[GRASS-SVN] r59174 - in grass/trunk: . locale
Mon Mar 3 01:31:50 PST 2014
Author: marisn
Date: 2014-03-03 01:31:49 -0800 (Mon, 03 Mar 2014)
New Revision: 59174
   grass/trunk/SUBMITTING
   grass/trunk/locale/README
Add a short notice and some examples on plural form handling in the source code with _n() macro
Modified: grass/trunk/SUBMITTING
--- grass/trunk/SUBMITTING	2014-03-03 07:34:50 UTC (rev 59173)
+++ grass/trunk/SUBMITTING	2014-03-03 09:31:49 UTC (rev 59174)
@@ -150,6 +150,11 @@
     example:
         /* GTC A name of a projection */
         G_message(_("State Plane"));
+    Any message with a noun in plural form has to pass _n() macro,
+    even if for the English language it is not required!
+        G_message(_n("One map", "%d maps", number), number);
     See locale/README for details.
Modified: grass/trunk/locale/README
--- grass/trunk/locale/README	2014-03-03 07:34:50 UTC (rev 59173)
+++ grass/trunk/locale/README	2014-03-03 09:31:49 UTC (rev 59174)
@@ -1,7 +1,11 @@
 HOWTO translate GRASS messages
-$Date$
+This file contains following sections:
+1. Instructions for programmers;
+2. A translation workflow overview;
+3. A detailed explanation of translation workflow, testing;
+4. Some notes and links
 [ Web page: http://grass.osgeo.org/devel/i18n.php ]
@@ -54,7 +58,40 @@
         /* GTC A comma separated keyword list.
            Should not contain spaces! */
         keywords = _("first,second,third");
+NOTE4:  Any string containing a number that requires a correct plural form of
+        a noun, has to pass trough ngettext function implemented in GRASS
+        as a _n() macro.
+        _n("Message in English for singular case", "Message in English for
+        plural case", number)
+Examples of messages with plural forms.
+Wrong:
+    G_message( _("%d map(s) from mapset <%s> removed"), n, ms);
+    G_message( n == 1 ? _("One file removed") : _("%d files removed"), n);
+    G_warning( _("%d %s without geometry skipped"), n,
+        n == 1 ? "feature" : "features");
+    G_message( _("%d maps selected"), n);
+    G_message( n == 1 ? _("Remove map") : _("Remove maps"));
+Correct:
+    G_message( _n("%d map from mapset <%s> removed",
+        "%d maps from mapset <%s> removed", n), n, ms);
+    /* Notice double use of number "n" - as an argument for
+    both functions - _n() and G_message() */
+    G_message( _n("One file removed", "%d files removed", n) n);
+    /* Both of forms of singular case "%d file" or "One file" are correct.
+    The choice between them is purely stylistic one. */
+    G_warning( _n("One feature without geometry skipped",
+        "%d features without geometry skipped", n), n);
+    G_message( _n("%d map selected", "%d maps selected", n), n);
+    /* Altough in English it is not necessary to provide a separate
+    text if "n" always is >1, in other languages is a difference if "n"
+    is i.e. 2-4, or n==10 etc. */
+    G_message( _n("Remove map", "Remove maps", n));
+    /* Number it self doesn't have to be used in the output text */
 All these messages strings will be then automatically
 extracted into the message files.
@@ -64,7 +101,14 @@
         fprintf (stdout,"\n");
   do not need a change as no translation is needed.
+A detailed example of adapting code for use in multiple languages
+can be found in gettext manual.
+How to prepare program source:
+http://www.gnu.org/software/gettext/manual/gettext.html#Sources
+More advanced tricks like resolving ambiguties and handling of plural forms:
+http://www.gnu.org/software/gettext/manual/gettext.html#Programmers
 GENERAL TRANSLATION PROCEDURE (no programming required)
