/gui_core/gselect.py:1242
-msgid "File:"
-msgstr "Fails:"
+#: ../gui/wxpython/iscatt/toolbars.py:162
+#: ../gui/wxpython/iscatt/toolbars.py:163
+#, fuzzy
+msgid "Include selected area to class"
+msgstr "Vaicājums izvēlētajai rastra/vektoru kartei"
-#: ../gui/wxpython/gui_modules/gselect.py:1230
-#: ../gui/wxpython/gui_core/gselect.py:1251
-msgid "Protocol:"
-msgstr "Protokols:"
+#: ../gui/wxpython/iscatt/toolbars.py:165
+#: ../gui/wxpython/iscatt/toolbars.py:166
+msgid "Exclude selected area from class"
+msgstr ""
-#: ../gui/wxpython/gui_modules/gselect.py:1257
-#: ../gui/wxpython/gui_core/gselect.py:1281
-msgid "Extension:"
-msgstr "Paplašinājums:"
+#: ../gui/wxpython/iscatt/toolbars.py:168
+msgid "Add new vertex"
+msgstr "Pievienot virsotni"
-#: ../gui/wxpython/gui_modules/gselect.py:1285
-#: ../gui/wxpython/gui_core/gselect.py:1309
-msgid "Load settings:"
+#: ../gui/wxpython/iscatt/toolbars.py:169
+msgid "Add new vertex to polygon boundary scatter plot"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gselect.py:1303
-#: ../gui/wxpython/gui_core/gselect.py:1330
-msgid "Format:"
-msgstr "Formāts:"
+#: ../gui/wxpython/iscatt/toolbars.py:171
+#, fuzzy
+msgid "Create selection polygon"
+msgstr "Izveidot jaunu novietojumu?"
-#: ../gui/wxpython/gui_modules/gselect.py:1325
-#: ../gui/wxpython/gui_core/gselect.py:1352
-msgid "Creation options:"
+#: ../gui/wxpython/iscatt/toolbars.py:172
+msgid "Add new vertex between last and first points of the boundary"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gselect.py:1362
-#: ../gui/wxpython/gui_core/gselect.py:1389
-#, python-format
-msgid "Settings <%s> not found"
-msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:174
+msgid "Move vertex"
+msgstr "Pārvietot virsotni"
-#: ../gui/wxpython/gui_modules/gselect.py:1374
-#: ../gui/wxpython/gui_core/gselect.py:1401
-#: ../gui/wxpython/gui_core/gselect.py:1422
-msgid "Save settings"
-msgstr "Saglabāt iestatījumus"
+#: ../gui/wxpython/iscatt/toolbars.py:175
+#, fuzzy
+msgid "Move boundary vertex"
-#: ../gui/wxpython/gui_modules/gselect.py:1380
-#: ../gui/wxpython/gui_core/gselect.py:1408
-msgid "Name not given, settings is not saved."
-msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:177
+msgid "Remove vertex"
+msgstr "Dzēst virsotni"
-#: ../gui/wxpython/gui_modules/gselect.py:1392
-#: ../gui/wxpython/gui_core/gselect.py:1461
-msgid "Unable to save settings"
-msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:178
+#, fuzzy
+msgid "Remove boundary vertex"
-#: ../gui/wxpython/gui_modules/gselect.py:1810
-#: ../gui/wxpython/gui_core/gselect.py:1885
-msgid "LineString"
+#: ../gui/wxpython/iscatt/toolbars.py:180
+msgid "Remove polygon (click on scatter plot for removing it's polygon)"
 msgstr ""
-msgid "Polygon"
-msgstr "Poligons"
+#: ../gui/wxpython/iscatt/toolbars.py:257
+#, fuzzy
+msgid "Add class"
+msgstr "Pievienot slāni"
-#: ../gui/wxpython/gui_modules/gselect.py:1818
-#: ../gui/wxpython/gui_core/gselect.py:1893
-msgid "Feature type:"
-msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:259
+#, fuzzy
+msgid "Remove selected class"
+msgstr "Pārsaukt izvēlēto karšu kopu"
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:357
-#: ../gui/wxpython/mapdisp/statusbar.py:357
-msgid "Render"
-msgstr "Zīmēt"
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:363
-#: ../gui/wxpython/mapdisp/statusbar.py:363
-msgid "Enable/disable auto-rendering"
+#: ../gui/wxpython/iscatt/dialogs.py:38
+msgid "Add scatter plots"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:385
-#: ../gui/wxpython/mapdisp/statusbar.py:385
-msgid "Show comp. extent"
+#: ../gui/wxpython/iscatt/dialogs.py:56
+msgid "x axis:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:388
-#: ../gui/wxpython/mapdisp/statusbar.py:388
-msgid "Show computational extent"
+#: ../gui/wxpython/iscatt/dialogs.py:62
+msgid "y axis:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:392
-#: ../gui/wxpython/mapdisp/statusbar.py:392
-msgid ""
-"Show/hide computational region extent (set with g.region). Display region "
-"drawn as a blue box inside the computational region, computational region "
-"inside a display region as a red box)."
+#: ../gui/wxpython/iscatt/dialogs.py:97
+msgid "Bands of scatter plots to be added (x y):"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:432
-#: ../gui/wxpython/mapdisp/statusbar.py:432
-msgid "Display mode"
-msgstr "Ekrāna režīms"
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:435
-#: ../gui/wxpython/gui_modules/preferences.py:1649
-#: ../gui/wxpython/gui_core/preferences.py:684
-#: ../gui/wxpython/mapdisp/statusbar.py:435
-msgid "Align region extent based on display size"
+#: ../gui/wxpython/iscatt/dialogs.py:135
+msgid "No scatter plots selected."
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:439
-#: ../gui/wxpython/mapdisp/statusbar.py:439
-msgid ""
-"Align region extent based on display size from center point. Default value "
-"for new map displays can be set up in 'User GUI settings' dialog."
+#: ../gui/wxpython/iscatt/dialogs.py:183
+msgid "Select both x and y bands."
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:452
-#: ../gui/wxpython/mapdisp/statusbar.py:452
-msgid "Display resolution"
+#: ../gui/wxpython/iscatt/dialogs.py:186
+msgid "Selected bands must be different."
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:455
-#: ../gui/wxpython/gui_modules/preferences.py:1662
-#: ../gui/wxpython/gui_core/preferences.py:697
-#: ../gui/wxpython/mapdisp/statusbar.py:455
-msgid "Constrain display resolution to computational settings"
+#: ../gui/wxpython/iscatt/dialogs.py:191
+msgid ""
+"Scatter plot with same bands combination (regardless x y order) has been "
+"already added into the list."
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:459
-#: ../gui/wxpython/mapdisp/statusbar.py:459
-msgid ""
-"Constrain display resolution to computational region settings. Default value "
+#: ../gui/wxpython/iscatt/dialogs.py:253 ../gui/wxpython/iclass/dialogs.py:708
+msgid "Enter name of new vector map:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:483
-#: ../gui/wxpython/mapdisp/statusbar.py:483
-msgid "Map scale"
-msgstr "Kartes mērogs"
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:497
-#: ../gui/wxpython/mapdisp/statusbar.py:497
-msgid ""
-"As everyone's monitors and resolutions are set differently these values are "
-"not true map scales, but should get you into the right neighborhood."
+#: ../gui/wxpython/iscatt/dialogs.py:292
+#, python-format
+msgid "Raster map <%s> already exists. Do you want to overwrite it?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:550
-#: ../gui/wxpython/mapdisp/statusbar.py:550
-msgid "Go to"
-msgstr "Iet uz"
+#: ../gui/wxpython/iscatt/dialogs.py:294
+#, fuzzy, python-format
+msgid "Raster <%s> exists"
+msgstr "Karšu kopa <%s> jau eksistē."
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:571
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:635
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:808
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:874
-#: ../gui/wxpython/mapdisp/statusbar.py:571
-#: ../gui/wxpython/mapdisp/statusbar.py:635
-#: ../gui/wxpython/mapdisp/statusbar.py:808
-#: ../gui/wxpython/mapdisp/statusbar.py:874
-msgid "Projection not defined (check the settings)"
+#: ../gui/wxpython/iscatt/dialogs.py:317
+msgid "Show confidence ellipses"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:649
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:821
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:904
-#: ../gui/wxpython/mapdisp/statusbar.py:649
-#: ../gui/wxpython/mapdisp/statusbar.py:821
-#: ../gui/wxpython/mapdisp/statusbar.py:904
-msgid "Error in projection (check the settings)"
+#: ../gui/wxpython/iscatt/dialogs.py:323
+msgid "Selection polygon color:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:681
-#: ../gui/wxpython/gui_modules/preferences.py:1989
-#: ../gui/wxpython/gui_core/preferences.py:1164
-#: ../gui/wxpython/mapdisp/statusbar.py:681
-msgid "Projection"
-msgstr "Projekcija"
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:683
-#: ../gui/wxpython/mapdisp/statusbar.py:683
-msgid "Use defined projection"
+#: ../gui/wxpython/iscatt/dialogs.py:324
+msgid "Color of selection polygon vertex:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:695
-#: ../gui/wxpython/mapdisp/statusbar.py:695
-msgid ""
-"Reproject coordinates displayed in the statusbar. Projection can be defined "
-"in GUI preferences dialog (tab 'Projection')"
-msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:325
+#, fuzzy
+msgid "Selected area color:"
+msgstr "Objekta krāsa:"
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:720
-#: ../gui/wxpython/mapdisp/statusbar.py:720
-msgid "MASK"
-msgstr "MASKA"
+#: ../gui/wxpython/iscatt/dialogs.py:338 ../gui/wxpython/vnet/dialogs.py:1165
+#, fuzzy
+msgid "Snapping treshold in pixels:"
+msgstr "Līnijas platums (pikseļos):"
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:763
-#: ../gui/wxpython/mapdisp/statusbar.py:763
-msgid "Display geometry"
+#: ../gui/wxpython/iscatt/dialogs.py:339
+msgid "Selected area opacity:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:779
-#: ../gui/wxpython/mapdisp/statusbar.py:779
-msgid "Coordinates"
-msgstr "Koordinātes"
+#: ../gui/wxpython/iscatt/dialogs.py:371
+#, fuzzy
+msgid "Selection style:"
+msgstr "Izvēlēties fontu"
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:833
-#: ../gui/wxpython/mapdisp/statusbar.py:833
-msgid "Extent"
-msgstr "Apjoms"
+#: ../gui/wxpython/iscatt/dialogs.py:393
+#, fuzzy
+msgid "Ellipses settings:"
+msgstr "Asu iestatījumi"
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:928
-#: ../gui/wxpython/mapdisp/statusbar.py:928
-msgid "Comp. region"
-msgstr "Aprēķinu reģions"
+#: ../gui/wxpython/iscatt/frame.py:129 ../gui/wxpython/iclass/dialogs.py:276
+msgid "Classes"
+msgstr "Klases"
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:977
-#: ../gui/wxpython/mapdisp/statusbar.py:977
-msgid "Go to GCP No."
+#: ../gui/wxpython/iscatt/frame.py:146
+msgid "GRASS GIS Interactive Scatter Plot Tool"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:993
-#: ../gui/wxpython/mapdisp/statusbar.py:993
-msgid "Valid Range:"
-msgstr "Derīgs diapazons:"
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:1053
-#: ../gui/wxpython/mapdisp/statusbar.py:1053
-msgid "RMS error"
+#: ../gui/wxpython/iscatt/frame.py:361
+msgid "scatter plot"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:1056
-#: ../gui/wxpython/mapdisp/statusbar.py:1056
-#, python-format
-msgid "Forward: %(forw)s, Backward: %(back)s"
-msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:375 ../gui/wxpython/iclass/dialogs.py:356
+msgid "Class name"
+msgstr "Klašu nosaukumi"
-#: ../gui/wxpython/gui_modules/render.py:128
-#: ../gui/wxpython/core/render.py:126
-#, python-format
-msgid "<%(name)s>: layer type <%(type)s> is not supported"
+#: ../gui/wxpython/iscatt/frame.py:415 ../gui/wxpython/iclass/dialogs.py:389
+msgid "Please use only ASCII characters."
 msgstr ""
-#: ../gui/wxpython/gui_modules/render.py:157
-#: ../gui/wxpython/core/render.py:155
-#, python-format
-msgid "Command '%s' failed\n"
+#: ../gui/wxpython/iscatt/frame.py:440
+msgid "Maximum limit of categories number was reached."
 msgstr ""
-#: ../gui/wxpython/gui_modules/render.py:158
-#: ../gui/wxpython/core/render.py:156
-#, python-format
-msgid "Details: %s\n"
-msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:535
+#, fuzzy
+msgid "Rename class"
+msgstr "Pārsaukt karšu kopu"
-#: ../gui/wxpython/gui_modules/render.py:250
-#: ../gui/wxpython/core/render.py:248
-#, python-format
-msgid "Unsupported map layer type '%s'"
-msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:539
+#, fuzzy
+msgid "Set color"
+msgstr "Līnijas krāsa"
-#: ../gui/wxpython/gui_modules/render.py:413
-#: ../gui/wxpython/core/render.py:399
-msgid "GISBASE not set. You must be in GRASS GIS to run this program."
-msgstr "Nav iestatīts GISBASE parametrs. Šo programmu var darbināt tikai GRASS GIS vidē."
-#: ../gui/wxpython/gui_modules/render.py:426
-#: ../gui/wxpython/gui_modules/mapdisp.py:131
-#: ../gui/wxpython/gui_core/mapdisp.py:109 ../gui/wxpython/core/render.py:412
-#, python-format
-msgid "GRASS module '%s' not found. Unable to start map display window."
+#: ../gui/wxpython/iscatt/frame.py:547
+msgid "Hide"
 msgstr ""
-#: ../gui/wxpython/gui_modules/render.py:458
-#: ../gui/wxpython/core/render.py:444
-#, python-format
-msgid "Error: Unable to open '%(file)s'. Reason: %(ret)s. wxGUI exited.\n"
-msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:549
+#, fuzzy
+msgid "Show"
+msgstr "Rādīt tīklu"
-#: ../gui/wxpython/gui_modules/render.py:568
-#: ../gui/wxpython/mapdisp/main.py:201
-#, python-format
-msgid "Unable to open file '%(file)s' for writting. Details: %(det)s"
+#: ../gui/wxpython/iscatt/frame.py:560
+msgid "Move to top"
 msgstr ""
-#: ../gui/wxpython/gui_modules/render.py:657
-#: ../gui/wxpython/core/render.py:620
-#, python-format
-msgid "Unable to zoom to raster map <%s>."
+#: ../gui/wxpython/iscatt/frame.py:566
+msgid "Move to bottom"
 msgstr ""
-#: ../gui/wxpython/gui_modules/render.py:658
-#: ../gui/wxpython/gui_modules/render.py:661
-#: ../gui/wxpython/gui_modules/gcmd.py:344 ../gui/wxpython/core/render.py:621
-#: ../gui/wxpython/core/render.py:624 ../gui/wxpython/core/gcmd.py:388
-msgid "Details:"
-msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:574
+#, fuzzy
+msgid "Move category up"
+msgstr "Pievienot jaunu kategoriju"
-#: ../gui/wxpython/gui_modules/render.py:660
-#: ../gui/wxpython/core/render.py:623
-#, python-format
-msgid "Unable to zoom to vector map <%s>."
+#: ../gui/wxpython/iscatt/frame.py:580
+msgid "Move category down"
 msgstr ""
-#: ../gui/wxpython/gui_modules/render.py:663
-#: ../gui/wxpython/core/render.py:626
-msgid ""
-"Unable to get current geographic extent. Force quiting wxGUI. Please "
-"manually run g.region to fix the problem."
-msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:588
+#, fuzzy
+msgid "Export class raster"
+msgstr "Eksportēt rastra karti"
-#: ../gui/wxpython/gui_modules/render.py:897
-#: ../gui/wxpython/gui_modules/render.py:926
-#: ../gui/wxpython/mapdisp/main.py:102 ../gui/wxpython/mapdisp/main.py:131
+#: ../gui/wxpython/iscatt/frame.py:660
 #, python-format
-msgid "Unable to read cmdfile '%(cmd)s'. Details: %(det)s"
+msgid "Change opacity of class <%s>"
 msgstr ""
-#: ../gui/wxpython/gui_modules/render.py:1043
-#: ../gui/wxpython/core/render.py:945
-#, python-format
-msgid "ERROR: Rendering failed. Details: %s"
+#: ../gui/wxpython/iscatt/frame.py:682
+msgid "Empty name was inserted."
 msgstr ""
-#: ../gui/wxpython/gui_modules/render.py:1100
-#: ../gui/wxpython/gui_modules/render.py:1193
-#: ../gui/wxpython/core/render.py:1002 ../gui/wxpython/core/render.py:1095
+#: ../gui/wxpython/iscatt/plots.py:42
 #, python-format
-msgid "Unable to render map layer <%s>."
+msgid ""
+"Unable to import matplotlib (try to install it).\n"
+"%s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/render.py:1302
-#, fuzzy, python-format
-msgid "Unable render overlay <%s>."
-msgstr "Jauna vektoru karte"
+#: ../gui/wxpython/iscatt/plots.py:571
+#, fuzzy
+msgid "Zoom to scatter plot extend"
+msgstr "Tuvināt līdz izvēlētajām kartēm"
-#: ../gui/wxpython/gui_modules/render.py:1341
-msgid "Unable render overlay <%s>"
+#: ../gui/wxpython/iscatt/controllers.py:142 ../gui/wxpython/dbmgr/base.py:147
+msgid "Loading data..."
+msgstr "Datu ielāde..."
-#: ../gui/wxpython/gui_modules/workspace.py:1366
-#: ../gui/wxpython/core/workspace.py:1037
-#, python-format
-msgid "Unable to open file <%s> for reading."
-msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:207
+#, fuzzy
+msgid "No data set."
+msgstr "Punktu datu kopa:"
-#: ../gui/wxpython/gui_modules/workspace.py:1379
-#: ../gui/wxpython/core/workspace.py:1050
+#: ../gui/wxpython/iscatt/controllers.py:223
 #, python-format
 msgid ""
-"Some lines were skipped when reading settings from file <%(file)s>.\n"
-"See 'Command output' window for details.\n"
+"Interactive Scatter Plot Tool can not be used.\n"
+"Number of cells (rows*cols) <%d> in current regionis higher than maximum "
+"limit <%d>.\n"
 "\n"
-"Number of skipped lines: %(line)d"
+"You can reduce number of cells in current region using <g.region> command."
 msgstr ""
-#: ../gui/wxpython/gui_modules/workspace.py:1383
-#: ../gui/wxpython/gui_modules/gcmd.py:90
-#: ../gui/wxpython/gui_modules/dbm.py:2366
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:780
-#: ../gui/wxpython/gui_modules/mapdisp_window.py:1856
-#: ../gui/wxpython/wxplot/dialogs.py:781
-#: ../gui/wxpython/core/workspace.py:1054 ../gui/wxpython/core/gcmd.py:134
-#: ../gui/wxpython/mapdisp/mapwindow.py:1748
-msgid "Warning"
-msgstr "Brīdinājums"
-#: ../gui/wxpython/gui_modules/workspace.py:1597
-#: ../gui/wxpython/core/workspace.py:1268
+#: ../gui/wxpython/iscatt/controllers.py:232
 #, python-format
-msgid " row %d:"
-msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:234
-#: ../gui/wxpython/gui_core/goutput.py:249
-msgid "Click here to show search module engine"
-msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:235
-#: ../gui/wxpython/gui_core/goutput.py:250
-msgid "Click here to hide search module engine"
-msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:253
-#: ../gui/wxpython/gui_core/goutput.py:268
-msgid "Output window"
-msgstr "Izvades logs"
-#: ../gui/wxpython/gui_modules/goutput.py:255
-#: ../gui/wxpython/gui_core/goutput.py:270
-msgid "Command prompt"
-msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:259
-#: ../gui/wxpython/gui_core/goutput.py:274
-msgid "Clear output window content"
-msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:261
-#: ../gui/wxpython/gui_core/goutput.py:276
-msgid "Clear command prompt content"
-msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:265
-#: ../gui/wxpython/gui_core/goutput.py:278
-msgid "Save output window content to the file"
-msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:268
-#: ../gui/wxpython/gui_core/goutput.py:280
-msgid "Abort running command"
-msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:518
-#: ../gui/wxpython/gui_core/goutput.py:546
-#, python-format
 msgid ""
-"Command '%s' not yet implemented in the WxGUI. Try adding it as a command "
-"layer instead."
+"Number of cells (rows*cols) <%d> in current region is higher than "
+"recommended threshold <%d>.\n"
+"It is strongly advised to reduce number of cells in current region bellow "
+"recommend threshold.\n"
+" It can be done by <g.region> command.\n"
+"\n"
+"Do you want to continue using Interactive Scatter Plot Tool with this region?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:553
-#: ../gui/wxpython/gui_core/goutput.py:586
-#, python-format
+#: ../gui/wxpython/iscatt/controllers.py:288
 msgid ""
-"Unable to run command:\n"
-"%(cmd)s\n"
-"\n"
-"Option <%(opt)s>: read from standard input is not supported by wxGUI"
+"Scatter plot with same band combination (regardless x y order) is already "
+"displayed."
 msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:635
-#: ../gui/wxpython/gui_core/goutput.py:674
-#: ../gui/wxpython/gui_core/goutput.py:820
-msgid "Save file as..."
-msgstr "Saglabāt failu kā..."
-#: ../gui/wxpython/gui_modules/goutput.py:671
-#: ../gui/wxpython/gui_modules/ghelp.py:346
-#: ../gui/wxpython/gui_core/goutput.py:717
-#: ../gui/wxpython/gui_core/ghelp.py:329
+#: ../gui/wxpython/iscatt/controllers.py:301
 #, python-format
-msgid "%d modules match"
+msgid "Band <%s> is not CELL (integer) type.\n"
 msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:770
-#: ../gui/wxpython/gui_core/goutput.py:873
-msgid "Please note that the data are left in inconsistent state and may be corrupted"
+#: ../gui/wxpython/iscatt/controllers.py:304
+msgid "Scatter plot cannot be added.\n"
 msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:773
-#: ../gui/wxpython/gui_core/goutput.py:875
-msgid "Command aborted"
-msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:782
-#: ../gui/wxpython/gui_core/goutput.py:862
+#: ../gui/wxpython/iscatt/controllers.py:310
 #, python-format
-msgid "%d sec"
+msgid ""
+"Scatter plot cannot be added.\n"
+"Multiple of bands ranges <%s:%d * %s:%d = %d> is higher than maximum limit <"
+"%d>.\n"
 msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:785
+#: ../gui/wxpython/iscatt/controllers.py:318
 #, python-format
-msgid "%d min %d sec"
-msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:789
-#: ../gui/wxpython/gui_core/goutput.py:877
-msgid "Command finished"
-msgstr ""
-#: ../gui/wxpython/gui_modules/gcmd.py:78 ../gui/wxpython/core/gcmd.py:122
-msgid "Reason"
-msgstr "Iemesls"
-#: ../gui/wxpython/gui_modules/gcmd.py:341 ../gui/wxpython/core/gcmd.py:385
-msgid "Execution failed:"
-msgstr ""
-#: ../gui/wxpython/gui_modules/gcmd.py:346
-#: ../gui/wxpython/gui_modules/gcmd.py:350 ../gui/wxpython/core/gcmd.py:390
-#: ../gui/wxpython/core/gcmd.py:394
-msgid "Error: "
-msgstr "Kļūda: "
-#: ../gui/wxpython/gui_modules/gcmd.py:425 ../gui/wxpython/core/gcmd.py:469
-#, python-format
-msgid "Unable to exectute command: '%s'"
-msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:420
-#: ../gui/wxpython/gui_modules/gmodeler.py:482
-#, python-format
-msgid "%s: undefined variable '%s'"
-msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1006
-#: ../gui/wxpython/gui_modules/dbm.py:2095
-#: ../gui/wxpython/dbmgr/manager.py:2115
-msgid "Nothing to delete."
-msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:232
-#: ../gui/wxpython/mapdisp/toolbars.py:90
-msgid "3D view mode not available"
-msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:233
-#: ../gui/wxpython/gui_modules/toolbars.py:250
-#: ../gui/wxpython/mapdisp/toolbars.py:91
-#: ../gui/wxpython/mapdisp/toolbars.py:108
-#, python-format
-msgid "Reason: %s"
-msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:234
-#: ../gui/wxpython/mapdisp/toolbars.py:92
 msgid ""
-"Note that the wxGUI's 3D view mode is currently disabled on MS Windows "
-"(hopefully this will be fixed soon). Please keep an eye out for updated "
-"versions of GRASS. In the meantime you can use \"NVIZ\" from the File menu."
+"Multiple of bands ranges <%s:%d * %s:%d = %d> is higher than recommended "
+"limit <%d>.\n"
+"It is strongly advised to reduce range extend of bands(e. g. using r."
+"rescale) bellow recommended threshold.\n"
+"\n"
+"Do you really want to add this scatter plot?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:242
-#: ../gui/wxpython/gui_modules/toolbars.py:1153
-#: ../gui/wxpython/mapdisp/toolbars.py:100
-#: ../gui/wxpython/vdigit/toolbars.py:798
-msgid "Digitize"
-msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:249
-#: ../gui/wxpython/mapdisp/toolbars.py:107
-msgid "Vector digitizer not available"
-msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:251
-#: ../gui/wxpython/mapdisp/toolbars.py:109
+#: ../gui/wxpython/iscatt/controllers.py:403
 msgid ""
-"Note that the wxGUI's vector digitizer is currently disabled (hopefully this "
-"will be fixed soon). Please keep an eye out for updated versions of GRASS. "
-"In the meantime you can use \"v.digit\" from the Develop Vector menu."
+"In order to select arrea in scatter plot, you have to select class first.\n"
+"\n"
+"There is no class yet, do you want to create one?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:446
-#: ../gui/wxpython/iclass/toolbars.py:66
-msgid "Set map canvas for "
+#: ../gui/wxpython/iscatt/controllers.py:407
+#: ../gui/wxpython/iclass/digit.py:70
+msgid "No class selected"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:448
-msgid " / Zoom to map"
-msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:814
-#: ../gui/wxpython/vdigit/toolbars.py:133
-#: ../gui/wxpython/vdigit/toolbars.py:451
-msgid "Digitization settings"
-msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:824
-#: ../gui/wxpython/vdigit/toolbars.py:467
-msgid "Break selected lines/boundaries at intersection"
-msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:826
-#: ../gui/wxpython/vdigit/toolbars.py:469
-msgid "Connect selected lines/boundaries"
-msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:828
-#: ../gui/wxpython/vdigit/toolbars.py:471
-msgid "Copy categories"
-msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:830
-#: ../gui/wxpython/vdigit/toolbars.py:473
-msgid "Copy features from (background) vector map"
-msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:832
-#: ../gui/wxpython/vdigit/toolbars.py:475
-msgid "Copy attributes"
-msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:834
-#: ../gui/wxpython/vdigit/toolbars.py:477
-msgid "Feature type conversion"
-msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:836
-#: ../gui/wxpython/vdigit/toolbars.py:479
-msgid "Flip selected lines/boundaries"
-msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:838
-#: ../gui/wxpython/vdigit/toolbars.py:481
-msgid "Merge selected lines/boundaries"
-msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:840
-#: ../gui/wxpython/vdigit/toolbars.py:483
-msgid "Snap selected lines/boundaries (only to nodes)"
-msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:842
-#: ../gui/wxpython/vdigit/toolbars.py:485
-msgid "Split line/boundary"
-msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:844
-#: ../gui/wxpython/vdigit/toolbars.py:487
-msgid "Query features"
-msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:846
-#: ../gui/wxpython/vdigit/toolbars.py:489
-msgid "Z bulk-labeling of 3D lines"
-msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:1002
-#: ../gui/wxpython/vdigit/toolbars.py:645
-msgid "Vector map is not 3D. Operation canceled."
-msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:1071
-#: ../gui/wxpython/gui_modules/toolbars.py:1185
-#: ../gui/wxpython/gui_modules/toolbars.py:1264
-#: ../gui/wxpython/vdigit/toolbars.py:714
-#: ../gui/wxpython/vdigit/toolbars.py:830
-#: ../gui/wxpython/vdigit/toolbars.py:909
-msgid "Select vector map"
-msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:1109
-#: ../gui/wxpython/vdigit/toolbars.py:752
+#: ../gui/wxpython/iscatt/controllers.py:437
 #, python-format
-msgid "Please wait, opening vector map <%s> for editing..."
+msgid ""
+"Error occured during computation of scatter plot category:\n"
+"%s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:1142
+#: ../gui/wxpython/iscatt/controllers.py:745
 #, python-format
-msgid "Unsupported feature type '%s'. Unable to edit OGR layer <%s>."
+msgid "Export scatter plot raster of class <%s>"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:1193
-#: ../gui/wxpython/vdigit/toolbars.py:838
+#: ../gui/wxpython/iscatt/controllers.py:762
 #, python-format
-msgid "Do you want to save changes in vector map <%s>?"
+msgid "Scatter plot raster of class <%s> exported to raster map <%s>."
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:1195
-#: ../gui/wxpython/vdigit/toolbars.py:840
-msgid "Save changes?"
-msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:1202
-#: ../gui/wxpython/vdigit/toolbars.py:847
+#: ../gui/wxpython/iscatt/controllers.py:765
 #, python-format
-msgid "Please wait, closing and rebuilding topology of vector map <%s>..."
+msgid ""
+"Export of scatter plot raster of class <%s> to map <%s> failed.\n"
+"%s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:1212
-#: ../gui/wxpython/vdigit/toolbars.py:857
-#, python-format
-msgid "Editing of vector map <%s> successfully finished"
-msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:1271
-#: ../gui/wxpython/gui_modules/toolbars.py:1276
-#: ../gui/wxpython/vdigit/toolbars.py:916
-#: ../gui/wxpython/vdigit/toolbars.py:921
-msgid "New vector map"
-#: ../gui/wxpython/gui_modules/location_wizard.py:127
-#: ../gui/wxpython/location_wizard/wizard.py:91
+#: ../gui/wxpython/location_wizard/wizard.py:95
 msgid "Define GRASS Database and Location Name"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:143
-#: ../gui/wxpython/location_wizard/wizard.py:107
-#: ../gui/wxpython/gis_set.py:110
+#: ../gui/wxpython/location_wizard/wizard.py:111
+#: ../gui/wxpython/gis_set.py:117
 msgid "GIS Data Directory:"
 msgstr "GIS datu mape:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:159
-#: ../gui/wxpython/location_wizard/wizard.py:123
+#: ../gui/wxpython/location_wizard/wizard.py:127
 msgid "Project Location"
 msgstr "Projekta novietojums"
-#: ../gui/wxpython/gui_modules/location_wizard.py:170
-#: ../gui/wxpython/location_wizard/wizard.py:134
+#: ../gui/wxpython/location_wizard/wizard.py:128
 #, fuzzy
+msgid "Name of location directory in GIS Data Directory"
+msgstr "Izvēlieties ĢIS datu mapi"
+#: ../gui/wxpython/location_wizard/wizard.py:139
+#, fuzzy
 msgid "Location Title"
 msgstr "Novietojuma nosaukums"
-#: ../gui/wxpython/gui_modules/location_wizard.py:200
-#: ../gui/wxpython/location_wizard/wizard.py:164
+#: ../gui/wxpython/location_wizard/wizard.py:140
+msgid "Optional location title, you can leave this field blank."
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:160
+#, python-format
+msgid ""
+"Name <%(name)s> is not a valid name for location. Please use only ASCII "
+"characters excluding %(chars)s and space."
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:163
+#, fuzzy
+msgid "Invalid location name"
+msgstr "Novietojuma nosaukums:"
+#: ../gui/wxpython/location_wizard/wizard.py:178
 msgid "Choose GRASS data directory:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:211
-#: ../gui/wxpython/gui_modules/location_wizard.py:1967
-#: ../gui/wxpython/location_wizard/wizard.py:175
-#: ../gui/wxpython/location_wizard/wizard.py:1993
-#: ../gui/wxpython/scripts/r.li.setup.py:336
+#: ../gui/wxpython/location_wizard/wizard.py:189
+#: ../gui/wxpython/location_wizard/wizard.py:2059
 msgid "Location already exists in GRASS Database."
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:215
-#: ../gui/wxpython/location_wizard/wizard.py:179
+#: ../gui/wxpython/location_wizard/wizard.py:193
 msgid "Unable to create location"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:228
-#: ../gui/wxpython/location_wizard/wizard.py:192
+#: ../gui/wxpython/location_wizard/wizard.py:206
 msgid ""
 "Title of the location is limited only to one line and 256 characters. The "
 "rest of the text will be ignored."
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:235
+#: ../gui/wxpython/location_wizard/wizard.py:213
 msgid "Choose method for creating a new location"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:242
-#: ../gui/wxpython/location_wizard/wizard.py:206
+#: ../gui/wxpython/location_wizard/wizard.py:220
 msgid "Select coordinate system parameters from a list"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:245
-#: ../gui/wxpython/location_wizard/wizard.py:209
+#: ../gui/wxpython/location_wizard/wizard.py:223
 msgid "Select EPSG code of spatial reference system"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:247
-#: ../gui/wxpython/location_wizard/wizard.py:211
+#: ../gui/wxpython/location_wizard/wizard.py:225
 msgid "Read projection and datum terms from a georeferenced data file"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:250
-#: ../gui/wxpython/location_wizard/wizard.py:214
-msgid "Read projection and datum terms from a WKT or PRJ file"
+#: ../gui/wxpython/location_wizard/wizard.py:228
+msgid "Read projection and datum terms from a Well Known Text (WKT) .prj file"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:253
-#: ../gui/wxpython/location_wizard/wizard.py:217
+#: ../gui/wxpython/location_wizard/wizard.py:231
 msgid "Specify projection and datum terms using custom PROJ.4 parameters"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:256
-msgid "Create an arbitrary non-earth coordinate system (XY)"
+#: ../gui/wxpython/location_wizard/wizard.py:234
+msgid "Create a generic Cartesian coordinate system (XY)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:357
-#: ../gui/wxpython/location_wizard/wizard.py:321
+#: ../gui/wxpython/location_wizard/wizard.py:335
 msgid "Choose projection"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:373
-#: ../gui/wxpython/gui_modules/location_wizard.py:874
-#: ../gui/wxpython/gui_modules/location_wizard.py:1037
-#: ../gui/wxpython/gui_modules/location_wizard.py:1302
-#: ../gui/wxpython/location_wizard/wizard.py:337
-#: ../gui/wxpython/location_wizard/wizard.py:838
-#: ../gui/wxpython/location_wizard/wizard.py:1007
-#: ../gui/wxpython/location_wizard/wizard.py:1312
+#: ../gui/wxpython/location_wizard/wizard.py:351
+#: ../gui/wxpython/location_wizard/wizard.py:852
+#: ../gui/wxpython/location_wizard/wizard.py:1024
+#: ../gui/wxpython/location_wizard/wizard.py:1335
 msgid "Code"
 msgstr "Kods"
-#: ../gui/wxpython/gui_modules/location_wizard.py:378
-#: ../gui/wxpython/location_wizard/wizard.py:342
+#: ../gui/wxpython/location_wizard/wizard.py:355
 msgid "Projection code:"
 msgstr "Projekcijas kods:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:386
-#: ../gui/wxpython/gui_modules/location_wizard.py:888
-#: ../gui/wxpython/gui_modules/location_wizard.py:1050
-#: ../gui/wxpython/location_wizard/wizard.py:350
-#: ../gui/wxpython/location_wizard/wizard.py:852
-#: ../gui/wxpython/location_wizard/wizard.py:1025
+#: ../gui/wxpython/location_wizard/wizard.py:363
+#: ../gui/wxpython/location_wizard/wizard.py:865
+#: ../gui/wxpython/location_wizard/wizard.py:1041
 msgid "Search in description:"
 msgstr "Meklēt pēc apraksta:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:560
-#: ../gui/wxpython/location_wizard/wizard.py:524
+#: ../gui/wxpython/location_wizard/wizard.py:538
 #, python-format
 msgid "Unable to read list: %s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:663
-#: ../gui/wxpython/location_wizard/wizard.py:627
+#: ../gui/wxpython/location_wizard/wizard.py:641
 msgid "Choose projection parameters"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:679
-#: ../gui/wxpython/location_wizard/wizard.py:643
+#: ../gui/wxpython/location_wizard/wizard.py:655
 msgid "Select datum or ellipsoid (next page)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:685
-#: ../gui/wxpython/location_wizard/wizard.py:649
+#: ../gui/wxpython/location_wizard/wizard.py:662
 msgid "Datum with associated ellipsoid"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:688
-#: ../gui/wxpython/location_wizard/wizard.py:652
+#: ../gui/wxpython/location_wizard/wizard.py:665
 msgid "Ellipsoid only"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:745
-#: ../gui/wxpython/location_wizard/wizard.py:709
+#: ../gui/wxpython/location_wizard/wizard.py:722
 #, python-format
 msgid "You must enter a value for %s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:757
-#: ../gui/wxpython/gui_modules/location_wizard.py:775
-#: ../gui/wxpython/location_wizard/wizard.py:721
-#: ../gui/wxpython/location_wizard/wizard.py:739
+#: ../gui/wxpython/location_wizard/wizard.py:734
+#: ../gui/wxpython/location_wizard/wizard.py:753
 #, python-format
 msgid " Enter parameters for %s projection "
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:798
-#: ../gui/wxpython/location_wizard/wizard.py:762
-msgid "No"
-msgstr "Nē"
-msgid "Yes"
-msgstr "Jā"
-#: ../gui/wxpython/gui_modules/location_wizard.py:852
-#: ../gui/wxpython/location_wizard/wizard.py:816
+#: ../gui/wxpython/location_wizard/wizard.py:830
 msgid "Specify geodetic datum"
 msgstr ""
 msgid "Ellipsoid"
 msgstr "Elipsoīds"
-#: ../gui/wxpython/gui_modules/location_wizard.py:879
-#: ../gui/wxpython/location_wizard/wizard.py:843
+#: ../gui/wxpython/location_wizard/wizard.py:856
 msgid "Datum code:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:1014
-#: ../gui/wxpython/location_wizard/wizard.py:978
+#: ../gui/wxpython/location_wizard/wizard.py:995
 msgid "Specify ellipsoid"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:1042
-#: ../gui/wxpython/location_wizard/wizard.py:1013
+#: ../gui/wxpython/location_wizard/wizard.py:1012
+msgid "Earth based"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1015
+msgid "Planetary bodies"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1029
 msgid "Ellipsoid code:"
 msgstr "Elipsoīda kods:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1131
-#: ../gui/wxpython/gui_modules/location_wizard.py:1191
-#: ../gui/wxpython/location_wizard/wizard.py:1141
-#: ../gui/wxpython/location_wizard/wizard.py:1201
+#: ../gui/wxpython/location_wizard/wizard.py:1161
+#: ../gui/wxpython/location_wizard/wizard.py:1221
 msgid "Select georeferenced file"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:1136
-#: ../gui/wxpython/location_wizard/wizard.py:1146
+#: ../gui/wxpython/location_wizard/wizard.py:1166
 msgid "Georeferenced file:"
 msgstr "Ģeoreferencēts fails:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1205
-#: ../gui/wxpython/gui_modules/location_wizard.py:1262
-#: ../gui/wxpython/location_wizard/wizard.py:1215
-#: ../gui/wxpython/location_wizard/wizard.py:1272
-msgid "Select WKT file"
+#: ../gui/wxpython/location_wizard/wizard.py:1235
+#: ../gui/wxpython/location_wizard/wizard.py:1292
+msgid "Select Well Known Text (WKT) .prj file"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:1210
-#: ../gui/wxpython/location_wizard/wizard.py:1220
-msgid "WKT file:"
+#: ../gui/wxpython/location_wizard/wizard.py:1240
+#, fuzzy
+msgid "WKT .prj file:"
 msgstr "WKT fails:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1276
-#: ../gui/wxpython/location_wizard/wizard.py:1286
+#: ../gui/wxpython/location_wizard/wizard.py:1309
 msgid "Choose EPSG Code"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:1284
-#: ../gui/wxpython/location_wizard/wizard.py:1294
+#: ../gui/wxpython/location_wizard/wizard.py:1317
 msgid "Path to the EPSG-codes file:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:1286
-#: ../gui/wxpython/gui_modules/preferences.py:2005
-#: ../gui/wxpython/location_wizard/wizard.py:1296
-#: ../gui/wxpython/gui_core/preferences.py:1180
+#: ../gui/wxpython/location_wizard/wizard.py:1319
+#: ../gui/wxpython/gui_core/preferences.py:1224
 msgid "EPSG code:"
 msgstr "EPSG kods:"
+#: ../gui/wxpython/vnet/dialogs.py:319
 msgid "Parameters"
 msgstr "Parametri"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1438
-#: ../gui/wxpython/location_wizard/wizard.py:1448
+#: ../gui/wxpython/location_wizard/wizard.py:1471
 msgid "Choose EPSG codes file"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:1467
-#: ../gui/wxpython/location_wizard/wizard.py:1477
+#: ../gui/wxpython/location_wizard/wizard.py:1500
 #, python-format
 msgid "Unable to read EPGS codes: %s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:1485
-#: ../gui/wxpython/location_wizard/wizard.py:1495
+#: ../gui/wxpython/location_wizard/wizard.py:1518
 msgid "Choose method of specifying georeferencing parameters"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:1493
-#: ../gui/wxpython/location_wizard/wizard.py:1503
+#: ../gui/wxpython/location_wizard/wizard.py:1526
 msgid "Enter PROJ.4 parameters string:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:1541
-#: ../gui/wxpython/gui_modules/location_wizard.py:1545
-#: ../gui/wxpython/location_wizard/wizard.py:1551
-#: ../gui/wxpython/location_wizard/wizard.py:1555
+#: ../gui/wxpython/location_wizard/wizard.py:1582
+#: ../gui/wxpython/location_wizard/wizard.py:1586
 msgid "Datum transform is required."
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:1567
-#: ../gui/wxpython/location_wizard/wizard.py:1577
-#: ../gui/wxpython/scripts/r.li.setup.py:591
+#: ../gui/wxpython/location_wizard/wizard.py:1621
+#: ../gui/wxpython/rlisetup/wizard.py:924
 msgid "Summary"
 msgstr "Kopsavilkums"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1612
-#: ../gui/wxpython/location_wizard/wizard.py:1622
-#: ../gui/wxpython/scripts/r.li.setup.py:613
+#: ../gui/wxpython/location_wizard/wizard.py:1662
 msgid "GRASS Database:"
 msgstr "GRASS datubāze:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1618
-#: ../gui/wxpython/location_wizard/wizard.py:1628
-#: ../gui/wxpython/scripts/r.li.setup.py:619
+#: ../gui/wxpython/location_wizard/wizard.py:1668
 msgid "Location Name:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1624
-#: ../gui/wxpython/location_wizard/wizard.py:1634
+#: ../gui/wxpython/location_wizard/wizard.py:1674
 msgid "Location Title:"
 msgstr "Novietojuma virsraksts:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1630
-#: ../gui/wxpython/location_wizard/wizard.py:1640
-#: ../gui/wxpython/scripts/r.li.setup.py:625
+#: ../gui/wxpython/location_wizard/wizard.py:1680
 msgid "Projection:"
 msgstr "Projekcija:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1636
-#: ../gui/wxpython/location_wizard/wizard.py:1646
-#: ../gui/wxpython/scripts/r.li.setup.py:660
-msgid "PROJ.4 definition:"
+#: ../gui/wxpython/location_wizard/wizard.py:1686
+msgid ""
+"PROJ.4 definition:\n"
+" (non-definitive)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:1709
-#: ../gui/wxpython/location_wizard/wizard.py:1719
-#: ../gui/wxpython/scripts/r.li.setup.py:716
+#: ../gui/wxpython/location_wizard/wizard.py:1789
 #, python-format
 msgid "Do you want to create GRASS location <%s>?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:1710
-#: ../gui/wxpython/location_wizard/wizard.py:1720
-#: ../gui/wxpython/scripts/r.li.setup.py:717
+#: ../gui/wxpython/location_wizard/wizard.py:1790
 msgid "Create new location?"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1750
-#: ../gui/wxpython/location_wizard/wizard.py:1760
+#: ../gui/wxpython/location_wizard/wizard.py:1834
 msgid "Define new GRASS Location"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:1835
-#: ../gui/wxpython/location_wizard/wizard.py:1845
-msgid "Do you want to set the default region extents and resolution now?"
-msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:1837
-#: ../gui/wxpython/location_wizard/wizard.py:1847
+#: ../gui/wxpython/location_wizard/wizard.py:1926
 #, python-format
-msgid "Location <%s> created"
-msgstr "Novietojums <%s> ir izveidots:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1850
-#: ../gui/wxpython/location_wizard/wizard.py:1860
-#, python-format
 msgid ""
 "Unable to create new location. Location <%(loc)s> not created.\n"
 "\n"
 "Details: %(err)s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:1858
-#: ../gui/wxpython/location_wizard/wizard.py:1868
+#: ../gui/wxpython/location_wizard/wizard.py:1934
 msgid "Location wizard canceled. Location not created."
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:1965
-#: ../gui/wxpython/location_wizard/wizard.py:1991
-#: ../gui/wxpython/scripts/r.li.setup.py:334
+#: ../gui/wxpython/location_wizard/wizard.py:2057
 msgid "Unable to create new location"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:1984
-#: ../gui/wxpython/location_wizard/wizard.py:2010
+#: ../gui/wxpython/location_wizard/wizard.py:2076
 #, python-format
 msgid ""
 "Location <%(loc)s> will be created in GIS data directory <%(dir)s>. You will "
 "need to change the default GIS data directory in the GRASS startup screen."
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:1989
-#: ../gui/wxpython/location_wizard/wizard.py:2015
-#: ../gui/wxpython/scripts/r.li.setup.py:362
+#: ../gui/wxpython/location_wizard/wizard.py:2081
 msgid "New GIS data directory"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:2014
-#: ../gui/wxpython/location_wizard/wizard.py:2040
-#: ../gui/wxpython/scripts/r.li.setup.py:523
+#: ../gui/wxpython/location_wizard/wizard.py:2112
 msgid "EPSG code missing."
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:2024
-#: ../gui/wxpython/gui_modules/location_wizard.py:2033
-#: ../gui/wxpython/location_wizard/wizard.py:2050
-#: ../gui/wxpython/location_wizard/wizard.py:2059
+#: ../gui/wxpython/location_wizard/wizard.py:2123
+#: ../gui/wxpython/location_wizard/wizard.py:2132
 #, python-format
 msgid "File <%s> not found."
 msgstr "Fails <%s> nav atrasts."
-#: ../gui/wxpython/gui_modules/location_wizard.py:2092
-#: ../gui/wxpython/location_wizard/dialogs.py:36
+#: ../gui/wxpython/location_wizard/dialogs.py:42
 msgid "Set default region extent and resolution"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:2139
-#: ../gui/wxpython/location_wizard/dialogs.py:83
+#: ../gui/wxpython/location_wizard/dialogs.py:89
 msgid "&Set region"
 msgstr "&Iestatīt reģionu"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2169
-#: ../gui/wxpython/location_wizard/dialogs.py:113
+#: ../gui/wxpython/location_wizard/dialogs.py:119
 msgid "Invalid location selected."
