[GRASS-SVN] r59177 - grass-addons/grass7/imagery/i.histo.match
svn_grass at osgeo.org
Mon Mar 3 02:41:17 PST 2014
Author: lucadelu
Date: 2014-03-03 02:41:17 -0800 (Mon, 03 Mar 2014)
New Revision: 59177
grass-addons/grass7/imagery/i.histo.match/i.histo.match.html
grass-addons/grass7/imagery/i.histo.match/i.histo.match.py
i.histo.match: PEP8 cleaning, renamed option, added possibility to create mosaic, improved documentation
Modified: grass-addons/grass7/imagery/i.histo.match/i.histo.match.html
--- grass-addons/grass7/imagery/i.histo.match/i.histo.match.html 2014-03-03 09:43:14 UTC (rev 59176)
+++ grass-addons/grass7/imagery/i.histo.match/i.histo.match.html 2014-03-03 10:41:17 UTC (rev 59177)
@@ -8,6 +8,30 @@
with the target histogram in order to obtain the target CDF value closest to
the original value.
+<h2>EXAMPLE</h2>
+This example is based the <a
+href="http://grass.osgeo.org/download/sample-data">North Carolina GRASS sample
+data set</a>, [complete GRASS location].
+<div><pre class="code">
+# create the output with histogram matching
+i.histo.match input=lsat5_1987_10,lsat7_2000_10
+# set grey color to the new maps
+r.colors map=lsat5_1987_10.match color=grey
+r.colors map=lsat7_2000_10.match color=grey
+# visualize and compare the results
+</pre></div>
+<center>
+<h5>Original data:</h5>
+<img src="original.png" border="1"><br>
+<h5>Matched data:</h5>
+<img src="matched.png" border="1"><br>
+</center>
<h2>SEE ALSO</h2>
<em>
Modified: grass-addons/grass7/imagery/i.histo.match/i.histo.match.py
--- grass-addons/grass7/imagery/i.histo.match/i.histo.match.py 2014-03-03 09:43:14 UTC (rev 59176)
+++ grass-addons/grass7/imagery/i.histo.match/i.histo.match.py 2014-03-03 10:41:17 UTC (rev 59177)
@@ -27,11 +27,18 @@
#% description: Name of raster maps to analize
#% required: yes
#%end
-#%option G_OPT_R_OUTPUT
+#%option
+#% key: suffix
+#% type: string
+#% gisprompt: Suffix for output maps
#% description: Suffix for output maps
#% required: no
#% answer: match
#%end
+#%option G_OPT_R_OUTPUT
+#% description: Name for mosaic output map
+#% required: no
+#%end
#%option G_OPT_DB_DATABASE
#% required : no
#% answer: $GISDBASE/$LOCATION_NAME/$MAPSET/histo.db
@@ -46,18 +53,25 @@
#%end
-import sys, os, sqlite3
+import sys
+import os
+import sqlite3
import grass.script as grass
def main():
# split input images
- images = options['input'].split(',')
+ all_images = options['input']
+ images = all_images.split(',')
# number of images
n_images = len(images)
# database path
dbopt = options['database']
# output suffix
- suffix = options['output']
+ suffix = options['suffix']
+ # output mosaic map
+ mosaic = options['output']
+ output_names = []
# name for average table
table_ave = "t%s_average" % suffix
# increment of one the maximum value for a correct use of range function
@@ -66,7 +80,8 @@
if dbopt.find('$GISDBASE/$LOCATION_NAME/$MAPSET') == 0:
dbopt_split = dbopt.split('/')[-1]
env = grass.gisenv()
- path = os.path.join(env['GISDBASE'], env['LOCATION_NAME'], env['MAPSET'])
+ path = os.path.join(env['GISDBASE'], env['LOCATION_NAME'],
+ env['MAPSET'])
dbpath = os.path.join(path, dbopt_split)
else:
if os.access(os.path.dirname(dbopt), os.W_OK):
@@ -90,12 +105,13 @@
curs.execute(query_create)
# set the region on the raster
grass.use_temp_region()
- grass.run_command('g.region', rast = i)
+ grass.run_command('g.region', rast=i)
# calculate statistics
- stats_out = grass.pipe_command('r.stats', flags='cin', input= i, separator=':')
- stats = stats_out.communicate()[0].split('\n')[:-1]
- stats_dict = dict( s.split(':', 1) for s in stats)
- cdf = 0
+ stats_out = grass.pipe_command('r.stats', flags='cin', input=i,
+ separator=':')
+ stats = stats_out.communicate()[0].split('\n')[:-1]
+ stats_dict = dict(s.split(':', 1) for s in stats)
+ cdf = 0
# for each number in the range
for n in range(0, max_value):
# try to insert the values otherwise insert 0
@@ -124,7 +140,7 @@
if val != 0 and numPixel != 0:
update_cdf = round(float(val) / float(numPixel), 6)
update_cdf = "UPDATE \"t%s\" SET cdf=%s WHERE (grey_value=%i)" % (
- iname, update_cdf,n)
+ iname, update_cdf, n)
curs.execute(update_cdf)
db.commit()
db.commit()
@@ -136,12 +152,12 @@
for i in images:
iname = i.split('@')[0]
pixel_freq = "SELECT pixel_frequency FROM \"t%s\" WHERE (grey_value=%i)" % (
- iname, n)
+ iname, n)
result = curs.execute(pixel_freq)
val = result.fetchone()[0]
numPixel += val
# calculate number of pixel divide by number of images
- div = (int(numPixel/n_images))
+ div = (int(numPixel / n_images))
pixelTot += div
# drop average table
query_drop = "DROP TABLE if exists %s" % table_ave
@@ -164,12 +180,12 @@
tot += val
# calculate new value of pixel_frequency
- average = (tot/n_images)
+ average = (tot / n_images)
cHist = cHist + int(average)
# insert new values into average table
if cHist != 0 and pixelTot != 0:
cdf = float(cHist) / float(pixelTot)
- insert = "INSERT INTO %s VALUES (%i, %i, %i, %s)" % (table_ave, n,
+ insert = "INSERT INTO %s VALUES (%i, %i, %i, %s)" % (table_ave, n,
int(average), cHist, cdf)
curs.execute(insert)
db.commit()
@@ -177,7 +193,7 @@
for i in images:
# write average rules file
outfile = open(grass.tempfile(), 'w')
new_grey = 0
@@ -198,26 +214,28 @@
outfile.close()
outname = '%s.%s' % (iname, suffix)
# check if a output map already exists
- result = grass.core.find_file(outname, element = 'cell')
+ result = grass.core.find_file(outname, element='cell')
if result['fullname'] and grass.overwrite():
grass.run_command('g.remove', rast=outname)
- grass.run_command('r.reclass', input= i, out = outname,
- rules = outfile.name)
+ grass.run_command('r.reclass', input=i, out=outname,
+ rules=outfile.name)
elif result['fullname'] and not grass.overwrite():
grass.warning(_("Raster map %s already exists and will not be overwritten" % i))
else:
+ output_names.append(outname)
# remove the rules file
- grass.try_remove(outfile.name)
+ grass.try_remove(outfile.name)
# write cmd history:
grass.raster_history(outname)
db.commit()
db.close()
+ if mosaic:
+ grass.use_temp_region()
+ grass.run_command('g.region', rast=all_images)
+ grass.run_command('r.patch', input=output_names, output=mosaic)
if __name__ == "__main__":
options, flags = grass.parser()
sys.exit(main())