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:2186
-#: ../gui/wxpython/location_wizard/dialogs.py:130
+#: ../gui/wxpython/location_wizard/dialogs.py:136
 msgid "Invalid region"
 msgstr "Nederīgs reģions"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2216
-#: ../gui/wxpython/location_wizard/dialogs.py:160
+#: ../gui/wxpython/location_wizard/dialogs.py:166
 msgid "Click here to show 3D settings"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:2217
-#: ../gui/wxpython/location_wizard/dialogs.py:161
+#: ../gui/wxpython/location_wizard/dialogs.py:167
 msgid "Click here to hide 3D settings"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:2240
-#: ../gui/wxpython/gui_modules/location_wizard.py:2521
-#: ../gui/wxpython/location_wizard/dialogs.py:184
-#: ../gui/wxpython/location_wizard/dialogs.py:465
+#: ../gui/wxpython/location_wizard/dialogs.py:190
+#: ../gui/wxpython/location_wizard/dialogs.py:472
 #, python-format
 msgid "Rows: %d"
 msgstr "Rindas: %d"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2241
-#: ../gui/wxpython/gui_modules/location_wizard.py:2522
-#: ../gui/wxpython/location_wizard/dialogs.py:185
-#: ../gui/wxpython/location_wizard/dialogs.py:466
+#: ../gui/wxpython/location_wizard/dialogs.py:191
+#: ../gui/wxpython/location_wizard/dialogs.py:473
 #, python-format
 msgid "Cols: %d"
 msgstr "Kolonas: %d"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2242
-#: ../gui/wxpython/gui_modules/location_wizard.py:2523
-#: ../gui/wxpython/location_wizard/dialogs.py:186
-#: ../gui/wxpython/location_wizard/dialogs.py:467
+#: ../gui/wxpython/location_wizard/dialogs.py:192
+#: ../gui/wxpython/location_wizard/dialogs.py:474
 #, python-format
 msgid "Cells: %d"
 msgstr "Šūnas: %d"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2283
-#: ../gui/wxpython/gui_modules/location_wizard.py:2525
-#: ../gui/wxpython/location_wizard/dialogs.py:227
-#: ../gui/wxpython/location_wizard/dialogs.py:469
+#: ../gui/wxpython/location_wizard/dialogs.py:234
+#: ../gui/wxpython/location_wizard/dialogs.py:476
 #, python-format
 msgid "Depth: %d"
 msgstr "Dziļums: %d"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2284
-#: ../gui/wxpython/gui_modules/location_wizard.py:2526
-#: ../gui/wxpython/location_wizard/dialogs.py:228
-#: ../gui/wxpython/location_wizard/dialogs.py:470
+#: ../gui/wxpython/location_wizard/dialogs.py:235
+#: ../gui/wxpython/location_wizard/dialogs.py:477
 #, python-format
 msgid "3D Cells: %d"
 msgstr "3D šūnas: %d"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2303
-#: ../gui/wxpython/location_wizard/dialogs.py:247
+#: ../gui/wxpython/location_wizard/dialogs.py:254
 msgid "T-B resolution"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:2366
-#: ../gui/wxpython/location_wizard/dialogs.py:310
+#: ../gui/wxpython/location_wizard/dialogs.py:317
 msgid "North"
 msgstr "Ziemeļi"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2374
-#: ../gui/wxpython/location_wizard/dialogs.py:318
+#: ../gui/wxpython/location_wizard/dialogs.py:325
 msgid "West"
 msgstr "Rietumi"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2394
-#: ../gui/wxpython/location_wizard/dialogs.py:338
+#: ../gui/wxpython/location_wizard/dialogs.py:345
 msgid "East"
 msgstr "Austrumi"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2403
-#: ../gui/wxpython/location_wizard/dialogs.py:347
+#: ../gui/wxpython/location_wizard/dialogs.py:354
 msgid "South"
 msgstr "Dienvidi"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2407
-#: ../gui/wxpython/location_wizard/dialogs.py:351
+#: ../gui/wxpython/location_wizard/dialogs.py:358
 msgid "N-S resolution"
 msgstr "Z-D izšķirtspēja"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2415
-#: ../gui/wxpython/location_wizard/dialogs.py:359
+#: ../gui/wxpython/location_wizard/dialogs.py:366
 msgid "E-W resolution"
 msgstr "A-R izšķirtspēja"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2493
-#: ../gui/wxpython/location_wizard/dialogs.py:437
+#: ../gui/wxpython/location_wizard/dialogs.py:444
 #, python-format
 msgid "Invalid value: %s"
 msgstr "Nederīga vētība: %s"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2578
-#: ../gui/wxpython/location_wizard/dialogs.py:521
+#: ../gui/wxpython/location_wizard/dialogs.py:528
 msgid "Select datum transformation"
 msgstr ""
-#: ../gui/wxpython/gui_modules/location_wizard.py:2603
-#: ../gui/wxpython/location_wizard/dialogs.py:546
+#: ../gui/wxpython/location_wizard/dialogs.py:553
 msgid "Select from list of datum transformations"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:114
-#: ../gui/wxpython/gui_core/dialogs.py:117
-msgid "Type of element:"
+#: ../gui/wxpython/mapswipe/toolbars.py:27
+#: ../gui/wxpython/modules/vclean.py:461
+msgid "Tools"
+msgstr "Rīki"
+#: ../gui/wxpython/mapswipe/toolbars.py:28
+#, fuzzy
+msgid "Quit Map Swipe"
+msgstr "Kartes skats"
+#: ../gui/wxpython/mapswipe/toolbars.py:29
+#: ../gui/wxpython/mapswipe/dialogs.py:42
+#, fuzzy
+msgid "Select raster maps"
+msgstr "3D rastra kartes"
+#: ../gui/wxpython/mapswipe/toolbars.py:104
+#, fuzzy
+msgid "Swipe mode"
+msgstr "Ekrāna režīms"
+#: ../gui/wxpython/mapswipe/dialogs.py:233
+msgid "Mirror mode"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:145
-#: ../gui/wxpython/gui_core/dialogs.py:148
-msgid "Select GRASS location and mapset"
+#: ../gui/wxpython/mapswipe/toolbars.py:113
+msgid "Choose view mode"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:146
-#: ../gui/wxpython/gui_core/dialogs.py:149
-msgid "Name of GRASS location:"
-msgstr "GRASS novietojuma nosaukums:"
+#: ../gui/wxpython/mapswipe/toolbars.py:137
+#, fuzzy
+msgid "Switch orientation"
+msgstr "Orientācija"
-#: ../gui/wxpython/gui_modules/gdialogs.py:166
-#: ../gui/wxpython/gui_modules/gdialogs.py:198
-#: ../gui/wxpython/gui_core/dialogs.py:169
-#: ../gui/wxpython/gui_core/dialogs.py:201
-msgid "Name of mapset:"
-msgstr "Karšu kopas nosaukums:"
+#: ../gui/wxpython/mapswipe/toolbars.py:139
+msgid "Switch maps"
+msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:196
-#: ../gui/wxpython/gui_core/dialogs.py:199
-msgid "Select mapset in GRASS location"
+#: ../gui/wxpython/mapswipe/dialogs.py:119
+#, fuzzy
+msgid "Name of top/left raster map:"
+msgstr "Rastra kartes nosaukums:"
+#: ../gui/wxpython/mapswipe/dialogs.py:123
+#, fuzzy
+msgid "Name of bottom/right raster map:"
+#: ../gui/wxpython/mapswipe/dialogs.py:156
+msgid "Switch to advanced mode"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:240
-#: ../gui/wxpython/gui_core/dialogs.py:243
-msgid "Name for new vector map:"
-msgstr "Jaunās vektoru kartes nosaukums:"
+#: ../gui/wxpython/mapswipe/dialogs.py:157
+msgid "Cancel"
+msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:252
-#: ../gui/wxpython/gui_core/dialogs.py:255
-msgid "Create attribute table"
-msgstr "Izveidot atribūtu tabulu"
+#: ../gui/wxpython/mapswipe/dialogs.py:161
+msgid "Switch to simple mode"
+msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:267
-#: ../gui/wxpython/gui_modules/preferences.py:1744
-#: ../gui/wxpython/gui_core/preferences.py:818
-#: ../gui/wxpython/gui_core/dialogs.py:270
-msgid "Add created map into layer tree"
-msgstr "Pievienot izveidoto karti slāņu sarakstam"
+#: ../gui/wxpython/mapswipe/dialogs.py:185
+msgid "Name of the first map is missing."
+msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:303
-#: ../gui/wxpython/gui_modules/preferences.py:1963
-#: ../gui/wxpython/gui_core/preferences.py:1137
-#: ../gui/wxpython/gui_core/dialogs.py:306
-msgid "Key column:"
-msgstr "Atslēgas kolona:"
+#: ../gui/wxpython/mapswipe/dialogs.py:187
+msgid "Name of the second map is missing."
+msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:399
-#: ../gui/wxpython/gui_core/dialogs.py:402
+#: ../gui/wxpython/mapswipe/dialogs.py:218
+#, fuzzy
+msgid "Map Swipe settings"
+msgstr "Kartes iestatījumi"
+#: ../gui/wxpython/mapswipe/dialogs.py:236
+msgid "Mirrored cursor"
+msgstr ""
+#: ../gui/wxpython/mapswipe/dialogs.py:255
+msgid "Shape:"
+msgstr ""
+#: ../gui/wxpython/mapswipe/frame.py:41
+#, fuzzy
+msgid "GRASS GIS Map Swipe"
+msgstr "GRASS GIS kartes ekrāns: "
+#: ../gui/wxpython/mapswipe/frame.py:278
+#: ../gui/wxpython/animation/frame.py:147
+msgid "Main Toolbar"
+msgstr ""
+#: ../gui/wxpython/mapswipe/frame.py:390
+msgid "Map <%s> not found. "
+msgstr "Karte <%s> nav atrasta."
+#: ../gui/wxpython/gui_core/query.py:34
+#, fuzzy
+msgid "Query results"
+msgstr "Vaicājumu rīks"
+#: ../gui/wxpython/gui_core/query.py:46
+msgid "Right click to copy selected values to clipboard."
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:50
+#, fuzzy
+msgid "Feature"
+msgstr "Objekta ID"
+#, fuzzy
+msgid "Value"
+msgstr "Vērtības"
+#: ../gui/wxpython/gui_core/query.py:66
+#, fuzzy
+msgid "Copy all to clipboard"
+msgstr "Kopēt koordinātas uz starpliktuvi"
+#: ../gui/wxpython/gui_core/query.py:69
+msgid "Redirect to console"
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:117 ../gui/wxpython/gui_core/query.py:118
 #, python-format
-msgid "Unable to create vector map <%s>."
+msgid "Copy from '%s' column"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:404
-#: ../gui/wxpython/gui_core/dialogs.py:407
+#: ../gui/wxpython/gui_core/query.py:119
+#, fuzzy
+msgid "Copy selected lines"
+msgstr "Saitēt izvēlētos slāņus"
+#: ../gui/wxpython/gui_core/query.py:122 ../gui/wxpython/gui_core/query.py:125
+msgid "Copy '%s'"
+msgstr "Kopēt"
+#: ../gui/wxpython/gui_core/query.py:126
+#, fuzzy
+msgid "Copy line"
+msgstr "Rindas:"
+#: ../gui/wxpython/gui_core/query.py:148
+msgid "Query results:"
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:151
+msgid " "
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:228
+msgid "east, north"
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:239
+#, fuzzy
+msgid "Nothing found"
+msgstr "Nekas"
+#: ../gui/wxpython/gui_core/gselect.py:57
 #, python-format
 msgid ""
-"Invalid or empty key column.\n"
-"Unable to create vector map <%s>."
+"Unable to import pyGRASS: %s\n"
+"Some functionality will be not accessible"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:431
-#: ../gui/wxpython/gui_core/dialogs.py:434
+#: ../gui/wxpython/gui_core/gselect.py:456
+msgid "Not selectable element"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:493
+#: ../gui/wxpython/gui_core/preferences.py:1762
+msgid "Mapset"
+msgstr "Karšu kopa"
+#: ../gui/wxpython/gui_core/gselect.py:504
+#, fuzzy
+msgid "Type: "
+msgstr "Tips"
+#: ../gui/wxpython/gui_core/gselect.py:515
 #, python-format
+msgid "GSelect: invalid item: %s"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1070 ../gui/wxpython/gis_set.py:833
+msgid "Choose GIS Data Directory"
+#: ../gui/wxpython/gui_core/gselect.py:1283
+msgid "Output settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1285
+msgid "Source settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1296
+msgid "Native"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1302
+msgid "File"
+msgstr "Fails"
+#: ../gui/wxpython/gui_core/gselect.py:1306
+#: ../gui/wxpython/gui_core/forms.py:1540
+msgid "Directory"
+msgstr "Mape"
+#: ../gui/wxpython/gui_core/gselect.py:1310 ../gui/wxpython/dbmgr/base.py:2576
+#: ../gui/wxpython/dbmgr/base.py:2701 ../gui/wxpython/dbmgr/base.py:2954
+msgid "Database"
+msgstr "Datubāze"
+#: ../gui/wxpython/gui_core/gselect.py:1314
+msgid "Protocol"
+msgstr "Protokols"
+#: ../gui/wxpython/gui_core/gselect.py:1325
+msgid "Output type"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1327
+msgid "Source type"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1347
+msgid "All files"
+msgstr "Visi faili"
+#: ../gui/wxpython/gui_core/gselect.py:1352
+#, fuzzy
+msgid "ZIP files"
+#: ../gui/wxpython/gui_core/gselect.py:1353
+#, fuzzy
+msgid "GZIP files"
+#: ../gui/wxpython/gui_core/gselect.py:1354
+#, fuzzy
+msgid "TAR files"
+#: ../gui/wxpython/gui_core/gselect.py:1355
+#, fuzzy
+msgid "TARGZ files"
+#: ../gui/wxpython/gui_core/gselect.py:1361
+msgid "File:"
+msgstr "Fails:"
+#: ../gui/wxpython/gui_core/gselect.py:1362
+msgid "Choose file to import"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1374
+#: ../gui/wxpython/gui_core/gselect.py:1436
+#: ../gui/wxpython/animation/dialogs.py:929
+#, fuzzy
+msgid "Directory:"
+msgstr "Mape"
+#: ../gui/wxpython/gui_core/gselect.py:1375
+#: ../gui/wxpython/gui_core/gselect.py:1437
+msgid "Choose input directory"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1389
+msgid "Extension:"
+msgstr "Paplašinājums:"
+#: ../gui/wxpython/gui_core/gselect.py:1414
+msgid "Choose file"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1426
+#: ../gui/wxpython/gui_core/gselect.py:2093
+msgid "Feature type:"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1427
+#, fuzzy
+msgid "simple features"
+msgstr "Dzēst objektu"
+#, fuzzy
+msgid "topological"
+msgstr "loģiskais VAI"
+#: ../gui/wxpython/gui_core/gselect.py:1533
+#: ../gui/wxpython/gui_core/gselect.py:1564
+#: ../gui/wxpython/gui_core/gselect.py:1615
+#: ../gui/wxpython/gui_core/gselect.py:1653
+msgid "Creation options:"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1547
+#: ../gui/wxpython/gui_core/gselect.py:1586
+#: ../gui/wxpython/gui_core/gselect.py:1638
+msgid "Format:"
+msgstr "Formāts:"
+#: ../gui/wxpython/gui_core/gselect.py:1645
+msgid "Protocol:"
+msgstr "Protokols:"
+#: ../gui/wxpython/gui_core/gselect.py:1668
+msgid "No settings available"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:2085
+msgid "LineString"
+msgstr ""
+msgid "Polygon"
+msgstr "Poligons"
+#: ../gui/wxpython/gui_core/forms.py:471
+msgid "Enter parameters for '"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:482
+msgid "Close this window without executing the command (Ctrl+Q)"
+msgstr "Aizvērt logu un neizpildīt komandu (Ctrl+Q)"
+#: ../gui/wxpython/gui_core/forms.py:508
+msgid "Run the command (Ctrl+R)"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:514
+msgid "Copy the current command string to the clipboard"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:530
+msgid "Show manual page of the command (Ctrl+H)"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:561
+msgid "Add created map(s) into layer tree"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:576
+#: ../gui/wxpython/gui_core/dialogs.py:1655
+msgid "Close dialog on finish"
+msgstr "Aizvērt dialogu, kad darbs ir pabeigts"
+#: ../gui/wxpython/gui_core/forms.py:578
 msgid ""
-"Vector map <%s> already exists in the current mapset. Do you want to "
-"overwrite it?"
+"Close dialog when command is successfully finished. Change this settings in "
+"Preferences dialog ('Command' tab)."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:434
-#: ../gui/wxpython/gui_core/dialogs.py:437
-msgid "Overwrite?"
-msgstr "Pārrakstīt?"
+#: ../gui/wxpython/gui_core/forms.py:745
+#, python-format
+msgid "'%s' copied to clipboard"
+msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:491
-#: ../gui/wxpython/gui_core/dialogs.py:494
+#: ../gui/wxpython/gui_core/forms.py:812 ../gui/wxpython/gui_core/forms.py:825
+msgid "Required"
+msgstr "Obilgāti"
+#: ../gui/wxpython/gui_core/forms.py:815 ../gui/wxpython/gui_core/forms.py:825
+msgid "Optional"
+msgstr "Izvēles"
+#: ../gui/wxpython/gui_core/forms.py:894
+#: ../gui/wxpython/gui_core/forms.py:1606
+msgid "Parameterized in model"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:971
+msgid "[multiple]"
+msgstr "[daudzvērtību]"
+#: ../gui/wxpython/gui_core/forms.py:1020
+msgid "valid range"
+msgstr "derīgs diapazons"
+#: ../gui/wxpython/gui_core/forms.py:1274
+msgid "Show graphical representation of temporal extent of dataset(s) ."
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1421 ../gui/wxpython/core/utils.py:988
+msgid "Select Color"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1454
+#: ../gui/wxpython/gui_core/preferences.py:975
+#: ../gui/wxpython/gui_core/preferences.py:997
+msgid "Transparent"
+msgstr "Caurspīdīgs"
+#: ../gui/wxpython/gui_core/forms.py:1483
+#: ../gui/wxpython/gui_core/forms.py:1539
 #, python-format
-msgid "New vector map <%s> created"
+msgid "Choose %s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:513
-#: ../gui/wxpython/gui_core/dialogs.py:516
-msgid "Load region:"
-msgstr "Ielādēt reģionu:"
+#: ../gui/wxpython/gui_core/forms.py:1512
+#: ../gui/wxpython/modules/mcalc_builder.py:148
+msgid "&Load"
+msgstr "Ie&lādēt"
-#: ../gui/wxpython/gui_modules/gdialogs.py:517
-#: ../gui/wxpython/gui_core/dialogs.py:520
-msgid "Save region:"
-msgstr "Saglabāt reģionu:"
+#: ../gui/wxpython/gui_core/forms.py:1514
+#, fuzzy
+msgid "&Save as"
+msgstr "Saglabāt kā"
-#: ../gui/wxpython/gui_modules/gdialogs.py:586
-#: ../gui/wxpython/gui_core/dialogs.py:589
-msgid "Set size and position"
-msgstr "Iestatīt izmēru un novietojumu"
+#: ../gui/wxpython/gui_core/forms.py:1518
+msgid "or enter values interactively"
+msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:587
-#: ../gui/wxpython/gui_core/dialogs.py:590
+#: ../gui/wxpython/gui_core/forms.py:1791
+msgid "Manual"
+msgstr "Rokasgrāmata"
+#: ../gui/wxpython/gui_core/forms.py:1832
+msgid "Nothing to load."
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1840
 msgid ""
-"Click and drag on the map display to set legend size and position and then "
-"press OK"
+"Unable to load file.\n"
+"\n"
+"Reason: %s"
+msgstr "Nav iespējams izveidot jaunu karšu kopu: %s"
+#: ../gui/wxpython/gui_core/forms.py:1866
+#: ../gui/wxpython/modules/colorrules.py:607
+msgid "Nothing to save."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:598
-#: ../gui/wxpython/gui_core/dialogs.py:601
+#: ../gui/wxpython/gui_core/forms.py:1870
+msgid "Save input as..."
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:2177
+msgid "No dataset given."
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:2216 ../gui/wxpython/core/gcmd.py:702
 #, python-format
+msgid "Error in %s"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:2330
+#, python-format
+msgid "Unable to parse command '%s'"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:2336
+#, python-format
+msgid "%(cmd)s: parameter '%(key)s' not available"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:2426
+msgid "Try to set up GRASS_ADDON_PATH or GRASS_ADDON_BASE variable."
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:119
+msgid "Click here to show search module engine"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:120
+msgid "Click here to hide search module engine"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:135
+msgid "Command prompt"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:137
+msgid "Output window"
+msgstr "Izvades logs"
+#: ../gui/wxpython/gui_core/goutput.py:144
+msgid "Clear output window content"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:146
+msgid "Clear command prompt content"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:148
+msgid "Save output window content to the file"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:150
+msgid "Abort running command"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:152
+#, fuzzy
+msgid "&Log file"
+msgstr "Logaritmiskā skala"
+#: ../gui/wxpython/gui_core/goutput.py:154
 msgid ""
-"Drag %s with mouse in pointer mode to position.\n"
-"Double-click to change options."
+"Toggle to save list of executed commands into a file; content saved when "
+"switching off."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:601
-#: ../gui/wxpython/gui_core/dialogs.py:604
+#: ../gui/wxpython/gui_core/goutput.py:377
+#: ../gui/wxpython/gui_core/goutput.py:464
+msgid "Save file as..."
+msgstr "Saglabāt failu kā..."
+#: ../gui/wxpython/gui_core/goutput.py:379
+#: ../gui/wxpython/gui_core/goutput.py:466
+#, python-format
+msgid "%(txt)s (*.txt)|*.txt|%(files)s (*)|*"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:380
+#: ../gui/wxpython/gui_core/goutput.py:467
+msgid "Text files"
+msgstr "Teksta faili"
+msgid "Files"
+msgstr "Faili"
+#: ../gui/wxpython/gui_core/goutput.py:392
+#, python-format
 msgid ""
+"Unable to write file '%(path)s'.\n"
 "\n"
-"Define raster map name for legend in properties dialog."
+"Details: %(error)s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:650
-#: ../gui/wxpython/gui_core/dialogs.py:653
+#: ../gui/wxpython/gui_core/goutput.py:395
 #, python-format
-msgid "Legend of raster map <%s>"
-msgstr "<%s> rastra kartes leģenda"
+msgid "Command output saved into '%s'"
+msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:784
-#: ../gui/wxpython/gui_core/dialogs.py:788
-msgid "Show text object"
-msgstr "Rādīt teksta objektu"
+#: ../gui/wxpython/gui_core/goutput.py:445
+#: ../gui/wxpython/core/gconsole.py:460
+#, python-format
+msgid ""
+"Unable to write file '%(filePath)s'.\n"
+"\n"
+msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:823
-#: ../gui/wxpython/gui_modules/preferences.py:1426
-#: ../gui/wxpython/gui_modules/preferences.py:1566
-#: ../gui/wxpython/gui_core/preferences.py:428
-#: ../gui/wxpython/gui_core/preferences.py:601
-#: ../gui/wxpython/gui_core/dialogs.py:827
+#: ../gui/wxpython/gui_core/goutput.py:450
+msgid "Command log saved to '%s'"
+msgstr "Mainīt iestatījumus"
+#: ../gui/wxpython/gui_core/toolbars.py:36
+msgid "Display map"
+msgstr "Rādīt karti"
+#: ../gui/wxpython/gui_core/toolbars.py:37
+msgid "Re-render modified map layers only"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:39
+msgid "Render map"
+msgstr "Zīmēt karti"
+#: ../gui/wxpython/gui_core/toolbars.py:40
+msgid "Force re-rendering all map layers"
+msgstr "Pārzīmēt visus kartes slāņus"
+#: ../gui/wxpython/gui_core/toolbars.py:42
+msgid "Erase display"
+msgstr "Dzēst ekrānu"
+#: ../gui/wxpython/gui_core/toolbars.py:43
+msgid "Erase display canvas with given background color"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:45
+msgid "Pointer"
+msgstr "Kursors"
+#: ../gui/wxpython/gui_core/toolbars.py:47
+msgid "Zoom in"
+msgstr "Tuvināt"
+#: ../gui/wxpython/gui_core/toolbars.py:48
+msgid "Drag or click mouse to zoom"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:50
+msgid "Zoom out"
+msgstr "Tālināt"
+#: ../gui/wxpython/gui_core/toolbars.py:51
+msgid "Drag or click mouse to unzoom"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:53
+msgid "Return to previous zoom"
+msgstr "Atgriezties uz iepriekšējo skatu"
+#: ../gui/wxpython/gui_core/toolbars.py:55
+msgid "Various zoom options"
+msgstr "Dažādas tuvināšanas opcijas"
+#: ../gui/wxpython/gui_core/toolbars.py:56
+msgid "Zoom to default or saved region, save to named region, ..."
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:58
+msgid "Zoom to selected map layer(s)"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:60
+#, fuzzy
+msgid "Zoom to computational region extent"
+msgstr "Tuvināt līdz aprēķinu reģionam"
+#: ../gui/wxpython/gui_core/toolbars.py:62
+msgid "Pan"
+msgstr "Pārcentrēt"
+#: ../gui/wxpython/gui_core/toolbars.py:63
+msgid "Drag with mouse to pan"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:65
+msgid "Save display to graphic file"
+msgstr "Saglabāt skatu kā bildi"
+#: ../gui/wxpython/gui_core/toolbars.py:69
+msgid "Select font"
+#: ../gui/wxpython/gui_core/toolbars.py:79
+msgid "Add map elements"
+msgstr "Pievienot kartes elementus"
+#: ../gui/wxpython/gui_core/toolbars.py:80
+msgid "Overlay elements like scale and legend onto map"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:82
+msgid "Create histogram with d.histogram"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:255
+#, fuzzy
+msgid "Select graphics tool"
+msgstr "Izvēlēties visu"
+#: ../gui/wxpython/gui_core/simplelmgr.py:101
+#, fuzzy
+msgid "Toolbar"
+msgstr "Rīki"
+#: ../gui/wxpython/gui_core/simplelmgr.py:137
+#, fuzzy
+msgid "Copy map names to clipboard (top to bottom)"
+#: ../gui/wxpython/gui_core/simplelmgr.py:138
+#, fuzzy
+msgid "Copy map names to clipboard (bottom to top)"
+#: ../gui/wxpython/gui_core/simplelmgr.py:418
+#, fuzzy
+msgid "Remove selected map(s) from list"
+msgstr "Pārsaukt izvēlēto karšu kopu"
+#: ../gui/wxpython/gui_core/simplelmgr.py:420
+#, fuzzy
+msgid "Layer up"
+msgstr "Slāņu grupa:"
+#: ../gui/wxpython/gui_core/simplelmgr.py:421
+#, fuzzy
+msgid "Move selected layer(s) up"
+#: ../gui/wxpython/gui_core/simplelmgr.py:423
+#, fuzzy
+msgid "Layer down"
+msgstr "Slāņa ID"
+#: ../gui/wxpython/gui_core/simplelmgr.py:424
+#, fuzzy
+msgid "Move selected layer(s) down"
+#: ../gui/wxpython/gui_core/simplelmgr.py:426
+#: ../gui/wxpython/gui_core/simplelmgr.py:427
+#, fuzzy
+msgid "Edit layer properties"
+msgstr "Vienuma īpašības"
+#: ../gui/wxpython/gui_core/simplelmgr.py:429
+#, fuzzy
+msgid "Change opacity"
+msgstr "Mainīt karšu kopu"
+#: ../gui/wxpython/gui_core/simplelmgr.py:430
+#, fuzzy
+msgid "Change layer opacity"
+msgstr "Pārvaldīt slāņus"
+#: ../gui/wxpython/gui_core/preferences.py:57
+msgid "User settings"
+msgstr "Lietotāja iestatījumi"
+#: ../gui/wxpython/gui_core/preferences.py:80
+msgid "Set to default"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:88
+msgid "Revert settings to default and apply changes"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:153
+msgid "Settings applied to current session but not saved"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:215
+msgid "Key column cannot be empty string."
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:229
+msgid "GUI Settings"
+msgstr "Grafiskās vides iestatījumi"
+#: ../gui/wxpython/gui_core/preferences.py:256
+msgid "Layer Manager settings"
+msgstr "Slāņu pārvaldnieka iestatījumi"
+#: ../gui/wxpython/gui_core/preferences.py:266
+msgid "Ask when removing map layer from layer tree"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:276
+msgid "Ask when quiting wxGUI or closing display"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:286
+#: ../gui/wxpython/gui_core/preferences.py:296
+#, python-format
+msgid "Hide '%s' tab (requires GUI restart)"
+msgstr ""
+msgid "Search module"
+msgstr "Meklēt moduli"
+#: ../gui/wxpython/gui_core/preferences.py:309
+msgid "Automatically copy selected text to clipboard (in Command console)"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:324
+msgid "Workspace settings"
+msgstr "Darbtelpas iestatījumi"
+#: ../gui/wxpython/gui_core/preferences.py:331
+msgid "Suppress positioning Map Display Window(s)"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:343
+msgid "Suppress positioning Layer Manager window"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:354
+msgid "Save current window layout as default"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:357
+msgid ""
+"Save current position and size of Layer Manager window and opened Map "
+"Display window(s) and use as default for next sessions."
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:393
+msgid "Font for command output:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:398
+#: ../gui/wxpython/gui_core/preferences.py:591
+#: ../gui/wxpython/mapwin/decorations.py:361
+#: ../gui/wxpython/animation/dialogs.py:849
 msgid "Set font"
 msgstr "Iestatīt fontu"
-#: ../gui/wxpython/gui_modules/gdialogs.py:834
-#: ../gui/wxpython/gui_core/dialogs.py:838
+#: ../gui/wxpython/gui_core/preferences.py:407
+msgid "Language settings"
+msgstr "Valodas iestatījumi"
+#: ../gui/wxpython/gui_core/preferences.py:416
+msgid "Choose language (requires to save and GRASS restart):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:439
+msgid "Appearance settings"
+msgstr "Izskata iestatījumi"
+#: ../gui/wxpython/gui_core/preferences.py:449
+msgid "Element list:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:471
+msgid "Menu style (requires to save and GUI restart):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:495
+msgid "Height of map selection popup window (in pixels):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:519
+msgid "Icon theme (requires GUI restart):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:539
+msgid "Module dialog style:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:572
+msgid "Map Display"
+#: ../gui/wxpython/gui_core/preferences.py:586
+msgid "Default font for GRASS displays:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:604
+msgid "Default display settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:614
+msgid "Display driver:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:634
+msgid "Statusbar mode:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:673
+#: ../gui/wxpython/mapdisp/statusbar.py:488
+msgid "Align region extent based on display size"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:686
+#: ../gui/wxpython/mapdisp/statusbar.py:527
+msgid "Constrain display resolution to computational settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:699
+msgid "Enable auto-rendering"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:712
+msgid "Enable auto-zooming to selected map layer"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:725
+msgid "Mouse wheel action:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:740
+msgid "Mouse scrolling direction:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:766
+#, fuzzy
+msgid "Advanced display settings"
+#: ../gui/wxpython/gui_core/preferences.py:772
+msgid "3D view depth buffer (possible values are 16, 24, 32):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:804
+msgid "Modules"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:807
+#, fuzzy
+msgid "Module dialog settings"
+#: ../gui/wxpython/gui_core/preferences.py:828
+#, fuzzy
+msgid "Close dialog when module is successfully finished"
+msgstr "Aizvērt dialogu, kad komandas izpilde ir pabeigta sekmīgi"
+#: ../gui/wxpython/gui_core/preferences.py:838
+#: ../gui/wxpython/gui_core/dialogs.py:271
+msgid "Add created map into layer tree"
+msgstr "Pievienot izveidoto karti slāņu sarakstam"
+#: ../gui/wxpython/gui_core/preferences.py:849
+msgid "Allow interactive input"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:859
+msgid "Verbosity level:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:884
+msgid "Layers"
+msgstr "Slāņi"
+#: ../gui/wxpython/gui_core/preferences.py:890
+msgid "Default raster settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:900
+msgid "Make null cells opaque"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:911
+msgid "Default color table"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:938
+msgid "Default vector settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:944
+msgid "Display:"
+msgstr "Attēlot:"
+#: ../gui/wxpython/gui_core/preferences.py:963
+msgid "Feature color:"
+msgstr "Objekta krāsa:"
+#: ../gui/wxpython/gui_core/preferences.py:985
+msgid "Area fill color:"
+msgstr "Poligona aizpildījuma krāsa:"
+#: ../gui/wxpython/gui_core/preferences.py:1028
+msgid "Symbol:"
+msgstr "Simbols:"
+#: ../gui/wxpython/gui_core/preferences.py:1055
+#: ../gui/wxpython/vdigit/preferences.py:361
+msgid "Attributes"
+msgstr "Atribūti"
+#: ../gui/wxpython/gui_core/preferences.py:1063
+#: ../gui/wxpython/dbmgr/base.py:1244
+msgid "Highlight selected features"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1081
+msgid "Line width (in pixels):"
+msgstr "Līnijas platums (pikseļos):"
+#: ../gui/wxpython/gui_core/preferences.py:1091
+msgid "Automatically hightlight selected features in map display"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1111
+msgid "Data browser"
+msgstr "Datu pārlūks"
+#: ../gui/wxpython/gui_core/preferences.py:1116
+msgid "Left mouse double click:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1128
+msgid "Encoding (e.g. utf-8, ascii, iso8859-1, koi8-r):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1139
+msgid "Ask when deleting data record(s) from table"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1160
+msgid "Create table"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1167
+#: ../gui/wxpython/gui_core/dialogs.py:303
+msgid "Key column:"
+msgstr "Atslēgas kolona:"
+#: ../gui/wxpython/gui_core/preferences.py:1194
+#: ../gui/wxpython/mapdisp/statusbar.py:765
+msgid "Projection"
+msgstr "Projekcija"
+#: ../gui/wxpython/gui_core/preferences.py:1201
+msgid "Projection statusbar settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1209
 msgid ""
-"Drag text with mouse in pointer mode to position.\n"
-"Double-click to change options"
+"\n"
+"Note: This only controls the coordinates displayed in the lower-left of the "
+"Map Display\n"
+"window's status bar. It is purely cosmetic and does not affect the working "
+"location's\n"
+"projection in any way. You will need to enable the Projection check box in "
+"the drop-down\n"
+"menu located at the bottom of the Map Display window.\n"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:915
-#: ../gui/wxpython/gui_core/dialogs.py:919
+#: ../gui/wxpython/gui_core/preferences.py:1241
+msgid "Proj.4 string (required):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1257
+msgid "EPSG file:"
+msgstr "EPSG fails:"
+#: ../gui/wxpython/gui_core/preferences.py:1272
+msgid ""
+"Load EPSG codes (be patient), enter EPSG code or insert Proj.4 string "
+"directly."
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1280
+msgid "&Load EPSG codes"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1292
+msgid "Coordinates format"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1300
+#, fuzzy
+msgid "Lat/long projections"
+#: ../gui/wxpython/gui_core/preferences.py:1319
+msgid "Precision:"
+msgstr "Precizitāte:"
+#: ../gui/wxpython/gui_core/preferences.py:1386
+#, python-format
+msgid "Unable to read EPSG codes: %s"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1415
+#: ../gui/wxpython/gui_core/preferences.py:1424
+#: ../gui/wxpython/gui_core/preferences.py:1433
+#, python-format
+msgid "EPSG code %s not found"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1441
+msgid "Select default display font"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1546
+msgid "Select font:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1570
+msgid "Character encoding:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1676
+msgid "Manage access to mapsets"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1689
+msgid ""
+"Check a mapset to make it accessible, uncheck it to hide it.\n"
+"  Notes:\n"
+"    - The current mapset is always accessible.\n"
+"    - You may only write to the current mapset.\n"
+"    - You may only write to mapsets which you own."
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1763
+msgid "Owner"
+msgstr ""
+#: ../gui/wxpython/gui_core/menu.py:139
+msgid "Double-click or Ctrl-Enter to run selected module"
+msgstr ""
+#: ../gui/wxpython/gui_core/menu.py:157
+msgid "Run selected module from the tree"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:76
+msgid "Required item is not set."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:106
+msgid "Select GRASS location and mapset"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:118
+msgid "Location or mapset is missing."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:125
+msgid "Name of GRASS location:"
+msgstr "GRASS novietojuma nosaukums:"
+#: ../gui/wxpython/gui_core/dialogs.py:131
+#: ../gui/wxpython/gui_core/dialogs.py:178
+msgid "Name of mapset:"
+msgstr "Karšu kopas nosaukums:"
+#: ../gui/wxpython/gui_core/dialogs.py:156
+msgid "Select mapset in GRASS location"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:170
+#, fuzzy
+msgid "Name of mapset is missing."
+#: ../gui/wxpython/gui_core/dialogs.py:189
+#: ../gui/wxpython/vdigit/toolbars.py:800
+#: ../gui/wxpython/vdigit/toolbars.py:940
+#: ../gui/wxpython/vdigit/toolbars.py:1027
+msgid "Select vector map"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:205
+#, fuzzy
+msgid "Name of vector map is missing."
+msgstr "Vektoru kartes nosaukums:"
+#: ../gui/wxpython/gui_core/dialogs.py:256
+msgid "Create attribute table"
+msgstr "Izveidot atribūtu tabulu"
+#: ../gui/wxpython/gui_core/dialogs.py:280
+#, fuzzy
+msgid "Name of new vector map is missing."
+msgstr "Jaunās vektoru kartes nosaukums:"
+#: ../gui/wxpython/gui_core/dialogs.py:289
+msgid "Name for new vector map:"
+#: ../gui/wxpython/gui_core/dialogs.py:386
+#, python-format
+msgid "Unable to create vector map <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:391
+#, python-format
+msgid ""
+"Invalid or empty key column.\n"
+"Unable to create vector map <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:418
+#, python-format
+msgid ""
+"Vector map <%s> already exists in the current mapset. Do you want to "
+"overwrite it?"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:500
+msgid "Load region:"
+msgstr "Ielādēt reģionu:"
+#: ../gui/wxpython/gui_core/dialogs.py:504
+msgid "Save region:"
+msgstr "Saglabāt reģionu:"
+#: ../gui/wxpython/gui_core/dialogs.py:546
 msgid "Create or edit imagery groups"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:933
-#: ../gui/wxpython/gui_core/dialogs.py:937
+#: ../gui/wxpython/gui_core/dialogs.py:579
 msgid "Apply changes to selected group and close dialog"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:934
-#: ../gui/wxpython/gui_core/dialogs.py:938
+#: ../gui/wxpython/gui_core/dialogs.py:580
 msgid "Apply changes to selected group"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:935
-#: ../gui/wxpython/gui_core/dialogs.py:939
+#: ../gui/wxpython/gui_core/dialogs.py:581
 msgid "Close dialog, changes are not applied"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:976
-#: ../gui/wxpython/gui_core/dialogs.py:980
-msgid "Select the group you want to edit or enter name of new group:"
+#: ../gui/wxpython/gui_core/dialogs.py:622
+#: ../gui/wxpython/gui_core/dialogs.py:1367
+msgid ""
+"Put here a regular expression. Characters '.*' stand for anything, character "
+"'^' stands for the beginning and '$' for the end."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:987
-#: ../gui/wxpython/gui_core/dialogs.py:991
-msgid "Layers in selected group:"
+#: ../gui/wxpython/gui_core/dialogs.py:629
+msgid "Select existing group or enter name of new group:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:999
-#: ../gui/wxpython/gui_core/dialogs.py:1003
+#: ../gui/wxpython/gui_core/dialogs.py:640
+msgid "Edit/create subgroup"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:649
+msgid "Select existing subgroup or enter name of new subgroup:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:671
+#: ../gui/wxpython/gui_core/dialogs.py:724
+#: ../gui/wxpython/gui_core/dialogs.py:1429
+#: ../gui/wxpython/gui_core/widgets.py:788 ../gui/wxpython/dbmgr/base.py:1241
+msgid "Select all"
+#: ../gui/wxpython/gui_core/dialogs.py:677
+#: ../gui/wxpython/gui_core/dialogs.py:730
+#: ../gui/wxpython/gui_core/dialogs.py:1354
+msgid "Pattern:"
+msgstr "Šablons:"
+#: ../gui/wxpython/gui_core/dialogs.py:692
+#: ../gui/wxpython/gui_core/dialogs.py:744
+#: ../gui/wxpython/gui_core/dialogs.py:1373
+msgid "List of maps:"
+msgstr "Karšu saraksts:"
+#: ../gui/wxpython/gui_core/dialogs.py:702
 msgid "Select map layers and add them to the list."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1003
-#: ../gui/wxpython/gui_core/dialogs.py:1007
+#: ../gui/wxpython/gui_core/dialogs.py:706
 msgid "Remove selected layer(s) from list."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1024
-#: ../gui/wxpython/gui_core/dialogs.py:1032
+#: ../gui/wxpython/gui_core/dialogs.py:749
+msgid "Check maps from group to be included into subgroup."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:907
 msgid "Add selected map layers into group"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1058
-#: ../gui/wxpython/gui_core/dialogs.py:1065
+#: ../gui/wxpython/gui_core/dialogs.py:1042
 #, python-format
 msgid "Group <%s> was changed, do you want to apply changes?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1060
-#: ../gui/wxpython/gui_core/dialogs.py:1067
+#: ../gui/wxpython/gui_core/dialogs.py:1044
+#: ../gui/wxpython/gui_core/dialogs.py:1056
 msgid "Unapplied changes"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1132
-#: ../gui/wxpython/gui_core/dialogs.py:1149
+#: ../gui/wxpython/gui_core/dialogs.py:1054
 #, python-format
+msgid "Subgroup <%s> was changed, do you want to apply changes?"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1110
+#, fuzzy
+msgid "No raster maps selected."
+msgstr "Pievienot rastra karti"
+#: ../gui/wxpython/gui_core/dialogs.py:1139
+#, python-format
 msgid "No changes to apply in group <%s>."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1135
-#: ../gui/wxpython/gui_core/dialogs.py:1152
+#: ../gui/wxpython/gui_core/dialogs.py:1142
 #, python-format
 msgid "Group <%s> was successfully created."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1137
-#: ../gui/wxpython/gui_core/dialogs.py:1154
+#: ../gui/wxpython/gui_core/dialogs.py:1144
 #, python-format
 msgid "Group <%s> was successfully changed."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1140
-#: ../gui/wxpython/gui_core/dialogs.py:1157
+#: ../gui/wxpython/gui_core/dialogs.py:1147
 #, python-format
 msgid "Creating of new group <%s> failed."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1142
-#: ../gui/wxpython/gui_core/dialogs.py:1159
+#: ../gui/wxpython/gui_core/dialogs.py:1149
 #, python-format
 msgid "Changing of group <%s> failed."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1171
-#: ../gui/wxpython/gui_core/dialogs.py:1188
+#: ../gui/wxpython/gui_core/dialogs.py:1187
 msgid "No group selected."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1228
-#: ../gui/wxpython/gui_core/dialogs.py:1283
-msgid "Use fully-qualified map names"
+#: ../gui/wxpython/gui_core/dialogs.py:1193
+msgid "No subgroup selected."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1235
-#: ../gui/wxpython/gui_core/dialogs.py:1547
-#, python-format
-msgid "Dynamic series (%s)"
+#: ../gui/wxpython/gui_core/dialogs.py:1296
+msgid "Use fully-qualified map names"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1273
-#: ../gui/wxpython/gui_core/dialogs.py:1311
+#: ../gui/wxpython/gui_core/dialogs.py:1312
+msgid "3D raster"
+msgstr "3D rastrs"
+#: ../gui/wxpython/gui_core/dialogs.py:1322
 msgid "Map type:"
 msgstr "Kartes tips:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1291
-#: ../gui/wxpython/gui_core/dialogs.py:1326
+#: ../gui/wxpython/gui_core/dialogs.py:1337
 msgid "Select toggle"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1298
-#: ../gui/wxpython/gui_core/dialogs.py:1333
+#: ../gui/wxpython/gui_core/dialogs.py:1344
 msgid "Mapset:"
 msgstr "Karšu kopa:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1308
-#: ../gui/wxpython/gui_core/dialogs.py:1343
-msgid "Pattern:"
-msgstr "Šablons:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1320
-#: ../gui/wxpython/gui_core/dialogs.py:1359
-msgid "List of maps:"
-msgstr "Karšu saraksts:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1374
-#: ../gui/wxpython/gui_modules/gdialogs.py:2046
-#: ../gui/wxpython/gui_modules/dbm.py:1128
-#: ../gui/wxpython/gui_core/dialogs.py:1412
-#: ../gui/wxpython/gui_core/dialogs.py:2150
-#: ../gui/wxpython/dbmgr/manager.py:1132
-msgid "Select all"
-msgstr "Izvēlēties visu"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1375
-#: ../gui/wxpython/gui_core/dialogs.py:1413
+#: ../gui/wxpython/gui_core/dialogs.py:1430
 msgid "Invert selection"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1376
-#: ../gui/wxpython/gui_modules/gdialogs.py:2047
-#: ../gui/wxpython/gui_modules/dbm.py:1129
-#: ../gui/wxpython/gui_core/dialogs.py:1414
-#: ../gui/wxpython/gui_core/dialogs.py:2151
-#: ../gui/wxpython/dbmgr/manager.py:1133
+#: ../gui/wxpython/gui_core/dialogs.py:1431
+#: ../gui/wxpython/gui_core/widgets.py:789 ../gui/wxpython/dbmgr/base.py:1242
 msgid "Deselect all"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1482
-#: ../gui/wxpython/gui_core/dialogs.py:1572
+#: ../gui/wxpython/gui_core/dialogs.py:1564
+#, python-format
+msgid "Dynamic series (%s)"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1589
 msgid "Multiple import"
 msgstr "Importēt vairākus"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1496
-#: ../gui/wxpython/gui_core/dialogs.py:1586
-#, python-format
-msgid " List of %s layers "
+#: ../gui/wxpython/gui_core/dialogs.py:1605
+#, fuzzy
+msgid "List of raster layers"
 msgstr " %s slāņu saraksts"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1501
-#: ../gui/wxpython/gui_core/dialogs.py:1591
+#: ../gui/wxpython/gui_core/dialogs.py:1607
+#, fuzzy
+msgid "List of vector layers"
+msgstr "Slāņu saraksts"
+#: ../gui/wxpython/gui_core/dialogs.py:1609
+#, fuzzy, python-format
+msgid "List of %s layers"
+msgstr " %s slāņu saraksts"
+#: ../gui/wxpython/gui_core/dialogs.py:1610
+msgid "right click to (un)select all"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1613
 msgid "Layer id"
 msgstr "Slāņa ID"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1502
-#: ../gui/wxpython/gui_core/dialogs.py:1592
-msgid "Layer name"
-msgstr "Slāņa nosaukums"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1503
-#: ../gui/wxpython/gui_core/dialogs.py:1593
-msgid "Name for GRASS map (editable)"
+#: ../gui/wxpython/gui_core/dialogs.py:1615
+#, fuzzy
+msgid "Name for output GRASS map (editable)"
 msgstr "GRASS kartes nosaukums (rediģējams)"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1510
-#: ../gui/wxpython/gui_modules/ghelp.py:821
-#: ../gui/wxpython/gui_core/dialogs.py:1600
-#: ../gui/wxpython/modules/extensions.py:67
+#: ../gui/wxpython/gui_core/dialogs.py:1618
+#, fuzzy
+msgid "Projection match"
+#: ../gui/wxpython/gui_core/dialogs.py:1624
+#: ../gui/wxpython/modules/extensions.py:68
 msgid "Options"
 msgstr "Opcijas"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1556
-#: ../gui/wxpython/gui_modules/gdialogs.py:1831
-#: ../gui/wxpython/gui_modules/ghelp.py:848
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:136
-#: ../gui/wxpython/gui_core/dialogs.py:1646
-#: ../gui/wxpython/gui_core/dialogs.py:1935
-#: ../gui/wxpython/modules/extensions.py:102
-#: ../gui/wxpython/modules/extensions.py:406
-#: ../gui/wxpython/modules/mcalc_builder.py:132
-msgid "Command dialog"
-msgstr "Komandas dialogs"
+#: ../gui/wxpython/gui_core/dialogs.py:1666
+#: ../gui/wxpython/gui_core/dialogs.py:1840
+msgid "&Import"
+msgstr "&Importēt"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1710
-#: ../gui/wxpython/gui_core/dialogs.py:1801
-msgid "Add linked layers into layer tree"
+#: ../gui/wxpython/gui_core/dialogs.py:1667
+#: ../gui/wxpython/gui_core/dialogs.py:1841
+msgid "Import selected layers"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1717
-#: ../gui/wxpython/gui_core/dialogs.py:1808
+#: ../gui/wxpython/gui_core/dialogs.py:1826
+msgid "this might not work for multiple bands"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1828
+#, python-brace-format
+msgid "Add linked layers into layer tree ({mightNotWork})"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1831
+#, fuzzy, python-brace-format
+msgid "Add imported layers into layer tree ({mightNotWork})"
+#: ../gui/wxpython/gui_core/dialogs.py:1837
 msgid "&Link"
 msgstr "&Saite"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1718
-#: ../gui/wxpython/gui_core/dialogs.py:1809
+#: ../gui/wxpython/gui_core/dialogs.py:1838
 msgid "Link selected layers"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1720
-#: ../gui/wxpython/gui_modules/gdialogs.py:1722
-#: ../gui/wxpython/gui_modules/gdialogs.py:1727
-#: ../gui/wxpython/gui_modules/gdialogs.py:1729
-#: ../gui/wxpython/gui_modules/ghelp.py:849
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:137
-#: ../gui/wxpython/gui_core/dialogs.py:1811
-#: ../gui/wxpython/gui_core/dialogs.py:1813
-#: ../gui/wxpython/gui_core/dialogs.py:1818
-#: ../gui/wxpython/gui_core/dialogs.py:1820
-#: ../gui/wxpython/modules/extensions.py:103
-#: ../gui/wxpython/modules/extensions.py:407
-#: ../gui/wxpython/modules/mcalc_builder.py:133
-#, python-format
-msgid "Open %s dialog"
+#: ../gui/wxpython/gui_core/dialogs.py:1850
+msgid "No layers selected. Operation canceled."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1823
-#: ../gui/wxpython/gui_core/dialogs.py:1927
+#: ../gui/wxpython/gui_core/dialogs.py:1947
 msgid "Define output format for vector data"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1825
-#: ../gui/wxpython/gui_core/dialogs.py:1929
+#: ../gui/wxpython/gui_core/dialogs.py:1949
 msgid "Define output format for raster data"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1836
-#: ../gui/wxpython/gui_core/dialogs.py:1940
+#: ../gui/wxpython/gui_core/dialogs.py:1957
 msgid "Set external format and close dialog"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1905
 #: ../gui/wxpython/gui_core/dialogs.py:2009
+msgid "No data source selected."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2022
 msgid "Import DXF layers"
 msgstr "Importēt DXF slāņus"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1909
-#: ../gui/wxpython/gui_core/dialogs.py:2013
+#: ../gui/wxpython/gui_core/dialogs.py:2026
 msgid "Choose DXF file to import"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:2114
-#: ../gui/wxpython/gui_core/dialogs.py:2218
+#: ../gui/wxpython/gui_core/dialogs.py:2032
+msgid "Add imported layers into layer tree"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2046
+msgid "No layers selected."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2175
 msgid "Set Map Layer Opacity"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:2141
-#: ../gui/wxpython/gui_core/dialogs.py:2245
+#: ../gui/wxpython/gui_core/dialogs.py:2203
 msgid "opaque"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:2260
-#: ../gui/wxpython/gui_core/dialogs.py:2333
+#: ../gui/wxpython/gui_core/dialogs.py:2299
 msgid "Set image size"
 msgstr "Iestatīt attēla izmēru"
-#: ../gui/wxpython/gui_modules/gdialogs.py:2269
-#: ../gui/wxpython/gui_core/dialogs.py:2342
+#: ../gui/wxpython/gui_core/dialogs.py:2308
 msgid "Image size"
 msgstr "Attēla izmērs"
-#: ../gui/wxpython/gui_modules/gdialogs.py:2316
-#: ../gui/wxpython/gui_core/dialogs.py:2389
+#: ../gui/wxpython/gui_core/dialogs.py:2355
 msgid "Template:"
 msgstr "Šablons:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:2354
-#: ../gui/wxpython/gui_core/dialogs.py:2427
+#: ../gui/wxpython/gui_core/dialogs.py:2393
 msgid "GRASS GIS SQL Query Utility"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:2365
-#: ../gui/wxpython/gui_core/dialogs.py:2438
+#: ../gui/wxpython/gui_core/dialogs.py:2404
 msgid " SQL statement "
 msgstr " SQL izteikums "
-#: ../gui/wxpython/gui_modules/psmap.py:615
-#, fuzzy
-msgid "North arrow"
-msgstr "Ziemeļu bulta"
+#: ../gui/wxpython/gui_core/dialogs.py:2449
+msgid "Symbols"
+msgstr "Simboli"
-#: ../gui/wxpython/gui_modules/menudata.py:89
-#: ../gui/wxpython/core/menudata.py:84
-msgid "Unknow tag"
+#: ../gui/wxpython/gui_core/dialogs.py:2476
+msgid "Symbol directory:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm_dialogs.py:70
-#: ../gui/wxpython/dbmgr/dialogs.py:71
-#, python-format
-msgid ""
-"No attribute table found.\n"
-"\n"
-"Do you want to create a new attribute table and defined a link to vector map "
-"<%s>?"
+#: ../gui/wxpython/gui_core/dialogs.py:2484
+msgid "Symbol name:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm_dialogs.py:73
-#: ../gui/wxpython/dbmgr/dialogs.py:74
-msgid "Create table?"
-msgstr "Izveidot tabulu?"
+#: ../gui/wxpython/gui_core/ghelp.py:57
+msgid "Info"
+msgstr "Informācija"
-#: ../gui/wxpython/gui_modules/dbm_dialogs.py:93
-#: ../gui/wxpython/dbmgr/dialogs.py:94
-msgid "Close dialog on submit"
-msgstr "Aizvērt dialogu pēc vērtības ierakstīšanas"
+#: ../gui/wxpython/gui_core/ghelp.py:58
+msgid "Copyright"
+msgstr "Autortiesības"
-#: ../gui/wxpython/gui_modules/dbm_dialogs.py:105
-#: ../gui/wxpython/dbmgr/dialogs.py:106
-msgid "No attributes found"
-msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:59
+msgid "License"
+msgstr "Licence"
-#: ../gui/wxpython/gui_modules/dbm_dialogs.py:113
-#: ../gui/wxpython/dbmgr/dialogs.py:114
-msgid "Define attributes"
-msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:60
+msgid "Authors"
+msgstr "Autori"
-#: ../gui/wxpython/gui_modules/dbm_dialogs.py:115
-#: ../gui/wxpython/dbmgr/dialogs.py:116
-msgid "Display attributes"
+#: ../gui/wxpython/gui_core/ghelp.py:61
+msgid "Contributors"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm_dialogs.py:119
-#: ../gui/wxpython/dbmgr/dialogs.py:120
-msgid "&Reload"
+#: ../gui/wxpython/gui_core/ghelp.py:62
+msgid "Extra contributors"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm_dialogs.py:120
-#: ../gui/wxpython/gui_modules/dbm_dialogs.py:564
-#: ../gui/wxpython/dbmgr/dialogs.py:121 ../gui/wxpython/dbmgr/dialogs.py:589
-msgid "&Submit"
-msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:63
+msgid "Translators"
+msgstr "Tulkotāji"
-#: ../gui/wxpython/gui_modules/dbm_dialogs.py:138
-#: ../gui/wxpython/gui_modules/vdigit.py:953
-#: ../gui/wxpython/dbmgr/dialogs.py:139 ../gui/wxpython/vdigit/dialogs.py:166
-msgid "Feature id:"
-msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:64
+msgid "Translation status"
+msgstr "Tulkošanas statuss"
-#: ../gui/wxpython/gui_modules/dbm_dialogs.py:403
-#: ../gui/wxpython/dbmgr/dialogs.py:428
-msgid "Unknown"
-msgstr "Nezināms"
+#: ../gui/wxpython/gui_core/ghelp.py:124
+msgid "Official GRASS site:"
+msgstr "Oficiālā GRASS GIS lapa:"
-#: ../gui/wxpython/gui_modules/dbm_dialogs.py:460
-#: ../gui/wxpython/gui_modules/dbm.py:2288
-#: ../gui/wxpython/gui_modules/dbm.py:2403
-#: ../gui/wxpython/gui_modules/dbm.py:2652
-#: ../gui/wxpython/gui_modules/vdigit.py:395
-#: ../gui/wxpython/gui_modules/vdigit.py:397
-#: ../gui/wxpython/gui_modules/vdigit.py:898
-#: ../gui/wxpython/gui_modules/vdigit.py:1342
-#: ../gui/wxpython/dbmgr/dialogs.py:485 ../gui/wxpython/dbmgr/manager.py:2314
-#: ../gui/wxpython/dbmgr/manager.py:2427 ../gui/wxpython/dbmgr/manager.py:2678
-#: ../gui/wxpython/vdigit/preferences.py:362
-#: ../gui/wxpython/vdigit/preferences.py:364
-#: ../gui/wxpython/vdigit/dialogs.py:111 ../gui/wxpython/vdigit/dialogs.py:555
-msgid "Layer"
-msgstr "Slānis"
+#: ../gui/wxpython/gui_core/ghelp.py:135
+#, fuzzy
+msgid "Code Revision"
+msgstr "SVN revīzija:"
-#: ../gui/wxpython/gui_modules/dbm_dialogs.py:461
-#: ../gui/wxpython/gui_modules/dbm_dialogs.py:578
-#: ../gui/wxpython/gui_modules/vdigit.py:905
-#: ../gui/wxpython/gui_modules/vdigit.py:1343
-#: ../gui/wxpython/dbmgr/dialogs.py:486 ../gui/wxpython/dbmgr/dialogs.py:604
-#: ../gui/wxpython/vdigit/dialogs.py:118 ../gui/wxpython/vdigit/dialogs.py:556
-msgid "Category"
-msgstr "Kategorija"
+#: ../gui/wxpython/gui_core/ghelp.py:198 ../gui/wxpython/gui_core/ghelp.py:410
+msgid "Language"
+msgstr "Valoda"
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1110
+#: ../gui/wxpython/gui_core/ghelp.py:227 ../gui/wxpython/gui_core/ghelp.py:251
+#: ../gui/wxpython/gui_core/ghelp.py:275 ../gui/wxpython/gui_core/ghelp.py:332
+#: ../gui/wxpython/gui_core/ghelp.py:394 ../gui/wxpython/gui_core/ghelp.py:544
 #, python-format
-msgid "Failed to read instruction %s: file %s not found."
+msgid "%s file missing"
 msgstr ""
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3211
-msgid "properties"
-msgstr "īpašības"
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5971
+#: ../gui/wxpython/gui_core/ghelp.py:318 ../gui/wxpython/gui_core/ghelp.py:380
 #, python-format
-msgid "size: %s x %s pts"
+msgid "Error when reading file '%s'."
 msgstr ""
-#: ../gui/wxpython/gui_modules/vclean.py:37
-msgid "set up vector cleaning tools"
-msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:319 ../gui/wxpython/gui_core/ghelp.py:381
+msgid "Lines:"
+msgstr "Rindas:"
-#: ../gui/wxpython/gui_modules/vclean.py:76
-#: ../gui/wxpython/modules/vclean.py:68
-msgid "break lines/boundaries"
-msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:337 ../gui/wxpython/gui_core/ghelp.py:339
+#: ../gui/wxpython/gui_core/ghelp.py:406
+msgid "E-mail"
+msgstr "E-pasts"
-#: ../gui/wxpython/gui_modules/vclean.py:77
-#: ../gui/wxpython/modules/vclean.py:69
-msgid "remove duplicates"
-msgstr ""
+msgid "Country"
+msgstr "Valsts"
-#: ../gui/wxpython/gui_modules/vclean.py:78
-#: ../gui/wxpython/modules/vclean.py:70
-msgid "remove dangles"
-msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:339
+msgid "OSGeo_ID"
+msgstr "OSGeo_ID"
-#: ../gui/wxpython/gui_modules/vclean.py:79
-#: ../gui/wxpython/modules/vclean.py:71
-msgid "change boundary dangles to lines"
-msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:414
+msgid "Nation"
+msgstr "Valoda"
-#: ../gui/wxpython/gui_modules/vclean.py:80
-#: ../gui/wxpython/modules/vclean.py:72
-msgid "remove bridges"
-msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:449
+#, python-format
+msgid "   %d translated"
+msgstr "   %d iztulkots"
-#: ../gui/wxpython/gui_modules/vclean.py:81
-#: ../gui/wxpython/modules/vclean.py:73
-msgid "change bridges to lines"
-msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:453 ../gui/wxpython/gui_core/ghelp.py:479
+#, python-format
+msgid "   %d fuzzy"
+msgstr "   %d neskaidrs"
-#: ../gui/wxpython/gui_modules/vclean.py:82
-#: ../gui/wxpython/modules/vclean.py:74
-msgid "snap lines/boundaries"
-msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:457 ../gui/wxpython/gui_core/ghelp.py:488
+#, python-format
+msgid "   %d untranslated"
+msgstr "   %d netulkots"
-#: ../gui/wxpython/gui_modules/vclean.py:83
-#: ../gui/wxpython/modules/vclean.py:75
-msgid "remove duplicate area centroids"
-msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:470
+#, python-format
+msgid "%d translated"
+msgstr "%d tulkots"
-#: ../gui/wxpython/gui_modules/vclean.py:84
-#: ../gui/wxpython/modules/vclean.py:76
-msgid "break polygons"
-msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:541
+#, python-format
+msgid "File <%s> not found"
+msgstr "Fails <%s> nav atrasts"
-#: ../gui/wxpython/gui_modules/vclean.py:85
-#: ../gui/wxpython/modules/vclean.py:77
-msgid "prune lines/boundaries"
-msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:695
+msgid "&Next"
+msgstr "&Nākamais"
-#: ../gui/wxpython/gui_modules/vclean.py:86
-#: ../gui/wxpython/modules/vclean.py:78
-msgid "remove small areas"
-msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:698
+msgid "&Previous"
+msgstr "&Iepriekšējais"
-#: ../gui/wxpython/gui_modules/vclean.py:87
-#: ../gui/wxpython/modules/vclean.py:79
-msgid "remove lines/boundaries of zero length"
+#: ../gui/wxpython/gui_core/widgets.py:82
+msgid " (...)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vclean.py:88
-#: ../gui/wxpython/modules/vclean.py:80
-msgid "remove small angles at nodes"
+#: ../gui/wxpython/gui_core/widgets.py:851
+msgid "Fulltext search"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vclean.py:121
-#: ../gui/wxpython/gui_modules/vclean.py:122
-#: ../gui/wxpython/modules/vclean.py:31 ../gui/wxpython/modules/vclean.py:113
-msgid "Set up vector cleaning tools"
+#: ../gui/wxpython/gui_core/widgets.py:852
+msgid "Type to search in all modules. Press Enter for next match."
 msgstr ""
-#: ../gui/wxpython/gui_modules/vclean.py:124
-#: ../gui/wxpython/modules/vclean.py:115
-msgid "Choose cleaning tools and set thresholds"
+#: ../gui/wxpython/gui_core/widgets.py:909
+msgid "Searching, please type more characters."
 msgstr ""
-#: ../gui/wxpython/gui_modules/vclean.py:128
-#: ../gui/wxpython/modules/vclean.py:119
-msgid "Select input vector map:"
+#: ../gui/wxpython/gui_core/widgets.py:918
+#, python-format
+msgid "%d modules match"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vclean.py:134
-#: ../gui/wxpython/modules/vclean.py:125
-msgid " Feature type: "
-msgstr " Objekta tips: "
+#: ../gui/wxpython/gui_core/widgets.py:992
+msgid "Save current settings"
+msgstr "Saglabāt pašreizējos iestatījumus"
-#: ../gui/wxpython/gui_modules/vclean.py:138
-#: ../gui/wxpython/modules/vclean.py:129
-msgid "Select output vector map:"
+#: ../gui/wxpython/gui_core/widgets.py:995
+msgid "Delete currently selected settings"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vclean.py:168
-#: ../gui/wxpython/gui_modules/menuform.py:510
-#: ../gui/wxpython/gui_core/forms.py:467 ../gui/wxpython/modules/vclean.py:159
-msgid "Copy the current command string to the clipboard (Ctrl+C)"
+#: ../gui/wxpython/gui_core/widgets.py:1013
+msgid "Load settings:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vclean.py:205
-#: ../gui/wxpython/modules/vclean.py:195
-msgid "line"
-msgstr "līnija"
-#: ../gui/wxpython/gui_modules/vclean.py:206
-#: ../gui/wxpython/modules/vclean.py:196
-msgid "boundary"
-msgstr "robeža"
-#: ../gui/wxpython/gui_modules/vclean.py:207
-#: ../gui/wxpython/modules/vclean.py:197
-msgid "centroid"
-msgstr "centroīds"
-#: ../gui/wxpython/gui_modules/vclean.py:208
-#: ../gui/wxpython/gui_modules/vdigit.py:450
-#: ../gui/wxpython/modules/vclean.py:198
-#: ../gui/wxpython/vdigit/preferences.py:417
-msgid "area"
-msgstr "laukums"
-#: ../gui/wxpython/gui_modules/vclean.py:209
-#: ../gui/wxpython/modules/vclean.py:199
-msgid "face"
-msgstr "fasete"
-#: ../gui/wxpython/gui_modules/vclean.py:363
-#: ../gui/wxpython/modules/vclean.py:355
+#: ../gui/wxpython/gui_core/widgets.py:1034
 #, python-format
-msgid "%s. cleaning tool removed, will be ignored"
+msgid "Settings <%s> not found"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vclean.py:365
-#: ../gui/wxpython/modules/vclean.py:357
-msgid "Please select a cleaning tool to remove"
-msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1044
+#: ../gui/wxpython/gui_core/widgets.py:1060
+msgid "Save settings"
+msgstr "Saglabāt iestatījumus"
-#: ../gui/wxpython/gui_modules/vclean.py:386
-#: ../gui/wxpython/modules/vclean.py:378
-#, python-format
-msgid "%s. cleaning tool moved up"
+#: ../gui/wxpython/gui_core/widgets.py:1049
+msgid "Name not given, settings is not saved."
 msgstr ""
-#: ../gui/wxpython/gui_modules/vclean.py:388
-#: ../gui/wxpython/modules/vclean.py:380
-msgid "1. cleaning tool can not be moved up "
-msgstr ""
-#: ../gui/wxpython/gui_modules/vclean.py:390
-#: ../gui/wxpython/modules/vclean.py:382
-msgid "Please select a cleaning tool to move up"
-msgstr ""
-#: ../gui/wxpython/gui_modules/vclean.py:413
-#: ../gui/wxpython/modules/vclean.py:405
+#: ../gui/wxpython/gui_core/widgets.py:1058
 #, python-format
-msgid "%s. cleaning tool moved down"
+msgid "Settings <%s> already exists. Do you want to overwrite the settings?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vclean.py:415
-#: ../gui/wxpython/modules/vclean.py:407
-msgid "Last cleaning tool can not be moved down "
+#: ../gui/wxpython/gui_core/widgets.py:1099
+msgid "No settings is defined. Operation canceled."
 msgstr ""
-#: ../gui/wxpython/gui_modules/vclean.py:417
-#: ../gui/wxpython/modules/vclean.py:409
-msgid "Please select a cleaning tool to move down"
+#: ../gui/wxpython/gui_core/widgets.py:1133
+msgid "Unable to save settings"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vclean.py:428
-#: ../gui/wxpython/modules/vclean.py:420
+#: ../gui/wxpython/gui_core/mapdisp.py:107 ../gui/wxpython/core/render.py:460
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:94
 #, python-format
-msgid "cleaning tool: '%s'"
+msgid "GRASS module '%s' not found. Unable to start map display window."
 msgstr ""
-#: ../gui/wxpython/gui_modules/vclean.py:436
-#: ../gui/wxpython/modules/vclean.py:428
+#: ../gui/wxpython/dbmgr/g.gui.dbmgr.py:52
 #, python-format
-msgid "Threshold for %(num)s. tool '%(tool)s': %(thresh)s"
+msgid "Loading attribute data for vector map <%s>..."
 msgstr ""
-#: ../gui/wxpython/gui_modules/vclean.py:457
-#: ../gui/wxpython/modules/vclean.py:468
-msgid "Executing selected cleaning operations..."
-msgstr ""
+#: ../gui/wxpython/dbmgr/g.gui.dbmgr.py:54
+msgid "GRASS GIS Attribute Table Manager"
+msgstr "GRASS GIS atribūtu tabulas pārvaldnieks"
-#: ../gui/wxpython/gui_modules/vclean.py:514
-#: ../gui/wxpython/modules/vclean.py:524
-msgid "Vector cleaning command copied to clipboard"
-msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:140 ../gui/wxpython/dbmgr/manager.py:145
-msgid "Loading data..."
-msgstr "Datu ielāde..."
-#: ../gui/wxpython/gui_modules/dbm.py:147 ../gui/wxpython/dbmgr/manager.py:152
+#: ../gui/wxpython/dbmgr/base.py:154
 #, python-format
 msgid ""
 "Attribute table <%s> not found. For creating the table switch to 'Manage "
 "layers' tab."
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:158 ../gui/wxpython/dbmgr/manager.py:163
+#: ../gui/wxpython/dbmgr/base.py:165
 #, python-format
 msgid "Column <%(column)s> not found in in the table <%(table)s>."
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:230 ../gui/wxpython/dbmgr/manager.py:234
+#: ../gui/wxpython/dbmgr/base.py:238
 msgid "Can display only 256 columns."
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:246 ../gui/wxpython/dbmgr/manager.py:250
-msgid "Limit 100000 records."
+#: ../gui/wxpython/dbmgr/base.py:253
+#, python-format
+msgid "Inconsistent number of columns in the table <%(table)s>."
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:263
-#: ../gui/wxpython/gui_modules/dbm.py:809
-#: ../gui/wxpython/gui_modules/dbm.py:1151
-#: ../gui/wxpython/gui_modules/dbm.py:1809
-#: ../gui/wxpython/gui_modules/dbm.py:1831
-#: ../gui/wxpython/gui_modules/dbm.py:1973
-#: ../gui/wxpython/dbmgr/manager.py:267 ../gui/wxpython/dbmgr/manager.py:821
-#: ../gui/wxpython/dbmgr/manager.py:1155 ../gui/wxpython/dbmgr/manager.py:1824
-#: ../gui/wxpython/dbmgr/manager.py:1846 ../gui/wxpython/dbmgr/manager.py:1990
+#: ../gui/wxpython/dbmgr/base.py:263
+msgid "Viewing limit: 100000 records."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:280 ../gui/wxpython/dbmgr/base.py:808
+#: ../gui/wxpython/dbmgr/base.py:962 ../gui/wxpython/dbmgr/base.py:1264
+#: ../gui/wxpython/dbmgr/base.py:1849 ../gui/wxpython/dbmgr/manager.py:188
 #, python-format
 msgid "Number of loaded records: %d"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:287 ../gui/wxpython/dbmgr/manager.py:291
+#: ../gui/wxpython/dbmgr/base.py:304
 msgid "Unknown value"
 msgstr "Nezināma vērtība"
-#: ../gui/wxpython/gui_modules/dbm.py:302 ../gui/wxpython/dbmgr/manager.py:306
+#: ../gui/wxpython/dbmgr/base.py:310
+msgid "Unable to decode value. Set encoding in GUI preferences ('Attributes')."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:319
 #, python-format
 msgid ""
 "Error loading attribute data. Record number: %(rec)d. Unable to convert "
@@ -11084,317 +11618,282 @@
 "Details: %(detail)s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:384 ../gui/wxpython/dbmgr/manager.py:388
+#: ../gui/wxpython/dbmgr/base.py:412
 msgid "Sort ascending"
 msgstr "Kārtot augoši"
-#: ../gui/wxpython/gui_modules/dbm.py:385 ../gui/wxpython/dbmgr/manager.py:389
+#: ../gui/wxpython/dbmgr/base.py:413
 msgid "Sort descending"
 msgstr "Kārtot dilstoši"
-#: ../gui/wxpython/gui_modules/dbm.py:388 ../gui/wxpython/dbmgr/manager.py:392
+#: ../gui/wxpython/dbmgr/base.py:416
 msgid "Calculate (only numeric columns)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:394 ../gui/wxpython/dbmgr/manager.py:398
+#: ../gui/wxpython/dbmgr/base.py:418
+msgid "Field calculator"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:423 ../gui/wxpython/dbmgr/base.py:2022
+#: ../gui/wxpython/modules/colorrules.py:1020
+msgid "Add column"
+msgstr "Pievienot kolonu"
+#: ../gui/wxpython/dbmgr/base.py:434
 msgid "Area size"
 msgstr "Laukuma platība"
-#: ../gui/wxpython/gui_modules/dbm.py:395 ../gui/wxpython/dbmgr/manager.py:399
+#: ../gui/wxpython/dbmgr/base.py:435
 msgid "Line length"
 msgstr "Līnijas garums"
-#: ../gui/wxpython/gui_modules/dbm.py:396 ../gui/wxpython/dbmgr/manager.py:400
+#: ../gui/wxpython/dbmgr/base.py:436
 msgid "Compactness of an area"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:397 ../gui/wxpython/dbmgr/manager.py:401
+#: ../gui/wxpython/dbmgr/base.py:437
 msgid "Fractal dimension of boundary defining a polygon"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:398 ../gui/wxpython/dbmgr/manager.py:402
+#: ../gui/wxpython/dbmgr/base.py:438
 msgid "Perimeter length of an area"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:399 ../gui/wxpython/dbmgr/manager.py:403
+#: ../gui/wxpython/dbmgr/base.py:439
 msgid "Number of features for each category"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:400 ../gui/wxpython/dbmgr/manager.py:404
+#: ../gui/wxpython/dbmgr/base.py:440
 msgid "Slope steepness of 3D line"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:401 ../gui/wxpython/dbmgr/manager.py:405
+#: ../gui/wxpython/dbmgr/base.py:441
 msgid "Line sinuousity"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:402 ../gui/wxpython/dbmgr/manager.py:406
+#: ../gui/wxpython/dbmgr/base.py:442
 msgid "Line azimuth"
 msgstr "Līnijas azimuts"
-#: ../gui/wxpython/gui_modules/dbm.py:561
-#: ../gui/wxpython/gui_modules/dbm.py:3082
-#: ../gui/wxpython/dbmgr/manager.py:565 ../gui/wxpython/dbmgr/manager.py:3104
-msgid "GRASS GIS Attribute Table Manager"
-msgstr "GRASS GIS atribūtu tabulas pārvaldnieks"
-#: ../gui/wxpython/gui_modules/dbm.py:591 ../gui/wxpython/dbmgr/manager.py:595
+#: ../gui/wxpython/dbmgr/base.py:537
 #, python-format
-msgid ""
-"Database connection for vector map <%s> is not defined in DB file. You can "
-"define new connection in 'Manage layers' tab."
+msgid "Add column to table <%s>"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:595
-msgid "Attribute Table Manager"
-msgstr "Atribūtu tabulas pārvaldnieks"
+#: ../gui/wxpython/dbmgr/base.py:904
+msgid "Unable to add column to the table. No column name defined."
+msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:619 ../gui/wxpython/dbmgr/manager.py:621
-msgid "Browse data"
-msgstr "Pārlūkot datus"
-#: ../gui/wxpython/gui_modules/dbm.py:625 ../gui/wxpython/dbmgr/manager.py:627
-msgid "Manage tables"
-msgstr "Pārvaldīt tabulas"
-#: ../gui/wxpython/gui_modules/dbm.py:633 ../gui/wxpython/dbmgr/manager.py:635
-msgid "Manage layers"
-msgstr "Pārvaldīt slāņus"
-#: ../gui/wxpython/gui_modules/dbm.py:648 ../gui/wxpython/dbmgr/manager.py:652
-msgid "Close Attribute Table Manager"
-msgstr "Aizvērt atribūtu tabulas pārvaldnieku"
-#: ../gui/wxpython/gui_modules/dbm.py:650 ../gui/wxpython/dbmgr/manager.py:654
-msgid "Reload attribute data (selected layer only)"
+#: ../gui/wxpython/dbmgr/base.py:917
+#, python-format
+msgid "Column <%(column)s> already exists in table <%(table)s>."
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:680 ../gui/wxpython/dbmgr/manager.py:684
+#: ../gui/wxpython/dbmgr/base.py:991
 msgid "Attribute data - right-click to edit/manage records"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:693
-#: ../gui/wxpython/gui_modules/dbm.py:825
-#: ../gui/wxpython/gui_modules/dbm.py:2420
-#: ../gui/wxpython/gui_modules/dbm.py:2672
-#: ../gui/wxpython/dbmgr/manager.py:697 ../gui/wxpython/dbmgr/manager.py:837
-#: ../gui/wxpython/dbmgr/manager.py:2314 ../gui/wxpython/dbmgr/manager.py:2444
-#: ../gui/wxpython/dbmgr/manager.py:2698
+#: ../gui/wxpython/dbmgr/base.py:1006 ../gui/wxpython/dbmgr/base.py:1983
+#: ../gui/wxpython/dbmgr/base.py:2576 ../gui/wxpython/dbmgr/base.py:2707
+#: ../gui/wxpython/dbmgr/base.py:2960
 msgid "Table"
 msgstr "Tabula"
-#: ../gui/wxpython/gui_modules/dbm.py:695
-#: ../gui/wxpython/gui_modules/dbm.py:827
-#: ../gui/wxpython/gui_modules/dbm.py:1005
-#: ../gui/wxpython/dbmgr/manager.py:699 ../gui/wxpython/dbmgr/manager.py:839
-#: ../gui/wxpython/dbmgr/manager.py:1009
+#: ../gui/wxpython/dbmgr/base.py:1008 ../gui/wxpython/dbmgr/base.py:1985
 msgid " (readonly)"
 msgstr " (tikai lasīšanai)"
-#: ../gui/wxpython/gui_modules/dbm.py:703 ../gui/wxpython/dbmgr/manager.py:707
+#: ../gui/wxpython/dbmgr/base.py:1022
 msgid "SQL Query"
 msgstr "SQL vaicājums"
-#: ../gui/wxpython/gui_modules/dbm.py:723 ../gui/wxpython/dbmgr/manager.py:726
-msgid "Apply SELECT statement and reload data records"
-msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:725
-#: ../gui/wxpython/gui_modules/dbm.py:2030
-#: ../gui/wxpython/gui_modules/sqlbuilder.py:458
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:454
-#: ../gui/wxpython/dbmgr/manager.py:728 ../gui/wxpython/dbmgr/manager.py:2047
-msgid "SQL Builder"
-msgstr "SQL veidotājs"
-#: ../gui/wxpython/gui_modules/dbm.py:729 ../gui/wxpython/dbmgr/manager.py:732
+#: ../gui/wxpython/dbmgr/base.py:1051
 msgid "Simple"
 msgstr "Vienkārši"
-#: ../gui/wxpython/gui_modules/dbm.py:732 ../gui/wxpython/dbmgr/manager.py:735
-msgid "Advanced"
-msgstr "Paplašināti"
+#: ../gui/wxpython/dbmgr/base.py:1054
+msgid "Apply SELECT statement and reload data records"
+msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:741
-#: ../gui/wxpython/gui_modules/dbm.py:747
-#: ../gui/wxpython/gui_modules/sqlbuilder.py:108
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:108
-#: ../gui/wxpython/dbmgr/manager.py:749 ../gui/wxpython/dbmgr/manager.py:755
+#: ../gui/wxpython/dbmgr/base.py:1068 ../gui/wxpython/dbmgr/base.py:1085
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:418
 #, python-format
 msgid "Example: %s"
 msgstr "Paraugs: %s"
-#: ../gui/wxpython/gui_modules/dbm.py:838
-#: ../gui/wxpython/gui_modules/sqlbuilder.py:87
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:87 ../gui/wxpython/dbmgr/manager.py:850
-msgid "Database connection"
-msgstr "Datubāzes savienojums"
+#: ../gui/wxpython/dbmgr/base.py:1076
+#, fuzzy
+msgid "Builder"
+msgstr "SQL veidotājs"
-#: ../gui/wxpython/gui_modules/dbm.py:850 ../gui/wxpython/dbmgr/manager.py:862
-#, python-format
-msgid "Table <%s> - right-click to delete column(s)"
-msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1078
+msgid "SQL Builder"
-#: ../gui/wxpython/gui_modules/dbm.py:863
-msgid "Manage columns"
-msgstr "Pārvaldīt kolonas"
-#: ../gui/wxpython/gui_modules/dbm.py:870
-#: ../gui/wxpython/gui_modules/dbm.py:2235
-#: ../gui/wxpython/dbmgr/manager.py:2260
-msgid "Column name"
-msgstr "Kolonas nosaukums"
-#: ../gui/wxpython/gui_modules/dbm.py:898
-msgid "Data length"
-msgstr "Datu graums"
-#: ../gui/wxpython/gui_modules/dbm.py:945 ../gui/wxpython/dbmgr/manager.py:951
-msgid "&Rename"
-msgstr "&Pārsaukt"
-#: ../gui/wxpython/gui_modules/dbm.py:1003
-#: ../gui/wxpython/dbmgr/manager.py:1007
-msgid "Layers of vector map"
-msgstr "Vektoru kartes slāņi"
-#: ../gui/wxpython/gui_modules/dbm.py:1016
-#: ../gui/wxpython/dbmgr/manager.py:1020
-msgid "List of layers"
-msgstr "Slāņu saraksts"
-#: ../gui/wxpython/gui_modules/dbm.py:1116
-#: ../gui/wxpython/gui_modules/preferences.py:753
-#: ../gui/wxpython/dbmgr/manager.py:1120 ../gui/wxpython/core/settings.py:804
+#: ../gui/wxpython/dbmgr/base.py:1229 ../gui/wxpython/core/settings.py:846
 msgid "Edit selected record"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1120
-#: ../gui/wxpython/gui_modules/dbm.py:1360
-#: ../gui/wxpython/dbmgr/manager.py:1124 ../gui/wxpython/dbmgr/manager.py:1376
+#: ../gui/wxpython/dbmgr/base.py:1233 ../gui/wxpython/dbmgr/base.py:1408
 msgid "Insert new record"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1121
-#: ../gui/wxpython/dbmgr/manager.py:1125
+#: ../gui/wxpython/dbmgr/base.py:1234
 msgid "Delete selected record(s)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1122
-#: ../gui/wxpython/dbmgr/manager.py:1126
+#: ../gui/wxpython/dbmgr/base.py:1235
 msgid "Delete all records"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1131
-#: ../gui/wxpython/dbmgr/manager.py:1135
-msgid "Highlight selected features"
-msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1132
-#: ../gui/wxpython/dbmgr/manager.py:1136
+#: ../gui/wxpython/dbmgr/base.py:1245
 msgid "Highlight selected features and zoom"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1136
-#: ../gui/wxpython/gui_modules/dbm.py:2069
-#: ../gui/wxpython/dbmgr/manager.py:1140 ../gui/wxpython/dbmgr/manager.py:2089
+#: ../gui/wxpython/dbmgr/base.py:1249 ../gui/wxpython/dbmgr/base.py:1728
 msgid "Extract selected features"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1137
-#: ../gui/wxpython/dbmgr/manager.py:1141
+#: ../gui/wxpython/dbmgr/base.py:1250
 msgid "Delete selected features"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1223
+#: ../gui/wxpython/dbmgr/base.py:1311
+msgid "Update existing record"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1337 ../gui/wxpython/dbmgr/base.py:1443
 #, python-format
+msgid "Value '%(value)s' needs to be entered as %(type)s."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1351
+#, python-format
 msgid ""
-"All data records (%d) will permanently deleted from table. Do you want to "
-"delete them?"
+"Unable to update existing record.\n"
+"%s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1371
-#: ../gui/wxpython/dbmgr/manager.py:1387
+#: ../gui/wxpython/dbmgr/base.py:1419
 #, python-format
 msgid "Record with category number %d already exists in the table."
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1381
-#: ../gui/wxpython/dbmgr/manager.py:1397
+#: ../gui/wxpython/dbmgr/base.py:1429
 #, python-format
 msgid "Category number (column %s) is missing."
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1395
-#: ../gui/wxpython/gui_modules/dbm.py:1502
-#: ../gui/wxpython/dbmgr/manager.py:1411 ../gui/wxpython/dbmgr/manager.py:1520
+#: ../gui/wxpython/dbmgr/base.py:1454
 #, python-format
-msgid "Value '%(value)s' needs to be entered as %(type)s."
+msgid ""
+"Unable to insert new record.\n"
+"%s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1406
-msgid "Unable to insert new record."
+#: ../gui/wxpython/dbmgr/base.py:1504
+#, python-format
+msgid ""
+"Selected data records (%d) will be permanently deleted from table. Do you "
+"want to delete them?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1475
-#: ../gui/wxpython/dbmgr/manager.py:1493
-msgid "Update existing record"
+#: ../gui/wxpython/dbmgr/base.py:1507 ../gui/wxpython/dbmgr/base.py:1553
+msgid "Delete records"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1515
-msgid "Unable to update existing record."
+#: ../gui/wxpython/dbmgr/base.py:1550
+#, python-format
+msgid ""
+"All data records (%d) will be permanently deleted from table. Do you want to "
+"delete them?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1601
-#: ../gui/wxpython/dbmgr/manager.py:1619
+#: ../gui/wxpython/dbmgr/base.py:1724
+msgid "Nothing to extract."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1757
+msgid "Nothing to delete."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1809 ../gui/wxpython/dbmgr/base.py:1834
+#, python-format
+msgid ""
+"Loading attribute data failed.\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1822
+#, python-format
+msgid ""
+"Invalid SQL select statement.\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1999 ../gui/wxpython/dbmgr/sqlbuilder.py:88
+msgid "Database connection"
+msgstr "Datubāzes savienojums"
+#: ../gui/wxpython/dbmgr/base.py:2011
+#, python-format
+msgid "Table <%s> - right-click to delete column(s)"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2030 ../gui/wxpython/dbmgr/base.py:2081
+#: ../gui/wxpython/dbmgr/dialogs.py:750
+msgid "Column"
+msgstr "Kolona"
+#: ../gui/wxpython/dbmgr/base.py:2057 ../gui/wxpython/dbmgr/dialogs.py:764
+msgid "Length"
+msgstr "Garums"
+#: ../gui/wxpython/dbmgr/base.py:2100
+msgid "&Rename"
+msgstr "&Pārsaukt"
+#: ../gui/wxpython/dbmgr/base.py:2193
 msgid "Unable to rename column. No column name defined."
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1610
-#: ../gui/wxpython/dbmgr/manager.py:1627
+#: ../gui/wxpython/dbmgr/base.py:2201
 #, python-format
 msgid ""
 "Unable to rename column <%(column)s> to <%(columnTo)s>. Column already "
 "exists in the table <%(table)s>."
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1627
-#: ../gui/wxpython/dbmgr/manager.py:1643
+#: ../gui/wxpython/dbmgr/base.py:2217
 #, python-format
 msgid ""
 "Unable to rename column. Column <%(column)s> doesn't exist in the table <"
 "%(table)s>."
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1655
-#: ../gui/wxpython/dbmgr/manager.py:1670
+#: ../gui/wxpython/dbmgr/base.py:2244
 msgid "Drop selected column"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1658
-#: ../gui/wxpython/dbmgr/manager.py:1673
+#: ../gui/wxpython/dbmgr/base.py:2247
 msgid "Drop all columns"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1673
-#: ../gui/wxpython/dbmgr/manager.py:1688
+#: ../gui/wxpython/dbmgr/base.py:2276
 #, python-format
 msgid ""
-"Selected column '%s' will PERMANENTLY removed from table. Do you want to "
-"drop the column?"
+"Selected column %s will PERMANENTLY removed from table. Do you want to drop "
+"the column?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1676
-#: ../gui/wxpython/gui_modules/dbm.py:1713
-#: ../gui/wxpython/dbmgr/manager.py:1691 ../gui/wxpython/dbmgr/manager.py:1728
+#: ../gui/wxpython/dbmgr/base.py:2279 ../gui/wxpython/dbmgr/base.py:2316
 msgid "Drop column(s)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1710
-#: ../gui/wxpython/dbmgr/manager.py:1725
+#: ../gui/wxpython/dbmgr/base.py:2313
 #, python-format
 msgid ""
 "Selected columns\n"
@@ -11402,3739 +11901,4125 @@
 "will PERMANENTLY removed from table. Do you want to drop the columns?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1748
-#: ../gui/wxpython/dbmgr/manager.py:1763
-msgid "Unable to add column to the table. No column name defined."
-msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2401
+msgid "List of layers"
-#: ../gui/wxpython/gui_modules/dbm.py:1769
-#: ../gui/wxpython/dbmgr/manager.py:1784
+#: ../gui/wxpython/dbmgr/base.py:2481 ../gui/wxpython/dbmgr/base.py:2883
+#: ../gui/wxpython/dbmgr/base.py:3303
 #, python-format
-msgid "Column <%(column)s> already exists in table <%(table)s>."
+msgid "Drop also linked attribute table (%s)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1934
-#: ../gui/wxpython/gui_modules/dbm.py:1958
-#: ../gui/wxpython/dbmgr/manager.py:1952 ../gui/wxpython/dbmgr/manager.py:1975
-#, python-format
-msgid ""
-"Loading attribute data failed.\n"
-"\n"
-"%s"
-msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2522
+msgid "Column name"
+msgstr "Kolonas nosaukums"
-#: ../gui/wxpython/gui_modules/dbm.py:1945
-#: ../gui/wxpython/dbmgr/manager.py:1963
-#, python-format
-msgid ""
-"Invalid SQL select statement.\n"
-"\n"
-"%s"
-msgstr ""
+msgid "Data length"
+msgstr "Datu graums"
-#: ../gui/wxpython/gui_modules/dbm.py:2064
-#: ../gui/wxpython/dbmgr/manager.py:2085
-msgid "Nothing to extract."
-msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2576 ../gui/wxpython/dbmgr/base.py:2690
+#: ../gui/wxpython/dbmgr/base.py:2940 ../gui/wxpython/dbmgr/dialogs.py:491
+#: ../gui/wxpython/vdigit/preferences.py:379
+#: ../gui/wxpython/vdigit/preferences.py:381
+#: ../gui/wxpython/vdigit/dialogs.py:113 ../gui/wxpython/vdigit/dialogs.py:557
+msgid "Layer"
+msgstr "Slānis"
-#: ../gui/wxpython/gui_modules/dbm.py:2180
-#: ../gui/wxpython/gui_modules/dbm.py:2594
-#: ../gui/wxpython/gui_modules/dbm.py:3019
-#: ../gui/wxpython/dbmgr/manager.py:2205 ../gui/wxpython/dbmgr/manager.py:2620
-#: ../gui/wxpython/dbmgr/manager.py:3041
-#, python-format
-msgid "Drop also linked attribute table (%s)"
-msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2409
-#: ../gui/wxpython/gui_modules/dbm.py:2660
-#: ../gui/wxpython/dbmgr/manager.py:2314 ../gui/wxpython/dbmgr/manager.py:2433
-#: ../gui/wxpython/dbmgr/manager.py:2686
+#: ../gui/wxpython/dbmgr/base.py:2576 ../gui/wxpython/dbmgr/base.py:2696
+#: ../gui/wxpython/dbmgr/base.py:2948
 msgid "Driver"
 msgstr "Dzinējs"
 msgid "Key"
 msgstr "Atslēga"
-#: ../gui/wxpython/gui_modules/dbm.py:2364
-#: ../gui/wxpython/dbmgr/manager.py:2390
-msgid ""
-"Unknown default DB connection. Please define DB connection using db.connect "
-"module."
-msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2385
-#: ../gui/wxpython/dbmgr/manager.py:2409
+#: ../gui/wxpython/dbmgr/base.py:2672
 msgid "Add layer"
 msgstr "Pievienot slāni"
-#: ../gui/wxpython/gui_modules/dbm.py:2395
-#: ../gui/wxpython/dbmgr/manager.py:2419
+#: ../gui/wxpython/dbmgr/base.py:2682
 msgid "Layer description"
 msgstr "Slāņa apraksts"
-#: ../gui/wxpython/gui_modules/dbm.py:2425
-#: ../gui/wxpython/gui_modules/dbm.py:2457
-#: ../gui/wxpython/gui_modules/dbm.py:2678
-#: ../gui/wxpython/dbmgr/manager.py:2449 ../gui/wxpython/dbmgr/manager.py:2487
-#: ../gui/wxpython/dbmgr/manager.py:2704
+#: ../gui/wxpython/dbmgr/base.py:2712 ../gui/wxpython/dbmgr/base.py:2750
+#: ../gui/wxpython/dbmgr/base.py:2966
 msgid "Key column"
 msgstr "Atslēgas kolona"
-#: ../gui/wxpython/gui_modules/dbm.py:2430
-#: ../gui/wxpython/dbmgr/manager.py:2454
+#: ../gui/wxpython/dbmgr/base.py:2717
 msgid "Insert record for each category into table"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2445
-#: ../gui/wxpython/dbmgr/manager.py:2469
+#: ../gui/wxpython/dbmgr/base.py:2732
 msgid "You need to add categories by v.category module."
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2452
-#: ../gui/wxpython/dbmgr/manager.py:2482
+#: ../gui/wxpython/dbmgr/base.py:2737
+msgid "Table description"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2745
 msgid "Table name"
 msgstr "Tabulas nosaukums"
-#: ../gui/wxpython/gui_modules/dbm.py:2465
-#: ../gui/wxpython/dbmgr/manager.py:2495
+#: ../gui/wxpython/dbmgr/base.py:2758
 msgid "&Create table"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2469
-#: ../gui/wxpython/dbmgr/manager.py:2499
-msgid "&Add layer"
-msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2473
-#: ../gui/wxpython/dbmgr/manager.py:2503
+#: ../gui/wxpython/dbmgr/base.py:2766
 msgid "&Set default"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2537
-#: ../gui/wxpython/dbmgr/manager.py:2474
-msgid "Table description"
-msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2577
-#: ../gui/wxpython/dbmgr/manager.py:2603
+#: ../gui/wxpython/dbmgr/base.py:2866
 msgid "Remove layer"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2580
-#: ../gui/wxpython/dbmgr/manager.py:2606
+#: ../gui/wxpython/dbmgr/base.py:2869
 msgid "Layer to remove"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2601
-#: ../gui/wxpython/dbmgr/manager.py:2627
+#: ../gui/wxpython/dbmgr/base.py:2890
 msgid "&Remove layer"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2645
-#: ../gui/wxpython/dbmgr/manager.py:2671
+#: ../gui/wxpython/dbmgr/base.py:2933
 msgid "Modify layer"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2717
-#: ../gui/wxpython/dbmgr/manager.py:2743
+#: ../gui/wxpython/dbmgr/base.py:3005
 msgid "&Modify layer"
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2765
-#: ../gui/wxpython/dbmgr/manager.py:2791
+#: ../gui/wxpython/dbmgr/base.py:3053
 msgid ""
 "Unable to get list of tables.\n"
 "Please use db.connect to set database parameters."
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2863
-#: ../gui/wxpython/dbmgr/manager.py:2888
+#: ../gui/wxpython/dbmgr/base.py:3150
 msgid "Unable to create new table. Table name or key column name is missing."
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2870
-#: ../gui/wxpython/dbmgr/manager.py:2894
+#: ../gui/wxpython/dbmgr/base.py:3156
 #, python-format
 msgid "Unable to create new table. Table <%s> already exists in the database."
 msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2909
-#: ../gui/wxpython/dbmgr/manager.py:2932
+#: ../gui/wxpython/dbmgr/base.py:3194
 #, python-format
 msgid ""
 "Unable to add new layer to vector map <%(vector)s>. Layer %(layer)d already "
 "exists."
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:75
-#: ../gui/wxpython/modules/colorrules.py:72
-msgid "Check all"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:116
+msgid "Set SQL statement to default"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:78
-#: ../gui/wxpython/modules/colorrules.py:75
-msgid "Clear all"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:118
+#, fuzzy
+msgid "Apply SQL statement in Attribute Table Manager"
+msgstr "Aizvērt atribūtu tabulas pārvaldnieku"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:120
+msgid "Close the dialog"
+msgstr "Aizvērt dialogu"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:171
+msgid "Columns"
+msgstr "Kolonas"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:182
+msgid "Interactive insertion"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:134
-#: ../gui/wxpython/modules/colorrules.py:131
-msgid "Enter vector attribute values"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:196
+msgid "Values"
+msgstr "Vērtības"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:206
+msgid "Get all values"
+msgstr "Saņemt visas vērtības"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:209
+msgid "Get sample"
+msgstr "Paņemt paraugu"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:210
+msgid "Get first 256 unique values as sample"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:288
-#: ../gui/wxpython/modules/colorrules.py:288
-msgid "Bad color format. Use color format '0:0:0'"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:226
+#, fuzzy
+msgid "Go to:"
+msgstr "Iet uz"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:239
+msgid "Close dialog on apply"
+msgstr "Aizvērt dialogu, kad izmaiņas tiek pielietotas"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:402
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:544
+#, python-format
+msgid "GRASS SQL Builder (%(type)s) - <%(map)s>"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:371
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:359
-#: ../gui/wxpython/modules/colorrules.py:373
-#: ../gui/wxpython/wxplot/dialogs.py:355
-msgid "Select raster map:"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:405
+msgid "Column to show (SELECT clause)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:373
-#: ../gui/wxpython/modules/colorrules.py:375
-msgid "Select vector map:"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:406
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:548
+msgid "Constraint for query (WHERE clause)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:389
-#: ../gui/wxpython/modules/colorrules.py:392
-msgid "Import or export color table:"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:421
+msgid "Verify"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:394
-#: ../gui/wxpython/modules/colorrules.py:397
-msgid "Load color table from file:"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:422
+msgid "Verify SQL statement"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:395
-#: ../gui/wxpython/modules/colorrules.py:398
-msgid "Choose file to load color table"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:430
+msgid "SQL statement not verified"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:396
-#: ../gui/wxpython/modules/colorrules.py:399
-msgid "Load"
-msgstr "Ielādēt"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:474
+msgid "SQL statement is not valid"
+msgstr "SQL izteikums nav derīgs"
-#: ../gui/wxpython/gui_modules/colorrules.py:397
-#: ../gui/wxpython/modules/colorrules.py:400
-msgid "Type filename or click to choose file and load color table"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:476
+#, python-format
+msgid ""
+"SQL statement is not valid.\n"
+"\n"
+"%s"
 msgstr ""
+"SQL izteiksme ir nederīga.\n"
+"\n"
+"%s"
-#: ../gui/wxpython/gui_modules/colorrules.py:403
-#: ../gui/wxpython/modules/colorrules.py:406
-msgid "Save color table to file:"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:478
+msgid "SQL statement is valid"
+msgstr "SQL izteiksme ir derīga"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:547
+msgid "Column to set (SET clause)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:404
-#: ../gui/wxpython/modules/colorrules.py:407
-msgid "Choose file to save color table"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:549
+msgid "Calculate column value to set"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:405
-#: ../gui/wxpython/modules/colorrules.py:408
-msgid "Type filename or click to choose file and save color table"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:604
+#, fuzzy
+msgid "Functions"
+msgstr "Darbība"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:637
+#, fuzzy
+msgid "SQL statement was not applied"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:639
+#, fuzzy
+msgid "SQL statement applied"
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:672
+msgid "Dbf driver does not support usage of SQL functions."
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:411
-#: ../gui/wxpython/modules/colorrules.py:414
-msgid "Reload default table"
+#: ../gui/wxpython/dbmgr/dialogs.py:74
+#, python-format
+msgid ""
+"No attribute table found.\n"
+"\n"
+"Do you want to create a new attribute table and defined a link to vector map "
+"<%s>?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:500
-#: ../gui/wxpython/iclass/toolbars.py:61
-#: ../gui/wxpython/modules/colorrules.py:504
-msgid "Preview"
-msgstr "Priekšskatījums"
+#: ../gui/wxpython/dbmgr/dialogs.py:77
+msgid "Create table?"
+msgstr "Izveidot tabulu?"
-#: ../gui/wxpython/gui_modules/colorrules.py:504
-#: ../gui/wxpython/modules/colorrules.py:508
-msgid "Show preview of map (current Map Display extent is used)."
+#: ../gui/wxpython/dbmgr/dialogs.py:97
+msgid "Close dialog on submit"
+msgstr "Aizvērt dialogu pēc vērtības ierakstīšanas"
+#: ../gui/wxpython/dbmgr/dialogs.py:109
+msgid "No attributes found"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:534
-#: ../gui/wxpython/gui_modules/colorrules.py:1659
-#: ../gui/wxpython/modules/colorrules.py:538
-#: ../gui/wxpython/modules/colorrules.py:1676
-msgid "No valid color rules given."
+#: ../gui/wxpython/dbmgr/dialogs.py:117
+msgid "Define attributes"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:566
-#: ../gui/wxpython/gui_modules/menuform.py:1642
-#: ../gui/wxpython/gui_core/forms.py:1649
-#: ../gui/wxpython/modules/colorrules.py:571
-msgid "Nothing to save."
+#: ../gui/wxpython/dbmgr/dialogs.py:119
+msgid "Display attributes"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:599
-#: ../gui/wxpython/modules/colorrules.py:604
-msgid "Invalid color table format"
+#: ../gui/wxpython/dbmgr/dialogs.py:123
+msgid "&Reload"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:676
-#: ../gui/wxpython/modules/colorrules.py:681
-#, python-format
-msgid "Invalid rule value '%s'. Unable to apply color table."
+#: ../gui/wxpython/dbmgr/dialogs.py:124 ../gui/wxpython/dbmgr/dialogs.py:595
+msgid "&Submit"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:751
-#: ../gui/wxpython/modules/colorrules.py:756
-msgid "Create new color table for raster map"
+#: ../gui/wxpython/dbmgr/dialogs.py:142 ../gui/wxpython/vdigit/dialogs.py:168
+msgid "Feature id:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:827
-#: ../gui/wxpython/modules/colorrules.py:834
-msgid "Enter raster category values or percents"
+#: ../gui/wxpython/dbmgr/dialogs.py:226
+#, python-format
+msgid "Column <%(col)s>: Value '%(value)s' needs to be entered as %(type)s."
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:833
-#: ../gui/wxpython/modules/colorrules.py:840
-msgid "fp range"
+#: ../gui/wxpython/dbmgr/dialogs.py:434
+msgid "Unknown"
+msgstr "Nezināms"
+#: ../gui/wxpython/dbmgr/dialogs.py:492 ../gui/wxpython/dbmgr/dialogs.py:610
+#: ../gui/wxpython/vdigit/dialogs.py:120 ../gui/wxpython/vdigit/dialogs.py:558
+msgid "Category"
+msgstr "Kategorija"
+#: ../gui/wxpython/dbmgr/manager.py:70
+#, fuzzy
+msgid "GRASS GIS Attribute Table Manager - "
+#: ../gui/wxpython/dbmgr/manager.py:72
+msgid "READONLY - "
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:834
-#: ../gui/wxpython/modules/colorrules.py:841
+#: ../gui/wxpython/dbmgr/manager.py:85
 #, python-format
-msgid "Enter raster category values or percents (%(range)s = %(min)d-%(max)d)"
+msgid ""
+"Database connection for vector map <%s> is not defined in DB file. You can "
+"define new connection in 'Manage layers' tab."
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:925
-#: ../gui/wxpython/modules/colorrules.py:930
-msgid "Create new color rules for vector map"
+#: ../gui/wxpython/dbmgr/manager.py:90
+msgid "Please wait, loading attribute data..."
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:936
-#: ../gui/wxpython/gui_modules/colorrules.py:1457
-#: ../gui/wxpython/modules/colorrules.py:941
-#: ../gui/wxpython/modules/colorrules.py:1467
-msgid "Enter vector attribute values or percents:"
+#: ../gui/wxpython/dbmgr/manager.py:99
+msgid "Browse data"
+msgstr "Pārlūkot datus"
+#: ../gui/wxpython/dbmgr/manager.py:105
+msgid "Manage tables"
+msgstr "Pārvaldīt tabulas"
+#: ../gui/wxpython/dbmgr/manager.py:110
+msgid "Manage layers"
+msgstr "Pārvaldīt slāņus"
+#: ../gui/wxpython/dbmgr/manager.py:121
+msgid "Close Attribute Table Manager"
+#: ../gui/wxpython/dbmgr/manager.py:123
+msgid "Reload attribute data (selected layer only)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:938
-#: ../gui/wxpython/gui_modules/colorrules.py:1459
-#: ../gui/wxpython/modules/colorrules.py:943
-#: ../gui/wxpython/modules/colorrules.py:1469
-msgid "Enter vector attribute values:"
+#: ../gui/wxpython/iclass/g.gui.iclass.py:75
+msgid "Name of subgroup required"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:948
-#: ../gui/wxpython/modules/colorrules.py:954
-msgid "Select vector columns"
+#: ../gui/wxpython/iclass/g.gui.iclass.py:78
+#: ../gui/wxpython/iclass/dialogs.py:189
+msgid "Group <%s> not found"
+msgstr "Karte <%s> nav atrasta."
+#: ../gui/wxpython/iclass/g.gui.iclass.py:80
+msgid "Subgroup <%s> not found"
+#: ../gui/wxpython/iclass/g.gui.iclass.py:113
+msgid "Loading raster map <%s>..."
+msgstr "<%s> rastra kartes leģenda"
+#: ../gui/wxpython/iclass/g.gui.iclass.py:116
+msgid "Loading training map <%s>..."
+msgstr "Datu ielāde..."
+#: ../gui/wxpython/iclass/toolbars.py:33
+msgid "Set opacity level"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:950
-#: ../gui/wxpython/modules/colorrules.py:956
-msgid "Layer:"
-msgstr "Slānis:"
+#: ../gui/wxpython/iclass/toolbars.py:35 ../gui/wxpython/iclass/dialogs.py:261
+msgid "Class manager"
+msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:952
-#: ../gui/wxpython/modules/colorrules.py:958
-msgid "Attribute column:"
+#: ../gui/wxpython/iclass/toolbars.py:39
+msgid "Run analysis, update histogram and coincidence plots"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:955
-#: ../gui/wxpython/modules/colorrules.py:961
-msgid "Load color from column:"
+#: ../gui/wxpython/iclass/toolbars.py:41
+msgid "Save signature file for i.maxlik"
 msgstr ""
-msgid "Save color to column:"
+#: ../gui/wxpython/iclass/toolbars.py:43
+#, fuzzy
+msgid "Remove selected map layer"
+msgstr "Pārsaukt izvēlēto karšu kopu"
+#: ../gui/wxpython/iclass/toolbars.py:45
+#, fuzzy
+msgid "Export training areas to vector map"
+msgstr "Rastra datu importēšana"
+#: ../gui/wxpython/iclass/toolbars.py:47
+#, fuzzy
+msgid "Import training areas from vector map"
+#: ../gui/wxpython/iclass/toolbars.py:66
+msgid "Training"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:957
-#: ../gui/wxpython/modules/colorrules.py:963
-msgid "Load size from column:"
+#: ../gui/wxpython/modules/colorrules.py:523
+msgid "Preview"
+msgstr "Priekšskatījums"
+#: ../gui/wxpython/iclass/toolbars.py:70
+msgid "Set map canvas for "
 msgstr ""
-msgid "Save size to column:"
+#: ../gui/wxpython/iclass/toolbars.py:72
+msgid "/ Zoom to map"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:959
-#: ../gui/wxpython/modules/colorrules.py:965
-msgid "Load width from column:"
+#: ../gui/wxpython/iclass/toolbars.py:244
+#: ../gui/wxpython/iclass/toolbars.py:249
+msgid "std dev"
 msgstr ""
-msgid "Save width to column:"
+#: ../gui/wxpython/iclass/toolbars.py:319
+msgid "Add raster map"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:963
-#: ../gui/wxpython/modules/colorrules.py:969
-msgid "Use color column instead of color table:"
+#: ../gui/wxpython/iclass/dialogs.py:78
+msgid "Name of imagery group is missing."
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:977
-#: ../gui/wxpython/dbmgr/manager.py:873
-#: ../gui/wxpython/modules/colorrules.py:983
-msgid "Add column"
-msgstr "Pievienot kolonu"
+#: ../gui/wxpython/iclass/dialogs.py:85
+msgid "Name of imagery group:"
+msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:978
-#: ../gui/wxpython/modules/colorrules.py:984
-msgid "Add GRASSRGB column to current attribute table."
+#: ../gui/wxpython/iclass/dialogs.py:97
+#, fuzzy
+msgid "Name of imagery subgroup:"
+msgstr "Rastra kartes nosaukums:"
+#: ../gui/wxpython/iclass/dialogs.py:171
+msgid "Please choose a subgroup."
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:1033
-#: ../gui/wxpython/gui_modules/colorrules.py:1081
-#: ../gui/wxpython/modules/colorrules.py:1039
-#: ../gui/wxpython/modules/colorrules.py:1088
-msgid "Import or export color table"
+#: ../gui/wxpython/iclass/dialogs.py:174
+#, python-format
+msgid "Subgroup <%s> not found in group <%s>"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:1093
-#: ../gui/wxpython/modules/colorrules.py:1100
+#: ../gui/wxpython/iclass/dialogs.py:180
 #, python-format
 msgid ""
-"Database connection for vector map <%s> is not defined in DB file.  Do you "
-"want to create and connect new attribute table?"
+"No data found in subgroup <%s> of group <%s>.\n"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:1096
-#: ../gui/wxpython/modules/colorrules.py:1103
-msgid "No database connection defined"
-msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:1168
+#: ../gui/wxpython/iclass/dialogs.py:185
 #, python-format
 msgid ""
-"Selected map <%s> is not in current mapset <%s>. Attribute table cannot be "
-"edited."
+"No data found in group <%s>.\n"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:1315
-#: ../gui/wxpython/modules/colorrules.py:1323
+#: ../gui/wxpython/iclass/dialogs.py:232
+#, fuzzy
+msgid "Name of map is missing."
+msgstr "Karšu kopas nosaukums:"
+#: ../gui/wxpython/iclass/dialogs.py:499
+msgid "Zoom to training areas of selected class"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:556
+msgid "Save signature file"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:613
+msgid "Enter name of signature file:"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:622
+msgid "Signature file path:"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:664
+msgid "Export training areas"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:718
+msgid "Export attribute table"
+msgstr "Eksportēt atribūtu tabulu"
+#: ../gui/wxpython/iclass/dialogs.py:720
+msgid "Export attribute table containing computed statistical data"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:758
 #, python-format
-msgid "%s column already exists."
+msgid "Vector map <%s> already exists. Do you want to overwrite it?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:1347
-#: ../gui/wxpython/modules/colorrules.py:1355
-msgid "Please wait, loading data from attribute table..."
+#: ../gui/wxpython/iclass/dialogs.py:760
+#, python-format
+msgid "Vector <%s> exists"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:1408
-#: ../gui/wxpython/modules/colorrules.py:1416
+#: ../gui/wxpython/iclass/frame.py:44
 #, python-format
 msgid ""
-"Number of loaded records reached %d, displaying all the records will be time-"
-"consuming and may lead to computer freezing, do you still want to continue?"
+"Loading imagery lib failed.\n"
+"%s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:1412
-#: ../gui/wxpython/modules/colorrules.py:1420
-msgid "Too many records"
-msgstr "Pārāk daudz ierakstu"
+#: ../gui/wxpython/iclass/frame.py:80
+msgid "GRASS GIS Supervised Classification Tool"
+msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:1447
+#: ../gui/wxpython/iclass/frame.py:306
+msgid "IClass Toolbar"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:318
+msgid "IClass Misc Toolbar"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:335
+msgid "Digitization Toolbar"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:359
+msgid "Plots"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:379
+msgid "Preview Display"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:382
+msgid "Training Areas Display"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:450
+msgid "Adjust Training Area Display to Preview Display"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:451
+msgid "Adjust Preview display to Training Area Display"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:452
+#, fuzzy
+msgid "Display synchronization ON"
+msgstr "Attēlot reģionu"
+#: ../gui/wxpython/iclass/frame.py:453
+msgid "Display synchronization OFF"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:523
+msgid "All changes will be lost. Do you want to continue?"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:531
+msgid "Import vector map"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:550
 #, python-format
-msgid "(range: %.1f to %.1f)"
+msgid "No areas in vector map <%s>.\n"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:1449
+#: ../gui/wxpython/iclass/frame.py:552
 #, python-format
-msgid "(range: %d to %d)"
+msgid "Vector map <%s> contains points or lines, these features are ignored."
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:1452
-#: ../gui/wxpython/modules/colorrules.py:1462
+#: ../gui/wxpython/iclass/frame.py:577
+msgid "Unable to open vector map <%s>"
+msgstr "Nav iespējams dzēst karšu kopu"
+#: ../gui/wxpython/iclass/frame.py:584
 #, python-format
-msgid "Enter vector attribute values or percents %s:"
+msgid "Unable to copy vector features from <%s>"
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:1454
-#: ../gui/wxpython/modules/colorrules.py:1464
+#: ../gui/wxpython/iclass/frame.py:594
+#, fuzzy
+msgid "Unable to open temporary vector map"
+msgstr "Jaunās vektoru kartes nosaukums:"
+#: ../gui/wxpython/iclass/frame.py:684
+msgid "No training areas to export."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:696
 #, python-format
-msgid "Enter vector attribute values %s:"
+msgid "%d training areas (%d classes) exported to vector map <%s>."
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:1598
-#: ../gui/wxpython/modules/colorrules.py:1610
-msgid "Please select column to save values to."
+#: ../gui/wxpython/iclass/frame.py:894
+msgid "Failed to create temporary vector map."
 msgstr ""
-#: ../gui/wxpython/gui_modules/colorrules.py:1644
-#: ../gui/wxpython/modules/colorrules.py:1661
-msgid "Thematic mapping for vector map in 3D view"
+#: ../gui/wxpython/iclass/frame.py:970
+#, python-format
+msgid "No area in category %s. Category skipped."
 msgstr ""
-#: ../gui/wxpython/gui_modules/prompt.py:395
-#: ../gui/wxpython/gui_core/prompt.py:393
+#: ../gui/wxpython/iclass/frame.py:973
+msgid "Analysis failed."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:980
+msgid "results"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:986
+msgid "No imagery group selected."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:991
+msgid ""
+"Due to recent changes in classes, signatures can be outdated and should be "
+"recalculated. Do you still want to continue?"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:994
+msgid "Outdated signatures"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:1010
 #, python-format
-msgid "Warning: flag <%(flag)s> not found in '%(module)s'"
+msgid ""
+"A signature file named %s already exists.\n"
+"Do you want to replace it?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/prompt.py:398
-#: ../gui/wxpython/gui_core/prompt.py:396
+#: ../gui/wxpython/iclass/frame.py:1058
+msgid "No imagery group selected. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:1067
 #, python-format
-msgid "Warning: option <%(param)s> not found in '%(module)s'"
+msgid ""
+"Group <%(group)s> does not have enough files (it has %(files)d files). "
+"Operation canceled."
 msgstr ""
-#: ../gui/wxpython/gui_modules/prompt.py:620
-#: ../gui/wxpython/gui_core/prompt.py:638
-msgid "Type GRASS command and run by pressing ENTER"
+#: ../gui/wxpython/iclass/frame.py:1076
+msgid "No areas given. Operation canceled."
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:148
-#: ../gui/wxpython/gui_modules/menuform.py:1326
-#: ../gui/wxpython/gui_core/forms.py:1310 ../gui/wxpython/core/utils.py:786
-msgid "Select Color"
+#: ../gui/wxpython/iclass/frame.py:1091
+msgid "Vector features are outside raster layers. Operation canceled."
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:472
-#: ../gui/wxpython/gui_core/forms.py:429
-msgid "Enter parameters for '"
+#: ../gui/wxpython/iclass/statistics.py:29
+msgid "Loading imagery lib failed"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:483
-#: ../gui/wxpython/gui_core/forms.py:440
-msgid "Close this window without executing the command (Ctrl+Q)"
-msgstr "Aizvērt logu un neizpildīt komandu (Ctrl+Q)"
+#: ../gui/wxpython/iclass/digit.py:57
+msgid ""
+"You are trying to create a training area outside the computational region. "
+"Please, use g.region to set the appropriate region first."
+msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:504
-#: ../gui/wxpython/gui_core/forms.py:461
-msgid "Run the command (Ctrl+R)"
+#: ../gui/wxpython/iclass/digit.py:66
+msgid ""
+"In order to create a training area, you have to select class first.\n"
+"\n"
+"There is no class yet, do you want to create one?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:524
-#: ../gui/wxpython/gui_core/forms.py:481
-msgid "Show manual page of the command (Ctrl+H)"
+#: ../gui/wxpython/iclass/plots.py:66
+msgid "Histograms"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:545
-#: ../gui/wxpython/gui_core/forms.py:502
-msgid "Add created map(s) into layer tree"
+#: ../gui/wxpython/iclass/plots.py:67
+msgid "Coincident plots"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:560
-#: ../gui/wxpython/gui_core/forms.py:517
-msgid "Close dialog on finish"
-msgstr "Aizvērt dialogu, kad darbs ir pabeigts"
+#: ../gui/wxpython/iclass/plots.py:68
+msgid "Scatter plots"
+msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:562
-#: ../gui/wxpython/gui_core/forms.py:519
+#: ../gui/wxpython/iclass/plots.py:83
+#, python-format
 msgid ""
-"Close dialog when command is successfully finished. Change this settings in "
-"Preferences dialog ('Command' tab)."
+"Scatter plot functionality is disabled.\n"
+"\n"
+"Reason: Unable to import packages needed for scatter plot.\n"
+"%s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:741
-#: ../gui/wxpython/gui_core/forms.py:699
+#: ../gui/wxpython/icons/icon.py:34
 #, python-format
-msgid "'%s' copied to clipboard"
+msgid "Unknown iconset '%s', using default 'grass'...\n"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:804
-#: ../gui/wxpython/gui_modules/menuform.py:817
-#: ../gui/wxpython/gui_core/forms.py:762 ../gui/wxpython/gui_core/forms.py:775
-msgid "Required"
-msgstr "Obilgāti"
+#: ../gui/wxpython/icons/icon.py:51
+#, python-format
+msgid "Unable to load icon theme. Reason: %s. Quiting wxGUI..."
+msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:807
-#: ../gui/wxpython/gui_core/forms.py:765 ../gui/wxpython/gui_core/forms.py:775
-msgid "Optional"
-msgstr "Izvēles"
+#: ../gui/wxpython/mapwin/buffered.py:137
+#, fuzzy
+msgid "legend"
+msgstr "Leģenda"
-#: ../gui/wxpython/gui_modules/menuform.py:850
-#: ../gui/wxpython/gui_core/forms.py:809
-msgid "Manual"
-msgstr "Rokasgrāmata"
+#, fuzzy
+msgid "scale bar"
+msgstr "Mērogjosla"
-#: ../gui/wxpython/gui_modules/menuform.py:890
-#: ../gui/wxpython/gui_modules/menuform.py:1438
-#: ../gui/wxpython/gui_core/forms.py:849
-#: ../gui/wxpython/gui_core/forms.py:1445
-msgid "Parameterized in model"
+#, fuzzy
+msgid "north arrow"
+msgstr "Ziemeļu bulta"
+#: ../gui/wxpython/mapwin/buffered.py:202
+msgid "Copy coordinates to clipboard"
+msgstr "Kopēt koordinātas uz starpliktuvi"
+#: ../gui/wxpython/mapwin/buffered.py:212
+#, python-brace-format
+msgid "Hide {overlay}"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:965
-#: ../gui/wxpython/gui_core/forms.py:926
-msgid "[multiple]"
-msgstr "[daudzvērtību]"
+#: ../gui/wxpython/mapwin/buffered.py:219
+#, fuzzy
+msgid "Resize legend"
+msgstr "Rastra leģenda"
-#: ../gui/wxpython/gui_modules/menuform.py:1012
-#: ../gui/wxpython/gui_core/forms.py:973
-msgid "valid range"
-msgstr "derīgs diapazons"
+#: ../gui/wxpython/mapwin/buffered.py:563
+#: ../gui/wxpython/modules/histogram.py:178
+msgid "Please wait, exporting image..."
+msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1345
-#: ../gui/wxpython/gui_core/forms.py:1329
-#: ../gui/wxpython/gui_core/preferences.py:956
-#: ../gui/wxpython/gui_core/preferences.py:978
-msgid "Transparent"
-msgstr "Caurspīdīgs"
+#: ../gui/wxpython/mapwin/buffered.py:771
+msgid "Unable to draw registered graphics. The graphics was unregistered."
+msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1365
-#: ../gui/wxpython/gui_modules/menuform.py:1420
-#: ../gui/wxpython/gui_core/forms.py:1349
-#: ../gui/wxpython/gui_core/forms.py:1405
+#: ../gui/wxpython/mapwin/buffered.py:1735
+msgid "Zoom to saved region extents"
+msgstr ""
+#: ../gui/wxpython/mapwin/buffered.py:1737
+#, fuzzy
+msgid "Set compulational region from named region"
+msgstr "Tuvināt līdz aprēķinu reģionam"
+#: ../gui/wxpython/mapwin/buffered.py:1749
 #, python-format
-msgid "Choose %s"
+msgid "Region <%s> not found. Operation canceled."
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1393
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:141
-#: ../gui/wxpython/gui_core/forms.py:1378
-#: ../gui/wxpython/modules/mcalc_builder.py:137
-msgid "&Load"
-msgstr "Ie&lādēt"
+#: ../gui/wxpython/mapwin/buffered.py:1778
+msgid "Save display extents to region file"
+msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1399
-#: ../gui/wxpython/gui_core/forms.py:1384
-msgid "or enter values interactively"
+#: ../gui/wxpython/mapwin/buffered.py:1780
+#, fuzzy
+msgid "Save computational region to region file"
+#: ../gui/wxpython/mapwin/buffered.py:1790
+#, python-format
+msgid "Region file <%s> already exists. Do you want to overwrite it?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1614
-#: ../gui/wxpython/gui_core/forms.py:1621
-msgid "Nothing to load."
+#: ../gui/wxpython/mapwin/buffered.py:1792
+#: ../gui/wxpython/wxplot/dialogs.py:803
+#: ../gui/wxpython/core/workspace.py:1329 ../gui/wxpython/core/gcmd.py:140
+msgid "Warning"
+msgstr "Brīdinājums"
+#: ../gui/wxpython/mapwin/analysis.py:218
+#: ../gui/wxpython/mapwin/analysis.py:330
+#, fuzzy
+msgid "Measuring finished"
+msgstr "Attāluma mērīšana"
+#: ../gui/wxpython/mapwin/analysis.py:233
+#: ../gui/wxpython/mapwin/analysis.py:340
+#, python-format
+msgid ""
+"Click and drag with left mouse button to measure.%sDouble click with left "
+"button to clear."
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1646
-#: ../gui/wxpython/gui_core/forms.py:1653
-msgid "Save input as..."
+#: ../gui/wxpython/mapwin/analysis.py:239
+msgid "Measuring distance"
+#: ../gui/wxpython/mapwin/analysis.py:242
+#, fuzzy
+msgid "Measuring distance:"
+#: ../gui/wxpython/mapwin/analysis.py:250
+#, python-format
+msgid ""
+"Geodesic distance calculation is not available.\n"
+"Reason: %s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1909
-#: ../gui/wxpython/gui_core/forms.py:1939
+#: ../gui/wxpython/mapwin/analysis.py:284
+#: ../gui/wxpython/mapwin/analysis.py:290
+msgid "segment"
+msgstr "segments"
+#: ../gui/wxpython/mapwin/analysis.py:285
+#: ../gui/wxpython/mapwin/analysis.py:291
+msgid "total distance"
+msgstr "kopējais garums"
+#: ../gui/wxpython/mapwin/analysis.py:286
+msgid "bearing"
+msgstr ""
+msgid "degrees (clockwise from grid-north)"
+msgstr ""
+#: ../gui/wxpython/mapwin/analysis.py:344
+#, fuzzy
+msgid "Measuring area:"
+#: ../gui/wxpython/mapwin/analysis.py:357
+msgid "Units not recognized, measurement failed."
+msgstr ""
+#: ../gui/wxpython/mapwin/analysis.py:362
+#: ../gui/wxpython/mapwin/analysis.py:364
+msgid "Area: {area} {unit}\n"
+msgstr ""
+#: ../gui/wxpython/mapwin/base.py:194
 #, python-format
-msgid "Error in %s"
+msgid ""
+"Error occured during calling of handler: %s \n"
+"Handler was unregistered."
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:2033
-#: ../gui/wxpython/gui_core/forms.py:2043
+#: ../gui/wxpython/mapwin/base.py:273
 #, python-format
-msgid "Unable to parse command '%s'"
+msgid ""
+"Error occured during unregistration of handler: %s \n"
+"                                        Handler was unregistered."
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:2039
-#: ../gui/wxpython/gui_core/forms.py:2049
+#: ../gui/wxpython/mapwin/base.py:302
 #, python-format
-msgid "%(cmd)s: parameter '%(key)s' not available"
+msgid "Handler: %s was not registered"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:2218
-#: ../gui/wxpython/gui_core/forms.py:2160
+#: ../gui/wxpython/mapwin/base.py:306
 #, python-format
-msgid "usage: %s <grass command>"
+msgid ""
+"                                        Handler was unregistered"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:420
-#: ../gui/wxpython/core/settings.py:477
-msgid "Segment break"
+#: ../gui/wxpython/mapwin/graphics.py:247
+#: ../gui/wxpython/mapwin/graphics.py:368
+#, python-format
+msgid "Property does not exist: %s"
+msgstr "Īpašība %s neeksistē"
+#: ../gui/wxpython/mapwin/decorations.py:172
+#: ../gui/wxpython/mapwin/decorations.py:219
+msgid ""
+"Please install Python Imaging Library (PIL)\n"
+"for better control of legend and other decorations."
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:480
-#: ../gui/wxpython/core/settings.py:537
-msgid "Data point"
+#: ../gui/wxpython/mapwin/decorations.py:321
+msgid "Show text object"
+msgstr "Rādīt teksta objektu"
+#: ../gui/wxpython/mapwin/decorations.py:372
+msgid ""
+"Drag text with mouse in pointer mode to position.\n"
+"Double-click to change options"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:554
-#: ../gui/wxpython/core/settings.py:611
-msgid "animation"
+#: ../gui/wxpython/modules/extensions.py:39
+msgid "Fetch & install extension from GRASS Addons"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:748
-#: ../gui/wxpython/core/settings.py:797
-msgid "Collapse all except PERMANENT and current"
+#: ../gui/wxpython/modules/extensions.py:50
+msgid "Repository"
+msgstr "Repozitorijs"
+#: ../gui/wxpython/modules/extensions.py:52
+msgid "List of extensions - double-click to install"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:749
-#: ../gui/wxpython/core/settings.py:798
-msgid "Collapse all except PERMANENT"
+#: ../gui/wxpython/modules/extensions.py:95
+msgid "&Fetch"
+msgstr "&Saņemt"
+#: ../gui/wxpython/modules/extensions.py:96
+msgid "Fetch list of available modules from GRASS Addons SVN repository"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:750
-#: ../gui/wxpython/core/settings.py:799
-msgid "Collapse all except current"
+#: ../gui/wxpython/modules/extensions.py:100
+msgid "&Install"
+msgstr "&Instalēt"
+#: ../gui/wxpython/modules/extensions.py:101
+msgid "Install selected add-ons GRASS module"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:751
-#: ../gui/wxpython/core/settings.py:800
-msgid "Collapse all"
+#: ../gui/wxpython/modules/extensions.py:104
+msgid "Show g.extension manual page"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:752
-#: ../gui/wxpython/core/settings.py:801
-msgid "Expand all"
+#: ../gui/wxpython/modules/extensions.py:168
+msgid "Extension not defined"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:754
-#: ../gui/wxpython/core/settings.py:805
-msgid "Display selected"
+#: ../gui/wxpython/modules/extensions.py:191
+msgid "Fetching list of modules from GRASS-Addons SVN (be patient)..."
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:762
-#: ../gui/wxpython/core/settings.py:813
-msgid "Classic (labels only)"
+#: ../gui/wxpython/modules/extensions.py:210
+#, fuzzy
+msgid "Install"
+msgstr "&Instalēt"
+#: ../gui/wxpython/modules/extensions.py:213
+#, fuzzy
+msgid "Show manual page"
+msgstr "Rādīt pamācību"
+#: ../gui/wxpython/modules/extensions.py:312
+#, fuzzy
+msgid "Unable to load extensions."
+msgstr "Nav iespējams dzēst novietojumu"
+#: ../gui/wxpython/modules/extensions.py:353
+msgid "Manage installed GRASS Addons extensions"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:763
-#: ../gui/wxpython/core/settings.py:814
-msgid "Combined (labels and module names)"
+#: ../gui/wxpython/modules/extensions.py:362
+msgid "List of installed extensions"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:764
-#: ../gui/wxpython/core/settings.py:815
-msgid "Professional (module names only)"
+#: ../gui/wxpython/modules/extensions.py:368
+msgid "Uninstall selected AddOns extensions"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:803
-#: ../gui/wxpython/core/settings.py:859
-msgid "box"
+#: ../gui/wxpython/modules/extensions.py:370
+#, fuzzy
+msgid "Reinstall selected AddOns extensions"
+msgstr "Pārsaukt izvēlēto novietojumu"
+#: ../gui/wxpython/modules/extensions.py:407
+#, fuzzy
+msgid "No extension selected. Operation canceled."
+msgstr "Darbība ir atcelta."
+#: ../gui/wxpython/modules/extensions.py:424
+#, python-format
+msgid ""
+"List of files to be removed:\n"
+"%(files)s\n"
+"\n"
+"Do you want really to remove <%(ext)s> extension?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:804
-#: ../gui/wxpython/core/settings.py:860
-msgid "sphere"
+#: ../gui/wxpython/modules/extensions.py:427
+msgid "Remove extension"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:805
-#: ../gui/wxpython/core/settings.py:861
-msgid "cube"
+#: ../gui/wxpython/modules/extensions.py:458
+msgid "Extension"
+msgstr "Paplašinājums"
+#: ../gui/wxpython/modules/vclean.py:37 ../gui/wxpython/modules/vclean.py:119
+msgid "Set up vector cleaning tools"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:806
-#: ../gui/wxpython/core/settings.py:862
-msgid "diamond"
+#: ../gui/wxpython/modules/vclean.py:74
+msgid "break lines/boundaries"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:807
-#: ../gui/wxpython/core/settings.py:863
-msgid "dtree"
+#: ../gui/wxpython/modules/vclean.py:75
+msgid "remove duplicates"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:808
-#: ../gui/wxpython/core/settings.py:864
-msgid "ctree"
+#: ../gui/wxpython/modules/vclean.py:76
+msgid "remove dangles"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:809
-#: ../gui/wxpython/core/settings.py:865
-msgid "aster"
+#: ../gui/wxpython/modules/vclean.py:77
+msgid "change boundary dangles to lines"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:810
-#: ../gui/wxpython/core/settings.py:866
-msgid "gyro"
+#: ../gui/wxpython/modules/vclean.py:78
+msgid "remove bridges"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:811
-#: ../gui/wxpython/core/settings.py:867
-msgid "histogram"
+#: ../gui/wxpython/modules/vclean.py:79
+msgid "change bridges to lines"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:845
-#: ../gui/wxpython/core/settings.py:901
-#, python-format
-msgid "Unable to read settings file <%s>\n"
+#: ../gui/wxpython/modules/vclean.py:80
+msgid "snap lines/boundaries"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:869
-#: ../gui/wxpython/core/settings.py:925
-#, python-format
-msgid ""
-"Error: Reading settings from file <%(file)s> failed.\n"
-"\t\tDetails: %(detail)s\n"
-"\t\tLine: '%(line)s'\n"
+#: ../gui/wxpython/modules/vclean.py:81
+msgid "remove duplicate area centroids"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:888
-#: ../gui/wxpython/core/settings.py:944
-msgid "Unable to create settings directory"
+#: ../gui/wxpython/modules/vclean.py:82
+msgid "break polygons"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:924
-#: ../gui/wxpython/core/settings.py:980
-#, python-format
-msgid ""
-"Writing settings to file <%(file)s> failed.\n"
-"\n"
-"Details: %(detail)s"
+#: ../gui/wxpython/modules/vclean.py:83
+msgid "prune lines/boundaries"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1023
-#: ../gui/wxpython/core/settings.py:1079
-msgid "Unable to set "
+#: ../gui/wxpython/modules/vclean.py:84
+msgid "remove small areas"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1049
-#: ../gui/wxpython/gui_modules/preferences.py:1055
-#: ../gui/wxpython/core/settings.py:1105 ../gui/wxpython/core/settings.py:1111
-#, python-format
-msgid "Unable to parse settings '%s'"
+#: ../gui/wxpython/modules/vclean.py:85
+msgid "remove lines/boundaries of zero length"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1076
-#: ../gui/wxpython/gui_core/preferences.py:58
-msgid "User settings"
-msgstr "Lietotāja iestatījumi"
+#: ../gui/wxpython/modules/vclean.py:86
+msgid "remove small angles at nodes"
+msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1096
-#: ../gui/wxpython/gui_core/preferences.py:78
-msgid "Set to default"
+#: ../gui/wxpython/modules/vclean.py:121
+msgid "Choose cleaning tools and set thresholds"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1104
-#: ../gui/wxpython/gui_core/preferences.py:86
-msgid "Revert settings to default and apply changes"
+#: ../gui/wxpython/modules/vclean.py:125
+msgid "Select input vector map:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1166
-#: ../gui/wxpython/gui_core/preferences.py:151
-msgid "Settings applied to current session but not saved"
+#: ../gui/wxpython/modules/vclean.py:131
+msgid " Feature type: "
+msgstr " Objekta tips: "
+#: ../gui/wxpython/modules/vclean.py:135
+msgid "Select output vector map:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1184
-#: ../gui/wxpython/gui_core/preferences.py:178
+#: ../gui/wxpython/modules/vclean.py:167
+msgid "Copy the current command string to the clipboard (Ctrl+C)"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:203
+msgid "line"
+msgstr "līnija"
+#: ../gui/wxpython/modules/vclean.py:204
+msgid "boundary"
+msgstr "robeža"
+#: ../gui/wxpython/modules/vclean.py:205
+msgid "centroid"
+msgstr "centroīds"
+#: ../gui/wxpython/modules/vclean.py:206
+#: ../gui/wxpython/vdigit/preferences.py:433
+msgid "area"
+msgstr "laukums"
+#: ../gui/wxpython/modules/vclean.py:207
+msgid "face"
+msgstr "fasete"
+#: ../gui/wxpython/modules/vclean.py:359
 #, python-format
-msgid "Settings saved to file '%s'."
+msgid "%s. cleaning tool removed, will be ignored"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1215
-#: ../gui/wxpython/gui_core/preferences.py:215
-msgid "Key column cannot be empty string."
+#: ../gui/wxpython/modules/vclean.py:361
+msgid "Please select a cleaning tool to remove"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1252
-#: ../gui/wxpython/gui_core/preferences.py:252
-msgid "GUI Settings"
-msgstr "Grafiskās vides iestatījumi"
+#: ../gui/wxpython/modules/vclean.py:382
+#, python-format
+msgid "%s. cleaning tool moved up"
+msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1278
-#: ../gui/wxpython/gui_core/preferences.py:280
-msgid "Layer Manager settings"
-msgstr "Slāņu pārvaldnieka iestatījumi"
+#: ../gui/wxpython/modules/vclean.py:384
+msgid "1. cleaning tool can not be moved up "
+msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1289
-#: ../gui/wxpython/gui_core/preferences.py:291
-msgid "Ask when removing map layer from layer tree"
+#: ../gui/wxpython/modules/vclean.py:386
+msgid "Please select a cleaning tool to move up"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1299
-#: ../gui/wxpython/gui_core/preferences.py:301
-msgid "Ask when quiting wxGUI or closing display"
+#: ../gui/wxpython/modules/vclean.py:408
+#, python-format
+msgid "%s. cleaning tool moved down"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1309
-#: ../gui/wxpython/gui_modules/preferences.py:1319
-#: ../gui/wxpython/gui_core/preferences.py:311
-#: ../gui/wxpython/gui_core/preferences.py:321
+#: ../gui/wxpython/modules/vclean.py:410
+msgid "Last cleaning tool can not be moved down "
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:412
+msgid "Please select a cleaning tool to move down"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:423
 #, python-format
-msgid "Hide '%s' tab (requires GUI restart)"
+msgid "cleaning tool: '%s'"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1332
-#: ../gui/wxpython/gui_core/preferences.py:334
-msgid "Automatically copy selected text to clipboard (in Command console)"
+#: ../gui/wxpython/modules/vclean.py:431
+#, python-format
+msgid "Threshold for %(num)s. tool '%(tool)s': %(thresh)s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1346
-#: ../gui/wxpython/gui_core/preferences.py:348
-msgid "Workspace settings"
-msgstr "Darbtelpas iestatījumi"
+#: ../gui/wxpython/modules/vclean.py:459
+msgid "Name of input vector map"
+msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1354
-#: ../gui/wxpython/gui_core/preferences.py:356
-msgid "Suppress positioning Map Display Window(s)"
+#: ../gui/wxpython/modules/vclean.py:460
+msgid "Name for output vector map"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1366
-#: ../gui/wxpython/gui_core/preferences.py:368
-msgid "Suppress positioning Layer Manager window"
+#: ../gui/wxpython/modules/vclean.py:462
+msgid "Threshold"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1377
-#: ../gui/wxpython/gui_core/preferences.py:379
-msgid "Save current window layout as default"
+#: ../gui/wxpython/modules/vclean.py:464
+#, python-format
+msgid "'%s' not defined"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1380
-#: ../gui/wxpython/gui_core/preferences.py:382
+#: ../gui/wxpython/modules/vclean.py:466
+#, python-format
 msgid ""
-"Save current position and size of Layer Manager window and opened Map "
-"Display window(s) and use as default for next sessions."
+"Some parameters not defined. Operation canceled.\n"
+"\n"
+"%s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1421
-#: ../gui/wxpython/gui_core/preferences.py:423
-msgid "Font for command output:"
+#: ../gui/wxpython/modules/vclean.py:471
+msgid "Executing selected cleaning operations..."
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1435
-#: ../gui/wxpython/gui_core/preferences.py:469
-msgid "Appearance settings"
-msgstr "Izskata iestatījumi"
+#: ../gui/wxpython/modules/vclean.py:527
+msgid "Vector cleaning command copied to clipboard"
+msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1446
-#: ../gui/wxpython/gui_core/preferences.py:480
-msgid "Element list:"
+#: ../gui/wxpython/modules/colorrules.py:74
+msgid "Check all"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1468
-msgid "Menu style (requires GUI restart):"
+#: ../gui/wxpython/modules/colorrules.py:77
+msgid "Clear all"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1492
-#: ../gui/wxpython/gui_core/preferences.py:526
-msgid "Height of map selection popup window (in pixels):"
+#: ../gui/wxpython/modules/colorrules.py:133
+msgid "Enter vector attribute values"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1516
-#: ../gui/wxpython/gui_core/preferences.py:550
-msgid "Icon theme (requires GUI restart):"
+#: ../gui/wxpython/modules/colorrules.py:290
+msgid "Bad color format. Use color format '0:0:0'"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1546
-#: ../gui/wxpython/gui_core/preferences.py:581
-msgid "Map Display"
-msgstr "Kartes skats"
+#: ../gui/wxpython/modules/colorrules.py:381
+#: ../gui/wxpython/wxplot/dialogs.py:371
+msgid "Select raster map:"
+msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1561
-#: ../gui/wxpython/gui_core/preferences.py:596
-msgid "Default font for GRASS displays:"
+#: ../gui/wxpython/modules/colorrules.py:383
+msgid "Select vector map:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1578
-#: ../gui/wxpython/gui_core/preferences.py:613
-msgid "Default display settings"
+#: ../gui/wxpython/modules/colorrules.py:400
+msgid "Import or export color table:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1590
-#: ../gui/wxpython/gui_core/preferences.py:625
-msgid "Display driver:"
+#: ../gui/wxpython/modules/colorrules.py:405
+msgid "Choose file to load color table"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1610
-#: ../gui/wxpython/gui_core/preferences.py:645
-msgid "Statusbar mode:"
+#: ../gui/wxpython/modules/colorrules.py:406
+msgid "Load"
+msgstr "Ielādēt"
+#: ../gui/wxpython/modules/colorrules.py:407
+msgid "Type filename or click to choose file and load color table"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1675
-#: ../gui/wxpython/gui_core/preferences.py:710
-msgid "Enable auto-rendering"
+#: ../gui/wxpython/modules/colorrules.py:413
+msgid "Choose file to save color table"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1688
-#: ../gui/wxpython/gui_core/preferences.py:723
-msgid "Enable auto-zooming to selected map layer"
+#: ../gui/wxpython/modules/colorrules.py:414
+msgid "Type filename or click to choose file and save color table"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1712
-#: ../gui/wxpython/gui_core/preferences.py:786
+#: ../gui/wxpython/modules/colorrules.py:422
 #, fuzzy
-msgid "Command dialog settings"
-msgstr "Mainīt iestatījumus"
+msgid "&Set"
+msgstr "Ie&statījumi"
-#: ../gui/wxpython/gui_modules/preferences.py:1734
-#: ../gui/wxpython/gui_core/preferences.py:808
-msgid "Close dialog when command is successfully finished"
-msgstr "Aizvērt dialogu, kad komandas izpilde ir pabeigta sekmīgi"
+#: ../gui/wxpython/modules/colorrules.py:429
+#, fuzzy
+msgid "Load color table:"
+msgstr "Krāsu tabulas"
-#: ../gui/wxpython/gui_modules/preferences.py:1755
-#: ../gui/wxpython/gui_core/preferences.py:829
-msgid "Allow interactive input"
+#: ../gui/wxpython/modules/colorrules.py:433
+msgid "Load color table from file:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1765
-#: ../gui/wxpython/gui_core/preferences.py:839
-msgid "Verbosity level:"
+#: ../gui/wxpython/modules/colorrules.py:436
+msgid "Save color table to file:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1784
-#, fuzzy
-msgid "Raster settings"
-msgstr "Rastra iestatījumi"
+#: ../gui/wxpython/modules/colorrules.py:465
+msgid "Reload default table"
+msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1795
-#: ../gui/wxpython/gui_core/preferences.py:880
-msgid "Make null cells opaque"
+#: ../gui/wxpython/modules/colorrules.py:527
+msgid "Show preview of map (current Map Display extent is used)."
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1806
-#: ../gui/wxpython/gui_core/preferences.py:891
-msgid "Default color table"
+#: ../gui/wxpython/modules/colorrules.py:557
+#: ../gui/wxpython/modules/colorrules.py:1714
+msgid "No valid color rules given."
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1832
-msgid "Vector settings"
-msgstr "Vektoru iestatījumi"
+#: ../gui/wxpython/modules/colorrules.py:640
+msgid "Invalid color table format"
+msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1838
-#: ../gui/wxpython/gui_core/preferences.py:923
-msgid "Display:"
-msgstr "Attēlot:"
+#: ../gui/wxpython/modules/colorrules.py:717
+#, python-format
+msgid "Invalid rule value '%s'. Unable to apply color table."
+msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1860
-#: ../gui/wxpython/gui_modules/vdigit.py:377
-#: ../gui/wxpython/gui_core/preferences.py:1034
-#: ../gui/wxpython/vdigit/preferences.py:344
-msgid "Attributes"
-msgstr "Atribūti"
+#: ../gui/wxpython/modules/colorrules.py:795
+msgid "Create new color table for raster map"
+msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1868
-#: ../gui/wxpython/gui_core/preferences.py:1042
-msgid "Highlighting"
-msgstr "Izcelšana"
+#: ../gui/wxpython/modules/colorrules.py:871
+msgid "Enter raster category values or percents"
+msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1884
-#: ../gui/wxpython/gui_core/preferences.py:1058
-msgid "Line width (in pixels):"
-msgstr "Līnijas platums (pikseļos):"
+#: ../gui/wxpython/modules/colorrules.py:877
+msgid "fp range"
+msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1907
-#: ../gui/wxpython/gui_core/preferences.py:1081
-msgid "Data browser"
-msgstr "Datu pārlūks"
+#: ../gui/wxpython/modules/colorrules.py:878
+#, python-format
+msgid "Enter raster category values or percents (%(range)s = %(min)d-%(max)d)"
+msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1912
-#: ../gui/wxpython/gui_core/preferences.py:1086
-msgid "Left mouse double click:"
+#: ../gui/wxpython/modules/colorrules.py:966
+msgid "Create new color rules for vector map"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1924
-#: ../gui/wxpython/gui_core/preferences.py:1098
-msgid "Encoding (e.g. utf-8, ascii, iso8859-1, koi8-r):"
+#: ../gui/wxpython/modules/colorrules.py:978
+#: ../gui/wxpython/modules/colorrules.py:1509
+msgid "Enter vector attribute values or percents:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1935
-#: ../gui/wxpython/gui_core/preferences.py:1109
-msgid "Ask when deleting data record(s) from table"
+#: ../gui/wxpython/modules/colorrules.py:980
+#: ../gui/wxpython/modules/colorrules.py:1511
+msgid "Enter vector attribute values:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1956
-#: ../gui/wxpython/gui_core/preferences.py:1130
-msgid "Create table"
+#: ../gui/wxpython/modules/colorrules.py:991
+msgid "Select vector columns"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1996
-#: ../gui/wxpython/gui_core/preferences.py:1171
-msgid "Projection statusbar settings"
+#: ../gui/wxpython/modules/colorrules.py:993
+msgid "Layer:"
+msgstr "Slānis:"
+#: ../gui/wxpython/modules/colorrules.py:995
+msgid "Attribute column:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:2022
-#: ../gui/wxpython/gui_core/preferences.py:1197
-msgid "Proj.4 string (required):"
+#: ../gui/wxpython/modules/colorrules.py:998
+msgid "Load color from column:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:2038
-#: ../gui/wxpython/gui_core/preferences.py:1213
-msgid "EPSG file:"
-msgstr "EPSG fails:"
+msgid "Save color to column:"
+msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:2053
-#: ../gui/wxpython/gui_core/preferences.py:1228
+#: ../gui/wxpython/modules/colorrules.py:1000
+msgid "Load size from column:"
+msgstr ""
+msgid "Save size to column:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1002
+msgid "Load width from column:"
+msgstr ""
+msgid "Save width to column:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1006
+msgid "Use color column instead of color table:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1021
+msgid "Add GRASSRGB column to current attribute table."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1076
+#: ../gui/wxpython/modules/colorrules.py:1125
+msgid "Import or export color table"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1137
+#, python-format
 msgid ""
-"Load EPSG codes (be patient), enter EPSG code or insert Proj.4 string "
-"directly."
+"Database connection for vector map <%s> is not defined in DB file.  Do you "
+"want to create and connect new attribute table?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:2061
-#: ../gui/wxpython/gui_core/preferences.py:1236
-msgid "&Load EPSG codes"
+#: ../gui/wxpython/modules/colorrules.py:1140
+msgid "No database connection defined"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:2072
-#: ../gui/wxpython/gui_core/preferences.py:1247
-msgid "Coordinates format"
+#: ../gui/wxpython/modules/colorrules.py:1212
+#, python-format
+msgid ""
+"Selected map <%(map)s> is not in current mapset <%(mapset)s>. Attribute "
+"table cannot be edited."
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:2081
-#: ../gui/wxpython/gui_core/preferences.py:1256
-#, fuzzy
-msgid "LL projections"
-msgstr "Projekcija"
+#: ../gui/wxpython/modules/colorrules.py:1365
+#, python-format
+msgid "%s column already exists."
+msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:2100
-#: ../gui/wxpython/gui_core/preferences.py:1275
-msgid "Precision:"
-msgstr "Precizitāte:"
+#: ../gui/wxpython/modules/colorrules.py:1397
+msgid "Please wait, loading data from attribute table..."
+msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:2138
-#: ../gui/wxpython/gui_core/preferences.py:1313
+#: ../gui/wxpython/modules/colorrules.py:1458
 #, python-format
-msgid "Unable to read EPSG codes: %s"
+msgid ""
+"Number of loaded records reached %d, displaying all the records will be time-"
+"consuming and may lead to computer freezing, do you still want to continue?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:2167
-#: ../gui/wxpython/gui_modules/preferences.py:2176
-#: ../gui/wxpython/gui_modules/preferences.py:2186
-#: ../gui/wxpython/gui_core/preferences.py:1342
-#: ../gui/wxpython/gui_core/preferences.py:1351
-#: ../gui/wxpython/gui_core/preferences.py:1360
+#: ../gui/wxpython/modules/colorrules.py:1462
+msgid "Too many records"
+msgstr "Pārāk daudz ierakstu"
+#: ../gui/wxpython/modules/colorrules.py:1504
 #, python-format
-msgid "EPSG code %s not found"
+msgid "Enter vector attribute values or percents %s:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:2194
-#: ../gui/wxpython/gui_core/preferences.py:1368
-msgid "Select default display font"
+#: ../gui/wxpython/modules/colorrules.py:1506
+#, python-format
+msgid "Enter vector attribute values %s:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:2277
-#: ../gui/wxpython/gui_core/preferences.py:1474
-msgid "Select font:"
+#: ../gui/wxpython/modules/colorrules.py:1648
+msgid "Please select column to save values to."
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:2301
-#: ../gui/wxpython/gui_core/preferences.py:1498
-msgid "Character encoding:"
+#: ../gui/wxpython/modules/colorrules.py:1684
+msgid "No color column defined. Operation canceled."
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:2419
-#: ../gui/wxpython/gui_core/preferences.py:1616
-msgid "Manage access to mapsets"
+#: ../gui/wxpython/modules/colorrules.py:1699
+msgid "Thematic mapping for vector map in 3D view"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:2432
-#: ../gui/wxpython/gui_core/preferences.py:1629
-msgid ""
-"Check a mapset to make it accessible, uncheck it to hide it.\n"
-"  Notes:\n"
-"    - The current mapset is always accessible.\n"
-"    - You may only write to the current mapset.\n"
-"    - You may only write to mapsets which you own."
+#: ../gui/wxpython/modules/histogram.py:269
+msgid "GRASS GIS Histogramming Tool (d.histogram)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:2507
-#: ../gui/wxpython/gui_core/preferences.py:1704
-msgid "Owner"
+#: ../gui/wxpython/modules/histogram.py:374
+msgid "Select font for histogram text"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:548
-msgid "Unable to display histogram of raster map."
+#: ../gui/wxpython/modules/mcalc_builder.py:58
+msgid "GRASS GIS Raster Map Calculator"
+msgstr "GRASS GIS rastra kalkulators"
+#: ../gui/wxpython/modules/mcalc_builder.py:61
+msgid "GRASS GIS 3D Raster Map Calculator"
+msgstr "GRASS GIS 3D rastra kalkulators"
+#: ../gui/wxpython/modules/mcalc_builder.py:72
+msgid "mapcalc statement"
+msgstr "mapcalc izteiksme"
+#: ../gui/wxpython/modules/mcalc_builder.py:128
+msgid "Operators"
+msgstr "Operatori"
+#: ../gui/wxpython/modules/mcalc_builder.py:130
+#: ../gui/wxpython/vnet/dialogs.py:302 ../gui/wxpython/scripts/vkrige.py:117
+msgid "Output"
+msgstr "Izvade"
+#: ../gui/wxpython/modules/mcalc_builder.py:132
+msgid "Operands"
+msgstr "Operandi"
+#: ../gui/wxpython/modules/mcalc_builder.py:134
+msgid "Expression"
+msgstr "Izteiksme"
+#: ../gui/wxpython/modules/mcalc_builder.py:146
+msgid "Save expression to file"
+msgstr "Saglabāt izteiksmi failā"
+#: ../gui/wxpython/modules/mcalc_builder.py:149
+msgid "Load expression from file"
+msgstr "Ielādēt izteiksmi no faila"
+#: ../gui/wxpython/modules/mcalc_builder.py:153
+msgid "exponent"
+msgstr "eksponente"
+#: ../gui/wxpython/modules/mcalc_builder.py:155
+msgid "divide"
+msgstr "dalīt"
+#: ../gui/wxpython/modules/mcalc_builder.py:157
+msgid "add"
+msgstr "pieskaitīt"
+#: ../gui/wxpython/modules/mcalc_builder.py:159
+msgid "subtract"
+msgstr "atņemt"
+#: ../gui/wxpython/modules/mcalc_builder.py:161
+msgid "modulus"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:661
+#: ../gui/wxpython/modules/mcalc_builder.py:163
+msgid "multiply"
+msgstr "reizināt"
+#: ../gui/wxpython/modules/mcalc_builder.py:168
+msgid "left shift"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:170
+msgid "right shift"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:172
+msgid "right shift (unsigned)"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:174
+msgid "greater than"
+msgstr "lielāks par"
+#: ../gui/wxpython/modules/mcalc_builder.py:176
+msgid "greater than or equal to"
+msgstr "lielāks vai vienāds"
+#: ../gui/wxpython/modules/mcalc_builder.py:178
+msgid "less than"
+msgstr "mazāks par"
+#: ../gui/wxpython/modules/mcalc_builder.py:180
+msgid "less than or equal to"
+msgstr "mazāks vai vienāds"
+#: ../gui/wxpython/modules/mcalc_builder.py:182
+msgid "equal to"
+msgstr "vienāds"
+#: ../gui/wxpython/modules/mcalc_builder.py:184
+msgid "not equal to"
+msgstr "nav vienāds"
+#: ../gui/wxpython/modules/mcalc_builder.py:187
+msgid "one's complement"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:189
+msgid "NOT"
+msgstr "NE"
+#: ../gui/wxpython/modules/mcalc_builder.py:191
+msgid "bitwise AND"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:193
+msgid "bitwise OR"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:195
+msgid "logical AND"
+msgstr "loģiskais UN"
+#: ../gui/wxpython/modules/mcalc_builder.py:197
+msgid "logical AND (ignores NULLs)"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:199
+msgid "logical OR"
+msgstr "loģiskais VAI"
+#: ../gui/wxpython/modules/mcalc_builder.py:201
+msgid "logical OR (ignores NULLs)"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:203
+msgid "conditional"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:216
+msgid "Name for new 3D raster map to create"
+msgstr "Jaunveidojamās 3D rastra kartes nosaukums"
+#: ../gui/wxpython/modules/mcalc_builder.py:218
+msgid "Name for new raster map to create"
+msgstr "Jaunveidojamās rastra kartes nosaukums"
+#: ../gui/wxpython/modules/mcalc_builder.py:222
+msgid "Insert existing 3D raster map"
+msgstr "Ievietot eksistējošu 3D rastra karti"
+#: ../gui/wxpython/modules/mcalc_builder.py:224
+msgid "Insert existing raster map"
+msgstr "Ievietot eksistējošu rastra karti"
+#: ../gui/wxpython/modules/mcalc_builder.py:228
+msgid "Insert mapcalc function"
+msgstr "Ievietot mapcalc funkciju"
+#: ../gui/wxpython/modules/mcalc_builder.py:239
+msgid "Add created raster map into layer tree"
+msgstr "Pievienot izveidoto rastra karti projekta slāņu sarakstam"
+#: ../gui/wxpython/modules/mcalc_builder.py:489
+msgid "You must enter the name of a new raster map to create."
+msgstr "Ir nepieciešams norādīt jaunveidojamās rastra kartes nosaukumu."
+#: ../gui/wxpython/modules/mcalc_builder.py:499
+msgid "You must enter an expression to create a new raster map."
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:538
+msgid "Choose a file name to save the expression"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:539
+#: ../gui/wxpython/modules/mcalc_builder.py:560
+msgid "Expression file (*)|*"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:559
+msgid "Choose a file name to load the expression"
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:44
+msgid "GRASS Bivariate Scatterplot Tool"
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:51
+msgid "Bivariate Scatterplot"
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:52 ../gui/wxpython/wxplot/scatter.py:53
+#: ../gui/wxpython/wxplot/scatter.py:134 ../gui/wxpython/wxplot/scatter.py:135
+#: ../gui/wxpython/wxplot/histogram.py:52
+#: ../gui/wxpython/wxplot/histogram.py:138
+msgid "Raster cell values"
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:85 ../gui/wxpython/wxplot/scatter.py:230
+#, fuzzy
+msgid "Nothing to plot."
+msgstr "Nekas"
+#: ../gui/wxpython/wxplot/scatter.py:95
+msgid "At least 2 raster maps must be specified"
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:116
+msgid "Bivariate Scatterplot of "
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:139 ../gui/wxpython/wxplot/scatter.py:143
 #, python-format
-msgid "Set opacity <%s>"
+msgid ": %s"
+msgstr ": %s"
+#: ../gui/wxpython/wxplot/scatter.py:236
+msgid "Regression Statistics for Scatterplot(s)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/sqlbuilder.py:68
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:68
+#: ../gui/wxpython/wxplot/scatter.py:248
 #, python-format
-msgid "GRASS SQL Builder (%(type)s): vector map <%(map)s>"
+msgid ""
+"Regression equation for raster map <%(rast1)s> vs. <%(rast2)s>:\n"
+"\n"
 msgstr ""
-#: ../gui/wxpython/gui_modules/sqlbuilder.py:75
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:75
-msgid "SQL statement not verified"
+#: ../gui/wxpython/wxplot/base.py:39
+msgid "Draw/re-draw plot"
 msgstr ""
-#: ../gui/wxpython/gui_modules/sqlbuilder.py:117
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:117
-msgid "Set SQL statement to default"
+#: ../gui/wxpython/wxplot/base.py:41
+msgid "Draw transect in map display window to profile"
 msgstr ""
-#: ../gui/wxpython/gui_modules/sqlbuilder.py:119
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:119
-msgid "Verify"
+#: ../gui/wxpython/wxplot/base.py:43
+msgid "Plot options"
 msgstr ""
-#: ../gui/wxpython/gui_modules/sqlbuilder.py:120
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:120
-msgid "Verify SQL statement"
+#: ../gui/wxpython/wxplot/base.py:45
+msgid "Plot statistics"
 msgstr ""
-#: ../gui/wxpython/gui_modules/sqlbuilder.py:122
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:122
-msgid "Apply SQL statement and close the dialog"
-msgstr "Pielietot SQL izteikumu un aizvērt dialogu"
+#: ../gui/wxpython/wxplot/base.py:47
+msgid "Save profile data to CSV file"
+msgstr ""
-#: ../gui/wxpython/gui_modules/sqlbuilder.py:124
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:124
-msgid "Close the dialog"
-msgstr "Aizvērt dialogu"
+#: ../gui/wxpython/wxplot/base.py:48
+msgid "Quit plot tool"
+msgstr ""
-#: ../gui/wxpython/gui_modules/sqlbuilder.py:173
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:173
-msgid "Columns"
-msgstr "Kolonas"
+#: ../gui/wxpython/wxplot/base.py:438
+msgid "Left Mouse Down at Point:"
+msgstr ""
-#: ../gui/wxpython/gui_modules/sqlbuilder.py:183
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:183
-msgid "Add on double-click"
+#: ../gui/wxpython/wxplot/base.py:467 ../gui/wxpython/wxplot/base.py:513
+#: ../gui/wxpython/wxplot/dialogs.py:557
+msgid "Text settings"
+msgstr "Teksta iestatījumi"
+#: ../gui/wxpython/wxplot/base.py:471 ../gui/wxpython/wxplot/base.py:527
+#: ../gui/wxpython/wxplot/dialogs.py:824
+msgid "Plot settings"
 msgstr ""
-#: ../gui/wxpython/gui_modules/sqlbuilder.py:184
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:184
-msgid "columns"
-msgstr "kolonas"
+#: ../gui/wxpython/wxplot/base.py:484
+msgid "This feature is not yet functional"
+msgstr ""
-msgid "values"
-msgstr "vērtības"
+#: ../gui/wxpython/wxplot/base.py:485
+msgid "Under Construction"
+msgstr ""
-#: ../gui/wxpython/gui_modules/sqlbuilder.py:195
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:195
-msgid "Values"
-msgstr "Vērtības"
+#: ../gui/wxpython/wxplot/profile.py:58
+msgid "GRASS Profile Analysis Tool"
+msgstr "GRASS GIS profilu analizēšanas rīks"
-#: ../gui/wxpython/gui_modules/sqlbuilder.py:204
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:204
-msgid "Get all values"
-msgstr "Saņemt visas vērtības"
+#: ../gui/wxpython/wxplot/profile.py:73 ../gui/wxpython/wxplot/profile.py:164
+msgid "Profile of"
+msgstr "Profils"
-#: ../gui/wxpython/gui_modules/sqlbuilder.py:207
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:207
-msgid "Get sample"
-msgstr "Paņemt paraugu"
+#: ../gui/wxpython/wxplot/profile.py:89
+#, python-format
+msgid "Distance (%s)"
+msgstr "Attālums (%s)"
-#: ../gui/wxpython/gui_modules/sqlbuilder.py:227
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:227
-msgid "Close dialog on apply"
-msgstr "Aizvērt dialogu, kad izmaiņas tiek pielietotas"
+#: ../gui/wxpython/wxplot/profile.py:91
+msgid "Distance along transect"
+msgstr ""
-#: ../gui/wxpython/gui_modules/sqlbuilder.py:427
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:423
-msgid "SQL statement is not valid"
-msgstr "SQL izteikums nav derīgs"
+#: ../gui/wxpython/wxplot/profile.py:92
+msgid "Cell values"
+msgstr "Šūnu vērtības"
-#: ../gui/wxpython/gui_modules/sqlbuilder.py:429
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:425
+#: ../gui/wxpython/wxplot/profile.py:157
+msgid "Not all points of profile lie inside computational region."
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:224
+msgid "Raster values"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:275
+msgid "You must draw a transect to profile in the map display window."
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:276
+msgid "Nothing to profile"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:338
+msgid "Choose prefix for file(s) where to save profile values..."
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:340
+msgid "Comma separated value (*.csv)|*.csv"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:350
+#, fuzzy
+msgid "Overwrite file?"
+msgstr "Pārrakstīt?"
+#: ../gui/wxpython/wxplot/profile.py:361
 #, python-format
 msgid ""
-"SQL statement is not valid.\n"
-"\n"
+"Unable to open file <%s> for writing.\n"
+"Reason: %s"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:373
+#, python-format
+msgid ""
+"%d files created:\n"
 "%s"
 msgstr ""
-"SQL izteiksme ir nederīga.\n"
-"\n"
-"%s"
-#: ../gui/wxpython/gui_modules/sqlbuilder.py:431
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:427
-msgid "SQL statement is valid"
-msgstr "SQL izteiksme ir derīga"
+#: ../gui/wxpython/wxplot/profile.py:375
+msgid "No files generated."
+msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:38
-#: ../gui/wxpython/wxplot/dialogs.py:34
+#: ../gui/wxpython/wxplot/profile.py:383
+msgid "Statistics for Profile(s)"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:35
 msgid "Select raster maps to profile"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:67
-#: ../gui/wxpython/wxplot/dialogs.py:63
+#: ../gui/wxpython/wxplot/dialogs.py:64
 msgid "Select raster map(s) to profile:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:110
-#: ../gui/wxpython/wxplot/dialogs.py:106
+#: ../gui/wxpython/wxplot/dialogs.py:107
 msgid "Select pairs of raster maps for scatterplots"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:146
-#: ../gui/wxpython/wxplot/dialogs.py:142
+#: ../gui/wxpython/wxplot/dialogs.py:143
 msgid "Select pairs of raster maps for bivariate scatterplots:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:161
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:390
-#: ../gui/wxpython/wxplot/dialogs.py:157 ../gui/wxpython/wxplot/dialogs.py:386
+#: ../gui/wxpython/wxplot/dialogs.py:158 ../gui/wxpython/wxplot/dialogs.py:405
 msgid "Number of bins (for FP maps)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:230
-#: ../gui/wxpython/wxplot/dialogs.py:226
+#: ../gui/wxpython/wxplot/dialogs.py:242
 msgid "Statistics"
 msgstr "Statistika"
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:281
-#: ../gui/wxpython/wxplot/dialogs.py:277
+#: ../gui/wxpython/wxplot/dialogs.py:293
 msgid "C&opy"
 msgstr "K&opēt"
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:282
-#: ../gui/wxpython/wxplot/dialogs.py:278
+#: ../gui/wxpython/wxplot/dialogs.py:294
 msgid "Copy regression statistics the clipboard (Ctrl+C)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:311
-#: ../gui/wxpython/wxplot/dialogs.py:307
+#: ../gui/wxpython/wxplot/dialogs.py:323
 msgid "Regression statistics copied to clipboard"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:320
-#: ../gui/wxpython/wxplot/dialogs.py:316
+#: ../gui/wxpython/wxplot/dialogs.py:332
 msgid "Select raster map or imagery group to histogram"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:346
-#: ../gui/wxpython/wxplot/dialogs.py:342
+#: ../gui/wxpython/wxplot/dialogs.py:358
 msgid "Histogram single raster"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:347
-#: ../gui/wxpython/wxplot/dialogs.py:343
+#: ../gui/wxpython/wxplot/dialogs.py:359
 msgid "Histogram imagery group"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:374
-#: ../gui/wxpython/wxplot/dialogs.py:370
+#: ../gui/wxpython/wxplot/dialogs.py:390
 msgid "Select image group:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:401
-#: ../gui/wxpython/wxplot/dialogs.py:397
+#: ../gui/wxpython/wxplot/dialogs.py:416
 msgid "Histogram type"
 msgstr "Histogrammas tips"
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:536
-#: ../gui/wxpython/gui_modules/wxplot.py:435
-#: ../gui/wxpython/wxplot/base.py:428 ../gui/wxpython/wxplot/dialogs.py:537
-msgid "Text settings"
-msgstr "Teksta iestatījumi"
+#: ../gui/wxpython/wxplot/dialogs.py:495
+msgid "Selected group must be in current mapset"
+msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:543
-#: ../gui/wxpython/wxplot/dialogs.py:544
+#: ../gui/wxpython/wxplot/dialogs.py:564
 msgid "Profile title:"
 msgstr "Profila virsraksts:"
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:553
-#: ../gui/wxpython/wxplot/dialogs.py:554
+#: ../gui/wxpython/wxplot/dialogs.py:574
 msgid "Title font size (pts):"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:564
-#: ../gui/wxpython/wxplot/dialogs.py:565
+#: ../gui/wxpython/wxplot/dialogs.py:585
 msgid "X-axis label:"
 msgstr "X ass nosaukums:"
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:574
-#: ../gui/wxpython/wxplot/dialogs.py:575
+#: ../gui/wxpython/wxplot/dialogs.py:595
 msgid "Y-axis label:"
 msgstr "Y ass nosaukums:"
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:584
-#: ../gui/wxpython/wxplot/dialogs.py:585
+#: ../gui/wxpython/wxplot/dialogs.py:605
 msgid "Label font size (pts):"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:607
-#: ../gui/wxpython/wxplot/dialogs.py:608
+#: ../gui/wxpython/wxplot/dialogs.py:627
 msgid "Font family:"
 msgstr "Fontu saime:"
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:621
-#: ../gui/wxpython/wxplot/dialogs.py:622
+#: ../gui/wxpython/wxplot/dialogs.py:641
 msgid "Style:"
 msgstr "Stils:"
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:635
-#: ../gui/wxpython/wxplot/dialogs.py:636
+#: ../gui/wxpython/wxplot/dialogs.py:655
 msgid "Weight:"
 msgstr "Svars:"
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:667
-#: ../gui/wxpython/wxplot/dialogs.py:668
+#: ../gui/wxpython/wxplot/dialogs.py:688
+#: ../gui/wxpython/wxplot/dialogs.py:1136
 msgid "Apply changes for the current session and close dialog"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:723
-#: ../gui/wxpython/wxplot/dialogs.py:724
+#: ../gui/wxpython/wxplot/dialogs.py:744
 #, python-format
-msgid "Plot text settings saved to file '%s'."
+msgid "Plot text sizes saved to file '%s'."
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:779
-#: ../gui/wxpython/wxplot/dialogs.py:780
+#: ../gui/wxpython/wxplot/dialogs.py:802
 msgid "No map or image group selected to plot."
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:801
-#: ../gui/wxpython/gui_modules/wxplot.py:439
-#: ../gui/wxpython/gui_modules/wxplot.py:496
-#: ../gui/wxpython/wxplot/base.py:432 ../gui/wxpython/wxplot/base.py:489
-#: ../gui/wxpython/wxplot/dialogs.py:802
-msgid "Plot settings"
-msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:821
-#: ../gui/wxpython/wxplot/dialogs.py:822
+#: ../gui/wxpython/wxplot/dialogs.py:844
 msgid "Map/image plotted"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:847
-#: ../gui/wxpython/wxplot/dialogs.py:848
+#: ../gui/wxpython/wxplot/dialogs.py:856
+#, fuzzy
+msgid "Settings for selected map"
+msgstr "Pārsaukt izvēlēto karšu kopu"
+#: ../gui/wxpython/wxplot/dialogs.py:872
 msgid "Line color"
 msgstr "Līnijas krāsa"
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:854
-#: ../gui/wxpython/gui_modules/vdigit.py:163
-#: ../gui/wxpython/wxplot/dialogs.py:855
-#: ../gui/wxpython/vdigit/preferences.py:130
+#: ../gui/wxpython/wxplot/dialogs.py:879
+#: ../gui/wxpython/vdigit/preferences.py:134
 msgid "Line width"
 msgstr "Līnijas platums"
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:888
-#: ../gui/wxpython/wxplot/dialogs.py:889
+#: ../gui/wxpython/wxplot/dialogs.py:913
 msgid "Transect segment marker settings"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:939
-#: ../gui/wxpython/wxplot/dialogs.py:940
+#: ../gui/wxpython/wxplot/dialogs.py:963
 msgid "Scatterplot points"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:991
-#: ../gui/wxpython/wxplot/dialogs.py:992
+#: ../gui/wxpython/wxplot/dialogs.py:1014
 msgid "Axis settings"
 msgstr "Asu iestatījumi"
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:997
-#: ../gui/wxpython/wxplot/dialogs.py:998
+#: ../gui/wxpython/wxplot/dialogs.py:1020
 msgid "X-Axis"
 msgstr "X ass"
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:998
-#: ../gui/wxpython/wxplot/dialogs.py:999
+#: ../gui/wxpython/wxplot/dialogs.py:1021
 msgid "Y-Axis"
 msgstr "Y ass"
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:1016
-#: ../gui/wxpython/wxplot/dialogs.py:1017
+#: ../gui/wxpython/wxplot/dialogs.py:1030
+#, fuzzy
+msgid "Scale"
+msgstr "Mērogs:"
+#: ../gui/wxpython/wxplot/dialogs.py:1034
+msgid ""
+"Automatic axis scaling, custom max and min, or scale matches data range (min)"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1039
 msgid "Custom min"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:1024
-#: ../gui/wxpython/wxplot/dialogs.py:1025
+#: ../gui/wxpython/wxplot/dialogs.py:1047
 msgid "Custom max"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:1032
-#: ../gui/wxpython/wxplot/dialogs.py:1033
+#: ../gui/wxpython/wxplot/dialogs.py:1055
 msgid "Log scale"
 msgstr "Logaritmiskā skala"
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:1056
-#: ../gui/wxpython/wxplot/dialogs.py:1057
+#: ../gui/wxpython/wxplot/dialogs.py:1079
 msgid "Grid and Legend settings"
 msgstr "Tīkla un leģendas iestatījumi"
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:1061
-#: ../gui/wxpython/wxplot/dialogs.py:1062
+#: ../gui/wxpython/wxplot/dialogs.py:1084
 msgid "Grid color"
 msgstr "Tīkla krāsa"
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:1068
-#: ../gui/wxpython/wxplot/dialogs.py:1069
+#: ../gui/wxpython/wxplot/dialogs.py:1091
 msgid "Show grid"
 msgstr "Rādīt tīklu"
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:1074
-#: ../gui/wxpython/wxplot/dialogs.py:1075
+#: ../gui/wxpython/wxplot/dialogs.py:1097
 msgid "Legend font size"
 msgstr "Leģendas fonta izmērs"
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:1084
-#: ../gui/wxpython/wxplot/dialogs.py:1085
+#: ../gui/wxpython/wxplot/dialogs.py:1107
 msgid "Show legend"
 msgstr "Rādīt leģendu"
-#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:1224
-#: ../gui/wxpython/wxplot/dialogs.py:1225
+#: ../gui/wxpython/wxplot/dialogs.py:1245
 #, python-format
 msgid "Plot settings saved to file '%s'."
 msgstr ""
-#: ../gui/wxpython/gui_modules/ghelp.py:75
-#: ../gui/wxpython/gui_modules/ghelp.py:83
-#: ../gui/wxpython/gui_core/ghelp.py:57 ../gui/wxpython/gui_core/ghelp.py:65
-msgid "description"
-msgstr "apraksts"
+#: ../gui/wxpython/wxplot/histogram.py:43
+#, fuzzy
+msgid "GRASS GIS Histogramming Tool"
+msgstr "GRASS GIS histogrammu veidošanas rīks"
-#: ../gui/wxpython/gui_modules/ghelp.py:76
-#: ../gui/wxpython/gui_modules/ghelp.py:85
-#: ../gui/wxpython/gui_core/ghelp.py:58 ../gui/wxpython/gui_core/ghelp.py:67
-msgid "command"
-msgstr "komanda"
+#: ../gui/wxpython/wxplot/histogram.py:51
+msgid "Histogram of"
+msgstr ""
-#: ../gui/wxpython/gui_modules/ghelp.py:77
-#: ../gui/wxpython/gui_modules/ghelp.py:84
-#: ../gui/wxpython/gui_core/ghelp.py:59 ../gui/wxpython/gui_core/ghelp.py:66
-msgid "keywords"
-msgstr "atslēgvārdi"
+#: ../gui/wxpython/wxplot/histogram.py:53
+#: ../gui/wxpython/wxplot/histogram.py:143
+msgid "Cell counts"
+msgstr "Šūnu skaits"
-#: ../gui/wxpython/gui_modules/ghelp.py:80
-#: ../gui/wxpython/gui_core/ghelp.py:62
-msgid "Find module(s)"
+#: ../gui/wxpython/wxplot/histogram.py:124
+#, python-format
+msgid "Histogram of image group <%s>"
 msgstr ""
-#: ../gui/wxpython/gui_modules/ghelp.py:152
-#: ../gui/wxpython/gui_modules/ghelp.py:185
-#: ../gui/wxpython/gui_core/ghelp.py:135 ../gui/wxpython/gui_core/ghelp.py:168
+#: ../gui/wxpython/wxplot/histogram.py:127
+#, fuzzy, python-format
+msgid "Histogram of raster map <%s>"
+msgstr "Izveidot rastra kartes histogrammu"
+#: ../gui/wxpython/wxplot/histogram.py:129
+#, fuzzy
+msgid "Histogram of selected raster maps"
+#: ../gui/wxpython/wxplot/histogram.py:136
 #, python-format
-msgid "%d modules found"
+msgid "Raster cell values %s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/ghelp.py:220
-#: ../gui/wxpython/gui_core/ghelp.py:203
-msgid "Menu tree (double-click to run command)"
+#: ../gui/wxpython/wxplot/histogram.py:144
+msgid "Percent of total cells"
 msgstr ""
-#: ../gui/wxpython/gui_modules/ghelp.py:230
-#: ../gui/wxpython/gui_core/ghelp.py:213
-msgid "Run selected command"
-msgstr "Darbināt izvēlēto komandu"
+#: ../gui/wxpython/wxplot/histogram.py:145
+msgid "Area"
+msgstr "Platība"
-#: ../gui/wxpython/gui_modules/ghelp.py:291
-#: ../gui/wxpython/gui_core/ghelp.py:274
-msgid "You must run this command from the menu or command line"
+#: ../gui/wxpython/wxplot/histogram.py:228
+msgid "Statistics for Map(s) Histogrammed"
 msgstr ""
-#: ../gui/wxpython/gui_modules/ghelp.py:361
-#: ../gui/wxpython/gui_modules/ghelp.py:1060
-#: ../gui/wxpython/gui_core/widgets.py:349
-#: ../gui/wxpython/modules/extensions.py:314
-msgid "Menu tree"
-msgstr "Izvēlnes koks"
+#: ../gui/wxpython/wxplot/histogram.py:232
+#, python-format
+msgid "Statistics for raster map <%s>"
+msgstr ""
-#: ../gui/wxpython/gui_modules/ghelp.py:515
-#: ../gui/wxpython/gui_core/ghelp.py:420
-msgid "Official GRASS site:"
-msgstr "Oficiālā GRASS GIS lapa:"
+#: ../gui/wxpython/vnet/toolbars.py:50
+msgid "Insert points from Map Display"
+msgstr ""
-#: ../gui/wxpython/gui_modules/ghelp.py:526
-#: ../gui/wxpython/gui_core/ghelp.py:431
-msgid "SVN Revision:"
-msgstr "SVN revīzija:"
+#: ../gui/wxpython/vnet/toolbars.py:52
+msgid "Activate snapping to nodes"
+msgstr ""
-#: ../gui/wxpython/gui_modules/ghelp.py:537
-#: ../gui/wxpython/gui_core/ghelp.py:442
-msgid "GIS Library Revision:"
+#: ../gui/wxpython/vnet/toolbars.py:54
+msgid "Activate mode for turns editing"
 msgstr ""
-#: ../gui/wxpython/gui_modules/ghelp.py:556
-#: ../gui/wxpython/gui_core/ghelp.py:496
-msgid "Info"
-msgstr "Informācija"
+#: ../gui/wxpython/vnet/toolbars.py:56
+msgid "Activate mode for global turns editing"
+msgstr ""
-#: ../gui/wxpython/gui_modules/ghelp.py:557
-#: ../gui/wxpython/gui_core/ghelp.py:497
-msgid "Copyright"
-msgstr "Autortiesības"
+#: ../gui/wxpython/vnet/toolbars.py:58
+#, fuzzy
+msgid "Add new point"
+msgstr "Kreisais: jauns punkts"
-#: ../gui/wxpython/gui_modules/ghelp.py:558
-#: ../gui/wxpython/gui_core/ghelp.py:498
-msgid "License"
-msgstr "Licence"
+#: ../gui/wxpython/vnet/toolbars.py:60
+#, fuzzy
+msgid "Delete selected point"
+msgstr "Dzēst izvēlēto novietojumu"
-#: ../gui/wxpython/gui_modules/ghelp.py:559
-#: ../gui/wxpython/gui_core/ghelp.py:499
-msgid "Authors"
-msgstr "Autori"
+#: ../gui/wxpython/vnet/toolbars.py:110
+msgid "Execute analysis"
+msgstr ""
-#: ../gui/wxpython/gui_modules/ghelp.py:560
-#: ../gui/wxpython/gui_core/ghelp.py:500
-msgid "Contributors"
+#: ../gui/wxpython/vnet/toolbars.py:112
+msgid "Go to previous analysis result"
 msgstr ""
-#: ../gui/wxpython/gui_modules/ghelp.py:561
-#: ../gui/wxpython/gui_core/ghelp.py:501
-msgid "Extra contributors"
+#: ../gui/wxpython/vnet/toolbars.py:114
+msgid "Go to next analysis result"
 msgstr ""
-#: ../gui/wxpython/gui_modules/ghelp.py:562
-#: ../gui/wxpython/gui_core/ghelp.py:502
-msgid "Translators"
-msgstr "Tulkotāji"
-#: ../gui/wxpython/gui_modules/ghelp.py:594
-#: ../gui/wxpython/gui_modules/ghelp.py:619
-#: ../gui/wxpython/gui_modules/ghelp.py:643
-#: ../gui/wxpython/gui_modules/ghelp.py:700
-#: ../gui/wxpython/gui_modules/ghelp.py:760
-#: ../gui/wxpython/gui_core/ghelp.py:537 ../gui/wxpython/gui_core/ghelp.py:561
-#: ../gui/wxpython/gui_core/ghelp.py:585 ../gui/wxpython/gui_core/ghelp.py:642
-#: ../gui/wxpython/gui_core/ghelp.py:704 ../gui/wxpython/gui_core/ghelp.py:854
-#, python-format
-msgid "%s file missing"
+#: ../gui/wxpython/vnet/toolbars.py:116
+msgid "Show analysis result"
 msgstr ""
-#: ../gui/wxpython/gui_modules/ghelp.py:686
-#: ../gui/wxpython/gui_modules/ghelp.py:746
-#: ../gui/wxpython/gui_core/ghelp.py:628 ../gui/wxpython/gui_core/ghelp.py:690
-#, python-format
-msgid "Error when reading file '%s'."
+#: ../gui/wxpython/vnet/toolbars.py:118
+msgid "Save temporary result"
 msgstr ""
-#: ../gui/wxpython/gui_modules/ghelp.py:687
-#: ../gui/wxpython/gui_modules/ghelp.py:747
-#: ../gui/wxpython/gui_core/ghelp.py:629 ../gui/wxpython/gui_core/ghelp.py:691
-msgid "Lines:"
-msgstr "Rindas:"
+#: ../gui/wxpython/vnet/toolbars.py:119
+#, fuzzy
+msgid "Vector network analysis settings"
+msgstr "Vektoru iestatījumi"
-#: ../gui/wxpython/gui_modules/ghelp.py:705
-#: ../gui/wxpython/gui_modules/ghelp.py:707
-#: ../gui/wxpython/gui_modules/ghelp.py:770
-#: ../gui/wxpython/gui_core/ghelp.py:647 ../gui/wxpython/gui_core/ghelp.py:649
-#: ../gui/wxpython/gui_core/ghelp.py:716
-msgid "E-mail"
-msgstr "E-pasts"
+#: ../gui/wxpython/vnet/toolbars.py:184
+msgid "Availiable analyses"
+msgstr ""
-msgid "Country"
-msgstr "Valsts"
+#: ../gui/wxpython/vnet/vnet_core.py:105
+msgid "Unable to perform analysis."
+msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:649
-msgid "OSGeo_ID"
-msgstr "OSGeo_ID"
-#: ../gui/wxpython/gui_modules/ghelp.py:772
-#: ../gui/wxpython/gui_core/ghelp.py:720
-msgid "Language"
-msgstr "Valoda"
-#: ../gui/wxpython/gui_modules/ghelp.py:797
-#: ../gui/wxpython/modules/extensions.py:42
-msgid "Fetch & install extension from GRASS Addons"
+#: ../gui/wxpython/vnet/vnet_core.py:210
+#, python-format
+msgid ""
+"Temporary map '%s' with result was changed outside vector network analysis "
+"tool.\n"
+"Showed result may not correspond original analysis result."
 msgstr ""
-#: ../gui/wxpython/gui_modules/ghelp.py:806
-#: ../gui/wxpython/modules/extensions.py:52
-msgid "Repository"
-msgstr "Repozitorijs"
-#: ../gui/wxpython/gui_modules/ghelp.py:808
-#: ../gui/wxpython/modules/extensions.py:54
-msgid "List of extensions"
+#: ../gui/wxpython/vnet/vnet_core.py:215
+msgid "Result changed outside"
 msgstr ""
-#: ../gui/wxpython/gui_modules/ghelp.py:812
-msgid "Fetch full info including description and keywords (takes time)"
+#: ../gui/wxpython/vnet/vnet_core.py:252
+msgid "Map can be created only in current mapset"
 msgstr ""
-#: ../gui/wxpython/gui_modules/ghelp.py:840
-#: ../gui/wxpython/modules/extensions.py:94
-msgid "&Fetch"
-msgstr "&Saņemt"
-#: ../gui/wxpython/gui_modules/ghelp.py:841
-#: ../gui/wxpython/modules/extensions.py:95
-msgid "Fetch list of available modules from GRASS Addons SVN repository"
+#: ../gui/wxpython/vnet/vnet_core.py:259 ../gui/wxpython/vnet/vnet_core.py:336
+#, python-format
+msgid "Vector map %s already exists. Do you want to overwrite it?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/ghelp.py:844
-#: ../gui/wxpython/modules/extensions.py:98
-msgid "&Install"
-msgstr "&Instalēt"
+#: ../gui/wxpython/vnet/vnet_core.py:262 ../gui/wxpython/vnet/vnet_core.py:339
+#, fuzzy
+msgid "Overwrite vector map"
+msgstr "Jauna vektoru karte"
-#: ../gui/wxpython/gui_modules/ghelp.py:845
-#: ../gui/wxpython/modules/extensions.py:99
-msgid "Install selected add-ons GRASS module"
+#: ../gui/wxpython/vnet/vnet_core.py:288
+msgid "Creation of turntable failed."
 msgstr ""
-#: ../gui/wxpython/gui_modules/ghelp.py:918
-#: ../gui/wxpython/modules/extensions.py:172
-msgid "Extension not defined"
+#: ../gui/wxpython/vnet/vnet_core.py:308
+msgid "Vector map with analysis result does not exist."
 msgstr ""
-#: ../gui/wxpython/gui_modules/ghelp.py:933
-#: ../gui/wxpython/modules/extensions.py:187
-msgid "Fetch list of available extensions by clicking on 'Fetch' button"
+#: ../gui/wxpython/vnet/vnet_core.py:329
+msgid "Map can be saved only to currently set mapset"
 msgstr ""
-#: ../gui/wxpython/gui_modules/ghelp.py:941
-#: ../gui/wxpython/modules/extensions.py:195
+#: ../gui/wxpython/vnet/vnet_core.py:408 ../gui/wxpython/vnet/vnet_core.py:608
 #, python-format
-msgid "%d items match"
+msgid "Please choose '%s' and '%s' point."
 msgstr ""
-#: ../gui/wxpython/gui_modules/ghelp.py:954
-#: ../gui/wxpython/modules/extensions.py:208
-msgid "Fetching list of modules from GRASS-Addons SVN (be patient)..."
+#: ../gui/wxpython/vnet/vnet_core.py:615
+msgid "Please choose at least two points."
 msgstr ""
-#: ../gui/wxpython/gui_modules/ghelp.py:1223
-#: ../gui/wxpython/gui_core/ghelp.py:994
-msgid "&Next"
-msgstr "&Nākamais"
-#: ../gui/wxpython/gui_modules/ghelp.py:1226
-#: ../gui/wxpython/gui_core/ghelp.py:997
-msgid "&Previous"
-msgstr "&Iepriekšējais"
-#: ../gui/wxpython/gui_modules/utils.py:300 ../gui/wxpython/core/utils.py:298
+#: ../gui/wxpython/vnet/vnet_core.py:894
 #, python-format
-msgid "Vector map <%(map)s>: %(msg)s\n"
+msgid ""
+"Input map '%s' for analysis was changed outside vector network analysis "
+"tool.\n"
+"Topology column may not correspond to changed situation."
 msgstr ""
-#: ../gui/wxpython/gui_modules/utils.py:523 ../gui/wxpython/core/utils.py:521
-#, python-format
-msgid "failed to open '%s'"
+#: ../gui/wxpython/vnet/vnet_core.py:899
+msgid "Input changed outside"
 msgstr ""
-#: ../gui/wxpython/gui_modules/utils.py:772 ../gui/wxpython/core/utils.py:740
+#: ../gui/wxpython/vnet/vnet_core.py:974
 #, python-format
-msgid "ERROR: Unable to determine GRASS version. Details: %s"
+msgid ""
+"Temporary map %s  already exists.\n"
+"Do you want to continue in analysis and overwrite it?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2140
+#: ../gui/wxpython/vnet/vnet_core.py:1000
 #, fuzzy
-msgid "Place scalebar"
-msgstr "Mērogjosla"
+msgid "Unable to use ctypes. \n"
+msgstr "Nav iespējams dzēst karšu kopu"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2146
-msgid "Delete last"
+#: ../gui/wxpython/vnet/vnet_core.py:1001
+#: ../gui/wxpython/vnet/vnet_core.py:1023
+msgid "Snapping mode can not be activated."
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot.py:406
-#, python-format
-msgid "Left Mouse Down at Point: (%.4f, %.4f)"
+#: ../gui/wxpython/vnet/vnet_core.py:1032
+msgid "Do you really want to activate snapping and overwrite it?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot.py:452
-#: ../gui/wxpython/wxplot/base.py:445
-msgid "This feature is not yet functional"
+#: ../gui/wxpython/vnet/vnet_core.py:1039
+#, python-format
+msgid ""
+"Temporary map '%s' was changed outside vector analysis tool.\n"
+"Do you really want to activate snapping and overwrite it? "
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot.py:453
-#: ../gui/wxpython/wxplot/base.py:446
-msgid "Under Construction"
+#: ../gui/wxpython/vnet/vnet_core.py:1044
+#, fuzzy
+msgid "Overwrite map"
+#: ../gui/wxpython/vnet/dialogs.py:67
+#, fuzzy
+msgid "GRASS GIS Vector Network Analysis Tool"
+#: ../gui/wxpython/vnet/dialogs.py:165
+msgid "Point list toolbar"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot.py:482
-#: ../gui/wxpython/wxplot/base.py:475
-msgid "Histogram text settings"
+#: ../gui/wxpython/vnet/dialogs.py:172
+#, fuzzy
+msgid "Analysis toolbar"
+msgstr "Analīze"
+#: ../gui/wxpython/vnet/dialogs.py:203
+msgid "Points for analysis:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot.py:559
-#: ../gui/wxpython/wxplot/histogram.py:40
-msgid "GRASS Histogramming Tool"
-msgstr "GRASS GIS histogrammu veidošanas rīks"
+#: ../gui/wxpython/vnet/dialogs.py:206
+#, fuzzy
+msgid "Points"
+msgstr "Punkts"
-#: ../gui/wxpython/gui_modules/wxplot.py:567
-#: ../gui/wxpython/wxplot/histogram.py:48
-msgid "Histogram of"
+#: ../gui/wxpython/vnet/dialogs.py:219
+#, fuzzy
+msgid "Analysis settings:"
+msgstr "Asu iestatījumi"
+#: ../gui/wxpython/vnet/dialogs.py:222
+msgid "Maximum distance of point to the network:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot.py:568
-#: ../gui/wxpython/gui_modules/wxplot.py:645
-#: ../gui/wxpython/gui_modules/wxplot.py:1104
-#: ../gui/wxpython/gui_modules/wxplot.py:1105
-#: ../gui/wxpython/gui_modules/wxplot.py:1203
-#: ../gui/wxpython/gui_modules/wxplot.py:1209
-#: ../gui/wxpython/wxplot/scatter.py:48 ../gui/wxpython/wxplot/scatter.py:49
-#: ../gui/wxpython/wxplot/scatter.py:143 ../gui/wxpython/wxplot/scatter.py:144
-#: ../gui/wxpython/wxplot/histogram.py:49
-#: ../gui/wxpython/wxplot/histogram.py:126
-msgid "Raster cell values"
+#: ../gui/wxpython/vnet/dialogs.py:234
+#, fuzzy
+msgid "Iso lines:"
+msgstr "Rindas:"
+#: ../gui/wxpython/vnet/dialogs.py:350
+#, fuzzy
+msgid "Add vector map into layer tree"
+msgstr "Pievienot izveidoto karti slāņu sarakstam"
+#: ../gui/wxpython/vnet/dialogs.py:469
+#, fuzzy
+msgid "Input tables"
+msgstr "Ievades dati"
+#: ../gui/wxpython/vnet/dialogs.py:495
+#, fuzzy
+msgid "Result tables"
+#: ../gui/wxpython/vnet/dialogs.py:507
+#, fuzzy
+msgid "Loading tables..."
+msgstr "Datu ielāde..."
+#: ../gui/wxpython/vnet/dialogs.py:640
+#, fuzzy
+msgid "Creating turntable..."
+msgstr "Izveidot tabulu?"
+#: ../gui/wxpython/vnet/dialogs.py:793
+#, fuzzy
+msgid "Input vector map does not exists."
+msgstr "Īpašība %s neeksistē"
+#: ../gui/wxpython/vnet/dialogs.py:811
+#, fuzzy
+msgid "Analysing..."
+msgstr "Analīze"
+#: ../gui/wxpython/vnet/dialogs.py:934
+msgid "Computing nodes..."
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot.py:569
-#: ../gui/wxpython/gui_modules/wxplot.py:650
-#: ../gui/wxpython/wxplot/histogram.py:50
-#: ../gui/wxpython/wxplot/histogram.py:131
-msgid "Cell counts"
-msgstr "Šūnu skaits"
+#: ../gui/wxpython/vnet/dialogs.py:1129
+msgid "Color table style %s:"
-#: ../gui/wxpython/gui_modules/wxplot.py:633
-#: ../gui/wxpython/gui_modules/wxplot.py:635
-#: ../gui/wxpython/wxplot/histogram.py:114
-#: ../gui/wxpython/wxplot/histogram.py:116
-#, python-format
-msgid "Histogram of %s"
+#: ../gui/wxpython/vnet/dialogs.py:1140
+msgid "Invert colors %s:"
+msgstr "Pārvaldīt krāsas"
+#: ../gui/wxpython/vnet/dialogs.py:1145
+#, fuzzy
+msgid "Line color:"
+msgstr "Līnijas krāsa"
+#: ../gui/wxpython/vnet/dialogs.py:1146
+msgid "Color for unused point:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot.py:643
-#: ../gui/wxpython/gui_modules/wxplot.py:1201
-#: ../gui/wxpython/gui_modules/wxplot.py:1207
-#: ../gui/wxpython/wxplot/histogram.py:124
-#, python-format
-msgid "Raster cell values %s"
+#: ../gui/wxpython/vnet/dialogs.py:1147
+msgid "Color for Start/From/Source/Used point:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot.py:651
-#: ../gui/wxpython/wxplot/histogram.py:132
-msgid "Percent of total cells"
+#: ../gui/wxpython/vnet/dialogs.py:1148
+msgid "Color for End/To/Sink point:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot.py:652
-#: ../gui/wxpython/wxplot/histogram.py:133
-msgid "Area"
-msgstr "Platība"
+#: ../gui/wxpython/vnet/dialogs.py:1149
+#, fuzzy
+msgid "Color for selected point:"
+msgstr "Tuvināt līdz izvēlētajām kartēm"
-#: ../gui/wxpython/gui_modules/wxplot.py:730
-#: ../gui/wxpython/wxplot/histogram.py:215
-msgid "Statistics for Map(s) Histogrammed"
+#: ../gui/wxpython/vnet/dialogs.py:1163
+#, fuzzy
+msgid "Point size:"
+msgstr "Fonta izmērs:"
+#: ../gui/wxpython/vnet/dialogs.py:1164
+#, fuzzy
+msgid "Point width:"
+msgstr "Līnijas platums"
+#: ../gui/wxpython/vnet/dialogs.py:1166
+msgid "Maximum number of results in history:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot.py:735
-#, python-format
-msgid ""
-"Statistics for %s\n"
-"\n"
-"%s\n"
+#: ../gui/wxpython/vnet/dialogs.py:1198
+msgid "Analysis result style:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot.py:753
-#: ../gui/wxpython/wxplot/profile.py:53
-msgid "GRASS Profile Analysis Tool"
-msgstr "GRASS GIS profilu analizēšanas rīks"
+#: ../gui/wxpython/vnet/dialogs.py:1228
+#, fuzzy
+msgid "Point style:"
+msgstr "Līnijas stils"
-#: ../gui/wxpython/gui_modules/wxplot.py:764
-#: ../gui/wxpython/gui_modules/wxplot.py:846
-#: ../gui/wxpython/wxplot/profile.py:64 ../gui/wxpython/wxplot/profile.py:151
-msgid "Profile of"
-msgstr "Profils"
+#: ../gui/wxpython/vnet/dialogs.py:1250
+#, fuzzy
+msgid "Other settings"
+msgstr "Rastra iestatījumi"
-#: ../gui/wxpython/gui_modules/wxplot.py:779
-#: ../gui/wxpython/wxplot/profile.py:78
-#, python-format
-msgid "Distance (%s)"
-msgstr "Attālums (%s)"
+#: ../gui/wxpython/vnet/dialogs.py:1325
+#, fuzzy
+msgid "New vector map with turntable"
-#: ../gui/wxpython/gui_modules/wxplot.py:781
-#: ../gui/wxpython/wxplot/profile.py:80
-msgid "Distance along transect"
+#: ../gui/wxpython/vnet/dialogs.py:1464
+msgid "Save analysis result"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot.py:782
-#: ../gui/wxpython/wxplot/profile.py:81
-msgid "Cell values"
-msgstr "Šūnu vērtības"
-#: ../gui/wxpython/gui_modules/wxplot.py:907
-#: ../gui/wxpython/wxplot/profile.py:211
-msgid "Raster values"
+#: ../gui/wxpython/vnet/dialogs.py:1575
+msgid "Edit intersection turns costs"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot.py:958
-#: ../gui/wxpython/wxplot/profile.py:262
-msgid "You must draw a transect to profile in the map display window."
+#: ../gui/wxpython/vnet/dialogs.py:1607
+msgid "Define Global Turn Costs"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot.py:959
-#: ../gui/wxpython/wxplot/profile.py:263
-msgid "Nothing to profile"
-msgstr ""
+#: ../gui/wxpython/vnet/widgets.py:373
+#, fuzzy
+msgid "Invalid value inserted. Operation canceled."
+msgstr "Darbība ir atcelta."
-#: ../gui/wxpython/gui_modules/wxplot.py:1026
-#: ../gui/wxpython/wxplot/profile.py:330
-msgid "Comma separated value (*.csv)|*.csv"
-msgstr ""
+#: ../gui/wxpython/vnet/widgets.py:519
+#, fuzzy
+msgid "Edit point"
+msgstr "Vektoru punktus"
-#: ../gui/wxpython/gui_modules/wxplot.py:1029
-#: ../gui/wxpython/wxplot/profile.py:333
-msgid "Path and prefix (for raster name) to save profile values..."
+#: ../gui/wxpython/vnet/vnet_data.py:144
+#, python-format
+msgid "Module <%s> does not support turns costs."
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot.py:1055
-#: ../gui/wxpython/wxplot/profile.py:359
-msgid "Statistics for Profile(s)"
+#: ../gui/wxpython/vnet/vnet_data.py:150
+#, python-format
+msgid "Vector map '%s' does not exist."
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot.py:1096
-#: ../gui/wxpython/wxplot/scatter.py:40
-msgid "GRASS Bivariate Scatterplot Tool"
+#: ../gui/wxpython/vnet/vnet_data.py:152
+msgid "Vector map was not chosen."
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot.py:1103
-#: ../gui/wxpython/wxplot/scatter.py:47
-msgid "Bivariate Scatterplot"
-msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:161
+#, fuzzy
+msgid "arc layer"
+msgstr "Kartes slāņi"
-#: ../gui/wxpython/gui_modules/wxplot.py:1181
-#: ../gui/wxpython/wxplot/scatter.py:125
-msgid "Bivariate Scatterplot of "
+#: ../gui/wxpython/vnet/vnet_data.py:162
+#, fuzzy
+msgid "node layer"
+msgstr "Pievienot slāni"
+#: ../gui/wxpython/vnet/vnet_data.py:163
+#, fuzzy
+msgid "turntable layer"
+msgstr "Pārvaldīt slāņus"
+#: ../gui/wxpython/vnet/vnet_data.py:164
+msgid "unique categories layer"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot.py:1292
-#: ../gui/wxpython/wxplot/scatter.py:244
-msgid "Regression Statistics for Scatterplot(s)"
+#: ../gui/wxpython/vnet/vnet_data.py:170
+#, python-format
+msgid "Chosen %s '%s' does not exist in vector map '%s'.\n"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot.py:1304
+#: ../gui/wxpython/vnet/vnet_data.py:173
 #, python-format
-msgid ""
-"Regression equation for %s vs. %s:\n"
-"\n"
+msgid "Choose existing %s.\n"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot.py:1305
+#: ../gui/wxpython/vnet/vnet_data.py:183
 #, python-format
 msgid ""
-"   %s = %s + %s(%s)\n"
-"\n"
+"Chosen column '%s' does not exist in attribute table of layer '%s' of vector "
+"map '%s'.\n"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot.py:1306
-#, python-format
-msgid "N = %s\n"
+#: ../gui/wxpython/vnet/vnet_data.py:237
+#, fuzzy
+msgid "type"
+msgstr "Datu tips"
+msgid "topology"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot.py:1307
-#, python-format
-msgid "R = %s\n"
+#: ../gui/wxpython/vnet/vnet_data.py:238 ../gui/wxpython/vnet/vnet_data.py:684
+#, fuzzy
+msgid "Start point"
+#, fuzzy
+msgid "End Point"
+msgstr "Punkts"
+#: ../gui/wxpython/vnet/vnet_data.py:491 ../gui/wxpython/vnet/vnet_data.py:500
+#: ../gui/wxpython/vnet/vnet_data.py:503
+#, fuzzy
+msgid "new point"
+#: ../gui/wxpython/vnet/vnet_data.py:661
+msgid "Arc forward/both direction(s) cost column:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot.py:1308
-#, python-format
-msgid "R-squared = %f\n"
+#: ../gui/wxpython/vnet/vnet_data.py:662
+msgid "arc forward/both"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxplot.py:1309
-#, python-format
-msgid "F = %s\n"
+#: ../gui/wxpython/vnet/vnet_data.py:665
+msgid "Arc backward direction cost column:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/histogram.py:177
-#: ../gui/wxpython/gui_modules/mapdisp_window.py:664
-#: ../gui/wxpython/modules/histogram.py:176
-#: ../gui/wxpython/mapdisp/mapwindow.py:471
-msgid "Please wait, exporting image..."
+#: ../gui/wxpython/vnet/vnet_data.py:666
+msgid "arc backward"
 msgstr ""
-#: ../gui/wxpython/gui_modules/histogram.py:267
-msgid "GRASS GIS Histogram of raster map"
-msgstr "GRASS GIS rastra kartes histogramma"
+#: ../gui/wxpython/vnet/vnet_data.py:669
+msgid "Arcs' cost column (for both directions):"
+msgstr ""
-#: ../gui/wxpython/gui_modules/histogram.py:358
-#: ../gui/wxpython/modules/histogram.py:368
-msgid "Select font for histogram text"
+#: ../gui/wxpython/vnet/vnet_data.py:670
+msgid "arc"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxvdigit.py:48
-#: ../gui/wxpython/vdigit/wxdigit.py:50
-msgid "Digitization Error"
+#: ../gui/wxpython/vnet/vnet_data.py:674
+#, fuzzy
+msgid "Node cost column:"
+msgstr "Skaitliska kolona:"
+#: ../gui/wxpython/vnet/vnet_data.py:675
+msgid "node"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxvdigit.py:53
-#: ../gui/wxpython/vdigit/wxdigit.py:55
+#: ../gui/wxpython/vnet/vnet_data.py:681
 #, python-format
-msgid "Unable to open vector map <%s>."
+msgid "Shortest path %s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxvdigit.py:55
-#: ../gui/wxpython/vdigit/wxdigit.py:57
-msgid "No vector map open for editing."
+#: ../gui/wxpython/vnet/vnet_data.py:685
+msgid "End point"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxvdigit.py:56
-msgid "Operation cancelled."
+#: ../gui/wxpython/vnet/vnet_data.py:701
+#, python-format
+msgid "Traveling salesman %s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxvdigit.py:63
+#: ../gui/wxpython/vnet/vnet_data.py:717
 #, python-format
-msgid ""
-"Writing new feature failed. Operation cancelled.\n"
-"\n"
-"Reason: %s"
+msgid "Maximum flow %s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxvdigit.py:72
+#: ../gui/wxpython/vnet/vnet_data.py:720
+#, fuzzy
+msgid "Source point"
+#: ../gui/wxpython/vnet/vnet_data.py:721
+msgid "Sink point"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:736
 #, python-format
-msgid "Reading feature id %d failed. Operation cancelled."
+msgid "Subnets for nearest centers %s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxvdigit.py:80
+#: ../gui/wxpython/vnet/vnet_data.py:752
 #, python-format
-msgid "Database link %d not available. Operation cancelled."
+msgid "Steiner tree for the network and given terminals %s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxvdigit.py:88
+#: ../gui/wxpython/vnet/vnet_data.py:766
 #, python-format
-msgid "Unable to start database driver <%s>. Operation cancelled."
+msgid "Shortest distance via the network %s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxvdigit.py:96
+#: ../gui/wxpython/vnet/vnet_data.py:785
 #, python-format
-msgid "Unable to open database <%(db)s> by driver <%(driver)s>. Operation cancelled."
+msgid "Cost isolines %s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxvdigit.py:104
+#: ../gui/wxpython/vnet/vnet_data.py:871
+#, fuzzy
+msgid "Overwrite map layer"
+msgstr "Pievienot rastra karti"
+#: ../gui/wxpython/core/render.py:135
 #, python-format
-msgid "Unable to execute SQL query '%s'. Operation cancelled."
+msgid "<%(name)s>: layer type <%(type)s> is not supported"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxvdigit.py:112
+#: ../gui/wxpython/core/render.py:156
 #, python-format
-msgid "Feature id %d is marked as dead. Operation cancelled."
+msgid "Command '%s' failed\n"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxvdigit.py:120
+#: ../gui/wxpython/core/render.py:158
 #, python-format
-msgid "Unsupported feature type %d. Operation cancelled."
+msgid "Details: %s\n"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxvdigit.py:466
-#: ../gui/wxpython/vdigit/wxdigit.py:411
+#: ../gui/wxpython/core/render.py:259
 #, python-format
-msgid "Unknown feature type '%s'"
+msgid "Unsupported map layer type '%s'"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxvdigit.py:471
-#: ../gui/wxpython/vdigit/wxdigit.py:416
-msgid "Not enough points for line"
+#: ../gui/wxpython/core/render.py:401
+msgid "Trying to recover from default region..."
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:391
-#: ../gui/wxpython/mapdisp/frame.py:65
-msgid "GRASS GIS - Map display"
-msgstr "GRASS GIS - kartes skats"
+#: ../gui/wxpython/core/render.py:447
+msgid "GISBASE not set. You must be in GRASS GIS to run this program."
+msgstr ""
+"Nav iestatīts GISBASE parametrs. Šo programmu var darbināt tikai GRASS GIS "
+"vidē."
-#: ../gui/wxpython/gui_modules/mapdisp.py:568
-#: ../gui/wxpython/mapdisp/frame.py:245
-msgid "Vector Digitizer Toolbar"
+#: ../gui/wxpython/core/render.py:492
+#, python-format
+msgid "Error: Unable to open '%(file)s'. Reason: %(ret)s. wxGUI exited.\n"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:589
-#: ../gui/wxpython/mapdisp/frame.py:266
+#: ../gui/wxpython/core/render.py:500
 #, python-format
 msgid ""
-"Unable to switch to 3D display mode.\n"
-"The Nviz python extension was not found or loaded properly.\n"
-"Switching back to 2D display mode.\n"
 "\n"
-"Details: %s"
+"ERROR: Unable to read WIND file: %s\n"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:614
-#: ../gui/wxpython/mapdisp/frame.py:291
-msgid "Starting 3D view mode..."
-msgstr "Startē 3D skata režīmu..."
+#: ../gui/wxpython/core/render.py:597
+msgid "Invalid map size %d,%d\n"
+msgstr "Nederīga vētība: %s"
-#: ../gui/wxpython/gui_modules/mapdisp.py:616
-#: ../gui/wxpython/mapdisp/frame.py:293
-msgid "Please wait, loading data..."
-msgstr "Datu ielāde. Lūdzu uzgaidiet...."
+#: ../gui/wxpython/core/render.py:680
+#, python-format
+msgid "Unable to zoom to raster map <%s>."
+msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:673
-#: ../gui/wxpython/mapdisp/frame.py:349
-msgid "Please wait, unloading data..."
+#: ../gui/wxpython/core/render.py:681 ../gui/wxpython/core/render.py:684
+#: ../gui/wxpython/core/render.py:687 ../gui/wxpython/core/gcmd.py:397
+msgid "Details:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:674
-#: ../gui/wxpython/mapdisp/frame.py:350
-msgid "Switching back to 2D view mode..."
+#: ../gui/wxpython/core/render.py:683
+#, python-format
+msgid "Unable to zoom to vector map <%s>."
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:977
-#: ../gui/wxpython/mapdisp/frame.py:654
-msgid "No raster or vector map layer selected for querying."
+#: ../gui/wxpython/core/render.py:686
+msgid "Unable to zoom to 3d raster map <%s>."
+msgstr "Nav iespējams izveidot jaunu karšu kopu: %s"
+#: ../gui/wxpython/core/render.py:689
+msgid ""
+"Unable to get current geographic extent. Force quiting wxGUI. Please "
+"manually run g.region to fix the problem."
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1023
-#: ../gui/wxpython/mapdisp/frame.py:700
+#: ../gui/wxpython/core/render.py:1006
 #, python-format
-msgid "Vector map <%s> opened for editing - skipped."
+msgid "ERROR: Rendering failed. Details: %s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1028
-#: ../gui/wxpython/mapdisp/frame.py:705
-msgid "Nothing to query."
+#: ../gui/wxpython/core/render.py:1063 ../gui/wxpython/core/render.py:1158
+#, python-format
+msgid "Unable to render map layer <%s>."
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1079
-#: ../gui/wxpython/mapdisp/frame.py:756
-msgid "No map layer selected for querying."
+#: ../gui/wxpython/core/render.py:1267 ../gui/wxpython/core/render.py:1306
+#, python-format
+msgid "Unable to render overlay <%s>."
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1116
-#: ../gui/wxpython/mapdisp/frame.py:793
-msgid "Nothing found."
-msgstr ""
+#: ../gui/wxpython/core/render.py:1403
+#, fuzzy
+msgid "Downloading data "
-#: ../gui/wxpython/gui_modules/mapdisp.py:1242
-#: ../gui/wxpython/mapdisp/toolbars.py:44
-msgid "Create bivariate scatterplot of raster maps"
-msgstr ""
+#: ../gui/wxpython/core/render.py:1413
+#, fuzzy
+msgid "Rendering & "
+msgstr "Zīmēt"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1252
-#: ../gui/wxpython/gui_core/toolbars.py:75
-msgid "Create histogram with d.histogram"
+#: ../gui/wxpython/core/render.py:1415
+#, fuzzy
+msgid "Rendering..."
+msgstr "Zīmēt"
+#: ../gui/wxpython/core/workspace.py:1312
+#, python-format
+msgid "Unable to open file <%s> for reading."
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1283
-#: ../gui/wxpython/mapdisp/frame.py:924
+#: ../gui/wxpython/core/workspace.py:1325
 #, python-format
 msgid ""
-"Click and drag with left mouse button to measure.%sDouble click with left "
-"button to clear."
+"Some lines were skipped when reading settings from file <%(file)s>.\n"
+"See 'Command output' window for details.\n"
+"\n"
+"Number of skipped lines: %(line)d"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1289
-#: ../gui/wxpython/mapdisp/frame.py:930
-msgid "Measuring distance"
-msgstr "Attāluma mērīšana"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1292
-#: ../gui/wxpython/mapdisp/frame.py:933
-#, fuzzy
-msgid "Measuring distance:"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1302
-#: ../gui/wxpython/mapdisp/frame.py:943
+#: ../gui/wxpython/core/workspace.py:1543
 #, python-format
-msgid ""
-"Geodesic distance is not yet supported by this tool.\n"
-"Reason: %s"
+msgid " row %d:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1330
-#: ../gui/wxpython/gui_modules/mapdisp.py:1336
-#: ../gui/wxpython/mapdisp/frame.py:971 ../gui/wxpython/mapdisp/frame.py:977
-msgid "segment"
-msgstr "segments"
+#: ../gui/wxpython/core/gcmd.py:128
+msgid "Reason"
+msgstr "Iemesls"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1331
-#: ../gui/wxpython/gui_modules/mapdisp.py:1337
-#: ../gui/wxpython/mapdisp/frame.py:972 ../gui/wxpython/mapdisp/frame.py:978
-msgid "total distance"
-msgstr "kopējais garums"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1332
-#: ../gui/wxpython/mapdisp/frame.py:973
-msgid "bearing"
+#: ../gui/wxpython/core/gcmd.py:394
+msgid "Execution failed:"
 msgstr ""
-msgid "deg"
-msgstr "grādi"
+#: ../gui/wxpython/core/gcmd.py:399 ../gui/wxpython/core/gcmd.py:403
+#: ../gui/wxpython/gis_set.py:430
+msgid "Error: "
+msgstr "Kļūda: "
-#: ../gui/wxpython/gui_modules/mapdisp.py:1476
-#, fuzzy
-msgid "Add north arrow"
-msgstr "Ziemeļu bulta"
+#: ../gui/wxpython/core/gcmd.py:478
+#, python-format
+msgid "Unable to exectute command: '%s'"
+msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1513
-#: ../gui/wxpython/mapdisp/frame.py:1115
-#, fuzzy
-msgid "Scale and North arrow"
+#: ../gui/wxpython/core/toolboxes.py:135
+msgid "Unable to parse user toolboxes XML files. Default files will be loaded."
+msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1519
-#: ../gui/wxpython/mapdisp/frame.py:1121
+#: ../gui/wxpython/core/toolboxes.py:175
 #, fuzzy
-msgid "Show/hide scale and North arrow"
+msgid "Unable to create toolboxes directory."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1520
-#: ../gui/wxpython/mapdisp/frame.py:1122
-#, fuzzy
-msgid "scale object"
+#: ../gui/wxpython/core/toolboxes.py:389
+msgid "Custom toolboxes"
+msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1550
-#: ../gui/wxpython/mapdisp/frame.py:1152
-msgid "Show/hide legend"
+#: ../gui/wxpython/core/toolboxes.py:455
+msgid "Addons"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1551
-#: ../gui/wxpython/mapdisp/frame.py:1153
-#, fuzzy
-msgid "legend object"
-msgstr "Leģenda"
+#: ../gui/wxpython/core/ws.py:48
+msgid ""
+"Unable to load GDAL Python bindings.\n"
+"WMS layers can not be displayed without the bindings.\n"
+msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1573
-#: ../gui/wxpython/mapdisp/toolbars.py:46
-#: ../gui/wxpython/mapdisp/frame.py:1176
-msgid "Add text layer"
-msgstr "Pievienot teksta slāni"
+#: ../gui/wxpython/core/utils.py:329
+#, python-format
+msgid "Vector map <%(map)s>: %(msg)s\n"
+msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1668
-#: ../gui/wxpython/mapdisp/frame.py:1271
-msgid "Zoom to computational region"
-msgstr "Tuvināt līdz aprēķinu reģionam"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1680
-#: ../gui/wxpython/mapdisp/frame.py:1283
-msgid "Set computational region from display extent"
+#: ../gui/wxpython/core/utils.py:556
+#, python-format
+msgid "failed to open '%s'"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1793
-#: ../gui/wxpython/mapdisp/main.py:316
+#: ../gui/wxpython/core/utils.py:851
 #, python-format
-msgid "Starting map display <%s>..."
+msgid "ERROR: Unable to determine GRASS version. Details: %s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1800
-#: ../gui/wxpython/mapdisp/main.py:323
-msgid "GRASS GIS Map Display: "
-msgstr "GRASS GIS kartes ekrāns: "
+#: ../gui/wxpython/core/utils.py:886
+msgid "Unable to open file '%s'\n"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1806
-#: ../gui/wxpython/mapdisp/main.py:329
+#: ../gui/wxpython/core/utils.py:893
 #, python-format
-msgid "Stopping map display <%s>..."
+msgid ""
+"%s: line skipped - unable to parse '%s'\n"
+"Reason: %s\n"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp_vdigit.py:382
-#: ../gui/wxpython/vdigit/mapwindow.py:382
-msgid "Update categories"
+#: ../gui/wxpython/core/utils.py:898
+#, python-format
+msgid "Duplicated key: %s\n"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp_vdigit.py:505
-#: ../gui/wxpython/gui_modules/mapdisp_vdigit.py:861
-#: ../gui/wxpython/vdigit/mapwindow.py:505
-#: ../gui/wxpython/vdigit/mapwindow.py:871
-msgid "No vector map selected for editing."
+#: ../gui/wxpython/core/utils.py:914
+msgid "Unable to create file '%s'\n"
+#: ../gui/wxpython/core/settings.py:485
+msgid "Segment break"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp_vdigit.py:994
-#: ../gui/wxpython/vdigit/mapwindow.py:1007
-msgid "Z bulk-labeling dialog"
+#: ../gui/wxpython/core/settings.py:551
+msgid "Data point"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:55
-#: ../gui/wxpython/modules/mcalc_builder.py:51
-msgid "GRASS GIS Raster Map Calculator"
-msgstr "GRASS GIS rastra kalkulators"
+#: ../gui/wxpython/core/settings.py:625
+msgid "animation"
+msgstr ""
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:58
-#: ../gui/wxpython/modules/mcalc_builder.py:54
-msgid "GRASS GIS 3D Raster Map Calculator"
-msgstr "GRASS GIS 3D rastra kalkulators"
+#: ../gui/wxpython/core/settings.py:839
+msgid "Collapse all except PERMANENT and current"
+msgstr ""
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:69
-#: ../gui/wxpython/modules/mcalc_builder.py:65
-msgid "mapcalc statement"
-msgstr "mapcalc izteiksme"
+#: ../gui/wxpython/core/settings.py:840
+msgid "Collapse all except PERMANENT"
+msgstr ""
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:120
-#: ../gui/wxpython/modules/mcalc_builder.py:116
-msgid "Operators"
-msgstr "Operatori"
+#: ../gui/wxpython/core/settings.py:841
+msgid "Collapse all except current"
+msgstr ""
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:122
-#: ../gui/wxpython/modules/mcalc_builder.py:118
-msgid "Operands"
-msgstr "Operandi"
+#: ../gui/wxpython/core/settings.py:842
+msgid "Collapse all"
+msgstr ""
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:124
-#: ../gui/wxpython/modules/mcalc_builder.py:120
-msgid "Expression"
-msgstr "Izteiksme"
+#: ../gui/wxpython/core/settings.py:843
+msgid "Expand all"
+msgstr ""
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:139
-#: ../gui/wxpython/modules/mcalc_builder.py:135
-msgid "Save expression to file"
-msgstr "Saglabāt izteiksmi failā"
+#: ../gui/wxpython/core/settings.py:847
+msgid "Display selected"
+msgstr ""
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:142
-#: ../gui/wxpython/modules/mcalc_builder.py:138
-msgid "Load expression from file"
-msgstr "Ielādēt izteiksmi no faila"
+#: ../gui/wxpython/core/settings.py:855
+msgid "Classic (labels only)"
+msgstr ""
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:146
-#: ../gui/wxpython/modules/mcalc_builder.py:142
-msgid "exponent"
-msgstr "eksponente"
+#: ../gui/wxpython/core/settings.py:856
+msgid "Combined (labels and module names)"
+msgstr ""
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:148
-#: ../gui/wxpython/modules/mcalc_builder.py:144
-msgid "divide"
-msgstr "dalīt"
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:150
-#: ../gui/wxpython/modules/mcalc_builder.py:146
-msgid "add"
-msgstr "pieskaitīt"
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:152
-#: ../gui/wxpython/modules/mcalc_builder.py:148
-msgid "subtract"
-msgstr "atņemt"
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:154
-#: ../gui/wxpython/modules/mcalc_builder.py:150
-msgid "modulus"
+#: ../gui/wxpython/core/settings.py:857
+msgid "Expert (module names only)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:156
-#: ../gui/wxpython/modules/mcalc_builder.py:152
-msgid "multiply"
-msgstr "reizināt"
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:161
-#: ../gui/wxpython/modules/mcalc_builder.py:157
-msgid "left shift"
+#: ../gui/wxpython/core/settings.py:862
+msgid "Basic top"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:163
-#: ../gui/wxpython/modules/mcalc_builder.py:159
-msgid "right shift"
+#: ../gui/wxpython/core/settings.py:863
+msgid "Basic left"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:165
-#: ../gui/wxpython/modules/mcalc_builder.py:161
-msgid "right shift (unsigned)"
+#: ../gui/wxpython/core/settings.py:864
+msgid "Fancy green"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:167
-#: ../gui/wxpython/modules/mcalc_builder.py:163
-msgid "greater than"
-msgstr "lielāks par"
+#: ../gui/wxpython/core/settings.py:865
+#, fuzzy
+msgid "List left"
+msgstr "Parādīt"
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:169
-#: ../gui/wxpython/modules/mcalc_builder.py:165
-msgid "greater than or equal to"
-msgstr "lielāks vai vienāds"
+#: ../gui/wxpython/core/settings.py:869
+msgid "Zoom and recenter"
+msgstr ""
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:171
-#: ../gui/wxpython/modules/mcalc_builder.py:167
-msgid "less than"
-msgstr "mazāks par"
+#: ../gui/wxpython/core/settings.py:870
+msgid "Zoom to mouse cursor"
+msgstr ""
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:173
-#: ../gui/wxpython/modules/mcalc_builder.py:169
-msgid "less than or equal to"
-msgstr "mazāks vai vienāds"
+#: ../gui/wxpython/core/settings.py:871
+msgid "Nothing"
+msgstr "Nekas"
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:175
-#: ../gui/wxpython/modules/mcalc_builder.py:171
-msgid "equal to"
-msgstr "vienāds"
+#: ../gui/wxpython/core/settings.py:872
+msgid "Scroll forward to zoom in"
+msgstr ""
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:177
-#: ../gui/wxpython/modules/mcalc_builder.py:173
-msgid "not equal to"
-msgstr "nav vienāds"
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:180
-#: ../gui/wxpython/modules/mcalc_builder.py:176
-msgid "one's complement"
+#: ../gui/wxpython/core/settings.py:873
+msgid "Scroll back to zoom in"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:182
-#: ../gui/wxpython/modules/mcalc_builder.py:178
-msgid "NOT"
-msgstr "NE"
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:184
-#: ../gui/wxpython/modules/mcalc_builder.py:180
-msgid "bitwise AND"
+#: ../gui/wxpython/core/settings.py:906 ../gui/wxpython/core/settings.py:918
+msgid "box"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:186
-#: ../gui/wxpython/modules/mcalc_builder.py:182
-msgid "bitwise OR"
+#: ../gui/wxpython/core/settings.py:907
+msgid "sphere"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:188
-#: ../gui/wxpython/modules/mcalc_builder.py:184
-msgid "logical AND"
-msgstr "loģiskais UN"
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:190
-#: ../gui/wxpython/modules/mcalc_builder.py:186
-msgid "logical AND (ignores NULLs)"
+#: ../gui/wxpython/core/settings.py:908
+msgid "cube"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:192
-#: ../gui/wxpython/modules/mcalc_builder.py:188
-msgid "logical OR"
-msgstr "loģiskais VAI"
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:194
-#: ../gui/wxpython/modules/mcalc_builder.py:190
-msgid "logical OR (ignores NULLs)"
+#: ../gui/wxpython/core/settings.py:909
+msgid "diamond"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:196
-#: ../gui/wxpython/modules/mcalc_builder.py:192
-msgid "conditional"
+#: ../gui/wxpython/core/settings.py:910
+msgid "aster"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:209
-#: ../gui/wxpython/modules/mcalc_builder.py:205
-msgid "Name for new 3D raster map to create"
-msgstr "Jaunveidojamās 3D rastra kartes nosaukums"
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:211
-#: ../gui/wxpython/modules/mcalc_builder.py:207
-msgid "Name for new raster map to create"
-msgstr "Jaunveidojamās rastra kartes nosaukums"
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:215
-#: ../gui/wxpython/modules/mcalc_builder.py:211
-msgid "Insert existing 3D raster map"
-msgstr "Ievietot eksistējošu 3D rastra karti"
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:217
-#: ../gui/wxpython/modules/mcalc_builder.py:213
-msgid "Insert existing raster map"
-msgstr "Ievietot eksistējošu rastra karti"
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:221
-#: ../gui/wxpython/modules/mcalc_builder.py:217
-msgid "Insert mapcalc function"
-msgstr "Ievietot mapcalc funkciju"
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:232
-#: ../gui/wxpython/modules/mcalc_builder.py:228
-msgid "Add created raster map into layer tree"
-msgstr "Pievienot izveidoto rastra karti projekta slāņu sarakstam"
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:457
-#: ../gui/wxpython/modules/mcalc_builder.py:453
-msgid "You must enter the name of a new raster map to create."
-msgstr "Ir nepieciešams norādīt jaunveidojamās rastra kartes nosaukumu."
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:464
-#: ../gui/wxpython/modules/mcalc_builder.py:460
-msgid "You must enter an expression to create a new raster map."
+#: ../gui/wxpython/core/settings.py:911
+msgid "gyro"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:506
-#: ../gui/wxpython/modules/mcalc_builder.py:502
-msgid "Choose a file name to save the expression"
+#: ../gui/wxpython/core/settings.py:912
+msgid "histogram"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:507
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:528
-#: ../gui/wxpython/modules/mcalc_builder.py:503
-#: ../gui/wxpython/modules/mcalc_builder.py:524
-msgid "Expression file (*)|*"
+#: ../gui/wxpython/core/settings.py:917
+msgid "cross"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mcalc_builder.py:527
-#: ../gui/wxpython/modules/mcalc_builder.py:523
-msgid "Choose a file name to load the expression"
+#: ../gui/wxpython/core/settings.py:919
+msgid "circle"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp_window.py:1814
-#: ../gui/wxpython/mapdisp/mapwindow.py:1706
-msgid "Zoom to saved region extents"
+#: ../gui/wxpython/core/settings.py:951
+#, python-format
+msgid "Unable to read settings file <%s>\n"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp_window.py:1823
-#: ../gui/wxpython/mapdisp/mapwindow.py:1715
+#: ../gui/wxpython/core/settings.py:975
 #, python-format
-msgid "Region <%s> not found. Operation canceled."
+msgid ""
+"Error: Reading settings from file <%(file)s> failed.\n"
+"\t\tDetails: %(detail)s\n"
+"\t\tLine: '%(line)s'\n"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp_window.py:1844
-#: ../gui/wxpython/mapdisp/mapwindow.py:1736
-msgid "Save display extents to region file"
+#: ../gui/wxpython/core/settings.py:994
+msgid "Unable to create settings directory"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp_window.py:1854
-#: ../gui/wxpython/mapdisp/mapwindow.py:1746
+#: ../gui/wxpython/core/settings.py:1030
 #, python-format
-msgid "Region file <%s> already exists. Do you want to overwrite it?"
+msgid ""
+"Writing settings to file <%(file)s> failed.\n"
+"\n"
+"Details: %(detail)s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gcpmanager.py:628
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2578
-msgid "Select target map to display:"
+#: ../gui/wxpython/core/settings.py:1129
+msgid "Unable to set "
 msgstr ""
-#: ../gui/wxpython/gui_modules/gcpmanager.py:965
+#: ../gui/wxpython/core/settings.py:1165 ../gui/wxpython/core/settings.py:1175
 #, python-format
-msgid "At least %d GCPs required. Operation cancelled."
+msgid "Unable to parse settings '%s'"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1052
-msgid "mapwin not defined for "
+#: ../gui/wxpython/core/gconsole.py:503
+#, python-format
+msgid ""
+"Unable to run command:\n"
+"%(cmd)s\n"
+"\n"
+"Option <%(opt)s>: read from standard input is not supported by wxGUI"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1458
+#: ../gui/wxpython/core/gconsole.py:615
 #, python-format
-msgid "Vector map <%s> already exists. Change extension name and georectify again."
+msgid "%d sec"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1468
-msgid "For all vector maps georectified successfully,"
+#: ../gui/wxpython/core/gconsole.py:618
+#, python-format
+msgid "%(min)d min %(sec)d sec"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1469
-msgid "you will need to copy any attribute tables"
+#: ../gui/wxpython/core/gconsole.py:626
+msgid ""
+"Please note that the data are left in inconsistent state and may be corrupted"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gcpmanager.py:1470
-msgid "and reconnect them to the georectified vectors"
+#: ../gui/wxpython/core/gconsole.py:628
+msgid "Command aborted"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gcpmanager.py:2089
-msgid "Invalid coordinate value. Operation cancelled."
+#: ../gui/wxpython/core/gconsole.py:630
+msgid "Command finished"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:87
-#: ../gui/wxpython/vdigit/preferences.py:53
-msgid "Apply changes for this session"
-msgstr ""
+#: ../gui/wxpython/core/menutree.py:140
+msgid "Unknow tag %s"
+msgstr "Nezināma vērtība"
-#: ../gui/wxpython/gui_modules/vdigit.py:90
-#: ../gui/wxpython/vdigit/preferences.py:56
-msgid "Close dialog and save changes to user settings file"
+#: ../gui/wxpython/mapdisp/gprint.py:150
+msgid ""
+"There was a problem printing.\n"
+"Perhaps your current printer is not set correctly?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:181
-#: ../gui/wxpython/vdigit/preferences.py:148
-msgid "Snapping"
-msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:29
+msgid "Query raster/vector map(s)"
+msgstr "Vaicājums rastra/vektoru kartei"
-#: ../gui/wxpython/gui_modules/vdigit.py:187
-#: ../gui/wxpython/vdigit/preferences.py:154
-msgid "Snapping threshold"
-msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:30
+msgid "Query selected raster/vector map(s)"
+msgstr "Vaicājums izvēlētajai rastra/vektoru kartei"
-#: ../gui/wxpython/gui_modules/vdigit.py:194
-#: ../gui/wxpython/vdigit/preferences.py:161
-msgid "screen pixels"
-msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:32
+#, fuzzy
+msgid "Show/hide scale bar"
+msgstr "Ziemeļu bulta"
-msgid "map units"
+#: ../gui/wxpython/mapdisp/toolbars.py:34
+msgid "Show/hide legend"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:203
-#: ../gui/wxpython/vdigit/preferences.py:170
-msgid "Snap also to vertex"
-msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:36
+#, fuzzy
+msgid "Show/hide north arrow"
-#: ../gui/wxpython/gui_modules/vdigit.py:208
-#: ../gui/wxpython/gui_modules/vdigit.py:635
-#: ../gui/wxpython/gui_modules/vdigit.py:649
-#: ../gui/wxpython/gui_modules/vdigit.py:653
-#: ../gui/wxpython/vdigit/preferences.py:175
-#: ../gui/wxpython/vdigit/preferences.py:603
-#: ../gui/wxpython/vdigit/preferences.py:617
-#: ../gui/wxpython/vdigit/preferences.py:621
-#, python-format
-msgid "Snapping threshold is %(value).1f %(units)s"
-msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:38
+msgid "Analyze map"
+msgstr "Analizēt karti"
-#: ../gui/wxpython/gui_modules/vdigit.py:221
-#: ../gui/wxpython/vdigit/preferences.py:188
-msgid "Select vector features"
-msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:39
+msgid "Measuring, profiling, histogramming, ..."
+msgstr "Mērīšana, profilēšana, histogrammu veidošana..."
-#: ../gui/wxpython/gui_modules/vdigit.py:238
-#: ../gui/wxpython/vdigit/preferences.py:205
-msgid "Select threshold"
-msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:41
+msgid "Measure distance"
+msgstr "Mērīt attālumu"
-#: ../gui/wxpython/gui_modules/vdigit.py:251
-#: ../gui/wxpython/vdigit/preferences.py:218
-msgid "Select only features inside of selection bounding box"
-msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:43
+#, fuzzy
+msgid "Measure area"
-#: ../gui/wxpython/gui_modules/vdigit.py:253
-#: ../gui/wxpython/vdigit/preferences.py:220
-msgid "By default are selected all features overlapping selection bounding box "
-msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:45
+msgid "Profile surface map"
+msgstr "Profilēt rastra karti"
-#: ../gui/wxpython/gui_modules/vdigit.py:256
-#: ../gui/wxpython/vdigit/preferences.py:223
-msgid "Check for duplicates"
+#: ../gui/wxpython/mapdisp/toolbars.py:47
+msgid "Create bivariate scatterplot of raster maps"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:268
-#: ../gui/wxpython/vdigit/preferences.py:235
-msgid "Digitize line features"
-msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:49
+#: ../gui/wxpython/mapdisp/frame.py:1141
+msgid "Add text layer"
+msgstr "Pievienot teksta slāni"
-#: ../gui/wxpython/gui_modules/vdigit.py:271
-#: ../gui/wxpython/vdigit/preferences.py:238
-msgid "Break lines at intersection"
-msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:51
+msgid "Create histogram of raster map"
-#: ../gui/wxpython/gui_modules/vdigit.py:281
-#: ../gui/wxpython/vdigit/preferences.py:248
-msgid "Save changes"
-msgstr "Saglabāt izmaiņas"
+#: ../gui/wxpython/mapdisp/toolbars.py:58
+msgid "Rotate 3D scene"
+msgstr "Rotēt 3D scēnu"
-#: ../gui/wxpython/gui_modules/vdigit.py:284
-#: ../gui/wxpython/vdigit/preferences.py:251
-msgid "Save changes on exit"
+#: ../gui/wxpython/mapdisp/toolbars.py:59
+msgid "Drag with mouse to rotate 3D scene"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:296
-#: ../gui/wxpython/vdigit/preferences.py:263
-msgid "Query tool"
-msgstr "Vaicājumu rīks"
-#: ../gui/wxpython/gui_modules/vdigit.py:303
-#: ../gui/wxpython/vdigit/preferences.py:270
-msgid "Choose query tool"
+#: ../gui/wxpython/mapdisp/toolbars.py:62
+msgid ""
+"Drag with mouse, hold Ctrl down for different mode or Shift to accelerate"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:308
-#: ../gui/wxpython/vdigit/preferences.py:275
-msgid "Select by box"
+#: ../gui/wxpython/mapdisp/toolbars.py:64
+msgid "Click mouse to zoom"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:317
-#: ../gui/wxpython/gui_modules/vdigit.py:449
-#: ../gui/wxpython/vdigit/preferences.py:284
-#: ../gui/wxpython/vdigit/preferences.py:416
-msgid "length"
-msgstr "garums"
-#: ../gui/wxpython/gui_modules/vdigit.py:322
-#: ../gui/wxpython/vdigit/preferences.py:289
-msgid "Select lines"
+#: ../gui/wxpython/mapdisp/toolbars.py:65
+msgid "Click mouse to unzoom"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:324
-#: ../gui/wxpython/gui_modules/vdigit.py:347
-#: ../gui/wxpython/vdigit/preferences.py:291
-#: ../gui/wxpython/vdigit/preferences.py:314
-msgid "shorter than"
+#: ../gui/wxpython/mapdisp/toolbars.py:93
+msgid "3D view mode not available"
 msgstr ""
-msgid "longer than"
+#: ../gui/wxpython/mapdisp/toolbars.py:94
+#: ../gui/wxpython/mapdisp/toolbars.py:108
+#, python-format
+msgid "Reason: %s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:340
-#: ../gui/wxpython/vdigit/preferences.py:307
-msgid "dangle"
+#: ../gui/wxpython/mapdisp/toolbars.py:99 ../gui/wxpython/mapdisp/frame.py:465
+#: ../gui/wxpython/vdigit/toolbars.py:899
+msgid "Digitize"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:345
-#: ../gui/wxpython/vdigit/preferences.py:312
-msgid "Select dangles"
+#: ../gui/wxpython/mapdisp/toolbars.py:107
+msgid "Vector digitizer not available"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:384
-#: ../gui/wxpython/vdigit/preferences.py:351
-msgid "Digitize new feature"
+#: ../gui/wxpython/mapdisp/toolbars.py:109
+msgid ""
+"Note that the wxGUI's vector digitizer is currently disabled (hopefully this "
+"will be fixed soon). Please keep an eye out for updated versions of GRASS. "
+"In the meantime you can use \"v.digit\" from the Develop Vector menu."
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:389
-#: ../gui/wxpython/vdigit/preferences.py:356
-msgid "Add new record into table"
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:135
+msgid "Map window test frame"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:395
-#: ../gui/wxpython/vdigit/preferences.py:362
-msgid "Mode"
-msgstr "Režīms"
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:154
+#, fuzzy
+msgid "Map display test"
+msgstr "Kartes skats"
-#: ../gui/wxpython/gui_modules/vdigit.py:417
-#: ../gui/wxpython/vdigit/preferences.py:384
-msgid "Next to use"
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:163
+msgid "Map window API test frame"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:405
-#: ../gui/wxpython/vdigit/preferences.py:372
-msgid "Category number"
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:193
+msgid "Map window distance measurement test frame"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:415
-#: ../gui/wxpython/vdigit/preferences.py:382
-msgid "Category mode"
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:224
+msgid "Map window profile tool test frame"
 msgstr ""
-msgid "Manual entry"
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:271
+msgid "Map window rlisetup test frame"
 msgstr ""
-msgid "No category"
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:332
+#, python-format
+msgid "Unknown value %s of test parameter."
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:430
-#: ../gui/wxpython/vdigit/preferences.py:397
-msgid "Delete existing feature(s)"
-msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:395
+msgid "Render"
+msgstr "Zīmēt"
-#: ../gui/wxpython/gui_modules/vdigit.py:435
-#: ../gui/wxpython/vdigit/preferences.py:402
-msgid "Delete record from table"
+#: ../gui/wxpython/mapdisp/statusbar.py:399
+msgid "Enable/disable auto-rendering"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:445
-#: ../gui/wxpython/vdigit/preferences.py:412
-msgid "Geometry attributes"
+#: ../gui/wxpython/mapdisp/statusbar.py:429
+msgid "Show comp. extent"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:451
-#: ../gui/wxpython/vdigit/preferences.py:418
-msgid "perimeter"
+#: ../gui/wxpython/mapdisp/statusbar.py:433
+msgid "Show computational extent"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:517
-#: ../gui/wxpython/vdigit/preferences.py:484
+#: ../gui/wxpython/mapdisp/statusbar.py:436
 msgid ""
-"Note: These settings are stored in the workspace not in the vector digitizer "
-"preferences."
+"Show/hide computational region extent (set with g.region). Display region "
+"drawn as a blue box inside the computational region, computational region "
+"inside a display region as a red box)."
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:546
-#: ../gui/wxpython/vdigit/preferences.py:514
-msgid "Highlight"
-msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:484
+msgid "Display mode"
+msgstr "Ekrāna režīms"
-#: ../gui/wxpython/gui_modules/vdigit.py:547
-#: ../gui/wxpython/vdigit/preferences.py:515
-msgid "Highlight (duplicates)"
+#: ../gui/wxpython/mapdisp/statusbar.py:491
+msgid ""
+"Align region extent based on display size from center point. Default value "
+"for new map displays can be set up in 'User GUI settings' dialog."
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:550
-#: ../gui/wxpython/vdigit/preferences.py:518
-msgid "Boundary (no area)"
+#: ../gui/wxpython/mapdisp/statusbar.py:524
+msgid "Display resolution"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:551
-#: ../gui/wxpython/vdigit/preferences.py:519
-msgid "Boundary (one area)"
+#: ../gui/wxpython/mapdisp/statusbar.py:530
+msgid ""
+"Constrain display resolution to computational region settings. Default value "
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:552
-#: ../gui/wxpython/vdigit/preferences.py:520
-msgid "Boundary (two areas)"
+#: ../gui/wxpython/mapdisp/statusbar.py:567
+msgid "Map scale"
+msgstr "Kartes mērogs"
+#: ../gui/wxpython/mapdisp/statusbar.py:581
+msgid ""
+"As everyone's monitors and resolutions are set differently these values are "
+"not true map scales, but should get you into the right neighborhood."
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:553
-#: ../gui/wxpython/vdigit/preferences.py:521
-msgid "Centroid (in area)"
+#: ../gui/wxpython/mapdisp/statusbar.py:634
+msgid "Go to"
+msgstr "Iet uz"
+#: ../gui/wxpython/mapdisp/statusbar.py:655
+#: ../gui/wxpython/mapdisp/statusbar.py:719
+#: ../gui/wxpython/mapdisp/statusbar.py:925
+#: ../gui/wxpython/mapdisp/statusbar.py:991
+msgid "Projection not defined (check the settings)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:554
-#: ../gui/wxpython/vdigit/preferences.py:522
-msgid "Centroid (outside area)"
+#: ../gui/wxpython/mapdisp/statusbar.py:733
+#: ../gui/wxpython/mapdisp/statusbar.py:938
+#: ../gui/wxpython/mapdisp/statusbar.py:1021
+msgid "Error in projection (check the settings)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:555
-#: ../gui/wxpython/vdigit/preferences.py:523
-msgid "Centroid (duplicate in area)"
+#: ../gui/wxpython/mapdisp/statusbar.py:767
+msgid "Use defined projection"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:556
-#: ../gui/wxpython/vdigit/preferences.py:524
-msgid "Node (one line)"
+#: ../gui/wxpython/mapdisp/statusbar.py:779
+msgid ""
+"Reproject coordinates displayed in the statusbar. Projection can be defined "
+"in GUI preferences dialog (tab 'Projection')"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:557
-#: ../gui/wxpython/vdigit/preferences.py:525
-msgid "Node (two lines)"
+#: ../gui/wxpython/mapdisp/statusbar.py:804
+msgid "MASK"
+msgstr "MASKA"
+#: ../gui/wxpython/mapdisp/statusbar.py:848
+msgid "Display geometry"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:558
-#: ../gui/wxpython/vdigit/preferences.py:526
-msgid "Vertex"
-msgstr "Virsotne"
+#: ../gui/wxpython/mapdisp/statusbar.py:870
+msgid "Coordinates"
+msgstr "Koordinātes"
-#: ../gui/wxpython/gui_modules/vdigit.py:559
-#: ../gui/wxpython/vdigit/preferences.py:527
-msgid "Area (closed boundary + centroid)"
-msgstr "Poligons (noslēgta robeža + centroīds)"
+#: ../gui/wxpython/mapdisp/statusbar.py:950
+msgid "Extent"
+msgstr "Apjoms"
-#: ../gui/wxpython/gui_modules/vdigit.py:560
-#: ../gui/wxpython/vdigit/preferences.py:528
-msgid "Direction"
-msgstr "Virziens"
+#: ../gui/wxpython/mapdisp/statusbar.py:1045
+#, fuzzy
+msgid "Computational region"
+msgstr "Tuvināt līdz aprēķinu reģionam"
-#: ../gui/wxpython/gui_modules/vdigit.py:628
-#: ../gui/wxpython/vdigit/preferences.py:596
-msgid "Snapping disabled"
-msgstr ""
+#: ../gui/wxpython/mapdisp/main.py:129
+msgid "Unsupported command %s."
+msgstr "Darbināt izvēlēto komandu"
-#: ../gui/wxpython/gui_modules/vdigit.py:630
-#: ../gui/wxpython/vdigit/preferences.py:598
+#: ../gui/wxpython/mapdisp/main.py:191
 #, python-format
-msgid "Snapping threshold is %(value).1f %(units)s (based on comp. resolution)"
+msgid "Unable to read cmdfile '%(cmd)s'. Details: %(det)s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:686
-#: ../gui/wxpython/vdigit/preferences.py:654
+#: ../gui/wxpython/mapdisp/main.py:444
 #, python-format
-msgid "Vector digitizer settings saved to file <%s>."
+msgid "Starting map display <%s>..."
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:861
-#: ../gui/wxpython/vdigit/dialogs.py:74
-msgid "List of categories - right-click to delete"
-msgstr ""
+#: ../gui/wxpython/mapdisp/main.py:451
+msgid "GRASS GIS Map Display: "
+msgstr "GRASS GIS kartes ekrāns: "
-#: ../gui/wxpython/gui_modules/vdigit.py:892
-#: ../gui/wxpython/vdigit/dialogs.py:105
-msgid "Add new category"
-msgstr "Pievienot jaunu kategoriju"
-#: ../gui/wxpython/gui_modules/vdigit.py:931
-#: ../gui/wxpython/vdigit/dialogs.py:144
-msgid "Ignore changes and close dialog"
-msgstr "Ignorēt izmaiņas un aizvērt dialogu"
-#: ../gui/wxpython/gui_modules/vdigit.py:933
-#: ../gui/wxpython/vdigit/dialogs.py:146
-msgid "Apply changes and close dialog"
-msgstr "Pielietot izmaiņas un aizvērt dialogu"
-#: ../gui/wxpython/gui_modules/vdigit.py:1023
-#: ../gui/wxpython/gui_modules/vdigit.py:1242
+#: ../gui/wxpython/mapdisp/main.py:457
 #, python-format
-msgid ""
-"Unable to add new layer/category <%(layer)s/%(category)s>.\n"
-"Layer and category number must be integer.\n"
-"Layer number must be greater then zero."
+msgid "Stopping map display <%s>..."
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1219
-#: ../gui/wxpython/vdigit/dialogs.py:432
-msgid "Unable to update vector map."
+#: ../gui/wxpython/mapdisp/frame.py:75
+msgid "GRASS GIS - Map display"
+msgstr "GRASS GIS - kartes skats"
+#: ../gui/wxpython/mapdisp/frame.py:293
+msgid "Vector Digitizer Toolbar"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1379
-#: ../gui/wxpython/vdigit/dialogs.py:592
+#: ../gui/wxpython/mapdisp/frame.py:314
 #, python-format
-msgid "%d lines selected for z bulk-labeling"
+msgid ""
+"Unable to switch to 3D display mode.\n"
+"The Nviz python extension was not found or loaded properly.\n"
+"Switching back to 2D display mode.\n"
+"\n"
+"Details: %s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1382
-#: ../gui/wxpython/vdigit/dialogs.py:595
-msgid "Set value"
-msgstr "Iestatīt vērtību"
+#: ../gui/wxpython/mapdisp/frame.py:340
+msgid "Starting 3D view mode..."
+msgstr "Startē 3D skata režīmu..."
-#: ../gui/wxpython/gui_modules/vdigit.py:1389
-#: ../gui/wxpython/vdigit/dialogs.py:602
-msgid "Starting value"
-msgstr "Sākotnējā vērtība"
+#: ../gui/wxpython/mapdisp/frame.py:341
+msgid "Please wait, loading data..."
+msgstr "Datu ielāde. Lūdzu uzgaidiet...."
-#: ../gui/wxpython/gui_modules/vdigit.py:1398
-#: ../gui/wxpython/vdigit/dialogs.py:611
-msgid "Step"
-msgstr "Solis"
-#: ../gui/wxpython/gui_modules/vdigit.py:1428
-#: ../gui/wxpython/vdigit/dialogs.py:641
-msgid "List of duplicates"
+#: ../gui/wxpython/mapdisp/frame.py:413
+msgid "Please wait, unloading data..."
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:1524
-#: ../gui/wxpython/vdigit/dialogs.py:737
-msgid "Feature id"
-msgstr "Objekta ID"
-#: ../gui/wxpython/gui_modules/vdigit.py:1525
-#: ../gui/wxpython/vdigit/dialogs.py:738
-msgid "Layer (Categories)"
+#: ../gui/wxpython/mapdisp/frame.py:415
+msgid "Switching back to 2D view mode..."
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxvdriver.py:844
-#: ../gui/wxpython/vdigit/wxdisplay.py:887
+#: ../gui/wxpython/mapdisp/frame.py:726
 #, python-format
-msgid ""
-"Topology for vector map <%s> is not available. Topology is required by "
-"digitizer. Do you want to rebuild topology (takes some time) and open the "
-"vector map for editing?"
+msgid "Vector map <%s> opened for editing - skipped."
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxvdriver.py:848
-#: ../gui/wxpython/vdigit/wxdisplay.py:891
-msgid "Topology missing"
+#: ../gui/wxpython/mapdisp/frame.py:732
+msgid "No raster or vector map layer selected for querying."
 msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:220
-msgid "Create a generic Cartesian coordinate system (XY)"
+#: ../gui/wxpython/mapdisp/frame.py:1241
+msgid "Set computational region from display extent"
 msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:995
-msgid "Earth based"
-msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:1242
+#, fuzzy
+msgid "Set computational region from named region"
-#: ../gui/wxpython/location_wizard/wizard.py:998
-msgid "Planetary bodies"
-msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:1245
+#, fuzzy
+msgid "Save computational region to named region"
-#: ../gui/wxpython/gui_core/gselect.py:1151
-msgid "PostGIS (PG)"
-msgstr ""
+#: ../gui/wxpython/animation/provider.py:362
+#, fuzzy
+msgid "Rendering map layers"
+msgstr "Pārzīmēt visus kartes slāņus"
-#: ../gui/wxpython/gui_core/gselect.py:1164
-msgid "Save current settings"
-msgstr "Saglabāt pašreizējos iestatījumus"
+#: ../gui/wxpython/animation/provider.py:458
+#, fuzzy
+msgid "Overlaying map layers"
+msgstr "Pievienot vektoru karti"
-#: ../gui/wxpython/gui_core/gselect.py:1167
-msgid "Delete currently selected settings"
+#: ../gui/wxpython/animation/provider.py:675
+msgid "Directory {} not removed."
 msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1413
-msgid "No data source defined, settings is not saved."
+#: ../gui/wxpython/animation/temporal_manager.py:107
+msgid ""
+"It is not allowed to display data with different temporal types (absolute "
+"and relative)."
 msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1420
+#: ../gui/wxpython/animation/temporal_manager.py:121
 #, python-format
-msgid "Settings <%s> already exists. Do you want to overwrite the settings?"
+msgid "It is not allowed to display data with different units (%s)."
 msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1442
-msgid "No settings is defined. Operation canceled."
+#: ../gui/wxpython/animation/temporal_manager.py:132
+msgid ""
+"You are going to display data with different temporal types of maps "
+"(interval and point). It is recommended to use data of one temporal type to "
+"avoid confusion."
 msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1616
+#: ../gui/wxpython/animation/temporal_manager.py:229
+#: ../gui/wxpython/animation/utils.py:69 ../gui/wxpython/animation/utils.py:75
+#: ../gui/wxpython/timeline/frame.py:402
+#, fuzzy, python-format
+msgid "Space time dataset <%s> not found."
+msgstr "Fails <%s> nav atrasts."
+#: ../gui/wxpython/animation/temporal_manager.py:331
 #, python-format
-msgid "Database <%s> not accessible."
+msgid "Topology of Space time dataset %s is invalid."
 msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:2145
-msgid "Try to set up GRASS_ADDON_PATH or GRASS_ADDON_BASE variable."
+#: ../gui/wxpython/animation/toolbars.py:28
+#, fuzzy
+msgid "Change animation speed"
+msgstr "Mainīt karšu kopu"
+#: ../gui/wxpython/animation/toolbars.py:29
+msgid "Play forward"
 msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:283
-msgid "&Protocol"
-msgstr "&Protokols"
+#: ../gui/wxpython/animation/toolbars.py:30
+msgid "Play back"
+msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:285
-msgid ""
-"Toggle to save list of executed commands into file; content saved when "
-"switching off."
+#: ../gui/wxpython/animation/toolbars.py:33
+msgid "Repeat"
 msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:507
-#: ../gui/wxpython/gui_core/goutput.py:802
-#, python-format
-msgid ""
-"Unable to write file '%(filePath)s'.\n"
-"\n"
-"Details: %(error)s"
+#: ../gui/wxpython/animation/toolbars.py:35
+msgid "Play back and forward"
 msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:676
-#: ../gui/wxpython/gui_core/goutput.py:822
-#, python-format
-msgid "%(txt)s (*.txt)|*.txt|%(files)s (*)|*"
+#: ../gui/wxpython/animation/toolbars.py:36
+#: ../gui/wxpython/animation/toolbars.py:37
+#: ../gui/wxpython/animation/dialogs.py:276
+#, fuzzy
+msgid "Add new animation"
+msgstr "Animācija"
+#: ../gui/wxpython/animation/toolbars.py:38
+#: ../gui/wxpython/animation/toolbars.py:39
+msgid "Add, edit or remove animation"
 msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:677
-#: ../gui/wxpython/gui_core/goutput.py:823
-msgid "Text files"
-msgstr "Teksta faili"
+#: ../gui/wxpython/animation/toolbars.py:40
+#: ../gui/wxpython/animation/toolbars.py:41
+#: ../gui/wxpython/animation/dialogs.py:744
+#, fuzzy
+msgid "Export animation"
+msgstr "Animācija"
-msgid "Files"
-msgstr "Faili"
+#: ../gui/wxpython/animation/toolbars.py:49
+msgid "Add space-time dataset or series of map layers"
+msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:689
-#, python-format
-msgid ""
-"Unable to write file '%(path)s'.\n"
-"\n"
+#: ../gui/wxpython/animation/toolbars.py:50
+msgid "Add space-time dataset or series of map layers for animation"
 msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:692
+#: ../gui/wxpython/animation/nviztask.py:54
 #, python-format
-msgid "Commands output saved into '%s'"
+msgid "No 3d view information in workspace file <%s>."
 msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:807
-#, python-format
-msgid "Commands protocol saved into '%s'"
+#: ../gui/wxpython/animation/nviztask.py:240
+msgid "Please add only one layer in the list."
 msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:865
-#, python-format
-msgid "%(min)d min %(sec)d sec"
+#: ../gui/wxpython/animation/nviztask.py:246
+msgid "No map series nor space-time dataset is added."
 msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:31
-msgid "Display map"
-msgstr "Rādīt karti"
+#: ../gui/wxpython/animation/g.gui.animation.py:91
+msgid "Options 'rast', 'vect', 'strds' and 'stvds' are mutually exclusive."
+msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:32
-msgid "Re-render modified map layers only"
+#: ../gui/wxpython/animation/dialogs.py:55
+msgid "Adjust speed of animation"
 msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:34
-msgid "Render map"
-msgstr "Zīmēt karti"
+#: ../gui/wxpython/animation/dialogs.py:100
+#, fuzzy
+msgid "Simple mode"
+msgstr "Vienkārši"
-#: ../gui/wxpython/gui_core/toolbars.py:35
-msgid "Force re-rendering all map layers"
-msgstr "Pārzīmēt visus kartes slāņus"
+#: ../gui/wxpython/animation/dialogs.py:104
+#, fuzzy
+msgid "Frame duration:"
+msgstr "Pārsaukt novietojumu"
-#: ../gui/wxpython/gui_core/toolbars.py:37
-msgid "Erase display"
-msgstr "Dzēst ekrānu"
+#: ../gui/wxpython/animation/dialogs.py:105
+#: ../gui/wxpython/animation/dialogs.py:128
+msgid "ms"
+msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:38
-msgid "Erase display canvas with given background color"
+#: ../gui/wxpython/animation/dialogs.py:122
+msgid "Temporal mode"
 msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:40
-msgid "Pointer"
-msgstr "Kursors"
+#: ../gui/wxpython/animation/dialogs.py:126
+msgid "Time unit:"
+msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:42
-msgid "Zoom in"
-msgstr "Tuvināt"
+#: ../gui/wxpython/animation/dialogs.py:127
+msgid "Duration of time unit:"
+msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:43
-msgid "Drag or click mouse to zoom"
+#: ../gui/wxpython/animation/dialogs.py:179
+msgid "year"
 msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:45
-msgid "Zoom out"
-msgstr "Tālināt"
+msgid "month"
+msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:46
-msgid "Drag or click mouse to unzoom"
+msgid "day"
 msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:48
-msgid "Return to previous zoom"
-msgstr "Atgriezties uz iepriekšējo skatu"
+msgid "hour"
+msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:50
-msgid "Various zoom options"
-msgstr "Dažādas tuvināšanas opcijas"
+msgid "minute"
+msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:51
-msgid "Zoom to computational, default, saved region, ..."
+msgid "second"
 msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:53
-msgid "Zoom to selected map layer(s)"
+#: ../gui/wxpython/animation/dialogs.py:241
+msgid "Animation speed is too high."
 msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:55
-msgid "Pan"
-msgstr "Pārcentrēt"
+#: ../gui/wxpython/animation/dialogs.py:278
+#, fuzzy
+msgid "Edit animation"
+msgstr "Animācija"
-#: ../gui/wxpython/gui_core/toolbars.py:56
-msgid "Drag with mouse to pan"
+#: ../gui/wxpython/animation/dialogs.py:290
+msgid "Advanced"
+msgstr "Paplašināti"
+#: ../gui/wxpython/animation/dialogs.py:314
+msgid "top left"
 msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:58
-msgid "Save display to graphic file"
-msgstr "Saglabāt skatu kā bildi"
+#, fuzzy
+msgid "top right"
+msgstr "Autortiesības"
-#: ../gui/wxpython/gui_core/toolbars.py:62
-msgid "Select font"
-msgstr "Izvēlēties fontu"
+#: ../gui/wxpython/animation/dialogs.py:315
+msgid "bottom left"
+msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:64
-msgid "Show manual"
-msgstr "Rādīt pamācību"
+msgid "bottom right"
+msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:68
-msgid "Add raster map layer"
-msgstr "Pievienot rastra karti"
+#: ../gui/wxpython/animation/dialogs.py:329
+msgid "Select 2D or 3D view"
+msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:70
-msgid "Add vector map layer"
-msgstr "Pievienot vektoru karti"
+#: ../gui/wxpython/animation/dialogs.py:336
+#, fuzzy
+msgid "Window position:"
+msgstr "Novietojums un izmērs"
-#: ../gui/wxpython/gui_core/toolbars.py:72
-msgid "Add map elements"
-msgstr "Pievienot kartes elementus"
-#: ../gui/wxpython/gui_core/toolbars.py:73
-msgid "Overlay elements like scale and legend onto map"
+#: ../gui/wxpython/animation/dialogs.py:339
+msgid "View mode:"
 msgstr ""
-#: ../gui/wxpython/gui_core/mapwindow.py:104
-#, python-format
+#: ../gui/wxpython/animation/dialogs.py:345
 msgid ""
-"Error occured during calling of handler: %s \n"
-"Handler was unregistered."
+"For 3D animation, please select only one space-time dataset\n"
+"or one series of map layers."
 msgstr ""
-#: ../gui/wxpython/gui_core/mapwindow.py:173
-#, python-format
-msgid ""
-"Error occured during unregistration of handler: %s \n"
-"                                        Handler was unregistered."
+#: ../gui/wxpython/animation/dialogs.py:390
+#, fuzzy
+msgid "3D view parameters"
+msgstr "Mainīt iestatījumus"
+#: ../gui/wxpython/animation/dialogs.py:397
+#, fuzzy
+msgid "Workspace file:"
+msgstr "Darbtelpa"
+#: ../gui/wxpython/animation/dialogs.py:398
+msgid "Choose workspace file to import 3D view parameters"
 msgstr ""
-#: ../gui/wxpython/gui_core/mapwindow.py:198
-#, python-format
-msgid "Handler: %s was not registered"
+#: ../gui/wxpython/animation/dialogs.py:405
+msgid "Parameter for animation:"
 msgstr ""
-#: ../gui/wxpython/gui_core/mapwindow.py:202
-#, python-format
-msgid ""
-"                                        Handler was unregistered"
+#: ../gui/wxpython/animation/dialogs.py:427
+msgid "Animate region change (2D view only)"
 msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:437
-msgid "Language settings"
-msgstr "Valodas iestatījumi"
+#: ../gui/wxpython/animation/dialogs.py:431
+#, fuzzy
+msgid "Start region:"
+msgstr "Saglabāt reģionu:"
-#: ../gui/wxpython/gui_core/preferences.py:447
-msgid "Choose language (requires to save and GRASS restart):"
+#: ../gui/wxpython/animation/dialogs.py:438
+#, fuzzy
+msgid "End region:"
+msgstr "Ielādēt reģionu:"
+#: ../gui/wxpython/animation/dialogs.py:442
+#, fuzzy
+msgid "Zoom value:"
+msgstr "Tālināt"
+#: ../gui/wxpython/animation/dialogs.py:443
+msgid "N-S/E-W distances in map units used to gradually reduce region."
 msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:502
-msgid "Menu style (requires to save and GUI restart):"
+#: ../gui/wxpython/animation/dialogs.py:450
+msgid "N-S:"
 msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:736
-msgid "Mouse wheel action:"
+#: ../gui/wxpython/animation/dialogs.py:453
+msgid "E-W:"
 msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:751
-msgid "Mouse scrolling direction:"
+#: ../gui/wxpython/animation/dialogs.py:545
+msgid "Only one series or space-time dataset is accepted for 3D mode."
 msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:869
-msgid "Default raster settings"
+#: ../gui/wxpython/animation/dialogs.py:553
+msgid "No map series or space-time dataset added."
 msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:917
-msgid "Default vector settings"
+#: ../gui/wxpython/animation/dialogs.py:581
+msgid "Region information is not complete"
 msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:944
-msgid "Feature color:"
-msgstr "Objekta krāsa:"
+#: ../gui/wxpython/animation/dialogs.py:610
+msgid "Add, edit or remove animations"
+msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:966
-msgid "Area fill color:"
-msgstr "Poligona aizpildījuma krāsa:"
+#: ../gui/wxpython/animation/dialogs.py:618
+#, fuzzy
+msgid "List of animations"
+msgstr "Karšu saraksts:"
-#: ../gui/wxpython/gui_core/preferences.py:1009
-msgid "Symbol:"
-msgstr "Simbols:"
+#: ../gui/wxpython/animation/dialogs.py:629
+msgid "Edit"
+msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1017
-msgid "Define also sub-group (same name as group)"
+#: ../gui/wxpython/animation/dialogs.py:682
+#, python-format
+msgid "Maximum number of animations is %d."
 msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1355
-msgid "Put here regular expression.'.*' means anything, '^' beginning and '$' end."
+#: ../gui/wxpython/animation/dialogs.py:729
+#: ../gui/wxpython/animation/controller.py:240
+msgid ""
+"More animations are using one window. Please select different window for "
+"each animation."
 msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1829
-msgid "No layers selected. Operation canceled."
+#: ../gui/wxpython/animation/dialogs.py:813
+msgid "Add time stamp"
 msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2483
-msgid "Symbols"
-msgstr "Simboli"
+#: ../gui/wxpython/animation/dialogs.py:833
+msgid "Add time stamp, image or text decoration by one of the buttons above."
+msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2510
-msgid "Symbol directory:"
+#: ../gui/wxpython/animation/dialogs.py:835
+msgid "Add image or text decoration by one of the buttons above."
 msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2518
-msgid "Symbol name:"
+#: ../gui/wxpython/animation/dialogs.py:844
+#, fuzzy
+msgid "Font settings:"
+msgstr "Teksta iestatījumi"
+#: ../gui/wxpython/animation/dialogs.py:846
+msgid "Sample text"
 msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:454
-msgid "Python:"
-msgstr "Python:"
+#: ../gui/wxpython/animation/dialogs.py:858
+#, fuzzy
+msgid "Image file:"
+msgstr "Attēla izmērs"
-#: ../gui/wxpython/gui_core/ghelp.py:465
-msgid "wxPython:"
-msgstr "wxPython:"
+#: ../gui/wxpython/animation/dialogs.py:859
+#, fuzzy
+msgid "Choose image file"
+msgstr "Aizvērt modeļa failu"
-#: ../gui/wxpython/gui_core/ghelp.py:480
-msgid "Language:"
-msgstr "Valoda:"
+#: ../gui/wxpython/animation/dialogs.py:867
+#, fuzzy
+msgid "Text:"
+msgstr "Teksts"
-#: ../gui/wxpython/gui_core/ghelp.py:503
-msgid "Translation status"
-msgstr "Tulkošanas statuss"
+#: ../gui/wxpython/animation/dialogs.py:880
+msgid "Placement as percentage of screen coordinates (X: 0, Y: 0 is top left):"
+msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:724
-msgid "Nation"
-msgstr "Valoda"
+#: ../gui/wxpython/animation/dialogs.py:903
+msgid "image sequence"
+msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:759
-#, python-format
-msgid "   %d translated"
-msgstr "   %d iztulkots"
+msgid "animated GIF"
+msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:763 ../gui/wxpython/gui_core/ghelp.py:789
-#, python-format
-msgid "   %d fuzzy"
-msgstr "   %d neskaidrs"
+#, fuzzy
+msgid "SWF"
+msgstr "WFS"
-#: ../gui/wxpython/gui_core/ghelp.py:767 ../gui/wxpython/gui_core/ghelp.py:798
-#, python-format
-msgid "   %d untranslated"
-msgstr "   %d netulkots"
+msgid "AVI"
+msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:780
-#, python-format
-msgid "%d translated"
-msgstr "%d tulkots"
+#: ../gui/wxpython/animation/dialogs.py:907
+#, fuzzy
+msgid "Export to:"
+msgstr "Eksportēt"
-#: ../gui/wxpython/gui_core/ghelp.py:851
-#, python-format
-msgid "File <%s> not found"
-msgstr "Fails <%s> nav atrasts"
+#: ../gui/wxpython/animation/dialogs.py:923
+#, fuzzy
+msgid "animation_"
+msgstr "Animācija"
-#: ../gui/wxpython/dbmgr/dialogs.py:222
-#, python-format
-msgid "Column <%(col)s>: Value '%(value)s' needs to be entered as %(type)s."
+#: ../gui/wxpython/animation/dialogs.py:930
+msgid "Choose directory for export"
 msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:881 ../gui/wxpython/dbmgr/manager.py:932
-msgid "Column"
-msgstr "Kolona"
+#: ../gui/wxpython/animation/dialogs.py:952
+#, fuzzy
+msgid "GIF file:"
+msgstr "EPSG fails:"
-#: ../gui/wxpython/dbmgr/manager.py:908
-msgid "Length"
-msgstr "Garums"
+#: ../gui/wxpython/animation/dialogs.py:953
+#: ../gui/wxpython/animation/dialogs.py:970
+#: ../gui/wxpython/animation/dialogs.py:993
+msgid "Choose file to save animation"
+msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:1181
-#, python-format
+#: ../gui/wxpython/animation/dialogs.py:969
+#, fuzzy
+msgid "SWF file:"
+msgstr "WKT fails:"
+#: ../gui/wxpython/animation/dialogs.py:986
 msgid ""
-"Selected data records (%d) will be permanently deleted from table. Do you "
-"want to delete them?"
+"Program 'ffmpeg' was not found.\n"
+"Please install it first and make sure\n"
+"it's in the PATH variable."
 msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:1227
-#, python-format
-msgid ""
-"All data records (%d) will be permanently deleted from table. Do you want to "
-"delete them?"
+#: ../gui/wxpython/animation/dialogs.py:992
+#, fuzzy
+msgid "AVI file:"
+#: ../gui/wxpython/animation/dialogs.py:996
+msgid "Video codec:"
 msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:1422
-#, python-format
-msgid ""
-"Unable to insert new record.\n"
-"%s"
+#: ../gui/wxpython/animation/dialogs.py:998
+msgid "Additional options:"
 msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:1533
-#, python-format
+#: ../gui/wxpython/animation/dialogs.py:1000
 msgid ""
-"Unable to update existing record.\n"
-"%s"
+"Consider adding '-sameq' or '-qscale 1' if not satisfied with video quality. "
+"Options depend on ffmpeg version."
 msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:31
-msgid "Set opacity level"
+#: ../gui/wxpython/animation/dialogs.py:1022
+#, python-format
+msgid "Current frame rate: %.2f fps"
 msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:33 ../gui/wxpython/iclass/dialogs.py:125
-msgid "Class manager"
-msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1140
+msgid "File %s not found."
-#: ../gui/wxpython/iclass/toolbars.py:35 ../gui/wxpython/iclass/dialogs.py:37
-msgid "Select imagery group"
+#: ../gui/wxpython/animation/dialogs.py:1142
+msgid "Decoration image file is missing."
 msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:37
-msgid "Run analysis"
-msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1149
+msgid "Directory %s not found."
-#: ../gui/wxpython/iclass/toolbars.py:39 ../gui/wxpython/iclass/dialogs.py:394
-msgid "Save signature file"
+#: ../gui/wxpython/animation/dialogs.py:1151
+#, fuzzy
+msgid "Export directory is missing."
+msgstr "Eksportēt vektrodatus"
+#: ../gui/wxpython/animation/dialogs.py:1155
+#: ../gui/wxpython/animation/dialogs.py:1159
+msgid "Export file is missing."
 msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:43 ../gui/wxpython/iclass/dialogs.py:502
-msgid "Export training areas"
+#: ../gui/wxpython/animation/dialogs.py:1196
+msgid "Time stamp"
 msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:45
+#: ../gui/wxpython/animation/dialogs.py:1267
 #, fuzzy
-msgid "Import training areas"
-msgstr "Rastra datu importēšana"
+msgid "Add space-time dataset layer"
-#: ../gui/wxpython/iclass/toolbars.py:61
-msgid "Training"
-msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1285
+#, fuzzy
+msgid "Multiple raster maps"
+msgstr "3D rastra kartes"
-#: ../gui/wxpython/iclass/toolbars.py:68
-msgid "/ Zoom to map"
-msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1286
+#, fuzzy
+msgid "Multiple vector maps"
+msgstr "Jauna vektoru karte"
-#: ../gui/wxpython/iclass/toolbars.py:218
-#: ../gui/wxpython/iclass/toolbars.py:223
-msgid "std dev"
-msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1287
+#, fuzzy
+msgid "Multiple 3D raster maps"
-#: ../gui/wxpython/iclass/toolbars.py:264
-msgid "Add raster map"
-msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1288
+#, fuzzy
+msgid "Space time raster dataset"
+msgstr "Rastra datu importēšana"
-#: ../gui/wxpython/iclass/dialogs.py:45
-msgid "Name of imagery group:"
-msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1289
+#, fuzzy
+msgid "Space time vector dataset"
+msgstr "Vektordatu importēšana"
-#: ../gui/wxpython/iclass/dialogs.py:140
-msgid "Classes"
-msgstr "Klases"
+#: ../gui/wxpython/animation/dialogs.py:1290
+#, fuzzy
+msgid "Space time 3D raster dataset"
+msgstr "Importēt 3D rastra datus"
-#: ../gui/wxpython/iclass/dialogs.py:225
-msgid "Class name"
-msgstr "Klašu nosaukumi"
+#: ../gui/wxpython/animation/dialogs.py:1329
+#, fuzzy
+msgid "Input data type:"
+msgstr "Ievades dati"
-#: ../gui/wxpython/iclass/dialogs.py:364
-msgid "Zoom to training areas of selected class"
-msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1404
+#, fuzzy
+msgid "Select raster/vector maps."
-#: ../gui/wxpython/iclass/dialogs.py:451
-msgid "Enter name of signature file:"
+#: ../gui/wxpython/animation/dialogs.py:1431
+msgid "Please select maps or dataset first."
 msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:460
-msgid "Signature file path:"
+#: ../gui/wxpython/animation/dialogs.py:1459
+#, fuzzy
+msgid "Animation Tool settings"
+msgstr "Asu iestatījumi"
+#: ../gui/wxpython/animation/dialogs.py:1517
+#: ../gui/wxpython/timeline/frame.py:273
+msgid "Time"
 msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:545
-msgid "Enter name of new vector map:"
+#: ../gui/wxpython/animation/dialogs.py:1525
+msgid "Absolute time format:"
 msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:553
-msgid "Export attribute table"
-msgstr "Eksportēt atribūtu tabulu"
-#: ../gui/wxpython/iclass/dialogs.py:555
-msgid "Export attribute table containing computed statistical data"
+#: ../gui/wxpython/animation/dialogs.py:1536
+msgid ""
+"Click and then press key up or down to preview different date and time "
+"formats. Type custom format string."
 msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:593
-#, python-format
-msgid "Vector map <%s> already exists. Do you want to overwrite it?"
+#: ../gui/wxpython/animation/dialogs.py:1545
+msgid "Learn more about formatting options"
 msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:595
-#, python-format
-msgid "Vector <%s> exists"
+#: ../gui/wxpython/animation/dialogs.py:1554
+msgid "Display instances with no data"
 msgstr ""
-#: ../gui/wxpython/iclass/frame.py:39
-#, python-format
+#: ../gui/wxpython/animation/dialogs.py:1555
 msgid ""
-"Loading imagery lib failed.\n"
-"%s"
+"When animating instant-based data which have irregular timestamps you can "
+"display 'no data frame' (checked option) or keep last frame."
 msgstr ""
-#: ../gui/wxpython/iclass/frame.py:72
-msgid "Supervised Classification Tool"
-msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1577
+#, fuzzy
+msgid "Invalid"
+msgstr "Nederīgs:"
-#: ../gui/wxpython/iclass/frame.py:259
-msgid "IClass Toolbar"
+#: ../gui/wxpython/animation/utils.py:156
+msgid "The number of maps in space-time datasets has to be the same."
 msgstr ""
-#: ../gui/wxpython/iclass/frame.py:271
-msgid "IClass Misc Toolbar"
+#: ../gui/wxpython/animation/utils.py:160
+msgid ""
+"The temporal type (absolute/relative) of space-time datasets has to be the "
+"same."
 msgstr ""
-#: ../gui/wxpython/iclass/frame.py:287
-msgid "Digitization Toolbar"
+#: ../gui/wxpython/animation/utils.py:164
+msgid ""
+"The map type (point/interval) of space-time datasets has to be the same."
 msgstr ""
-#: ../gui/wxpython/iclass/frame.py:308
-msgid "Plots"
+#: ../gui/wxpython/animation/utils.py:168
+msgid ""
+"The temporal extents of maps in space-time datasets have to be the same."
 msgstr ""
-#: ../gui/wxpython/iclass/frame.py:328
-msgid "Preview Display"
+#: ../gui/wxpython/animation/utils.py:176
+msgid "The number of maps to animate has to be the same for each map series."
 msgstr ""
-#: ../gui/wxpython/iclass/frame.py:331
-msgid "Training Areas Display"
+#: ../gui/wxpython/animation/utils.py:180
+msgid ""
+"The number of maps to animate has to be the same as the number of maps in "
+"temporal dataset."
 msgstr ""
-#: ../gui/wxpython/iclass/frame.py:379
-msgid "Adjust Training Area Display to Preview Display"
-msgstr ""
+#: ../gui/wxpython/animation/frame.py:157
+#, fuzzy
+msgid "Animation Toolbar"
+msgstr "Animācija"
-#: ../gui/wxpython/iclass/frame.py:383
-msgid "Adjust Preview display to Training Area Display"
-msgstr ""
+#: ../gui/wxpython/animation/frame.py:264
+#, fuzzy
+msgid "Loading data"
+msgstr "Datu ielāde..."
-#: ../gui/wxpython/iclass/frame.py:433
-msgid "All changes will be lost. Do you want to continue?"
+#: ../gui/wxpython/animation/frame.py:273
+msgid " ({} out of {})"
 msgstr ""
-#: ../gui/wxpython/iclass/frame.py:441
-msgid "Import vector map"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:463
+#: ../gui/wxpython/animation/frame.py:570
+#: ../gui/wxpython/animation/controller.py:523
 #, python-format
-msgid "No areas in vector map <%s>.\n"
+msgid "%(from)s %(dash)s %(to)s"
 msgstr ""
-#: ../gui/wxpython/iclass/frame.py:465
+#: ../gui/wxpython/animation/frame.py:573
 #, python-format
-msgid "Vector map <%s> contains points or lines, these features are ignored."
+msgid "to %(to)s"
 msgstr ""
-#: ../gui/wxpython/iclass/frame.py:593
-msgid "No training areas to export."
+#: ../gui/wxpython/animation/data.py:64
+msgid "No animation name selected."
 msgstr ""
-#: ../gui/wxpython/iclass/frame.py:648
-#, python-format
-msgid ""
-"Failed to add attribute table. Details:\n"
-"%s"
-msgstr ""
+#: ../gui/wxpython/animation/data.py:130
+#, fuzzy
+msgid "No workspace file selected."
+msgstr "Aizvērt darbtelpas failu"
-#: ../gui/wxpython/iclass/frame.py:787
-msgid "Failed to create temporary vector map."
-msgstr ""
+#: ../gui/wxpython/animation/data.py:133
+msgid "File %s not found"
+msgstr "Fails <%s> nav atrasts"
-#: ../gui/wxpython/iclass/frame.py:857
+#: ../gui/wxpython/animation/data.py:142
+msgid "Animation %d"
+msgstr "Animācija"
+#: ../gui/wxpython/animation/controller.py:219
 #, python-format
-msgid "No area in category %s. Category skipped."
+msgid "Maximum number of animations is %s."
 msgstr ""
-#: ../gui/wxpython/iclass/frame.py:860
-msgid "Analysis failed."
+#: ../gui/wxpython/animation/controller.py:396
+msgid "Failed to display legend."
 msgstr ""
-#: ../gui/wxpython/iclass/frame.py:869
-msgid "No imagery group selected."
+#: ../gui/wxpython/animation/controller.py:427
+msgid "Inconsistent number of maps, please check input data."
 msgstr ""
-#: ../gui/wxpython/iclass/frame.py:874
-msgid ""
-"Due to recent changes in classes, signatures can be outdated and should be "
-"recalculated. Do you still want to continue?"
+#: ../gui/wxpython/animation/controller.py:450
+msgid "No animation to export."
 msgstr ""
-#: ../gui/wxpython/iclass/frame.py:877
-msgid "Outdated signatures"
+#: ../gui/wxpython/animation/controller.py:484
+msgid "Preparing export, please wait..."
 msgstr ""
-#: ../gui/wxpython/iclass/frame.py:890
+#: ../gui/wxpython/animation/controller.py:529
 #, python-format
-msgid ""
-"A signature file named %s already exists.\n"
-"Do you want to replace it?"
+msgid "%(start)s %(unit)s"
 msgstr ""
-#: ../gui/wxpython/iclass/frame.py:938
-msgid "No imagery group selected. Operation canceled."
+#: ../gui/wxpython/animation/controller.py:544
+msgid "Exporting animation, please wait..."
 msgstr ""
-#: ../gui/wxpython/iclass/frame.py:947
-#, python-format
-msgid ""
-"Group <%(group)s> does not have enough files (it has %(files)d files). "
-"Operation canceled."
+#: ../gui/wxpython/rlisetup/wizard.py:57
+msgid "Create new configuration file for r.li modules"
 msgstr ""
-#: ../gui/wxpython/iclass/frame.py:956
-msgid "No areas given. Operation canceled."
+#: ../gui/wxpython/rlisetup/wizard.py:96
+#, python-format
+msgid "Do you want to create r.li configuration file <%s>?"
 msgstr ""
-#: ../gui/wxpython/iclass/frame.py:971
-msgid "Vector features are outside raster layers. Operation canceled."
-msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:98
+#, fuzzy
+msgid "Create new r.li configuration file?"
+msgstr "Izveidot jaunu novietojumu?"
-#: ../gui/wxpython/iclass/frame.py:1162
-msgid "results"
+#: ../gui/wxpython/rlisetup/wizard.py:111
+msgid "r.li.setup wizard canceled. Configuration file not created."
 msgstr ""
-#: ../gui/wxpython/iclass/statistics.py:27
-msgid "Loading imagery lib failed"
+#: ../gui/wxpython/rlisetup/wizard.py:295
+msgid "Select maps and define name"
 msgstr ""
-#: ../gui/wxpython/iclass/digit.py:50
-msgid ""
-"In order to create a training area, you have to select class first.\n"
-"\n"
-"There is no class yet, do you want to create one?"
-msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:306
+#, fuzzy
+msgid "Name for new configuration file to create"
+msgstr "Jaunveidojamās rastra kartes nosaukums"
-#: ../gui/wxpython/iclass/digit.py:54
-msgid "No class selected"
+#: ../gui/wxpython/rlisetup/wizard.py:318
+msgid "Raster map to use to select areas"
 msgstr ""
-#: ../gui/wxpython/iclass/plots.py:51
-msgid "Histograms"
+#: ../gui/wxpython/rlisetup/wizard.py:328
+msgid "Vector map to use to select areas"
 msgstr ""
-#: ../gui/wxpython/iclass/plots.py:52
-msgid "Coincident plots"
+#: ../gui/wxpython/rlisetup/wizard.py:340
+msgid "Define sampling  region (region for analysis)"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:33
-#, python-format
-msgid "Unknown iconset '%s', using default 'grass'...\n"
+#: ../gui/wxpython/rlisetup/wizard.py:342
+#: ../gui/wxpython/rlisetup/wizard.py:600
+#, fuzzy
+msgid "Whole map layer"
+msgstr "Kartes slāņi"
+#: ../gui/wxpython/rlisetup/wizard.py:343
+#, fuzzy
+msgid "Keyboard setting"
+msgstr "Vektoru iestatījumi"
+#: ../gui/wxpython/rlisetup/wizard.py:344
+msgid "Draw the sampling frame"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:50
+#: ../gui/wxpython/rlisetup/wizard.py:382
 #, python-format
-msgid "Unable to load icon theme. Reason: %s. Quiting wxGUI..."
+msgid "The configuration file %s already exists, please change name"
 msgstr ""
-#: ../gui/wxpython/modules/extensions.py:58
-msgid "Fetch full info including description and keywords"
-msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:437
+#, fuzzy
+msgid "Insert sampling frame parameter"
+msgstr "Ievietot eksistējošu 3D rastra karti"
-#: ../gui/wxpython/modules/extensions.py:388
-msgid "Uninstall GRASS Addons extensions"
+#: ../gui/wxpython/rlisetup/wizard.py:448
+msgid "Column of upper left corner"
 msgstr ""
-#: ../gui/wxpython/modules/extensions.py:397
-msgid "List of installed extensions"
+#: ../gui/wxpython/rlisetup/wizard.py:461
+msgid "Row of upper left corner"
 msgstr ""
-#: ../gui/wxpython/modules/extensions.py:403
-msgid "&Uninstall"
+#: ../gui/wxpython/rlisetup/wizard.py:474
+#: ../gui/wxpython/rlisetup/wizard.py:486
+msgid "Row lenght of sampling frame"
 msgstr ""
-#: ../gui/wxpython/modules/extensions.py:404
-msgid "Uninstall selected AddOns extensions"
+#: ../gui/wxpython/rlisetup/wizard.py:547
+#: ../gui/wxpython/rlisetup/sampling_frame.py:144
+msgid "Draw sampling frame"
 msgstr ""
-#: ../gui/wxpython/modules/extensions.py:451
-msgid "No extension selected for removal. Operation canceled."
-msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:594
+#, fuzzy
+msgid "Insert sampling areas"
-#: ../gui/wxpython/modules/extensions.py:460
-#, python-format
+#: ../gui/wxpython/rlisetup/wizard.py:601
+#, fuzzy
+msgid "Regions"
+msgstr "Reģions"
+#: ../gui/wxpython/rlisetup/wizard.py:602
+#, fuzzy
+msgid "Sample units"
+msgstr "Paraugs: %s"
+#: ../gui/wxpython/rlisetup/wizard.py:604
 msgid ""
-"List of files to be removed:\n"
-"%(files)s\n"
-"\n"
-"Do you want really to remove <%(ext)s> extension?"
+"Select areas from the\n"
+"overlayed vector map"
 msgstr ""
-#: ../gui/wxpython/modules/extensions.py:463
-msgid "Remove extension"
+#: ../gui/wxpython/rlisetup/wizard.py:609
+#: ../gui/wxpython/rlisetup/wizard.py:622
+msgid "This option is not supported yet"
 msgstr ""
-#: ../gui/wxpython/modules/extensions.py:488
-msgid "Extension"
-msgstr "Paplašinājums"
+#: ../gui/wxpython/rlisetup/wizard.py:616
+#, fuzzy
+msgid "Choose a method"
+msgstr "Izvēlieties ĢIS datu mapi"
-#: ../gui/wxpython/modules/vclean.py:456
-msgid "Name of input vector map"
+#: ../gui/wxpython/rlisetup/wizard.py:617
+msgid "Use keyboard to enter sampling area"
 msgstr ""
-#: ../gui/wxpython/modules/vclean.py:457
-msgid "Name for output vector map"
+#: ../gui/wxpython/rlisetup/wizard.py:618
+msgid "Use mouse to draw sampling area"
 msgstr ""
-#: ../gui/wxpython/modules/vclean.py:458
-msgid "Tools"
-msgstr "Rīki"
-#: ../gui/wxpython/modules/vclean.py:459
-msgid "Threshold"
+#: ../gui/wxpython/rlisetup/wizard.py:674
+msgid "Function not supported yet"
 msgstr ""
-#: ../gui/wxpython/modules/vclean.py:461
-#, python-format
-msgid "'%s' not defined"
+#: ../gui/wxpython/rlisetup/wizard.py:719
+#: ../gui/wxpython/rlisetup/wizard.py:867
+msgid "Select type of shape"
 msgstr ""
-#: ../gui/wxpython/modules/vclean.py:463
-#, python-format
-msgid ""
-"Some parameters not defined. Operation canceled.\n"
-"\n"
-"%s"
+#: ../gui/wxpython/rlisetup/wizard.py:720
+#: ../gui/wxpython/rlisetup/wizard.py:868
+msgid "Circle"
 msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1175
-#, python-format
-msgid ""
-"Selected map <%(map)s> is not in current mapset <%(mapset)s>. Attribute "
-"table cannot be edited."
+#: ../gui/wxpython/rlisetup/wizard.py:741
+#: ../gui/wxpython/rlisetup/wizard.py:892
+msgid "Width size (in cells)? "
 msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1646
-msgid "No color column defined. Operation canceled."
+#: ../gui/wxpython/rlisetup/wizard.py:742
+#: ../gui/wxpython/rlisetup/wizard.py:893
+msgid "What radius size (in meters)? "
 msgstr ""
-#: ../gui/wxpython/modules/histogram.py:266
-msgid "GRASS GIS Histogramming Tool (d.histogram)"
+#: ../gui/wxpython/rlisetup/wizard.py:743
+#: ../gui/wxpython/rlisetup/wizard.py:894
+msgid "Height size (in cells)? "
 msgstr ""
-#: ../gui/wxpython/wxplot/scatter.py:148 ../gui/wxpython/wxplot/scatter.py:152
-#, python-format
-msgid ": %s"
-msgstr ": %s"
+#: ../gui/wxpython/rlisetup/wizard.py:744
+#: ../gui/wxpython/rlisetup/wizard.py:895
+#, fuzzy
+msgid "Name of the circle mask"
+msgstr "Rastra kartes nosaukums:"
-#: ../gui/wxpython/wxplot/scatter.py:256
-#, python-format
-msgid ""
-"Regression equation for raster map <%(rast1)s> vs. <%(rast2)s>:\n"
-"\n"
+#: ../gui/wxpython/rlisetup/wizard.py:750
+msgid "Select method of sampling unit distribution"
 msgstr ""
-#: ../gui/wxpython/wxplot/base.py:35
-msgid "Draw/re-draw plot"
+#: ../gui/wxpython/rlisetup/wizard.py:751
+msgid "Random non overlapping"
 msgstr ""
-#: ../gui/wxpython/wxplot/base.py:37
-msgid "Draw transect in map display window to profile"
+#: ../gui/wxpython/rlisetup/wizard.py:752
+msgid "Systematic contiguos"
 msgstr ""
-#: ../gui/wxpython/wxplot/base.py:39
-msgid "Plot options"
+#: ../gui/wxpython/rlisetup/wizard.py:753
+msgid "Stratified random"
 msgstr ""
-#: ../gui/wxpython/wxplot/base.py:41
-msgid "Plot statistics"
+#: ../gui/wxpython/rlisetup/wizard.py:754
+msgid "Systematic non contiguos"
 msgstr ""
-#: ../gui/wxpython/wxplot/base.py:43
-msgid "Save profile data to CSV file"
+#: ../gui/wxpython/rlisetup/wizard.py:755
+msgid "Centered over sites"
 msgstr ""
-#: ../gui/wxpython/wxplot/base.py:44
-msgid "Quit plot tool"
+#: ../gui/wxpython/rlisetup/wizard.py:762
+#: ../gui/wxpython/rlisetup/wizard.py:807
+msgid "What number of Sampling Units to use?"
 msgstr ""
-#: ../gui/wxpython/wxplot/base.py:399
-msgid "Left Mouse Down at Point:"
+#: ../gui/wxpython/rlisetup/wizard.py:821
+msgid "Insert number of row strates"
 msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:144
-msgid "Not all points of profile lie inside computational region."
+#: ../gui/wxpython/rlisetup/wizard.py:822
+msgid "Insert number of column strates"
 msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:476
-msgid "Selected group must be in current mapset"
+#: ../gui/wxpython/rlisetup/wizard.py:828
+msgid "Insert distance between units"
 msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:219
-#, python-format
-msgid "Statistics for raster map <%s>"
+#: ../gui/wxpython/rlisetup/wizard.py:878
+msgid "Width size (in cells) ?"
 msgstr ""
-#: ../gui/wxpython/core/render.py:1204 ../gui/wxpython/core/render.py:1243
-#, python-format
-msgid "Unable to render overlay <%s>."
+#: ../gui/wxpython/rlisetup/wizard.py:885
+msgid "Height size (in cells) ?"
 msgstr ""
-#: ../gui/wxpython/core/gcmd.py:74
-#, python-format
-msgid "ERROR: %s\n"
-msgstr "KĻŪDA: %s\n"
-#: ../gui/wxpython/core/settings.py:822
-msgid "Zoom and recenter"
+#: ../gui/wxpython/rlisetup/wizard.py:932
+msgid "Configuration file name:"
 msgstr ""
-#: ../gui/wxpython/core/settings.py:823
-msgid "Zoom to mouse cursor"
-msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:942
+#, fuzzy
+msgid "Raster name:"
+msgstr "Rastrs:"
-#: ../gui/wxpython/core/settings.py:824
-msgid "Nothing"
-msgstr "Nekas"
+#: ../gui/wxpython/rlisetup/wizard.py:952
+#, fuzzy
+msgid "Vector name:"
+msgstr "Vektori:"
-#: ../gui/wxpython/core/settings.py:825
-msgid "Scroll forward to zoom in"
-msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:962
+#, fuzzy
+msgid "Region type:"
+msgstr "Reģions:"
-#: ../gui/wxpython/core/settings.py:826
-msgid "Scroll back to zoom in"
+#: ../gui/wxpython/rlisetup/wizard.py:982
+msgid "Sampling area type:"
 msgstr ""
-#: ../gui/wxpython/mapdisp/gprint.py:152
-msgid ""
-"There was a problem printing.\n"
-"Perhaps your current printer is not set correctly?"
+#: ../gui/wxpython/rlisetup/wizard.py:1048
+msgid "Region keybord values:"
 msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:28
-msgid "Query raster/vector map(s)"
-msgstr "Vaicājums rastra/vektoru kartei"
+#: ../gui/wxpython/rlisetup/wizard.py:1061
+#: ../gui/wxpython/rlisetup/wizard.py:1085
+#, fuzzy
+msgid "Type of shape:"
+msgstr "Leģendas tips"
-#: ../gui/wxpython/mapdisp/toolbars.py:29
-msgid "Query selected raster/vector map(s)"
-msgstr "Vaicājums izvēlētajai rastra/vektoru kartei"
+#: ../gui/wxpython/rlisetup/wizard.py:1064
+#: ../gui/wxpython/rlisetup/wizard.py:1088
+msgid "Radius size:"
+msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:31
-msgid "Add scalebar and north arrow"
-msgstr "Pievienot mērogjoslu un ziemeļu bultu"
+#: ../gui/wxpython/rlisetup/wizard.py:1065
+#: ../gui/wxpython/rlisetup/wizard.py:1089
+#, fuzzy
+msgid "Name circle mask:"
+msgstr "Karšu kopas nosaukums:"
-#: ../gui/wxpython/mapdisp/toolbars.py:33
-msgid "Add legend"
-msgstr "Pievienot leģendu"
+#: ../gui/wxpython/rlisetup/wizard.py:1067
+#: ../gui/wxpython/rlisetup/wizard.py:1091
+#, fuzzy
+msgid "Width size:"
+msgstr "Platums:"
-#: ../gui/wxpython/mapdisp/toolbars.py:37
-msgid "Analyze map"
-msgstr "Analizēt karti"
+#: ../gui/wxpython/rlisetup/wizard.py:1068
+#: ../gui/wxpython/rlisetup/wizard.py:1092
+#, fuzzy
+msgid "Heigth size:"
+msgstr "Fonta izmērs:"
-#: ../gui/wxpython/mapdisp/toolbars.py:38
-msgid "Measuring, profiling, histogramming, ..."
-msgstr "Mērīšana, profilēšana, histogrammu veidošana..."
+#: ../gui/wxpython/rlisetup/wizard.py:1071
+msgid "Method of distribution:"
+msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:40
-msgid "Measure distance"
-msgstr "Mērīt attālumu"
+#: ../gui/wxpython/rlisetup/wizard.py:1074
+msgid "Number sampling units:"
+msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:42
-msgid "Profile surface map"
-msgstr "Profilēt rastra karti"
+#: ../gui/wxpython/rlisetup/wizard.py:1077
+msgid "Distance between units:"
+msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:48
-msgid "Create histogram of raster map"
-msgstr "Izveidot rastra kartes histogrammu"
-#: ../gui/wxpython/mapdisp/toolbars.py:50
-msgid "Vector network analysis (experimental, GSoC 2012)"
+#: ../gui/wxpython/rlisetup/wizard.py:1080
+msgid "Number row strates:"
 msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:55
-msgid "Rotate 3D scene"
-msgstr "Rotēt 3D scēnu"
+#: ../gui/wxpython/rlisetup/wizard.py:1082
+#, fuzzy
+msgid "Number column strates:"
+msgstr "Skaitliska kolona:"
-#: ../gui/wxpython/mapdisp/toolbars.py:56
-msgid "Drag with mouse to rotate 3D scene"
+#: ../gui/wxpython/rlisetup/frame.py:20
+msgid "GRASS GIS Setup for r.li modules"
 msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:59
-msgid "Drag with mouse, hold Ctrl down for different mode or Shift to accelerate"
+#: ../gui/wxpython/rlisetup/frame.py:37
+msgid "Available sampling area configuration files"
 msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:61
-msgid "Click mouse to zoom"
+#: ../gui/wxpython/rlisetup/frame.py:46
+msgid "Remove a configuration file"
 msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:62
-msgid "Click mouse to unzoom"
-msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:49
+#, fuzzy
+msgid "Create a new configuration file"
-#: ../gui/wxpython/mapdisp/mapwindow.py:151
-msgid "Copy coordinates to clipboard"
-msgstr "Kopēt koordinātas uz starpliktuvi"
+#: ../gui/wxpython/rlisetup/frame.py:52
+#, fuzzy
+msgid "Rename a configuration file"
-#: ../gui/wxpython/mapdisp/mapwindow.py:684
-msgid "Unable to draw registered graphics. The graphics was unregistered."
+#: ../gui/wxpython/rlisetup/frame.py:135
+msgid "You have to select a configuration file"
 msgstr ""
-#: ../gui/wxpython/mapdisp/mapwindow.py:2032
-#: ../gui/wxpython/mapdisp/mapwindow.py:2140
+#: ../gui/wxpython/rlisetup/frame.py:138
 #, python-format
-msgid "Property does not exist: %s"
-msgstr "Īpašība %s neeksistē"
+msgid ""
+"Set te new name for %s \"                                            "
+"\"configuration file"
+msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:1335
-#, python-format
-msgid "wx.vnet not available, run '%s' to install this extension"
+#: ../gui/wxpython/rlisetup/frame.py:140
+#, fuzzy
+msgid "Rename configuration file"
+#: ../gui/wxpython/rlisetup/sampling_frame.py:145
+msgid "Draw sampling frame by clicking and dragging"
 msgstr ""
-#: ../gui/wxpython/gis_set.py:97
+#: ../gui/wxpython/gis_set.py:104
 msgid "Choose project location and mapset"
 msgstr "Izvēlieties projekta novietojumu un karšu kopu"
-#: ../gui/wxpython/gis_set.py:100
+#: ../gui/wxpython/gis_set.py:107
 msgid "Manage"
 msgstr "Pārvaldīt"
-#: ../gui/wxpython/gis_set.py:102
+#: ../gui/wxpython/gis_set.py:109
 #, python-format
 msgid ""
 "Welcome to GRASS GIS %s\n"
@@ -15143,7 +16028,7 @@
 "Laipni lūdzam GRASS GIS %s\n"
 "Pasaules vadošajā brīvajā ĢIS"
-#: ../gui/wxpython/gis_set.py:106
+#: ../gui/wxpython/gis_set.py:113
 msgid ""
 "Select an existing project location and mapset\n"
 "or define a new location"
@@ -15151,7 +16036,7 @@
 "Izvēlieties eksistējošu novietojumu un karšu kopu\n"
 "vai arī definējiet jaunu novietojumu"
-#: ../gui/wxpython/gis_set.py:112
+#: ../gui/wxpython/gis_set.py:130
 msgid ""
 "Project location\n"
 "(projection/coordinate system)"
@@ -15159,7 +16044,7 @@
 "Projekta novietojums\n"
 "(projekcija/koordinātu sistēma)"
-#: ../gui/wxpython/gis_set.py:115
+#: ../gui/wxpython/gis_set.py:133
 msgid ""
 "Accessible mapsets\n"
 "(directories of GIS files)"
@@ -15167,7 +16052,7 @@
 "Pieejamās karšu kopas\n"
 "(mapes ar ĢIS failiem)"
-#: ../gui/wxpython/gis_set.py:118
+#: ../gui/wxpython/gis_set.py:136
 msgid ""
 "Create new mapset\n"
 "in selected location"
@@ -15175,11 +16060,11 @@
 "Izveidot jaunu karšu kopu\n"
 "izvēlētajā novietojumā"
-#: ../gui/wxpython/gis_set.py:121
+#: ../gui/wxpython/gis_set.py:139
 msgid "Define new location"
 msgstr "Definēt jaunu novietojumu"
-#: ../gui/wxpython/gis_set.py:124
+#: ../gui/wxpython/gis_set.py:142
 msgid ""
 "Rename/delete selected\n"
 "mapset or location"
@@ -15187,68 +16072,114 @@
 "Pārsaukt vai dzēst izvēlēto\n"
 "novietojumu vai karšu kopu"
-#: ../gui/wxpython/gis_set.py:129
+#: ../gui/wxpython/gis_set.py:147
 msgid "Start &GRASS"
 msgstr "Startēt &GRASS"
-#: ../gui/wxpython/gis_set.py:135
+#: ../gui/wxpython/gis_set.py:153
 msgid "&Browse"
 msgstr "&Pārlūkot"
-#: ../gui/wxpython/gis_set.py:137
+#: ../gui/wxpython/gis_set.py:155
 msgid "&Create mapset"
 msgstr "Izveidot &karšu kopu"
-#: ../gui/wxpython/gis_set.py:139
+#: ../gui/wxpython/gis_set.py:157
 msgid "&Location wizard"
 msgstr "&Novietojuma vednis"
-#: ../gui/wxpython/gis_set.py:141
+#: ../gui/wxpython/gis_set.py:158
+msgid ""
+"Start location wizard. After location is created successfully, GRASS session "
+"is started."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:162
 msgid "Rename mapset"
 msgstr "Pārsaukt karšu kopu"
 msgid "Rename location"
-#: ../gui/wxpython/gis_set.py:142
+#: ../gui/wxpython/gis_set.py:163
 msgid "Delete mapset"
 msgstr "Dzēst karšu kopu"
 msgid "Delete location"
 msgstr "Dzēst novietojumu"
-#: ../gui/wxpython/gis_set.py:184
+#: ../gui/wxpython/gis_set.py:205
 msgid "Welcome to GRASS GIS"
 msgstr "Laipni lūdzam GRASS GIS"
-#: ../gui/wxpython/gis_set.py:192
+#: ../gui/wxpython/gis_set.py:213
 msgid "Enter GRASS session"
 msgstr "Sākt GRASS sesiju"
-#: ../gui/wxpython/gis_set.py:208 ../gui/wxpython/gis_set.py:551
+#: ../gui/wxpython/gis_set.py:229 ../gui/wxpython/gis_set.py:700
 msgid "Unable to set GRASS database. Check your locale settings."
-msgstr "Nav iespējams iestatīt GRASS datubāzi. Pārbaudiet lokāles iestatījumus."
+msgstr ""
+"Nav iespējams iestatīt GRASS datubāzi. Pārbaudiet lokāles iestatījumus."
-#: ../gui/wxpython/gis_set.py:226
-#, python-format
-msgid "ERROR: Location <%s> not found"
+#: ../gui/wxpython/gis_set.py:247
+msgid "ERROR: Location <%s> not found\n"
 msgstr "KĻŪDA: Novietojums <%s> nav atrasts"
-#: ../gui/wxpython/gis_set.py:238
-#, python-format
-msgid "ERROR: Mapset <%s> not found"
+#: ../gui/wxpython/gis_set.py:264
+msgid "ERROR: Mapset <%s> not found\n"
 msgstr "KĻŪDA: Karšu kopa <%s> nav atrasta"
-#: ../gui/wxpython/gis_set.py:420
+#: ../gui/wxpython/gis_set.py:408
+#, python-format
+msgid "Invalid line in GISRC file (%s):%s\n"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:422
+#, fuzzy
+msgid "Warning: "
+msgstr "Brīdinājums"
+#: ../gui/wxpython/gis_set.py:459
+#, python-format
 msgid ""
+"Do you want to import <%(name)s> to the newly created location? The "
+"location's default region will be set from this imported map."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:464
+#, fuzzy
+msgid "Import data?"
+#: ../gui/wxpython/gis_set.py:476
+#, fuzzy
+msgid "Do you want to create new mapset?"
+msgstr "Nav iespējams izveidot jaunu karšu kopu: %s"
+#: ../gui/wxpython/gis_set.py:529
+#, python-format
+msgid ""
+"Import of <%(name)s> failed.\n"
+"Reason: %(msg)s"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:532
+#, python-format
+msgid "Data file <%(name)s> imported successfully."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:567
+msgid ""
 "Mapset <PERMANENT> is required for valid GRASS location.\n"
 "\n"
 "This mapset cannot be renamed."
 msgstr ""
-#: ../gui/wxpython/gis_set.py:425 ../gui/wxpython/gis_set.py:460
+#: ../gui/wxpython/gis_set.py:572 ../gui/wxpython/gis_set.py:608
 #, python-format
 msgid ""
 "Current name: %s\n"
@@ -15259,11 +16190,11 @@
 "\n"
 "Jaunais nosaukums:"
-#: ../gui/wxpython/gis_set.py:426
+#: ../gui/wxpython/gis_set.py:573
 msgid "Rename selected mapset"
 msgstr "Pārsaukt izvēlēto karšu kopu"
-#: ../gui/wxpython/gis_set.py:437
+#: ../gui/wxpython/gis_set.py:585
 #, python-format
 msgid ""
 "Unable to rename mapset.\n"
@@ -15271,7 +16202,7 @@
 "Mapset <%s> already exists in location."
 msgstr ""
-#: ../gui/wxpython/gis_set.py:449
+#: ../gui/wxpython/gis_set.py:597
 #, python-format
 msgid ""
@@ -15279,11 +16210,11 @@
 "%s"
 msgstr ""
-#: ../gui/wxpython/gis_set.py:461
+#: ../gui/wxpython/gis_set.py:609
 msgid "Rename selected location"
 msgstr "Pārsaukt izvēlēto novietojumu"
-#: ../gui/wxpython/gis_set.py:472
+#: ../gui/wxpython/gis_set.py:621
 #, python-format
 msgid ""
 "Unable to rename location.\n"
@@ -15291,7 +16222,7 @@
 "Location <%s> already exists in GRASS database."
 msgstr ""
-#: ../gui/wxpython/gis_set.py:485
+#: ../gui/wxpython/gis_set.py:634
 #, python-format
 msgid ""
@@ -15299,14 +16230,14 @@
 "%s"
 msgstr ""
-#: ../gui/wxpython/gis_set.py:497
+#: ../gui/wxpython/gis_set.py:646
 msgid ""
 "\n"
 "This mapset cannot be deleted."
 msgstr ""
-#: ../gui/wxpython/gis_set.py:501
+#: ../gui/wxpython/gis_set.py:650
 #, python-format
 msgid ""
 "Do you want to continue with deleting mapset <%(mapset)s> from location <"
@@ -15315,15 +16246,15 @@
 "ALL MAPS included in this mapset will be PERMANENTLY DELETED!"
 msgstr ""
-#: ../gui/wxpython/gis_set.py:506
+#: ../gui/wxpython/gis_set.py:655
 msgid "Delete selected mapset"
 msgstr "Dzēst izvēlēto karšu kopu"
-#: ../gui/wxpython/gis_set.py:515
+#: ../gui/wxpython/gis_set.py:664
 msgid "Unable to delete mapset"
 msgstr "Nav iespējams dzēst karšu kopu"
-#: ../gui/wxpython/gis_set.py:526
+#: ../gui/wxpython/gis_set.py:675
 #, python-format
 msgid ""
 "Do you want to continue with deleting location <%s>?\n"
@@ -15331,20 +16262,30 @@
 "ALL MAPS included in this location will be PERMANENTLY DELETED!"
 msgstr ""
-#: ../gui/wxpython/gis_set.py:530
+#: ../gui/wxpython/gis_set.py:679
 msgid "Delete selected location"
 msgstr "Dzēst izvēlēto novietojumu"
-#: ../gui/wxpython/gis_set.py:541
+#: ../gui/wxpython/gis_set.py:690
 msgid "Unable to delete location"
 msgstr "Nav iespējams dzēst novietojumu"
-#: ../gui/wxpython/gis_set.py:700
+#: ../gui/wxpython/gis_set.py:711
+msgid "No GRASS location found in '%s'."
+msgstr "GRASS novietojuma nosaukums:"
+#: ../gui/wxpython/gis_set.py:818
 #, python-format
+msgid "Path '%s' doesn't exist."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:859
+#, python-format
 msgid "Mapset <%s> already exists."
 msgstr "Karšu kopa <%s> jau eksistē."
-#: ../gui/wxpython/gis_set.py:705
+#: ../gui/wxpython/gis_set.py:864
 #, python-format
 msgid ""
 "Mapset <%s> is reserved for direct read access to OGR layers. Please "
@@ -15353,16 +16294,16 @@
 "Are you really sure that you want to create this mapset?"
 msgstr ""
-#: ../gui/wxpython/gis_set.py:709
+#: ../gui/wxpython/gis_set.py:868
 msgid "Reserved mapset name"
 msgstr "Rezervēts karšu kopas nosaukums"
-#: ../gui/wxpython/gis_set.py:727
+#: ../gui/wxpython/gis_set.py:890
 #, python-format
 msgid "Unable to create new mapset: %s"
-#: ../gui/wxpython/gis_set.py:744
+#: ../gui/wxpython/gis_set.py:903
 #, python-format
 msgid ""
 "GRASS is already running in selected mapset <%(mapset)s>\n"
@@ -15374,11 +16315,11 @@
 "this operation) and continue?"
 msgstr ""
-#: ../gui/wxpython/gis_set.py:750 ../gui/wxpython/gis_set.py:762
+#: ../gui/wxpython/gis_set.py:909 ../gui/wxpython/gis_set.py:921
 msgid "Lock file found"
 msgstr ""
-#: ../gui/wxpython/gis_set.py:758
+#: ../gui/wxpython/gis_set.py:917
 msgid ""
 "ARE YOU REALLY SURE?\n"
 "\n"
@@ -15386,7 +16327,7 @@
 "your data. Have another look in the processor manager just to be sure..."
 msgstr ""
-#: ../gui/wxpython/gis_set.py:773
+#: ../gui/wxpython/gis_set.py:932
 #, python-format
 msgid ""
 "Unable to remove '%(lock)s'.\n"
@@ -15394,26 +16335,69 @@
 "Details: %(reason)s"
 msgstr ""
-#: ../gui/wxpython/gis_set.py:801
-msgid "GRASS Quickstart"
+#: ../gui/wxpython/gis_set.py:980
+#, python-format
+msgid ""
+"Name <%(name)s> is not a valid name for location or mapset. Please use only "
+"ASCII characters excluding %(chars)s and space."
 msgstr ""
-#: ../gui/wxpython/gis_set.py:874
+#: ../gui/wxpython/gis_set.py:1048
 msgid "Starting GRASS for the first time"
 msgstr ""
-#: ../gui/wxpython/gis_set.py:875
+#: ../gui/wxpython/gis_set.py:1049
 msgid ""
 "GRASS needs a directory in which to store its data. Create one now if you "
 "have not already done so. A popular choice is \"grassdata\", located in your "
 "home directory."
 msgstr ""
+#: ../gui/wxpython/vdigit/g.gui.vdigit.py:59
+#, fuzzy
+msgid "GRASS GIS Vector Digitizer"
+msgstr "GRASS GIS slāņu pārvaldnieks"
+#: ../gui/wxpython/vdigit/g.gui.vdigit.py:95
+msgid "Vector digitizer not available. %s"
+#: ../gui/wxpython/vdigit/g.gui.vdigit.py:100
+#, python-format
+msgid ""
+"Vector map <%s> not found in current mapset. New vector map can be created "
+"by providing '-c' flag."
+msgstr ""
+#: ../gui/wxpython/vdigit/g.gui.vdigit.py:103
+#, python-format
+msgid "New vector map <%s> created"
+msgstr ""
+#: ../gui/wxpython/vdigit/g.gui.vdigit.py:105
+msgid "Unable to create new vector map <%s>"
+#: ../gui/wxpython/vdigit/wxdigit.py:53
+msgid "Digitization Error"
+msgstr ""
 #: ../gui/wxpython/vdigit/wxdigit.py:58
+#, python-format
+msgid "Unable to open vector map <%s>."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:60 ../gui/wxpython/vdigit/toolbars.py:566
+msgid "No vector map open for editing."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:61
 msgid "Operation canceled."
 msgstr "Darbība ir atcelta."
-#: ../gui/wxpython/vdigit/wxdigit.py:65
+#: ../gui/wxpython/vdigit/wxdigit.py:68
 #, python-format
 msgid ""
 "Writing new feature failed. Operation canceled.\n"
@@ -15421,271 +16405,914 @@
 "Reason: %s"
 msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:74
+#: ../gui/wxpython/vdigit/wxdigit.py:77
 #, python-format
 msgid "Reading feature id %d failed. Operation canceled."
 msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:82
+#: ../gui/wxpython/vdigit/wxdigit.py:85
 #, python-format
 msgid "Database link %d not available. Operation canceled."
 msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:90
+#: ../gui/wxpython/vdigit/wxdigit.py:93
 #, python-format
 msgid "Unable to start database driver <%s>. Operation canceled."
 msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:98
+#: ../gui/wxpython/vdigit/wxdigit.py:101
 #, python-format
-msgid "Unable to open database <%(db)s> by driver <%(driver)s>. Operation canceled."
+msgid ""
+"Unable to open database <%(db)s> by driver <%(driver)s>. Operation canceled."
 msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:106
+#: ../gui/wxpython/vdigit/wxdigit.py:109
 #, python-format
 msgid "Unable to execute SQL query '%s'. Operation canceled."
 msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:114
+#: ../gui/wxpython/vdigit/wxdigit.py:117
 #, python-format
 msgid "Feature id %d is marked as dead. Operation canceled."
 msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:122
+#: ../gui/wxpython/vdigit/wxdigit.py:125
 #, python-format
 msgid "Unsupported feature type %d. Operation canceled."
 msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:92
+#: ../gui/wxpython/vdigit/wxdigit.py:452
+#, python-format
+msgid "Unknown feature type '%s'"
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:457
+msgid "Not enough points for line"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:95
+msgid "Select area/boundary/centroid tool"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:121
 msgid "Digitize new point"
 msgstr "Digitizēt jaunu punktu"
-#: ../gui/wxpython/vdigit/toolbars.py:93
-#: ../gui/wxpython/vdigit/toolbars.py:102
-#: ../gui/wxpython/vdigit/toolbars.py:105
+#: ../gui/wxpython/vdigit/toolbars.py:122
+#: ../gui/wxpython/vdigit/toolbars.py:131
+#: ../gui/wxpython/vdigit/toolbars.py:134
 msgid "Left: new point"
 msgstr "Kreisais: jauns punkts"
-#: ../gui/wxpython/vdigit/toolbars.py:95
+#: ../gui/wxpython/vdigit/toolbars.py:124
 msgid "Digitize new line"
 msgstr "Digitizēt jaunu līniju"
-#: ../gui/wxpython/vdigit/toolbars.py:96 ../gui/wxpython/vdigit/toolbars.py:99
-#: ../gui/wxpython/vdigit/toolbars.py:123
+#: ../gui/wxpython/vdigit/toolbars.py:125
+#: ../gui/wxpython/vdigit/toolbars.py:128
+#: ../gui/wxpython/vdigit/toolbars.py:152
 msgid "Left: new point; Ctrl+Left: undo last point; Right: close line"
 msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:98
+#: ../gui/wxpython/vdigit/toolbars.py:127
 msgid "Digitize new boundary"
 msgstr "Digitizēt jaunu robežu"
-#: ../gui/wxpython/vdigit/toolbars.py:101
+#: ../gui/wxpython/vdigit/toolbars.py:130
 msgid "Digitize new centroid"
 msgstr "Digitizēt jaunu centroīdu"
-#: ../gui/wxpython/vdigit/toolbars.py:104
-msgid ""
-"Digitize new area (composition of boundaries without category and one "
-"centroid with category)"
+#: ../gui/wxpython/vdigit/toolbars.py:133
+#, fuzzy
+msgid "Digitize new area (boundary without category)"
+msgstr "Digitizēt jaunu robežu"
+#: ../gui/wxpython/vdigit/toolbars.py:136
+msgid "Add new vertex to line or boundary"
 msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:107
-msgid "Add new vertex"
-msgstr "Pievienot virsotni"
-#: ../gui/wxpython/vdigit/toolbars.py:108
-#: ../gui/wxpython/vdigit/toolbars.py:111
-#: ../gui/wxpython/vdigit/toolbars.py:114
-#: ../gui/wxpython/vdigit/toolbars.py:126
-#: ../gui/wxpython/vdigit/toolbars.py:129
-#: ../gui/wxpython/vdigit/toolbars.py:132
-#: ../gui/wxpython/vdigit/toolbars.py:141
+#: ../gui/wxpython/vdigit/toolbars.py:137
+#: ../gui/wxpython/vdigit/toolbars.py:140
+#: ../gui/wxpython/vdigit/toolbars.py:143
+#: ../gui/wxpython/vdigit/toolbars.py:155
+#: ../gui/wxpython/vdigit/toolbars.py:158
+#: ../gui/wxpython/vdigit/toolbars.py:161
+#: ../gui/wxpython/vdigit/toolbars.py:170
 msgid "Left: Select; Ctrl+Left: Unselect; Right: Confirm"
 msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:110
-msgid "Delete feature(s)"
-msgstr "Dzēst objektu"
+#: ../gui/wxpython/vdigit/toolbars.py:139
+msgid "Delete selected point(s), line(s), boundary(ies) or centroid(s)"
+msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:113
-msgid "Delete area(s)"
-msgstr "Dzēst laukumu"
+#: ../gui/wxpython/vdigit/toolbars.py:142
+#, fuzzy
+msgid "Delete selected area(s)"
+msgstr "Dzēst izvēlēto karšu kopu"
-#: ../gui/wxpython/vdigit/toolbars.py:116
+#: ../gui/wxpython/vdigit/toolbars.py:145
 msgid "Display/update attributes"
 msgstr "Attēlot/atjaunināt atribūtus"
-#: ../gui/wxpython/vdigit/toolbars.py:117
-#: ../gui/wxpython/vdigit/toolbars.py:120
+#: ../gui/wxpython/vdigit/toolbars.py:146
+#: ../gui/wxpython/vdigit/toolbars.py:149
 msgid "Left: Select"
 msgstr "Kreisais: izvēlēties"
-#: ../gui/wxpython/vdigit/toolbars.py:119
+#: ../gui/wxpython/vdigit/toolbars.py:148
 msgid "Display/update categories"
 msgstr "Attēlot/atjaunināt kategorijas"
-#: ../gui/wxpython/vdigit/toolbars.py:122
-msgid "Edit line/boundary"
+#: ../gui/wxpython/vdigit/toolbars.py:151
+#, fuzzy
+msgid "Edit selected line/boundary"
 msgstr "Rediģēt līniju/robežu"
-#: ../gui/wxpython/vdigit/toolbars.py:125
-msgid "Move feature(s)"
-msgstr "Pārvietot objektu"
+#: ../gui/wxpython/vdigit/toolbars.py:154
+msgid "Move selected point(s), line(s), boundary(ies) or centroid(s)"
+msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:128
-msgid "Move vertex"
+#: ../gui/wxpython/vdigit/toolbars.py:157
+#, fuzzy
+msgid "Move selected vertex"
 msgstr "Pārvietot virsotni"
-#: ../gui/wxpython/vdigit/toolbars.py:131
-msgid "Remove vertex"
+#: ../gui/wxpython/vdigit/toolbars.py:160
+#, fuzzy
+msgid "Remove selected vertex"
 msgstr "Dzēst virsotni"
-#: ../gui/wxpython/vdigit/toolbars.py:134
+#: ../gui/wxpython/vdigit/toolbars.py:162
+#: ../gui/wxpython/vdigit/preferences.py:31
+msgid "Digitization settings"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:163
 msgid "Quit digitizer"
 msgstr "Iziet no digitizētāja"
-#: ../gui/wxpython/vdigit/toolbars.py:135
+#: ../gui/wxpython/vdigit/toolbars.py:164
 msgid "Quit digitizer and save changes"
 msgstr "Iziet no digitizētāja un saglabāt izmaiņas"
-#: ../gui/wxpython/vdigit/toolbars.py:136
+#: ../gui/wxpython/vdigit/toolbars.py:165
 msgid "Vector Digitizer manual"
 msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:137
+#: ../gui/wxpython/vdigit/toolbars.py:166
 msgid "Show Vector Digitizer manual"
 msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:139
+#: ../gui/wxpython/vdigit/toolbars.py:168
 msgid "Additional tools (copy, flip, connect, etc.)"
 msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:143
+#: ../gui/wxpython/vdigit/toolbars.py:172
 msgid "Undo"
 msgstr "Atdarīt"
-#: ../gui/wxpython/vdigit/toolbars.py:144
+#: ../gui/wxpython/vdigit/toolbars.py:173
 msgid "Undo previous changes"
 msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:146
+#: ../gui/wxpython/vdigit/toolbars.py:175
 msgid "Redo"
 msgstr "Pārdarīt"
-#: ../gui/wxpython/vdigit/toolbars.py:147
+#: ../gui/wxpython/vdigit/toolbars.py:176
 msgid "Redo previous changes"
 msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:786
+#: ../gui/wxpython/vdigit/toolbars.py:522
+msgid "Break selected lines/boundaries at intersection"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:524
+msgid "Connect selected lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:526
+msgid "Copy categories"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:528
+msgid "Copy features from (background) vector map"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:530
+msgid "Copy attributes"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:532
+msgid "Feature type conversion"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:534
+msgid "Flip selected lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:536
+msgid "Merge selected lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:538
+msgid "Snap selected lines/boundaries (only to nodes)"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:540
+msgid "Split line/boundary"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:542
+msgid "Query features"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:544
+msgid "Z bulk-labeling of 3D lines"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:570
+#, fuzzy
+msgid "Select background vector map"
+msgstr "Izveidot jaunu vektordatu karti"
+#: ../gui/wxpython/vdigit/toolbars.py:727
+msgid "Vector map is not 3D. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:829
 #, python-format
-msgid "Unsupported feature type '%(type)s'. Unable to edit OGR layer <%(layer)s>."
+msgid ""
+"Topology for vector map <%s> is not available. Topology is required by "
+"digitizer.\n"
+"Do you want to rebuild topology (takes some time) and open the vector map "
+"for editing?"
 msgstr ""
-#: ../gui/wxpython/vdigit/mapwindow.py:513
+#: ../gui/wxpython/vdigit/toolbars.py:833
+#, fuzzy
+msgid "Digitizer error"
+msgstr "Digitizēt jaunu punktu"
+#: ../gui/wxpython/vdigit/toolbars.py:853
+#, python-format
+msgid "Please wait, opening vector map <%s> for editing..."
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:887
+#, python-format
+msgid ""
+"Unsupported feature type '%(type)s'. Unable to edit OGR layer <%(layer)s>."
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:948
+#, python-format
+msgid "Do you want to save changes in vector map <%s>?"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:950
+msgid "Save changes?"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:957
+#, python-format
+msgid "Please wait, closing and rebuilding topology of vector map <%s>..."
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:971
+#, python-format
+msgid "Editing of vector map <%s> successfully finished"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:1034
+#: ../gui/wxpython/vdigit/toolbars.py:1039
+msgid "New vector map"
+#: ../gui/wxpython/vdigit/mapwindow.py:410
+msgid "Update categories"
+msgstr ""
+#: ../gui/wxpython/vdigit/mapwindow.py:534
+#: ../gui/wxpython/vdigit/mapwindow.py:904
+msgid "No vector map selected for editing."
+msgstr ""
+#: ../gui/wxpython/vdigit/mapwindow.py:542
 msgid "Nothing to do. Choose appropriate tool from digitizer toolbar."
 msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:512
+#: ../gui/wxpython/vdigit/mapwindow.py:1040
+msgid "Z bulk-labeling dialog"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:57
+msgid "Apply changes for this session"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:60
+msgid "Close dialog and save changes to user settings file"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:152
+msgid "Snapping"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:158
+msgid "Snapping threshold"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:165
+msgid "screen pixels"
+msgstr ""
+msgid "map units"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:174
+msgid "Snap also to vertex"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:179
+#: ../gui/wxpython/vdigit/preferences.py:623
+#: ../gui/wxpython/vdigit/preferences.py:637
+#: ../gui/wxpython/vdigit/preferences.py:641
+#, python-format
+msgid "Snapping threshold is %(value).1f %(units)s"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:192
+msgid "Select vector features"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:209
+msgid "Select threshold"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:222
+msgid "Select only features inside of selection bounding box"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:224
+msgid ""
+"By default are selected all features overlapping selection bounding box "
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:227
+msgid "Check for duplicates"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:239
+#, fuzzy
+msgid "Digitize lines/boundaries"
+msgstr "Digitizēt jaunu līniju/robežu"
+#: ../gui/wxpython/vdigit/preferences.py:242
+msgid "Break lines at intersection"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:252
+#, fuzzy
+msgid "Digitize areas"
+msgstr "Digitizēt jaunu līniju"
+#: ../gui/wxpython/vdigit/preferences.py:255
+msgid "Close boundary (snap to the start node)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:265
+msgid "Save changes"
+msgstr "Saglabāt izmaiņas"
+#: ../gui/wxpython/vdigit/preferences.py:268
+msgid "Save changes on exit"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:280
+msgid "Query tool"
+msgstr "Vaicājumu rīks"
+#: ../gui/wxpython/vdigit/preferences.py:287
+msgid "Choose query tool"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:292
+msgid "Select by box"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:301
+#: ../gui/wxpython/vdigit/preferences.py:432
+msgid "length"
+msgstr "garums"
+#: ../gui/wxpython/vdigit/preferences.py:306
+msgid "Select lines"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:308
+#: ../gui/wxpython/vdigit/preferences.py:331
+msgid "shorter than"
+msgstr ""
+msgid "longer than"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:324
+msgid "dangle"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:329
+msgid "Select dangles"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:368
+msgid "Digitize new feature"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:373
+msgid "Add new record into table"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:379
+msgid "Mode"
+msgstr "Režīms"
+#: ../gui/wxpython/vdigit/preferences.py:401
+msgid "Next to use"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:389
+msgid "Category number"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:399
+msgid "Category mode"
+msgstr ""
+msgid "Manual entry"
+msgstr ""
+msgid "No category"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:414
+msgid "Delete existing feature(s)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:419
+msgid "Delete record from table"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:429
+msgid "Geometry attributes"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:434
+msgid "perimeter"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:503
+msgid ""
+"Note: These settings are stored in the workspace not in the vector digitizer "
+"preferences."
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:532
 msgid "Digitize new line segment"
 msgstr "Digitizēt jaunu līnijas segmentu"
-#: ../gui/wxpython/vdigit/preferences.py:513
+#: ../gui/wxpython/vdigit/preferences.py:533
 msgid "Digitize new line/boundary"
-#: ../gui/wxpython/vdigit/dialogs.py:236 ../gui/wxpython/vdigit/dialogs.py:455
+#: ../gui/wxpython/vdigit/preferences.py:534
+msgid "Highlight"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:535
+msgid "Highlight (duplicates)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:538
+msgid "Boundary (no area)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:539
+msgid "Boundary (one area)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:540
+msgid "Boundary (two areas)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:541
+msgid "Centroid (in area)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:542
+msgid "Centroid (outside area)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:543
+msgid "Centroid (duplicate in area)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:544
+msgid "Node (one line)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:545
+msgid "Node (two lines)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:546
+msgid "Vertex"
+msgstr "Virsotne"
+#: ../gui/wxpython/vdigit/preferences.py:547
+msgid "Area (closed boundary + centroid)"
+msgstr "Poligons (noslēgta robeža + centroīds)"
+#: ../gui/wxpython/vdigit/preferences.py:548
+msgid "Direction"
+msgstr "Virziens"
+#: ../gui/wxpython/vdigit/preferences.py:616
+msgid "Snapping disabled"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:618
 #, python-format
+msgid "Snapping threshold is %(value).1f %(units)s (based on comp. resolution)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:674
+#, python-format
+msgid "Vector digitizer settings saved to file <%s>."
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:76
+msgid "List of categories - right-click to delete"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:107
+msgid "Add new category"
+msgstr "Pievienot jaunu kategoriju"
+#: ../gui/wxpython/vdigit/dialogs.py:146
+msgid "Ignore changes and close dialog"
+msgstr "Ignorēt izmaiņas un aizvērt dialogu"
+#: ../gui/wxpython/vdigit/dialogs.py:238 ../gui/wxpython/vdigit/dialogs.py:457
+#, python-format
 msgid ""
 "Unable to add new layer/category <%(layer)s/%(category)s>.\n"
 "Layer and category number must be integer.\n"
 "Layer number must be greater than zero."
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:33
+#: ../gui/wxpython/vdigit/dialogs.py:434
+msgid "Unable to update vector map."
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:594
+#, python-format
+msgid "%d lines selected for z bulk-labeling"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:597
+msgid "Set value"
+msgstr "Iestatīt vērtību"
+#: ../gui/wxpython/vdigit/dialogs.py:604
+msgid "Starting value"
+msgstr "Sākotnējā vērtība"
+#: ../gui/wxpython/vdigit/dialogs.py:613
+msgid "Step"
+msgstr "Solis"
+#: ../gui/wxpython/vdigit/dialogs.py:643
+msgid "List of duplicates"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:739
+msgid "Feature id"
+msgstr "Objekta ID"
+#: ../gui/wxpython/vdigit/dialogs.py:740
+msgid "Layer (Categories)"
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdisplay.py:940
+#, python-format
+msgid ""
+"digitizer. Do you want to rebuild topology (takes some time) and open the "
+"vector map for editing?"
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdisplay.py:944
+msgid "Topology missing"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:38
+msgid "The Timeline Tool needs \"Matplotlib\" package to be installed."
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:73
+msgid "Timeline Tool"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:134
+msgid "3D plot of spatio-temporal extents"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:137
+msgid "3D plot of spatio-temporal extents (matplotlib >= 1.0.0)"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:142
+msgid "Select space time dataset(s):"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:165
+#, python-format
+msgid "Dataset <%s> not found in temporal database"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:177
+msgid ""
+"Datasets have different temporal type (absolute x relative), which is not "
+"allowed."
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:192
+msgid "Datasets have different time unit which is not allowed."
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:267
+#, python-format
+msgid "X [%s]"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:268
+#, python-format
+msgid "Y [%s]"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:270
+#, fuzzy
+msgid "X"
+msgstr "X:"
+#: ../gui/wxpython/timeline/frame.py:271
+#, fuzzy
+msgid "Y"
+msgstr "Y:"
+#: ../gui/wxpython/timeline/frame.py:328
+#, python-format
+msgid "Time [%s]"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:351 ../gui/wxpython/timeline/frame.py:442
+#, fuzzy
+msgid "Invalid input data"
+msgstr "Nederīga ievade"
+#: ../gui/wxpython/timeline/frame.py:415
+#, python-format
+msgid "Please specify the space time dataset <%s>."
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:416
+msgid "Ambiguous dataset name"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:494
+#, fuzzy, python-format
+msgid "Space time raster dataset: %s"
+#: ../gui/wxpython/timeline/frame.py:496
+#, python-format
+msgid "Space time vector dataset: %s"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:498
+msgid "Space time 3D raster dataset: %s"
+#: ../gui/wxpython/timeline/frame.py:500
+msgid "Mapset: %s"
+msgstr "Karšu kopa:"
+#: ../gui/wxpython/timeline/frame.py:501
+msgid "Map name: %s"
+#: ../gui/wxpython/timeline/frame.py:502
+#, python-format
+msgid "Start time: %s"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:503
+msgid "End time: %s"
+#: ../gui/wxpython/timeline/frame.py:506
+msgid "WARNING: invalid topology"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:508
+msgid ""
+"\n"
+"Press Del to dismiss."
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:31
 msgid "No GRASS-python library found."
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:65
+#: ../gui/wxpython/scripts/vkrige.py:66
 msgid "Input Data"
-#: ../gui/wxpython/scripts/vkrige.py:71
+#: ../gui/wxpython/scripts/vkrige.py:72
 msgid "Point dataset:"
 msgstr "Punktu datu kopa:"
-#: ../gui/wxpython/scripts/vkrige.py:83
+#: ../gui/wxpython/scripts/vkrige.py:84
 msgid "Numeric column:"
-#: ../gui/wxpython/scripts/vkrige.py:94
+#: ../gui/wxpython/scripts/vkrige.py:95
 msgid "Kriging"
 msgstr "Krīgings"
-#: ../gui/wxpython/scripts/vkrige.py:114
-msgid "Output"
-msgstr "Izvade"
-#: ../gui/wxpython/scripts/vkrige.py:118
+#: ../gui/wxpython/scripts/vkrige.py:120
 msgid "Name for the output raster map:"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:126
+#: ../gui/wxpython/scripts/vkrige.py:128
 msgid "Export variance map as well: "
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:267
+#: ../gui/wxpython/scripts/vkrige.py:280
 msgid "Kriging Module"
 msgstr "Krīginga modulis"
-#: ../gui/wxpython/scripts/vkrige.py:271
+#: ../gui/wxpython/scripts/vkrige.py:284
 msgid "Ready."
 msgstr "Gatavs."
-#: ../gui/wxpython/scripts/vkrige.py:295
+#: ../gui/wxpython/scripts/vkrige.py:308
 msgid "Variogram fitting"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:305
+#: ../gui/wxpython/scripts/vkrige.py:318
 msgid "Plot/refresh variogram"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:316
+#: ../gui/wxpython/scripts/vkrige.py:329
 msgid ":"
 msgstr ":"
-#: ../gui/wxpython/scripts/vkrige.py:341
+#: ../gui/wxpython/scripts/vkrige.py:354
 msgid "Kriging techniques"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:355
+#: ../gui/wxpython/scripts/vkrige.py:368
 msgid "Block size:"
 msgstr "Bloka izmērs:"
-#: ../gui/wxpython/scripts/vkrige.py:388
+#: ../gui/wxpython/scripts/vkrige.py:401
 msgid "Auto-fit variogram"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:412
+#: ../gui/wxpython/scripts/vkrige.py:425
 msgid "Model: "
 msgstr "Modelis: "
-#: ../gui/wxpython/scripts/vkrige.py:496
+#: ../gui/wxpython/scripts/vkrige.py:514
 msgid "Work in progress! No functionality provided."
 msgstr ""
-#: ../gui/wxpython/scripts/r.li.setup.py:141
-msgid "I m!"
-msgstr ""
+#~ msgid "WMS import"
+#~ msgstr "WMS importēšana"
-#: ../gui/wxpython/scripts/r.li.setup.py:357
-#, python-format
-msgid ""
-"Location <%(loc)s> will be created in GIS data directory <%(dir)s>.You will "
-"need to change the default GIS data directory in the GRASS startup screen."
-msgstr ""
+#, fuzzy
+#~ msgid "Executes any SQL statement."
+#~ msgstr "SQL izteikums"
-#: ../gui/wxpython/scripts/r.li.setup.py:547
-#: ../gui/wxpython/scripts/r.li.setup.py:571
-msgid "File not found."
-msgstr "Fails nav atrasts."
+#~ msgid "RGB"
+#~ msgstr "RGB"
+#~ msgid "HIS"
+#~ msgstr "HIS"
+#~ msgid "Comp. region"
+#~ msgstr "Aprēķinu reģions"
+#, fuzzy
+#~ msgid "Unable render overlay <%s>."
+#~ msgstr "Jauna vektoru karte"
+#~ msgid "Set size and position"
+#~ msgstr "Iestatīt izmēru un novietojumu"
+#~ msgid "Command dialog"
+#~ msgstr "Komandas dialogs"
+#~ msgid "properties"
+#~ msgstr "īpašības"
+#~ msgid "Attribute Table Manager"
+#~ msgstr "Atribūtu tabulas pārvaldnieks"
+#~ msgid "Manage columns"
+#~ msgstr "Pārvaldīt kolonas"
+#~ msgid "Highlighting"
+#~ msgstr "Izcelšana"
+#~ msgid "Apply SQL statement and close the dialog"
+#~ msgstr "Pielietot SQL izteikumu un aizvērt dialogu"
+#~ msgid "columns"
+#~ msgstr "kolonas"
+#~ msgid "values"
+#~ msgstr "vērtības"
+#~ msgid "description"
+#~ msgstr "apraksts"
+#~ msgid "command"
+#~ msgstr "komanda"
+#~ msgid "keywords"
+#~ msgstr "atslēgvārdi"
+#~ msgid "Menu tree"
+#~ msgstr "Izvēlnes koks"
+#, fuzzy
+#~ msgid "Place scalebar"
+#~ msgstr "Mērogjosla"
+#~ msgid "GRASS GIS Histogram of raster map"
+#~ msgstr "GRASS GIS rastra kartes histogramma"
+#~ msgid "deg"
+#~ msgstr "grādi"
+#, fuzzy
+#~ msgid "Scale and North arrow"
+#~ msgstr "Ziemeļu bulta"
+#, fuzzy
+#~ msgid "scale object"
+#, fuzzy
+#~ msgid "legend object"
+#~ msgstr "Leģenda"
+#~ msgid "&Protocol"
+#~ msgstr "&Protokols"
+#~ msgid "Python:"
+#~ msgstr "Python:"
+#~ msgid "wxPython:"
+#~ msgstr "wxPython:"
+#~ msgid "Language:"
+#~ msgstr "Valoda:"
+#~ msgid "ERROR: %s\n"
+#~ msgstr "KĻŪDA: %s\n"
+#~ msgid "Add scalebar and north arrow"
+#~ msgstr "Pievienot mērogjoslu un ziemeļu bultu"
+#~ msgid "Delete area(s)"
+#~ msgstr "Dzēst laukumu"
+#~ msgid "Move feature(s)"
+#~ msgstr "Pārvietot objektu"
+#~ msgid "File not found."
+#~ msgstr "Fails nav atrasts."
